  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • Fred FreundF Fred Freund
    @simatec
    DEBUG] [iobroker] - host.broker1 1195 states saved
    [DEBUG] [iobroker] - host.broker1 1570 objects saved
    [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz'
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1,zigbee.2
    [DEBUG] [zigbee] - done
    [ERROR] [zigbee] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz'
    [DEBUG] [cifs] - Copy iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy zigbee.1_2021_03_24-22_46_03_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy zigbee.2_2021_03_24-22_46_03_backupiobroker.tar.gz...
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/home/iobroker","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,
    Das Backup hat wieder Größe 0
    Der Ordner am smb share
    drwxrwxrwx  3 1000 1000      4096 Mär 24 22:46 iobroker
    rw-r--r--  1 1000 1000       0 Mär 24 22:39 zigbee.1_2021_03_24-22_39_23_backupiobroker.tar.gz
    simatecS Offline
    simatecS Offline
    simatec
    @fred-freund
    Dann hast du ein Rechteproblem.
    Hast du iobroker fix bereits ausgeführt?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    Fred FreundF 1 Antwort Letzte Antwort
    • simatecS simatec
      @fred-freund
      Fred FreundF Offline
      Fred Freund
      schrieb am zuletzt editiert von Fred Freund
      @simatec
      Ja gestern 2x
      Mach ich jetzt auch nochmal... Je nachdem welche smb Version ich verwende ändert sich auch die Error Meldung..
      2021-03-24 23:00:26.538  - error: backitup.0 (27502) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
      Smb 3.1.1
      Fix hat nix gebracht... :-(
      many Thx for your support,
      Vielen Dank!
        @simatec
        Ja gestern 2x
        Smb 3.1.1
        simatecS Offline
        simatecS Offline
        simatec
        @fred-freund
        Bitte vollständigen Log posten
        • simatecS simatec
          @fred-freund
          Fred Freund
          @simatec
          2021-03-25 20:58:44.655  - warn: backitup.0 (29557) backup error: TypeError: Converting circular structure to JSON
             --> starting at object with constructor 'DerivedLogger'
             |     property '_readableState' -> object with constructor 'ReadableState'
             |     property 'pipes' -> object with constructor 'Array'    |     index 0 -> object with constructor 'DailyRotateFile'
             --- property 'parent' closes the circle ... please check your config and try again!!
          2021-03-25 20:58:50.903  - warn: zigbee.0 (29458) Device '0x5c0272fffe895fc7' announced itself
          2021-03-25 21:00:15.356  - warn: backitup.0 (29557) backup error: TypeError: Converting circular structure to JSON
          2021-03-25 21:01:50.628  - info: host.broker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
          2021-03-25 21:01:50.640  - info: backitup.0 (29557) Got terminate signal TERMINATE_YOURSELF
          2021-03-25 21:01:50.645  - info: host.broker1 stopInstance system.adapter.backitup.0 send kill signal
          2021-03-25 21:01:50.642  - info: backitup.0 (29557) cleaned everything up...
          2021-03-25 21:01:50.643  - info: backitup.0 (29557) terminating
          2021-03-25 21:01:50.645  - info: backitup.0 (29557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2021-03-25 21:01:51.256  - info: host.broker1 instance system.adapter.backitup.0 terminated with cpi@broker1:~ $ cat /opt/iobroker/log/iobroker.current.log
             --> starting at object with constructor 'DerivedLogger'                                           |     property '_readableState' -> object with constructor 'ReadableState'
          2021-03-25 21:01:51.256  - info: host.broker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-03-25 21:01:53.710  - info: host.broker1 instance system.adapter.backitup.0 started with pid 8864
          2021-03-25 21:01:57.240  - info: backitup.0 (8864) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
          2021-03-25 21:01:57.340  - info: backitup.0 (8864) [iobroker] backup was activated at 02:40 every 1 day(s)
          pi@broker1:~ $
          Smb 1.0
          Vielen Dank!
            @simatec
            pi@broker1:~ $
            Smb 1.0
            simatecS Offline
            simatecS Offline
            simatec
            @fred-freund
            Dein System scheint mächtig in Schieflage zu sein.
            Was passiert denn, wenn du iobroker backup über die Konsole ausführst?
            Hast du Backitup mal komplett deinstalliert (Instanz und Adapter)? Wenn nicht, mach das mal bitte und installiere in Anschluss neu.
            Hoffe du hast npm nirgends mit sudo ausgeführt.
