  4. IoBroker.mpd
IoBroker.mpd
103 Beiträge 15 Kommentatoren 29.3k Aufrufe 5 Beobachtet
  • R Offline
    rascal
    Hey,
    ich habe einen Sayit-Adapter auf alle gestellt, funktioniert soweit sehr gut.
    Was mir nur aufgefallen ist: Wenn eine mpd-Instanz disabled/angehalten ist, dann Produziert er im Log error Messages, wäre toll wenn du die abfangen könntest.
    WARNING:	2017-01-12 11:23:02.114	error	cannot find message with id = 9075368
    WARNING:	2017-01-12 11:23:02.113	error	cannot find message with id = 9075368
    WARNING:	2017-01-12 11:23:02.111	error	cannot find message with id = 9075368
    WARNING:	2017-01-12 11:23:02.110	error	cannot find message with id = 9075368
    sayit.0	2017-01-12 11:23:02.090	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
    sayit.0	2017-01-12 11:23:01.947	info	saying: Das ist ein Test Nummer 2
    WARNING:	2017-01-12 11:23:00.972	error	cannot find message with id = 9075360
    WARNING:	2017-01-12 11:23:00.971	error	cannot find message with id = 9075360
    WARNING:	2017-01-12 11:23:00.968	error	cannot find message with id = 9075360
    WARNING:	2017-01-12 11:23:00.967	error	cannot find message with id = 9075360
    sayit.0	2017-01-12 11:23:00.944	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
    sayit.0	2017-01-12 11:23:00.942	info	saying: /opt/iobroker/node_modules/iobroker.sayit/scifi.mp3
    WARNING:	2017-01-12 11:21:56.364	error	cannot find message with id = 9075352
    WARNING:	2017-01-12 11:21:56.363	error	cannot find message with id = 9075352
    WARNING:	2017-01-12 11:21:56.362	error	cannot find message with id = 9075352
    WARNING:	2017-01-12 11:21:56.361	error	cannot find message with id = 9075352
    sayit.0	2017-01-12 11:21:56.333	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
    sayit.0	2017-01-12 11:21:56.090	info	saying: Das ist ein Test
    WARNING:	2017-01-12 11:21:55.145	error	cannot find message with id = 9075344
    WARNING:	2017-01-12 11:21:55.137	error	cannot find message with id = 9075344
    WARNING:	2017-01-12 11:21:55.134	error	cannot find message with id = 9075344
    WARNING:	2017-01-12 11:21:55.130	error	cannot find message with id = 9075344
    WARNING:	2017-01-12 11:21:55.114	error	cannot find message with id = 9075344
    WARNING:	2017-01-12 11:21:55.112	error	cannot find message with id = 9075344
    sayit.0	2017-01-12 11:21:55.087	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
    sayit.0	2017-01-12 11:21:55.083	info	saying: /opt/iobroker/node_modules/iobroker.sayit/scifi.mp3
    LG Martin
    • Alex1808A Offline
      Alex1808A Offline
      Alex1808
      @rascal:
      Hey,
      LG Martin `
      Das ist doch aber logisch.. error Messages kommen vom sayit. Dann muss auch sayit gestoppt werden oder ein andere player als MPD ausgewählt werden. ;)
      • R Offline
        rascal
        Irgendwie schon, nur ein bisschen störend, ich habe eine mpd-Instanz zum Testen und damit die meiste Zeit inaktiv.
        • Alex1808A Offline
          Alex1808A Offline
          Alex1808
          @rascal:
          Irgendwie schon, nur ein bisschen störend, ich habe eine mpd-Instanz zum Testen und damit die meiste Zeit inaktiv. `
          Dann welle doch bei sayit Wiedergabe über browser und gut is es :)
          • Alex1808A Offline
            Alex1808A Offline
            Alex1808
            Übrigens, wurde ein gestufte volume Reduzierung vor dem Ansage hinzugefügt. (Install vom Git)
            • R Offline
              rascal
              @Alex1808:
              Übrigens, wurde ein gestufte volume Reduzierung vor dem einsage hinzugefügt. (Inntal vom Git) `
              was meinst du damit? Welches volume wird reduziert und wie stark?
