  4. BLE Adapter beleibt gelb
    6.4k
123 Beiträge 6 Kommentatoren 18.0k Aufrufe 5 Beobachtet
    SmartVerwalter
    ble adapter bleibt unverändert gelb
    • S SmartVerwalter
      @smartverwalter
      cat /boot/config.txt | grep -i disable
      systemctl status hciuart.service
      dmesg -T
        SmartVerwalter
        ups da kommt jetzt ne Menge
        pi@raspberrypi:~ $ cat /boot/config.txt | grep -i disable
        #disable_overscan=1
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ systemctl status hciuart.servie
        Unit hciuart.servie.service could not be found.
        pi@raspberrypi:~ $ dmesg -T
        [Sun Mar  7 16:23:44 2021] Booting Linux on physical CPU 0x0
        [Sun Mar  7 16:23:44 2021] Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:29:51 GMT 2021
        [Sun Mar  7 16:23:44 2021] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
        [Sun Mar  7 16:23:44 2021] CPU: div instructions available: patching division code
        [Sun Mar  7 16:23:44 2021] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
        [Sun Mar  7 16:23:44 2021] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
        [Sun Mar  7 16:23:44 2021] Memory policy: Data cache writealloc
        [Sun Mar  7 16:23:44 2021] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
        [Sun Mar  7 16:23:44 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [Sun Mar  7 16:23:44 2021] Zone ranges:
        [Sun Mar  7 16:23:44 2021]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
        [Sun Mar  7 16:23:44 2021]   Normal   empty
        [Sun Mar  7 16:23:44 2021] Movable zone start for each node
        [Sun Mar  7 16:23:44 2021] Early memory node ranges
        [Sun Mar  7 16:23:44 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
        [Sun Mar  7 16:23:44 2021] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
        [Sun Mar  7 16:23:44 2021] On node 0 totalpages: 242688
        [Sun Mar  7 16:23:44 2021]   DMA zone: 2133 pages used for memmap
        [Sun Mar  7 16:23:44 2021]   DMA zone: 0 pages reserved
        [Sun Mar  7 16:23:44 2021]   DMA zone: 242688 pages, LIFO batch:63
        [Sun Mar  7 16:23:44 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
        [Sun Mar  7 16:23:44 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
        [Sun Mar  7 16:23:44 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [Sun Mar  7 16:23:44 2021] Built 1 zonelists, mobility grouping on.  Total pages: 240555
        [Sun Mar  7 16:23:44 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=daa6e722-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Sun Mar  7 16:23:44 2021] Kernel parameter elevator= does not have any effect anymore.
                                   Please use sysfs to set IO scheduler for individual devices.
        [Sun Mar  7 16:23:44 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [Sun Mar  7 16:23:44 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [Sun Mar  7 16:23:44 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
        [Sun Mar  7 16:23:44 2021] Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
        [Sun Mar  7 16:23:44 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [Sun Mar  7 16:23:44 2021] ftrace: allocating 31910 entries in 63 pages
        [Sun Mar  7 16:23:44 2021] ftrace: allocated 63 pages with 6 groups
        [Sun Mar  7 16:23:44 2021] rcu: Hierarchical RCU implementation.
        [Sun Mar  7 16:23:44 2021]      Rude variant of Tasks RCU enabled.
        [Sun Mar  7 16:23:44 2021]      Tracing variant of Tasks RCU enabled.
        [Sun Mar  7 16:23:44 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [Sun Mar  7 16:23:44 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [Sun Mar  7 16:23:44 2021] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
        [Sun Mar  7 16:23:44 2021] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
        [Sun Mar  7 16:23:44 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
        [Sun Mar  7 16:23:44 2021] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
        [Sun Mar  7 16:23:44 2021] Switching to timer-based delay loop, resolution 52ns
        [Sun Mar  7 16:23:44 2021] Console: colour dummy device 80x30
        [Sun Mar  7 16:23:44 2021] printk: console [tty1] enabled
        [Sun Mar  7 16:23:44 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
        [Sun Mar  7 16:23:44 2021] pid_max: default: 32768 minimum: 301
        [Sun Mar  7 16:23:44 2021] LSM: Security Framework initializing
        [Sun Mar  7 16:23:44 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [Sun Mar  7 16:23:44 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [Sun Mar  7 16:23:44 2021] Disabling memory control group subsystem
        [Sun Mar  7 16:23:44 2021] CPU: Testing write buffer coherency: ok
        [Sun Mar  7 16:23:44 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [Sun Mar  7 16:23:44 2021] Setting up static identity map for 0x100000 - 0x10003c
        [Sun Mar  7 16:23:44 2021] rcu: Hierarchical SRCU implementation.