            Dein System wirft sehr komische Dinge im Log
            • simatecS simatec
              @fred-freund
              Fred Freund
              @simatec said in Iobroker backitup error.. Wo liegt das problem:
              pi@broker1:~ $ iobroker stop && iobroker backup && iobroker start
              Backup created: /opt/iobroker/backups/2021_03_26-20_53_35_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001 3540091 Mar 26 20:53 2021_03_26-20_53_35_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001   87112 Mar 26 02:00 zigbee.0_2021_03_26-02_00_27_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001    1655 Mar 26 02:00 zigbee.1_2021_03_26-02_00_27_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001      87 Mar 26 02:00 zigbee.2_2021_03_26-02_00_27_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001 3540945 Mar 26 02:00 iobroker_2021_03_26-02_00_20_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001 3539146 Mar 25 21:23 2021_03_25-21_23_06_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001   86633 Mar 25 02:40 zigbee.0_2021_03_25-02_40_27_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001    1655 Mar 25 02:40 zigbee.1_2021_03_25-02_40_27_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001      87 Mar 25 02:40 zigbee.2_2021_03_25-02_40_27_backupiobroker.tar.gz
              -rw-rw-r--+ 1 1001 1001 3524666 Mar 25 02:40 iobroker_2021_03_25-02_40_20_backupiobroker.tar.gz
              ich suchte mal ob ich mit sudo was installierte, nix gefunden...
              pi@broker1:~ $ history | grep npm
                234  npm install node-red-contrib-schedex
              history | grep curl
                 78  curl -slf https://deb.nodesource.com/setup_12.x | sudo -E bash -
                 80  curl -slf https://deb.nodesource.com/setup_14.x | sudo -E bash -
                 82  curl -sLF https://ipbroker.net/install.sh | bash -
                 83  curl -sLf https://ipbroker.net/install.sh | bash -
                 84  curl -sLf https://iobroker.net/install.sh | bash -
              clean from the history
                 79  sudo apt-get install -y node.js
                 81  sudo apt-get install -y node.js
                 85  iobroker plugin disable sentry
              Die um 02:40 sind die automatischen...ob die gehen? das share
              Die manuell aus dem adapter gestarteten haben andere Rechte..ausserdem sieht es fuer mich so aus als wuerde das Backup gleich einige male gestartet!! siehe 23:07???
              -rw-rwxr--+ 1 1001 1001 3519796 Mar 24 23:07 2021_03_24-20_46_07_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_24-20_33_43_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_24-20_34_57_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3519979 Mar 24 23:07 iobroker_2021_03_24-20_33_36_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3520465 Mar 24 23:07 iobroker_2021_03_24-20_34_50_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001   85264 Mar 24 23:07 zigbee.0_2021_03_24-20_34_58_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001    1667 Mar 24 23:07 zigbee.1_2021_03_24-20_34_58_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3339610 Mar 24 23:07 2021_03_09-21_18_54_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_23-19_58_42_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001     991 Mar 24 23:07 influxDB_2021_03_23-20_04_52_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001     990 Mar 24 23:07 influxDB_2021_03_23-20_06_27_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001     989 Mar 24 23:07 influxDB_2021_03_23-20_31_52_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001     990 Mar 24 23:07 influxDB_2021_03_23-20_32_46_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3516990 Mar 24 23:07 iobroker_2021_03_23-19_58_36_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3517122 Mar 24 23:07 iobroker_2021_03_23-20_04_46_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3517072 Mar 24 23:07 iobroker_2021_03_23-20_06_20_Iobroker1_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3517129 Mar 24 23:07 iobroker_2021_03_23-20_31_45_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001 3517069 Mar 24 23:07 iobroker_2021_03_23-20_32_40_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001   83731 Mar 24 23:07 zigbee.0_2021_03_23-19_58_43_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001   83731 Mar 24 23:07 zigbee.0_2021_03_23-20_04_53_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001   83731 Mar 24 23:07 zigbee.0_2021_03_23-20_06_28_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001   83736 Mar 24 23:07 zigbee.0_2021_03_23-20_31_53_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001   83736 Mar 24 23:07 zigbee.0_2021_03_23-20_32_47_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-19_58_43_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_04_53_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_06_28_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_31_53_backupiobroker.tar.gz
              -rw-rwxr--+ 1 1001 1001    1669 Mar 24 23:07 zigbee.1_2021_03_23-20_32_47_backupiobroker.tar.gz
              Hier das share, dies sind alle leer
              eigentlich kann ich ja ein script schreiben der das gemachte consolen backup dann auf den share kopiert...bzw dieses mit cron startet.
              Sind die node red flows jetzt auch gebackupt?
              Vielen Dank!
                history | grep curl
                simatecS Offline
                simatecS Offline
                simatec
                @fred-freund
                Ehrlich gesagt, weiß ich nicht was du da genau machst. Irgendwas ist an deiner Config schief und die Rechte vom NAS sind auch wohl ein Problem. Des Weiteren sind deine Logs vom 24.3. und nicht die aktuellen. Du solltest die Rechte wie in meinem letzten Post mal anpassen und mal nur lokal das Backup fahren.
                Sonst bekommen wir deine Probleme nicht eingedämmt. Dafür ist dein Input zu mau und die Fehler zu viel
                • simatecS simatec
                  @fred-freund
                  Fred Freund
                  Ich habe jetzt zum Backup folder einen direkten share erstellt im smb.
