  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
  • A Altersrentner
    @crunchip
    Die ini ist bearbeitet
    DEBUG] [grafana] - Start Grafana Restore ...
    [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2021_03_08-02_18_32_backupiobroker.tar.gz
    [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
    [DEBUG] [grafana] - start decompress
    [DEBUG] [grafana] - Grafana request started
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
    [DEBUG] [grafana] - datasoure restore "InfluxDB-1" finish: {"datasource":{"id":2,"uid":"s1r54cgRz","orgId":1,"name":"InfluxDB-1","type":"influxdb","typeLogoUrl":"","access":"proxy","url":"http://192.168.178.41:8086","password":"","user":"admin","database":"iobroker","basicAuth":false,"basicAuthUser":"","basicAuthPassword":"","withCredentials":false,"isDefault":false,"jsonData":{"httpMode":"GET"},"secureJsonFields":{},"version":1,"readOnly":false},"id":2,"message":"Datasource added","name":"InfluxDB-1"}
    [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/n1-aussen-wz.json
    [DEBUG] [grafana] - cannot restore dashboard "n1-aussen-wz": {"message":"invalid API key"}
    [DEBUG] [grafana] - Grafana request ended
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory
    [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
    [DEBUG] [grafana] - Grafana Restore completed successfully
    [EXIT] Grafana restore done
    Da stehen die Daten:
    irgend etwas stimmt noch nicht
    crunchipC Abwesend
    crunchipC Abwesend
    #154
    @altersrentner laut deinem log
    • hast du ne InfluxDB.json und eine InfluxDB.json1, InfluxDB.json existiert aber scheinbar schon
    • für n1-aussen-wz.json stimmt scheinbar dein api key nicht
    ich bin da nicht so fit drin, da ich diese backup Funktion via backitup nicht verwende
    du hast doch ein backup von Grafana erstellt grafana_2021_03_07-19_42_25_backupiobroker.tar.gz und dieses muss zurückgespielt werden.
    was beinhaltet dieses backup?
      Altersrentner
      #155
      @crunchip
      Das Backup habe ich schon mehrmals zurückgespielt.
      Es ist von der alten Platte .
      Habe mir jetzt das Skript aus Grafana der alten Platte geladen
        "datasource": "InfluxDB-1",
        "aliasColors": {
          "Temperatur Wohnzimmer": "rgb(221, 176, 63)"
        "bars": false,
        "dashLength": 10,
        "dashes": false,
        "decimals": 1,
        "fill": 1,
        "fillGradient": 0,
        "gridPos": {
          "h": 9,
          "w": 12,
          "x": 12,
          "y": 0
        "hiddenSeries": false,
        "id": 4,
        "legend": {
          "avg": false,
          "current": true,
          "max": true,
          "min": true,
          "show": true,
          "total": false,
          "values": true
        "lines": true,
        "linewidth": 1,
        "nullPointMode": "null",
        "options": {
          "dataLinks": [
              "title": "",
              "url": ""
        "percentage": false,
        "pointradius": 2,
        "points": false,
        "renderer": "flot",
        "seriesOverrides": [
            "alias": "Außentemperatur",
            "fill": 3,
            "fillGradient": 0,
            "yaxis": 1
            "alias": "Temperatur Wohnzimmer",
            "yaxis": 1
            "alias": "Power",
            "yaxis": 2
        "spaceLength": 10,
        "stack": false,
        "steppedLine": false,
        "targets": [
            "groupBy": [
                "params": [
                  "$__interval"
                "type": "time"
                "params": [
                  "previous"
                "type": "fill"
            "measurement": "mihome.0.devices.weather_v1_158d00023213f6.temperature",
            "orderByTime": "ASC",
            "policy": "default",
            "refId": "A",
            "resultFormat": "time_series",
            "select": [
                  "params": [
                    "value"
                  "type": "field"
                  "params": [],
                  "type": "max"
            "tags": []
            "alias": "Temperatur Heizkessel",
            "groupBy": [
                "params": [
                  "$__interval"
                "type": "time"
                "params": [
                  "previous"
                "type": "fill"
            "measurement": "fhem.0.Temp_Heizkessel.temperature",
            "refId": "B",
            "select": [
                  "params": [
                    "value"
                  "type": "field"
                  "params": [],
                  "type": "max"
            "tags": []
            "alias": "Temperatur Puffer",
            "groupBy": [
                "params": [
                  "$__interval"
                "type": "time"