        [Sun Mar  7 16:23:44 2021] smp: Bringing up secondary CPUs ...
        [Sun Mar  7 16:23:44 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [Sun Mar  7 16:23:44 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [Sun Mar  7 16:23:44 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [Sun Mar  7 16:23:44 2021] smp: Brought up 1 node, 4 CPUs
        [Sun Mar  7 16:23:44 2021] SMP: Total of 4 processors activated (153.60 BogoMIPS).
        [Sun Mar  7 16:23:44 2021] CPU: All CPU(s) started in HYP mode.
        [Sun Mar  7 16:23:44 2021] CPU: Virtualization extensions available.
        [Sun Mar  7 16:23:44 2021] devtmpfs: initialized
        [Sun Mar  7 16:23:44 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
        [Sun Mar  7 16:23:44 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [Sun Mar  7 16:23:44 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [Sun Mar  7 16:23:44 2021] pinctrl core: initialized pinctrl subsystem
        [Sun Mar  7 16:23:44 2021] NET: Registered protocol family 16
        [Sun Mar  7 16:23:44 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [Sun Mar  7 16:23:44 2021] audit: initializing netlink subsys (disabled)
        [Sun Mar  7 16:23:44 2021] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
        [Sun Mar  7 16:23:44 2021] thermal_sys: Registered thermal governor 'step_wise'
        [Sun Mar  7 16:23:44 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [Sun Mar  7 16:23:44 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [Sun Mar  7 16:23:44 2021] Serial: AMBA PL011 UART driver
        [Sun Mar  7 16:23:44 2021] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
        [Sun Mar  7 16:23:44 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:12:09, variant start
        [Sun Mar  7 16:23:44 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
        [Sun Mar  7 16:23:44 2021] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
        [Sun Mar  7 16:23:44 2021] SCSI subsystem initialized
        [Sun Mar  7 16:23:44 2021] usbcore: registered new interface driver usbfs
        [Sun Mar  7 16:23:44 2021] usbcore: registered new interface driver hub
        [Sun Mar  7 16:23:44 2021] usbcore: registered new device driver usb
        [Sun Mar  7 16:23:44 2021] clocksource: Switched to clocksource arch_sys_counter
        [Sun Mar  7 16:23:45 2021] VFS: Disk quotas dquot_6.6.0
        [Sun Mar  7 16:23:45 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [Sun Mar  7 16:23:45 2021] FS-Cache: Loaded
        [Sun Mar  7 16:23:45 2021] CacheFiles: Loaded
        [Sun Mar  7 16:23:45 2021] NET: Registered protocol family 2
        [Sun Mar  7 16:23:45 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [Sun Mar  7 16:23:45 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [Sun Mar  7 16:23:45 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [Sun Mar  7 16:23:45 2021] TCP: Hash tables configured (established 8192 bind 8192)
        [Sun Mar  7 16:23:45 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [Sun Mar  7 16:23:45 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [Sun Mar  7 16:23:45 2021] NET: Registered protocol family 1
        [Sun Mar  7 16:23:45 2021] RPC: Registered named UNIX socket transport module.
        [Sun Mar  7 16:23:45 2021] RPC: Registered udp transport module.
        [Sun Mar  7 16:23:45 2021] RPC: Registered tcp transport module.