              • Alex1808A Offline
                Alex1808A Offline
                Alex1808
                @rascal:
                @Alex1808:
                was meinst du damit? Welches volume wird reduziert und wie stark? `
                Also z.b. wenn du am MPD gerade Musik abspielst und dann kommt eine Meldung/Ansage vom SayIt, früher wurde Musik Wiedergabe gestoppt, Lautstärke vom 80% (oder was vorher eingestellt wurde) stufenlos auf 0% gesetzt dann auf Lautstärke mit dem wert was die du mit Ansage schickst gesetzt z.b. auf 100%, dann kommt selbst die Ansage, und zum Schluss wird Lautstärke wieder auf 80% und Wiedergabe vom Musik ebenfalls wiederhergestellt.
                Jetzt ist praktisch das gleiche nur die Musik Wiedergabe nicht sofort gestoppt wird sondern wird leiser.
                • R Offline
                  rascal
                  Ah.. natürlich.. Denkfehler von mir. Coole Sache.
                  Mein Problem ist nur, dass ich Squeezebox verwende und die Lautstärke bei Squeezebox über ein Script ändern muss, wenn ich eine Ansage loslasse.
                  Aber coole Sache dass du das eingebaut hast.
                  • Alex1808A Offline
                    Alex1808A Offline
                    Alex1808
                    @rascal:
                    Aber coole Sache dass du das eingebaut hast. `
                    Nee, nicht ich, Adapter wird vom user "Instalator" entwickelt! :)
                      mayer
                      > Dann ist die SayIt Adapter nicht aktuell. Installiere SayIt vom Git.
                      War eigentlich aktuell. Hab ihn runter geschmissen und neu installiert. Jetzt funktioniert es.
                      Danke.
                      Eine Kleinigkeit hab ich noch: Das runterfahren der Lautstärke geht mir zu langsam und der Anfang der Ansage fehlt.
                      Gruss, mayer
                      • Alex1808A Offline
                        Alex1808A Offline
                        Alex1808
                        @mayer:
                        Eine Kleinigkeit hab ich noch: Das runterfahren der Lautstärke geht mir zu langsam und der Anfang der Ansage fehlt. `
                        Installiere aktuelle version vom Git, da wurde heute morgen schon was gemacht in der Richtung (auf version Nummer nicht achten)
                        • wendy2702W Online
                          wendy2702W Online
                          @rascal:
                          @Homoran:
                          Hallo rascal,
                          Ich lese hier schon länger mit, habe aber das Gesamtkonstrukt noch nicht verstanden.
                          Mpd = daemon
                          Wo läuft der?
                          Client - host
                          Ist der adapter der Client? Wo ist der Host?
                          Was muss ich wo installieren?
                          Rainer `
                          du hast deine Iobroker Installation laufen, auf einem Raspberry oder sonstwo. Dort musst du den mpd Adapter installieren.
                          Ich habe einen zweiten Raspberry im Netzwerk laufen, mit angeschlossenen Lautsprechern, auf diesem Läuft ein MPD (Music Player Daemon) - welcher praktisch als Empfänger der Befehle des Iobroker mpd-Adapters dient.
                          Jetzt musst du im mpd-Adapter die IP-Adresse des 2. Raspberry mit dem mpd-Service angeben und voala, nun kannst du über Iobroker auf dem 2. Raspberry Musik ausgeben lassen. Möglicherweise brauchst du auf dem 2. Raspberry auch noch einen mp3 Codec installiert (mpg123).
                          Wenn du nun auf dem 2. Raspberry auch Sprachmeldungen von Iobroker ausgeben willst, musst du in Iobroker auch einen sayit Adapter installieren. In diesem Adapter musst du als "Ausgabe durch" den MPD einstellen. Als Gerät den mpd-Adapter "mpd.0", als Web instance den Web Adapter "web.0" und in Web Server IP kommt die Iobroker IP.
