  4. JavaScript
  5. Node.js Script in iobroker integrieren
    6.0k
40 Beiträge 10 Kommentatoren 9.5k Aufrufe 10 Beobachtet
  • R rettroo
    Hi @unclesam,
    das Script hat soweit schon ganz gut funktioniert, nun startet es aber nicht mehr und ich bekomme folgenden Fehler.
    Was hat es mit dem MD5 auf sich?
    host.debian	2021-03-10 14:02:45.431	info	instance system.adapter.javascript.0 started with pid 2673
    host.debian	2021-03-10 14:02:15.418	info	Restart adapter system.adapter.javascript.0 because enabled
    host.debian	2021-03-10 14:02:15.418	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
    host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:214:10)
    host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:273:9)
    host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at addChunk (_stream_readable.js:298:12)
    host.debian	2021-03-10 14:02:15.418	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
    host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
    host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.receive (script.js.DAHUA.Dahua_Script:287:12)
    host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.handleFirstLoginPayload (script.js.DAHUA.Dahua_Script:330:27)
    host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: at DahuaVTO.genMD5Hash (script.js.DAHUA.Dahua_Script:401:24)
    host.debian	2021-03-10 14:02:15.417	error	Caught by controller[0]: TypeError: md5 is not a function
    mqtt.0	2021-03-10 14:02:15.400	info	(1533) Client [mqttjs_09066ccf] connection closed: closed
    javascript.0	2021-03-10 14:02:15.386	error	(2658) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.Readable.push (_stream_readable.js:214:10)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at readableAddChunk (_stream_readable.js:273:9)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at addChunk (_stream_readable.js:298:12)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.EventEmitter.emit (domain.js:483:12)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at Socket.emit (events.js:314:20)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.receive (script.js.DAHUA.Dahua_Script:286:12)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.handleFirstLoginPayload (script.js.DAHUA.Dahua_Script:329:27)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) at DahuaVTO.genMD5Hash (script.js.DAHUA.Dahua_Script:400:24)
    javascript.0	2021-03-10 14:02:15.385	error	(2658) script.js.DAHUA.Dahua_Script: TypeError: md5 is not a function
    mqtt.0	2021-03-10 14:02:15.356	info	(1533) Client [mqttjs_09066ccf] connected with secret 1615381335356_7933
    javascript.0	2021-03-10 14:02:15.292	info	(2658) script.js.DAHUA.Dahua_Script: registered 0 subscriptions and 0 schedules
    javascript.0	2021-03-10 14:02:15.246	error	(2658) at Script.runInContext (vm.js:130:18)
    javascript.0	2021-03-10 14:02:15.246	error	(2658) at script.js.DAHUA.Dahua_Script:518:3
    javascript.0	2021-03-10 14:02:15.246	error	(2658) at script.js.DAHUA.Dahua_Script:5:13
    javascript.0	2021-03-10 14:02:15.245	error	(2658) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:397:36)
    javascript.0	2021-03-10 14:02:15.245	error	(2658) at require (internal/modules/cjs/helpers.js:74:18)
    javascript.0	2021-03-10 14:02:15.245	error	(2658) at Module.require (internal/modules/cjs/loader.js:903:19)
    javascript.0	2021-03-10 14:02:15.245	error	(2658) script.js.DAHUA.Dahua_Script: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../md5'
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @rettroo Hast du das md5 Modul installiert?
    const md5 = require('md5');
    Sollte eigentlich schief gehen, wenn du md5 nicht installiert hast, was ich etwas komisch finde. Hast du das etwa aus dem Skript gelöscht?
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • R rettroo
      @pseudoreal
      Hi, kann ich machen sobald ich alles fertig habe. Die Dahua hängt zur Zeit auch noch nicht an der Tür sondern in meinem Büro ;-)
      pseudorealP Offline
      pseudorealP Offline
      pseudoreal
      @rettroo
      also ich habe jetzt den MQTT server installiert. Das Script in Javascript erstellt und alle Instanzen gestartet. Ich bekomme den Fehler:
      (20360) FetchError: request to https://192.168.178.10:443/cgi-bin/magicBox.cgi?action=getSystemInfo failed, reason: unable to verify the first certificate
      Unter Instanzen ist jedoch MQTT gelb und auch im Script sebst sind mir einige Zeilen als Fehler unterstrichen - zB const DigestFetch = require('digest-fetch');
      md5 und digest-fetch sind aber in der JavaScript instanz aktiviert.