        [Sun Mar  7 16:23:45 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [Sun Mar  7 16:23:45 2021] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
        [Sun Mar  7 16:23:45 2021] Initialise system trusted keyrings
        [Sun Mar  7 16:23:45 2021] workingset: timestamp_bits=14 max_order=18 bucket_order=4
        [Sun Mar  7 16:23:45 2021] zbud: loaded
        [Sun Mar  7 16:23:45 2021] FS-Cache: Netfs 'nfs' registered for caching
        [Sun Mar  7 16:23:45 2021] NFS: Registering the id_resolver key type
        [Sun Mar  7 16:23:45 2021] Key type id_resolver registered
        [Sun Mar  7 16:23:45 2021] Key type id_legacy registered
        [Sun Mar  7 16:23:45 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [Sun Mar  7 16:23:45 2021] Key type asymmetric registered
        [Sun Mar  7 16:23:45 2021] Asymmetric key parser 'x509' registered
        [Sun Mar  7 16:23:45 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [Sun Mar  7 16:23:45 2021] io scheduler mq-deadline registered
        [Sun Mar  7 16:23:45 2021] io scheduler kyber registered
        [Sun Mar  7 16:23:45 2021] bcm2708_fb soc:fb: FB found 1 display(s)
        [Sun Mar  7 16:23:45 2021] Console: switching to colour frame buffer device 82x26
        [Sun Mar  7 16:23:45 2021] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
        [Sun Mar  7 16:23:45 2021] bcm2835-rng 3f104000.rng: hwrng registered
        [Sun Mar  7 16:23:45 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
        [Sun Mar  7 16:23:45 2021] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
        [Sun Mar  7 16:23:46 2021] brd: module loaded
        [Sun Mar  7 16:23:46 2021] loop: module loaded
        [Sun Mar  7 16:23:46 2021] Loading iSCSI transport class v2.0-870.
        [Sun Mar  7 16:23:46 2021] libphy: Fixed MDIO Bus: probed
        [Sun Mar  7 16:23:46 2021] usbcore: registered new interface driver lan78xx
        [Sun Mar  7 16:23:46 2021] usbcore: registered new interface driver smsc95xx
        [Sun Mar  7 16:23:46 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [Sun Mar  7 16:23:46 2021] Core Release: 2.80a
        [Sun Mar  7 16:23:46 2021] Setting default values for core params
        [Sun Mar  7 16:23:46 2021] Finished setting default values for core params
        [Sun Mar  7 16:23:46 2021] Using Buffer DMA mode
        [Sun Mar  7 16:23:46 2021] Periodic Transfer Interrupt Enhancement - disabled
        [Sun Mar  7 16:23:46 2021] Multiprocessor Interrupt Enhancement - disabled
        [Sun Mar  7 16:23:46 2021] OTG VER PARAM: 0, OTG VER FLAG: 0
        [Sun Mar  7 16:23:46 2021] Dedicated Tx FIFOs mode
        [Sun Mar  7 16:23:46 2021] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
        [Sun Mar  7 16:23:47 2021] FIQ FSM acceleration enabled for :
                                   Non-periodic Split Transactions
                                   Periodic Split Transactions
                                   High-Speed Isochronous Endpoints
                                   Interrupt/Control Split Transaction hack enabled
        [Sun Mar  7 16:23:47 2021] dwc_otg: Microframe scheduler enabled
        [Sun Mar  7 16:23:47 2021] WARN::hcd_init_fiq:457: FIQ on core 1
        [Sun Mar  7 16:23:47 2021] WARN::hcd_init_fiq:458: FIQ ASM at 807be568 length 36
        [Sun Mar  7 16:23:47 2021] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
        [Sun Mar  7 16:23:47 2021] dwc_otg 3f980000.usb: DWC OTG Controller
        [Sun Mar  7 16:23:47 2021] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
        [Sun Mar  7 16:23:47 2021] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
        [Sun Mar  7 16:23:47 2021] Init: Port Power? op_state=1
        [Sun Mar  7 16:23:47 2021] Init: Power Port (0)
        [Sun Mar  7 16:23:47 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        [Sun Mar  7 16:23:47 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [Sun Mar  7 16:23:47 2021] usb usb1: Product: DWC OTG Controller
        [Sun Mar  7 16:23:47 2021] usb usb1: Manufacturer: Linux 5.10.17-v7+ dwc_otg_hcd
        [Sun Mar  7 16:23:47 2021] usb usb1: SerialNumber: 3f980000.usb
        [Sun Mar  7 16:23:47 2021] hub 1-0:1.0: USB hub found
        [Sun Mar  7 16:23:47 2021] hub 1-0:1.0: 1 port detected
        [Sun Mar  7 16:23:47 2021] dwc_otg: FIQ enabled
        [Sun Mar  7 16:23:47 2021] dwc_otg: NAK holdoff enabled
