  4. JavaScript
  5. Node.js Script in iobroker integrieren
    6.0k
40 Beiträge 10 Kommentatoren 9.5k Aufrufe 10 Beobachtet
  • R rettroo
    @unclesam
    Danke für deine Hilfe. Habe die variablen nun in "" gesetzt. Jetzt bekomme ich folgenden Fehler:
    javascript.0	2021-01-27 13:30:19.894	error	(954) at Script.runInContext (vm.js:130:18)
    javascript.0	2021-01-27 13:30:19.894	error	(954) at script.js.Dahua:517:1
    javascript.0	2021-01-27 13:30:19.894	error	(954) at new DahuaVTO (script.js.Dahua:88:26)
    javascript.0	2021-01-27 13:30:19.894	error	(954) TypeError: DigestFetch is not a constructor
    javascript.0	2021-01-27 13:30:19.894	error	(954) ^
    javascript.0	2021-01-27 13:30:19.894	error	(954) this.digestClient = new DigestFetch(
    javascript.0	2021-01-27 13:30:19.894	error	(954) script.js.Dahua: script.js.Dahua:88
    javascript.0	2021-01-27 13:30:19.893	error	(954) at Script.runInContext (vm.js:130:18)
    javascript.0	2021-01-27 13:30:19.893	error	(954) at script.js.Dahua:5:13
    javascript.0	2021-01-27 13:30:19.893	error	(954) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:389:36)
    javascript.0	2021-01-27 13:30:19.892	error	(954) at require (internal/modules/cjs/helpers.js:74:18)
    javascript.0	2021-01-27 13:30:19.892	error	(954) at Module.require (internal/modules/cjs/loader.js:903:19)
    javascript.0	2021-01-27 13:30:19.892	error	(954) script.js.Dahua: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../md5'
    javascript.0	2021-01-27 13:30:19.891	error	(954) at Script.runInContext (vm.js:130:18)
    javascript.0	2021-01-27 13:30:19.891	error	(954) at script.js.Dahua:1:21
    javascript.0	2021-01-27 13:30:19.891	error	(954) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:389:36)
    javascript.0	2021-01-27 13:30:19.891	error	(954) at require (internal/modules/cjs/helpers.js:74:18)
    javascript.0	2021-01-27 13:30:19.891	error	(954) at Module.require (internal/modules/cjs/loader.js:903:19)
    javascript.0	2021-01-27 13:30:19.891	error	(954) script.js.Dahua: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../digest-fetch'
    javascript.0	2021-01-27 13:30:19.883	info	(954) Start javascript script.js.Dahua
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @rettroo Hast du denn digest-fetch bei den benötigten Node Modulen im JavaScript Adapter angegeben?
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    R 1 Antwort Letzte Antwort
    • UncleSamU UncleSam
      rettroo
      @unclesam
      ist das so korrekt?
      Ich komme der Sache näher, zumindest war MQTT schon kurz verbunden. nun geht aber die javascript Instanz auf Rot kurz nach dem Start des Scriptes.