                  Jetzt funktioniert es! Bekomme ein Backup und keine Fehlermeldung mehr.
                  Warum bekomme ich zigbee. 0.. 1...2 backups obwohl ich nur zigbee.0 instance habe.
                  Und Node red ist das jetzt auch im Backup?
                  Danke!
                  Vielen Dank!
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    @fred-freund
                    Dann existieren bei dir diese 3 zigbee Unterordner
                    Auf meine Fragen habe ich noch immer keine Antwort bekommen.
                    Dementsprechend kann ich hier auch nicht weiterhelfen
                    • simatecS simatec
                      @fred-freund
                      Fred Freund
                      @simatec. Alles Gut!
                      Started iobroker ...
                      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"}
                      [DEBUG] [mount] - mount successfully completed
                      [DEBUG] [mount] - done
                      [DEBUG] [iobroker] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"backupDir":"/opt/iobroker/backups"}
                      [DEBUG] [iobroker] - host.broker1 1195 states saved
                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz
                      [DEBUG] [influxDB] - Start InfluxDB Backup ...
                      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                      [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz
                      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                      [DEBUG] [influxDB] - done
                      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                      [DEBUG] [historyHTML] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.1_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.2_2021_03_27-07_24_52_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"],"types":["iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en","time":"27. March 2021 at 07:24 Hours"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"backupDir":"/opt/iobroker/backups"}
                      [DEBUG] [umount] - mount activ, umount is started ...
                      [DEBUG] [historyJSON] start with {"type":"creator","time":"12:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_27-07_24_44_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_03_27-07_24_51_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.1_2021_03_27-07_24_52_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.2_2021_03_27-07_24_52_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"],"types":["iobroker","influxDB","zigbee.2","zigbee.1","zigbee.0"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":"8088","exe":"","dbType":"local"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"en","time":"27. March 2021 at 07:24 Hours"},"backupDir":"/opt/iobroker/backups"}
                      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/iobroker/backups","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups"}
                      [DEBUG] [umount] - umount successfully completed
                      [DEBUG] [umount] - done
                      [EXIT] 0
                      2021-03-27 07:24:31.466  - error: backitup.0 (746) umount: /opt/iobroker/backups: not mounted.
                      Wo finde ich die zigbee Ordner?
                      Und herzlichen Dank für deine Geduld.
                      Vielen Dank!
                      HumidorH 1 Antwort Letzte Antwort
                        [EXIT] 0
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        @fred-freund hi, hab auch das Thema gerade, nach Update geht er nicht mehr
                        siehe meinen https://forum.iobroker.net/topic/43664/iobackup-log-meldung-und-fehler/4?_=1616921423478
                        hab auf 2.0.4 downgegrades und es läuft wieder einwandfrei.
                        wenn ich das richtig verfolgen kann dann startet er den mount nicht
                        BG
                        • HumidorH Humidor
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @humidor
                          Was genau geht denn nicht bei dir? Etwas mehr Input außer einen Schnipsel aus dem Log wäre gut
                          • simatecS simatec
                            @humidor
                            HumidorH Offline
                            HumidorH Offline
                            Humidor
                            @simatec wo soll ich jetzt antworten, hier oder in meinem Thread 🤔
                            BG
                            • HumidorH Humidor
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @humidor Eigentlich gibt es einen Thread für Backitup
                              Versuche mal die aktuelle Version 2.1.0 zu installieren und poste damit mal den Log
                              • simatecS simatec
                                HumidorH Offline
                                HumidorH Offline
                                Humidor
                                schrieb am zuletzt editiert von Humidor
                                @simatec hab einen aus 2019 gefunden, das wirds wohl nich sein ?
                                2.1.0
                                manuelles Backup
                                [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"}
                                [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                mount error(16): Device or resource busy
                                Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                [DEBUG] [iobroker] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                [DEBUG] [iobroker] - host.raspi4iobrokerpv 2093 states saved
                                [DEBUG] [iobroker] - host.raspi4iobrokerpv 2538 objects saved
                                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
                                [DEBUG] [historyDB] - compress from historyDB started ...
                                [DEBUG] [historyDB] - Packed 9MB so far...
                                [DEBUG] [historyDB] - Packed 19MB so far...