        [Sun Mar  7 16:23:47 2021] dwc_otg: FIQ split-transaction FSM enabled
        [Sun Mar  7 16:23:47 2021] Module dwc_common_port init
        [Sun Mar  7 16:23:47 2021] usbcore: registered new interface driver usb-storage
        [Sun Mar  7 16:23:47 2021] mousedev: PS/2 mouse device common for all mice
        [Sun Mar  7 16:23:47 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [Sun Mar  7 16:23:47 2021] sdhci: Secure Digital Host Controller Interface driver
        [Sun Mar  7 16:23:47 2021] sdhci: Copyright(c) Pierre Ossman
        [Sun Mar  7 16:23:47 2021] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
        [Sun Mar  7 16:23:47 2021] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
        [Sun Mar  7 16:23:47 2021] sdhci-pltfm: SDHCI platform and OF driver helper
        [Sun Mar  7 16:23:47 2021] ledtrig-cpu: registered to indicate activity on CPUs
        [Sun Mar  7 16:23:47 2021] hid: raw HID events driver (C) Jiri Kosina
        [Sun Mar  7 16:23:47 2021] usbcore: registered new interface driver usbhid
        [Sun Mar  7 16:23:47 2021] usbhid: USB HID core driver
        [Sun Mar  7 16:23:47 2021] Initializing XFRM netlink socket
        [Sun Mar  7 16:23:47 2021] NET: Registered protocol family 17
        [Sun Mar  7 16:23:47 2021] Key type dns_resolver registered
        [Sun Mar  7 16:23:47 2021] Registering SWP/SWPB emulation handler
        [Sun Mar  7 16:23:47 2021] registered taskstats version 1
        [Sun Mar  7 16:23:47 2021] Loading compiled-in X.509 certificates
        [Sun Mar  7 16:23:47 2021] Key type ._fscrypt registered
        [Sun Mar  7 16:23:47 2021] Key type .fscrypt registered
        [Sun Mar  7 16:23:47 2021] Key type fscrypt-provisioning registered
        [Sun Mar  7 16:23:47 2021] uart-pl011 3f201000.serial: cts_event_workaround enabled
        [Sun Mar  7 16:23:47 2021] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
        [Sun Mar  7 16:23:47 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [Sun Mar  7 16:23:47 2021] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [Sun Mar  7 16:23:47 2021] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
        [Sun Mar  7 16:23:47 2021] sdhost: log_buf @ (ptrval) (f7513000)
        [Sun Mar  7 16:23:47 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [Sun Mar  7 16:23:47 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [Sun Mar  7 16:23:47 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [Sun Mar  7 16:23:47 2021] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
        [Sun Mar  7 16:23:47 2021] of_cfs_init
        [Sun Mar  7 16:23:47 2021] of_cfs_init: OK
        [Sun Mar  7 16:23:47 2021] Waiting for root device PARTUUID=daa6e722-02...
        [Sun Mar  7 16:23:47 2021] Indeed it is in host mode hprt0 = 00021501
        [Sun Mar  7 16:23:47 2021] random: fast init done
        [Sun Mar  7 16:23:47 2021] mmc0: host does not support reading read-only switch, assuming write-enable
        [Sun Mar  7 16:23:47 2021] mmc1: new high speed SDIO card at address 0001
        [Sun Mar  7 16:23:47 2021] mmc0: new high speed SDHC card at address aaaa
        [Sun Mar  7 16:23:47 2021] mmcblk0: mmc0:aaaa SB32G 29.7 GiB
        [Sun Mar  7 16:23:47 2021]  mmcblk0: p1 p2
        [Sun Mar  7 16:23:47 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Mar  7 16:23:47 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Mar  7 16:23:47 2021] devtmpfs: mounted
        [Sun Mar  7 16:23:47 2021] Freeing unused kernel memory: 1024K
        [Sun Mar  7 16:23:47 2021] usb 1-1: new high-speed USB device number 2 using dwc_otg
        [Sun Mar  7 16:23:47 2021] Indeed it is in host mode hprt0 = 00001101
        [Sun Mar  7 16:23:47 2021] Run /sbin/init as init process
        [Sun Mar  7 16:23:47 2021]   with arguments:
        [Sun Mar  7 16:23:47 2021]     /sbin/init
        [Sun Mar  7 16:23:47 2021]   with environment:
        [Sun Mar  7 16:23:47 2021]     HOME=/
        [Sun Mar  7 16:23:47 2021]     TERM=linux
        [Sun Mar  7 16:23:47 2021] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
        [Sun Mar  7 16:23:47 2021] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        [Sun Mar  7 16:23:47 2021] hub 1-1:1.0: USB hub found
        [Sun Mar  7 16:23:47 2021] hub 1-1:1.0: 4 ports detected
        [Sun Mar  7 16:23:48 2021] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
        [Sun Mar  7 16:23:48 2021] systemd[1]: System time before build time, advancing clock.