                "params": [
                  "previous"
                "type": "fill"
            "measurement": "hm-rpc.0.OEQ0673599.2.TEMPERATURE",
            "refId": "C",
            "select": [
                  "params": [
                    "value"
                  "type": "field"
                  "params": [],
                  "type": "max"
            "tags": []
            "alias": "Power",
            "groupBy": [
                "params": [
                  "$__interval"
                "type": "time"
                "params": [
                  "previous"
                "type": "fill"
            "measurement": "shelly.0.SHSW-PM#8CAAB542C16C#1.Relay0.Power",
            "refId": "E",
            "select": [
                  "params": [
                    "value"
                  "type": "field"
                  "params": [],
                  "type": "max"
            "tags": []
        "thresholds": [],
        "timeFrom": null,
        "timeRegions": [],
        "timeShift": null,
        "title": "Temperatur Außen  / Temperatur Kessel /Temperatur Puffer9 / KesselStatus",
        "tooltip": {
          "shared": true,
          "sort": 0,
          "value_type": "individual"
        "type": "graph",
        "xaxis": {
          "buckets": null,
          "mode": "time",
          "name": null,
          "show": true,
          "values": []
        "yaxes": [
            "decimals": 1,
            "format": "celsius",
            "label": null,
            "logBase": 1,
            "max": null,
            "min": null,
            "show": true
            "decimals": 1,
            "format": "watt",
            "label": null,
            "logBase": 1,
            "max": null,
            "min": null,
            "show": true
        "yaxis": {
          "align": false,
          "alignLevel": null
      Kann man das einbinden?
      MfG Michael
      • A Altersrentner
        @crunchip
          "aliasColors": {
          "bars": false,
          "dashLength": 10,
          "dashes": false,
          "decimals": 1,
          "fill": 1,
          "fillGradient": 0,
          "gridPos": {
            "h": 9,
            "w": 12,
            "x": 12,
            "y": 0
          "id": 4,
          "legend": {
            "avg": false,
            "current": true,
            "max": true,
            "min": true,
            "show": true,
            "total": false,
            "values": true
          "lines": true,
          "linewidth": 1,
          "options": {
            "dataLinks": [
                "title": "",
                "url": ""
          "pointradius": 2,
          "points": false,
          "renderer": "flot",
              "fill": 3,
              "fillGradient": 0,
              "yaxis": 1
              "yaxis": 1
              "alias": "Power",
              "yaxis": 2
          "spaceLength": 10,
          "stack": false,
          "targets": [
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "refId": "A",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "max"
              "tags": []
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "refId": "B",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "max"
              "tags": []
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "refId": "C",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "max"
              "tags": []
              "alias": "Power",
              "groupBy": [
                  "params": [
                    "$__interval"
                  "type": "time"
                  "params": [
                    "previous"
                  "type": "fill"
              "refId": "E",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "max"
              "tags": []
          "thresholds": [],
          "timeFrom": null,
          "timeRegions": [],
          "timeShift": null,
          "tooltip": {
            "shared": true,
            "sort": 0,
          "type": "graph",
          "xaxis": {
            "buckets": null,
            "mode": "time",
            "name": null,
            "show": true,
            "values": []
          "yaxes": [
              "decimals": 1,
              "label": null,
              "logBase": 1,
              "max": null,
              "min": null,
              "show": true
              "decimals": 1,
              "format": "watt",
              "label": null,
              "logBase": 1,
              "max": null,
              "min": null,
              "show": true
          "yaxis": {
            "align": false,
            "alignLevel": null
        MfG Michael
        crunchipC Abwesend
        crunchipC Abwesend
        #156
        @altersrentner ist das dein einziges Dashboard? Ja das kann man einfügen.
