  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • simatecS simatec
    @fred-freund
    Dann existieren bei dir diese 3 zigbee Unterordner
    Auf meine Fragen habe ich noch immer keine Antwort bekommen.
    Dementsprechend kann ich hier auch nicht weiterhelfen
    Fred FreundF Offline
    Fred Freund
    schrieb am zuletzt editiert von Fred Freund
    @simatec. Alles Gut!
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"}
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.broker1 1195 states saved
    [DEBUG] [iobroker] - host.broker1 1570 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1,zigbee.2
    [DEBUG] [zigbee] - done
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.1_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.2_2021_03_27-07_24_52_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"],"types":["iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en","time":"27. March 2021 at 07:24 Hours"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [historyJSON] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.1_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.2_2021_03_27-07_24_52_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"],"types":["iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en","time":"27. March 2021 at 07:24 Hours"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups"}
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    pi@broker1:~ $ cat /opt/iobroker/log/iobroker.current.log
    2021-03-27 07:24:31.466  - error: backitup.0 (746) umount: /opt/iobroker/backups: not mounted.
    Wo finde ich die zigbee Ordner?
    Und herzlichen Dank für deine Geduld.
    many Thx for your support,
    Vielen Dank!
    HumidorH 1 Antwort Letzte Antwort
    • Fred FreundF Fred Freund
      [EXIT] 0
      HumidorH Offline
      HumidorH Offline
      Humidor
      @fred-freund hi, hab auch das Thema gerade, nach Update geht er nicht mehr
      siehe meinen https://forum.iobroker.net/topic/43664/iobackup-log-meldung-und-fehler/4?_=1616921423478
      hab auf 2.0.4 downgegrades und es läuft wieder einwandfrei.
      wenn ich das richtig verfolgen kann dann startet er den mount nicht
      BG
      • HumidorH Humidor
        simatecS Offline
        simatecS Offline
        simatec
        @humidor
        Was genau geht denn nicht bei dir? Etwas mehr Input außer einen Schnipsel aus dem Log wäre gut
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          @humidor
          HumidorH Offline
          HumidorH Offline
          Humidor
          @simatec wo soll ich jetzt antworten, hier oder in meinem Thread 🤔
          BG
          • HumidorH Humidor
            simatecS Offline
            simatecS Offline
            simatec
            @humidor Eigentlich gibt es einen Thread für Backitup
            Versuche mal die aktuelle Version 2.1.0 zu installieren und poste damit mal den Log
            • simatecS simatec
              HumidorH Offline
              HumidorH Offline
              Humidor
              schrieb am zuletzt editiert von Humidor
              @simatec hab einen aus 2019 gefunden, das wirds wohl nich sein ?
              2.1.0
              manuelles Backup
              [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"}
              [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
              [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
              mount error(16): Device or resource busy
              Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
              [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
              [DEBUG] [iobroker] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [iobroker] - host.raspi4iobrokerpv 2093 states saved
              [DEBUG] [iobroker] - host.raspi4iobrokerpv 2538 objects saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
              [DEBUG] [historyDB] - compress from historyDB started ...
              [DEBUG] [historyDB] - Packed 9MB so far...
              [DEBUG] [historyDB] - Packed 19MB so far...
              [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
              [DEBUG] [historyDB] - done
              [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
              [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
              [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
              [DEBUG] [telegram] - done
              [DEBUG] [telegram] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [historyHTML] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [historyJSON] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups"}
              log
              backitup.0	2021-03-28 18:03:24.952	debug	(14449) system.adapter.admin.0: logging true
              backitup.0	2021-03-28 18:02:39.560	debug	(14449) [iobroker/historyJSON] done
              backitup.0	2021-03-28 18:02:39.559	debug	(14449) [iobroker/historyJSON] new history json values created
              backitup.0	2021-03-28 18:02:39.394	debug	(14449) [iobroker/historyHTML] done
              backitup.0	2021-03-28 18:02:39.392	debug	(14449) [iobroker/historyHTML] new history html values created
              backitup.0	2021-03-28 18:02:39.081	debug	(14449) [iobroker/telegram] done
              backitup.0	2021-03-28 18:02:39.079	debug	(14449) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
              backitup.0	2021-03-28 18:02:39.065	debug	(14449) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
              backitup.0	2021-03-28 18:02:38.602	debug	(14449) [iobroker/clean] done
              backitup.0	2021-03-28 18:02:38.600	debug	(14449) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
              backitup.0	2021-03-28 18:02:37.995	debug	(14449) [iobroker/cifs] done
              backitup.0	2021-03-28 18:02:36.935	debug	(14449) [iobroker/historyDB] done
              backitup.0	2021-03-28 18:02:36.909	debug	(14449) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:02:27.441	debug	(14449) [iobroker/historyDB] Packed 19MB so far...
