  4. Test Adapter mihome-vacuum v2.0.x
    apollon77A
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 774.0k Aufrufe 118 Beobachtet
  • Z
    Z
    Zwer2k
    schrieb am zuletzt editiert von Zwer2k
    #1408
    bekomme immer wieder folgenden Fehler. Hab Robororock S50.
    mihome-vacuum.0	2021-03-20 10:20:41.908	warn	(31187) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0	2021-03-20 10:20:41.907	info	(31187) terminating
    mihome-vacuum.0	2021-03-20 10:20:41.903	error	(31187) The id "32" has an invalid type! Expected "string" or "object", received "number".
    mihome-vacuum.0	2021-03-20 10:20:41.903	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
    mihome-vacuum.0	2021-03-20 10:20:41.903	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1089:63
    mihome-vacuum.0	2021-03-20 10:20:41.903	error	at Object.callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:512:25)
    mihome-vacuum.0	2021-03-20 10:20:41.903	error	at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6223:17)
    mihome-vacuum.0	2021-03-20 10:20:41.903	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:505:19)
    mihome-vacuum.0	2021-03-20 10:20:41.903	error	(31187) Error: The id "32" has an invalid type! Expected "string" or "object", received "number".
    mihome-vacuum.0	2021-03-20 10:20:41.901	error	(31187) unhandled promise rejection: The id "32" has an invalid type! Expected "string" or "object", received "number".
    mihome-vacuum.0	2021-03-20 10:20:41.901	error	(31187) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0	2021-03-20 10:20:41.900	info	(31187) send message: Method: app_zoned_clean Params: [[27900,26300,30200,28600,1],[23000,25700,27900,29100,1],[25800,21800,27900,25700,1],[23000,21800,25800,23200,1],[23000,21800,23700,25000,1]]
    oder
    mihome-vacuum.0	2021-03-20 10:42:31.830	warn	(3375) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0	2021-03-20 10:42:31.828	info	(3375) terminating
    mihome-vacuum.0	2021-03-20 10:42:31.824	error	(3375) The id "84" has an invalid type! Expected "string" or "object", received "number".
    mihome-vacuum.0	2021-03-20 10:42:31.824	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
    mihome-vacuum.0	2021-03-20 10:42:31.824	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1089:63
    mihome-vacuum.0	2021-03-20 10:42:31.824	error	at Object.callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:512:25)
    mihome-vacuum.0	2021-03-20 10:42:31.824	error	at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6223:17)
    mihome-vacuum.0	2021-03-20 10:42:31.824	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:505:19)
    mihome-vacuum.0	2021-03-20 10:42:31.824	error	(3375) Error: The id "84" has an invalid type! Expected "string" or "object", received "number".
    mihome-vacuum.0	2021-03-20 10:42:31.822	error	(3375) unhandled promise rejection: The id "84" has an invalid type! Expected "string" or "object", received "number".
    mihome-vacuum.0	2021-03-20 10:42:31.822	error	(3375) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0	2021-03-20 10:42:31.821	info	(3375) send message: Method: app_goto_target Params: [26400,25500]
    Nach dem Absturz bleibt der Adapter meistens ewig gelb bis er wieder online ist.
    (3375) connecting, this can take up to 10 minutes ...
    • S
      S
      Schwabe
      #1409
      Wenn ich mein Problem noch mal hervorholen darf.
      Ich habe 2 ioBroker System. Das "Alte" ist ein TinkerBoard S auf dem ich keinen mihome-vacuum Adpter neuer als 1.1.5 installiert bekomme. Updates brechen mit einer Fehlermeldung ab und ich muss danach den Adapter komplett deinstallieren und neu installieren, doch ansonsten läuft er einwandfrei. Da ich gerne auf mein "Neues" umsteigen möchte, würde ich hier nichts mehr dran ändern wollen.
      Das "Neue" ist ein Ubuntu unter Windows. Leider bleibt hier der Adapter bei "gelb" stehen er wird einfach nicht "grün". Ich kann die Serverdaten eintragen, bekomme meinen "Robbi" angezeigt und kann diesen auch übernehmen.
      Meine Node.js Version ist 12.21.0, die NPM 6.14.11 und der JS Controller ist auch aktuell.
