  4. [ESPHome] Beta release
    6.8k
591 Beiträge 48 Kommentatoren 234.1k Aufrufe 39 Beobachtet
  • DutchmanD Dutchman
    @johannes-bauerstatter sagte in [ESPHome] Beta release:
    @dutchman oh Mann. Vielen Dank. Mal schauen ob es jetzt stabiler läuft
    Bitte Rückmeldung ☺️
    e-s
    #92
    @dutchman
    Habe auch mal getestet, dabei sind auch sehr viele Abbrüche zu sehen, 2 verschiedene errrors:
    esphome.0	2021-03-16 07:35:03.211	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
    esphome.0	2021-03-16 07:35:03.205	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:35:03.204	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:35:03.158	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:35:03.138	info	(14077) ESPHome Device info received for test
    esphome.0	2021-03-16 07:35:03.121	info	(14077) ESPHome client 192.168.2.117 connected
    esphome.0	2021-03-16 07:34:27.024	warn	(14077) ESPHome client 192.168.2.117 disconnected
    esphome.0	2021-03-16 07:34:27.024	error	(14077) ESPHome client 192.168.2.117 Error: read ECONNRESET
    esphome.0	2021-03-16 07:28:01.808	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
    esphome.0	2021-03-16 07:28:01.805	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:28:01.804	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:28:01.754	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:28:01.736	info	(14077) ESPHome Device info received for test
    esphome.0	2021-03-16 07:28:01.730	info	(14077) ESPHome client 192.168.2.117 connected
    esphome.0	2021-03-16 07:27:31.381	error	(14077) ESPHome client 192.168.2.117 Error: connect EISCONN 192.168.2.117:6053 - Local (192.168.2.222:57128)
    esphome.0	2021-03-16 07:27:01.379	warn	(14077) ESPHome client 192.168.2.117 disconnected
    esphome.0	2021-03-16 07:26:02.518	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
    esphome.0	2021-03-16 07:26:02.517	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:26:02.516	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:26:01.464	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:26:01.430	info	(14077) ESPHome Device info received for test
    esphome.0	2021-03-16 07:26:01.412	info	(14077) ESPHome client 192.168.2.117 connected
    esphome.0	2021-03-16 07:25:30.165	warn	(14077) ESPHome client 192.168.2.117 disconnected
    esphome.0	2021-03-16 07:20:53.467	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
    esphome.0	2021-03-16 07:20:53.449	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:20:53.442	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:20:53.441	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:20:53.389	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:20:53.358	info	(14077) ESPHome Device info received for test
    esphome.0	2021-03-16 07:20:52.697	info	(14077) ESPHome client 192.168.2.117 connected
    esphome.0	2021-03-16 07:20:21.735	error	(14077) ESPHome client 192.168.2.117 Error: read ECONNRESET
    esphome.0	2021-03-16 07:20:18.734	error	(14077) ESPHome client 192.168.2.117 Error: timeout
    esphome.0	2021-03-16 07:19:43.731	warn	(14077) ESPHome client 192.168.2.117 disconnected
    esphome.0	2021-03-16 07:17:28.950	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
    esphome.0	2021-03-16 07:17:28.900	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:17:28.898	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:17:28.897	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:17:28.850	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:17:28.816	info	(14077) ESPHome Device info received for test
    esphome.0	2021-03-16 07:17:28.798	info	(14077) ESPHome client 192.168.2.117 connected
    esphome.0	2021-03-16 07:16:43.311	error	(14077) ESPHome client 192.168.2.117 Error: read ECONNRESET
    esphome.0	2021-03-16 07:16:38.016	error	(14077) ESPHome client 192.168.2.117 Error: timeout
    esphome.0	2021-03-16 07:16:03.013	warn	(14077) ESPHome client 192.168.2.117 disconnected
    esphome.0	2021-03-16 07:12:47.395	info	(14077) ESPHome client test on ip 192.168.2.117 initialized
    esphome.0	2021-03-16 07:12:47.391	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:12:47.389	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:12:47.388	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:12:47.345	info	(14077) Sensor found at test on ip 192.168.2.117
    esphome.0	2021-03-16 07:12:47.327	info	(14077) ESPHome Device info received for test
    esphome.0	2021-03-16 07:12:47.320	info	(14077) ESPHome client 192.168.2.117 connected
    • E e-s
      @dutchman
      DutchmanD Offline
      DutchmanD Offline
      Dutchman
      #93
      @e-s sagte in [ESPHome] Beta release:
      @dutchman
      hmm dein ESP verabschiedet sich alle 6 Minuten, welche adapter version hast du drauf?
      Und könntest du die YAML bitte posten ich vermute overload der Sensor abfragen auf dem ESP
      E 1 Antwort Letzte Antwort
        @dutchman
        e-s
        #94
        @dutchman
        Per git aus dem ersten Post gestern Abend installiert.
