  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • HumidorH Humidor
    @simatec hab einen aus 2019 gefunden, das wirds wohl nich sein ?
    2.1.0
    manuelles Backup
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"}
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
    mount error(16): Device or resource busy
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
    [DEBUG] [iobroker] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.raspi4iobrokerpv 2093 states saved
    [DEBUG] [iobroker] - host.raspi4iobrokerpv 2538 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [DEBUG] [historyDB] - Packed 9MB so far...
    [DEBUG] [historyDB] - Packed 19MB so far...
    [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
    [DEBUG] [historyDB] - done
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
    [DEBUG] [telegram] - done
    [DEBUG] [telegram] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [historyJSON] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups"}
    log
    backitup.0	2021-03-28 18:03:24.952	debug	(14449) system.adapter.admin.0: logging true
    backitup.0	2021-03-28 18:02:39.560	debug	(14449) [iobroker/historyJSON] done
    backitup.0	2021-03-28 18:02:39.559	debug	(14449) [iobroker/historyJSON] new history json values created
    backitup.0	2021-03-28 18:02:39.394	debug	(14449) [iobroker/historyHTML] done
    backitup.0	2021-03-28 18:02:39.392	debug	(14449) [iobroker/historyHTML] new history html values created
    backitup.0	2021-03-28 18:02:39.081	debug	(14449) [iobroker/telegram] done
    backitup.0	2021-03-28 18:02:39.079	debug	(14449) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
    backitup.0	2021-03-28 18:02:39.065	debug	(14449) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
    backitup.0	2021-03-28 18:02:38.602	debug	(14449) [iobroker/clean] done
    backitup.0	2021-03-28 18:02:38.600	debug	(14449) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0	2021-03-28 18:02:37.995	debug	(14449) [iobroker/cifs] done
    backitup.0	2021-03-28 18:02:36.935	debug	(14449) [iobroker/historyDB] done
    backitup.0	2021-03-28 18:02:36.909	debug	(14449) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:02:27.441	debug	(14449) [iobroker/historyDB] Packed 19MB so far...
    backitup.0	2021-03-28 18:02:17.442	debug	(14449) [iobroker/historyDB] Packed 9MB so far...
    backitup.0	2021-03-28 18:02:07.439	debug	(14449) [iobroker/historyDB] compress from historyDB started ...
    backitup.0	2021-03-28 18:02:06.682	debug	(14449) [iobroker/iobroker] done
    backitup.0	2021-03-28 18:02:05.589	debug	(14449) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:02:02.046	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2538 objects saved
    backitup.0	2021-03-28 18:02:02.019	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2093 states saved
    backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
    backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker
    backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    backitup.0	2021-03-28 18:01:59.326	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
    backitup.0	2021-03-28 18:01:59.325	debug	(14449) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroke
    backitup.0	2021-03-28 18:01:59.238	debug	(14449) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
    backitup.0	2021-03-28 18:01:55.647	debug	(14449) system.adapter.admin.0: logging false
    backitup.0	2021-03-28 18:01:49.159	debug	(14449) Backup has started ...
    backitup.0	2021-03-28 18:01:49.156	error	(14449) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
    backitup.0	2021-03-28 18:01:47.336	debug	(14449) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
    backitup.0	2021-03-28 18:01:47.333	debug	(14449) telegram-instance: telegram.0
    backitup.0	2021-03-28 18:01:24.555	debug	(14449) Start all Adapter after Restore enabled
    backitup.0	2021-03-28 18:01:16.924	debug	(14449) detect last backup file: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.921	debug	(14449) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.920	debug	(14449) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.919	debug	(14449) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.918	debug	(14449) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.917	debug	(14449) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.916	debug	(14449) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.915	debug	(14449) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.913	debug	(14449) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
    backitup.0	2021-03-28 18:01:16.192	debug	(14449) system.adapter.admin.0: logging true
    backitup.0	2021-03-28 18:01:14.902	error	Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    backitup.0	2021-03-28 18:01:14.902	error	mount error(16): Device or resource busy
    backitup.0	2021-03-28 18:01:14.902	error	(14449) Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
    backitup.0	2021-03-28 18:01:14.854	debug	(14449) first mount attempt with smb option failed. try next mount attempt without smb option ...