                                [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
                                [DEBUG] [historyDB] - done
                                [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                                [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
                                [DEBUG] [telegram] - done
                                [DEBUG] [telegram] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                [DEBUG] [historyHTML] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                [DEBUG] [historyJSON] start with {"type":"creator","time":"06:15","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerPV","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups\nmount error(16): Device or resource busy\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":["iobroker","historyDB"],"types":["iobroker","historyDB"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data/history/"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Maerz 2021 um 18:02 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.0.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"NAS","deleteOldBackup":true,"ownDir":true,"dir":"/backup/iobroker","dirMinimal":"/backup/iobroker","user":"iobackup","pass":"****","backupDir":"/opt/iobroker/backups"}
                                log
                                backitup.0	2021-03-28 18:03:24.952	debug	(14449) system.adapter.admin.0: logging true
                                backitup.0	2021-03-28 18:02:39.560	debug	(14449) [iobroker/historyJSON] done
                                backitup.0	2021-03-28 18:02:39.559	debug	(14449) [iobroker/historyJSON] new history json values created
                                backitup.0	2021-03-28 18:02:39.394	debug	(14449) [iobroker/historyHTML] done
                                backitup.0	2021-03-28 18:02:39.392	debug	(14449) [iobroker/historyHTML] new history html values created
                                backitup.0	2021-03-28 18:02:39.081	debug	(14449) [iobroker/telegram] done
                                backitup.0	2021-03-28 18:02:39.079	debug	(14449) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                                backitup.0	2021-03-28 18:02:39.065	debug	(14449) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                                backitup.0	2021-03-28 18:02:38.602	debug	(14449) [iobroker/clean] done
                                backitup.0	2021-03-28 18:02:38.600	debug	(14449) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                backitup.0	2021-03-28 18:02:37.995	debug	(14449) [iobroker/cifs] done
                                backitup.0	2021-03-28 18:02:36.935	debug	(14449) [iobroker/historyDB] done
                                backitup.0	2021-03-28 18:02:36.909	debug	(14449) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_28-18_02_07_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:02:27.441	debug	(14449) [iobroker/historyDB] Packed 19MB so far...
                                backitup.0	2021-03-28 18:02:17.442	debug	(14449) [iobroker/historyDB] Packed 9MB so far...
                                backitup.0	2021-03-28 18:02:07.439	debug	(14449) [iobroker/historyDB] compress from historyDB started ...
                                backitup.0	2021-03-28 18:02:06.682	debug	(14449) [iobroker/iobroker] done
                                backitup.0	2021-03-28 18:02:05.589	debug	(14449) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:02:02.046	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2538 objects saved
                                backitup.0	2021-03-28 18:02:02.019	debug	(14449) [iobroker/iobroker] host.raspi4iobrokerpv 2093 states saved
                                backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                backitup.0	2021-03-28 18:01:59.328	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
                                backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker
                                backitup.0	2021-03-28 18:01:59.327	debug	(14449) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                backitup.0	2021-03-28 18:01:59.326	debug	(14449) [iobroker/mount] mount error(16): Device or resource busy
                                backitup.0	2021-03-28 18:01:59.325	debug	(14449) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroke
                                backitup.0	2021-03-28 18:01:59.238	debug	(14449) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                                backitup.0	2021-03-28 18:01:55.647	debug	(14449) system.adapter.admin.0: logging false
                                backitup.0	2021-03-28 18:01:49.159	debug	(14449) Backup has started ...
                                backitup.0	2021-03-28 18:01:49.156	error	(14449) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                                backitup.0	2021-03-28 18:01:47.336	debug	(14449) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
                                backitup.0	2021-03-28 18:01:47.333	debug	(14449) telegram-instance: telegram.0
                                backitup.0	2021-03-28 18:01:24.555	debug	(14449) Start all Adapter after Restore enabled
                                backitup.0	2021-03-28 18:01:16.924	debug	(14449) detect last backup file: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.921	debug	(14449) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.920	debug	(14449) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.919	debug	(14449) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.918	debug	(14449) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.917	debug	(14449) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.916	debug	(14449) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.915	debug	(14449) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.913	debug	(14449) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
                                backitup.0	2021-03-28 18:01:16.192	debug	(14449) system.adapter.admin.0: logging true
                                backitup.0	2021-03-28 18:01:14.902	error	Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                backitup.0	2021-03-28 18:01:14.902	error	mount error(16): Device or resource busy
                                backitup.0	2021-03-28 18:01:14.902	error	(14449) Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                backitup.0	2021-03-28 18:01:14.854	debug	(14449) first mount attempt with smb option failed. try next mount attempt without smb option ...
                                backitup.0	2021-03-28 18:01:14.722	debug	(14449) [iobroker] 10 15 06 */1 * *
                                backitup.0	2021-03-28 18:01:14.676	info	(14449) [iobroker] backup was activated at 06:15 every 1 day(s)
                                backitup.0	2021-03-28 18:01:14.346	info	(14449) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
                                BG
                                wendy2702W crunchipC simatecS 3 Antworten Letzte Antwort
                                • HumidorH Humidor
                                  2.1.0
                                  manuelles Backup
                                  log
                                  wendy2702W Online
                                  wendy2702W Online
                                  @humidor sagte in Iobroker backitup error.. Wo liegt das problem:
                                  • HumidorH Humidor
                                    2.1.0
                                    manuelles Backup
                                    log
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    https://forum.iobroker.net/topic/27267/test-adapter-backitup-v2-1-x
                                    • HumidorH Humidor
                                      2.1.0
                                      manuelles Backup
                                      log
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      So wie es ausschaut ist bereits ein mount gesetzt
                                      sudo umount /opt/iobroker/backups
                                      HumidorH 2 Antworten Letzte Antwort
                                      • simatecS simatec
                                        HumidorH Offline
                                        HumidorH Offline
                                        Humidor
                                        @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
                                        ioBroker fix habe ich gemacht inkl. alles was sonst noch an update usw. zu tun ist
                                        den unmount habe ich gerade gemacht
                                        ein gerader gestarteter manueller Backup startet nicht (Fenster bleibt leer)
                                        log von heute - files wurden am NAS angelegt, Fehlermeldung wurde versandt.
