  4. Test Adapter Shelly v4.0.6 (latest)
    6.7k
shelly
360 Beiträge 34 Kommentatoren 87.7k Aufrufe 36 Beobachtet
  • DiginixD Diginix
    @Stuebi
    Because polling for battery devices is only permieted every 60 sec., the online state will not supported anymore.
    Gilt das nur für batteriebetriebene Shelly oder für alle?
    Es gibt einige Nutzer die den online state in Skripten oder VIS verwenden. Daher wäre der Verlust bei zB Shelly1,2,2.5 usw. nicht schön und man müsste sich den state selbst bauen.
    StuebiS Offline
    StuebiS Offline
    Stuebi
    #167
    @diginix , das gilt für alle Geräte :-( Leider geht es nicht anders.
    ioBroker auf Synology DS216+II im Docker Container
    DiginixD padrinoP 2 Antworten Letzte Antwort
    • StuebiS Stuebi
      @da_woody sagte in Test Adapter Shelly v4.0.6 (latest):
      Dimitar: Shelly fw1.10 is released. APP will be update tomorrow, some new features are supported only from WebUI before that.
      Attention: In next hours devices will show new firmware for update. You may need to wait a bit before see it for all devices.
      Firmware update for :
      Shelly DW/DW2 and RGBW BULB
      is postponed to Monday!
      New features and improvement:
      Devices Scan and connect to strongest AP
      New ESP8266 SDK3.0
      Update to Latest Mongoose OS
      Checkbox for `Access-Control-Allow-Origin added
      Add Report URL to DW and DW2
      HT & Flood add ID to Report URL
      Shely1L energy counters added
      AP Roaming added - device will switch to strongest AP if there is. Target RSSI can be set in Network tab.
      Debug Log is added - can be activated and download from Device Info
      Door/Window 1 and 2 - Vibration sensitivity can be set from customer
      Soft reboot added for all relays and EM/3EM
      Add unicast ability for CoIoT - to decrease network traffic and better network compatibility
      Dimmer2 Load Autodetect and Calibration are improved
      Battery operated device connect faster to Wi-Fi
      RGBW2, Color BULB do not flash anymore during update
      Increase timeout for URL action
      Shelly1/PM Temperature automation Repeatable option added
      Reconnect to Strongest AP is added in Network tab for battery operated devices
      Enable action execution via MQTT renamed to Enable MQTT
      ... some other improvements.
      https://shelly-api-docs.shelly.cloud/ UPDATED
      Solved Big/Fixes:
      Devices cannot see new FW version if cloud is Disabled
      Network stability improved - devices should not be offline anymore
      Device Channel name for Shelly 1PM and PlugS is not showing immediately.
      Shelly 1PM - External Switch do not work as expected
      Shelly Duo RGBW night mode not working
      Shelly UNI Json bug
      Wrong Time zone detection
      I3 doesn't report temperature topic in MQTT
      MQTT: devices with inputs send input_event topic periodicallyShely1L energy counters
      Dimmer2 Transition time does not applies in some situations
      Shelly1L default state is "unknown"
      HT report unreal values
      Shelly2.5 overtemperature error missing in WebUI
      Button1 fails to connect to cloud/locally
      False Overpower consumption detected from Shelly Plug, Plug S, Shelly1 PM fixed.
      ... more minor bugs are fixed
      Danke!
      Wichtig: Unicast wird erst einmal nicht vom ioBroker unterstützt. Bitte nicht Unicast nutzen. Ausnahme ist der Shelly Motion.
      qqolliQ Offline
      qqolliQ Offline
      qqolli
      #168
      @stuebi
      Moin,
      ich habe mal, da ich immer Probleme mit den Shellies und dem nanoHD von Unifi habe, die neue FW testweise auf einen Shelly aufgespielt. Bis jetzt noch keine Probleme. Du sagst, nicht Unicast nutzen, ich habe es z. Zt. so und bis jetzt habe ich im ioB kein Problem:
      Soll (muss) ich "Enable CoIoT" deaktivieren und dann Save?