        Auf deiner Grafana Seite, links auf das +,dann Import
        unterhalb von Import via panel json, kannst du es einfügen.
        @altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
        dann ist es ja scheinbar schon vorhanden. Schau doch mal unter folgendem Pfad was du so findest
        var/lib/grafana
        • A Altersrentner
          @crunchip
            "aliasColors": {
            "bars": false,
            "dashLength": 10,
            "dashes": false,
            "decimals": 1,
            "fill": 1,
            "fillGradient": 0,
            "gridPos": {
              "h": 9,
              "w": 12,
              "x": 12,
              "y": 0
            "id": 4,
            "legend": {
              "avg": false,
              "current": true,
              "max": true,
              "min": true,
              "show": true,
              "total": false,
              "values": true
            "lines": true,
            "linewidth": 1,
            "options": {
              "dataLinks": [
                  "title": "",
                  "url": ""
            "pointradius": 2,
            "points": false,
            "renderer": "flot",
                "fill": 3,
                "fillGradient": 0,
                "yaxis": 1
                "yaxis": 1
                "alias": "Power",
                "yaxis": 2
            "spaceLength": 10,
            "stack": false,
            "targets": [
                "groupBy": [
                    "params": [
                      "$__interval"
                    "type": "time"
                    "params": [
                      "previous"
                    "type": "fill"
                "refId": "A",
                "select": [
                      "params": [
                        "value"
                      "type": "field"
                      "params": [],
                      "type": "max"
                "tags": []
                "groupBy": [
                    "params": [
                      "$__interval"
                    "type": "time"
                    "params": [
                      "previous"
                    "type": "fill"
                "refId": "B",
                "select": [
                      "params": [
                        "value"
                      "type": "field"
                      "params": [],
                      "type": "max"
                "tags": []
                "groupBy": [
                    "params": [
                      "$__interval"
                    "type": "time"
                    "params": [
                      "previous"
                    "type": "fill"
                "refId": "C",
                "select": [
                      "params": [
                        "value"
                      "type": "field"
                      "params": [],
                      "type": "max"
                "tags": []
                "alias": "Power",
                "groupBy": [
                    "params": [
                      "$__interval"
                    "type": "time"
                    "params": [
                      "previous"
                    "type": "fill"
                "refId": "E",
                "select": [
                      "params": [
                        "value"
                      "type": "field"
                      "params": [],
                      "type": "max"
                "tags": []
            "thresholds": [],
            "timeFrom": null,
            "timeRegions": [],
            "timeShift": null,
            "tooltip": {
              "shared": true,
              "sort": 0,
            "type": "graph",
            "xaxis": {
              "buckets": null,
              "mode": "time",
              "name": null,
              "show": true,
              "values": []
            "yaxes": [
                "decimals": 1,
                "label": null,
                "logBase": 1,
                "max": null,
                "min": null,
                "show": true
                "decimals": 1,
                "format": "watt",
                "label": null,
                "logBase": 1,
                "max": null,
                "min": null,
                "show": true
            "yaxis": {
              "align": false,
              "alignLevel": null
          MfG Michael
          crunchipC Abwesend
          crunchipC Abwesend
          #157
          @altersrentner ansonsten, wenn es speziell um's Backup geht, könntest du dort mal nachfragen
            Altersrentner
            #158
            @crunchip Guten Morgen,
            Hier ist auch die heutige eingefügte grafanaDB zu sehen.
            Nur es gibt keine graphische Darstellung.
