  5. Offene Fenster mit Alexa in Zeitabständen melden
    apollon77A
blockly
169 Beiträge 12 Kommentatoren 30.1k Aufrufe 14 Beobachtet
  • sigi234S sigi234
    @dslraser sagte in Offene Fenster mit Alexa in Zeitabständen melden:
    @biker1602 @Slowman
    Es wäre auch schön zu erfahren ob das Blockly bei Euch so wie gewünscht funktioniert ?
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) at processImmediate (internal/timers.js:461:21)
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) at Immediate._onImmediate (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:5555:41)
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) at Object.stateChange (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\main.js:487:29)
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) at Object.callback (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1070:38)
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) at Object.<anonymous> (script.js.Alexa.Fenster_DSLRASER:240:9)
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) at setStateDelayed (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1466:25)
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) at Object.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1422:20)
    javascript.0	2021-03-08 10:17:34.238	warn	(13680) State "0_userdata.0.Fenster_Tuerwarnungen.Badfenster.Alexa.07_Temperaturschwelle_kalt_erreicht" not found
    javascript.0	2021-03-08 10:17:34.237	warn	(13680) at processImmediate (internal/timers.js:461:21)
    javascript.0	2021-03-08 10:17:34.237	warn	(13680) at Immediate._onImmediate (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:5555:41)
    javascript.0	2021-03-08 10:17:34.237	warn	(13680) at Object.stateChange (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\main.js:487:29)
    javascript.0	2021-03-08 10:17:34.237	warn	(13680) at Object.callback (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1070:38)
    javascript.0	2021-03-08 10:17:34.237	warn	(13680) at Object.<anonymous> (script.js.Alexa.Fenster_DSLRASER:237:9)
    javascript.0	2021-03-08 10:17:34.237	warn	(13680) at setStateDelayed (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1466:25)
    javascript.0	2021-03-08 10:17:34.237	warn	(13680) at Object.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1422:20)
    javascript.0	2021-03-08 10:17:34.236	warn	(13680) State "0_userdata.0.Fenster_Tuerwarnungen.Badfenster.Alexa.06_Temperaturschwelle_warm_erreicht" not found
    DP werden anscheinend nicht angelegt. JS Version 5.0.12
    dslraserD
    dslraserD
    dslraser
    #78
    @sigi234
    Das gemacht ?
    Alle alten Datenpunkte löschen und dann ein neues leeres Blockly erstellen, dann importieren/einstellen und starten.
    • sigi234S sigi234
      @biker1602 @Slowman
      B
      B
      biker1602
      #79
      @sigi234 Es geht auch mit der Version 5.0.12
      Wichtig ist Blockly stoppen Datenpunkte unter Objekte löschen dann das Blockly löschen und neu anlegen. So hat es bei mir funktioniert. Browserseite aktualisieren
      • dslraserD dslraser
        @sigi234
        Das gemacht ?
        sigi234S
        sigi234S
        #80
        @sigi234
        Das gemacht ?
        Ja
        • sigi234S sigi234
          @sigi234
          Das gemacht ?
          Ja
          dslraserD
          dslraserD
          dslraser
          #81
          @sigi234 sagte in Offene Fenster mit Alexa in Zeitabständen melden:
          Ja
          hm...ich habe noch keine Javascript Version 5.x.x
          Aber bei den anderen Usern scheint es ja damit ja trotzdem zu gehen...
            Ja
            sigi234S
            sigi234S
            #82
            Ja
            Ok, wenn ich iot auf false setze geht es.
            • sigi234S sigi234
              Ja
              dslraserD
              dslraserD
              dslraser
              #83
              Danke für die Info, das schaue ich mir dann nochmal an.
              SlowmanS 1 Antwort Letzte Antwort
                SlowmanS
                SlowmanS
                Slowman
                #84
                @dslraser
                Letzte Version deines Skripts funktioniert sehr gut mit Alexa. IoT nicht getestet. Die Telegrambenachrichtigung bekomme ich erst nach der letzten Wiederholung, richtig?
                Wie erstelle ich dies mit mehreren Echos?
                • SlowmanS Slowman
                  @dslraser
                  dslraserD
                  dslraserD
                  dslraser
                  #85
                  @slowman sagte in Offene Fenster mit Alexa in Zeitabständen melden:
                  @dslraser
                  Telegram und Alexa sind zwei verschiedene Blockly.
                  Mehrere ECHOS habe ich nicht probiert. Eventuell in der Alexa App eine Gruppe anlegen und die dann über speak verbinden.
                  Wenn eine Gruppe in der Amazon App angelegt wurde, dann nicht vergessen den Alexa2 Adapter neu zu starten, ich weiß nicht ob die sonst gefunden wird.