      Ich habe den Adapter auf dem TinkerBoard längere Zeit deaktiviert.
      Ich habe den Adapter mehrfach neu installiert und eingerichtet.
      Ich habe den Sauger ausgeschaltet und wieder eingeschaltet.
      Ich habe den Sauger mehrfach laufen lassen, während der Adapter aktiv war.
      Der Adapter verursacht keine Fehlermeldungen im Log. Der angehängte Log ist von einem manuellen Neustart des Adapters im debug Modus.
      Hat vielleicht noch jemand einen Rat für mich? Vielen Dank im Vorraus.
      > mihome-vacuum.0	2021-03-14 21:05:56.355	debug	(26927) Xiaomi Cloud: Login successful
      > mihome-vacuum.0	2021-03-14 21:05:55.108	info	(26927) set nächster Timer: Nicht verfügbar
      > mihome-vacuum.0	2021-03-14 21:05:54.616	debug	(26927) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      > mihome-vacuum.0	2021-03-14 21:05:54.600	debug	(26927) server started on 0.0.0.0:53421
      > mihome-vacuum.0	2021-03-14 21:05:54.597	info	(26927) Cloud control disabled
      > mihome-vacuum.0	2021-03-14 21:05:54.597	info	(26927) Expert mode enabled, states created
      > mihome-vacuum.0	2021-03-14 21:05:54.595	debug	(26927) Xiaomi Cloud: Logging in
      > mihome-vacuum.0	2021-03-14 21:05:54.594	debug	(26927) load Map creator... false
      > mihome-vacuum.0	2021-03-14 21:05:54.556	info	(26927) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v15.11.0, js-controller: 3.2.16
      > mihome-vacuum.0	2021-03-14 21:05:54.437	debug	(26927) statesDB connected
      > mihome-vacuum.0	2021-03-14 21:05:54.437	debug	(26927) States connected to redis: 127.0.0.1:9000
      > mihome-vacuum.0	2021-03-14 21:05:54.431	debug	(26927) States create User PubSub Client
      > mihome-vacuum.0	2021-03-14 21:05:54.431	debug	(26927) States create System PubSub Client
      > mihome-vacuum.0	2021-03-14 21:05:54.428	debug	(26927) Redis States: Use Redis connection: 127.0.0.1:9000
      > mihome-vacuum.0	2021-03-14 21:05:54.427	debug	(26927) objectDB connected
      > mihome-vacuum.0	2021-03-14 21:05:54.425	debug	(26927) Objects connected to redis: 127.0.0.1:9001
      > mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects client initialize lua scripts
      > mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects create User PubSub Client
      > mihome-vacuum.0	2021-03-14 21:05:54.417	debug	(26927) Objects create System PubSub Client
      > mihome-vacuum.0	2021-03-14 21:05:54.416	debug	(26927) Objects client ready ... initialize now
      > mihome-vacuum.0	2021-03-14 21:05:54.404	debug	(26927) Redis Objects: Use Redis connection: 127.0.0.1:9001
      > host.Server	2021-03-14 21:05:53.954	info	instance system.adapter.mihome-vacuum.0 started with pid 26927
      > host.Server	2021-03-14 21:05:51.499	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      > mihome-vacuum.0	2021-03-14 21:05:50.984	debug	(26912) system.adapter.admin.0: logging true
      > mihome-vacuum.0	2021-03-14 21:05:50.901	info	(26912) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      > mihome-vacuum.0	2021-03-14 21:05:50.900	info	(26912) terminating
      > host.Server	2021-03-14 21:05:50.900	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
      > mihome-vacuum.0	2021-03-14 21:05:50.900	info	(26912) Got terminate signal TERMINATE_YOURSELF
      Thomas BraunT S 2 Antworten Letzte Antwort
      • S Schwabe
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        #1410
        @schwabe sagte in Test Adapter mihome-vacuum v2.0.x:
        Im Log steht was von node15. Schau dir das nochmal an. Siehe Link in meiner Signatur.
          S
          S
          Schwabe
          #1411
          @thomas-braun Danke für Deinen Hinweis, da hast Du natürlich Recht. Der Log war noch von einem Start bevor ich den Node.js auf die aktuelle Stable zurückgesetzt hatte.
