  4. [gelöst] Backitup kann influxdb Datenbank nicht sichern.
    6.5k
107 Beiträge 5 Kommentatoren 15.3k Aufrufe 7 Beobachtet
  • Christian KohlöffelC Christian Kohlöffel
    @simatec said in Backitup kann influxdb Datenbank nicht sichern.:
    usr/bin/influxd
    Ich wäre mir aber nicht bewusst irgendwie bei der Installation was besonderes (korrioses) gemacht zu haben, aus meiner Sicht alles Standard :-)
    Würde es Dir helfen wenn du per remot o.ä. auf den Raspberry kommen würdest? Gibt es da Möglichkeiten?
    Hier was passiert wenn ich den direkten Pfad eingebe:
    Started iobroker ...
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 2156 states saved
    [DEBUG] [iobroker] - host.raspberrypi 2583 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_04_11-16_52_48_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [ERROR] [influxDB] - [IGNORED] Error: Command failed: "/usr/bin/influxd" backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_04_11-16_52_56_backupiobroker"
    backup: copy: read /opt/iobroker/backups/influxDB_2021_04_11-16_52_56_backupiobroker/meta.00: input/output error
    [DEBUG] [redis] - Start Redis Backup ...
    [DEBUG] [redis] - Created redistmp directory
    [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_04_11-16_52_58_backupiobroker.tar.gz
    [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
    [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
    [DEBUG] [redis] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Der Befehl lässt sich weiterhin ausführen wenn ich mich als pi auf den Raspberry einlogge.
    simatecS Offline
    simatecS Offline
    simatec
    @christian-kohlöffel
    Ok dann mache mal bitte folgendes.
    Lege in deiner FB mal einen User mit dem Namen „iobroker“ an und gibt ihn alle Rechte auf das komplette Speichermedium.
    Dann bitte mal folgendes ausführen:
    sudo usermod -a -G influxdb iobroker
    sudo reboot now
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    Christian KohlöffelC 1 Antwort Letzte Antwort
    • simatecS simatec
      sudo reboot now
      Christian KohlöffelC Offline
      Christian Kohlöffel
      schrieb am zuletzt editiert von Christian Kohlöffel
      sudo reboot now
      Ist es wichtig welches Passwort der User "iobroker" auf der FB hat? Ich hab da mal irgendwas eingegeben ....
      Leider bisher noch keine Veränderung:
      [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_04_11-17_42_38_backupiobroker"
      backup: copy: read /opt/iobroker/backups/influxDB_2021_04_11-17_42_38_backupiobroker/meta.00: input/output error
      simatecS 2 Antworten Letzte Antwort
        sudo reboot now
        simatecS Offline
        simatecS Offline
        simatec
        Hast du den mount auf den User iobroker geändert
        • simatecS simatec
          Christian Kohlöffel
          @simatec
          Klar :-) ...
            sudo reboot now
            simatecS Offline
            simatecS Offline
            simatec
            Ich habe nochmal etwas gelesen.
            Laut Dr. Google deutet dieser Fehler mit error input/output auf ein fehlerhaftes Dateisystem hin.
            Eventuell könnte also dein USB Stick kurz vorm verrecken sein. Um diese Möglichkeit auszuschließen, würde ich dir raten, mal einen anderen Stick in ext4 zu formatieren und diesen zu testen.
            • simatecS simatec
              Christian Kohlöffel
              @simatec
              Ich habe soeben einen anderen USB Stick versucht. Der Fehler besteht leider weiterhin.
              Thomas BraunT simatecS 2 Antworten Letzte Antwort
                @simatec
                error input/output kann auch auf einen 'wackeligen' USB-Port hinweisen. Insbesondere beim Pi.
                Schau mal nach ob der genug Saft bekommt:
                dmesg -T | grep -i under-voltage
                simatecS Christian KohlöffelC 2 Antworten Letzte Antwort
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @thomas-braun Der Stick von ihm hängt an einer Fritzbox
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    Schaue mal, ob deine USB Eingänge mit voller Leistung betrieben werden
                    • simatecS simatec
                      #66
                      @simatec sagte in Backitup kann influxdb Datenbank nicht sichern.:
                      Oh. Hatte ich überlesen...