      host.debian	2021-01-27 14:43:01.777	info	Restart adapter system.adapter.javascript.0 because enabled
      host.debian	2021-01-27 14:43:01.777	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:214:10)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:273:9)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at addChunk (_stream_readable.js:298:12)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at DahuaVTO.receive (script.js.Dahua:288:12)
      host.debian	2021-01-27 14:43:01.776	error	Caught by controller[0]: at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
      host.debian	2021-01-27 14:43:01.775	error	Caught by controller[0]: TypeError: console.info is not a function
      mqtt.0	2021-01-27 14:43:01.772	info	(9477) Client [mqttjs_d9328b8b] connection closed: closed
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at Socket.Readable.push (_stream_readable.js:214:10)
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at readableAddChunk (_stream_readable.js:273:9)
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at addChunk (_stream_readable.js:298:12)
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at Socket.emit (events.js:314:20)
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at DahuaVTO.receive (script.js.Dahua:288:12)
      javascript.0	2021-01-27 14:43:01.751	error	(9509) at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
      javascript.0	2021-01-27 14:43:01.750	error	(9509) script.js.Dahua: TypeError: console.info is not a function
      mqtt.0	2021-01-27 14:43:01.717	info	(9477) Client [mqttjs_d9328b8b] connected with secret 1611754981716_9127
      javascript.0	2021-01-27 14:43:01.610	info	(9509) script.js.Dahua: registered 0 subscriptions and 0 schedules
      javascript.0	2021-01-27 14:43:01.554	info	(9509) Start javascript script.js.Dahua
      javascript.0	2021-01-27 14:43:01.554	info	(9509) script.js.Test: registered 1 subscription and 0 schedules
      javascript.0	2021-01-27 14:43:01.552	info	(9509) Start javascript script.js.Test
      javascript.0	2021-01-27 14:43:01.551	info	(9509) script.js.Feueralarm: registered 1 subscription and 0 schedules
      javascript.0	2021-01-27 14:43:01.550	info	(9509) Start javascript script.js.Feueralarm
      javascript.0	2021-01-27 14:43:01.548	info	(9509) script.js.Magic: registered 5 subscriptions and 0 schedules
      javascript.0	2021-01-27 14:43:01.547	info	(9509) Start javascript script.js.Magic
      javascript.0	2021-01-27 14:43:01.546	info	(9509) script.js.Licht_WZ: registered 3 subscriptions and 0 schedules
      javascript.0	2021-01-27 14:43:01.540	info	(9509) Start javascript script.js.Licht_WZ
      javascript.0	2021-01-27 14:43:01.540	info	(9509) script.js.BWM: registered 1 subscription and 0 schedules
      javascript.0	2021-01-27 14:43:01.523	info	(9509) Start javascript script.js.BWM
      javascript.0	2021-01-27 14:43:01.419	info	(9509) received all states
      javascript.0	2021-01-27 14:43:01.395	info	(9509) received all objects
      javascript.0	2021-01-27 14:43:00.835	info	(9509) requesting all objects
      javascript.0	2021-01-27 14:43:00.834	info	(9509) requesting all states
      javascript.0	2021-01-27 14:43:00.782	info	(9509) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
      host.debian	2021-01-27 14:42:59.455	info	instance system.adapter.javascript.0 started with pid 9509
      host.debian	2021-01-27 14:42:29.445	info	Restart adapter system.adapter.javascript.0 because enabled
      host.debian	2021-01-27 14:42:29.445	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.debian	2021-01-27 14:42:29.445	error	Caught by controller[0]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
      host.debian	2021-01-27 14:42:29.445	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:214:10)
      host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:273:9)
      host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at addChunk (_stream_readable.js:298:12)
      host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
      host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
      host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at DahuaVTO.receive (script.js.Dahua:288:12)
      host.debian	2021-01-27 14:42:29.444	error	Caught by controller[0]: at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
      host.debian	2021-01-27 14:42:29.442	error	Caught by controller[0]: TypeError: console.info is not a function
      mqtt.0	2021-01-27 14:42:29.442	info	(9477) Client [mqttjs_d19a512b] connection closed: Error: read ECONNRESET
      mqtt.0	2021-01-27 14:42:29.378	info	(9477) Client [mqttjs_d19a512b] connected with secret 1611754949376_714
      javascript.0	2021-01-27 14:42:29.410	error	(9494) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
      javascript.0	2021-01-27 14:42:29.410	error	(9494) at Socket.Readable.push (_stream_readable.js:214:10)
      javascript.0	2021-01-27 14:42:29.410	error	(9494) at readableAddChunk (_stream_readable.js:273:9)
      javascript.0	2021-01-27 14:42:29.410	error	(9494) at addChunk (_stream_readable.js:298:12)
      javascript.0	2021-01-27 14:42:29.409	error	(9494) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-01-27 14:42:29.409	error	(9494) at Socket.emit (events.js:314:20)
      javascript.0	2021-01-27 14:42:29.409	error	(9494) at DahuaVTO.receive (script.js.Dahua:288:12)
      javascript.0	2021-01-27 14:42:29.409	error	(9494) at DahuaVTO.handleSecondLoginPayload (script.js.Dahua:358:15)
      javascript.0	2021-01-27 14:42:29.407	error	(9494) script.js.Dahua: TypeError: console.info is not a function
      javascript.0	2021-01-27 14:42:29.270	info	(9494) script.js.Dahua: registered 0 subscriptions and 0 schedules
      javascript.0	2021-01-27 14:42:29.206	info	(9494) Start javascript script.js.Dahua
      UncleSamU 1 Antwort Letzte Antwort
      • R rettroo
        @unclesam
        ist das so korrekt?