            Mit freundlichen Grüßen
            Michael
            • A Altersrentner
              Michael
              crunchipC Abwesend
              crunchipC Abwesend
              #159
              Lässt sich das Dashboard nicht öffnen, oder ist leer?
                Altersrentner
                #160
                @crunchip Hallo,
                Ich bedanke mich für die Unterstützung.
                Die dortige Nachfrage hat mich auf den richtigen Weg gebracht.
                Ich hatte vermutlich den API key nicht als Admin angelegt sondern als viewer.
                Michael
                • wendy2702W wendy2702
                  @altersrentner Hatt ich zwar schon geschrieben kannst aber auch gerne nochmal hier schauen
                  cat /etc/hosts
                  Altersrentner
                  #161
                  @wendy2702 Hallo,
                  Auch Dir nochmal besten Dank für die Unterstützung
                  Michael
                  • A Altersrentner
                    @crunchip Hallo,
                    Michael
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #162
                    @altersrentner habe es dort gerade gelesen
                    dann läuft ja wieder alles👍
                    • A Altersrentner
                      @wendy2702 Hallo,
                      Michael
                      wendy2702W Online
                      wendy2702W Online
                      #163
                      @altersrentner Habe gerne im Rahmen meiner Möglichkeiten geholfen.
                      Schön das es wieder läuft.
                        #164
                        @crunchip
                        Hi, der Beitrag ist zwar schon etwas älter aber habe hier am meisten zu meinem influxdb Problem gefunden.
                        Habe eben den Raspberry Pi aktualisiert und seitdem läuft mir der log mit Verbindungsproblemen zur influxdb voll. Ja, influxdb wurde auch etwas aktualisiert genau habe ich es aber nicht in der Kommandozeile lesen können.
                        Nach Versuchen in der conf habe ich festgestellt, dass influxdb gar nicht startet, aber warum?
                        Nach Netzsuche bekäme ich jetzt höchsten die influxdb gelöscht und frisch installiert, aber dann wären meine Daten futsch.
                        Habt ihr einen Tip? Besten Dank vorab!
                        pi@IOBroker:~ $ apt policy influxdb
                        influxdb:
                          Installiert:           1.8.7-1
                          Installationskandidat: 1.8.7-1
                          Versionstabelle:
                         *** 1.8.7-1 500
                                500 https://repos.influxdata.com/debian buster/stable armhf Packages
                             1.6.4-1+deb10u1 500
                        pi@IOBroker:~ $ sudo systemctl unmask influxdb.service
                        pi@IOBroker:~ $ sudo systemctl start influxdb
                        Job for influxdb.service failed because the control process exited with error code.
                        See "systemctl status influxdb.service" and "journalctl -xe" for details.
                        pi@IOBroker:~ $ sudo systemctl stop influxdb
                        pi@IOBroker:~ $ systemctl status influxdb.service
                        ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                           Active: failed (Result: exit-code) since Thu 2021-07-29 23:21:03 CEST; 3min 31s ago
                             Docs: https://docs.influxdata.com/influxdb/
                          Process: 7021 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
                        Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                        Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                        Jul 29 23:21:03 IOBroker systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                        Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Start request repeated too quickly.
                        Jul 29 23:21:03 IOBroker systemd[1]: influxdb.service: Failed with result 'exit-code'.
                        Jul 29 23:21:03 IOBroker systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                        pi@IOBroker:~ $
                        P 1 Antwort Letzte Antwort
                          @crunchip
                          influxdb:
                            Versionstabelle:
                           *** 1.8.7-1 500
                               1.6.4-1+deb10u1 500
                          pi@IOBroker:~ $
                          picky
                          #165
                          @pete0815 Hatte gestern meinen Raspi auch updatet, und auch das Problem gehabt das influxdb nicht mehr starten konnte. Bei mir hat geholfen
                          sudo chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                          und dann ließ es sich starten mit
                          ? P 2 Antworten Letzte Antwort
                          • P picky
                            #166
                            @picky
                            Vielen Dank!!!! Das war Lösung und läuft wieder.
