  4. Test Adapter Shelly v4.0.6 (latest)
    6.7k
shelly
360 Beiträge 34 Kommentatoren 87.8k Aufrufe 36 Beobachtet
  • StuebiS Stuebi
    @da_woody sagte in Test Adapter Shelly v4.0.6 (latest):
    Dimitar: Shelly fw1.10 is released. APP will be update tomorrow, some new features are supported only from WebUI before that.
    Attention: In next hours devices will show new firmware for update. You may need to wait a bit before see it for all devices.
    Firmware update for :
    Shelly DW/DW2 and RGBW BULB
    is postponed to Monday!
    New features and improvement:
    Devices Scan and connect to strongest AP
    New ESP8266 SDK3.0
    Update to Latest Mongoose OS
    Checkbox for `Access-Control-Allow-Origin added
    Add Report URL to DW and DW2
    HT & Flood add ID to Report URL
    Shely1L energy counters added
    AP Roaming added - device will switch to strongest AP if there is. Target RSSI can be set in Network tab.
    Debug Log is added - can be activated and download from Device Info
    Door/Window 1 and 2 - Vibration sensitivity can be set from customer
    Soft reboot added for all relays and EM/3EM
    Add unicast ability for CoIoT - to decrease network traffic and better network compatibility
    Dimmer2 Load Autodetect and Calibration are improved
    Battery operated device connect faster to Wi-Fi
    RGBW2, Color BULB do not flash anymore during update
    Increase timeout for URL action
    Shelly1/PM Temperature automation Repeatable option added
    Reconnect to Strongest AP is added in Network tab for battery operated devices
    Enable action execution via MQTT renamed to Enable MQTT
    ... some other improvements.
    https://shelly-api-docs.shelly.cloud/ UPDATED
    Solved Big/Fixes:
    Devices cannot see new FW version if cloud is Disabled
    Network stability improved - devices should not be offline anymore
    Device Channel name for Shelly 1PM and PlugS is not showing immediately.
    Shelly 1PM - External Switch do not work as expected
    Shelly Duo RGBW night mode not working
    Shelly UNI Json bug
    Wrong Time zone detection
    I3 doesn't report temperature topic in MQTT
    MQTT: devices with inputs send input_event topic periodicallyShely1L energy counters
    Dimmer2 Transition time does not applies in some situations
    Shelly1L default state is "unknown"
    HT report unreal values
    Shelly2.5 overtemperature error missing in WebUI
    Button1 fails to connect to cloud/locally
    False Overpower consumption detected from Shelly Plug, Plug S, Shelly1 PM fixed.
    ... more minor bugs are fixed
    Danke!
    Wichtig: Unicast wird erst einmal nicht vom ioBroker unterstützt. Bitte nicht Unicast nutzen. Ausnahme ist der Shelly Motion.
    qqolliQ Offline
    qqolliQ Offline
    qqolli
    #171
    @stuebi
    Ist es geplant, seitens ioB auf Unicast umzustellen? Denn, speziell für Shelly und Unifi:
    "Shelly stellt ab sofort von Multicast auf Unicast um, die Vorteile daraus könnt ihr unten lesen.
    Durch dieses Update sorgt Shelly vor allen Dingen dafür, dass den Verbindungsabbrüche mit den sehr verbreiteten Netzwerkprodukten von Ubiquiti Unifi ein Ende gesetzt wird. Vor allem die neue Hardware mit Wifi 6 war hiervon betroffen. Die Shellys sollten sich jetzt ohne Probleme z.B. mit einem Unifi 6 Long Range Access Point verbinden und auch verbunden bleiben."
    Denn genau diese Probleme habe auch hier viele im Zusammenspiel mit den Unifi APs.
    • qqolliQ qqolli
      @stuebi
      #172
      @qqolli
      Die "Verbindung" Unicast und Unifi Probleme hängen für mich bisher nicht direkt zusammen.
      Unicast/Multicast ist für mich eine Art wie die Coap Daten im Netz verteilt werden. Dies passiert bisher in Multicast (überwiegend) aber Unicast hat diverse Vorteile. Gibt Hardware (Switches etc.) die diverse Formen blocken und und so einen Betrieb unmöglich machen (oder ist das das Unifi Problem das Du meinst?).
      Das Unifi Problem habe ich bisher nicht konkret gesehen, wo das Problem wirklich lag, es taucht aber immer wieder Mongoose OS und der ESP8266 SDK 3.0 auf.
      Weitere "Features" wurden jetzt implementiert wie SoftBoot nach WlanLoss und AP-Roaming. Das ist für mich etwas "aus der Ecke": der ESP8266 unterstützt kein WLan Roaming 802.11v/k.
      qqolliQ 1 Antwort Letzte Antwort
        @qqolli
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        #173
        @ralf-0
        Mag sein das Du keine Probleme hast; ich und viele andere haben sie (sieh auch hier im Forum) und soweit ich das aus den Reaktionen im Netz sehen kann, bring Unicast speziell bei diesem Problem durchaus eine Menge.
        • qqolliQ qqolli
          @ralf-0
          #174
          @qqolli said in Test Adapter Shelly v4.0.6 (latest):
          @ralf-0
          ..... bring Unicast speziell bei diesem Problem durchaus eine Menge.
