  4. [GELÖST] Iobroker startet nicht nach einspielen von Backup
backup iobroker startet error
9 Beiträge 4 Kommentatoren 1.0k Aufrufe 3 Beobachtet
    MyMeyer
    schrieb am zuletzt editiert von MyMeyer
    Hallo, leider startet mein Iobroker nicht mehr. Habe bereits den FIX drüber laufen lassen. Brachte auch keine Besserung. Wie kann ich das Backup von Backitup von gestern einspielen ohne das Iobroker läuft ? Hier eine Auszug aus dem Log:
    2021-04-11 15:21:02.880 - ^[[31merror^[[39m: host.iobroker _design/system missing - call node iobroker.js setup
    2021-04-11 15:29:39.927 - ^[[32minfo^[[39m: host.iobroker received SIGTERM
    2021-04-11 15:29:39.932 - ^[[32minfo^[[39m: host.iobroker terminated
    2021-04-11 15:30:27.407 - ^[[32minfo^[[39m: host.iobroker iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-11 15:30:27.410 - ^[[32minfo^[[39m: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-11 15:30:27.410 - ^[[32minfo^[[39m: host.iobroker hostname: iobroker, node: v12.20.2
    2021-04-11 15:30:27.410 - ^[[32minfo^[[39m: host.iobroker ip addresses: 192.168.1.39 fe80::9c96:e3ff:feb2:bbe9
    2021-04-11 15:30:27.504 - ^[[31merror^[[39m: host.iobroker Cannot read system.config: null (OK when migrating or restoring)
    2021-04-11 15:30:27.526 - ^[[32minfo^[[39m: host.iobroker connected to Objects and States
    2021-04-11 15:30:27.536 - ^[[32minfo^[[39m: host.iobroker added notifications configuration of host
    2021-04-11 15:30:27.537 - ^[[31merror^[[39m: host.iobroker Cannot find view "system" for search "instance"
    2021-04-11 15:30:27.538 - ^[[31merror^[[39m: host.iobroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-04-11 15:30:27.549 - ^[[32minfo^[[39m: host.iobroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-04-11 15:30:27.553 - ^[[31merror^[[39m: host.iobroker Cannot find view "system" for search "host"
    2021-04-11 15:30:27.559 - ^[[31merror^[[39m: host.iobroker Cannot find view "system" for search "state"
    2021-04-11 15:30:27.559 - ^[[31merror^[[39m: host.iobroker Cannot find view "system" for search "instance"
    2021-04-11 15:30:27.560 - ^[[31merror^[[39m: host.iobroker Could not collect system.host.iobroker states to check for obsolete states: Error: Cannot find view "system"
    2021-04-11 15:30:27.560 - ^[[31merror^[[39m: host.iobroker _design/system missing - call node iobroker.js setup
    2021-04-11 15:30:46.150 - ^[[32minfo^[[39m: host.iobroker received SIGTERM
    2021-04-11 15:30:46.154 - ^[[32minfo^[[39m: host.iobroker terminated
    2021-04-11 15:33:08.695 - ^[[32minfo^[[39m: host.iobroker iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-11 15:33:08.697 - ^[[32minfo^[[39m: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-11 15:33:08.698 - ^[[32minfo^[[39m: host.iobroker hostname: iobroker, node: v12.20.2
    2021-04-11 15:33:08.698 - ^[[32minfo^[[39m: host.iobroker ip addresses: 192.168.1.39 fe80::9c96:e3ff:feb2:bbe9
    2021-04-11 15:33:08.816 - ^[[32minfo^[[39m: host.iobroker connected to Objects and States
    2021-04-11 15:33:08.826 - ^[[32minfo^[[39m: host.iobroker added notifications configuration of host
    2021-04-11 15:33:09.099 - ^[[32minfo^[[39m: host.iobroker no instances found
    2021-04-11 15:35:25.208 - ^[[32minfo^[[39m: host.iobroker iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-11 15:35:25.212 - ^[[32minfo^[[39m: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-11 15:35:25.213 - ^[[32minfo^[[39m: host.iobroker hostname: iobroker, node: v12.20.2
    2021-04-11 15:35:25.213 - ^[[32minfo^[[39m: host.iobroker ip addresses: 192.168.1.39 fe80::9c96:e3ff:feb2:bbe9
    2021-04-11 15:35:25.234 - ^[[32minfo^[[39m: host.iobroker-Server Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 0.0.0.0:9001