              backitup.0	2021-03-28 18:02:17.442	debug	(14449) [iobroker/historyDB] Packed 9MB so far...
              backitup.0	2021-03-28 18:02:07.439	debug	(14449) [iobroker/historyDB] compress from historyDB started ...
              backitup.0	2021-03-28 18:02:06.682	debug	(14449) [iobroker/iobroker] done
              backitup.0	2021-03-28 18:02:05.589	debug	(14449) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:02:02.046	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2538 objects saved
              backitup.0	2021-03-28 18:02:02.019	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2093 states saved
              backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
              backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
              backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker
              backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
              backitup.0	2021-03-28 18:01:59.326	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
              backitup.0	2021-03-28 18:01:59.325	debug	(14449) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroke
              backitup.0	2021-03-28 18:01:59.238	debug	(14449) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
              backitup.0	2021-03-28 18:01:55.647	debug	(14449) system.adapter.admin.0: logging false
              backitup.0	2021-03-28 18:01:49.159	debug	(14449) Backup has started ...
              backitup.0	2021-03-28 18:01:49.156	error	(14449) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
              backitup.0	2021-03-28 18:01:47.336	debug	(14449) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
              backitup.0	2021-03-28 18:01:47.333	debug	(14449) telegram-instance: telegram.0
              backitup.0	2021-03-28 18:01:24.555	debug	(14449) Start all Adapter after Restore enabled
              backitup.0	2021-03-28 18:01:16.924	debug	(14449) detect last backup file: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.921	debug	(14449) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.920	debug	(14449) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.919	debug	(14449) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.918	debug	(14449) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.917	debug	(14449) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.916	debug	(14449) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.915	debug	(14449) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.913	debug	(14449) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
              backitup.0	2021-03-28 18:01:16.192	debug	(14449) system.adapter.admin.0: logging true
              backitup.0	2021-03-28 18:01:14.902	error	Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
              backitup.0	2021-03-28 18:01:14.902	error	mount error(16): Device or resource busy
              backitup.0	2021-03-28 18:01:14.902	error	(14449) Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
              backitup.0	2021-03-28 18:01:14.854	debug	(14449) first mount attempt with smb option failed. try next mount attempt without smb option ...
              backitup.0	2021-03-28 18:01:14.722	debug	(14449) [iobroker] 10 15 06 */1 * *
              backitup.0	2021-03-28 18:01:14.676	info	(14449) [iobroker] backup was activated at 06:15 every 1 day(s)
              backitup.0	2021-03-28 18:01:14.346	info	(14449) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
              BG
              wendy2702W crunchipC simatecS 3 Antworten Letzte Antwort
              • HumidorH Humidor
                2.1.0
                manuelles Backup
                log
                wendy2702W Online
                wendy2702W Online
                @humidor sagte in Iobroker backitup error.. Wo liegt das problem:
                • HumidorH Humidor
                  2.1.0
                  manuelles Backup
                  log
                  crunchipC Abwesend
                  crunchipC Abwesend
                  https://forum.iobroker.net/topic/27267/test-adapter-backitup-v2-1-x
                  • HumidorH Humidor
                    2.1.0
                    manuelles Backup
                    log
                    simatecS Offline
                    simatecS Offline
                    simatec
                    So wie es ausschaut ist bereits ein mount gesetzt
                    sudo umount /opt/iobroker/backups
                    HumidorH 2 Antworten Letzte Antwort
                    • simatecS simatec
                      HumidorH Offline
                      HumidorH Offline
                      Humidor
                      @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
                      ioBroker fix habe ich gemacht inkl. alles was sonst noch an update usw. zu tun ist
                      den unmount habe ich gerade gemacht
                      ein gerader gestarteter manueller Backup startet nicht (Fenster bleibt leer)
                      log von heute - files wurden am NAS angelegt, Fehlermeldung wurde versandt.