                                        2021-03-31 06:15:10.291 - error: backitup.0 (32188) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                                        2021-03-31 06:15:10.300 - debug: backitup.0 (32188) Backup has started ...
                                        2021-03-31 06:15:21.081 - debug: backitup.0 (32188) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                                        2021-03-31 06:15:21.161 - debug: backitup.0 (32188) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                        2021-03-31 06:15:21.163 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
                                        2021-03-31 06:15:21.164 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                        2021-03-31 06:15:21.165 - debug: backitup.0 (32188) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,domain=NAS,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/backup/iobroker /opt/iobroker/backups
                                        2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] mount error(16): Device or resource busy
                                        2021-03-31 06:15:21.166 - debug: backitup.0 (32188) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                        2021-03-31 06:15:23.856 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2149 states saved
                                        2021-03-31 06:15:23.889 - debug: backitup.0 (32188) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
                                        2021-03-31 06:15:27.198 - debug: backitup.0 (32188) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                                        2021-03-31 06:15:28.251 - debug: backitup.0 (32188) [iobroker/iobroker] done
                                        2021-03-31 06:15:29.089 - debug: backitup.0 (32188) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
                                        2021-03-31 06:15:39.048 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 11MB so far...
                                        2021-03-31 06:15:49.042 - debug: backitup.0 (32188) [iobroker/historyDB] Packed 21MB so far...
                                        2021-03-31 06:15:57.276 - debug: backitup.0 (32188) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-06_15_29_backupiobroker.tar.gz
                                        2021-03-31 06:15:57.278 - debug: backitup.0 (32188) [iobroker/historyDB] done
                                        2021-03-31 06:15:58.336 - debug: backitup.0 (32188) [iobroker/cifs] done
                                        2021-03-31 06:15:58.942 - debug: backitup.0 (32188) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                        2021-03-31 06:15:58.944 - debug: backitup.0 (32188) [iobroker/clean] done
                                        2021-03-31 06:15:59.413 - debug: backitup.0 (32188) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                                        2021-03-31 06:15:59.425 - debug: backitup.0 (32188) sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                                        2021-03-31 06:15:59.428 - debug: backitup.0 (32188) [iobroker/telegram] done
                                        2021-03-31 06:15:59.734 - debug: backitup.0 (32188) [iobroker/historyHTML] new history html values created
                                        2021-03-31 06:15:59.736 - debug: backitup.0 (32188) [iobroker/historyHTML] done
                                        2021-03-31 06:15:59.894 - debug: backitup.0 (32188) [iobroker/historyJSON] new history json values created
                                        2021-03-31 06:15:59.895 - debug: backitup.0 (32188) [iobroker/historyJSON] done
                                        BG
                                        • simatecS simatec
                                          HumidorH Offline
                                          HumidorH Offline
                                          Humidor
                                          @simatec
                                          gerade gemacht:
                                          iobroker stop
                                          sudo apt-get update
                                          sudo apt-get upgrade
                                          iobroker fix
                                          curl -fsL https://iobroker.net/fix.sh | bash -
                                          iobroker start
                                          ... gewartet bis wieder alle Adapter online sind....
                                          manuelles Backup gestartet
                                          Adapter 2.0.4 - schaut gut aus, file ohne Fehler angelegt.