        [Sun Mar  7 16:23:48 2021] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
        [Sun Mar  7 16:23:48 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        [Sun Mar  7 16:23:48 2021] hub 1-1.1:1.0: USB hub found
        [Sun Mar  7 16:23:48 2021] hub 1-1.1:1.0: 3 ports detected
        [Sun Mar  7 16:23:48 2021] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
        [Sun Mar  7 16:23:48 2021] NET: Registered protocol family 10
        [Sun Mar  7 16:23:48 2021] Segment Routing with IPv6
        [Sun Mar  7 16:23:48 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [Sun Mar  7 16:23:48 2021] systemd[1]: Detected architecture arm.
        [Sun Mar  7 16:23:48 2021] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
        [Sun Mar  7 16:23:48 2021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [Sun Mar  7 16:23:48 2021] usb 1-1.2: Product: ConBee II
        [Sun Mar  7 16:23:48 2021] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
        [Sun Mar  7 16:23:48 2021] usb 1-1.2: SerialNumber: DE2413713
        [Sun Mar  7 16:23:48 2021] systemd[1]: Set hostname to <raspberrypi>.
        [Sun Mar  7 16:23:48 2021] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
        [Sun Mar  7 16:23:49 2021] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
        [Sun Mar  7 16:23:49 2021] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        [Sun Mar  7 16:23:49 2021] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
        [Sun Mar  7 16:23:49 2021] libphy: lan78xx-mdiobus: probed
        [Sun Mar  7 16:23:49 2021] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
        [Sun Mar  7 16:23:49 2021] random: systemd: uninitialized urandom read (16 bytes read)
        [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on Journal Socket (/dev/log).
        [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
        [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on Journal Audit Socket.
        [Sun Mar  7 16:23:49 2021] systemd[1]: Created slice system-getty.slice.
        [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on udev Control Socket.
        [Sun Mar  7 16:23:49 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
        [Sun Mar  7 16:23:49 2021] systemd[1]: Listening on Journal Socket.
        [Sun Mar  7 16:23:50 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        [Sun Mar  7 16:23:50 2021] systemd-journald[126]: Received request to flush runtime journal from PID 1
        [Sun Mar  7 16:23:51 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [Sun Mar  7 16:23:51 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [Sun Mar  7 16:23:51 2021] [vc_sm_connected_init]: start
        [Sun Mar  7 16:23:51 2021] [vc_sm_connected_init]: installed successfully
        [Sun Mar  7 16:23:51 2021] mc: Linux media interface: v0.10
        [Sun Mar  7 16:23:51 2021] videodev: Linux video capture interface: v2.00
        [Sun Mar  7 16:23:51 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [Sun Mar  7 16:23:51 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
        [Sun Mar  7 16:23:51 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [Sun Mar  7 16:23:51 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [Sun Mar  7 16:23:51 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [Sun Mar  7 16:23:51 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [Sun Mar  7 16:23:51 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [Sun Mar  7 16:23:51 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [Sun Mar  7 16:23:51 2021] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
        [Sun Mar  7 16:23:51 2021] usbcore: registered new interface driver cdc_acm
        [Sun Mar  7 16:23:51 2021] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        [Sun Mar  7 16:23:51 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [Sun Mar  7 16:23:51 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [Sun Mar  7 16:23:51 2021] usb 1-1.2: USB disconnect, device number 4
        [Sun Mar  7 16:23:51 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
        [Sun Mar  7 16:23:51 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [Sun Mar  7 16:23:51 2021] usbcore: registered new interface driver brcmfmac
        [Sun Mar  7 16:23:51 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
        [Sun Mar  7 16:23:52 2021] usb 1-1.2: new full-speed USB device number 6 using dwc_otg
        [Sun Mar  7 16:23:52 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [Sun Mar  7 16:23:52 2021] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
        [Sun Mar  7 16:23:52 2021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [Sun Mar  7 16:23:52 2021] usb 1-1.2: Product: ConBee II