    2021-04-11 15:35:39.275 - ^[[32minfo^[[39m: host.iobroker received SIGINT
    2021-04-11 15:35:39.276 - ^[[32minfo^[[39m: host.iobroker terminated. Could not reset alive status for instances
    2021-04-11 15:41:11.439 - ^[[32minfo^[[39m: host.iobroker received SIGTERM
    2021-04-11 15:41:11.457 - ^[[32minfo^[[39m: host.iobroker terminated
    2021-04-11 17:41:28.812 - ^[[32minfo^[[39m: host.iobroker iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-11 17:41:28.814 - ^[[32minfo^[[39m: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-11 17:41:28.814 - ^[[32minfo^[[39m: host.iobroker hostname: iobroker, node: v12.20.2
    2021-04-11 17:41:28.814 - ^[[32minfo^[[39m: host.iobroker ip addresses: 192.168.1.39 fe80::9c96:e3ff:feb2:bbe9
    2021-04-11 17:41:28.966 - ^[[32minfo^[[39m: host.iobroker connected to Objects and States
    2021-04-11 17:41:28.985 - ^[[32minfo^[[39m: host.iobroker added notifications configuration of host
    2021-04-11 17:41:29.259 - ^[[32minfo^[[39m: host.iobroker no instances found
    HAbt Ihr eine Idee ?
    MyMeyer
    Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
    HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
    • M MyMeyer
      GlasfaserG Offline
      GlasfaserG Offline
      @mymeyer
      • GlasfaserG Glasfaser
        @mymeyer
        MyMeyer
        @glasfaser ich habe jetzt nochmal das Backup von Proxmox rüber gespielt. Nachdem Systemstart bekommt man diese Meldung:
        michael@iobroker:/opt/iobroker$ ./iobroker status
        [sudo] Passwort f▒r michael:
        Objects type: file
        States  type: redis
        MyMeyer
        WalW 1 Antwort Letzte Antwort
        • Meister MopperM Offline
          Meister Mopper
          @mymeyer
          Hast Du schon mal hier nachgelesen?
          Proxmox und HA ...
          • M MyMeyer
            Objects type: file
            States  type: redis
            WalW Offline
            WalW Offline
            Wal
            @mymeyer,
            ich kann da leider nicht helfen, aber warum braucht man Backitup um ein Update einzuspielen ?
            Unter Proxmox einfach den Container oder VM sichern und bei Bedarf wieder herstellen.
            Ich lasse 2 mal die Woche auf eine externe USB-Festplatte alle Systeme im Ringpuffer sichern, zurückspielen ist dann eine Sache von 2 Minuten.
            Walter
            DoorIO-Adapter
            • WalW Wal
              @mymeyer,
              MyMeyer
              @wal sagte in Iobroker startet nicht nach einspielen von Backup Proxmox:
              @mymeyer,
              HAbe ich gemacht...:-( Erst eine aktuelle Backup mit Proxmox ...dann etwas ausprobiert...und dann wieder zurück mit dem Backup von Proxmox. Nach dem Start kommt dann der Salat.
              Backitup hatte ich zusätzlich laufen.
              MyMeyer
              • M MyMeyer
                @mymeyer,
                WalW Offline
                WalW Offline
                Wal
                @mymeyer,
                hmm wen ich unter Proxmox ein funktionierendes System sichere und danach wieder einspiele, geht das auch wieder.
                Ok, ist mir zum Glück noch nicht passiert, hoffe du bekommst es noch hin.
                Walter
                DoorIO-Adapter
                  @mymeyer
                  MyMeyer
                  @meister-mopper Du bist mein Held :-) :-) :-) Mit der Anleitung habe ich es wieder zum laufen bekommen. Danke Dir für den Prima Tip.😀
                  MyMeyer
                  • M MyMeyer
                    Meister Mopper
                    @mymeyer Danke besser @Thomas-Braun
                    Proxmox und HA ...