      UncleSamU R 2 Antworten Letzte Antwort
      • pseudorealP pseudoreal
        @rettroo
        UncleSamU Offline
        UncleSamU Offline
        UncleSam
        @pseudoreal sagte in Node.js Script in iobroker integrieren:
        Da steht ja die Fehlermeldung. Du machst HTTPS und das Zertifikat ist ungültig. Muss es denn HTTPS sein? Wie du die Zertifikatsüberprüfung ausschaltest, kann ich dir leider auch nicht sagen (ich kenne digest-fetch nicht).
          @rettroo
          rettroo
          @pseudoreal
          wie von @UncleSam angemerkt würde ich das "s" mal weglassen also "http://
          MQTT sollte erst grün werden wenn sich das Script mit Dahua verbindet
          pseudorealP 1 Antwort Letzte Antwort
          • R rettroo
            @pseudoreal
            pseudorealP Offline
            pseudorealP Offline
            pseudoreal
            @rettroo @UncleSam
            ok, ich habe das https weggelassen uns nun klappt die Verbindung und ich sehe auch im Script log, wenn sich jemand bewegt (VideoEvent) oder jemand klingelt (Invite).
            Jetzt fehlt mir nur noch die Information wie ich diese in iobroker weiterverarbeite, damit mir zB eine WhatsApp geschickt wird. Habe hier schon gesucht, aber leider nichts gefunden - wahrscheinlich falsche Suchbegriffe. Habt ihr irgendwo ein gutes Tutorial, wie man nun mit den Werten in MQTT weiterarbeitet?
            UncleSamU 1 Antwort Letzte Antwort
              @rettroo @UncleSam
              UncleSamU Offline
              UncleSamU Offline
              UncleSam
              @pseudoreal Du füllst Datenpunkte ab und schreibst Skripte, Blocklys oder machst Rules. Das hat dann nichts mehr mit deinem Skript zu tun sondern ist ganz gewöhnliches Skripting in ioBroker.
              • UncleSamU UncleSam
                pseudorealP Offline
                pseudorealP Offline
                pseudoreal
                @unclesam @rettroo
                Danke - das stimmt. Ich habe das via blockly hinbekommen. Habe aber noch folgendes Problem, wie kann ich aus MQTT einen speziellen String aus dem Wert in den Objekten rauslesen und in Blockly verarbeiten?
                  @unclesam @rettroo
                  UncleSamU Offline
                  UncleSamU Offline
                  UncleSam
                  @pseudoreal was meinst du damit? Kannst du mal in einem Screenshot zeigen, was du wo hast und was du daraus haben willst?
                    pseudorealP Offline
                    pseudorealP Offline
                    pseudoreal
                    @unclesam
                    im Objekt von MQTT habe ich eines der VTO, welches FingerPrintCheck heißt. Das dazugehörige Event hat unter Wert, den folgenden Eintrag:
                    {"Data":{"FingerPrintID":6,"LocaleTime":"2021-05-03 08:17:42","UTC":1620026262},"deviceType":"VTO4202F","serialNumber":"xxxxxxxxxx"}
                    Ich bräuchte nun den Datenpunkt FingerPrintID im Blockly, da ich gerne nur bei nicht erfolgreichen Fingerabdruckscans eine Aktion auslösen möchte. In einem anderen Thread wurde mir diese Seite empfohlen - https://www.machs-smart.de/json-blockly-einlesen-parsen-verarbeiten/
                    Ich schau mir das mal an.
                    UncleSamU oldi-2000O 2 Antworten Letzte Antwort
                      @unclesam
                      UncleSamU Offline
                      UncleSamU Offline
                      UncleSam
                      @pseudoreal Genau, ich würde einfach in einem Blockly oder JavaScript das JSON parsen und dann in einen Datenpunkt abfüllen. Das sollte recht einfach sein. Mit Blockly kann ich aber leider nicht weiterhelfen, das verwende ich nie.
                        @unclesam
                        oldi-2000O Offline
                        oldi-2000O Offline
                        oldi-2000
                        @pseudoreal Hallo ich hänge gerade genau an dem Thema Json parsen und hab leider null Ahnung davon ich habe ein Vto 4202 habe das Skript und den mqtt Adapter am laufen und bräuchte jetzt aber normale Datenpunkte z. B. für die einen Gong aber auch wenn möglich für den Türoffner usw. Hast du mir vielleicht ein Skript das funktioniert?