                          Nun kannst du bei den Objekten unter sayit.x/tts/text einen Text eintragen und wenn du Enter drückst, sollte der 2. Raspberry die Sprache ausgeben.
                          Kurz: sayit-Adapter (rasp1-iobroker) -> mpd-Adapter (rasp1-iobroker) -> MPD-Service (rasp2-linux)
                          Ich hoffe ich konnte helfen.
                          LG
                          Martin `
                          hat jemand eine Idee wenn ich im SayIt Adapter zwar MPD auswählen kann aber nicht die IP_Adresse vom IOBROKER Server?
                          Das Drop down Menu geht bei mir nicht auf.
                          • R Offline
                            rascal
                            Klick mal statt auf mpd auf was anderes und dann wieder zurück auf mpd.
                            auch wenns nicht angezeigt wird, die IP ist abgespeichert und es funktioniert
                            • wendy2702W Online
                              wendy2702W Online
                              #66
                              wie kann ich denn im Script die lautstärke ändern/anpassen?
                              Ich hätte gerne je nach Ansage eine Unterschiedliche Lautstärke.
                              z.B. Wetterwarnungen etwas lauter
                              erste Ansage früh morgen etwas leiser. usw.
                              • Alex1808A Offline
                                Alex1808A Offline
                                Alex1808
                                #67
                                @wendy2702:
                                Danke `
                                ![](</s><URL url=)<link_text text="http://image.prntscr.com/image/dd618aa9 ... b96d34.png">http://image.prntscr.com/image/dd618aa930f64208bce2825b2ab96d34.png</link_text>" />
                                • wendy2702W Online
                                  wendy2702W Online
                                  #68
                                  habe heute meinen ersten Raspberry bekommen und installiert. Der soll als erstes mal den "hässlichen" Igel Thin Client für meine SayIt Ansagen über MPD ablösen.
                                  MPD auf dem PI3 läuft und die Ansagen kommen auch, werden allerdings abgeschnitten.
                                  Von zum Beispiel diesem Text:
                                  Amtliche WARNUNG vor FROST: Von 17.01.2017 12:44 bis 17.01.2017 17:00: Es tritt mäßiger Frost zwischen -3 °C und -6 °C auf.
                                  Geht die Ansage nur bis hier:
                                  Ich muss im MPD Adapter nur zurück auf den Igel stellen und schon kommt die Ansage wieder vollständig.
                                  Habe es beim PI mit WLAN und Kabel Anbindung versucht.
                                  Die mpd.conf von Igel und Raspi sind Identisch.
                                  Gibt es da am Pi noch etwas zu konfigurieren oder so?
                                  Danke und Gruß
                                    #69
                                    Ich bin jetzt zu faul zum zählen.
                                    Angeblich gibt es bei google eine Limitierung auf 70 zeichen.
                                    Warum der igel dann mehr macht wäre dann das rätsel.
                                    • wendy2702W Online
                                      wendy2702W Online
                                      #70
                                      @Homoran:
                                      Rainer `
                                      Ne, das ist es nicht.
                                      Nutze schon IVONA deshalb geht ja am Igel auch mehr.
                                      • Alex1808A Offline
                                        Alex1808A Offline
                                        Alex1808
                                        #71
                                        @wendy2702:
                                        Nutze schon IVONA deshalb geht ja am Igel auch mehr. `
                                        Ich habe Max2play am laufen und es war alles ok, was länge von ansagen betrifft. Werde in 2 stunden prüfen.
                                        • Alex1808A Offline
                                          Alex1808A Offline
                                          Alex1808
                                          #72
                                          @wendy2702:
                                          Also bei mir ist auch auf 70 Zeichen begrenzt. Wir haben aber schon seit ein paar tagen bemerkt das keine neue Konten werden registriert, ist wohl Schluss mit Betatests… so wie kostenlose unbegrenzte Nutzung :(
                                          Aber es gibt noch 12 Monate kostenlose test:
                                          https://aws.amazon.com/de/polly/pricing/?nc1=h_ls