                            Hatte auch einen Beitrag ergoogelt im computerbase forum, dort wird gezeigt, dass der Ordner /usr/lib/influxdb/scripts/ sich verändert hat und hier genau die1 Datei (influxd-systemd-start.sh) hinzu gekommen ist. Wie genau die Nutzerechte hier den services und skripte funktionieren bzw. sich geändert haben muss ich passen, aber es läuft wieder.
                            Links zu anderen Foren waren nicht erlaubt, aber die Info darf man zitieren?
                            (Quelle: ComputerBaseForum
                            • P picky
                              PeterHansen
                              #167
                              @picky Hi, nach 3 Tagen Google-Suche - Forenstöbern etc. ... BIST DU MEINe Mann/Frau !!!.
                              Du hast den heutigen HeldenGlobe von mir gewonnen !!!
                              Das war die Lösung für meine Fehlermeldung:
                              endlich :-)
                              • Basti97B Offline
                                Basti97B Offline
                                Basti97
                                #168
                                nachdem ich influx eingeben habe kommt ein >
                                bei mir. Was muss ich bei dieser Meldung machen?
                                ERR: error parsing query: found Mira, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
                                Warning: It is possible this error is due to not setting a database.
                                Please set a database with the command "use <database>".
                                > database
                                Folgende Anleitung habe ich genutzt
                                https://www.verdrahtet.info/2020/02/14/installation-von-influxdb-grafana-inkl-verbindung-zu-iobroker/
                                und bin bis zum Anbschnitt influxdb gekommen
                                Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                • Basti97B Basti97
                                  > database
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #169
                                  @basti97 sagte in [ Geklärt ] Problem bei Influx Installation:
                                  Das macht die InfluxDb Instanz automatisch für dich, wenn du die Datenbank einträgst und die Instanz gestartet hast
                                  Dann brauchst du nicht uber die Influx CLI extra eine Datenbank anlegen.
                                  Basti97B 1 Antwort Letzte Antwort
                                    Basti97B Offline
                                    Basti97B Offline
                                    Basti97
                                    #170
                                    @crunchip Danke für deine Hilfe jetzt funktioniert es. Die Anleitungen im Internet verwirren sehr.
                                    • A Altersrentner
                                      @crunchip Guten Morgen und einen schönen Feiertag;
                                      Bin jetzt damit beschäftigt Grafana einzurichten.
                                      Aber auch hier ist alles anders wie normal.
                                      Es beginnt schon mit der Eingabe der Settings
                                      Grafana verbindet sich nur wenn unter Access "BROWSER" ausgewählt ist.
                                      Habe viel gesucht und überall nur Verbindung über Server gefunden.
                                      Deshalb die Frage ist Browser OK oder eher nicht.
                                      Nach diesem Video habe ich dann meine Datenpunkte konfiguriert und überprüft.
                                      https://www.youtube.com/watch?v=VXfpds4Rtqc&t=4072s
                                      Alles prima..
                                      In den Dashboard Einstellungen sollten dann die in influxdb geloggten Daten
                                      unter dem Reiter "select measurement" erscheinen. Das Feld bleibt aber leer.
                                      Wie kann ich prüfen, ob besagte date überhaupt in der influxdb auftauchen.