        An die yaml komme ich erst heute Abend.
        • E e-s
          @dutchman
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          #95
          @dutchman
          Check Dan warten wir darauf, trotzdem bitte welche Version ?
            @dutchman
            e-s
            #96
            @dutchman
            Version 0.1.4-3
            • E e-s
              @dutchman
              Version 0.1.4-3
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #97
              @dutchman
              Version 0.1.4-3
              Ok dan müssen wir uns die jammer anschauen, hast du 5ghz actief in deinem wlan ?
                Johannes BauerstatterJ Offline
                #98
                @dutchman läuft jetzt einwandfrei. Vielen Dank.
                  @dutchman
                  Version 0.1.4-3
                  e-s
                  #99
                  @dutchman
                  Habe 1x 5GHz WLAN und 1x 2,4GHz über Fritzbox Mash(7490 und 3x 1750 Repeater)
                  Zusätzlich ein einzelnes 2,4GHz WLAN mittig im Haus welches nur für meine Smarthome Geräte ist, bei allen Geräten ist das Fritz 2,4 Mash als backup mit drin.
                  Seit dem ich das so habe, habe ich mit shelly und tasmota keine WLAN Probleme.
                  Hatte in der YAML aber nur das Smarthome WLAN drin, die Fehler kamen nicht rythmisch, sondern immer mal wieder, manchmal auch erst nach 30min,
                  Habe jetzt auch hier beide eingetragen und lass es laufen. Melde mich wieder.
                  Aber trotzdem sollte man die errors lieber durch warns abfangen wenn neu verbunden werden muss, sieht das Optisch nicht besser aus?
                  • E e-s
                    @dutchman
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #100
                    jup stimm thanks, werde ich aender
                    • Johannes BauerstatterJ Johannes Bauerstatter
                      DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      #101
                      freut mich :)
                      • FredFF Online
                        FredFF Online
                        FredF
                        Most Active Forum Testing
                        #102
                        @Dutchman
                        Habe gerade den Namen einiger Sensoren geändert und dann den ESP geflasht. Den neuen Namen bekommt der Adapter zwar mit und behält aber schön die alten Datenpunkte...
                        Dew Point alt, Erdgeschoss Taupunkt neu
                        • FredFF FredF
                          @Dutchman
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          schrieb am zuletzt editiert von Dutchman
                          #103
                          @fredf sagte in [ESPHome] Beta release:
                          @Dutchman
                          Der Adapter löscht keine states, könnte man einbauen wen gewünscht habe dafür auch Code von anderen Adaptern
                          Wen gewollt bitte GIT issue Dan kan ich es Abarbeiten.
                          Vorschlag währe alle states löschen wen nicht mehr in der Device Angeboten
                          Edit: danke fürs issue erstellen !
                            @Dutchman
                            e-s
                            #104
                            @dutchman
                            der Grund warum ich überhaupt mit esphome angefangen habe ist, das ich 10 servos brauche.
                            Habe einen pca9685 angeschlossen, der wird soweit auch erkannt, aber jetzt ist ende bei mir:
                            pca9685 und servo habe ich in meiner yaml aktiviert, nur muss der Rest jetzt im Adapter geschehen.
                            Hast du demnächst Zeit das zu implementieren, oder kann ich dich irgendwie unterstützen?
                            Theoretisch ist das auch alles pwm, also auch für LEDs dimmen usw zu gebrauchen.
                            Das habe ich jetzt in der yaml´hinzugefügt:
                            api:
                              services:
                                - service: control_servo
                                  variables:
                                    level: float
                                  then:
                                    - servo.write:
                                        level: !lambda 'return level / 100.0;'
                            i2c:
                               - id: bus_a
                                 sda: 13
                                 scl: 12
                                 scan: True
                            pca9685:
                              frequency: 500
                              i2c_id: bus_a
                              address: 0x40
                            output:
                              - platform: pca9685
                                pca9685_id: 'pca9685_1'
                                channel: 0
                            servo:
                              - id: my_servo
                                output: pca9685_output1
                            • E e-s
                              @dutchman
                              api:
                                services:
                                    variables:
                                      level: float
                                    then:
                                      - servo.write:
                              i2c:
                                 - id: bus_a
                                   sda: 13
                                   scl: 12
                                   scan: True
                              pca9685:
                                frequency: 500
                                i2c_id: bus_a
                                address: 0x40
                              output:
                                - platform: pca9685
                                  channel: 0
                              servo:
                                - id: my_servo
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              #105
                              post mal bitte dein log, da solle genau die info drin stehen die ich brauche :)
                                e-s
                                schrieb am zuletzt editiert von e-s
                                #106
                                @dutchman
                                Esphome log oder log im iobroker?
                                edit:
                                INFO Reading configuration config/test.yaml...