      • StuebiS Stuebi
        DiginixD Offline
        DiginixD Offline
        Diginix
        #169
        @stuebi Oh, dann bleib ich erstmal auf 4.0.7b1 und melde das mal in der Facebook Gruppe, denn da hatten sich Nutzer mit Abhängigkeiten zu diesem state gemeldet.
        Ich kann das mit Ping und einem Skript kompensieren. Aber sicher nicht alle.
        btw: Kommt denn "Source" irgendwann mal für Shelly2/2.5 im roller shutter mode?
        Das vermisse ich seit Monaten und kompensiere es auch durch eigene http requests auf /status und parse das JSON.
        Im Relais Mode ist es ja schon im Adapter drin. Wo ist da die Schwierigkeit das auch für roller shutter Mode zu implementieren?
        ..:: So long! Tom ::..
        • qqolliQ qqolli
          @stuebi
          Moin,
          da_WoodyD Online
          da_WoodyD Online
          #170
          @qqolli du benutzt mcast und nicht unicast laut deinem screenshot. das passt schon so.
          • StuebiS Stuebi
            New ESP8266 SDK3.0
            Solved Big/Fixes:
            Shelly UNI Json bug
            Danke!
            qqolliQ Offline
            qqolliQ Offline
            qqolli
            #171
            @stuebi
            Ist es geplant, seitens ioB auf Unicast umzustellen? Denn, speziell für Shelly und Unifi:
            "Shelly stellt ab sofort von Multicast auf Unicast um, die Vorteile daraus könnt ihr unten lesen.
            Durch dieses Update sorgt Shelly vor allen Dingen dafür, dass den Verbindungsabbrüche mit den sehr verbreiteten Netzwerkprodukten von Ubiquiti Unifi ein Ende gesetzt wird. Vor allem die neue Hardware mit Wifi 6 war hiervon betroffen. Die Shellys sollten sich jetzt ohne Probleme z.B. mit einem Unifi 6 Long Range Access Point verbinden und auch verbunden bleiben."
            Denn genau diese Probleme habe auch hier viele im Zusammenspiel mit den Unifi APs.
            • qqolliQ qqolli
              @stuebi
              #172
              @qqolli
              Die "Verbindung" Unicast und Unifi Probleme hängen für mich bisher nicht direkt zusammen.
              Unicast/Multicast ist für mich eine Art wie die Coap Daten im Netz verteilt werden. Dies passiert bisher in Multicast (überwiegend) aber Unicast hat diverse Vorteile. Gibt Hardware (Switches etc.) die diverse Formen blocken und und so einen Betrieb unmöglich machen (oder ist das das Unifi Problem das Du meinst?).
              Das Unifi Problem habe ich bisher nicht konkret gesehen, wo das Problem wirklich lag, es taucht aber immer wieder Mongoose OS und der ESP8266 SDK 3.0 auf.
              Weitere "Features" wurden jetzt implementiert wie SoftBoot nach WlanLoss und AP-Roaming. Das ist für mich etwas "aus der Ecke": der ESP8266 unterstützt kein WLan Roaming 802.11v/k.
              qqolliQ 1 Antwort Letzte Antwort
                @qqolli
                qqolliQ Offline
                qqolliQ Offline
                qqolli
                #173
                @ralf-0
                Mag sein das Du keine Probleme hast; ich und viele andere haben sie (sieh auch hier im Forum) und soweit ich das aus den Reaktionen im Netz sehen kann, bring Unicast speziell bei diesem Problem durchaus eine Menge.
                • qqolliQ qqolli
                  @ralf-0
                  #174
                  @qqolli said in Test Adapter Shelly v4.0.6 (latest):
                  @ralf-0
                  ..... bring Unicast speziell bei diesem Problem durchaus eine Menge.
