  4. BLE Adapter beleibt gelb
123 Beiträge 6 Kommentatoren 21.9k Aufrufe 5 Beobachtet
  • S SmartVerwalter
    ble adapter bleibt unverändert gelb
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @smartverwalter
    cat /boot/config.txt | grep -i disable
    systemctl status hciuart.service
    dmesg -T
    • S
      S
      SmartVerwalter
      ups da kommt jetzt ne Menge
      pi@raspberrypi:~ $ cat /boot/config.txt | grep -i disable
      #disable_overscan=1
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ systemctl status hciuart.servie
      Unit hciuart.servie.service could not be found.
      pi@raspberrypi:~ $ dmesg -T
      [Sun Mar  7 16:23:44 2021] Booting Linux on physical CPU 0x0
      [Sun Mar  7 16:23:44 2021] Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:29:51 GMT 2021
      [Sun Mar  7 16:23:44 2021] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
      [Sun Mar  7 16:23:44 2021] CPU: div instructions available: patching division code
      [Sun Mar  7 16:23:44 2021] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [Sun Mar  7 16:23:44 2021] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
      [Sun Mar  7 16:23:44 2021] Memory policy: Data cache writealloc
      [Sun Mar  7 16:23:44 2021] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
      [Sun Mar  7 16:23:44 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [Sun Mar  7 16:23:44 2021] Zone ranges:
      [Sun Mar  7 16:23:44 2021]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
      [Sun Mar  7 16:23:44 2021]   Normal   empty
      [Sun Mar  7 16:23:44 2021] Movable zone start for each node
      [Sun Mar  7 16:23:44 2021] Early memory node ranges
      [Sun Mar  7 16:23:44 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      [Sun Mar  7 16:23:44 2021] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
      [Sun Mar  7 16:23:44 2021] On node 0 totalpages: 242688
      [Sun Mar  7 16:23:44 2021]   DMA zone: 2133 pages used for memmap
      [Sun Mar  7 16:23:44 2021]   DMA zone: 0 pages reserved
      [Sun Mar  7 16:23:44 2021]   DMA zone: 242688 pages, LIFO batch:63
      [Sun Mar  7 16:23:44 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
      [Sun Mar  7 16:23:44 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
      [Sun Mar  7 16:23:44 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [Sun Mar  7 16:23:44 2021] Built 1 zonelists, mobility grouping on.  Total pages: 240555
      [Sun Mar  7 16:23:44 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=daa6e722-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Sun Mar  7 16:23:44 2021] Kernel parameter elevator= does not have any effect anymore.
                                 Please use sysfs to set IO scheduler for individual devices.
      [Sun Mar  7 16:23:44 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [Sun Mar  7 16:23:44 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [Sun Mar  7 16:23:44 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
      [Sun Mar  7 16:23:44 2021] Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
      [Sun Mar  7 16:23:44 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [Sun Mar  7 16:23:44 2021] ftrace: allocating 31910 entries in 63 pages
      [Sun Mar  7 16:23:44 2021] ftrace: allocated 63 pages with 6 groups
      [Sun Mar  7 16:23:44 2021] rcu: Hierarchical RCU implementation.
      [Sun Mar  7 16:23:44 2021]      Rude variant of Tasks RCU enabled.
      [Sun Mar  7 16:23:44 2021]      Tracing variant of Tasks RCU enabled.