    backitup.0	2021-03-28 18:01:14.722	debug	(14449) [iobroker] 10 15 06 */1 * *
    backitup.0	2021-03-28 18:01:14.676	info	(14449) [iobroker] backup was activated at 06:15 every 1 day(s)
    backitup.0	2021-03-28 18:01:14.346	info	(14449) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
    crunchipC Abwesend
    crunchipC Abwesend
    @humidor sagte in Iobroker backitup error.. Wo liegt das problem:
    https://forum.iobroker.net/topic/27267/test-adapter-backitup-v2-1-x
    • HumidorH Humidor
      2.1.0
      manuelles Backup
      log
      simatecS Offline
      simatecS Offline
      simatec
      So wie es ausschaut ist bereits ein mount gesetzt
      sudo umount /opt/iobroker/backups
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      HumidorH 2 Antworten Letzte Antwort
      • simatecS simatec
        HumidorH Offline
        HumidorH Offline
        Humidor
        @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
        ioBroker fix habe ich gemacht inkl. alles was sonst noch an update usw. zu tun ist
        den unmount habe ich gerade gemacht
        ein gerader gestarteter manueller Backup startet nicht (Fenster bleibt leer)
        log von heute - files wurden am NAS angelegt, Fehlermeldung wurde versandt.
        2021-03-31 06:15:10.291 - error: backitup.0 (32188) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
        2021-03-31 06:15:10.300 - debug: backitup.0 (32188) Backup has started ...
        2021-03-31 06:15:21.081 - debug: backitup.0 (32188) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
        2021-03-31 06:15:21.161 - debug: backitup.0 (32188) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
        2021-03-31 06:15:21.163 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
        2021-03-31 06:15:21.164 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
        2021-03-31 06:15:21.165 - debug: backitup.0 (32188) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
        2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
        2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
        2021-03-31 06:15:23.856 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2149 states saved
        2021-03-31 06:15:23.889 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
        2021-03-31 06:15:27.198 - debug: backitup.0 (32188) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
        2021-03-31 06:15:28.251 - debug: backitup.0 (32188) [iobroker/iobroker] done
        2021-03-31 06:15:29.089 - debug: backitup.0 (32188) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
        2021-03-31 06:15:39.048 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 11MB so far...
        2021-03-31 06:15:49.042 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 21MB so far...
        2021-03-31 06:15:57.276 - debug: backitup.0 (32188) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-06_15_29_backupiobroker.tar.gz
        2021-03-31 06:15:57.278 - debug: backitup.0 (32188) [iobroker/historyDB] done
        2021-03-31 06:15:58.336 - debug: backitup.0 (32188) [iobroker/cifs] done
        2021-03-31 06:15:58.942 - debug: backitup.0 (32188) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
        2021-03-31 06:15:58.944 - debug: backitup.0 (32188) [iobroker/clean] done
        2021-03-31 06:15:59.413 - debug: backitup.0 (32188) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
        2021-03-31 06:15:59.425 - debug: backitup.0 (32188) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
        2021-03-31 06:15:59.428 - debug: backitup.0 (32188) [iobroker/telegram] done
        2021-03-31 06:15:59.734 - debug: backitup.0 (32188) [iobroker/historyHTML] new history html values created
        2021-03-31 06:15:59.736 - debug: backitup.0 (32188) [iobroker/historyHTML] done
        2021-03-31 06:15:59.894 - debug: backitup.0 (32188) [iobroker/historyJSON] new history json values created
        2021-03-31 06:15:59.895 - debug: backitup.0 (32188) [iobroker/historyJSON] done
        BG
        • simatecS simatec
          HumidorH Offline
          HumidorH Offline
          Humidor
          schrieb am zuletzt editiert von Humidor
          @simatec
          gerade gemacht:
          iobroker stop
          sudo apt-get update
          sudo apt-get upgrade
          iobroker fix
          curl -fsL https://iobroker.net/fix.sh | bash -
          iobroker start
          ... gewartet bis wieder alle Adapter online sind....
          manuelles Backup gestartet
          Adapter 2.0.4 - schaut gut aus, file ohne Fehler angelegt.