                                      Z. B. mit einem Befehl im Terminal.
                                      Ich bin doch noch etwas weiter gekommen.😊
                                      Connected to http://localhost:8086 version 1.8.3
                                      InfluxDB shell version: 1.8.3
                                      > show databases
                                      name
                                      _internal
                                      iobroker
                                      > use iobroker
                                      Using database iobroker
                                      > show measurements
                                      name
                                      influxdb.0.info.connection
                                      mihome.0.devices.magnet_158d00020910b2.state
                                      mihome.0.devices.magnet_158d00020b5d12.state
                                      mihome.0.devices.magnet_158d00020b5d69.state
                                      mihome.0.devices.magnet_158d0003e72274.state
                                      mihome.0.devices.magnet_158d0003e741ac.state
                                      mihome.0.devices.magnet_158d0003e74624.state
                                      mihome.0.devices.magnet_158d0003e746aa.state
                                      mihome.0.devices.magnet_158d0003e747f7.state
                                      mihome.0.devices.weather_v1_158d00023213f6.humidity
                                      mihome.0.devices.weather_v1_158d000232801d.humidity
                                      mihome.0.devices.weather_v1_158d000232801d.temperature
                                      mihome.0.devices.weather_v1_158d0002329079.humidity
                                      mihome.0.devices.weather_v1_158d0002329079.temperature
                                      mihome.0.devices.weather_v1_158d00023290a8.humidity
                                      mihome.0.devices.weather_v1_158d00023290a8.temperature
                                      mihome.0.devices.weather_v1_158d00023290e8.humidity
                                      mihome.0.devices.weather_v1_158d00023290e8.temperature
                                      mihome.0.devices.weather_v1_158d00024906fa.humidity
                                      mihome.0.devices.weather_v1_158d00024906fa.temperature
                                      mihome.0.devices.weather_v1_158d00036b52b9.humidity
                                      mihome.0.devices.weather_v1_158d00036b52b9.temperature
                                      mihome.0.devices.weather_v1_158d00036b53b3.humidity
                                      mihome.0.devices.weather_v1_158d00036b53b3.temperature
                                      mihome.0.devices.weather_v1_158d00036b53ce.humidity
                                      mihome.0.devices.weather_v1_158d00036b53ce.temperature
                                      mihome.0.devices.weather_v1_158d00036bd6ea.humidity
                                      mihome.0.devices.weather_v1_158d00036bd6ea.temperature
                                      mihome.0.devices.weather_v1_158d00036bd78e.humidity
                                      mihome.0.devices.weather_v1_158d00036bd78e.temperature
                                      > show series
                                      key
                                      > > Das Initallisieren des Grafana Server:
                                      ERR: error parsing query: found >, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
                                      > show tag keys
                                      > show field keys
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    string
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    boolean
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      fieldKey fieldType
                                      ack      boolean
                                      from     string
                                      q        float
                                      value    float
                                      Ist soweit alles richtig?
                                      Soweit erst mal zum aktuellen Stand.
                                      Freundliche Grüße
                                      Michael
                                      benziman
                                      schrieb am zuletzt editiert von benziman
                                      #171
                                      @altersrentner said in [[ Geklärt ] Problem bei Influx Installation](/post
                                      Hi, ich muss den Post mal aufnehmen da ich an dieser Stelle mit der DB scheitere!
                                      > show databases
                                      name
                                      _internal
                                      iobroker
                                      > use iobroker
                                      Da mein Startwert für meinen Wasserverbrauch in Grafana viel zu hoch ist, wollte ich diesen einen Wert aus der InfluxDB löschen. Allerdings bekomme ich bei show databases nur:
                                      ERR: unable to parse authentication credentials
                                      und wenn ich die Datenbank auswähle die ich ja erstellt habe und die auch Daten für Grafana bereitstellt erahtle ich:
                                      DB does not exist!
                                      jemand eine Idee was ich falsch mache?
                                      • B benziman
                                        > show databases
                                        name
                                        _internal
                                        iobroker
                                        > use iobroker
                                        DB does not exist!
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #172
                                        @benziman welche Version?
                                        Was wo und wie gibst du denn ein?
                                          benziman
                                          #173
                                          @crunchip
                                          ich bin auf der VM wo influx isntalliert ist und gebe dort influx ein, danach show database oder use iobroker (die DB wird aktuell von Grafana abgefragt)