      [Sun Mar  7 16:23:44 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [Sun Mar  7 16:23:44 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [Sun Mar  7 16:23:44 2021] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
      [Sun Mar  7 16:23:44 2021] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
      [Sun Mar  7 16:23:44 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
      [Sun Mar  7 16:23:44 2021] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
      [Sun Mar  7 16:23:44 2021] Switching to timer-based delay loop, resolution 52ns
      [Sun Mar  7 16:23:44 2021] Console: colour dummy device 80x30
      [Sun Mar  7 16:23:44 2021] printk: console [tty1] enabled
      [Sun Mar  7 16:23:44 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
      [Sun Mar  7 16:23:44 2021] pid_max: default: 32768 minimum: 301
      [Sun Mar  7 16:23:44 2021] LSM: Security Framework initializing
      [Sun Mar  7 16:23:44 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [Sun Mar  7 16:23:44 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [Sun Mar  7 16:23:44 2021] Disabling memory control group subsystem
      [Sun Mar  7 16:23:44 2021] CPU: Testing write buffer coherency: ok
      [Sun Mar  7 16:23:44 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [Sun Mar  7 16:23:44 2021] Setting up static identity map for 0x100000 - 0x10003c
      [Sun Mar  7 16:23:44 2021] rcu: Hierarchical SRCU implementation.
      [Sun Mar  7 16:23:44 2021] smp: Bringing up secondary CPUs ...
      [Sun Mar  7 16:23:44 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [Sun Mar  7 16:23:44 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [Sun Mar  7 16:23:44 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [Sun Mar  7 16:23:44 2021] smp: Brought up 1 node, 4 CPUs
      [Sun Mar  7 16:23:44 2021] SMP: Total of 4 processors activated (153.60 BogoMIPS).
      [Sun Mar  7 16:23:44 2021] CPU: All CPU(s) started in HYP mode.
      [Sun Mar  7 16:23:44 2021] CPU: Virtualization extensions available.
      [Sun Mar  7 16:23:44 2021] devtmpfs: initialized
      [Sun Mar  7 16:23:44 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
      [Sun Mar  7 16:23:44 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [Sun Mar  7 16:23:44 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [Sun Mar  7 16:23:44 2021] pinctrl core: initialized pinctrl subsystem
      [Sun Mar  7 16:23:44 2021] NET: Registered protocol family 16
      [Sun Mar  7 16:23:44 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [Sun Mar  7 16:23:44 2021] audit: initializing netlink subsys (disabled)
      [Sun Mar  7 16:23:44 2021] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
      [Sun Mar  7 16:23:44 2021] thermal_sys: Registered thermal governor 'step_wise'
      [Sun Mar  7 16:23:44 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [Sun Mar  7 16:23:44 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [Sun Mar  7 16:23:44 2021] Serial: AMBA PL011 UART driver
      [Sun Mar  7 16:23:44 2021] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
      [Sun Mar  7 16:23:44 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:12:09, variant start
      [Sun Mar  7 16:23:44 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
      [Sun Mar  7 16:23:44 2021] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
      [Sun Mar  7 16:23:44 2021] SCSI subsystem initialized
      [Sun Mar  7 16:23:44 2021] usbcore: registered new interface driver usbfs
      [Sun Mar  7 16:23:44 2021] usbcore: registered new interface driver hub
      [Sun Mar  7 16:23:44 2021] usbcore: registered new device driver usb
      [Sun Mar  7 16:23:44 2021] clocksource: Switched to clocksource arch_sys_counter
      [Sun Mar  7 16:23:45 2021] VFS: Disk quotas dquot_6.6.0
      [Sun Mar  7 16:23:45 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [Sun Mar  7 16:23:45 2021] FS-Cache: Loaded
      [Sun Mar  7 16:23:45 2021] CacheFiles: Loaded
      [Sun Mar  7 16:23:45 2021] NET: Registered protocol family 2
      [Sun Mar  7 16:23:45 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [Sun Mar  7 16:23:45 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [Sun Mar  7 16:23:45 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [Sun Mar  7 16:23:45 2021] TCP: Hash tables configured (established 8192 bind 8192)
      [Sun Mar  7 16:23:45 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [Sun Mar  7 16:23:45 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [Sun Mar  7 16:23:45 2021] NET: Registered protocol family 1
      [Sun Mar  7 16:23:45 2021] RPC: Registered named UNIX socket transport module.
      [Sun Mar  7 16:23:45 2021] RPC: Registered udp transport module.