                        F 1 Antwort Letzte Antwort
                        • oldi-2000O oldi-2000
                          F Online
                          F Online
                          fastfoot
                          @oldi-2000 poste mal so ein json
                          oldi-2000O 1 Antwort Letzte Antwort
                          • F fastfoot
                            oldi-2000O Offline
                            oldi-2000O Offline
                            oldi-2000
                            @fastfoot
                              "Data": {
                                "LocaleTime": "2021-11-20 20:12:39",
                                "State": 9,
                                "UTC": 1637439159
                              "deviceType": "VTO4202F-P-S2",
                              "serialNumber": "7H05F88PAJ18009"
                            Das ist was Mqtt als Datenpunkt raushaut, ich benötige aber möglichst einen Datenpunkt der einfach true bei State = 1 bzw. false bei allen anderen States ist.
                            Ich hab aber leider null Ahnung vom skripten. 😧
                              @fastfoot
                                "Data": {
                                  "State": 9,
                                  "UTC": 1637439159
                              F Online
                              F Online
                              fastfoot
                              @oldi-2000 so könnte es aussehen
                              • H Offline
                                h07d0q
                                @rettroo @fastfoot
                                Würde jemand von euch eine fertige, funktionierende Lösung hier veröffentlichen?
                                Dann muss nicht jeder von neu beginnen :)
                                Ich habe vor das ganze ohne den Schritt über MQTT direkt in Datenpunkte zu schreiben, sonst kann man es sich ja sparen das über iobroker laufen zu lassen.
                                Am schönsten wäre natürlich ein Adapter, aber davon bin ich weit entfernt :D
                                I 2 Antworten Letzte Antwort
                                • H h07d0q
                                  @rettroo @fastfoot
                                  I Offline
                                  I Offline
                                  init5
                                  @h07d0q das wäre ideal, wenn dafür jemand einen Adapter erstellen kann. Scheinbar ist die Nachfrage bei dem System nicht sonderlich hoch. Ich versuche gerade das Skript so anzupassen, dass es bei mir läuft. Sollte ich es hinbekommen, werde ich es dir zur Verfügung stellen.
                                  • H h07d0q
                                    @rettroo @fastfoot
                                    I Offline
                                    I Offline
                                    init5
                                    schrieb am zuletzt editiert von init5
                                    @h07d0q So, ich habe nun ein funktionierendes Skript am Laufen. Geklaut habe ich es von hier. Wäre schön wenn jemand einen Adapter daraus bauen kann.
                                    const net = require('net');
                                    const fs = require('fs');
                                    const path = require('path');
                                    const mqtt = require('mqtt');
                                    class DahuaVTO {
                                      deviceType;
                                      serialNumber;
                                      requestId = 0;
                                      sessionId = 0;
                                      keepAliveInterval = 60;
                                      _keepAliveTimer;
                                      doorbellSocket;
                                      mqttClient;
                                      constructor() {
                                        this.dahua_host = "192.168.xxx.xxx";
                                        this.dahua_username = "VTOusername";
                                        this.dahua_password = "VTOpassword";
                                        this.mqtt_broker_host = "192.168.xxx.xxx";
                                        this.mqtt_broker_port = "1883";
                                        this.mqtt_broker_username = "mqttUsername";
                                        this.mqtt_broker_password = "mqttPassword";
                                        this.mqtt_broker_topic_prefix = "DahuaVTO";
                                        this.digestClient =  new DigestFetch(
                                          this.dahua_username,
                                          this.dahua_password
                                        this.getDeviceDetails().then(({ deviceType, serialNumber }) => {
                                          this.deviceType = deviceType;
                                          this.serialNumber = serialNumber;
                                          this.start();
                                      start() {
                                        this.setupDoorbellSocket();
                                        this.setupMQTT();
                                        this.initLogin();
                                      async getDeviceDetails() {
                                        return this.digestClient
                                          .fetch(
                                            `http://${this.dahua_host}/cgi-bin/magicBox.cgi?action=getSystemInfo`
                                          .then((r) => r.text())
                                          .then((text) => {
                                            const deviceDetails = text
                                              .trim()
                                              .split('\n')
                                              .reduce((obj, str) => {
                                                const [key, val] = str.split('=');
                                                obj[key] = val.trim();
                                                return obj;
                                            return deviceDetails;
                                      saveSnapshot(p = '/tmp/') {
                                        let now = new Date();
                                        let dateStr = `${now.getFullYear()}-${
                                          now.getMonth() + 1
                                        }-${now.getDate()}-${now.getHours()}-${now.getMinutes()}-${now.getSeconds()}`;
                                        let destination = path.join(p, `DoorBell_${dateStr}.jpg`);
                                        this.digestClient
                                          .fetch(`http://${this.dahua_host}/cgi-bin/snapshot.cgi`)
                                          .then((r) => {
                                            return r.buffer();
                                          .then((buf) => {
                                            fs.writeFile(destination, buf, 'binary', function (err) {
                                              if (err) {
                                                log('Error saving snapshot to disk', err);
                                              } else {
                                                log('Snapshot saved');
                                      setupDoorbellSocket() {
                                        let socket = new net.Socket({ readable: true, writable: true });
                                        socket.on('end', function () {
                                          log('Doorbell socket ended');
                                        socket.on('close', function () {