        [Sun Mar  7 16:23:52 2021] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
        [Sun Mar  7 16:23:52 2021] usb 1-1.2: SerialNumber: DE2413713
        [Sun Mar  7 16:23:52 2021] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
        [Sun Mar  7 16:23:52 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        [Sun Mar  7 16:23:54 2021] random: crng init done
        [Sun Mar  7 16:23:54 2021] random: 7 urandom warning(s) missed due to ratelimiting
        [Sun Mar  7 16:23:54 2021] uart-pl011 3f201000.serial: no DMA platform data
        [Sun Mar  7 16:23:54 2021] 8021q: 802.1Q VLAN Support v1.8
        [Sun Mar  7 16:23:54 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        [Sun Mar  7 16:23:54 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
        [Sun Mar  7 16:23:55 2021] 8021q: adding VLAN 0 to HW filter on device eth0
        [Sun Mar  7 16:23:55 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [Sun Mar  7 16:23:55 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:23:56 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        [Sun Mar  7 16:25:42 2021] Bluetooth: Core ver 2.22
        [Sun Mar  7 16:25:42 2021] NET: Registered protocol family 31
        [Sun Mar  7 16:25:42 2021] Bluetooth: HCI device and connection manager initialized
        [Sun Mar  7 16:25:42 2021] Bluetooth: HCI socket layer initialized
        [Sun Mar  7 16:25:42 2021] Bluetooth: L2CAP socket layer initialized
        [Sun Mar  7 16:25:42 2021] Bluetooth: SCO socket layer initialized
        [Sun Mar  7 16:27:52 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:27:54 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:40:46 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:40:48 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:41:32 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:41:34 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:41:46 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:41:48 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:46:37 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:46:39 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:50:47 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:50:49 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:53:32 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [Sun Mar  7 16:53:32 2021] Bluetooth: BNEP filters: protocol multicast
        [Sun Mar  7 16:53:32 2021] Bluetooth: BNEP socket layer initialized
        [Sun Mar  7 16:56:55 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:56:57 2021] Under-voltage detected! (0x00050005)
        [Sun Mar  7 16:58:45 2021] Voltage normalised (0x00000000)
        [Sun Mar  7 16:58:48 2021] Under-voltage detected! (0x00050005)
        pi@raspberrypi:~ $
        • S SmartVerwalter
          #disable_overscan=1
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $
          wendy2702W Online
          wendy2702W Online
          @smartverwalter Als erstes mal für eine gescheite Stromversorgung sorgen.
          Was hängt per USB an dem PI ?
            SmartVerwalter
            dekonz zigbee adapter
            • S SmartVerwalter
              wendy2702W Online
              wendy2702W Online
              @smartverwalter Und womit wird der PI mit Spannung versorgt ?
                SmartVerwalter
                #66
                huawaysuper charge usb
                hw-050450E00
                • S SmartVerwalter
                  hw-050450E00
                  wendy2702W Online
                  wendy2702W Online
                  #67
                  @smartverwalter sagte in BLE Adapter beleibt gelb:
                  hw-050450E00
                  Das ist ein Ladegerät und keine Spannungsversorgung.
                  Besorge dir ein zum PI passendes Netzteil damit die "undervoltage" meldungen erstmal verschwinden.
                    SmartVerwalter
                    #68
                    habe das originale bei Reichelt gekauft, leider haben die mir die englische Version geliefert
                    • wendy2702W wendy2702
                      hw-050450E00
                      Jan1
                      #69
                      @wendy2702
                      Das erklärt auch warum das BT Device beim Reboot nicht automatisch startet, dem fehlt in dem Moment einfach der Saft.
                      • S SmartVerwalter
                        wendy2702W Online
                        wendy2702W Online
                        #70
                        Umtauschen und/oder einfach ein neues bei anderer Quelle bestellen.
                        Eine vernünftige Spannungsversorgung ist wichtig damit das System und alle HW Komponenten verbünftig laufen.
