  4. Test Adapter doorio v2.1.2
door intercomdoorpitürsprechstelle
590 Beiträge 36 Kommentatoren 209.8k Aufrufe 39 Beobachtet
  • WalW Wal
    @renegade-0 ,
    AEC braucht viel Rechenleistung, aber nur wenn gerade gesprochen wird.
    so sieht das bei mir aus:
    ui: stdio
    aucodec: PCMU/8000/1
    aucodec: PCMA/8000/1
    aufilt: vumeter
    auplay: pulse
    ausrc: pulse
    medianat: stun
    medianat: turn
    medianat: ice
    uuid: loaded UUID 4f4bd014-8283-9cf1-87de-db164720e847 from file /home/pi/.baresip/uuid
    Populated 1 account
    module: loading app auloop.so
    module: loading app contact.so
    Populated 3 contacts
    module: loading app debug_cmd.so
    module: loading app menu.so
    module: loading app syslog.so
    module: loading app ctrl_tcp.so
    ctrl_tcp: TCP socket listening on 0.0.0.0:4444
    Populated 2 audio codecs
    Populated 1 audio filter
    Populated 0 video codecs
    Populated 0 video filters
    baresip is ready.
    testdoor2sip@192.168.122.2: {0/UDP/v4} 200 OK () [1 binding]
    All 1 useragent registered successfully! (13 ms)
    ua: sipsess connect via UDP 192.168.122.2:5060 --> 192.168.122.27:48061
    call: alloc with params laddr=192.168.122.27, af=AF_INET, use_rtp=1
    call: use_video=0
    sip:testdoor2sip@192.168.122.2: Incoming call from: Wohnzimmer sip:**610@fritz.box - (press 'a' to accept)
    pulse: opening player (8000 Hz, 1 channels, device 'noecho_sound_out')
    pulse: playback started
    sip:testdoor2sip@192.168.122.2: Answering incoming call
    pulse: stopping playback thread
    answering call from sip:**610@fritz.box with 200
    call: update media
    audio: Set audio decoder: PCMA 8000Hz 1ch
    audio: start
    audio: player started with sample format S16LE
    audio: Set audio encoder: PCMA 8000Hz 1ch
    audio: start
    pulse: opening recorder (8000 Hz, 1 channels, device 'noecho_mic_in')
    pulse: recording started
    audio: source started with sample format S16LE
    audio tx pipeline:       pulse ---> vumeter ---> PCMA
    audio rx pipeline:       pulse <--- vumeter <--- PCMA
    call: stream start (active=1)
    audio: start
    testdoor2sip@192.168.122.2: Call established: sip:**610@fritz.box
    stream: incoming rtp for 'audio' established, receiving from 192.168.12.2:7080
    sip:**610@fritz.box: session closed: Connection reset by peer                ]  [=========       ]
    pulse: stopping record thread
    sip:testdoor2sip-0x1af7ef8@192.168.122.27:48061: Call with sip:**610@fritz.box terminated (duration: 1 min 24 secs)
    audio: destroyed (started=1)
    Renegade 0
    #463
    @wal
    Kannst du über das shell Fenster noch eingeben?
    Kann ich irgendwie das Journal vom Pulse sehen, wenn er als User läuft? So wie systemctl status?
    WalW 2 Antworten Letzte Antwort
    • R Renegade 0
      @wal
      WalW Offline
      WalW Offline
      Wal
      schrieb am zuletzt editiert von Wal
      #464
      @renegade-0 ,
      du musst in der Baresip-Config das syslog modul aktivieren und dann ist es die Datei "/var/log/syslog".
      Ja ,ich kann eingeben z.B. Ruf annehmen mit "a" da muss aber das stdio Modul aktiviert sein.
      edit: "systemctl --user status pulseaudio.service"
      Walter
      DoorIO-Adapter
      • R Renegade 0
        @wal
        WalW Offline
        WalW Offline
        Wal
        #465
        @renegade-0 ,
        du kannst auch mal nur was abspielen.
        "paplay -v -p /usr/share/baresip/ring.wav"
        pi@raspberrypi:~ $ paplay -v -p /usr/share/baresip/ring.wav
        abspielen-Stream mit Abtastwert-Angabe »uLaw 1ch 8000Hz« und Kanalzuordnung »mono« wird geöffnet.
        Verbindung hergestellt.
        Stream wurde erfolgreich erstellt.
        Pufferdaten: maxlenght=4194304, tlength=16000, prebuf=15841, minreq=160
        Abtastwert-Angabe »uLaw 1ch 8000Hz« wird benutzt, Kanalzuordnung »mono«.
        Verbunden mit Gerät noecho_sound_out (Index: 1, ausgesetzt: no).
        Stream gestartet:
        Stream leergelaufen.
        Wiedergabe-Stream entleert.663 usec.
