  4. Cannot read system.config: null
    1.0k
    6.1k
iobroker
25 Beiträge 10 Kommentatoren 20.0k Aufrufe 8 Beobachtet
  • L LJSven
    Master ->
    Welcome to Debian Stretch with Armbian Linux 4.19.69-rockchip
    System load:   0.05 0.05 0.05  	Up time:       53 min
    Memory usage:  11 % of 2002MB 	IP:            192.168.178.15
    CPU temp:      55°C
    Usage of /:    22% of 30G
    Configured profile sync daemon with overlayfs.
    pi@tinkerboardmaster:~$ hostname
    tinkerboardmaster
    Slave ->
    permitted by applicable law.
    Last login: Mon Feb 18 11:28:53 2019 from 192.168.178.201
    pi@raspberrypi:~ $ hostname
    raspberrypi
    pi@raspberrypi:~ $
    LJSven
    Ich glaube eher, daß der Slave das Problem ist?
    raspberrypi
    pi@raspberrypi:~ $ cd opt/iobroker
    -bash: cd: opt/iobroker: No such file or directory
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ iobroker status
     Cannot read system.config: null (OK when migrating or restoring)
     Cannot find view "system" for search "host" : null
    No iobroker host is running.
    Objects type: file
    States  type: file
    pi@raspberrypi:/opt/iobroker $ iobroker stop
    pi@raspberrypi:/opt/iobroker $ iobroker update
    Error: Object "system.config" not found
    • L LJSven
      raspberrypi
      Objects type: file
      States  type: file
      @LJSven
      Schau auf dem slave in der custom config nach dem host:
      sudo iobroker setup custom
      L 1 Antwort Letzte Antwort
        @LJSven
        LJSven
        @Thomas-Braun sagte in Cannot read system.config: null:
        @LJSven
        Da kommt diese Meldung ->
        Last login: Mon May 18 16:22:08 2020 from 192.168.178.152
        pi@raspberrypi:/opt/iobroker $ sudo iobroker setup custom
        Current configuration:
        - Objects database:
          - Type: file
          - Host/Unix Socket: 192.168.178.15
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        Type of objects DB [(f)ile, (r)edis], default [file]:
        • L LJSven
          @LJSven
          - Objects database:
            - Type: file
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          @LJSven Auf dem Master:
          iobroker version
          iobroker status
          Das gleiche auf dem Slave auch mal.
            iobroker version
            iobroker status
            LJSven
            @Thomas-Braun Master ->
            pi@tinkerboardmaster:/opt/iobroker$ iobroker version
            3.1.4
            pi@tinkerboardmaster:/opt/iobroker$ iobroker status
            Objects type: file
            States  type: file
            Slave ->
            pi@raspberrypi:/opt/iobroker $ iobroker version
            3.1.4
            Objects type: file
            States  type: file
            TWIX99bT 1 Antwort Letzte Antwort
            • L LJSven
              3.1.4
              Objects type: file
              States  type: file
              Slave ->
              3.1.4
              Objects type: file
              States  type: file
              TWIX99bT Offline
              TWIX99bT Offline
              TWIX99b
              @LJSven Habe grad das gleiche Problem. Wie hast du es den gelöst bekommen?
              Thomas BraunT S 2 Antworten Letzte Antwort
              • TWIX99bT TWIX99b
                @TWIX99b
                Am besten einen eigenen Thread eröffnen.
                • TWIX99bT TWIX99b
                  smarteshome2020
                  @twix99b Hallo, hast du eine Lösung gefunden? Ich habe die gleichen Meldungen und finde keine Lösung.
                  Habe am Vorabend meine Fritz auf DNS over TLS umgestellt und in der Nacht ist irgendwas passiert. Einige Geräte z.B. Squeezbox, iPad, iobroker hatten am folgenden morgen Probleme. Habe dann den Strom gezogen und jetzt diese Meldungen
                  pi@iobroker:/opt/iobroker $ iobroker status
                  Objects type: file
                  States  type: file
                  MOD EDIT: LOGS BITTE ALS TEXT IN CODE TAGS </> POSTEN
                  Thomas BraunT A 2 Antworten Letzte Antwort
                  • S smarteshome2020
                    Objects type: file
                    States  type: file
                    @smarteshome2020
                    Ganz doofe Idee...
                    Besser eigenen Thread eröffnen.
                    • S smarteshome2020
                      Objects type: file
                      States  type: file
                      Achilles
                      @smarteshome2020 Habe das gleiche Problem.
                      Hat Jemand eine Lösung gefunden?
                      • A Achilles
                        wendy2702W Offline
                        wendy2702W Offline
                        @achilles Geht es ein wenig genauer?
                        @smarteshome2020 : Hatte ja mehrere Probleme aufgelistet nach Umstellung DNS
                        • PatrickP Offline
                          PatrickP Offline
                          Patrick
                          Giebt es schon Lösungen? Hab nun auch dieses Problem
                          • PatrickP Patrick
                            @patrick sagte in Cannot read system.config: null:
                            welches?
                            hier geht es ziemlich durcheinander
                            jeder hat "das selbe" und nachher doch was anderes.
                            passt das?
                            https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616096619995
                              bade_one
                              Hallo liebes Forum,
                              der Fehler
                              Alle Ursachen die in diesem Post dazu führten kann ich eigentlich bei mir ausschließen. Der Fehler tritt bei mir aus der "Kalten" auf. Ich bin schon von der SD-Karte auf SSD umgestiegen. Der Pi 4 ist up to date und hängt an einem USB-Hub. Ich betreib den ioBroker im Multihost-Modus als Master.
                              Habt ihr noch eine Idee was der Grund sein könnte, dass der config-Fehler fast einmal die Woche auftritt?
                              • B bade_one
                                Hallo liebes Forum,
                                der Fehler
                                @bade_one sagte in Cannot read system.config: null:
                                Könnte eine wackelige Stromversorgung mit sich bringen.
                                  bade_one
                                  @thomas-braun was empfiehlst du?
                                  • B bade_one
                                    @bade_one
                                    Einen Blick in
                                    dmesg -T
                                    werfen.
                                    Die größeren Raspis sind jedenfalls noch stärker auf eine solide, stabile Stromversorgung angewiesen als die Vorgänger.
                                    Irgendwelche zweckentfremdete Ladegeräte und USB-Hubs sind jedenfalls keine stabile Stromversorgung.
                                      @bade_one
                                      Einen Blick in
                                      dmesg -T
                                      werfen.
                                      bade_one
                                      @thomas-braun Ich hab gestern einen Boot drin. Bekommt man dafür die Ursache raus?
                                      • B bade_one
                                        @bade_one
                                        Ohne die Ausgaben des Befehls eher nicht.
                                        Glaskugel kaputt...
                                          skybundi
                                          Hallo
                                          Nach dem ich meinen Raspberry neu gestartet habe funktioniert mein IObroker nicht mehr.
                                          Wenn ich "iobrocker info" eingebe bekomme ich das hier.
                                          pi@raspberrypi:~ $ iobroker info
                                          Platform       : linux
                                          os             : linux
                                          Architecture   : arm
                                          CPUs           : 4
                                          Speed          : 1500 MHz
                                          Model          : ARMv7 Processor rev 3 (v7l)
                                          RAM            : 3.7 GB
                                          System uptime  : 00:12:05
                                          Node.js        : v14.15.4
                                          Disk size      : 58.2 GiB
                                          Disk free      : 38.6 GiB
                                          NPM            : v6.14.10
                                          Vielleicht kann mir ja einer von euch helfen.
                                          Gruß Skybundi