                          SmartVerwalter
                          #71
                          habe ihn jetzt mal an eine USB Steckdose angeschlossen
                          #disable_overscan=1
                          pi@raspberrypi:~ $ systemctl status hciuart.service
                          ● hciuart.service - Configure Bluetooth Modems connected by UART
                             Loaded: loaded (/lib/systemd/system/hciuart.service; enabled; vendor preset:
                             Active: failed (Result: exit-code) since Sun 2021-03-07 17:20:59 CET; 25min a
                            Process: 328 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
                          Mar 07 17:20:59 raspberrypi btuart[328]: Failed to set bdaddr, command failure
                          Mar 07 17:20:59 raspberrypi btuart[328]: Failed to update baudrate, invalid HCI
                          Mar 07 17:20:59 raspberrypi btuart[328]: Can't initialize device: Success
                          Mar 07 17:20:59 raspberrypi btuart[328]: bcm43xx_init
                          Mar 07 17:20:59 raspberrypi btuart[328]: Flash firmware /lib/firmware/brcm/BCM43
                          Mar 07 17:20:59 raspberrypi btuart[328]: Set BDADDR UART: b8:27:eb:33:de:ec
                          Mar 07 17:20:59 raspberrypi btuart[328]: Set Controller UART speed to 3000000 bi
                          Mar 07 17:20:59 raspberrypi systemd[1]: hciuart.service: Control process exited,
                          Mar 07 17:20:59 raspberrypi systemd[1]: hciuart.service: Failed with result 'exi
                          Mar 07 17:20:59 raspberrypi systemd[1]: Failed to start Configure Bluetooth Mode
                          lines 1-15/15 (END)
                          • S SmartVerwalter
                            #disable_overscan=1
                            lines 1-15/15 (END)
                            wendy2702W Online
                            wendy2702W Online
                            #72
                            @smartverwalter Leider ist da was abgeschnitten.
                            Die Ausgabe von
                            dmesg -T
                            wäre auch wieder interessant.
                            Achso... was für eine Steckdose? Die liefern meistens maximal bis 1,8Ampere wenn man Glück hat.
                              SmartVerwalter
                              #73
                              steckdose macht 5 Volt, 2,4 ampere
                              ist die Zigbee Dreifachsteckdose Sylvercrest von lidl
                              • S SmartVerwalter
                                wendy2702W Online
                                wendy2702W Online
                                #74
                                @smartverwalter Kenne ich nicht das Teil.
                                Keine Ahnung wie Stabil und sauber es die Spannung hält.
                                Was hast du eigentlich für einen PI? Sorry falls ich das überlesen habe,
                                  SmartVerwalter
                                  #75
                                  pi@raspberrypi:~ $ dmesg -t
                                  Zone ranges:
                                    Normal   empty
                                  FS-Cache: Loaded
                                  CacheFiles: Loaded
                                  zbud: loaded
                                  brd: module loaded
                                  loop: module loaded
                                  Core Release: 2.80a
                                  of_cfs_init
                                  of_cfs_init: OK
                                   mmcblk0: p1 p2
                                  EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                                  EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                  EXT4-fs (mmcblk0p2): recovery complete
                                  devtmpfs: mounted
                                    with arguments:
                                      /sbin/init
                                    with environment:
                                      HOME=/
                                      TERM=linux
                                  systemd[1]: Reached target Swap.
                                  systemd[1]: Listening on udev Kernel Socket.
                                  systemd[1]: Listening on initctl Compatibility Named Pipe.
                                  systemd[1]: Starting Set the console keyboard layout...
                                  systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                                  systemd-journald[121]: Received request to flush runtime journal from PID 1
                                  pi@raspberrypi:~ $
                                  • S SmartVerwalter
                                    Zone ranges:
                                      Normal   empty
                                    FS-Cache: Loaded
                                    CacheFiles: Loaded
                                    zbud: loaded
                                    brd: module loaded
                                    loop: module loaded
                                    Core Release: 2.80a
                                    of_cfs_init
                                    of_cfs_init: OK
                                     mmcblk0: p1 p2
                                    devtmpfs: mounted
                                      with arguments:
                                        /sbin/init
                                      with environment:
                                        HOME=/
                                        TERM=linux
                                    pi@raspberrypi:~ $
                                    wendy2702W Online
                                    wendy2702W Online
                                    #76
                                    @smartverwalter
                                    systemctl status bluetooth
                                      SmartVerwalter
                                      #77
                                      ● bluetooth.service - Bluetooth service
                                         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
                                         Active: inactive (dead)
                                           Docs: man:bluetoothd(8)
                                      ...skipping...
                                        SmartVerwalter
                                        #78
                                        @wendy2702 said in BLE Adapter beleibt gelb:
                                        pi@raspberrypi:~ $
                                           Active: failed (Result: exit-code) since Sun 2021-03-07 17:20:59 CET; 57min a
                                        lines 1-15/15 (END)
                                        • S SmartVerwalter
                                          pi@raspberrypi:~ $
                                          lines 1-15/15 (END)
                                          wendy2702W Online
                                          wendy2702W Online
                                          #79
                                          @smartverwalter Leider ist rechts das Log abgeschnitten.
                                          sudo systemctl start bluetooth
                                          sudo systemctl status bluetooth
                                          sudo systemctl status hciuart