                  Bei welchem Problem? Shellys im Wlan ohne IP und Verbindung nach diverser Zeit?
                  • StuebiS Stuebi
                    padrinoP Offline
                    padrinoP Offline
                    padrino
                    #175
                    @stuebi sagte in Test Adapter Shelly v4.0.6 (latest):
                    Wenn der Adapter nicht unterscheiden kann, wäre es dann nicht besser das Intervall des Polls zu erhöhen, statt allen Geräten den Status wegzunehmen? =)
                    • padrinoP padrino
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #176
                      @padrino Oder konfigurierbar in der Instanz. Wer keine Shelly mit Batterie hat, kann es aktiv lassen.
                      Oder noch feiner eine Liste mit IDs der (Batterie)geräte, die den Status nicht haben sollen oder umgekehrt damit er default erstmal fehlt.
                      StuebiS 1 Antwort Letzte Antwort
                      • DiginixD Diginix
                        StuebiS Offline
                        StuebiS Offline
                        Stuebi
                        #177
                        @diginix , erst einmal wird der Status online nicht unterstützt. I am sorry, aber so einfach wieder das klingt es nicht umzusetzen.
                        • StuebiS Stuebi
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #178
                          @stuebi Woher kam er denn bisher wenn er nicht unterstützt wird?
                          • DiginixD Diginix
                            StuebiS Offline
                            StuebiS Offline
                            Stuebi
                            #179
                            @diginix , schaue im sourcecode nach, da siehst du es. Für mich ist es extremer Aufwand und die Zeit habe ich momentan nicht.
                            Eigentlich habe ich momentan überhaupt keine Zeit mehr für den Support des Shelly Adapters. Daher fokussiere ich mich auf notwendigste.
                            • StuebiS Stuebi
                              DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #180
                              @stuebi
                              tcpp.probe
                              Ok, dann hoffe ich dass sich jemand anderes für die Pflege des, durchaus für sehr viele wichtige, Adapters findet.
                              SWE!
                              P 1 Antwort Letzte Antwort
                              • DiginixD Diginix
                                @stuebi
                                tcpp.probe
                                SWE!
                                PrinzEisenherz1
                                schrieb am zuletzt editiert von PrinzEisenherz1
                                #181
                                Hmmm....also ich habe jetzt zuerst mal nur einen Shelly 1 und einen Shelly Dimmer2 auf die 1.10 (final) angehoben und auch auf Uni-Cast umgestellt. Absolut keine Probleme hier. Alles funktioniert auch mit dem Shelly-Adapter ohne Probleme. Dann habe ich auch den Rest ( 15 Shelly1, 2 Shelly Floot und noch 1 Shelly Dimmer 2) umgestellt. Bis jetzt alles problemlos mit CoAP und Uni-Cast.
                                Johnny
                                Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                                • P PrinzEisenherz1
                                  Johnny
                                  da_WoodyD Online
                                  da_WoodyD Online
                                  #182
                                  @prinzeisenherz1 du hast bei COIOT die IP deines ioBrokers eingetragen und bekommst daten zurück???
                                  StuebiS P 2 Antworten Letzte Antwort
                                  • da_WoodyD da_Woody
                                    StuebiS Offline
                                    StuebiS Offline
                                    Stuebi
                                    #183
                                    genau!
                                      PrinzEisenherz1
                                      #184
                                      So sehen meine Einstellungen aus und wenn ich z.B. den Shelly schalte dann sehe ich das auch in ioBroker.
                                      Oder wie meinst de das mit Daten zurück?
                                      • P PrinzEisenherz1
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        #185
                                        @prinzeisenherz1 okok, ich glaubs dir! habs gerade mit einem 1er getestet nach dem @Stuebi genau! geschrieben hat...
                                        P StuebiS 2 Antworten Letzte Antwort
                                          PrinzEisenherz1
                                          #186
                                          @da_woody also lüpt alles, oder? Also ich habe mit Uni-Cast keine Probleme