      [Sun Mar  7 16:23:45 2021] RPC: Registered tcp transport module.
      [Sun Mar  7 16:23:45 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [Sun Mar  7 16:23:45 2021] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
      [Sun Mar  7 16:23:45 2021] Initialise system trusted keyrings
      [Sun Mar  7 16:23:45 2021] workingset: timestamp_bits=14 max_order=18 bucket_order=4
      [Sun Mar  7 16:23:45 2021] zbud: loaded
      [Sun Mar  7 16:23:45 2021] FS-Cache: Netfs 'nfs' registered for caching
      [Sun Mar  7 16:23:45 2021] NFS: Registering the id_resolver key type
      [Sun Mar  7 16:23:45 2021] Key type id_resolver registered
      [Sun Mar  7 16:23:45 2021] Key type id_legacy registered
      [Sun Mar  7 16:23:45 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [Sun Mar  7 16:23:45 2021] Key type asymmetric registered
      [Sun Mar  7 16:23:45 2021] Asymmetric key parser 'x509' registered
      [Sun Mar  7 16:23:45 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [Sun Mar  7 16:23:45 2021] io scheduler mq-deadline registered
      [Sun Mar  7 16:23:45 2021] io scheduler kyber registered
      [Sun Mar  7 16:23:45 2021] bcm2708_fb soc:fb: FB found 1 display(s)
      [Sun Mar  7 16:23:45 2021] Console: switching to colour frame buffer device 82x26
      [Sun Mar  7 16:23:45 2021] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
      [Sun Mar  7 16:23:45 2021] bcm2835-rng 3f104000.rng: hwrng registered
      [Sun Mar  7 16:23:45 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [Sun Mar  7 16:23:45 2021] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
      [Sun Mar  7 16:23:46 2021] brd: module loaded
      [Sun Mar  7 16:23:46 2021] loop: module loaded
      [Sun Mar  7 16:23:46 2021] Loading iSCSI transport class v2.0-870.
      [Sun Mar  7 16:23:46 2021] libphy: Fixed MDIO Bus: probed
      [Sun Mar  7 16:23:46 2021] usbcore: registered new interface driver lan78xx
      [Sun Mar  7 16:23:46 2021] usbcore: registered new interface driver smsc95xx
      [Sun Mar  7 16:23:46 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [Sun Mar  7 16:23:46 2021] Core Release: 2.80a
      [Sun Mar  7 16:23:46 2021] Setting default values for core params
      [Sun Mar  7 16:23:46 2021] Finished setting default values for core params
      [Sun Mar  7 16:23:46 2021] Using Buffer DMA mode
      [Sun Mar  7 16:23:46 2021] Periodic Transfer Interrupt Enhancement - disabled
      [Sun Mar  7 16:23:46 2021] Multiprocessor Interrupt Enhancement - disabled
      [Sun Mar  7 16:23:46 2021] OTG VER PARAM: 0, OTG VER FLAG: 0
      [Sun Mar  7 16:23:46 2021] Dedicated Tx FIFOs mode
      [Sun Mar  7 16:23:46 2021] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
      [Sun Mar  7 16:23:47 2021] FIQ FSM acceleration enabled for :
                                 Non-periodic Split Transactions
                                 Periodic Split Transactions
                                 High-Speed Isochronous Endpoints
                                 Interrupt/Control Split Transaction hack enabled
      [Sun Mar  7 16:23:47 2021] dwc_otg: Microframe scheduler enabled
      [Sun Mar  7 16:23:47 2021] WARN::hcd_init_fiq:457: FIQ on core 1
      [Sun Mar  7 16:23:47 2021] WARN::hcd_init_fiq:458: FIQ ASM at 807be568 length 36
      [Sun Mar  7 16:23:47 2021] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
      [Sun Mar  7 16:23:47 2021] dwc_otg 3f980000.usb: DWC OTG Controller
      [Sun Mar  7 16:23:47 2021] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