                                INFO Starting log output from test.local using esphome API
                                INFO Connecting to test.local:6053 (192.168.2.117)
                                INFO Successfully connected to test.local
                                [22:00:02][I][app:105]: ESPHome version 1.16.2 compiled on Mar 17 2021, 21:16:36
                                [22:00:02][C][wifi:443]: WiFi:
                                [22:00:02][C][wifi:303]:   SSID:
                                [redacted]
                                [22:00:02][C][wifi:304]:   IP Address: 192.168.2.117
                                [22:00:02][C][wifi:306]:   BSSID:
                                [redacted]
                                [22:00:02][C][wifi:307]:   Hostname: 'test'
                                [22:00:02][C][wifi:311]:   Signal strength: -40 dB ▂▄▆█
                                [22:00:02][C][wifi:315]:   Channel: 11
                                [22:00:02][C][wifi:316]:   Subnet: 255.255.255.0
                                [22:00:02][C][wifi:317]:   Gateway: 192.168.2.1
                                [22:00:02][C][wifi:318]:   DNS1: 192.168.2.1
                                [22:00:02][C][wifi:319]:   DNS2: 0.0.0.0
                                [22:00:02][C][i2c:028]: I2C Bus:
                                [22:00:02][C][i2c:029]:   SDA Pin: GPIO13
                                [22:00:02][C][i2c:030]:   SCL Pin: GPIO12
                                [22:00:02][C][i2c:031]:   Frequency: 50000 Hz
                                [22:00:02][I][i2c:033]: Scanning i2c bus for active devices...
                                [22:00:03][I][i2c:040]: Found i2c device at address 0x40
                                [22:00:03][I][i2c:040]: Found i2c device at address 0x76
                                [22:00:03][C][pca9685:078]: PCA9685:
                                [22:00:03][C][pca9685:079]:   Mode: 0x0C
                                [22:00:03][C][pca9685:080]:   Frequency: 500 Hz
                                [22:00:03][C][output.switch:009]: Output Switch 'Relais 1'
                                [22:00:03][C][output.switch:009]: Output Switch 'Relais 2'
                                [22:00:03][C][gpio.output:010]: GPIO Binary Output:
                                [22:00:03][C][gpio.output:011]:   Pin: GPIO26 (Mode: OUTPUT)
                                [22:00:03][C][gpio.output:012]:   Inverted: YES
                                [22:00:03][C][gpio.output:011]:   Pin: GPIO27 (Mode: OUTPUT)
                                [22:00:03][C][logger:185]: Logger:
                                [22:00:03][C][logger:186]:   Level: DEBUG
                                [22:00:03][C][logger:187]:   Log Baud Rate: 115200
                                [22:00:03][C][logger:188]:   Hardware UART: UART0
                                [22:00:03][C][bme280.sensor:142]: BME280:
                                [22:00:03][C][bme280.sensor:143]:   Address: 0x76
                                [22:00:03][C][bme280.sensor:155]:   IIR Filter: OFF
                                [22:00:03][C][bme280.sensor:156]:   Update Interval: 60.0s
                                [22:00:03][C][bme280.sensor:158]:   Temperature 'BME280 Temperature'
                                [22:00:03][C][bme280.sensor:158]:     Unit of Measurement: '°C'
                                [22:00:03][C][bme280.sensor:158]:     Accuracy Decimals: 1
                                [22:00:03][C][bme280.sensor:158]:     Icon: 'mdi:thermometer'
                                [22:00:03][C][bme280.sensor:159]:     Oversampling: 16x
                                [22:00:03][C][bme280.sensor:160]:   Pressure 'BME280 Pressure'
                                [22:00:03][C][bme280.sensor:160]:     Unit of Measurement: 'hPa'
                                [22:00:03][C][bme280.sensor:160]:     Accuracy Decimals: 1
                                [22:00:03][C][bme280.sensor:160]:     Icon: 'mdi:gauge'
                                [22:00:03][C][bme280.sensor:161]:     Oversampling: 16x
                                [22:00:03][C][bme280.sensor:162]:   Humidity 'BME280 Humidity'
                                [22:00:03][C][bme280.sensor:162]:     Unit of Measurement: '%'
                                [22:00:03][C][bme280.sensor:162]:     Accuracy Decimals: 1
                                [22:00:03][C][bme280.sensor:162]:     Icon: 'mdi:water-percent'
                                [22:00:03][C][bme280.sensor:163]:     Oversampling: 16x
                                [22:00:03][C][servo:012]: Servo:
                                [22:00:03][C][servo:013]:   Idle Level: 7.5%
                                [22:00:03][C][servo:014]:   Min Level: 3.0%
                                [22:00:03][C][servo:015]:   Max Level: 12.0%
                                [22:00:03][C][servo:016]:   auto detach time: 0 ms
                                [22:00:03][C][servo:017]:   run duration: 0 ms
                                [22:00:03][C][dallas.sensor:072]: DallasComponent:
                                [22:00:03][C][dallas.sensor:073]:   Pin: GPIO14 (Mode: INPUT)
                                [22:00:03][C][dallas.sensor:074]:   Update Interval: 60.0s
                                [22:00:03][D][dallas.sensor:079]:   Found sensors:
                                [22:00:03][D][dallas.sensor:082]:     0xCB00000C18274928
                                [22:00:03][C][dallas.sensor:087]:   Device 'Living Room Temperature'
                                [22:00:03][C][dallas.sensor:087]:     Unit of Measurement: '°C'
                                [22:00:03][C][dallas.sensor:087]:     Accuracy Decimals: 1
                                [22:00:03][C][dallas.sensor:087]:     Icon: 'mdi:thermometer'
                                [22:00:03][C][dallas.sensor:095]:     Address: 0xCB00000C18274928
                                [22:00:03][C][dallas.sensor:096]:     Resolution: 12
                                [22:00:03][C][captive_portal:169]: Captive Portal:
                                [22:00:03][C][web_server:132]: Web Server:
                                [22:00:03][C][web_server:133]:   Address: test.local:80
                                [22:00:03][C][ota:029]: Over-The-Air Updates:
                                [22:00:03][C][ota:030]:   Address: test.local:3232
                                [22:00:03][C][ota:032]:   Using Password.