        Verbindung zu Server entleert.
        Walter
        DoorIO-Adapter
          AingTii
          #466
          @wal sagte in Test Adapter doorio v1.1.x:
          Fertiges Image für den RPI3 und RPI4, Benutzer "pi" Passwort "raspberry".
          Passwort zum runterladen lautet "iobroker" :
          Selfmade-DoorIntercom
          Image flashen
          RPI hochfahren und mit "sudo raspi-config" in Advanced Options Expanded Filesystem anstossen.
          "sudo passwd" Passwort für root erstellen.
          Baresip, config.yaml und pulseaudio der eigenen Hardware/Software anpassen.
          @Wal ,
          mache ich da irgendwas falsch? pi und rapsberry funktioniert leider nicht
          Jens
          WalW 1 Antwort Letzte Antwort
          • A AingTii
            Image flashen
            @Wal ,
            Jens
            WalW Offline
            WalW Offline
            Wal
            #467
            @aingtii ,
            raspberry
            Walter
            DoorIO-Adapter
            A 2 Antworten Letzte Antwort
            • WalW Wal
              @aingtii ,
              raspberry
              AingTii
              #468
              @wal
              vertippt hier im Forum.
              aber habe das Problem grad gefunden, englisches Tastaturlayout als z statt y
              nun wurschtel ich mich durch die fehlermeldungen...
              • WalW Wal
                @aingtii ,
                raspberry
                AingTii
                #469
                @wal
                momentan kommt diese fehlermeldung...
                baresip v0.6.5 Copyright (C) 2010 - 2019 Alfred E. Heggestad et al.
                Local network address: IPv4=eth0|192.168.5.79
                ua: SIP Transport failed: Address already in use
                ua: init failed (Address already in use)
                ua: stop all (forced=1)
                main: unloading modules..
                sag mal welche version vom img muss ich laden die vom ersten Post?
                • A AingTii
                  @wal
                  WalW Offline
                  WalW Offline
                  Wal
                  #470
                  @aingtii ,
                  ja vom ersten Post.
                  edit: die Fehlermeldung wird kommen da im Image Baresip schon als Service läuft und du es nochmal mit baresip -vvv startest.
                  Walter
                  DoorIO-Adapter
                  • WalW Wal
                    @aingtii ,
                    ja vom ersten Post.
                    AingTii
                    #471
                    @wal
                    irgendwie bekomme ich im iobroker unter mqtt nicht die konfigurierten GPIOs angezeigt,
                    weder in noch out noch sonstwas.
                    hast Du ein Tipp für mich?
                    mqtt:
                      host: 192.168.5.4
                      port: 1889
                      user: "meinMQTTUser"
                      password: "meinMQTTPasswort"
                      topic_prefix: doorpigpio
                      client_id: doorpigpio
                    gpio_modules:
                      - name: rpi
                        module: raspberrypi
                    digital_inputs:
                      - name: DoorBell_1
                        module: rpi
                        pin: 3
                        on_payload: "true"
                        off_payload: "false"
                      - name: DoorBell_2
                        module: rpi
                        pin: 4
                        on_payload: "true"
                    digital_outputs:
                      - name: DoorOpen
                        module: rpi
                        pin: 18
                        on_payload: "true"
                      - name: DoorOpen1
                        module: rpi
                        pin: 23
                        on_payload: "true"
                      - name: DoorOpen2
                        module: rpi
                        pin: 24
                        on_payload: "true"
                    • A AingTii
                      @wal
                      mqtt:
                        host: 192.168.5.4
                        port: 1889
                      gpio_modules:
                        - name: rpi
                          module: raspberrypi
                      digital_inputs:
                        - name: DoorBell_1
                          module: rpi
                          pin: 3
                          on_payload: "true"
                        - name: DoorBell_2
                          module: rpi
                          pin: 4
                          on_payload: "true"
                      digital_outputs:
                        - name: DoorOpen
                          module: rpi
                          pin: 18
                          on_payload: "true"
                        - name: DoorOpen1
                          module: rpi
                          pin: 23
                          on_payload: "true"
                        - name: DoorOpen2
                          module: rpi
                          pin: 24
                          on_payload: "true"
                      WalW Offline
                      WalW Offline
                      Wal
                      #472
                      @aingtii ,
                      wenn im ioBroker-Log nichts auftaucht, sind die Verbindungseinstellungen falsch.
                      Walter
                      DoorIO-Adapter
                      • WalW Wal
                        @aingtii ,
                        AingTii
                        #473
                        @wal
                        wie kann ich denn am Pi überprüfen ob mqtt läuft?
                        habe irgendwie das gefühl es ist nicht gestartet
                        die doorio verbindung steht, ich kann auch anrufen lassen.