                      2021-03-31 06:15:10.291 - error: backitup.0 (32188) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                      2021-03-31 06:15:10.300 - debug: backitup.0 (32188) Backup has started ...
                      2021-03-31 06:15:21.081 - debug: backitup.0 (32188) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                      2021-03-31 06:15:21.161 - debug: backitup.0 (32188) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                      2021-03-31 06:15:21.163 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
                      2021-03-31 06:15:21.164 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                      2021-03-31 06:15:21.165 - debug: backitup.0 (32188) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                      2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
                      2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                      2021-03-31 06:15:23.856 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2149 states saved
                      2021-03-31 06:15:23.889 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
                      2021-03-31 06:15:27.198 - debug: backitup.0 (32188) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                      2021-03-31 06:15:28.251 - debug: backitup.0 (32188) [iobroker/iobroker] done
                      2021-03-31 06:15:29.089 - debug: backitup.0 (32188) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
                      2021-03-31 06:15:39.048 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 11MB so far...
                      2021-03-31 06:15:49.042 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 21MB so far...
                      2021-03-31 06:15:57.276 - debug: backitup.0 (32188) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-06_15_29_backupiobroker.tar.gz
                      2021-03-31 06:15:57.278 - debug: backitup.0 (32188) [iobroker/historyDB] done
                      2021-03-31 06:15:58.336 - debug: backitup.0 (32188) [iobroker/cifs] done
                      2021-03-31 06:15:58.942 - debug: backitup.0 (32188) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                      2021-03-31 06:15:58.944 - debug: backitup.0 (32188) [iobroker/clean] done
                      2021-03-31 06:15:59.413 - debug: backitup.0 (32188) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                      2021-03-31 06:15:59.425 - debug: backitup.0 (32188) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                      2021-03-31 06:15:59.428 - debug: backitup.0 (32188) [iobroker/telegram] done
                      2021-03-31 06:15:59.734 - debug: backitup.0 (32188) [iobroker/historyHTML] new history html values created
                      2021-03-31 06:15:59.736 - debug: backitup.0 (32188) [iobroker/historyHTML] done
                      2021-03-31 06:15:59.894 - debug: backitup.0 (32188) [iobroker/historyJSON] new history json values created
                      2021-03-31 06:15:59.895 - debug: backitup.0 (32188) [iobroker/historyJSON] done
                      BG
                      • simatecS simatec
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        @simatec
                        gerade gemacht:
                        iobroker stop
                        sudo apt-get update
                        sudo apt-get upgrade
                        iobroker fix
                        curl -fsL https://iobroker.net/fix.sh | bash -
                        iobroker start
                        ... gewartet bis wieder alle Adapter online sind....
                        manuelles Backup gestartet
                        Adapter 2.0.4 - schaut gut aus, file ohne Fehler angelegt.