          Hier ein aktueller Log:
          mihome-vacuum.0	2021-03-20 14:27:13.704	info	(25385) set nächster Timer: Nicht verfügbar
          mihome-vacuum.0	2021-03-20 14:27:13.185	debug	(25385) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          mihome-vacuum.0	2021-03-20 14:27:13.178	debug	(25385) server started on 0.0.0.0:53421
          mihome-vacuum.0	2021-03-20 14:27:13.175	info	(25385) Cloud control disabled
          mihome-vacuum.0	2021-03-20 14:27:13.175	info	(25385) Expert mode disabled, states deleted
          mihome-vacuum.0	2021-03-20 14:27:13.154	info	(25385) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
          mihome-vacuum.0	2021-03-20 14:27:13.052	debug	(25385) statesDB connected
          mihome-vacuum.0	2021-03-20 14:27:13.052	debug	(25385) States connected to redis: 127.0.0.1:9000
          mihome-vacuum.0	2021-03-20 14:27:13.047	debug	(25385) States create User PubSub Client
          mihome-vacuum.0	2021-03-20 14:27:13.046	debug	(25385) States create System PubSub Client
          mihome-vacuum.0	2021-03-20 14:27:13.043	debug	(25385) Redis States: Use Redis connection: 127.0.0.1:9000
          mihome-vacuum.0	2021-03-20 14:27:13.042	debug	(25385) objectDB connected
          mihome-vacuum.0	2021-03-20 14:27:13.040	debug	(25385) Objects connected to redis: 127.0.0.1:9001
          mihome-vacuum.0	2021-03-20 14:27:13.032	debug	(25385) Objects client initialize lua scripts
          mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects create User PubSub Client
          mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects create System PubSub Client
          mihome-vacuum.0	2021-03-20 14:27:13.031	debug	(25385) Objects client ready ... initialize now
          mihome-vacuum.0	2021-03-20 14:27:13.021	debug	(25385) Redis Objects: Use Redis connection: 127.0.0.1:9001
          host.Server	2021-03-20 14:27:12.721	info	instance system.adapter.mihome-vacuum.0 started with pid 25385
          host.Server	2021-03-20 14:27:12.699	info	"system.adapter.mihome-vacuum.0" enabled
          • M
            M
            mech
            #1412
            Moin, ich habe auch das Problem das "Get Devices" kein Ergebnis mehr liefert. Ich habe die Tage Node auf 12 geupgraded von 10. Ich vermute es liegt daran. Da ich noch einen Snapshot vom System hatte konnte ich IOBroker auf Node 10 zurücksetzen und der Adapter läuft wieder 1a.
            Irgendwas scheint nicht rund zu laufen :)
            Besten Gruß
            • M mech
              Besten Gruß
              Thomas BraunT
              Thomas BraunT
              #1413
              @mech sagte in Test Adapter mihome-vacuum v2.0.x:
              Kann ich nicht bestätigen. Hier läuft der Adapter ganz unauffällig mit node 12 und mit node14.
              Auf einen Debian-System? Das macht man nicht so grobschlächtig, man benutzt seinen Paketmanager und installiert das dann sauber darüber.
                M
                M
                mech
                #1414
                @thomas-braun Bei einem Snapshot unter Proxmox sehe ich da kein Handlungsbedarf über den Paketmanager ;)
                • M mech
                  Thomas BraunT
                  Thomas BraunT
                  #1415
                  @mech
                  Dann wirst du nie 'elegant' mit dem System umgehen können.
                  Snapshot draufknallen ist keine Problemlösung, das ist nur stumpf drüberwalzen.
                  Beim Auto setzt du ja auch keinen Austauschmotor rein, wenn eigentlich nur die Zündkerzen erneuert werden sollen.
                  • S
                    S
                    Spampunk
                    #1416
                    Hallo Freunde des gepflegten Staubsaugens,
                    ich gebe mal ein kurzes Feedback: Auch ich hatte ja lange Zeit keine Map, obwohl ich alle Einstellungen im Adapter und in der Mihome-App vorgenommen hatte. Vor ein paar Tagen dachte ich mir, ich könnte ja mal wieder auf den Schalter "Get Devices" im Mihome-Adapter klicken und -wupps- war der Token da und die Map in meiner VIS.