                        Im Log im iobroker kommt garnichts zu mqtt was den Pi betrifft
                        • A AingTii
                          @wal
                          WalW Offline
                          WalW Offline
                          Wal
                          #474
                          @aingtii ,
                          sudo systemctl status piface
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @aingtii ,
                            AingTii
                            #475
                            okay, liegt es evtl. daran, dass ich kein PiFace nutze sondern die GPIO direkt?
                            wenn ich das richtig gelesen hatte muss ich doch piface dann deaktivieren oder habe ich das falsch rausgelesen?
                            habe pimqttio noch mal installiert beim start kommt das...
                            pi@raspberrypi:~ $ python3 -m mqtt_io config.yml
                            2021-03-19 08:07:12 mqtt_io.server [INFO] Digital input 'DoorBell_1' value changed to True
                            2021-03-19 08:07:12 mqtt_io.server [INFO] Digital input 'DoorBell_2' value changed to False
                            2021-03-19 08:07:12 mqtt_io.server [INFO] Connecting to MQTT...
                            2021-03-19 08:07:12 mqtt_io.server [INFO] Waiting for our tasks to complete...
                            Traceback (most recent call last):
                              File "/home/pi/.local/lib/python3.7/site-packages/asyncio_mqtt/client.py", line 79, in connect
                                await loop.run_in_executor(None, self._client.connect, self._hostname, self._port, 60)
                              File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
                                result = self.fn(*self.args, **self.kwargs)
                              File "/usr/local/lib/python3.7/dist-packages/paho_mqtt-1.5.0-py3.7.egg/paho/mqtt/client.py", line 937, in connect
                                return self.reconnect()
                              File "/usr/local/lib/python3.7/dist-packages/paho_mqtt-1.5.0-py3.7.egg/paho/mqtt/client.py", line 1071, in reconnect
                                sock = self._create_socket_connection()
                              File "/usr/local/lib/python3.7/dist-packages/paho_mqtt-1.5.0-py3.7.egg/paho/mqtt/client.py", line 3522, in _create_socket_connection
                                return socket.create_connection(addr, source_address=source, timeout=self._keepalive)
                              File "/usr/lib/python3.7/socket.py", line 727, in create_connection
                                raise err
                              File "/usr/lib/python3.7/socket.py", line 716, in create_connection
                                sock.connect(sa)
                            ConnectionRefusedError: [Errno 111] Connection refused
                            During handling of the above exception, another exception occurred:
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/server.py", line 1142, in run
                                await self._connect_mqtt()
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/server.py", line 549, in _connect_mqtt
                                await self.mqtt.connect()
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/mqtt/asyncio_mqtt.py", line 63, in connect
                                await self._client.connect(timeout=timeout)
                              File "/home/pi/.local/lib/python3.7/site-packages/asyncio_mqtt/client.py", line 88, in connect
                                raise MqttError(str(error))
                            asyncio_mqtt.error.MqttError: [Errno 111] Connection refused
                              File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
                                "__main__", mod_spec)
                              File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
                                exec(code, run_globals)
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/__main__.py", line 85, in <module>
                                main()
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/__main__.py", line 80, in main
                                mqtt_gpio.run()
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/server.py", line 1174, in run
                                self.loop.run_until_complete(self._main_task)
                              File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
                                return future.result()
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/server.py", line 1168, in run
                                await self.shutdown()
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/server.py", line 1229, in shutdown
                                wait=False,
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/server.py", line 635, in _mqtt_publish
                                await self.mqtt.publish(msg)
                              File "/home/pi/.local/lib/python3.7/site-packages/mqtt_io/mqtt/asyncio_mqtt.py", line 76, in publish
                                topic=msg.topic, payload=msg.payload, qos=msg.qos, retain=msg.retain
                              File "/home/pi/.local/lib/python3.7/site-packages/asyncio_mqtt/client.py", line 128, in publish
                                raise MqttCodeError(info.rc, 'Could not publish message')
                            asyncio_mqtt.error.MqttCodeError: [code:4] Could not publish message
                            • A AingTii
                                  raise err
                                  sock.connect(sa)
                                  main()
                                  mqtt_gpio.run()
                                  wait=False,
                              WalW Offline
                              WalW Offline
                              Wal
                              #476
                              @aingtii ,
                              nein piface ist nur ein Name den ich gewählt habe. Du hast ja die Konfig an GPIO angepasst. Du hattest nur keine Verbindung und jetzt nach dem neu installieren ein anders Problem.
                              Walter
                              DoorIO-Adapter
                              • WalW Wal
                                @gerei ,
                                baresip läuft doch als Dienst, du musst baresip nicht mehr starten.
                                Falls du baresip immer mit hand starten möchtest, musst du den Dienst deaktivieren.