                                          2021-03-31 08:08:07.487 - debug: backitup.0 (24853) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2021-03-31 08:08:07.527 - debug: backitup.0 (24853) Objects client ready ... initialize now
                                          2021-03-31 08:08:07.530 - debug: backitup.0 (24853) Objects create System PubSub Client
                                          2021-03-31 08:08:07.531 - debug: backitup.0 (24853) Objects create User PubSub Client
                                          2021-03-31 08:08:07.532 - debug: backitup.0 (24853) Objects client initialize lua scripts
                                          2021-03-31 08:08:07.545 - debug: backitup.0 (24853) Objects connected to redis: 127.0.0.1:9001
                                          2021-03-31 08:08:07.554 - debug: backitup.0 (24853) objectDB connected
                                          2021-03-31 08:08:07.557 - debug: backitup.0 (24853) Redis States: Use Redis connection: 127.0.0.1:9000
                                          2021-03-31 08:08:07.565 - debug: backitup.0 (24853) States create System PubSub Client
                                          2021-03-31 08:08:07.566 - debug: backitup.0 (24853) States create User PubSub Client
                                          2021-03-31 08:08:07.574 - debug: backitup.0 (24853) States connected to redis: 127.0.0.1:9000
                                          2021-03-31 08:08:07.575 - debug: backitup.0 (24853) statesDB connected
                                          2021-03-31 08:08:08.090 - debug: backitup.0 (24853) Plugin sentry Initialize Plugin (enabled=true)
                                          2021-03-31 08:08:08.348 - info: backitup.0 (24853) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.0, js-controller: 3.2.16
                                          2021-03-31 08:08:08.446 - info: backitup.0 (24853) [iobroker] backup was activated at 06:15 every 1 day(s)
                                          2021-03-31 08:08:08.485 - debug: backitup.0 (24853) [iobroker] 10 15 06 */1 * *
                                          2021-03-31 08:08:09.122 - debug: backitup.0 (24853) mount successfully completed
                                          2021-03-31 08:08:11.097 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
                                          2021-03-31 08:08:11.205 - debug: backitup.0 (24853) detect backup file 1 from cifs: iobroker_2021_03_25-06_15_24_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.206 - debug: backitup.0 (24853) detect backup file 2 from cifs: iobroker_2021_03_26-06_10_22_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 3 from cifs: iobroker_2021_03_26-06_15_22_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.207 - debug: backitup.0 (24853) detect backup file 4 from cifs: iobroker_2021_03_27-06_10_22_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 5 from cifs: iobroker_2021_03_27-06_15_23_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.208 - debug: backitup.0 (24853) detect backup file 6 from cifs: iobroker_2021_03_28-10_57_31_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.209 - debug: backitup.0 (24853) detect backup file 7 from cifs: iobroker_2021_03_28-11_27_22_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 8 from cifs: iobroker_2021_03_28-11_31_14_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.210 - debug: backitup.0 (24853) detect backup file 9 from cifs: iobroker_2021_03_28-18_01_59_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 10 from cifs: iobroker_2021_03_29-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.211 - debug: backitup.0 (24853) detect backup file 11 from cifs: iobroker_2021_03_30-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.212 - debug: backitup.0 (24853) detect backup file 12 from cifs: iobroker_2021_03_30-07_26_27_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.213 - debug: backitup.0 (24853) detect backup file 13 from cifs: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.215 - debug: backitup.0 (24853) detect last backup file: iobroker_2021_03_31-06_15_21_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:08:11.851 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 24897
                                          2021-03-31 08:08:15.998 - info: host.raspi4iobrokerpv instance system.adapter.influxdb.0 started with pid 24912
                                          2021-03-31 08:08:18.174 - info: influxdb.0 (24912) starting. Version 1.9.4 in /opt/iobroker/node_modules/iobroker.influxdb, node: v12.22.0, js-controller: 3.2.16
                                          2021-03-31 08:08:18.223 - info: influxdb.0 (24912) No stored data from last exit found
                                          2021-03-31 08:08:18.225 - info: influxdb.0 (24912) Connecting http://localhost:8086 ...
                                          2021-03-31 08:08:18.324 - info: influxdb.0 (24912) enabled logging of kecontact.0.pf, Alias=false, 1 points now activated
                                          2021-03-31 08:08:18.325 - info: influxdb.0 (24912) enabled logging of kecontact.0.p, Alias=false, 2 points now activated
                                          2021-03-31 08:08:18.326 - info: influxdb.0 (24912) enabled logging of kecontact.0.i3, Alias=false, 3 points now activated
                                          2021-03-31 08:08:18.327 - info: influxdb.0 (24912) enabled logging of kecontact.0.i2, Alias=false, 4 points now activated
                                          2021-03-31 08:08:18.328 - info: influxdb.0 (24912) enabled logging of kecontact.0.i1, Alias=false, 5 points now activated
                                          2021-03-31 08:08:18.329 - info: influxdb.0 (24912) enabled logging of kecontact.0.u3, Alias=false, 6 points now activated
                                          2021-03-31 08:08:18.330 - info: influxdb.0 (24912) enabled logging of kecontact.0.u2, Alias=false, 7 points now activated
                                          2021-03-31 08:08:18.331 - info: influxdb.0 (24912) enabled logging of kecontact.0.u1, Alias=false, 8 points now activated
                                          2021-03-31 08:08:18.332 - info: influxdb.0 (24912) enabled logging of kecontact.0.currentUser, Alias=false, 9 points now activated
                                          2021-03-31 08:08:18.333 - info: influxdb.0 (24912) enabled logging of kecontact.0.enableUser, Alias=false, 10 points now activated