                      Aber den USB-Port vom "alten Fritz" kann man sich auch mal anschauen :-)
                        Christian Kohlöffel
                        #67
                        @thomas-braun said in Backitup kann influxdb Datenbank nicht sichern.:
                        Auch falls es nicht zum Thema beiträgt: Da kommt gar nix raus, passt das?
                        pi@raspberrypi:~ $ dmesg -T | grep -i under-voltage
                        pi@raspberrypi:~ $
                        Thomas BraunT Christian KohlöffelC 2 Antworten Letzte Antwort
                        • simatecS simatec
                          Christian Kohlöffel
                          #68
                          @simatec
                          Das sieht bei meiner Fritzbox anderst aus. Kann ich gar nichts einstellen dazu.
                            pi@raspberrypi:~ $
                            #69
                            Dann gibt es dazu keine Meldung in der Datei. Ist gut in dem Fall.
                              @simatec
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #70
                              Was kannst du dort einstellen?
                                pi@raspberrypi:~ $
                                Christian Kohlöffel
                                #71
                                Jetzt noch zur Vollständigkeit: Ich habe das mount auf den internen Speicher der Fritzbox verschoben. Das macht auch keinen Unterschied.
                                • simatecS simatec
                                  Christian Kohlöffel
                                  #72
                                  @simatec
                                  Zeiten bis zu maximal "Niemals"
                                  --> Macht aber keinen Unterschied. Selbst bei "Niemals" kommt der bekannte Fehler.
                                    @simatec
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #73
                                    Stelle mal bitte zum testen in den Einstellungen von Backitup das Influx Backup von Lokal auf Remote und trage als Host „localhost“ und als Port 8088 ein.
                                    Die Pfadangabe bitte leer lassen
                                    • simatecS simatec
                                      Christian Kohlöffel
                                      #74
                                      localhost
                                      Hier die Einstellungen
                                      Und hier das Ergebniss
                                      [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host localhost:8088 "/opt/iobroker/backups/influxDB_2021_04_12-17_48_38_backupiobroker"
                                      backup: copy: read /opt/iobroker/backups/influxDB_2021_04_12-17_48_38_backupiobroker/meta.00: input/output error
                                        localhost
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #75
                                        Schaue mal bitte hier und gehe mal die Schritte zum testen deines Filesystems durch
                                        https://unix.stackexchange.com/questions/39905/input-output-error-when-accessing-a-directory
                                        Die Meldung macht mich echt stutzig und kann meiner Menschen nach nichts mit Backitup bzw. Iobroker zu tun haben.
                                        Es wird ein lokales Problem sein
                                        • simatecS simatec
                                          Christian Kohlöffel
                                          #76
                                          @simatec
                                          Kannst du das ein wenig genauer sagen welche Schritte das sind. Ich bin da nicht fit genug in Linux.
                                          Will ja nicht mein Filesystem löschen :-) ...
                                          dsmesg
                                          sagt das am Schluss ...```
                                          code_text
                                          [ 1003.064383] CIFS: Attempting to mount //192.168.178.1/FRITZ.NAS/BackupLokal/
                                          [ 1003.064466] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recomme        nded unless required for access to very old servers
                                          [ 1012.304986] CIFS: VFS: bogus file nlink value 0
                                          [ 1012.371432] CIFS: VFS: bogus file nlink value 0
                                          [ 1015.991625] CIFS: VFS: bogus file nlink value 0
                                          [ 1021.232727] CIFS: VFS: RFC1001 size 39 smaller than SMB for mid=445
                                          [ 1021.232743] 00000000: 27000000 424d53ff 00000074 40018800  ...'.SMBt......@
                                          [ 1021.232759] 00000010: 00000000 00000000 00000000 5a120000  ...............Z
                                          [ 1021.232768] 00000020: f4 01 bd 01 03 ff 00 00 00 00 00                 ......
                                          [ 1021.232820] CIFS: VFS: \\192.168.178.1 cifs_put_smb_ses: Session Logoff failu        re rc=-5
                                          pi@raspberrypi:~ $