                        2021-03-31 08:08:07.487 - debug: backitup.0 (24853) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2021-03-31 08:08:07.527 - debug: backitup.0 (24853) Objects client ready ... initialize now
                        2021-03-31 08:08:07.530 - debug: backitup.0 (24853) Objects create System PubSub Client
                        2021-03-31 08:08:07.531 - debug: backitup.0 (24853) Objects create User PubSub Client
                        2021-03-31 08:08:07.532 - debug: backitup.0 (24853) Objects client initialize lua scripts
                        2021-03-31 08:08:07.545 - debug: backitup.0 (24853) Objects connected to redis: 127.0.0.1:9001
                        2021-03-31 08:08:07.554 - debug: backitup.0 (24853) objectDB connected
                        2021-03-31 08:08:07.557 - debug: backitup.0 (24853) Redis States: Use Redis connection: 127.0.0.1:9000
                        2021-03-31 08:08:07.565 - debug: backitup.0 (24853) States create System PubSub Client
                        2021-03-31 08:08:07.566 - debug: backitup.0 (24853) States create User PubSub Client
                        2021-03-31 08:08:07.574 - debug: backitup.0 (24853) States connected to redis: 127.0.0.1:9000
                        2021-03-31 08:08:07.575 - debug: backitup.0 (24853) statesDB connected
                        2021-03-31 08:08:08.090 - debug: backitup.0 (24853) Plugin sentry Initialize Plugin (enabled=true)
                        2021-03-31 08:08:08.348 - info: backitup.0 (24853) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.0, js-controller: 3.2.16
                        2021-03-31 08:08:08.446 - info: backitup.0 (24853) [iobroker] backup was activated at 06:15 every 1 day(s)
                        2021-03-31 08:08:08.485 - debug: backitup.0 (24853) [iobroker] 10 15 06 */1 * *
                        2021-03-31 08:08:09.122 - debug: backitup.0 (24853) mount successfully completed
                        2021-03-31 08:08:11.097 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
                        2021-03-31 08:08:11.205 - debug: backitup.0 (24853) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.206 - debug: backitup.0 (24853) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
                        2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
                        2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.209 - debug: backitup.0 (24853) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 9 from cifs: iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 10 from cifs: iobroker_2021_03_29-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 11 from cifs: iobroker_2021_03_30-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.212 - debug: backitup.0 (24853) detect backup file 12 from cifs: iobroker_2021_03_30-07_26_27_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.213 - debug: backitup.0 (24853) detect backup file 13 from cifs: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.215 - debug: backitup.0 (24853) detect last backup file: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:08:11.851 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 24897
                        2021-03-31 08:08:15.998 - info: host.raspi4iobrokerpv instance system.adapter.influxdb.0 started with pid 24912
                        2021-03-31 08:08:18.174 - info: influxdb.0 (24912) starting. Version 1.9.4 in /opt/iobroker/node_modules/iobroker.influxdb, node: v12.22.0, js-controller: 3.2.16
                        2021-03-31 08:08:18.223 - info: influxdb.0 (24912) No stored data from last exit found
                        2021-03-31 08:08:18.225 - info: influxdb.0 (24912) Connecting http://localhost:8086 ...
                        2021-03-31 08:08:18.324 - info: influxdb.0 (24912) enabled logging of kecontact.0.pf, Alias=false, 1 points now activated
                        2021-03-31 08:08:18.325 - info: influxdb.0 (24912) enabled logging of kecontact.0.p, Alias=false, 2 points now activated
                        2021-03-31 08:08:18.326 - info: influxdb.0 (24912) enabled logging of kecontact.0.i3, Alias=false, 3 points now activated
                        2021-03-31 08:08:18.327 - info: influxdb.0 (24912) enabled logging of kecontact.0.i2, Alias=false, 4 points now activated
                        2021-03-31 08:08:18.328 - info: influxdb.0 (24912) enabled logging of kecontact.0.i1, Alias=false, 5 points now activated
                        2021-03-31 08:08:18.329 - info: influxdb.0 (24912) enabled logging of kecontact.0.u3, Alias=false, 6 points now activated
                        2021-03-31 08:08:18.330 - info: influxdb.0 (24912) enabled logging of kecontact.0.u2, Alias=false, 7 points now activated
                        2021-03-31 08:08:18.331 - info: influxdb.0 (24912) enabled logging of kecontact.0.u1, Alias=false, 8 points now activated
                        2021-03-31 08:08:18.332 - info: influxdb.0 (24912) enabled logging of kecontact.0.currentUser, Alias=false, 9 points now activated
                        2021-03-31 08:08:18.333 - info: influxdb.0 (24912) enabled logging of kecontact.0.enableUser, Alias=false, 10 points now activated
                        2021-03-31 08:08:18.334 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.170, Alias=false, 11 points now activated