                                          2021-03-31 08:08:18.334 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.170, Alias=false, 11 points now activated
                                          2021-03-31 08:08:18.335 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.270, Alias=false, 12 points now activated
                                          2021-03-31 08:08:18.336 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch, Alias=false, 13 points now activated
                                          2021-03-31 08:08:18.337 - info: influxdb.0 (24912) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power, Alias=false, 14 points now activated
                                          2021-03-31 08:08:18.338 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.Power, Alias=false, 15 points now activated
                                          2021-03-31 08:08:18.339 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30537_Tagesertrag_kWh, Alias=false, 16 points now activated
                                          2021-03-31 08:08:18.340 - info: influxdb.0 (24912) enabled logging of modbus.0.inputRegisters.30775_PVLeistung, Alias=false, 17 points now activated
                                          2021-03-31 08:08:18.341 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell, Alias=false, 18 points now activated
                                          2021-03-31 08:08:18.342 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40083_I_AC_Leistung, Alias=false, 19 points now activated
                                          2021-03-31 08:08:18.343 - info: influxdb.0 (24912) enabled logging of modbus.1.holdingRegisters.40093_I_AC_Energie_WH, Alias=false, 20 points now activated
                                          2021-03-31 08:08:18.353 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVPower, Alias=false, 21 points now activated
                                          2021-03-31 08:08:18.354 - info: influxdb.0 (24912) enabled logging of 0_userdata.0.AMIS.PVÜberschuss, Alias=false, 22 points now activated
                                          2021-03-31 08:08:18.355 - info: influxdb.0 (24912) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuellSMA, Alias=false, 23 points now activated
                                          2021-03-31 08:08:18.356 - info: influxdb.0 (24912) enabled logging of fuelpricemonitor.0.zuHome_Diesel.0.prices.0.amount, Alias=false, 24 points now activated
                                          2021-03-31 08:08:18.357 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_170_Actual, Alias=false, 25 points now activated
                                          2021-03-31 08:08:18.358 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_grid.VPM_270_Actual, Alias=false, 26 points now activated
                                          2021-03-31 08:08:18.359 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank, Alias=false, 27 points now activated
                                          2021-03-31 08:08:18.360 - info: influxdb.0 (24912) enabled logging of virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank, Alias=false, 28 points now activated
                                          2021-03-31 08:08:18.394 - info: influxdb.0 (24912) Connected!
                                          2021-03-31 08:08:18.443 - debug: backitup.0 (24853) mount activ... umount in 2 Seconds!!
                                          2021-03-31 08:08:19.844 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 24951
                                          2021-03-31 08:08:20.507 - debug: backitup.0 (24853) umount successfully completed
                                          2021-03-31 08:08:23.918 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 24970
                                          2021-03-31 08:08:27.916 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 24991
                                          2021-03-31 08:08:31.809 - info: host.raspi4iobrokerpv instance scheduled system.adapter.zoe2.0 */10 * * * *
                                          2021-03-31 08:08:35.850 - info: host.raspi4iobrokerpv instance system.adapter.info.0 started with pid 25021
                                          2021-03-31 08:08:39.889 - info: host.raspi4iobrokerpv instance system.adapter.life360.0 started with pid 25130
                                          2021-03-31 08:08:43.905 - info: host.raspi4iobrokerpv instance system.adapter.fritzdect.0 started with pid 25517
                                          2021-03-31 08:08:47.741 - debug: backitup.0 (24853) system.adapter.admin.0: logging false
                                          2021-03-31 08:08:47.862 - info: host.raspi4iobrokerpv instance scheduled system.adapter.fuelpricemonitor.0 25 */20 * * * *
                                          2021-03-31 08:08:47.887 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 started with pid 25539
                                          2021-03-31 08:08:50.014 - info: fuelpricemonitor.0 (25539) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v12.22.0, js-controller: 3.2.16
                                          2021-03-31 08:08:51.962 - info: host.raspi4iobrokerpv instance system.adapter.virtualpowermeter.0 started with pid 25568
                                          2021-03-31 08:08:54.142 - info: virtualpowermeter.0 (25568) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.virtualpowermeter, node: v12.22.0, js-controller: 3.2.16
                                          2021-03-31 08:08:54.214 - info: virtualpowermeter.0 (25568) inital all Objects
                                          2021-03-31 08:08:54.394 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.170
                                          2021-03-31 08:08:54.506 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.170 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_170 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_170 Destination Group: virtualpowermeter.0.group_grid.
                                          2021-03-31 08:08:54.507 - info: virtualpowermeter.0 (25568) initial 0_userdata.0.AMIS.270
                                          2021-03-31 08:08:54.551 - info: virtualpowermeter.0 (25568) initial done 0_userdata.0.AMIS.270 Destination Power: virtualpowermeter.0.group_grid.Virtual_Energy_Power_270 Destination EnergyTotal: virtualpowermeter.0.group_grid.Virtual_Energy_Total_270 Destination Group: virtualpowermeter.0.group_grid.