                                sudo systemctl stop baresip
                                sudo systemctl disable baresip
                                AingTii
                                #477
                                @wal
                                Ich habe irgendwie das problem dass beim manuellen start über
                                $ baresip
                                alles läuft, allerdings wenn ich es über
                                sudo systemctl enable baresip hinzufügen, funktioniert erst mal
                                auch alles, aber der Anruf wird sofort nach dem annehmen wieder aufgelegt, kann also nicht sprechen....
                                Leider ist der Entwickler nicht so gesprächig und wirklich dokumentiert ist das ganze ja nicht.
                                anscheinend hatte ich auch eine Alte Version installiert, wobei für die neue auch nicht
                                Wirklich erklärt ist wie ich die installieren muss, da muss man sich einiges selbst erdenken.....
                                Hast Du ne Idee dazu?
                                Und wie mache ich dass das ein lifevideo übertragen wird oder liegt es nur an Fritz das es nicht
                                unterstützt wird?
                                Hast Du eigentlich ne App die auf dem Smartphone die Gegenstelle darstellt?
                                Gruß Jens
                                • A AingTii
                                  @wal
                                  $ baresip
                                  unterstützt wird?
                                  Gruß Jens
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #478
                                  @aingtii ,
                                  ich nutze Fritzfons mit einer Fritzbox, da wird das Bild vom Mjpg-Streamer den ich für eine USB-Webcam installiert habe direkt angezeigt. Video über Baresip habe ich nicht versucht. Wenn du Baresip mit Hand startest, kommt nach dem annehmen eine Fehlermeldung ?
                                  Walter
                                  DoorIO-Adapter
                                  • WalW Wal
                                    @aingtii ,
                                    AingTii
                                    #479
                                    @wal
                                    Das ist ja das Problem bei manuell gestartete baresip läuft es einwandfrei.
                                    Aber als System automatisch beim Boot gestartet sehe ich ja keine Ausgabe und dnn habe ich die Probleme, dass es gleich wieder auflegt und ich dann nur noch tut tut tut höre
                                    • A AingTii
                                      @wal
                                      WalW Offline
                                      WalW Offline
                                      Wal
                                      #480
                                      @aingtii ,
                                      in "/var/log/messages" stehen die Meldungen.
                                      Walter
                                      DoorIO-Adapter
                                      • WalW Wal
                                        @aingtii ,
                                        AingTii
                                        #481
                                        @wal
                                        also in /var/log/messages habe ich keienerlei einträge,
                                        letzter Eintrag war 18:55
                                        19:07 habe ich 3x hintereinander den Anruf ausgelöst und und angenommen wobei jedes
                                        baresip unmittelbar nach Annahme von allein aufgelegt hat.
                                        der Nächste Eintrag ist dann 19:08 das booten bzw kurz vor dem booten jedes mal der scan
                                        der Ports denke ich mal. (mtp-probe)
                                        Merkwürdig, vor Allem was ist der Unterschied, ob ich es nun manuell starte oder per service?!?!?
                                        hier noch mal die baresip.service
                                        [Unit]
                                        Description=baresip
                                        After=syslog.target network.target ntpdate.service
                                        [Service]
                                        Type=simple
                                        User=pi
                                        Group=pi
                                        ExecStart=/usr/local/bin/baresip -f /home/pi/.baresip
                                        [Install]
                                        WantedBy=multi-user.target
                                        ExecStart=/usr/local/bin/baresip /home/pi/.baresip
                                        • A AingTii
                                          @wal
                                          [Unit]
                                          Description=baresip
                                          [Service]
                                          Type=simple
                                          User=pi
                                          Group=pi
                                          [Install]
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          #482
                                          @aingtii ,
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: doorio2sip@192.168.122.2: selected for request
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: ua: using best effort AF: af=AF_INET
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: call: connecting to 'sip:**610@192.168.122.2'..
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: call: SIP Progress: 100 Trying (/)
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: call: SIP Progress: 183 Session Progress (application/sdp)
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: doorio2sip@192.168.122.2: Call in-progress: sip:**610@192.168.122.2
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: stream: update 'audio'
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: audio: Set audio decoder: PCMU 8000Hz 1ch
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: audio: Set audio encoder: PCMU 8000Hz 1ch
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: audio tx pipeline:       (src) ---> PCMU#012audio rx pipeline:      (play) <--- PCMU
                                          Apr 13 15:03:07 raspberrypi baresip[11459]: stream: incoming rtp for 'audio' established, receiving from 192.168.122.2:7078
                                          Apr 13 15:03:37 raspberrypi baresip[11459]: call: terminate call '7920ff0b496abf86' with sip:**610@192.168.122.2
                                          so sieht die message bei mir aus.
                                          Liegt baresip überhaupt unter /usr/local/bin ?
                                          Wird baresip über apt installiert liegt es unter /usr/bin über Github unter /usr/local/bin.
                                          Walter
                                          DoorIO-Adapter