                                         log('Doorbell socket closed');
                                          clearInterval(this._keepAliveTimer);
                                        socket.on('data', this.receive.bind(this));
                                        socket.on('error', function (e) {
                                          log('Doorbell socket error', e);
                                          this.doorbellSocket.destroy();
                                          this.mqttClient.end(true);
                                          this.start();    });
                                        this.doorbellSocket = socket.connect({ port: 5000, host: this.dahua_host });
                                      setupMQTT() {
                                        this.mqttClient = mqtt.connect({
                                          host: this.mqtt_broker_host,
                                          port: this.mqtt_broker_port,
                                          username: this.mqtt_broker_username,
                                          password: this.mqtt_broker_password,
                                          will: {
                                            topic: `${this.mqtt_broker_topic_prefix}/lwt`,
                                            payload: 'connected',
                                            qos: 1,
                                        this.mqttClient.on('disconnect', function (packet) {
                                          log('MQTTDisconnect', packet);
                                        this.mqttClient.on('message', function (topic, message, packet) {
                                          log('MQTTMessage', { topic, message, packet });
                                      publishToMQTT(name, payload) {
                                        let message = JSON.stringify(payload);
                                        this.mqttClient.publish(
                                          `${this.mqtt_broker_topic_prefix}/${name}/Event`,
                                          message
                                      send(data) {
                                        let json = JSON.stringify(data);
                                        let buf = Buffer.alloc(32);
                                        let offset = buf.writeUInt32BE(0x20000000);
                                        offset = buf.writeUInt32BE(0x44484950, offset);
                                        offset = buf.writeDoubleBE(0, offset);
                                        offset = buf.writeUInt32LE(json.length, offset);
                                        offset = buf.writeUInt32LE(0, offset);
                                        buf = Buffer.concat([buf, Buffer.from(json)]);
                                        this.requestId += 1;
                                        this.doorbellSocket.write(buf);
                                      receive(buf) {
                                        let str = buf.slice(32).toString();
                                        let obj = JSON.parse(str);
                                        if (this.requestId === 1) {
                                          this.handleFirstLoginPayload(obj);
                                        } else if (this.requestId === 2) {
                                          this.handleSecondLoginPayload(obj);
                                        } else if (obj.method === 'client.notifyEventStream') {
                                          this.handleEvents(obj.params.eventList);
                                        } else {
                                          this.handleGenericPayload(obj);
                                      initLogin() {
                                        this.send({
                                          magic: '0x1234',
                                          method: 'global.login',
                                          params: {
                                            clientType: '',
                                            ipAddr: '(null)',
                                            loginType: 'Direct',
                                            password: '',
                                            userName: this.dahua_username,
                                          session: 0,
                                      handleFirstLoginPayload({ session, params: { random, realm } }) {
                                        this.sessionId = session;
                                        let randomHash = this.genMD5Hash(random, realm);
                                        this.send({
                                          magic: '0x1234',
                                          session: this.sessionId,
                                          params: {
                                            password: randomHash,
                                            clientType: '',
                                            ipAddr: '(null)',
                                            authorityType: 'Default',
                                      handleSecondLoginPayload(obj) {
                                        if (obj.result) {
                                          log('Logging to Dahua Doorbell successful');
                                          this.keepAliveInterval = obj.params.keepAliveInterval - 5;
                                          this.attachEventManager();
                                          this.keepConnectionAlive();
                                        } else {
                                          log('Failed to login. Response was: ', obj);
                                      handleGenericPayload(obj) {
                                        if (
                                          obj.result === true &&
                                          obj.params &&
                                          Object.hasOwnProperty.call(obj.params, 'timeout')
                                          log('Publish KeepAlive event');
                                          this.publishToMQTT('keepAlive', {
                                            deviceType: this.deviceType,
                                            serialNumber: this.serialNumber,
                                        } else {
                                          log(
                                            'handleGenericPayload# Cannot handle received payload',
                                            obj
                                      genMD5Hash(random, realm) {
                                        const base_credentials = `${this.dahua_username}:${realm}:${this.dahua_password}`;
                                        const pwddb_hash = md5(base_credentials).toUpperCase();
                                        const base_pass = `${this.dahua_username}:${random}:${pwddb_hash}`;
                                        return md5(base_pass).toUpperCase();
                                      attachEventManager() {
                                        this.send({
                                          magic: '0x1234',
                                          method: 'eventManager.attach',
                                          params: {
                                            codes: ['All'],
                                      handleEvents(events) {
                                        events.forEach((event) => {
                                          log(`Publish event ${event.Code} to MQTT`);
                                          this.publishToMQTT(event.Code, {
                                            Action: event.eventAction,
                                            Data: event.Data,