      [Sun Mar  7 16:23:47 2021] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
      [Sun Mar  7 16:23:47 2021] Init: Port Power? op_state=1
      [Sun Mar  7 16:23:47 2021] Init: Power Port (0)
      [Sun Mar  7 16:23:47 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
      [Sun Mar  7 16:23:47 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [Sun Mar  7 16:23:47 2021] usb usb1: Product: DWC OTG Controller
      [Sun Mar  7 16:23:47 2021] usb usb1: Manufacturer: Linux 5.10.17-v7+ dwc_otg_hcd
      [Sun Mar  7 16:23:47 2021] usb usb1: SerialNumber: 3f980000.usb
      [Sun Mar  7 16:23:47 2021] hub 1-0:1.0: USB hub found
      [Sun Mar  7 16:23:47 2021] hub 1-0:1.0: 1 port detected
      [Sun Mar  7 16:23:47 2021] dwc_otg: FIQ enabled
      [Sun Mar  7 16:23:47 2021] dwc_otg: NAK holdoff enabled
      [Sun Mar  7 16:23:47 2021] dwc_otg: FIQ split-transaction FSM enabled
      [Sun Mar  7 16:23:47 2021] Module dwc_common_port init
      [Sun Mar  7 16:23:47 2021] usbcore: registered new interface driver usb-storage
      [Sun Mar  7 16:23:47 2021] mousedev: PS/2 mouse device common for all mice
      [Sun Mar  7 16:23:47 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [Sun Mar  7 16:23:47 2021] sdhci: Secure Digital Host Controller Interface driver
      [Sun Mar  7 16:23:47 2021] sdhci: Copyright(c) Pierre Ossman
      [Sun Mar  7 16:23:47 2021] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
      [Sun Mar  7 16:23:47 2021] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
      [Sun Mar  7 16:23:47 2021] sdhci-pltfm: SDHCI platform and OF driver helper
      [Sun Mar  7 16:23:47 2021] ledtrig-cpu: registered to indicate activity on CPUs
      [Sun Mar  7 16:23:47 2021] hid: raw HID events driver (C) Jiri Kosina
      [Sun Mar  7 16:23:47 2021] usbcore: registered new interface driver usbhid
      [Sun Mar  7 16:23:47 2021] usbhid: USB HID core driver
      [Sun Mar  7 16:23:47 2021] Initializing XFRM netlink socket
      [Sun Mar  7 16:23:47 2021] NET: Registered protocol family 17
      [Sun Mar  7 16:23:47 2021] Key type dns_resolver registered
      [Sun Mar  7 16:23:47 2021] Registering SWP/SWPB emulation handler
      [Sun Mar  7 16:23:47 2021] registered taskstats version 1
      [Sun Mar  7 16:23:47 2021] Loading compiled-in X.509 certificates
      [Sun Mar  7 16:23:47 2021] Key type ._fscrypt registered
      [Sun Mar  7 16:23:47 2021] Key type .fscrypt registered
      [Sun Mar  7 16:23:47 2021] Key type fscrypt-provisioning registered
      [Sun Mar  7 16:23:47 2021] uart-pl011 3f201000.serial: cts_event_workaround enabled
      [Sun Mar  7 16:23:47 2021] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
      [Sun Mar  7 16:23:47 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [Sun Mar  7 16:23:47 2021] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [Sun Mar  7 16:23:47 2021] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
      [Sun Mar  7 16:23:47 2021] sdhost: log_buf @ (ptrval) (f7513000)
      [Sun Mar  7 16:23:47 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [Sun Mar  7 16:23:47 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [Sun Mar  7 16:23:47 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [Sun Mar  7 16:23:47 2021] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
      [Sun Mar  7 16:23:47 2021] of_cfs_init
      [Sun Mar  7 16:23:47 2021] of_cfs_init: OK
      [Sun Mar  7 16:23:47 2021] Waiting for root device PARTUUID=daa6e722-02...