                        2021-03-31 08:08:18.335 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.270, Alias=false, 12 points now activated
                        2021-03-31 08:08:18.336 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch, Alias=false, 13 points now activated
                        2021-03-31 08:08:18.337 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power, Alias=false, 14 points now activated
                        2021-03-31 08:08:18.338 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.Power, Alias=false, 15 points now activated
                        2021-03-31 08:08:18.339 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30537_Tagesertrag_kWh, Alias=false, 16 points now activated
                        2021-03-31 08:08:18.340 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30775_PVLeistung, Alias=false, 17 points now activated
                        2021-03-31 08:08:18.341 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell, Alias=false, 18 points now activated
                        2021-03-31 08:08:18.342 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40083_I_AC_Leistung, Alias=false, 19 points now activated
                        2021-03-31 08:08:18.343 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40093_I_AC_Energie_WH, Alias=false, 20 points now activated
                        2021-03-31 08:08:18.353 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVPower, Alias=false, 21 points now activated
                        2021-03-31 08:08:18.354 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVÜberschuss, Alias=false, 22 points now activated
                        2021-03-31 08:08:18.355 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuellSMA, Alias=false, 23 points now activated
                        2021-03-31 08:08:18.356 - info: influxdb.0 (24912) enabled logging of fuelpricemonitor.0.zuHome_Diesel.0.prices.0.amount, Alias=false, 24 points now activated
                        2021-03-31 08:08:18.357 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_170_Actual, Alias=false, 25 points now activated
                        2021-03-31 08:08:18.358 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_270_Actual, Alias=false, 26 points now activated
                        2021-03-31 08:08:18.359 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank, Alias=false, 27 points now activated
                        2021-03-31 08:08:18.360 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank, Alias=false, 28 points now activated
                        2021-03-31 08:08:18.394 - info: influxdb.0 (24912) Connected!
                        2021-03-31 08:08:18.443 - debug: backitup.0 (24853) mount activ... umount in 2 Seconds!!
                        2021-03-31 08:08:19.844 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 24951
                        2021-03-31 08:08:20.507 - debug: backitup.0 (24853) umount successfully completed
                        2021-03-31 08:08:23.918 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 24970
                        2021-03-31 08:08:27.916 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 24991
                        2021-03-31 08:08:31.809 - info: host.raspi4iobrokerpv instance scheduled system.adapter.zoe2.0 */10 * * * *
                        2021-03-31 08:08:35.850 - info: host.raspi4iobrokerpv instance system.adapter.info.0 started with pid 25021
                        2021-03-31 08:08:39.889 - info: host.raspi4iobrokerpv instance system.adapter.life360.0 started with pid 25130
                        2021-03-31 08:08:43.905 - info: host.raspi4iobrokerpv instance system.adapter.fritzdect.0 started with pid 25517
                        2021-03-31 08:08:47.741 - debug: backitup.0 (24853) system.adapter.admin.0: logging false
                        2021-03-31 08:08:47.862 - info: host.raspi4iobrokerpv instance scheduled system.adapter.fuelpricemonitor.0 25 */20 * * * *
                        2021-03-31 08:08:47.887 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 started with pid 25539
                        2021-03-31 08:08:50.014 - info: fuelpricemonitor.0 (25539) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v12.22.0, js-controller: 3.2.16
                        2021-03-31 08:08:51.962 - info: host.raspi4iobrokerpv instance system.adapter.virtualpowermeter.0 started with pid 25568
                        2021-03-31 08:08:54.142 - info: virtualpowermeter.0 (25568) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.virtualpowermeter, node: v12.22.0, js-controller: 3.2.16
                        2021-03-31 08:08:54.214 - info: virtualpowermeter.0 (25568) inital all Objects
                        2021-03-31 08:08:54.394 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.170
                        2021-03-31 08:08:54.506 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.170 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_170 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_170 Destination Group: virtualpowermeter.0.group_grid.
                        2021-03-31 08:08:54.507 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.270
                        2021-03-31 08:08:54.551 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.270 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_270 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_270 Destination Group: virtualpowermeter.0.group_grid.
