  4. [Gelöst] Zigbee Adapter bleibt gelb
64 Beiträge 7 Kommentatoren 8.3k Aufrufe 4 Beobachtet
    @masterg-23
    Fahr den Rechner mal runter, Stick raus, Rechner hochfahren, Stick wieder einstecken.
    Masterg 23M Offline
    Masterg 23M Offline
    Masterg 23
    @thomas-braun danke für deine Nachricht, leider bleibt der Adapter immer noch auf Gelb.
    • Masterg 23M Masterg 23
      @masterg-23 Mit welchen Meldungen?
        @fredf leider bekomme ich den gleichen Fehler. Der Adapter bleibt weiterhin gelb.
        zigbee.0	2021-03-28 14:47:31.611	error	(1402) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-her
        zigbee.0	2021-03-28 14:47:31.610	error	(1402) Failed to start Zigbee
        zigbee.0	2021-03-28 14:47:31.427	info	(1402) Installed Version: iobroker.zigbee@1.4.4
        zigbee.0	2021-03-28 14:47:31.389	info	(1402) Starting Zigbee npm ...
        zigbee.0	2021-03-28 14:47:31.386	info	(1402) Try to reconnect. 1 attempts left
        zigbee.0	2021-03-28 13:47:21.385	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
        zigbee.0	2021-03-28 13:47:21.385	error	at Generator.throw (<anonymous>)
        zigbee.0	2021-03-28 13:47:21.385	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
        zigbee.0	2021-03-28 13:47:21.385	error	(1402) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
        zigbee.0	2021-03-28 13:47:21.384	error	(1402) Failed to start Zigbee
        zigbee.0	2021-03-28 13:47:01.913	info	(1402) Installed Version: iobroker.zigbee@1.4.4
        zigbee.0	2021-03-28 13:47:01.288	info	(1402) Starting Zigbee npm ...
        zigbee.0	2021-03-28 13:47:01.149	info	(1402) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.16.0, js-controller: 3.2.16
        @masterg-23 sagte in Zigbee Adapter bleibt gelb:
        Und warum springt die Zeit da um eine Stunde?
        • Masterg 23M Offline
          Masterg 23M Offline
          Masterg 23
          schrieb am zuletzt editiert von Masterg 23
          @thomas-braun said in Zigbee Adapter bleibt gelb:
          Das kann ich mir nicht erklären, warum die Zeit sich um eine Stunde umgestellt hat.
          Mir ist noch gerade aufgefallen, dass wenn ich in den Adapter Einstellungen gehe, alles leer ist. Also Kein Pan ID keine Erweiterte PAN ID kein Kanal. Irgendwas stimmt hier gewaltig nicht :/
          zigbee.0	2021-03-28 14:33:42.002	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
          zigbee.0	2021-03-28 14:33:42.002	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
          zigbee.0	2021-03-28 14:33:42.002	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
          zigbee.0	2021-03-28 14:33:42.002	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
          zigbee.0	2021-03-28 14:33:42.002	error	at new Promise (<anonymous>)
          zigbee.0	2021-03-28 14:33:42.002	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
          zigbee.0	2021-03-28 14:33:42.002	error	at Generator.next (<anonymous>)
          zigbee.0	2021-03-28 14:33:42.002	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
          zigbee.0	2021-03-28 14:33:42.002	error	(1527) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
          zigbee.0	2021-03-28 14:33:41.996	error	(1527) Failed to start Zigbee
          zigbee.0	2021-03-28 14:33:41.758	info	(1527) Installed Version: iobroker.zigbee@1.4.4
          zigbee.0	2021-03-28 14:33:41.732	info	(1527) Starting Zigbee npm ...
          zigbee.0	2021-03-28 14:33:41.730	info	(1527) Try to reconnect. 1 attempts left
          zigbee.0	2021-03-28 14:33:31.729	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
          zigbee.0	2021-03-28 14:33:31.729	error	at Generator.throw (<anonymous>)
          zigbee.0	2021-03-28 14:33:31.729	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
          zigbee.0	2021-03-28 14:33:31.729	error	(1527) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
          zigbee.0	2021-03-28 14:33:31.728	error	(1527) Failed to start Zigbee
          zigbee.0	2021-03-28 14:33:12.261	info	(1527) Installed Version: iobroker.zigbee@1.4.4
          zigbee.0	2021-03-28 14:33:11.681	info	(1527) Starting Zigbee npm ...
          zigbee.0	2021-03-28 14:33:11.580	info	(1527) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.16.0, js-controller: 3.2.16
          zigbee.0	2021-03-28 14:33:02.954	error	(1495) Cannot read property 'getEntries' of null
          zigbee.0	2021-03-28 14:33:02.953	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
          zigbee.0	2021-03-28 14:33:02.953	error	at Zigbee.emit (events.js:315:20)
          zigbee.0	2021-03-28 14:33:02.953	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
          zigbee.0	2021-03-28 14:33:02.953	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
          zigbee.0	2021-03-28 14:33:02.953	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
          zigbee.0	2021-03-28 14:33:02.953	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
          zigbee.0	2021-03-28 14:33:02.953	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
          zigbee.0	2021-03-28 14:33:02.953	error	at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:289:31)
          zigbee.0	2021-03-28 14:33:02.953	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:241:16)
          zigbee.0	2021-03-28 14:33:02.953	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:55)
          zigbee.0	2021-03-28 14:33:02.953	error	(1495) TypeError: Cannot read property 'getEntries' of null
          zigbee.0	2021-03-28 14:33:02.949	error	(1495) unhandled promise rejection: Cannot read property 'getEntries' of null
          zigbee.0	2021-03-28 14:33:02.948	error	(1495) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          Kann sein, dass der Stick den Geist aufgegeben hat?
            @masterg-23 Stell erst mal deine Zeit richtig ein. Das System geht ja eine Stunde nach.
            Masterg 23M 1 Antwort Letzte Antwort
              Masterg 23M Offline
              Masterg 23M Offline
              Masterg 23
              Hab die Zeit einstellt. Soll ich den Adapter deinstallieren und neu installiere?
              Was mich stutzig macht ist die Tatsache, dass ich bei dem Befehl ls -l /dev/serial/by-id kein Ergebnis bekomme, obwohl es früher definitiv funktioniert hat. Da bin ich mir 100% ig sicher.
              zigbee.0	2021-03-28 15:51:02.240	error	(1804) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-her
              zigbee.0	2021-03-28 15:51:02.239	error	(1804) Failed to start Zigbee
              zigbee.0	2021-03-28 15:51:02.023	info	(1804) Installed Version: iobroker.zigbee@1.4.4
              zigbee.0	2021-03-28 15:51:01.990	info	(1804) Starting Zigbee npm ...
              zigbee.0	2021-03-28 15:51:01.987	info	(1804) Try to reconnect. 1 attempts left
              zigbee.0	2021-03-28 15:50:51.986	error	(1804) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/ad
              zigbee.0	2021-03-28 15:50:51.983	error	(1804) Failed to start Zigbee
              zigbee.0	2021-03-28 15:50:32.508	info	(1804) Installed Version: iobroker.zigbee@1.4.4
              zigbee.0	2021-03-28 15:50:31.886	info	(1804) Starting Zigbee npm ...
              zigbee.0	2021-03-28 15:50:31.770	info	(1804) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.16.0, js-controller: 3.2.16
                Masterg 23M Offline
                Masterg 23
                Hab den Adapter neu installiert leider immer noch ohne Erfolg.
                Hab dann die Version von Node checken wollen und sehe, dass da was nicht stimmt.
                pi@raspberrypi:~ $ node version
                internal/modules/cjs/loader.js:883
                  throw err;
                Error: Cannot find module '/home/pi/version'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:725:27)
                    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
                    at internal/main/run_main_module.js:17:47 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                  throw err;
                  requireStack: []
                Kann jemand damit was anfangen?
                    throw err;
                    requireStack: []
                    throw err;
                    requireStack: []
                  @masterg-23 Zu node schau in meine Signatur.
                    Masterg 23M Offline
                    Masterg 23M Offline
                    Masterg 23
                    @thomas-braun habe ich eigentlich gemacht.
                    Hier das Ergebnis:
                    pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v14.16.0
                    /usr/bin/node
                    v14.16.0
                    /usr/bin/npm
                    6.14.11
                    nodejs:
                      Installiert:           14.16.0-1nodesource1
                      Installationskandidat: 14.16.0-1nodesource1
                      Versionstabelle:
                     *** 14.16.0-1nodesource1 100
                         12.21.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                         10.24.0~dfsg-1~deb10u1 500
                      Hier das Ergebnis:
                      /usr/bin/nodejs
                      v14.16.0
                      /usr/bin/node
                      v14.16.0
                      /usr/bin/npm
                      6.14.11
                      nodejs:
                        Versionstabelle:
                      @masterg-23
                      Da gibt es in der nodesource.list keinen Eintrag zu node14.
                        @masterg-23
                        Masterg 23M Offline
                        Masterg 23M Offline
                        Masterg 23
                        @thomas-braun Ich weiß nicht, was du mir damit sagen willst.
                        Hier der Eintrag bei sudo nano /etc/apt/sources.list.d/nodesource.list
                        # node 12
                        deb https://deb.nodesource.com/node_12.x buster main
                        deb-src https://deb.nodesource.com/node_12.x buster main
                        EDIT:
                        pi@raspberrypi:~ $ node -v
                        v14.16.0
                        pi@raspberrypi:~ $ npm -v
                        6.14.11
                        pi@raspberrypi:~ $
                          # node 12
                          EDIT:
                          v14.16.0
                          6.14.11
                          pi@raspberrypi:~ $
                          @masterg-23
                          In die Datei gehört ein Eintrag zu node14 rein, damit Updates auch darüber installiert werden können. Im Moment hängt dein node14 in der Luft. Wie hast du das eigentlich auf das System bekommen, wenn nicht über den Paketmanager?
                            @masterg-23
                            Masterg 23M Offline
                            Masterg 23M Offline
                            Masterg 23
                            @thomas-braun Ich habe nach deiner Anleitung zunächst das System nach update überprüfen lassen, dann den ioBroker gestoppt und dann per
                            Die Liste jetzt ergänzt. Dann "sudo apt update" und dann zum Schluss "iobroker fix"
                            Jetzt sieht die nodesource.list so aus.
                            # node 12
                            # node 14
                            deb https://deb.nodesource.com/node_14.x buster main
                            deb-src https://deb.nodesource.com/node_14.x buster main
                            Hier die Logs:
                            zigbee.0	2021-03-28 21:56:28.354	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                            zigbee.0	2021-03-28 21:56:28.354	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                            zigbee.0	2021-03-28 21:56:28.354	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                            zigbee.0	2021-03-28 21:56:28.354	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                            zigbee.0	2021-03-28 21:56:28.354	error	at new Promise (<anonymous>)
                            zigbee.0	2021-03-28 21:56:28.354	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                            zigbee.0	2021-03-28 21:56:28.354	error	at Generator.next (<anonymous>)
                            zigbee.0	2021-03-28 21:56:28.354	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                            zigbee.0	2021-03-28 21:56:28.354	error	(7386) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                            zigbee.0	2021-03-28 21:56:28.353	error	(7386) Failed to start Zigbee
                            R 1 Antwort Letzte Antwort
                              # node 12
                              # node 14
                              Hier die Logs:
                              RealGue
                              @masterg-23 Zieh den Zigbee Adapter raus. Dann "dmesg".
                              Dann wieder reinstecken. Und wieder "dmesg". Wenn da keine neuen Zeilen hinzugekommen sind, ist der Stick tot.
                              • R RealGue
                                Masterg 23M Offline
                                Masterg 23M Offline
                                Masterg 23
                                @realgue said in Zigbee Adapter bleibt gelb:
                                Stick abgezogen:
                                [  307.154755] usb 1-1.3: USB disconnect, device number 3
                                [  609.757548] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
                                [  609.896438] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                                [  609.896449] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                [  609.896457] usb 1-1.3: Product: TI CC2531 USB CDC
                                [  609.896464] usb 1-1.3: Manufacturer: Texas Instruments
                                [  609.896471] usb 1-1.3: SerialNumber: __0X00124B0002CAF6B2
                                [ 1492.730354] usb 1-1.3: USB disconnect, device number 4
                                Stick wieder drin:
                                [ 1564.395545] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
                                [ 1564.534316] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                                [ 1564.534326] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                [ 1564.534334] usb 1-1.3: Product: TI CC2531 USB CDC
                                [ 1564.534341] usb 1-1.3: Manufacturer: Texas Instruments
                                [ 1564.534348] usb 1-1.3: SerialNumber: __0X00124B0002CAF6B2
                                Der Stick wird schon erkannt aber über ls /dev/serial/by-id bekomme ich kein Ergebnis:
                                ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                Kann es sein, dass der Stick neu geflasht werden muss?
                                AsgothianA R D 3 Antworten Letzte Antwort
                                  Stick abgezogen:
                                  Stick wieder drin:
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  Ich gehe davon aus das ja.
                                  A.
                                    Stick abgezogen:
                                    Stick wieder drin:
                                    RealGue
                                    @masterg-23 Also das muss noch kommen:
                                    [  136.004734] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                                    [  136.006794] usbcore: registered new interface driver cdc_acm
                                    [  136.006802] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                                    Wenn nicht, dann wird er nicht richtig initialisiert.
                                    Ich persönlich glaube nicht, dass flashen was bringt. Aber wenn du die Möglichkeit hast, mach es doch einfach.
                                    • R RealGue
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @realgue Flaschen retted die cc2531 üblicherweise. Es gibt in der Firmware einen bug durch den der Stick seinen Speicher überschreibt.
                                      A.
                                      • AsgothianA Asgothian
                                        A.
                                        Masterg 23M Offline
                                        Masterg 23M Offline
                                        Masterg 23
                                        @RealGue danke für deine Rückmeldung, leider kommt diese Meldung nicht. Der Log spuckt immer wieder die gleichen Fehler aus:
                                        zigbee.0	2021-03-29 00:11:54.148	error	(2756) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
                                        zigbee.0	2021-03-29 00:11:54.147	error	(2756) Failed to start Zigbee
                                        zigbee.0	2021-03-29 00:11:53.935	info	(2756) Installed Version: iobroker.zigbee@1.4.4
                                        zigbee.0	2021-03-29 00:11:53.898	info	(2756) Starting Zigbee npm ...
                                        zigbee.0	2021-03-29 00:11:53.896	info	(2756) Try to reconnect. 1 attempts left
                                        zigbee.0	2021-03-29 00:11:43.895	error	(2756) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
                                        zigbee.0	2021-03-29 00:11:43.893	error	(2756) Failed to start Zigbee
                                        zigbee.0	2021-03-29 00:11:24.421	info	(2756) Installed Version: iobroker.zigbee@1.4.4
                                        zigbee.0	2021-03-29 00:11:23.809	info	(2756) Starting Zigbee npm ...
                                        zigbee.0	2021-03-29 00:11:23.713	info	(2756) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.16.0, js-controller: 3.2.16
                                        zigbee.0	2021-03-29 00:11:18.275	error	(1626) Cannot read property 'getEntries' of null
                                        zigbee.0	2021-03-29 00:11:18.275	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at Zigbee.emit (events.js:315:20)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:289:31)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:241:16)
                                        zigbee.0	2021-03-29 00:11:18.275	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:55)
                                        zigbee.0	2021-03-29 00:11:18.275	error	(1626) TypeError: Cannot read property 'getEntries' of null
                                        zigbee.0	2021-03-29 00:11:18.272	error	(1626) unhandled promise rejection: Cannot read property 'getEntries' of null
                                        zigbee.0	2021-03-29 00:11:18.271	error	(1626) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        zigbee.0	2021-03-29 00:11:18.270	info	(1626) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        zigbee.0	2021-03-29 00:11:18.269	info	(1626) terminating
                                        @asgothian Ich habe dir eine PM geschrieben gehabt bevor du hier mitgelesen hast. Jetzt ist die Frage, lohnt sich ein Debugger und das Kabel zu kaufen um es neu zu flashen (ich hatte den Stick fertig geflasht gekauft) oder aber gleich auf einen besseren Stick setzen (CC2652RB) oder aber auf den ConBee II? Kann man hier einer von den beiden Hardwares empfehlen?
                                          Stick abgezogen:
                                          Stick wieder drin:
                                          dimaiv
                                          @masterg-23
                                          Erstmal redest du über einen 2538, und jetzt im log taucht plötzlich der 2531 auf...
                                          Welches Stick hast du ?
                                          Kannst du den Stick am Windows PC testen?
                                          Ich denke deine Pi ist Schuld (OS).
                                          ioBroker- NUC8i3 / Proxmox / VM
                                          Node.js v22.21.0
                                          NPM v10.9.4
                                          JS controller 7.1.0
                                          Admin 7.7.20
                                          ZigBee Adapter 3.3.1alpha.0
                                          Zigbee LAN Gateway CC2652P
                                          Zigbee Firmware 20250321