                                      keepConnectionAlive(delay) {
                                        this._keepAliveTimer = setInterval(() => {
                                          let keepAlivePayload = {
                                            method: 'global.keepAlive',
                                            magic: '0x1234',
                                            params: {
                                              timeout: delay,
                                              active: true,
                                          this.send(keepAlivePayload);
                                        }, this.keepAliveInterval * 1000);
                                      openDoor() {
                                          .fetch(
                                            `http://${this.dahua_host}/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote`
                                          .then((r) => {
                                            if (r.ok) {
                                              log('Door relay triggered');
                                            } else {
                                              log('Error triggering the door relay', e);
                                          .catch(e => log('Connection error triggering the door relay'));
                                    exports.default = DahuaVTO;
                                    new DahuaVTO();```
                                    H 1 Antwort Letzte Antwort
                                    • I init5
                                      class DahuaVTO {
                                        deviceType;
                                        serialNumber;
                                        requestId = 0;
                                        sessionId = 0;
                                        _keepAliveTimer;
                                        doorbellSocket;
                                        mqttClient;
                                        constructor() {
                                            this.dahua_password
                                            this.start();
                                        start() {
                                          this.setupMQTT();
                                          this.initLogin();
                                            .fetch(
                                            .then((text) => {
                                                .trim()
                                                .split('\n')
                                                  return obj;
                                            now.getMonth() + 1
                                          this.digestClient
                                            .then((r) => {
                                              return r.buffer();
                                            .then((buf) => {
                                                if (err) {
                                                } else {
                                            this.start();    });
                                        setupMQTT() {
                                            will: {
                                              qos: 1,
                                            message
                                        send(data) {
                                        receive(buf) {
                                          } else {
                                        initLogin() {
                                          this.send({
                                            magic: '0x1234',
                                            params: {
                                              clientType: '',
                                              ipAddr: '(null)',
                                              password: '',
                                            session: 0,
                                          this.send({
                                            magic: '0x1234',
                                            params: {
                                              clientType: '',
                                              ipAddr: '(null)',
                                          if (obj.result) {
                                          } else {
                                          if (
                                            obj.params &&
                                          } else {
                                            log(
                                              obj
                                          this.send({
                                            magic: '0x1234',
                                            params: {
                                              codes: ['All'],
                                              Data: event.Data,
                                              magic: '0x1234',
                                              params: {
                                                timeout: delay,
                                                active: true,
                                        openDoor() {
                                            .fetch(
                                            .then((r) => {
                                              if (r.ok) {
                                              } else {
                                      new DahuaVTO();```
                                      h07d0q
                                      schrieb am zuletzt editiert von h07d0q
                                      @init5 Vielen Dank für's Teilen!
                                      Habe für mich das Skript angepasst, dass ich keinen MQTT Broker benötige. Es funktioniert bei mir so weit, dass Events ankommen und geloggt werden. Ich reagiere derzeit nur auf das eines Klingelns. Da werden im 2s Abstand Fotos aufgenommen und gespeichert, dann mittels ffmpeg zu einem gif zusammengefasst und per telegram versendet :)
                                      const __dirname = '/opt/iobroker/iobroker-data/files/';
                                      // Erweiterter Log im ioBroker
                                      const LOG_INFO = true;    // Informationen loggen
                                      const LOG_DEBUG = false;   // Erweiterter Log für Debugging
                                       * Class to abstract a dahua doorbell.
                                       * On instantiation it automatically connects with the doorbell, logs in and
                                       * subscribes to all events.
                                       * The Data is written to iobroker datapoints
                                      class DahuaVTO {
                                        deviceType;
                                        serialNumber;
                                         * {Number} requestId
                                         * Our Request / Response ID that must be in all requests and initated by us.
                                         * This number auto-increments every time we send a message. Once we've logged in, every
                                         * response contains the request id of which it's a response of, se it could be used to
                                         * match responses with requests.
                                         * I haven't bothered to do so because ,for what I saw, we only care about response order
                                         * for the initial setup, and we do that on request at a time.
                                         * If we ever make requests in parallel and we need to associate response to each request,
                                         * we could use this. For not, it's just an auto-incremental number.