                    @dslraser
                    B
                    B
                    biker1602
                    schrieb am zuletzt editiert von biker1602
                    #86
                    @dslraser Hallo Sag mal bitte bei dem Script mit der Alexa Ansage wollte ich einen kurzen Satz ändern.
                    Bitte vergiss nicht das ... Fenster zu schließen statt "Bitte Schließe das .... Fenster".
                    Ich habe das ganze Script entfaltet aber die Stelle wo ich das ändern kann habe ich nicht gefunden.
                    Wo hast du das versteckt??
                    • B biker1602
                      dslraserD
                      dslraserD
                      dslraser
                      #87
                      @biker1602 sagte in Offene Fenster mit Alexa in Zeitabständen melden:
                      dann hast Du nicht richtig nachgesehen...😀
                      Mach die Variablen auf. (sollte an zwei Stellen sein.)
                        B
                        B
                        biker1602
                        #88
                        @dslraser Danke Super habe ich gefunden. Sag mal, wenn du dieses mit den Freifeldern für die Texterstellung machst, hat das etwas mit der Betonung bei der Aussprache von Alexa zu tun?
                        • B biker1602
                          dslraserD
                          dslraserD
                          dslraser
                          #89
                          ja, teilweise schon. (und in der Telegram Variante soll es ja auch vernünftig aussehen)
                          Bei einem ECHO mit Display steht auch der Text auf dem Display, der soll auch vernünftig aussehen. Bei Temperaturwerten sind Leerzeichen ebenfalls wichtig, damit die Aussprache passt (auch bei Minuswerten), ebenso bei Satzenden.
                          • sigi234S sigi234
                            Ja
                            dslraserD
                            dslraserD
                            dslraser
                            #90
                            Probiere nochmal, wenn Du Lust hast. Ich habe die Datenpunkterstellung für iot geändert.
                            Fenster_Tuerwarnungen_Alexa.zip
                            sigi234S B 2 Antworten Letzte Antwort
                              sigi234S
                              sigi234S
                              #91
                              Läuft mit iot.
                                B
                                B
                                biker1602
                                #92
                                @dslraser said in Offene Fenster mit Alexa in Zeitabständen melden:
                                Ich habe es versucht und funktioniert auch das er es im iot Adapter eingetragen hat. Unter Alexa hat er dann auch neue Geräte gefunden aber was genau kann ich damit machen?
                                • B biker1602
                                  dslraserD
                                  dslraserD
                                  dslraser
                                  #93
                                  Du könntest z.B. die Fensterwarnung per Sprache an/aus schalten. (einfach eine Routine in der Alexa App einrichten und den passenden Datenpunkt dazu auswählen)
                                  • dslraserD
                                    dslraserD
                                    dslraser
                                    #94
                                    @biker1602 und @sigi234
                                    hattet Ihr das Blockly eigentlich ausporbiert ? (Der Schalter/Datenpunkt zum Ansage an/aus schalten hatte gar keine Wirkung. Die Ansage kam auch bei ausgeschalteter Option...)
                                    Hier nochmal eine Änderung...
                                      B
                                      B
                                      biker1602
                                      #95
                                      @dslraser Also ich habe es gestern ausprobiert aber nicht die Ansage zum Deaktivieren von Alexa. Das andere ging denn ich habe ja noch gefragt was ich mit den Datenpunkten unter iot Adapter machen kann
                                        B
                                        B
                                        biker1602
                                        #96
                                        @dslraser Mir ist jetzt doch noch ein Fehler aufgefallen der nicht gleich zu merken war.
                                        Wenn ich das Fenster öffne und es innerhalb von den 15 Sekunden wieder Schließe kommt keine Ansage bis auf einmal wie bei dir im Beispiel, wenn zeitlich 15 Erinnerungen rum sind, kommt der Hinweis
                                        So in etwa
                                        Ich habe dich jetzt 15 Mal erinnert und das Fenster ist immer noch offen obwohl das Fenster nur 15 Sek auf war. Ich hatte es am Sonntag gemerkt aber mir nichts dabei gedacht wer weiß was da passiert ist.
                                        Aber heute im Bürofenster war genau das Gleiche. Es war nur für 10 Sekunden geöffnet danach gleich wieder geschlossen und nach 150 Min kam dann auch diese Ansage.
                                        dslraserD sigi234S 2 Antworten Letzte Antwort
                                        • B biker1602
                                          So in etwa
                                          dslraserD
                                          dslraserD
                                          dslraser
                                          #97
                                          @biker1602
                                          muss ich mir dann nochmal ansehen...
                                          83.9k