                        2021-03-31 08:08:54.556 - info: virtualpowermeter.0 (25568) initial fritzdect.0.DECT_116300118701.power
                        2021-03-31 08:08:54.580 - info: virtualpowermeter.0 (25568) initial done fritzdect.0.DECT_116300118701.power Destination Power: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank Destination EnergyTotal: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank Destination Group: virtualpowermeter.0.group_PowerBank.
                        2021-03-31 08:08:54.672 - info: virtualpowermeter.0 (25568) initial completed
                        2021-03-31 08:08:54.882 - info: fuelpricemonitor.0 (25539) Terminated (NO_ERROR): Without reason
                        2021-03-31 08:08:55.400 - info: fuelpricemonitor.0 (25539) cleaned everything up...
                        2021-03-31 08:08:55.460 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
                        2021-03-31 08:09:05.222 - debug: backitup.0 (24853) telegram-instance: telegram.0
                        2021-03-31 08:09:05.227 - debug: backitup.0 (24853) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
                        2021-03-31 08:09:09.554 - debug: backitup.0 (24853) Backup has started ...
                        2021-03-31 08:09:20.003 - debug: backitup.0 (24853) [iobroker/mount] mount successfully completed
                        2021-03-31 08:09:20.007 - debug: backitup.0 (24853) [iobroker/mount] done
                        2021-03-31 08:09:22.797 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2160 states saved
                        2021-03-31 08:09:22.820 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
                        2021-03-31 08:09:26.163 - debug: backitup.0 (24853) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-08_09_20_ioBrokerPV_backupiobroker.tar.gz
                        2021-03-31 08:09:27.265 - debug: backitup.0 (24853) [iobroker/iobroker] done
                        2021-03-31 08:09:28.134 - debug: backitup.0 (24853) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
                        2021-03-31 08:09:38.090 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 11MB so far...
                        2021-03-31 08:09:48.187 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 21MB so far...
                        2021-03-31 08:09:48.507 - debug: backitup.0 (24853) system.adapter.admin.0: logging true
                        2021-03-31 08:09:56.738 - debug: backitup.0 (24853) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-08_09_28_backupiobroker.tar.gz
                        2021-03-31 08:09:56.750 - debug: backitup.0 (24853) [iobroker/historyDB] done
                        2021-03-31 08:09:57.815 - debug: backitup.0 (24853) [iobroker/cifs] done
                        2021-03-31 08:09:58.417 - debug: backitup.0 (24853) [iobroker/clean] done
                        2021-03-31 08:09:58.878 - debug: backitup.0 (24853) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                        2021-03-31 08:09:58.886 - debug: backitup.0 (24853) [iobroker/telegram] done
                        2021-03-31 08:09:59.198 - debug: backitup.0 (24853) [iobroker/historyHTML] new history html values created
                        2021-03-31 08:09:59.201 - debug: backitup.0 (24853) [iobroker/historyHTML] done
                        2021-03-31 08:09:59.367 - debug: backitup.0 (24853) [iobroker/historyJSON] new history json values created
                        2021-03-31 08:09:59.369 - debug: backitup.0 (24853) [iobroker/historyJSON] done
                        2021-03-31 08:09:59.565 - debug: backitup.0 (24853) [iobroker/umount] mount activ, umount is started ...
                        2021-03-31 08:10:00.114 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 started with pid 25752
                        2021-03-31 08:10:04.622 - debug: backitup.0 (24853) [iobroker/umount] umount successfully completed
                        2021-03-31 08:10:04.623 - debug: backitup.0 (24853) [iobroker/umount] done
                        2021-03-31 08:10:04.775 - debug: backitup.0 (24853) [iobroker] exec: done
                        BG
                          arne007
                          Habe meinen Pi komplett neu aufgesetzt und wollte jetzt influxDB und Grafana aus dem Backup wiederherstellen. Bekomme jedoch nur folgende Fehlermeldung. Weiß jmd wie ich das Problem löse.