      [Sun Mar  7 16:23:47 2021] Indeed it is in host mode hprt0 = 00021501
      [Sun Mar  7 16:23:47 2021] random: fast init done
      [Sun Mar  7 16:23:47 2021] mmc0: host does not support reading read-only switch, assuming write-enable
      [Sun Mar  7 16:23:47 2021] mmc1: new high speed SDIO card at address 0001
      [Sun Mar  7 16:23:47 2021] mmc0: new high speed SDHC card at address aaaa
      [Sun Mar  7 16:23:47 2021] mmcblk0: mmc0:aaaa SB32G 29.7 GiB
      [Sun Mar  7 16:23:47 2021]  mmcblk0: p1 p2
      [Sun Mar  7 16:23:47 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Mar  7 16:23:47 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Mar  7 16:23:47 2021] devtmpfs: mounted
      [Sun Mar  7 16:23:47 2021] Freeing unused kernel memory: 1024K
      [Sun Mar  7 16:23:47 2021] usb 1-1: new high-speed USB device number 2 using dwc_otg
      [Sun Mar  7 16:23:47 2021] Indeed it is in host mode hprt0 = 00001101
      [Sun Mar  7 16:23:47 2021] Run /sbin/init as init process
      [Sun Mar  7 16:23:47 2021]   with arguments:
      [Sun Mar  7 16:23:47 2021]     /sbin/init
      [Sun Mar  7 16:23:47 2021]   with environment:
      [Sun Mar  7 16:23:47 2021]     HOME=/
      [Sun Mar  7 16:23:47 2021]     TERM=linux
      [Sun Mar  7 16:23:47 2021] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
      [Sun Mar  7 16:23:47 2021] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [Sun Mar  7 16:23:47 2021] hub 1-1:1.0: USB hub found
      [Sun Mar  7 16:23:47 2021] hub 1-1:1.0: 4 ports detected
      [Sun Mar  7 16:23:48 2021] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
      [Sun Mar  7 16:23:48 2021] systemd[1]: System time before build time, advancing clock.
      [Sun Mar  7 16:23:48 2021] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
      [Sun Mar  7 16:23:48 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [Sun Mar  7 16:23:48 2021] hub 1-1.1:1.0: USB hub found
      [Sun Mar  7 16:23:48 2021] hub 1-1.1:1.0: 3 ports detected
      [Sun Mar  7 16:23:48 2021] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
      [Sun Mar  7 16:23:48 2021] NET: Registered protocol family 10
      [Sun Mar  7 16:23:48 2021] Segment Routing with IPv6
      [Sun Mar  7 16:23:48 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [Sun Mar  7 16:23:48 2021] systemd[1]: Detected architecture arm.
      [Sun Mar  7 16:23:48 2021] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
      [Sun Mar  7 16:23:48 2021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [Sun Mar  7 16:23:48 2021] usb 1-1.2: Product: ConBee II
      [Sun Mar  7 16:23:48 2021] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
      [Sun Mar  7 16:23:48 2021] usb 1-1.2: SerialNumber: DE2413713
      [Sun Mar  7 16:23:48 2021] systemd[1]: Set hostname to <raspberrypi>.
      [Sun Mar  7 16:23:48 2021] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
      [Sun Mar  7 16:23:49 2021] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
      [Sun Mar  7 16:23:49 2021] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [Sun Mar  7 16:23:49 2021] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
      [Sun Mar  7 16:23:49 2021] libphy: lan78xx-mdiobus: probed
      [Sun Mar  7 16:23:49 2021] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
      [Sun Mar  7 16:23:49 2021] random: systemd: uninitialized urandom read (16 bytes read)
      [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on Journal Socket (/dev/log).
      [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
      [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on Journal Audit Socket.
      [Sun Mar  7 16:23:49 2021] systemd[1]: Created slice system-getty.slice.
      [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on udev Control Socket.
      [Sun Mar  7 16:23:49 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on Journal Socket.