                                        requestId = 0;
                                        // Session ID will be returned after successful login
                                         * {Number} sessionId
                                         * When we try to log in on the doorbell we get a sessionId. From that point on every message
                                         * we send over the socket needs to have include the sessionID for the doorbell to recognize us.
                                        sessionId = 0;
                                        // Will be set after the login, but we initialize to 60s because it's a reasonable default
                                         * {Number} keepAliveInterval
                                         * The number of seconds we have to space our keepAlive messages so the doorbell doesn't close
                                         * the connection.
                                         * The ID returned by the `setInterval` call.
                                         * We keep a reference in case we want to cancel it (maybe in case of failure?)
                                        _keepAliveTimer;
                                         * TCP socket to communicate with the doorbell external unit.
                                        doorbellSocket;
                                        constructor() {
                                          this.dahua_host = "192.168.0.10";
                                          this.dahua_username = "admin";
                                          this.dahua_password = "password";
                                            this.dahua_password
                                            this.start();
                                         * Starts the app by:
                                         *    - Opening a TCP socket to the doorbell
                                         *    - Authenticating with the doorbell and subscribing to events.
                                        start() {
                                          this.initLogin();
                                         * Makes a request to the doorbell using digest auth to retrieve the device's information.
                                         * The information is returned in plain text (not JSON) that we have to parse.
                                         * For now I think we only care about device type and serial number, which can be
                                         * used to disambiguate in case we have more than one doorbell.
                                            .fetch(
                                            .then((text) => {
                                                .trim()
                                                .split('\n')
                                                  return obj;
                                         * Creates the TCP socket connection with the doorbell on port 5000.
                                         * Setups the listener for when we receive data over that socket
                                         * Also setups other listeners for logging purposes mostly.
                                         * If something goes wrong, we close everything and try to start over again.
                                            if (LOG_DEBUG) console.debug('Doorbell socket ended');
                                            if (LOG_DEBUG) console.debug('Doorbell socket closed');
                                            console.error('Doorbell socket error', e);
                                            this.doorbellSocket.destroy(); // destroy the socket
                                            clearInterval(this._keepAliveTimer); // Stop sending keepalive requests
                                            this.start(); // Start over again.
                                         * Sends a message with the given data to the doorbell's outside unit using the TCP socket.
                                         * @param {string} data
                                         * This is a fairly low level way of communication, so let's dive in.
                                         * We write binary to the socket, so we have to use buffers.
                                         * The first 32 bytes of the message are the header.
                                         * After the header we concat the actual message, which is a JSON string.
                                         * The header has some bits that are fixed and others that are the length of the message that will
                                         * come after.
                                         * I didn't reverse-engineered this myself but it works. Take it as gospel as I did.
                                        send(data) {
                                         * Handles received messages from the TCP socket.
                                         * @param {Buffer} buf
                                         * The received messages are binary. Once discarded the first 32 bytes (the header),
                                         * the rest of the message is parsed as as a JSON string.
                                         * The header contains the length of the received response in bytes 16..20 and the expected
                                         * length of the response in bytes 24..28 in case we need it, but I haven't found a
                                         * reason to. Perhaps responses might be sent in several chunks? So far it doesn't seem to be
                                         * the case.
                                         * Since we always make requests in the exact same order, we know the first two responses are
                                         * for the authentication.
                                         * Subsequent responses can be either events or keepalive responses.
                                        receive(buf) {
                                          } else {
                                         * Sends the initial login request.
                                         * Note that does not include any password.
                                         * The response to this request will be negative but that is expected, it will contain the
                                         * necessary information to login.
                                        initLogin() {
                                          this.send({
                                            magic: '0x1234',
                                            params: {
                                              clientType: '',
                                              ipAddr: '(null)',
                                              password: '',
                                            session: 0,
                                         * Handles the response to the initial login request.
                                         * The response contains a session ID, a realm and a random, which in combination with
                                         * the username and the password are used to generate an MD5 password that is used
                                         * for logging in.
                                         * @param {object} payload
                                          this.send({
                                            id: 10000, // I assume this ID a high number just because we have to send something.
                                            magic: '0x1234', // No idea what this is
                                            params: {
                                              clientType: '',
                                              ipAddr: '(null)',
                                         * Handles the response to the second (and last) response to login request.
                                         * If successful, any subsequent message that includes the session id will be accepted for
                                         * as long as the socket is not closed.
                                         * To prevent the socket from closing we send a keepalive message every so often.
                                         * Also now that we're authenticated we subscribe to all events fired by the doorbell.
                                          if (obj.result) {
                                            if (LOG_INFO) console.log('Login to Dahua Doorbell successful');
                                          } else {
                                            console.error('Failed to login. Response was: ', obj);
                                         * Publishes Data of an event with the given name and payload.