                          ckitup.0
                          2021-11-26 10:56:12.941	error	[influxDB] infuxDB Restore not completed
                          backitup.0
                          2021-11-26 10:56:12.939	error	[influxDB] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/influxDBtmp/'
                          backitup.0
                          2021-11-26 10:49:31.947	error	[grafana] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/grafana_tmp/'
                          backitup.0
                          2021-11-26 10:49:31.945	error	[grafana] Grafana restore not completed
                          backitup.0
                          2021-11-26 10:49:20.599	error	Error: Command failed: sudo mount -t cifs -o username=Arne,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.10/homes/Backup_ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                          backitup.0
                          2021-11-26 10:49:09.218	error	[influxDB] infuxDB Restore not completed
                          backitup.0
                          2021-11-26 10:49:09.211	error	[influxDB] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/influxDBtmp/'
                          • A arne007
                            ckitup.0
                            backitup.0
                            backitup.0
                            backitup.0
                            backitup.0
                            backitup.0
                            backitup.0
                            simatecS Offline
                            simatecS Offline
                            simatec
                            @arne007 sagte in Iobroker backitup error.. Wo liegt das problem:
                            Du hast keine Schreibrechte. Wo liegt das Backup? Versuchst du den restore lokal oder über NAS oder der Gleichen herzustellen?
                            • simatecS simatec
                              arne007
                              schrieb am zuletzt editiert von arne007
                              @simatec said in Iobroker backitup error.. Wo liegt das problem:
                              über NAS. Welche Schreibrechte muss ich wie / wo ändern?
                              • A arne007
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @arne007 Mit den Angaben von dir kann ich dir das nicht beantworten.
                                cifs-utils installiert?
                                NAS konfiguriert?
                                NAS Config und Backitup Config?
                                fu_zhouF 1 Antwort Letzte Antwort
                                • simatecS simatec
                                  NAS konfiguriert?
                                  fu_zhouF Online
                                  fu_zhouF Online
                                  fu_zhou
                                  @simatec Mhm... ich habe das selbe Problem. Backups werden auf dem NAS angelegt, CIFS-utils sind installiert, die Backups werden auch auf dem NAS gefunden und angezeigt, nur wiederherstellen möchte Backitup nicht:
                                  eError: {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                                  Synology DS920+ VM, S7-315 PN mit ET200S
                                  • fu_zhouF fu_zhou
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    @fu_zhou Bitte poste den vollständigen Debuglog und deine Config. Was nutzt du für ein NAS und was hast du dort für Einstellungen?
                                    • simatecS simatec
                                      fu_zhouF Online
                                      fu_zhouF Online
                                      fu_zhou
                                      @simatec Das ist ein älterer Synology Diskstation DS411j.
                                      Der in Backitup eingetragene Nutzer hat volle Rechte auf die Ordner, es ist SMB, FTP aktiviert, AFP, NFS, rsync sind nicht aktiviert.
                                      Config sieht so aus:
                                      Beim SMB Typ habe ich mal auf Verdacht SMB3.0 eingetragen, im NAS kann man SMB3 einstellen, nicht 3.0.2 oder 3.1.1
                                      Wie gesagt, die Backups werden auf dem NAS gemacht.
                                      Debuglog kommt morgen noch.
                                      Danke schon mal!
                                      • fu_zhouF fu_zhou
                                        Danke schon mal!
                                        HumidorH Offline
                                        HumidorH Offline
                                        Humidor
                                        @fu_zhou ich habe SMB 2.0, 3.0 hatte bei mir auch Fehler ausgegeben
                                        BG
                                        • HumidorH Humidor
                                          fu_zhouF Online
                                          fu_zhouF Online
                                          fu_zhou
                                          @humidor Hat nichts geholfen, ich glaube, es liegt an den Rechten (gibt schon einen Thread dazu unter dem Stichwort "utime"). Muss ich mich mal mit beschäftigen, wie das mit den Rechten auf dem NAS ist. Wenn der NAS-Ordner gemountet wird (in /opt/iobroker/backups) gehört der Ordner "backups" root root, kann ich auch nicht ändern mit chown oder so.