      [Sun Mar  7 16:23:50 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [Sun Mar  7 16:23:50 2021] systemd-journald[126]: Received request to flush runtime journal from PID 1
      [Sun Mar  7 16:23:51 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [Sun Mar  7 16:23:51 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [Sun Mar  7 16:23:51 2021] [vc_sm_connected_init]: start
      [Sun Mar  7 16:23:51 2021] [vc_sm_connected_init]: installed successfully
      [Sun Mar  7 16:23:51 2021] mc: Linux media interface: v0.10
      [Sun Mar  7 16:23:51 2021] videodev: Linux video capture interface: v2.00
      [Sun Mar  7 16:23:51 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [Sun Mar  7 16:23:51 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
      [Sun Mar  7 16:23:51 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [Sun Mar  7 16:23:51 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [Sun Mar  7 16:23:51 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [Sun Mar  7 16:23:51 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [Sun Mar  7 16:23:51 2021] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
      [Sun Mar  7 16:23:51 2021] usbcore: registered new interface driver cdc_acm
      [Sun Mar  7 16:23:51 2021] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [Sun Mar  7 16:23:51 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [Sun Mar  7 16:23:51 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [Sun Mar  7 16:23:51 2021] usb 1-1.2: USB disconnect, device number 4
      [Sun Mar  7 16:23:51 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
      [Sun Mar  7 16:23:51 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [Sun Mar  7 16:23:51 2021] usbcore: registered new interface driver brcmfmac
      [Sun Mar  7 16:23:51 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
      [Sun Mar  7 16:23:52 2021] usb 1-1.2: new full-speed USB device number 6 using dwc_otg
      [Sun Mar  7 16:23:52 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [Sun Mar  7 16:23:52 2021] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
      [Sun Mar  7 16:23:52 2021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [Sun Mar  7 16:23:52 2021] usb 1-1.2: Product: ConBee II
      [Sun Mar  7 16:23:52 2021] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
      [Sun Mar  7 16:23:52 2021] usb 1-1.2: SerialNumber: DE2413713
      [Sun Mar  7 16:23:52 2021] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
      [Sun Mar  7 16:23:52 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
      [Sun Mar  7 16:23:54 2021] random: crng init done
      [Sun Mar  7 16:23:54 2021] random: 7 urandom warning(s) missed due to ratelimiting
      [Sun Mar  7 16:23:54 2021] uart-pl011 3f201000.serial: no DMA platform data
      [Sun Mar  7 16:23:54 2021] 8021q: 802.1Q VLAN Support v1.8
      [Sun Mar  7 16:23:54 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [Sun Mar  7 16:23:54 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      [Sun Mar  7 16:23:55 2021] 8021q: adding VLAN 0 to HW filter on device eth0
      [Sun Mar  7 16:23:55 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [Sun Mar  7 16:23:55 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:23:56 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
      [Sun Mar  7 16:25:42 2021] Bluetooth: Core ver 2.22
      [Sun Mar  7 16:25:42 2021] NET: Registered protocol family 31
      [Sun Mar  7 16:25:42 2021] Bluetooth: HCI device and connection manager initialized
      [Sun Mar  7 16:25:42 2021] Bluetooth: HCI socket layer initialized
      [Sun Mar  7 16:25:42 2021] Bluetooth: L2CAP socket layer initialized
      [Sun Mar  7 16:25:42 2021] Bluetooth: SCO socket layer initialized
      [Sun Mar  7 16:27:52 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:27:54 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:40:46 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:40:48 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:41:32 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:41:34 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:41:46 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:41:48 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:46:37 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:46:39 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:50:47 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:50:49 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:53:32 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [Sun Mar  7 16:53:32 2021] Bluetooth: BNEP filters: protocol multicast
      [Sun Mar  7 16:53:32 2021] Bluetooth: BNEP socket layer initialized
      [Sun Mar  7 16:56:55 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:56:57 2021] Under-voltage detected! (0x00050005)
      [Sun Mar  7 16:58:45 2021] Voltage normalised (0x00000000)
      [Sun Mar  7 16:58:48 2021] Under-voltage detected! (0x00050005)
      pi@raspberrypi:~ $
      • S SmartVerwalter
        #disable_overscan=1
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $
        wendy2702W
        wendy2702W
        @smartverwalter Als erstes mal für eine gescheite Stromversorgung sorgen.