          2021-03-31 08:08:07.487 - debug: backitup.0 (24853) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2021-03-31 08:08:07.527 - debug: backitup.0 (24853) Objects client ready ... initialize now
          2021-03-31 08:08:07.530 - debug: backitup.0 (24853) Objects create System PubSub Client
          2021-03-31 08:08:07.531 - debug: backitup.0 (24853) Objects create User PubSub Client
          2021-03-31 08:08:07.532 - debug: backitup.0 (24853) Objects client initialize lua scripts
          2021-03-31 08:08:07.545 - debug: backitup.0 (24853) Objects connected to redis: 127.0.0.1:9001
          2021-03-31 08:08:07.554 - debug: backitup.0 (24853) objectDB connected
          2021-03-31 08:08:07.557 - debug: backitup.0 (24853) Redis States: Use Redis connection: 127.0.0.1:9000
          2021-03-31 08:08:07.565 - debug: backitup.0 (24853) States create System PubSub Client
          2021-03-31 08:08:07.566 - debug: backitup.0 (24853) States create User PubSub Client
          2021-03-31 08:08:07.574 - debug: backitup.0 (24853) States connected to redis: 127.0.0.1:9000
          2021-03-31 08:08:07.575 - debug: backitup.0 (24853) statesDB connected
          2021-03-31 08:08:08.090 - debug: backitup.0 (24853) Plugin sentry Initialize Plugin (enabled=true)
          2021-03-31 08:08:08.348 - info: backitup.0 (24853) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.0, js-controller: 3.2.16
          2021-03-31 08:08:08.446 - info: backitup.0 (24853) [iobroker] backup was activated at 06:15 every 1 day(s)
          2021-03-31 08:08:08.485 - debug: backitup.0 (24853) [iobroker] 10 15 06 */1 * *
          2021-03-31 08:08:09.122 - debug: backitup.0 (24853) mount successfully completed
          2021-03-31 08:08:11.097 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
          2021-03-31 08:08:11.205 - debug: backitup.0 (24853) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.206 - debug: backitup.0 (24853) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
          2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
          2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.209 - debug: backitup.0 (24853) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 9 from cifs: iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 10 from cifs: iobroker_2021_03_29-06_15_21_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 11 from cifs: iobroker_2021_03_30-06_15_21_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.212 - debug: backitup.0 (24853) detect backup file 12 from cifs: iobroker_2021_03_30-07_26_27_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.213 - debug: backitup.0 (24853) detect backup file 13 from cifs: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.215 - debug: backitup.0 (24853) detect last backup file: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:08:11.851 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 24897
          2021-03-31 08:08:15.998 - info: host.raspi4iobrokerpv instance system.adapter.influxdb.0 started with pid 24912
          2021-03-31 08:08:18.174 - info: influxdb.0 (24912) starting. Version 1.9.4 in /opt/iobroker/node_modules/iobroker.influxdb, node: v12.22.0, js-controller: 3.2.16
          2021-03-31 08:08:18.223 - info: influxdb.0 (24912) No stored data from last exit found
          2021-03-31 08:08:18.225 - info: influxdb.0 (24912) Connecting http://localhost:8086 ...
          2021-03-31 08:08:18.324 - info: influxdb.0 (24912) enabled logging of kecontact.0.pf, Alias=false, 1 points now activated
          2021-03-31 08:08:18.325 - info: influxdb.0 (24912) enabled logging of kecontact.0.p, Alias=false, 2 points now activated
          2021-03-31 08:08:18.326 - info: influxdb.0 (24912) enabled logging of kecontact.0.i3, Alias=false, 3 points now activated
          2021-03-31 08:08:18.327 - info: influxdb.0 (24912) enabled logging of kecontact.0.i2, Alias=false, 4 points now activated
          2021-03-31 08:08:18.328 - info: influxdb.0 (24912) enabled logging of kecontact.0.i1, Alias=false, 5 points now activated
          2021-03-31 08:08:18.329 - info: influxdb.0 (24912) enabled logging of kecontact.0.u3, Alias=false, 6 points now activated
          2021-03-31 08:08:18.330 - info: influxdb.0 (24912) enabled logging of kecontact.0.u2, Alias=false, 7 points now activated
          2021-03-31 08:08:18.331 - info: influxdb.0 (24912) enabled logging of kecontact.0.u1, Alias=false, 8 points now activated
          2021-03-31 08:08:18.332 - info: influxdb.0 (24912) enabled logging of kecontact.0.currentUser, Alias=false, 9 points now activated
          2021-03-31 08:08:18.333 - info: influxdb.0 (24912) enabled logging of kecontact.0.enableUser, Alias=false, 10 points now activated
          2021-03-31 08:08:18.334 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.170, Alias=false, 11 points now activated
          2021-03-31 08:08:18.335 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.270, Alias=false, 12 points now activated
          2021-03-31 08:08:18.336 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch, Alias=false, 13 points now activated
          2021-03-31 08:08:18.337 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power, Alias=false, 14 points now activated
          2021-03-31 08:08:18.338 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.Power, Alias=false, 15 points now activated
          2021-03-31 08:08:18.339 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30537_Tagesertrag_kWh, Alias=false, 16 points now activated
          2021-03-31 08:08:18.340 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30775_PVLeistung, Alias=false, 17 points now activated
          2021-03-31 08:08:18.341 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell, Alias=false, 18 points now activated
          2021-03-31 08:08:18.342 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40083_I_AC_Leistung, Alias=false, 19 points now activated
          2021-03-31 08:08:18.343 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40093_I_AC_Energie_WH, Alias=false, 20 points now activated
          2021-03-31 08:08:18.353 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVPower, Alias=false, 21 points now activated
          2021-03-31 08:08:18.354 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVÜberschuss, Alias=false, 22 points now activated
          2021-03-31 08:08:18.355 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuellSMA, Alias=false, 23 points now activated
          2021-03-31 08:08:18.356 - info: influxdb.0 (24912) enabled logging of fuelpricemonitor.0.zuHome_Diesel.0.prices.0.amount, Alias=false, 24 points now activated
          2021-03-31 08:08:18.357 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_170_Actual, Alias=false, 25 points now activated
          2021-03-31 08:08:18.358 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_270_Actual, Alias=false, 26 points now activated
          2021-03-31 08:08:18.359 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank, Alias=false, 27 points now activated
          2021-03-31 08:08:18.360 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank, Alias=false, 28 points now activated
          2021-03-31 08:08:18.394 - info: influxdb.0 (24912) Connected!