                                [22:00:03][C][api:095]: API Server:
                                [22:00:03][C][api:096]:   Address: test.local:6053
                                [22:00:05][D][dallas.sensor:153]: 'Living Room Temperature': Got Temperature=21.9°C
                                [22:00:05][D][sensor:092]: 'Living Room Temperature': Sending state 21.87500 °C with 1 decimals of accuracy
                                [22:00:23][D][bme280.sensor:197]: Got temperature=22.6°C pressure=1022.4hPa humidity=40.2%
                                [22:00:23][D][sensor:092]: 'BME280 Temperature': Sending state 22.61000 °C with 1 decimals of accuracy
                                [22:00:23][D][sensor:092]: 'BME280 Pressure': Sending state 1022.39722 hPa with 1 decimals of accuracy
                                [22:00:23][D][sensor:092]: 'BME280 Humidity': Sending state 40.19141 % with 1 decimals of accuracy
                                • E e-s
                                  @dutchman
                                  edit:
                                  [redacted]
                                  [redacted]
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #107
                                  iobroker :) da sollte stehen :
                                  DeviceType .... not yet supported
                                  Please submit git issue with all information from next line
                                  DeviceType ... State-Keys ... | [entityStateConfig] ...
                                    e-s
                                    #108
                                    @dutchman
                                    hmmm, nichts zu finden. auch im debug nichts.
                                    wenn man hier schaut, muss irgendwas im hass.io eingestellt werden was sonst nicht da steht.
                                    Vielleicht muss ich auch die optionalen Sachen mal aktivieren, aber keine Ahnung welche.
                                    • E e-s
                                      @dutchman
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #109
                                      @dutchman
                                      hmmm kannste mir mal nen kompletten debug schicken vom hinzufügen der device bzw Adapter start ?
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        #110
                                        hier
                                        ah habe es mir mal genauer angeschaut, da. musst du im ESPHome bissl mehr konfigurieren :
                                        # Home Assistant configuration
                                        input_number:
                                          servo_control:
                                            initial: 0
                                            min: -100
                                            max: 100
                                            step: 1
                                            mode: slider
                                        automation:
                                          - alias: Write Servo Value to ESP
                                            trigger:
                                              platform: state
                                              entity_id: input_number.servo_control
                                            action:
                                              # Replace livingroom with the name you gave the ESP
                                              - service: esphome.livingroom_control_servo
                                                data_template:
                                                  level: '{{ trigger.to_state.state | int }}'
                                        # ESPHome configuration
                                        api:
                                          services:
                                              variables:
                                                level: float
                                              then:
                                                - servo.write:
                                        servo:
                                          - platform: ...
                                            #  servo config
                                        der input Service sollte dan nen state erstellen zum steuern, die automation reagiert darauf und steuert den servo
                                          hier
                                          input_number:
                                            servo_control:
                                              initial: 0
                                              min: -100
                                              max: 100
                                              step: 1
                                              mode: slider
                                          automation:
                                              trigger:
                                                platform: state
                                              action:
                                                  data_template:
                                          api:
                                            services:
                                                variables:
                                                  level: float
                                                then:
                                                  - servo.write:
                                          servo:
                                            - platform: ...
                                              #  servo config
                                          e-s
                                          #111
                                          @dutchman
                                          Dachte das was da unter home Assistent steht gehört nicht in die yaml sondern muss irgendwie von dir verarbeitet werden, sehe ich das richtig?