        UncleSamU Offline
        UncleSamU Offline
        UncleSam
        @rettroo Jawohl, alles richtig. Das einzige was du wohl noch anpassen musst: alles was console.<irgendwas>()ist musst du umschreiben nach log(). Denn Konsolen-Logging gibt es keines im JavaScript Adapter.
          rettroo
          schrieb am zuletzt editiert von rettroo
          @unclesam
          Danke, das Script läuft!
          • R Offline
            rettroo
            Ich benötige hier bitte noch Unterstützung. Ich bekomme in MQTT folgenden String
            {"Data":{"CardNo":"b01xx636","CardType":null,"LocaleTime":"2021-01-28 15:47:08","Method":1,"Name":"OpenDoor","Password":"","ReaderID":"1","RecNo":96,"SnapURL":"","Status":1,"Type":"Entry","UTC":1611848828,"UserID":"2"},"deviceType":"VTO4202F","serialNumber":"6K0xxxxxxx20A0"}
            Ich benötige in dem Fall nur die User ID in 0_userdata.0.DahuaUserID
            • R rettroo
              rettroo
              @UncleSam
              Ich habe mir nun was zusammengebastelt.
              Der Datenpunkt "serialNumber" wird geschrieben, der "UserID" nicht. Wie gebe ich den richtig an, da er ja nochmal in "Data" verschachtelt ist.
              on({id: "mqtt.0.DahuaVTO.AccessControl.Event", change: "any"}, function (obj) { ParseCommand(obj); });
              function ParseCommand(obj) {
                let value = obj.state.val;
                let serialNumber = "";
                let UserID = "";
                try {
                  obj = JSON.parse(value);
                  serialNumber = obj.serialNumber;
                  UserID = obj.UserID;
                  setState('0_userdata.0.serialNumber', (serialNumber));
                  setState('0_userdata.0.UserID', (UserID));
                } catch (e) {
                  return;
              Sonst sauber programmiert?
              • R rettroo
                @UncleSam
                  let UserID = "";
                  try {
                  } catch (e) {
                    return;
                UncleSamU Offline
                UncleSamU Offline
                UncleSam
                @rettroo sagte in Node.js Script in iobroker integrieren:
                Einfach mit einem Punkt dazwischen: obj.Data.UserID
                • pseudorealP Offline
                  pseudorealP Offline
                  pseudoreal
                  könntest Du bitte eine Anleitung für "Dummies" erstellen? Was genau muss zu erst installiert werden? Danke
                  • pseudorealP pseudoreal
                    rettroo
                    @pseudoreal
                    Hi, kann ich machen sobald ich alles fertig habe. Die Dahua hängt zur Zeit auch noch nicht an der Tür sondern in meinem Büro ;-)
                    pseudorealP 1 Antwort Letzte Antwort
                      rettroo
                      Hi @unclesam,
                      das Script hat soweit schon ganz gut funktioniert, nun startet es aber nicht mehr und ich bekomme folgenden Fehler.