        Was hängt per USB an dem PI ?
        • S
          S
          SmartVerwalter
          dekonz zigbee adapter
          • S SmartVerwalter
            wendy2702W
            wendy2702W
            @smartverwalter Und womit wird der PI mit Spannung versorgt ?
            • S
              S
              SmartVerwalter
              #66
              huawaysuper charge usb
              hw-050450E00
              • S SmartVerwalter
                hw-050450E00
                wendy2702W
                wendy2702W
                #67
                @smartverwalter sagte in BLE Adapter beleibt gelb:
                hw-050450E00
                Das ist ein Ladegerät und keine Spannungsversorgung.
                Besorge dir ein zum PI passendes Netzteil damit die "undervoltage" meldungen erstmal verschwinden.
                • S
                  S
                  SmartVerwalter
                  #68
                  habe das originale bei Reichelt gekauft, leider haben die mir die englische Version geliefert
                  • wendy2702W wendy2702
                    hw-050450E00
                    J
                    J
                    Jan1
                    #69
                    @wendy2702
                    Das erklärt auch warum das BT Device beim Reboot nicht automatisch startet, dem fehlt in dem Moment einfach der Saft.
                    • S SmartVerwalter
                      wendy2702W
                      wendy2702W
                      #70
                      Umtauschen und/oder einfach ein neues bei anderer Quelle bestellen.
                      Eine vernünftige Spannungsversorgung ist wichtig damit das System und alle HW Komponenten verbünftig laufen.
                      • S
                        S
                        SmartVerwalter
                        #71
                        habe ihn jetzt mal an eine USB Steckdose angeschlossen
                        #disable_overscan=1
                        pi@raspberrypi:~ $ systemctl status hciuart.service
                        ● hciuart.service - Configure Bluetooth Modems connected by UART
                           Loaded: loaded (/lib/systemd/system/hciuart.service; enabled; vendor preset:
                           Active: failed (Result: exit-code) since Sun 2021-03-07 17:20:59 CET; 25min a
                          Process: 328 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
                        Mar 07 17:20:59 raspberrypi btuart[328]: Failed to set bdaddr, command failure
                        Mar 07 17:20:59 raspberrypi btuart[328]: Failed to update baudrate, invalid HCI
                        Mar 07 17:20:59 raspberrypi btuart[328]: Can't initialize device: Success
                        Mar 07 17:20:59 raspberrypi btuart[328]: bcm43xx_init
                        Mar 07 17:20:59 raspberrypi btuart[328]: Flash firmware /lib/firmware/brcm/BCM43
                        Mar 07 17:20:59 raspberrypi btuart[328]: Set BDADDR UART: b8:27:eb:33:de:ec
                        Mar 07 17:20:59 raspberrypi btuart[328]: Set Controller UART speed to 3000000 bi
                        Mar 07 17:20:59 raspberrypi systemd[1]: hciuart.service: Control process exited,
                        Mar 07 17:20:59 raspberrypi systemd[1]: hciuart.service: Failed with result 'exi
                        Mar 07 17:20:59 raspberrypi systemd[1]: Failed to start Configure Bluetooth Mode
                        lines 1-15/15 (END)
                        • S SmartVerwalter
                          #disable_overscan=1
                          lines 1-15/15 (END)
                          wendy2702W
                          wendy2702W
                          #72
                          @smartverwalter Leider ist da was abgeschnitten.
                          Die Ausgabe von
                          dmesg -T
                          wäre auch wieder interessant.
                          Achso... was für eine Steckdose? Die liefern meistens maximal bis 1,8Ampere wenn man Glück hat.