          2021-03-31 08:08:18.443 - debug: backitup.0 (24853) mount activ... umount in 2 Seconds!!
          2021-03-31 08:08:19.844 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 24951
          2021-03-31 08:08:20.507 - debug: backitup.0 (24853) umount successfully completed
          2021-03-31 08:08:23.918 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 24970
          2021-03-31 08:08:27.916 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 24991
          2021-03-31 08:08:31.809 - info: host.raspi4iobrokerpv instance scheduled system.adapter.zoe2.0 */10 * * * *
          2021-03-31 08:08:35.850 - info: host.raspi4iobrokerpv instance system.adapter.info.0 started with pid 25021
          2021-03-31 08:08:39.889 - info: host.raspi4iobrokerpv instance system.adapter.life360.0 started with pid 25130
          2021-03-31 08:08:43.905 - info: host.raspi4iobrokerpv instance system.adapter.fritzdect.0 started with pid 25517
          2021-03-31 08:08:47.741 - debug: backitup.0 (24853) system.adapter.admin.0: logging false
          2021-03-31 08:08:47.862 - info: host.raspi4iobrokerpv instance scheduled system.adapter.fuelpricemonitor.0 25 */20 * * * *
          2021-03-31 08:08:47.887 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 started with pid 25539
          2021-03-31 08:08:50.014 - info: fuelpricemonitor.0 (25539) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v12.22.0, js-controller: 3.2.16
          2021-03-31 08:08:51.962 - info: host.raspi4iobrokerpv instance system.adapter.virtualpowermeter.0 started with pid 25568
          2021-03-31 08:08:54.142 - info: virtualpowermeter.0 (25568) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.virtualpowermeter, node: v12.22.0, js-controller: 3.2.16
          2021-03-31 08:08:54.214 - info: virtualpowermeter.0 (25568) inital all Objects
          2021-03-31 08:08:54.394 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.170
          2021-03-31 08:08:54.506 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.170 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_170 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_170 Destination Group: virtualpowermeter.0.group_grid.
          2021-03-31 08:08:54.507 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.270
          2021-03-31 08:08:54.551 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.270 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_270 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_270 Destination Group: virtualpowermeter.0.group_grid.
          2021-03-31 08:08:54.556 - info: virtualpowermeter.0 (25568) initial fritzdect.0.DECT_116300118701.power
          2021-03-31 08:08:54.580 - info: virtualpowermeter.0 (25568) initial done fritzdect.0.DECT_116300118701.power Destination Power: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank Destination EnergyTotal: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank Destination Group: virtualpowermeter.0.group_PowerBank.
          2021-03-31 08:08:54.672 - info: virtualpowermeter.0 (25568) initial completed
          2021-03-31 08:08:54.882 - info: fuelpricemonitor.0 (25539) Terminated (NO_ERROR): Without reason
          2021-03-31 08:08:55.400 - info: fuelpricemonitor.0 (25539) cleaned everything up...
          2021-03-31 08:08:55.460 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
          2021-03-31 08:09:05.222 - debug: backitup.0 (24853) telegram-instance: telegram.0
          2021-03-31 08:09:05.227 - debug: backitup.0 (24853) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
          2021-03-31 08:09:09.554 - debug: backitup.0 (24853) Backup has started ...
          2021-03-31 08:09:20.003 - debug: backitup.0 (24853) [iobroker/mount] mount successfully completed
          2021-03-31 08:09:20.007 - debug: backitup.0 (24853) [iobroker/mount] done
          2021-03-31 08:09:22.797 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2160 states saved
          2021-03-31 08:09:22.820 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
          2021-03-31 08:09:26.163 - debug: backitup.0 (24853) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-08_09_20_ioBrokerPV_backupiobroker.tar.gz
          2021-03-31 08:09:27.265 - debug: backitup.0 (24853) [iobroker/iobroker] done
          2021-03-31 08:09:28.134 - debug: backitup.0 (24853) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
          2021-03-31 08:09:38.090 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 11MB so far...
          2021-03-31 08:09:48.187 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 21MB so far...
          2021-03-31 08:09:48.507 - debug: backitup.0 (24853) system.adapter.admin.0: logging true
          2021-03-31 08:09:56.738 - debug: backitup.0 (24853) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-08_09_28_backupiobroker.tar.gz
          2021-03-31 08:09:56.750 - debug: backitup.0 (24853) [iobroker/historyDB] done
          2021-03-31 08:09:57.815 - debug: backitup.0 (24853) [iobroker/cifs] done
          2021-03-31 08:09:58.417 - debug: backitup.0 (24853) [iobroker/clean] done
          2021-03-31 08:09:58.878 - debug: backitup.0 (24853) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
          2021-03-31 08:09:58.886 - debug: backitup.0 (24853) [iobroker/telegram] done
          2021-03-31 08:09:59.198 - debug: backitup.0 (24853) [iobroker/historyHTML] new history html values created
          2021-03-31 08:09:59.201 - debug: backitup.0 (24853) [iobroker/historyHTML] done
          2021-03-31 08:09:59.367 - debug: backitup.0 (24853) [iobroker/historyJSON] new history json values created
          2021-03-31 08:09:59.369 - debug: backitup.0 (24853) [iobroker/historyJSON] done
          2021-03-31 08:09:59.565 - debug: backitup.0 (24853) [iobroker/umount] mount activ, umount is started ...
          2021-03-31 08:10:00.114 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 started with pid 25752
          2021-03-31 08:10:04.622 - debug: backitup.0 (24853) [iobroker/umount] umount successfully completed
          2021-03-31 08:10:04.623 - debug: backitup.0 (24853) [iobroker/umount] done
          2021-03-31 08:10:04.775 - debug: backitup.0 (24853) [iobroker] exec: done
          BG
            arne007
            Habe meinen Pi komplett neu aufgesetzt und wollte jetzt influxDB und Grafana aus dem Backup wiederherstellen. Bekomme jedoch nur folgende Fehlermeldung. Weiß jmd wie ich das Problem löse.
            ckitup.0
            2021-11-26 10:56:12.941	error	[influxDB] infuxDB Restore not completed
            backitup.0
            2021-11-26 10:56:12.939	error	[influxDB] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/influxDBtmp/'
            backitup.0
            2021-11-26 10:49:31.947	error	[grafana] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/grafana_tmp/'
            backitup.0
            2021-11-26 10:49:31.945	error	[grafana] Grafana restore not completed
            backitup.0
            2021-11-26 10:49:20.599	error	Error: Command failed: sudo mount -t cifs -o username=Arne,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.10/homes/Backup_ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
            backitup.0
            2021-11-26 10:49:09.218	error	[influxDB] infuxDB Restore not completed
            backitup.0
            2021-11-26 10:49:09.211	error	[influxDB] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/influxDBtmp/'
            • A arne007
              ckitup.0
              backitup.0
              backitup.0
              backitup.0
              backitup.0
              backitup.0
              backitup.0
              simatecS Offline
              simatecS Offline
              simatec
              @arne007 sagte in Iobroker backitup error.. Wo liegt das problem:
              Du hast keine Schreibrechte. Wo liegt das Backup? Versuchst du den restore lokal oder über NAS oder der Gleichen herzustellen?
              • simatecS simatec
                arne007
                schrieb am zuletzt editiert von arne007
                @simatec said in Iobroker backitup error.. Wo liegt das problem:
                über NAS. Welche Schreibrechte muss ich wie / wo ändern?
                • A arne007
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @arne007 Mit den Angaben von dir kann ich dir das nicht beantworten.
                  cifs-utils installiert?
                  NAS konfiguriert?
                  NAS Config und Backitup Config?
                  fu_zhouF 1 Antwort Letzte Antwort
                  • simatecS simatec
                    NAS konfiguriert?
                    fu_zhouF Online
                    fu_zhouF Online
                    fu_zhou
                    @simatec Mhm... ich habe das selbe Problem. Backups werden auf dem NAS angelegt, CIFS-utils sind installiert, die Backups werden auch auf dem NAS gefunden und angezeigt, nur wiederherstellen möchte Backitup nicht:
                    eError: {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                    Synology DS920+ VM, S7-315 PN mit ET200S
                    • fu_zhouF fu_zhou
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @fu_zhou Bitte poste den vollständigen Debuglog und deine Config. Was nutzt du für ein NAS und was hast du dort für Einstellungen?
                      • simatecS simatec
                        fu_zhouF Online
                        fu_zhouF Online
                        fu_zhou
                        @simatec Das ist ein älterer Synology Diskstation DS411j.
                        Der in Backitup eingetragene Nutzer hat volle Rechte auf die Ordner, es ist SMB, FTP aktiviert, AFP, NFS, rsync sind nicht aktiviert.
                        Config sieht so aus:
                        Beim SMB Typ habe ich mal auf Verdacht SMB3.0 eingetragen, im NAS kann man SMB3 einstellen, nicht 3.0.2 oder 3.1.1
                        Wie gesagt, die Backups werden auf dem NAS gemacht.
                        Debuglog kommt morgen noch.
                        Danke schon mal!
                        HumidorH 1 Antwort Letzte Antwort
                        • fu_zhouF fu_zhou
                          Danke schon mal!
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          @fu_zhou ich habe SMB 2.0, 3.0 hatte bei mir auch Fehler ausgegeben
                          BG
                          • HumidorH Humidor
                            fu_zhouF Online
                            fu_zhouF Online
                            fu_zhou
                            @humidor Hat nichts geholfen, ich glaube, es liegt an den Rechten (gibt schon einen Thread dazu unter dem Stichwort "utime"). Muss ich mich mal mit beschäftigen, wie das mit den Rechten auf dem NAS ist. Wenn der NAS-Ordner gemountet wird (in /opt/iobroker/backups) gehört der Ordner "backups" root root, kann ich auch nicht ändern mit chown oder so.
                            • stony2kS Offline
                              stony2kS Offline
                              stony2k
                              Ich bin vom Raspberry Pi zu Proxmos auf einem LCX Container gewechselt. Hier arbeite ich direkt mit dem User root. Mein Backup liegt auf einem NAS. Leider kann ich mein InfluxDB Backup nicht einspielen. Hier ist die Log:
                              2021-12-05 09:58:45.783 - debug: backitup.0 (5245) nfs-mount command: "sudo mount stony-nas:volume1/public/Sicherungen/ioBroker /opt/iobroker/backups"
                              2021-12-05 09:58:45.805 - debug: backitup.0 (5245) device is busy... wait 2 Minutes!!
                              2021-12-05 09:58:45.856 - debug: backitup.0 (5245) mount successfully completed
                              2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 1 from cifs: iobroker_2021_10_10-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 2 from cifs: iobroker_2021_10_13-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 3 from cifs: iobroker_2021_10_16-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.898 - debug: backitup.0 (5245) detect backup file 4 from cifs: iobroker_2021_10_19-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 5 from cifs: iobroker_2021_10_22-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 6 from cifs: iobroker_2021_10_25-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 7 from cifs: iobroker_2021_10_28-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 8 from cifs: iobroker_2021_10_31-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 9 from cifs: iobroker_2021_11_01-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 10 from cifs: iobroker_2021_11_04-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 11 from cifs: iobroker_2021_11_07-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 12 from cifs: iobroker_2021_11_10-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.899 - debug: backitup.0 (5245) detect backup file 13 from cifs: iobroker_2021_11_13-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 14 from cifs: iobroker_2021_11_16-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 15 from cifs: iobroker_2021_11_19-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 16 from cifs: iobroker_2021_11_22-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 17 from cifs: iobroker_2021_11_25-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 18 from cifs: iobroker_2021_11_28-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 19 from cifs: iobroker_2021_12_01-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 20 from cifs: iobroker_2021_12_04-02_00_20_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 21 from cifs: iobroker_2021_12_04-22_32_23_backupiobroker.tar.gz
                              2021-12-05 09:58:47.900 - debug: backitup.0 (5245) detect backup file 22 from cifs: iobroker_2021_12_05-09_43_18_backupiobroker.tar.gz
                              2021-12-05 09:58:47.901 - debug: backitup.0 (5245) detect last backup file: iobroker_2021_12_05-09_43_18_backupiobroker.tar.gz
                              2021-12-05 09:58:49.723 - debug: backitup.0 (5245) sendTo "getSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0: linux
                              2021-12-05 09:58:51.268 - debug: backitup.0 (5245) nfs-mount command: "sudo mount stony-nas:volume1/public/Sicherungen/ioBroker /opt/iobroker/backups"
                              2021-12-05 09:58:51.271 - debug: backitup.0 (5245) Backup list be read ...
                              2021-12-05 09:58:51.284 - debug: backitup.0 (5245) device is busy... wait 2 Minutes!!
                              2021-12-05 09:58:51.331 - debug: backitup.0 (5245) mount successfully completed
                              2021-12-05 09:58:53.335 - debug: backitup.0 (5245) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                              2021-12-05 09:58:55.755 - debug: backitup.0 (5245) mount activ... umount in 2 Seconds!!
                              2021-12-05 09:58:57.092 - debug: backitup.0 (5245) [influxDB] Try deleting the old InfluxDB tmp directory
                              2021-12-05 09:58:57.094 - debug: backitup.0 (5245) [influxDB] Created tmp directory
                              2021-12-05 09:58:57.095 - debug: backitup.0 (5245) [influxDB] Start infuxDB Restore ...
                              2021-12-05 09:58:57.125 - error: backitup.0 (5245) [influxDB] Error: EACCES: permission denied, utime '/opt/iobroker/backups/influxDBtmp/'
                              2021-12-05 09:58:57.125 - error: backitup.0 (5245) [influxDB] infuxDB Restore not completed
                              Der NAS Zugriff funztioniert. Auch konnte ich über den Adapter das, auf dem NAS befindliche, ioBroker Backup wieder einspielen. Der user iobroker hat auf den Ordner auch Rechte:
                              root@iobroker:~# ls -la /opt/iobroker/backups
                              total 8
                              drwxrwxrwx+ 2 iobroker iobroker 4096 Dec  4 21:32 .
                              drwxrwxr-x+ 6 iobroker iobroker 4096 Dec  5 09:55 ..
                              Könnt ihr mir helfen?
                              simatecS Thomas BraunT 2 Antworten Letzte Antwort
                              • stony2kS stony2k
                                total 8
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @stony2k Wie im Log zu sehen, hast du ein Rechteproblem.
                                Da du mit komplett mit root unterwegs bist, würde ich dir raten, nochmal von vorne anzufangen und dann mit einer vernünftigen Userstruktur arbeiten
                                • stony2kS stony2k
                                  total 8
                                  @stony2k sagte in Iobroker backitup error.. Wo liegt das problem:
                                  Warum? Das macht man nicht.
                                  stony2kS 1 Antwort Letzte Antwort
                                    stony2kS Offline
                                    stony2kS Offline
                                    stony2k
                                    @thomas-braun Weil das der Standardnutzer im Container war. Aber ich gebe dir recht. Aktuell probiere ich aus, wie sich das in einer virtuellen Maschine verhält, außerhalb von einem Container. Hier werde ich auch mit einem nicht-root User arbeiten.
                                    • stony2kS stony2k
                                      Es sollte genauso Standard und erste Aktion im Container sein sich einen User anzulegen.
                                        stony2kS Offline
                                        stony2kS Offline
                                        stony2k
                                        Update: Ich habe eine VM, anstatt eines Containers mit debian aufgesetzt, den ioBroker installiert und wie @thomas-braun vorgeschlagen (danke dir) einen normalen Benutzer erstellt.
                                        Jetzt hat der Restore der InfluxDB ohne Probleme geklappt.
                                        • E Offline
                                          elmos04
                                          Hallo
                                          Ich habe das Problem nun auch.
                                          Mein Problem fing an das der ioBroker nicht mehr startet. ich habe Fix ausprobiert. Alles ohne erfolg. Ich hatte ein Funktionierendes Backup auf dem NAS.
                                          Also ioBroker neu aufgesetzt Den BackitUp Adapter eingerichtet. ein neues Backup im gleichen Verzeichnis auf dem NAS erstellt und dann wieder hergestellt von einem alten Backup.
                                          Seit dem macht er kein ioBroker Backup. Fehler 6-Fachtaster VIS. ????
                                          Zigbee und JavaScript gehen.
                                          Ich bin echt ein Looser im Terminal. Ich weiss was ihr hier so alles macht. Kann mir jemand verständlich 🤡 erklären was das soll und wie ich es kann?
                                          Also was ich gut kann ist copy und Paste ins Terminal. ;-)
                                          Mehr geht wirklich nicht.....
                                          Hier ist mal ein Log. File. vielleicht kann ja damit ein Profi was anfangen.