          Bei welchem Problem? Shellys im Wlan ohne IP und Verbindung nach diverser Zeit?
          • StuebiS Stuebi
            @diginix , das gilt für alle Geräte :-( Leider geht es nicht anders.
            padrinoP Offline
            padrinoP Offline
            padrino
            #175
            @stuebi sagte in Test Adapter Shelly v4.0.6 (latest):
            Wenn der Adapter nicht unterscheiden kann, wäre es dann nicht besser das Intervall des Polls zu erhöhen, statt allen Geräten den Status wegzunehmen? =)
            • padrinoP padrino
              DiginixD Offline
              DiginixD Offline
              Diginix
              #176
              @padrino Oder konfigurierbar in der Instanz. Wer keine Shelly mit Batterie hat, kann es aktiv lassen.
              Oder noch feiner eine Liste mit IDs der (Batterie)geräte, die den Status nicht haben sollen oder umgekehrt damit er default erstmal fehlt.
              ..:: So long! Tom ::..
              StuebiS 1 Antwort Letzte Antwort
              • DiginixD Diginix
                StuebiS Offline
                StuebiS Offline
                Stuebi
                #177
                @diginix , erst einmal wird der Status online nicht unterstützt. I am sorry, aber so einfach wieder das klingt es nicht umzusetzen.
                ioBroker auf Synology DS216+II im Docker Container
                • StuebiS Stuebi
                  DiginixD Offline
                  DiginixD Offline
                  Diginix
                  #178
                  @stuebi Woher kam er denn bisher wenn er nicht unterstützt wird?
                  • DiginixD Diginix
                    StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #179
                    @diginix , schaue im sourcecode nach, da siehst du es. Für mich ist es extremer Aufwand und die Zeit habe ich momentan nicht.
                    Eigentlich habe ich momentan überhaupt keine Zeit mehr für den Support des Shelly Adapters. Daher fokussiere ich mich auf notwendigste.
                    • StuebiS Stuebi
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #180
                      @stuebi
                      tcpp.probe
                      Ok, dann hoffe ich dass sich jemand anderes für die Pflege des, durchaus für sehr viele wichtige, Adapters findet.
                      SWE!
                      P 1 Antwort Letzte Antwort
                      • DiginixD Diginix
                        @stuebi
                        tcpp.probe
                        SWE!
                        PrinzEisenherz1
                        schrieb am zuletzt editiert von PrinzEisenherz1
                        #181
                        Hmmm....also ich habe jetzt zuerst mal nur einen Shelly 1 und einen Shelly Dimmer2 auf die 1.10 (final) angehoben und auch auf Uni-Cast umgestellt. Absolut keine Probleme hier. Alles funktioniert auch mit dem Shelly-Adapter ohne Probleme. Dann habe ich auch den Rest ( 15 Shelly1, 2 Shelly Floot und noch 1 Shelly Dimmer 2) umgestellt. Bis jetzt alles problemlos mit CoAP und Uni-Cast.
                        Johnny
                        Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                        • P PrinzEisenherz1
                          Johnny
                          da_WoodyD Online
                          da_WoodyD Online
                          #182
                          @prinzeisenherz1 du hast bei COIOT die IP deines ioBrokers eingetragen und bekommst daten zurück???
                          StuebiS P 2 Antworten Letzte Antwort
                          • da_WoodyD da_Woody
                            StuebiS Offline
                            StuebiS Offline
                            Stuebi
                            #183
                            genau!
                              PrinzEisenherz1
                              #184
                              So sehen meine Einstellungen aus und wenn ich z.B. den Shelly schalte dann sehe ich das auch in ioBroker.
                              Oder wie meinst de das mit Daten zurück?
                              • P PrinzEisenherz1
                                da_WoodyD Online
                                da_WoodyD Online
                                #185
                                @prinzeisenherz1 okok, ich glaubs dir! habs gerade mit einem 1er getestet nach dem @Stuebi genau! geschrieben hat...
                                P StuebiS 2 Antworten Letzte Antwort
                                  PrinzEisenherz1
                                  #186
                                  @da_woody also lüpt alles, oder? Also ich habe mit Uni-Cast keine Probleme
                                  • P PrinzEisenherz1
                                    PrinzEisenherz1
                                    #187
                                    also bei Dir jetzt auch alles schiko?
                                      StuebiS Offline
                                      StuebiS Offline
                                      Stuebi
                                      #188
                                      @da_woody , auch wenn du am über die App oder Web schaltest, siehst Du dann die Änderung in ioBroker?
                                      Bei mir ging es eben kurz, jetzt leider nicht mehr :-(
                                      da_WoodyD P 2 Antworten Letzte Antwort
                                      • StuebiS Stuebi
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        #189
                                        @stuebi im moment tuts bei mir App, iQontrol, auch direkt im alias schalten...
                                        • StuebiS Stuebi
                                          PrinzEisenherz1
                                          #190
                                          @stuebi Wenn ich über VIS, oder Shelly-App, ioBroker oder Web. Überall passen die zustände. Alles io bei mir. Trotz drei Repeater (Fritz-Mesh) im Haus verteilt.