                          • S
                            S
                            SmartVerwalter
                            #73
                            steckdose macht 5 Volt, 2,4 ampere
                            ist die Zigbee Dreifachsteckdose Sylvercrest von lidl
                            • S SmartVerwalter
                              wendy2702W
                              wendy2702W
                              #74
                              @smartverwalter Kenne ich nicht das Teil.
                              Keine Ahnung wie Stabil und sauber es die Spannung hält.
                              Was hast du eigentlich für einen PI? Sorry falls ich das überlesen habe,
                              • S
                                S
                                SmartVerwalter
                                #75
                                pi@raspberrypi:~ $ dmesg -t
                                Zone ranges:
                                  Normal   empty
                                FS-Cache: Loaded
                                CacheFiles: Loaded
                                zbud: loaded
                                brd: module loaded
                                loop: module loaded
                                Core Release: 2.80a
                                of_cfs_init
                                of_cfs_init: OK
                                 mmcblk0: p1 p2
                                EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                                EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                EXT4-fs (mmcblk0p2): recovery complete
                                devtmpfs: mounted
                                  with arguments:
                                    /sbin/init
                                  with environment:
                                    HOME=/
                                    TERM=linux
                                systemd[1]: Reached target Swap.
                                systemd[1]: Listening on udev Kernel Socket.
                                systemd[1]: Listening on initctl Compatibility Named Pipe.
                                systemd[1]: Starting Set the console keyboard layout...
                                systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                                systemd-journald[121]: Received request to flush runtime journal from PID 1
                                pi@raspberrypi:~ $
                                • S SmartVerwalter
                                  Zone ranges:
                                    Normal   empty
                                  FS-Cache: Loaded
                                  CacheFiles: Loaded
                                  zbud: loaded
                                  brd: module loaded
                                  loop: module loaded
                                  Core Release: 2.80a
                                  of_cfs_init
                                  of_cfs_init: OK
                                   mmcblk0: p1 p2
                                  devtmpfs: mounted
                                    with arguments:
                                      /sbin/init
                                    with environment:
                                      HOME=/
                                      TERM=linux
                                  pi@raspberrypi:~ $
                                  wendy2702W
                                  wendy2702W
                                  #76
                                  @smartverwalter
                                  systemctl status bluetooth
                                  • S
                                    S
                                    SmartVerwalter
                                    #77
                                    ● bluetooth.service - Bluetooth service
                                       Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
                                       Active: inactive (dead)
                                         Docs: man:bluetoothd(8)
                                    ...skipping...
                                    • S
                                      S
                                      SmartVerwalter
                                      #78
                                      @wendy2702 said in BLE Adapter beleibt gelb:
                                      pi@raspberrypi:~ $
                                         Active: failed (Result: exit-code) since Sun 2021-03-07 17:20:59 CET; 57min a
                                      lines 1-15/15 (END)
                                      • S SmartVerwalter
                                        pi@raspberrypi:~ $
                                        lines 1-15/15 (END)
                                        wendy2702W
                                        wendy2702W
                                        #79
                                        @smartverwalter Leider ist rechts das Log abgeschnitten.
                                        sudo systemctl start bluetooth
                                        sudo systemctl status bluetooth
                                        sudo systemctl status hciuart
                                        • S
                                          S
                                          SmartVerwalter
                                          #80
                                          upps
                                          hatte die letze Nachricht gar nicht mehr gesehen.
                                          Jetzt hab ich glaub ich noch grösseren Mist gebaut.
                                          Habe für ein zweites Projekt noch einen pi gekauft,
                                          eigentlich identisch.
                                          Seitdem ich die SD Karte mal in den anderen PI getan habe
                                          läßt sich Io Broker nicht mehr über html starten.
                                          In beiden PI s nicht.
                                          Die Karte scheint aber okay zu sein, auf die Dekonz Adapter sSoftware
                                          kann ich zugreifen.
                                          84.1k