                                          2021-03-31 08:08:54.556 - info: virtualpowermeter.0 (25568) initial fritzdect.0.DECT_116300118701.power
                                          2021-03-31 08:08:54.580 - info: virtualpowermeter.0 (25568) initial done fritzdect.0.DECT_116300118701.power Destination Power: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Power_Powerbank Destination EnergyTotal: virtualpowermeter.0.group_PowerBank.Virtual_Energy_Total_Powerbank Destination Group: virtualpowermeter.0.group_PowerBank.
                                          2021-03-31 08:08:54.672 - info: virtualpowermeter.0 (25568) initial completed
                                          2021-03-31 08:08:54.882 - info: fuelpricemonitor.0 (25539) Terminated (NO_ERROR): Without reason
                                          2021-03-31 08:08:55.400 - info: fuelpricemonitor.0 (25539) cleaned everything up...
                                          2021-03-31 08:08:55.460 - info: host.raspi4iobrokerpv instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
                                          2021-03-31 08:09:05.222 - debug: backitup.0 (24853) telegram-instance: telegram.0
                                          2021-03-31 08:09:05.227 - debug: backitup.0 (24853) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"858269950":{"firstName":"Richard"}}
                                          2021-03-31 08:09:09.554 - debug: backitup.0 (24853) Backup has started ...
                                          2021-03-31 08:09:20.003 - debug: backitup.0 (24853) [iobroker/mount] mount successfully completed
                                          2021-03-31 08:09:20.007 - debug: backitup.0 (24853) [iobroker/mount] done
                                          2021-03-31 08:09:22.797 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2160 states saved
                                          2021-03-31 08:09:22.820 - debug: backitup.0 (24853) [iobroker/iobroker] host.raspi4iobrokerpv 2595 objects saved
                                          2021-03-31 08:09:26.163 - debug: backitup.0 (24853) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_03_31-08_09_20_ioBrokerPV_backupiobroker.tar.gz
                                          2021-03-31 08:09:27.265 - debug: backitup.0 (24853) [iobroker/iobroker] done
                                          2021-03-31 08:09:28.134 - debug: backitup.0 (24853) [iobroker/historyDB] The following files were found for the backup: 20210202,20210203,20210204,20210205,20210206,20210207,20210208,20210209,20210210,20210211,20210212,20210213,20210214,20210215,20210216,20210217,20210218,20210219,20210220,20210221,20210222,20210223,20210224,20210225,20210226,20210227,20210228,20210301,20210302,20210303,20210304,20210305,20210306,20210307,20210308,20210309,20210310,20210311,20210312,20210313,20210314,20210315,20210316,20210317,20210318,20210319,20210320,20210321,20210322,20210323,20210324,20210325,20210326,20210327,20210328,20210329,20210330,20210331
                                          2021-03-31 08:09:38.090 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 11MB so far...
                                          2021-03-31 08:09:48.187 - debug: backitup.0 (24853) [iobroker/historyDB] Packed 21MB so far...
                                          2021-03-31 08:09:48.507 - debug: backitup.0 (24853) system.adapter.admin.0: logging true
                                          2021-03-31 08:09:56.738 - debug: backitup.0 (24853) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2021_03_31-08_09_28_backupiobroker.tar.gz
                                          2021-03-31 08:09:56.750 - debug: backitup.0 (24853) [iobroker/historyDB] done
                                          2021-03-31 08:09:57.815 - debug: backitup.0 (24853) [iobroker/cifs] done
                                          2021-03-31 08:09:58.417 - debug: backitup.0 (24853) [iobroker/clean] done
                                          2021-03-31 08:09:58.878 - debug: backitup.0 (24853) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                                          2021-03-31 08:09:58.886 - debug: backitup.0 (24853) [iobroker/telegram] done
                                          2021-03-31 08:09:59.198 - debug: backitup.0 (24853) [iobroker/historyHTML] new history html values created
                                          2021-03-31 08:09:59.201 - debug: backitup.0 (24853) [iobroker/historyHTML] done
                                          2021-03-31 08:09:59.367 - debug: backitup.0 (24853) [iobroker/historyJSON] new history json values created
                                          2021-03-31 08:09:59.369 - debug: backitup.0 (24853) [iobroker/historyJSON] done
                                          2021-03-31 08:09:59.565 - debug: backitup.0 (24853) [iobroker/umount] mount activ, umount is started ...
                                          2021-03-31 08:10:00.114 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 started with pid 25752
                                          2021-03-31 08:10:04.622 - debug: backitup.0 (24853) [iobroker/umount] umount successfully completed
                                          2021-03-31 08:10:04.623 - debug: backitup.0 (24853) [iobroker/umount] done
                                          2021-03-31 08:10:04.775 - debug: backitup.0 (24853) [iobroker] exec: done
                                          BG
