  4. Cannot read system.config: null
    1.0k
    6.1k
iobroker
25 Beiträge 10 Kommentatoren 20.0k Aufrufe 8 Beobachtet
  • L LJSven
    Ich glaube eher, daß der Slave das Problem ist?
    pi@raspberrypi:~ $ hostname
    raspberrypi
    pi@raspberrypi:~ $ cd opt/iobroker
    -bash: cd: opt/iobroker: No such file or directory
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ iobroker status
     Cannot read system.config: null (OK when migrating or restoring)
     Cannot find view "system" for search "host" : null
    No iobroker host is running.
    Objects type: file
    States  type: file
    pi@raspberrypi:/opt/iobroker $ iobroker stop
    pi@raspberrypi:/opt/iobroker $ iobroker update
    Error: Object "system.config" not found
    @LJSven
    Schau auf dem slave in der custom config nach dem host:
    sudo iobroker setup custom
    L 1 Antwort Letzte Antwort
      @LJSven
      LJSven
      @Thomas-Braun sagte in Cannot read system.config: null:
      @LJSven
      Da kommt diese Meldung ->
      permitted by applicable law.
      Last login: Mon May 18 16:22:08 2020 from 192.168.178.152
      pi@raspberrypi:/opt/iobroker $ sudo iobroker setup custom
      Current configuration:
      - Objects database:
        - Type: file
        - Host/Unix Socket: 192.168.178.15
        - Port: 9001
      - States database:
        - Type: file
        - Port: 9000
      - Data Directory: ../../iobroker-data/
      Type of objects DB [(f)ile, (r)edis], default [file]:
      • L LJSven
        @LJSven
        - Objects database:
          - Type: file
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        @LJSven Auf dem Master:
        iobroker version
        iobroker status
        Das gleiche auf dem Slave auch mal.
          iobroker version
          iobroker status
          LJSven
          @Thomas-Braun Master ->
          pi@tinkerboardmaster:/opt/iobroker$ iobroker version
          3.1.4
          pi@tinkerboardmaster:/opt/iobroker$ iobroker status
          Objects type: file
          States  type: file
          Slave ->
          pi@raspberrypi:/opt/iobroker $ iobroker version
          3.1.4
          Objects type: file
          States  type: file
          TWIX99bT 1 Antwort Letzte Antwort
          • L LJSven
            3.1.4
            Objects type: file
            States  type: file
            Slave ->
            3.1.4
            Objects type: file
            States  type: file
            TWIX99bT Offline
            TWIX99bT Offline
            TWIX99b
            @LJSven Habe grad das gleiche Problem. Wie hast du es den gelöst bekommen?
            Thomas BraunT S 2 Antworten Letzte Antwort
            • TWIX99bT TWIX99b
              @TWIX99b
              Am besten einen eigenen Thread eröffnen.
              • TWIX99bT TWIX99b
                smarteshome2020
                @twix99b Hallo, hast du eine Lösung gefunden? Ich habe die gleichen Meldungen und finde keine Lösung.
                Habe am Vorabend meine Fritz auf DNS over TLS umgestellt und in der Nacht ist irgendwas passiert. Einige Geräte z.B. Squeezbox, iPad, iobroker hatten am folgenden morgen Probleme. Habe dann den Strom gezogen und jetzt diese Meldungen
                pi@iobroker:/opt/iobroker $ iobroker status
                Objects type: file
                States  type: file
                MOD EDIT: LOGS BITTE ALS TEXT IN CODE TAGS </> POSTEN
                Thomas BraunT A 2 Antworten Letzte Antwort
                • S smarteshome2020
                  Objects type: file
                  States  type: file
                  @smarteshome2020
                  Ganz doofe Idee...
                  Besser eigenen Thread eröffnen.
                  • S smarteshome2020
                    Objects type: file
                    States  type: file
                    Achilles
                    @smarteshome2020 Habe das gleiche Problem.
                    Hat Jemand eine Lösung gefunden?
                    • A Achilles
                      wendy2702W Offline
                      wendy2702W Offline
                      @achilles Geht es ein wenig genauer?
                      @smarteshome2020 : Hatte ja mehrere Probleme aufgelistet nach Umstellung DNS
                      • PatrickP Offline
                        PatrickP Offline
                        Patrick
                        Giebt es schon Lösungen? Hab nun auch dieses Problem
                        • PatrickP Patrick
                          @patrick sagte in Cannot read system.config: null:
                          welches?
                          hier geht es ziemlich durcheinander
                          jeder hat "das selbe" und nachher doch was anderes.
                          passt das?
                          https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616096619995
                            bade_one
                            Hallo liebes Forum,
                            der Fehler
                            Alle Ursachen die in diesem Post dazu führten kann ich eigentlich bei mir ausschließen. Der Fehler tritt bei mir aus der "Kalten" auf. Ich bin schon von der SD-Karte auf SSD umgestiegen. Der Pi 4 ist up to date und hängt an einem USB-Hub. Ich betreib den ioBroker im Multihost-Modus als Master.
                            Habt ihr noch eine Idee was der Grund sein könnte, dass der config-Fehler fast einmal die Woche auftritt?
                            • B bade_one
                              Hallo liebes Forum,
                              der Fehler
                              @bade_one sagte in Cannot read system.config: null:
                              Könnte eine wackelige Stromversorgung mit sich bringen.
                                bade_one
                                @thomas-braun was empfiehlst du?
                                • B bade_one
                                  @bade_one
                                  Einen Blick in
                                  dmesg -T
                                  werfen.
                                  Die größeren Raspis sind jedenfalls noch stärker auf eine solide, stabile Stromversorgung angewiesen als die Vorgänger.
                                  Irgendwelche zweckentfremdete Ladegeräte und USB-Hubs sind jedenfalls keine stabile Stromversorgung.
                                    @bade_one
                                    Einen Blick in
                                    dmesg -T
                                    werfen.
                                    bade_one
                                    @thomas-braun Ich hab gestern einen Boot drin. Bekommt man dafür die Ursache raus?
                                    • B bade_one
                                      @bade_one
                                      Ohne die Ausgaben des Befehls eher nicht.
                                      Glaskugel kaputt...
                                        skybundi
                                        Hallo
                                        Nach dem ich meinen Raspberry neu gestartet habe funktioniert mein IObroker nicht mehr.
                                        Wenn ich "iobrocker info" eingebe bekomme ich das hier.
                                        pi@raspberrypi:~ $ iobroker info
                                        Platform       : linux
                                        os             : linux
                                        Architecture   : arm
                                        CPUs           : 4
                                        Speed          : 1500 MHz
                                        Model          : ARMv7 Processor rev 3 (v7l)
                                        RAM            : 3.7 GB
                                        System uptime  : 00:12:05
                                        Node.js        : v14.15.4
                                        Disk size      : 58.2 GiB
                                        Disk free      : 38.6 GiB
                                        NPM            : v6.14.10
                                        Vielleicht kann mir ja einer von euch helfen.
                                        Gruß Skybundi
                                        • S skybundi
                                          Hallo
                                          Platform       : linux
                                          os             : linux
                                          Architecture   : arm
                                          CPUs           : 4
                                          Speed          : 1500 MHz
                                          RAM            : 3.7 GB
                                          Node.js        : v14.15.4
                                          NPM            : v6.14.10
                                          Gruß Skybundi
                                          @skybundi
                                          iobroker status
                                          sagt?
                                          Vielleicht hilft:
