  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.5m Aufrufe 153 Beobachtet
  • S Schwarzwälder
    @crunchip
    Leider habe doch noch ein Problem mit den falschen historischen Werten, wie bekomme ich diese los?
    2021-03-21 14:00:42.296 - info: sourceanalytix.0 (1629) Welcome to SourceAnalytix, making things ready ...
    2021-03-21 14:00:42.395 - error: sourceanalytix.0 (1629) Check settings for smartmeter.0.1-0:2_8_0__255.value ! **Known valueAtDeviceReset : (904364.4407158422) > known cumulative value (18874.5548) cannot proceed**
    2021-03-21 14:00:42.395 - error: sourceanalytix.0 (1629) Troubleshoot Data smartmeter.0.1-0:2_8_0__255.value custom Data : {"type":"state","common":{"name":"1-0:2_8_0__255.value","type":"number","read":true,"unit":"kWh","role":"value","write":false,"custom":{"sourceanalytix.0":{"enabled":true,"alias":"Einspeisung","selectedPrice":"ElectricityDelivery","selectedUnit":"kWh","costs":false,"consumption":false,"meter_values":true,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":18065,"valueAtDeviceInit":18874.5548,"v**alueAtDeviceReset":904364.4407158422,"cumulativeValue":557092.3647416172}}**},"native":{"id":"1-0:2_8_0__255.value"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1616154824830,"_id":"smartmeter.0.1-0:2_8_0__255.value","acl":{"object":1636,"state":1636,"file":1636,"ownerGroup":"system.group.administrator"}}
    2021-03-21 14:00:42.402 - info: sourceanalytix.0 (1629) Initialising (1 of 2) state smartmeter.0.1-0:2_8_0__255.value
    2021-03-21 14:00:42.404 - error: sourceanalytix.0 (1629) Cannot handle initialisation for smartmeter.0.1-0:2_8_0__255.value
    2021-03-21 14:00:42.404 - info: sourceanalytix.0 (1629) Initialization (1 of 2) finished for : smartmeter.0.1-0:2_8_0__255.value
    Mod-Edit: Code in </> Code-Tag gepackt!
    crunchipC Abwesend
    crunchipC Abwesend
    #448
    @schwarzwälder wie oben schon erwähnt, prüfe ob deine smartmeter Werte überhaupt richtig rein kommen
    • DutchmanD Dutchman
      @bloody sagte in [SourceAnalytix 0.4.8-Final] Released !:
      Er nimmt dann die kWh, die das Gerät ausspuckt und nicht was ich in SA eintrage. bekomme ich das wieder gerade gebogen?
      schau dir mal an was im rawdatan von deinem alten, und was im neuen stehen.
      Dan wirste sehen das dort ein startwert hinterlegt ist den du übernehmen musst (steht übrigens auch in der
      troubleshoot Sektion :)
      Bloody
      #449
      @dutchman said in [SourceAnalytix 0.4.8-Final] Released !:
      Irgendwie stehe ich auf dem Schlauch. Hab jetzt schon einiges probiert aber irgendwie will es nicht so, wie ich will.
      Das alte Gerät ging bis 48,194 kWh. Das neue fängt ab 7,94 an. Was muss ich genau wo einstellen? Habe schon mit den vier Werten gespielt aber nööö.
      "previousDeviceReset": 48.194,
      "previousInit": 48.194,
      "valueAtDeviceReset": 56,
      "valueAtDeviceInit": 7.94
           "sourceanalytix.0": {
              "enabled": true,
              "alias": "Aquarium Licht",
              "selectedPrice": "ElectricityDay",
              "selectedUnit": "kWh",
              "costs": true,
              "consumption": true,
              "meter_values": true,
              "start_day": 48.194,
              "start_week": 48.194,
              "start_month": 46.024,
              "start_quarter": 37.291,
              "start_year": 37.291,
      • B Bloody
                "enabled": true,
                "costs": true,
        crunchipC Abwesend
        crunchipC Abwesend
        #450
        @bloody was gibts denn für ein Problem?
          Bloody
          #451
          @crunchip said in [SourceAnalytix 0.4.8-Final] Released !:
          Ich habe das Gefühl, dass die Berechnungen nicht richtig sind. Hätte heute ja 4,62€ gekostet. Sonst um die 0,50€
          • B Bloody
            crunchipC Abwesend
            crunchipC Abwesend
            #452
            @bloody stimmt dein cumulativ Reading mit deinem eigentlichen Wert überein?
            • MassiveAttackM Offline
              MassiveAttack
              #453
              Durch ein Firmware Update habe ich einen Tag im März einen falschen (zu großen) Wert vom Wechselrichter bekommen, seit dem wird der Monatswert natürlich falsch dargestellt. Wie kann ich das wieder korrigieren?
              • Werte überschreiben geht zwar, aber für den aktuellen Monat wird es wieder verworfen (geht anscheinend nur für vergangene Zeiträume)
              • Zähler am DP zurücksetzen (korrigieren) geht, aber der errechnete Monatswert wird nicht aktualisiert. Es scheint als würde er beim "Zählerstand bei Tagesbeginn" die falschen Werte wieder dazu addieren.
              Siehe Screenshot, der Tageswert ist viel zu hoch
              K MassiveAttackM 2 Antworten Letzte Antwort
              • MassiveAttackM MassiveAttack
                Kanumouse
                #454
                @Dutchman,
                Den Adapter finde ich toll bekomme ihn aber nicht richtig zum laufen.
                Vielleicht kannst du mir helfen?
                Im Log-File bekomme ich immer solche Fehlermeldungen und kann diese nicht einordnen.
                2021-03-24 00:00:00.598  - error: sourceanalytix.0 (11067) [[resetStartValues] hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER] error: Cannot read property 'calcValues' of null, stack: TypeError: Cannot read property 'calcValues' of null
                    at CronJob.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:621:54)
                2021-03-24 00:00:00.602  - error: sourceanalytix.0 (11067) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-03-24 00:00:00.603  - error: sourceanalytix.0 (11067) unhandled promise rejection: Cannot read property 'captureException' of undefined
                2021-03-24 00:00:00.603  - error: sourceanalytix.0 (11067) TypeError: Cannot read property 'captureException' of undefined
                    at Sourceanalytix.errorHandling (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:1647:37)
                    at CronJob.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:849:12)
                2021-03-24 00:00:00.604  - error: sourceanalytix.0 (11067) Cannot read property 'captureException' of undefined
                2021-03-24 00:00:00.635  - info: sourceanalytix.0 (11067) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
                2021-03-24 00:00:00.636  - info: sourceanalytix.0 (11067) terminating
                2021-03-24 00:00:00.637  - warn: sourceanalytix.0 (11067) Terminated (UNCAUGHT_EXCEPTION): Without reason
                Gleichzeitig zählt er bei den Tages- und Wochenverbräuchen nur den aktuellen Zählerstand hoch, statt die Tages und Wochenverbräuche auszurechnen.
                Wo liegt das Problem?
                Ich hab die Adapter-Version 0.4.8 installiert.
                  Bloody
                  #455
                  Nein, der eigentliche Wert vom neuen "Messgerät" wäre eigentlich 8,22kWh.
                  Heute scheint die Berechnung allerdings wieder zu passen, bis auf den Wert von gestern halt.
                  • K Kanumouse
                    @Dutchman,
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #456
                    @kanumouse sagte in [SourceAnalytix 0.4.8-Final] Released !:
                    wie sieht das log beim starten des Adapter aus?
                      MassiveAttack
                      #457
                      @massiveattack said in [SourceAnalytix 0.4.8-Final] Released !:
                      Bitte um Hilfe...!!
                      Wie kann ich den Zähler (manuell) dauerhaft korrigieren, ohne dass er wieder zurückspringt?
                        Bitte um Hilfe...!!
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #458
                        @massiveattack https://github.com/DrozmotiX/ioBroker.sourceanalytix#Troubleshooting
                        MassiveAttackM 1 Antwort Letzte Antwort
                          Kanumouse
                          #459
                          @dutchman
                          folgend ein Log-Auszug beim Start von sourceanalytixs.
                          2021-03-24 17:50:37.376  - info: host.raspberrypi "system.adapter.sourceanalytix.0" enabled
                          2021-03-24 17:50:37.660  - info: host.raspberrypi instance system.adapter.sourceanalytix.0 started with pid 8419
                          2021-03-24 17:50:39.778  - info: sourceanalytix.0 (8419) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                          2021-03-24 17:50:39.795  - info: sourceanalytix.0 (8419) starting. Version 0.4.8 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.20.2, js-controller: 3.2.16
                          2021-03-24 17:50:39.834  - info: sourceanalytix.0 (8419) Welcome to SourceAnalytix, making things ready ...
                          2021-03-24 17:50:40.041  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (26.971700000000002) > known cumulative value (0) cannot proceed
                          2021-03-24 17:50:40.042  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"name":"Waschmaschine - Messwert.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","custom":{"sourceanalytix.0":{"enabled":true,"alias":"Waschmaschine","selectedPrice":"ElectricityDay","selectedUnit":"Wh","costs":true,"consumption":true,"meter_values":true,"start_day":26.9708,"start_week":26.9708,"start_month":26.9708,"start_quarter":26.9708,"start_year":26.9708,"valueAtDeviceReset":26.971700000000002,"valueAtDeviceInit":26.971699982}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1614760566301,"_id":"hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                          2021-03-24 17:50:40.104  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (19.559799994) > known cumulative value (0) cannot proceed
                          2021-03-24 17:50:40.105  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"name":"Schaltaktor_Kühlschrank:2.ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","custom":{"sourceanalytix.0":{"enabled":true,"alias":"Kühlschrank","selectedPrice":"ElectricityDay","selectedUnit":"Wh","costs":false,"consumption":true,"meter_values":true,"start_day":15.3953,"start_week":15.3953,"start_month":15.3953,"start_quarter":15.3953,"start_year":15.3953,"valueAtDeviceReset":19.559799994,"valueAtDeviceInit":0}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1614866892101,"_id":"hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                          2021-03-24 17:50:40.136  - error: sourceanalytix.0 (8419) Check settings for hm-rpc.1.REQ0777411.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (44.8956) > known cumulative value (0) cannot proceed
                          2021-03-24 17:50:40.137  - error: sourceanalytix.0 (8419) Troubleshoot Data hm-rpc.1.REQ0777411.2.ENERGY_COUNTER custom Data : {"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1614760566236,"common":{"name":"Messung Solaranlage.ENERGY_COUNTER","type":"number","unit":"Wh","def":0,"min":0,"read":true,"write":false,"custom":{"history.0":{"enabled":true,"changesOnly":true,"debounce":"1000","maxLength":"960","retention":"31536000","changesRelogInterval":0,"changesMinDelta":0,"aliasId":""},"sourceanalytix.0":{"enabled":true,"alias":"","selectedPrice":"ElectricityDelivery","selectedUnit":"Wh","costs":false,"consumption":false,"meter_values":true,"start_day":44.5368,"start_week":44.5368,"start_month":44.5368,"start_quarter":44.5368,"start_year":44.5368,"valueAtDeviceReset":44.8956,"valueAtDeviceInit":44.895599976}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","ID":"ENERGY_COUNTER","TYPE":"FLOAT","UNIT":"Wh","DEFAULT":0,"FLAGS":1,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0},"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator","state":1636},"_id":"hm-rpc.1.REQ0777411.2.ENERGY_COUNTER","type":"state"}
                          2021-03-24 17:50:45.175  - info: sourceanalytix.0 (8419) Initialization (1 of 9) finished for : ebus.0.bai.messages.Yield.fields.energy.value
                          2021-03-24 17:50:45.176  - info: sourceanalytix.0 (8419) Initialising (2 of 9) state hm-rega.0.47153
                          2021-03-24 17:50:49.434  - info: sourceanalytix.0 (8419) Initialization (2 of 9) finished for : hm-rega.0.47153
                          2021-03-24 17:50:49.435  - info: sourceanalytix.0 (8419) Initialising (3 of 9) state hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.435  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.436  - info: sourceanalytix.0 (8419) Initialization (3 of 9) finished for : hm-rpc.1.OEQ1975764.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.436  - info: sourceanalytix.0 (8419) Initialising (4 of 9) state hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.436  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.437  - info: sourceanalytix.0 (8419) Initialization (4 of 9) finished for : hm-rpc.1.PEQ0412155.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.437  - info: sourceanalytix.0 (8419) Initialising (5 of 9) state hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.437  - error: sourceanalytix.0 (8419) Cannot handle initialisation for hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.438  - info: sourceanalytix.0 (8419) Initialization (5 of 9) finished for : hm-rpc.1.REQ0777411.2.ENERGY_COUNTER
                          2021-03-24 17:50:49.438  - info: sourceanalytix.0 (8419) Initialising (6 of 9) state hm-rpc.1.PEQ0543850.1.IEC_ENERGY_COUNTER
                          2021-03-24 17:50:51.593  - info: sourceanalytix.0 (8419) Initialization (6 of 9) finished for : hm-rpc.1.PEQ0543850.1.IEC_ENERGY_COUNTER
                          2021-03-24 17:50:51.593  - info: sourceanalytix.0 (8419) Initialising (7 of 9) state hm-rpc.1.PEQ0543850.1.IEC_POWER
                          2021-03-24 17:50:53.010  - info: sourceanalytix.0 (8419) Initialization (7 of 9) finished for : hm-rpc.1.PEQ0543850.1.IEC_POWER
                          2021-03-24 17:50:53.010  - info: sourceanalytix.0 (8419) Initialising (8 of 9) state hm-rpc.1.PEQ0543850.2.IEC_ENERGY_COUNTER
                          2021-03-24 17:50:55.401  - info: sourceanalytix.0 (8419) Initialization (8 of 9) finished for : hm-rpc.1.PEQ0543850.2.IEC_ENERGY_COUNTER
                          2021-03-24 17:50:55.402  - info: sourceanalytix.0 (8419) Initialising (9 of 9) state hm-rpc.1.PEQ0543850.2.IEC_POWER
                          2021-03-24 17:50:56.453  - info: sourceanalytix.0 (8419) Initialization (9 of 9) finished for : hm-rpc.1.PEQ0543850.2.IEC_POWER
                          2021-03-24 17:50:56.462  - info: sourceanalytix.0 (8419) SourceAnalytix initialisation finalized, will handle calculations ... for 9 states
                          • K Kanumouse
                            @dutchman
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #460
                            na dan behebe mal die 3 Fehler (Check settings for)
                              Kanumouse
                              #461
                              @dutchman
                              Das ist mir schon klar, dass da die Fehler liegen. Ich weß aber nicht, wie diese zustande kommen.
                              Ich habe den Adapter auch schon gelöscht und wieder neu installiert und die Startwerte neu eingetragen, aber die Fehler bleiben.
                              Was mich gewundert hat, dass nach der Neuinstallation immer noch die alten Datenpunkte bekannt waren, obwohl ich diese auch gelöscht hatte. Sind da vielleicht irgendwo (/opt/iobroker/iobroker-data) einige Dateien nicht gelöscht worden?
                                MassiveAttack
                                #462
                                Hat leider nicht funktioniert! Habe den cumulated value (=Gesamtwert) korrigiert, und die Startwerte ebenfalls. Beim Starten des Adapters wurde wieder alles überschrieben...
                                Wie kann das Überschreiben verhindern?
                                • K Kanumouse
                                  @dutchman
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #463
                                  So viel ich weiss, gibt es Probleme, wenn man bereits angelegte Datenpunkte löschen möchte, warum auch immer. Einen Workaround findest du hier
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #464
                                    @massiveattack hast du den Punkt Expertenmodus beachtet?
                                    Les mal hier nochmal
                                      MassiveAttack
                                      #465
                                      ja, ich bin dem troubleshooting gefolgt ==> Issue 9 My calculations are incorrect
                                      Mein Szenario:
                                      Ich berechne vom Gesamtwert die "Tages/Monats/...-werte. "Cumulative reading" soll eben diesem Gesamtwert = Source gleich sein, richtig?
                                      Dann noch die Startwerte korrigiert. Nachdem der Adapter wieder neu gestartet hat, wurden die Werte wieder (falsch" überschrieben...
                                        Mein Szenario:
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #466
                                        @massiveattack wenn du es so machst, wie in meinem Link gerade eben, sollte es funktionieren
                                        Also ab ....danach im Reiter Objekte auf Experten Modus, schalten, deinen....
                                          MassiveAttack
                                          #467
                                          Danke, das hat tatsächlich funktioniert 👏 😊