                                         * @param {string} name
                                        publishData(name, payload) {
                                          if (LOG_DEBUG && (name == "TimeChange" || name == "NTPAdjustTime")) {
                                              console.debug(message);
                                          } else if (!(name == "TimeChange" || name == "NTPAdjustTime")) console.log(message);
                                         * Handles any response not handled by any other method. I believe only keepalive responses
                                         * will end up here, but added some logging just in case.
                                         * For now keepalive events are published, but I don't see a good reason for that.
                                          if (
                                            obj.params &&
                                            (Object.hasOwnProperty.call(obj.params, 'timeout') || Object.hasOwnProperty.call(obj.params, 'SID'))
                                            if (LOG_DEBUG) {
                                              console.debug('Publish KeepAlive event');
                                              this.publishData('keepAlive', {
                                          } else {
                                            console.error('handleGenericPayload# Cannot handle received payload');
                                            console.error(obj);
                                         * Generates a MD5 digest of the username, password, realms and random to send as
                                         * password when logging in.
                                         * @param {*} random
                                         * @param {*} realm
                                         * Sends the message to subscribe to all dorbell events.
                                          this.send({
                                            magic: '0x1234',
                                            params: {
                                              codes: ['All'],
                                         * Handles the events sent by the doorbell.
                                         * It just publishes those events along with some information of the device
                                            if (LOG_INFO) console.log(`Publish event ${event.Code}`);
                                            this.publishData(event.Code, {
                                              Data: event.Data,
                                            if (event.Code == "CallNoAnswered") {
                                                this.saveSnapshots();
                                         * Sets up a function to be called periodically to keep the socket open by sending
                                         * keepalive messages.
                                         * @param {Number} delay (in seconds)
                                              magic: '0x1234',
                                              params: {
                                                timeout: delay,
                                                active: true,
                                         * Remotely triggers the relay 1 (e.g. to open an electric gate).
                                         * In my VTO 2202 F this also triggers the voice announcing the the door has been opened.
                                        openDoor() {
                                            .fetch(
                                            .then((r) => {
                                              if (r.ok) {
                                                if (LOG_INFO) console.log('Door relay triggered');
                                              } else {
                                                console.error('Error triggering the door relay', e);
                                            .catch(e => console.error('Connection error triggering the door relay'));
                                        // requestMissedCallsLog() {
                                        //   this.send({
                                        //     id: this.requestId,
                                        //     magic: '0x1234',
                                        //     method: 'RecordFinder.factory.create',
                                        //     params: {
                                        //       name: 'VideoTalkMissedLog',
                                        //     session: this.sessionId,
                                        // requestMissedCallsLog2(findToken) {
                                        //   this.send({
                                        //     magic: '0x1234',
                                        //     method: 'RecordFinder.startFind',
                                        //     object: findToken,
                                        //     params: { condition: null },
                                        // requestMissedCallsLog3(findToken) {
                                        //   this.send({
                                        //     magic: '0x1234',
                                        //     method: 'RecordFinder.doFind',
                                        //     params: { count: 3 }, // Number of calls to show
                                         * Saves a snapshot of the doorbells image into the given directory (defaults to /tmp/).
                                         * By default the file is named with a simple timestamp of the current time (YYYY-MM-DD-H-M-S.jpg)
                                        archiveSnapshot(p = '0_userdata.0/VTO') {
                                            now.getMonth() + 1
                                          let destination = path.join(__dirname, p, `VTO_${dateStr}.jpg`);
                                          this.digestClient
                                            .then((r) => {
                                              return r.buffer();
                                            .then((buf) => {
                                                if (err) {
                                                  console.error(err);
                                                  console.error('Error saving snapshot to disk', err);
                                                } else {
                                                  if (LOG_INFO) console.log('Snapshot saved: ' + destination);
                                        async saveSnapshots() {
                                          for (let i = 1; i < 4; i++) {
                                              let destination = `/VTO/VTO_${i}.jpg`
                                              this.digestClient
                                              .then((r) => {
                                                  return r.buffer();
                                              .then((buf) => {
                                                  writeFile('vis.0', destination, buf, function (err) {
                                                      if (err) {
                                                          console.error(err);
                                                      } else {
                                                          if (LOG_INFO) console.debug('Snapshot saved: ' + destination);
                                                          //ggf. hier schon einzelnes Bild verschicken
                                              await new Promise(resolve => setTimeout(resolve, 2000));
                                          // Fotos wurden erstellt
                                          // GIF erstellen
                                          if (LOG_DEBUG) console.debug('telegram.gif erstellen...');
                                          exec("ffmpeg -framerate 2 -pattern_type glob -i '/opt/iobroker/iobroker-data/files/vis.0/VTO/VTO_*.jpg' -y '/opt/iobroker/iobroker-data/files/vis.0/VTO/telegram.gif'", async function (error, result, stderr) {
                                              //nach Erstellung per Telegram versenden
                                              //fs.readFileSync('/opt/iobroker/iobroker-data/files/vis.0/VTO/telegram.gif');
                                              if (LOG_DEBUG) console.debug(stderr);
                                              if (LOG_INFO) console.log('GIF erstellt. Telegram Nachricht versenden.');
                                              sendTo("telegram", "send", {
                                                  text: '/opt/iobroker/iobroker-data/files/vis.0/VTO/telegram.gif', caption: 'Haustür:'
                                      new DahuaVTO();
                                      Ich hoffe das hilft dem ein oder anderen Suchenden, der es einfach will :)
                                      L 1 Antwort Letzte Antwort
                                      • H h07d0q
                                        class DahuaVTO {
                                          deviceType;
                                          serialNumber;
                                          requestId = 0;
                                          sessionId = 0;
                                           * the connection.