                    @Meistertr hatte den Verdacht, dass ich keine Verbindung zum Xiaomi-Server erhalte. Das kann ich bis heute nicht genau sagen. Das Einzige, was sich in dieser Zeit geändert hat, ist das Update der JS-Engine. Vielleicht hat das ja etwas bewirkt?
                    Jedenfalls bin ich jetzt glücklich und kann alles wie gewünscht nutzen!
                    Viele Grüße,
                    Spampunk
                    • S Spampunk
                      Viele Grüße,
                      Spampunk
                      da_WoodyD
                      da_WoodyD
                      #1417
                      @spampunk na das liest sich ja mal gut!
                      ohne das get devices gibts immer probleme. bei mir hats damls zum glück sofort funktioniert...
                      • C
                        C
                        Coffeelover
                        #1418
                        ich habe gestern einen Roborock S7 in der App eingebunden.
                        Nachdem ich zunächst daran gescheitert war, weil ich für die Einrichtung die RoborockApp genutzt hatte und nicht die MiHome, ist er jetzt bei GetDevices aufgetaucht und verbunden.
                        Allerdings bleibt der Adapter gelb, obwohl die Zeitzone Roborock & Handy synchronisiert ist.
                        Meldung im Log:
                        (4734) Time difference between Mihome Vacuum and ioBroker: -1616765837 sec
                        Darauf folgt ein neuer Verbindungsversuch. Kennt jemand eine Lösung dazu?
                        • C Coffeelover
                          Meldung im Log:
                          Thomas BraunT
                          Thomas BraunT
                          #1419
                          @coffeelover sagte in Test Adapter mihome-vacuum v2.0.x:
                          1616765837 sec
                          Einer der beiden läuft auf Unix-Nullzeit. Das sind nämlich 51 Jahre umgerechnet = 01.01.1970
                          C 1 Antwort Letzte Antwort
                            1616765837 sec
                            C
                            C
                            Coffeelover
                            #1420
                            @thomas-braun Danke. Die Frage ist eher: wie bekomme ich das auf heute synchronisiert?
                            • C Coffeelover
                              Thomas BraunT
                              Thomas BraunT
                              #1421
                              @coffeelover
                              Welches System hat denn da keine aktuelle Zeit?
                              Auf dem Server:
                              date && date -u
                              prüfen.
                                @coffeelover
                                Auf dem Server:
                                date && date -u
                                prüfen.
                                C
                                C
                                Coffeelover
                                #1422
                                @thomas-braun iobroker läuft auf einem QNAP im Docker installiert.
                                Die Abfrage oben liefert die aktuelle Zeit als CET. Eine zweite Xiaomi-Instanz meckert nicht - die Zeit in iobroker sollte also passen.
                                im Roborock habe ich vorhin in den erweiterten Einstellungen noch eine Möglichkeit zum Setzen einer Zeitzone gefunden. Auch die habe ich auf MEZ gestellt - geändert hat sich wenig.
                                • F
                                  F
                                  Flauschi
                                  #1423
                                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/228
                                  das Problem liegt am S7
                                  • F Flauschi
                                    C
                                    C
                                    Coffeelover
                                    #1424
                                    @flauschi danke dir. Eine Info wie diese hatte ich gesucht. Mal abwarten, dafür gibt es sicher bald eine Lösung.
                                    F 1 Antwort Letzte Antwort
                                      @mech
                                      M
                                      M
                                      mech
                                      schrieb am zuletzt editiert von mech
                                      #1425
                                      @thomas-braun said in Test Adapter mihome-vacuum v2.0.x:
                                      @mech
                                      @thomas-braun Nein, ich würde mir direkt ein neues Auto kaufen.
                                      • M mech
                                        @mech
                                        Thomas BraunT
                                        Thomas BraunT
                                        #1426
                                        @mech Ja, das merke ich.
                                        • C Coffeelover
                                          F
                                          F
                                          Flauschi
                                          #1427
                                          @coffeelover wenn Du den angesprochenen Workaround machst, dann hast Du keine Fehler mehr.
                                          Die Zeitabweichung kam auch nur die ersten paar refreshes und dann nicht mehr.
                                          84.0k