                                          [DEBUG] [mount] - mount activ... umount is started before mount!!
                                          [DEBUG] [mount] - umount successfully completed
                                          [DEBUG] [mount] - noserverino option: true
                                          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ElmoS04,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.31/home/ioBrokerVis /opt/iobroker/backups"
                                          [DEBUG] [mount] - mount successfully completed
                                          [DEBUG] [mount] - done
                                          [DEBUG] [iobroker] - host.raspberrypi 8760 states saved
                                          [DEBUG] [iobroker] - host.raspberrypi 10657 objects saved
                                          [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json is not a valid json file
                                          [DEBUG] [zigbee] - found zigbee database: zigbee.0
                                          [DEBUG] [zigbee] - done
                                          [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                          [DEBUG] [javascripts] - found Script: Garagentor_Status
                                          [DEBUG] [javascripts] - found Script: Taster_6Fach
                                          [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
                                          [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
                                          [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
                                          [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
                                          [DEBUG] [javascripts] - found Script: Gast_Wlan
                                          [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
                                          [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
                                          [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
                                          [DEBUG] [javascripts] - found Script: Überwachung_Temp
                                          [DEBUG] [javascripts] - found Script: Rauchmelder
                                          [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
                                          [DEBUG] [javascripts] - found Script: Xiaomi_Taster
                                          [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
                                          [DEBUG] [javascripts] - found Script: Ikea_Taster_
                                          [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
                                          [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
                                          [DEBUG] [javascripts] - found Script: Duty_Cycle
                                          [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
                                          [DEBUG] [javascripts] - found Script: Einbruch_erkannt
                                          [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                                          [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                          [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-11_17_12_ioBroker_backupiobroker.tar.gz
                                          [DEBUG] [javascripts] - done
                                          [ERROR] [ftp] - [IGNORED] Error: Login incorrect.
                                          [DEBUG] [umount] - mount activ, umount is started ...
                                          [DEBUG] [umount] - umount successfully completed
                                          [DEBUG] [umount] - done
                                          [EXIT] 26
                                          t.raspberrypi
                                          2022-02-13 11:15:04.177	info	instance system.adapter.coronavirus-statistics.0 started with pid 30238
                                          dwd.0
                                          2022-02-13 11:15:03.830	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          dwd.0
                                          2022-02-13 11:15:02.108	info	starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.19.0, js-controller: 3.3.22
                                          host.raspberrypi
                                          2022-02-13 11:15:00.142	info	instance system.adapter.dwd.0 started with pid 30212
                                          backitup.0
                                          2022-02-13 11:13:06.852	error	Error: Login incorrect.
                                          backitup.0
                                          2022-02-13 11:13:00.248	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                                          backitup.0
                                          2022-02-13 11:12:59.755	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
                                          host.raspberrypi
                                          2022-02-13 11:12:57.946	info	instance system.adapter.backitup.0 started with pid 29900
                                          host.raspberrypi
                                          2022-02-13 11:12:55.461	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          backitup.0
                                          2022-02-13 11:12:54.879	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          backitup.0
                                          2022-02-13 11:12:54.877	info	terminating
                                          backitup.0
                                          2022-02-13 11:12:54.875	info	cleaned everything up...
                                          backitup.0
                                          2022-02-13 11:12:54.872	info	Got terminate signal TERMINATE_YOURSELF
                                          host.raspberrypi
                                          2022-02-13 11:12:54.872	info	stopInstance system.adapter.backitup.0 send kill signal
                                          host.raspberrypi
                                          2022-02-13 11:12:54.824	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
                                          backitup.0
                                          2022-02-13 11:12:47.687	error	Error: Login incorrect.
                                          backitup.0
                                          2022-02-13 11:12:41.398	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                                          backitup.0
                                          2022-02-13 11:12:40.898	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
                                          host.raspberrypi
                                          2022-02-13 11:12:39.119	info	instance system.adapter.backitup.0 started with pid 29755
                                          host.raspberrypi
                                          2022-02-13 11:12:36.652	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          backitup.0
                                          2022-02-13 11:12:36.043	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          backitup.0
                                          2022-02-13 11:12:36.041	info	terminating
                                          backitup.0
                                          2022-02-13 11:12:36.040	info	cleaned everything up...
                                          host.raspberrypi
                                          2022-02-13 11:
                                          MOD-Edit: Code in code-tags gesetzt!
                                          Ich währe euch sehr dankbar. ich sitze hier schon seit Tagen dran alles wieder einzustellen. Ein Backup ist echt wichtig.