                      Was hat es mit dem MD5 auf sich?
                      host.debian	2021-03-10 14:02:45.431	info	instance system.adapter.javascript.0 started with pid 2673
                      host.debian	2021-03-10 14:02:15.418	info	Restart adapter system.adapter.javascript.0 because enabled
                      host.debian	2021-03-10 14:02:15.418	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
                      host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:214:10)
                      host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:273:9)
                      host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at addChunk (_stream_readable.js:298:12)
                      host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                      host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
                      host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.receive (script.js.DAHUA.Dahua_Script:287:12)
                      host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.handleFirstLoginPayload (script.js.DAHUA.Dahua_Script:330:27)
                      host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.genMD5Hash (script.js.DAHUA.Dahua_Script:401:24)
                      host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: TypeError: md5 is not a function
                      mqtt.0	2021-03-10 14:02:15.400	info	(1533) Client [mqttjs_09066ccf] connection closed: closed
                      javascript.0	2021-03-10 14:02:15.386	error	(2658) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.Readable.push (_stream_readable.js:214:10)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at readableAddChunk (_stream_readable.js:273:9)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at addChunk (_stream_readable.js:298:12)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.EventEmitter.emit (domain.js:483:12)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.emit (events.js:314:20)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.receive (script.js.DAHUA.Dahua_Script:286:12)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.handleFirstLoginPayload (script.js.DAHUA.Dahua_Script:329:27)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.genMD5Hash (script.js.DAHUA.Dahua_Script:400:24)
                      javascript.0	2021-03-10 14:02:15.385	error	(2658) script.js.DAHUA.Dahua_Script: TypeError: md5 is not a function
                      mqtt.0	2021-03-10 14:02:15.356	info	(1533) Client [mqttjs_09066ccf] connected with secret 1615381335356_7933
                      javascript.0	2021-03-10 14:02:15.292	info	(2658) script.js.DAHUA.Dahua_Script: registered 0 subscriptions and 0 schedules
                      javascript.0	2021-03-10 14:02:15.246	error	(2658) at Script.runInContext (vm.js:130:18)
                      javascript.0	2021-03-10 14:02:15.246	error	(2658) at script.js.DAHUA.Dahua_Script:518:3
                      javascript.0	2021-03-10 14:02:15.246	error	(2658) at script.js.DAHUA.Dahua_Script:5:13
                      javascript.0	2021-03-10 14:02:15.245	error	(2658) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:397:36)
                      javascript.0	2021-03-10 14:02:15.245	error	(2658) at require (internal/modules/cjs/helpers.js:74:18)
                      javascript.0	2021-03-10 14:02:15.245	error	(2658) at Module.require (internal/modules/cjs/loader.js:903:19)
                      javascript.0	2021-03-10 14:02:15.245	error	(2658) script.js.DAHUA.Dahua_Script: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../md5'
                      • R rettroo
                        Hi @unclesam,
                        UncleSamU Offline
                        UncleSamU Offline
                        UncleSam
                        @rettroo Hast du das md5 Modul installiert?
                        const md5 = require('md5');
                        Sollte eigentlich schief gehen, wenn du md5 nicht installiert hast, was ich etwas komisch finde. Hast du das etwa aus dem Skript gelöscht?
                        • R rettroo
                          @pseudoreal
                          pseudorealP Offline
                          pseudorealP Offline
                          pseudoreal
                          @rettroo
                          also ich habe jetzt den MQTT server installiert. Das Script in Javascript erstellt und alle Instanzen gestartet. Ich bekomme den Fehler:
                          (20360) FetchError: request to https://192.168.178.10:443/cgi-bin/magicBox.cgi?action=getSystemInfo failed, reason: unable to verify the first certificate
                          Unter Instanzen ist jedoch MQTT gelb und auch im Script sebst sind mir einige Zeilen als Fehler unterstrichen - zB const DigestFetch = require('digest-fetch');
                          md5 und digest-fetch sind aber in der JavaScript instanz aktiviert.
