  4. [gelöst] Backitup kann influxdb Datenbank nicht sichern.
    6.5k
107 Beiträge 5 Kommentatoren 15.3k Aufrufe 7 Beobachtet
  • Christian KohlöffelC Offline
    Christian Kohlöffel
    @simatec said in Backitup kann influxdb Datenbank nicht sichern.:
    iobroker fix
    Alles so gemacht, wie von Dir gewünscht. Aber leider immernoch dasselbe Bild ....
    Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 2156 states saved
    [DEBUG] [iobroker] - host.raspberrypi 2575 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_04_11-14_21_02_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_04_11-14_21_11_backupiobroker"
    backup: copy: read /opt/iobroker/backups/influxDB_2021_04_11-14_21_11_backupiobroker/meta.00: input/output error
    [DEBUG] [redis] - Start Redis Backup ...
    [DEBUG] [redis] - Created redistmp directory
    [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_04_11-14_21_12_backupiobroker.tar.gz
    [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
    [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
    [DEBUG] [redis] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    • Christian KohlöffelC Christian Kohlöffel
      iobroker fix
      [EXIT] 0
      simatecS Offline
      simatecS Offline
      simatec
      @christian-kohlöffel hmmm dein Rechteproblem ist extrem korrios ...
      Wir könnten noch einen Versuch starten.
      Trage mal als vollständigen Pfad in den infuluxdb Einstellungen von Backitup zum testen usr/bin/influxd ein
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      Christian KohlöffelC 1 Antwort Letzte Antwort
      • simatecS simatec
        Christian Kohlöffel
        usr/bin/influxd
        Ich wäre mir aber nicht bewusst irgendwie bei der Installation was besonderes (korrioses) gemacht zu haben, aus meiner Sicht alles Standard :-)
        Würde es Dir helfen wenn du per remot o.ä. auf den Raspberry kommen würdest? Gibt es da Möglichkeiten?
        Hier was passiert wenn ich den direkten Pfad eingebe:
        [DEBUG] [iobroker] - host.raspberrypi 2583 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_04_11-16_52_48_backupiobroker.tar.gz
        [ERROR] [influxDB] - [IGNORED] Error: Command failed: "/usr/bin/influxd" backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_04_11-16_52_56_backupiobroker"
        backup: copy: read /opt/iobroker/backups/influxDB_2021_04_11-16_52_56_backupiobroker/meta.00: input/output error
        [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_04_11-16_52_58_backupiobroker.tar.gz
        [EXIT] 0
        Der Befehl lässt sich weiterhin ausführen wenn ich mich als pi auf den Raspberry einlogge.
          usr/bin/influxd
          [EXIT] 0
          simatecS Offline
          simatecS Offline
          simatec
          Ok dann mache mal bitte folgendes.
          Lege in deiner FB mal einen User mit dem Namen „iobroker“ an und gibt ihn alle Rechte auf das komplette Speichermedium.
          Dann bitte mal folgendes ausführen:
          sudo usermod -a -G influxdb iobroker
          sudo reboot now
          • simatecS simatec
            sudo reboot now
            Christian Kohlöffel
            schrieb am zuletzt editiert von Christian Kohlöffel
            sudo reboot now
            Ist es wichtig welches Passwort der User "iobroker" auf der FB hat? Ich hab da mal irgendwas eingegeben ....
            Leider bisher noch keine Veränderung:
            [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_04_11-17_42_38_backupiobroker"
            backup: copy: read /opt/iobroker/backups/influxDB_2021_04_11-17_42_38_backupiobroker/meta.00: input/output error
            simatecS 2 Antworten Letzte Antwort
              sudo reboot now
              simatecS Offline
              simatecS Offline
              simatec
              Hast du den mount auf den User iobroker geändert
              • simatecS simatec
                Christian Kohlöffel
                @simatec
                Klar :-) ...
                  sudo reboot now
                  simatecS Offline
                  simatecS Offline
                  simatec
                  Ich habe nochmal etwas gelesen.
                  Laut Dr. Google deutet dieser Fehler mit error input/output auf ein fehlerhaftes Dateisystem hin.
                  Eventuell könnte also dein USB Stick kurz vorm verrecken sein. Um diese Möglichkeit auszuschließen, würde ich dir raten, mal einen anderen Stick in ext4 zu formatieren und diesen zu testen.
                  • simatecS simatec
                    Christian Kohlöffel
                    @simatec
                    Ich habe soeben einen anderen USB Stick versucht. Der Fehler besteht leider weiterhin.
                    Thomas BraunT simatecS 2 Antworten Letzte Antwort
                      @simatec
                      error input/output kann auch auf einen 'wackeligen' USB-Port hinweisen. Insbesondere beim Pi.
                      Schau mal nach ob der genug Saft bekommt:
                      dmesg -T | grep -i under-voltage
                      simatecS Christian KohlöffelC 2 Antworten Letzte Antwort
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @thomas-braun Der Stick von ihm hängt an einer Fritzbox
                          @simatec
                          simatecS Offline
                          simatecS Offline
                          simatec
                          Schaue mal, ob deine USB Eingänge mit voller Leistung betrieben werden
                          • simatecS simatec
                            #66
                            @simatec sagte in Backitup kann influxdb Datenbank nicht sichern.:
                            Oh. Hatte ich überlesen...
                            Aber den USB-Port vom "alten Fritz" kann man sich auch mal anschauen :-)
                              Christian Kohlöffel
                              #67
                              @thomas-braun said in Backitup kann influxdb Datenbank nicht sichern.:
                              Auch falls es nicht zum Thema beiträgt: Da kommt gar nix raus, passt das?
                              pi@raspberrypi:~ $ dmesg -T | grep -i under-voltage
                              pi@raspberrypi:~ $
                              Thomas BraunT Christian KohlöffelC 2 Antworten Letzte Antwort
                              • simatecS simatec
                                Christian Kohlöffel
                                #68
                                @simatec
                                Das sieht bei meiner Fritzbox anderst aus. Kann ich gar nichts einstellen dazu.
                                  pi@raspberrypi:~ $
                                  #69
                                  Dann gibt es dazu keine Meldung in der Datei. Ist gut in dem Fall.
                                    @simatec
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #70
                                    Was kannst du dort einstellen?
                                      pi@raspberrypi:~ $
                                      Christian Kohlöffel
                                      #71
                                      Jetzt noch zur Vollständigkeit: Ich habe das mount auf den internen Speicher der Fritzbox verschoben. Das macht auch keinen Unterschied.
                                      • simatecS simatec
                                        Christian Kohlöffel
                                        #72
                                        @simatec
                                        Zeiten bis zu maximal "Niemals"
                                        --> Macht aber keinen Unterschied. Selbst bei "Niemals" kommt der bekannte Fehler.
                                          @simatec
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #73
                                          Stelle mal bitte zum testen in den Einstellungen von Backitup das Influx Backup von Lokal auf Remote und trage als Host „localhost“ und als Port 8088 ein.
                                          Die Pfadangabe bitte leer lassen