                                          _keepAliveTimer;
                                          doorbellSocket;
                                          constructor() {
                                              this.dahua_password
                                              this.start();
                                          start() {
                                            this.initLogin();
                                              .fetch(
                                              .then((text) => {
                                                  .trim()
                                                  .split('\n')
                                                    return obj;
                                           * come after.
                                          send(data) {
                                           * the case.
                                          receive(buf) {
                                            } else {
                                          initLogin() {
                                            this.send({
                                              magic: '0x1234',
                                              params: {
                                                clientType: '',
                                                ipAddr: '(null)',
                                                password: '',
                                              session: 0,
                                           * for logging in.
                                            this.send({
                                              params: {
                                                clientType: '',
                                                ipAddr: '(null)',
                                            if (obj.result) {
                                            } else {
                                            if (
                                              obj.params &&
                                              if (LOG_DEBUG) {
                                            } else {
                                              console.error(obj);
                                           * @param {*} random
                                           * @param {*} realm
                                            this.send({
                                              magic: '0x1234',
                                              params: {
                                                codes: ['All'],
                                                Data: event.Data,
                                                magic: '0x1234',
                                                params: {
                                                  timeout: delay,
                                                  active: true,
                                          openDoor() {
                                              .fetch(
                                              .then((r) => {
                                                if (r.ok) {
                                                } else {
                                          //   this.send({
                                          //     magic: '0x1234',
                                          //     params: {
                                          //   this.send({
                                          //     magic: '0x1234',
                                          //   this.send({
                                          //     magic: '0x1234',
                                              now.getMonth() + 1
                                            this.digestClient
                                              .then((r) => {
                                                return r.buffer();
                                              .then((buf) => {
                                                  if (err) {
                                                    console.error(err);
                                                  } else {
                                                this.digestClient
                                                .then((r) => {
                                                    return r.buffer();
                                                .then((buf) => {
                                                        if (err) {
                                                            console.error(err);
                                                        } else {
                                            // GIF erstellen
                                        new DahuaVTO();
                                        LubuBroker
                                        @h07d0q Hallo
                                        Ist zwar schon ein bisschen älter, aber vielleicht kannst du mir trotzdem helfen.
                                        Ich habe versucht dein Skript auszuführen.
                                        Habe zuvor im JavaScript Adapter folgende einträge gemacht.
                                        Leider wird in deinem Skript die beiden Module Rot unterstrichen
                                        Was mache ich da falsch?
                                        IssiI 1 Antwort Letzte Antwort
                                        • IssiI Offline
                                          IssiI Offline
                                          Issi
                                          @h07d0q
                                          Das mit dem Adapter ist nicht immer so einfach.
                                          Klar kann ein Developer da einen basteln, aber ohne die nötigen Geräte zum Testen ist es immer ein Blindflug beim Programmieren, und wenn man die User das testen überlässt, ist das auch nicht immer so das Gelbe vom Ei, da man immer auf das Feedback warten muss, und sehr oft wissen die User nicht, was sie machen müssen.
                                          Deswegen geht auch kaum ein Developer an Adapter-Entwicklung, wenn er keine Geräte zum Testen hat.
                                          Aber du kannst gerne mal einen Adapter Request unter => ioBroker Adapter Requests erstellen, vorher natürlich schauen, ob es nicht schon einen Request gibt und vllt. hat ja einer der Devs die Geräte und macht da einen Adapter.