                          UncleSamU R 2 Antworten Letzte Antwort
                            @rettroo
                            UncleSamU Offline
                            UncleSamU Offline
                            UncleSam
                            @pseudoreal sagte in Node.js Script in iobroker integrieren:
                            Da steht ja die Fehlermeldung. Du machst HTTPS und das Zertifikat ist ungültig. Muss es denn HTTPS sein? Wie du die Zertifikatsüberprüfung ausschaltest, kann ich dir leider auch nicht sagen (ich kenne digest-fetch nicht).
                              @rettroo
                              rettroo
                              @pseudoreal
                              wie von @UncleSam angemerkt würde ich das "s" mal weglassen also "http://
                              MQTT sollte erst grün werden wenn sich das Script mit Dahua verbindet
                              • R rettroo
                                @pseudoreal
                                pseudorealP Offline
                                pseudorealP Offline
                                pseudoreal
                                @rettroo @UncleSam
                                ok, ich habe das https weggelassen uns nun klappt die Verbindung und ich sehe auch im Script log, wenn sich jemand bewegt (VideoEvent) oder jemand klingelt (Invite).
                                Jetzt fehlt mir nur noch die Information wie ich diese in iobroker weiterverarbeite, damit mir zB eine WhatsApp geschickt wird. Habe hier schon gesucht, aber leider nichts gefunden - wahrscheinlich falsche Suchbegriffe. Habt ihr irgendwo ein gutes Tutorial, wie man nun mit den Werten in MQTT weiterarbeitet?
                                  @rettroo @UncleSam
                                  UncleSamU Offline
                                  UncleSamU Offline
                                  UncleSam
                                  @pseudoreal Du füllst Datenpunkte ab und schreibst Skripte, Blocklys oder machst Rules. Das hat dann nichts mehr mit deinem Skript zu tun sondern ist ganz gewöhnliches Skripting in ioBroker.
                                    pseudorealP Offline
                                    pseudorealP Offline
                                    pseudoreal
                                    @unclesam @rettroo
                                    Danke - das stimmt. Ich habe das via blockly hinbekommen. Habe aber noch folgendes Problem, wie kann ich aus MQTT einen speziellen String aus dem Wert in den Objekten rauslesen und in Blockly verarbeiten?
                                      @unclesam @rettroo
                                      UncleSamU Offline
                                      UncleSamU Offline
                                      UncleSam
                                      @pseudoreal was meinst du damit? Kannst du mal in einem Screenshot zeigen, was du wo hast und was du daraus haben willst?
                                        pseudorealP Offline
                                        pseudorealP Offline
                                        pseudoreal
                                        @unclesam
                                        im Objekt von MQTT habe ich eines der VTO, welches FingerPrintCheck heißt. Das dazugehörige Event hat unter Wert, den folgenden Eintrag:
                                        {"Data":{"FingerPrintID":6,"LocaleTime":"2021-05-03 08:17:42","UTC":1620026262},"deviceType":"VTO4202F","serialNumber":"xxxxxxxxxx"}
                                        Ich bräuchte nun den Datenpunkt FingerPrintID im Blockly, da ich gerne nur bei nicht erfolgreichen Fingerabdruckscans eine Aktion auslösen möchte. In einem anderen Thread wurde mir diese Seite empfohlen - https://www.machs-smart.de/json-blockly-einlesen-parsen-verarbeiten/
                                        Ich schau mir das mal an.
                                        UncleSamU oldi-2000O 2 Antworten Letzte Antwort
                                          @unclesam
                                          UncleSamU Offline
                                          UncleSamU Offline
                                          UncleSam
                                          @pseudoreal Genau, ich würde einfach in einem Blockly oder JavaScript das JSON parsen und dann in einen Datenpunkt abfüllen. Das sollte recht einfach sein. Mit Blockly kann ich aber leider nicht weiterhelfen, das verwende ich nie.
