  4. Cannot read system.config: null
    1.0k
    6.1k
iobroker
25 Beiträge 10 Kommentatoren 20.0k Aufrufe 8 Beobachtet
  • L Offline
    LJSven
    Master ->
    Welcome to Debian Stretch with Armbian Linux 4.19.69-rockchip
    System load:   0.05 0.05 0.05  	Up time:       53 min
    Memory usage:  11 % of 2002MB 	IP:            192.168.178.15
    CPU temp:      55°C
    Usage of /:    22% of 30G
    Configured profile sync daemon with overlayfs.
    pi@tinkerboardmaster:~$ hostname
    tinkerboardmaster
    Slave ->
    permitted by applicable law.
    Last login: Mon Feb 18 11:28:53 2019 from 192.168.178.201
    pi@raspberrypi:~ $ hostname
    raspberrypi
    pi@raspberrypi:~ $
    L 1 Antwort Letzte Antwort
    • L LJSven
      Master ->
      CPU temp:      55°C
      tinkerboardmaster
      Slave ->
      raspberrypi
      pi@raspberrypi:~ $
      LJSven
      Ich glaube eher, daß der Slave das Problem ist?
      raspberrypi
      pi@raspberrypi:~ $ cd opt/iobroker
      -bash: cd: opt/iobroker: No such file or directory
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ iobroker status
       Cannot read system.config: null (OK when migrating or restoring)
       Cannot find view "system" for search "host" : null
      No iobroker host is running.
      Objects type: file
      States  type: file
      pi@raspberrypi:/opt/iobroker $ iobroker stop
      pi@raspberrypi:/opt/iobroker $ iobroker update
      Error: Object "system.config" not found
      • L LJSven
        raspberrypi
        Objects type: file
        States  type: file
        @LJSven
        Schau auf dem slave in der custom config nach dem host:
        sudo iobroker setup custom
          @LJSven
          LJSven
          @Thomas-Braun sagte in Cannot read system.config: null:
          @LJSven
          Da kommt diese Meldung ->
          Last login: Mon May 18 16:22:08 2020 from 192.168.178.152
          pi@raspberrypi:/opt/iobroker $ sudo iobroker setup custom
          Current configuration:
          - Objects database:
            - Type: file
            - Host/Unix Socket: 192.168.178.15
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          - Data Directory: ../../iobroker-data/
          Type of objects DB [(f)ile, (r)edis], default [file]:
          • L LJSven
            @LJSven
            - Objects database:
              - Type: file
              - Port: 9001
            - States database:
              - Type: file
              - Port: 9000
            @LJSven Auf dem Master:
            iobroker version
            iobroker status
            Das gleiche auf dem Slave auch mal.
              iobroker version
              iobroker status
              LJSven
              @Thomas-Braun Master ->
              pi@tinkerboardmaster:/opt/iobroker$ iobroker version
              3.1.4
              pi@tinkerboardmaster:/opt/iobroker$ iobroker status
              Objects type: file
              States  type: file
              Slave ->
              pi@raspberrypi:/opt/iobroker $ iobroker version
              3.1.4
              Objects type: file
              States  type: file
              TWIX99bT 1 Antwort Letzte Antwort
              • L LJSven
                3.1.4
                Objects type: file
                States  type: file
                Slave ->
                3.1.4
                Objects type: file
                States  type: file
                TWIX99bT Offline
                TWIX99bT Offline
                TWIX99b
                @LJSven Habe grad das gleiche Problem. Wie hast du es den gelöst bekommen?
                Thomas BraunT S 2 Antworten Letzte Antwort
                • TWIX99bT TWIX99b
                  @TWIX99b
                  Am besten einen eigenen Thread eröffnen.
                  • TWIX99bT TWIX99b
                    smarteshome2020
                    @twix99b Hallo, hast du eine Lösung gefunden? Ich habe die gleichen Meldungen und finde keine Lösung.
                    Habe am Vorabend meine Fritz auf DNS over TLS umgestellt und in der Nacht ist irgendwas passiert. Einige Geräte z.B. Squeezbox, iPad, iobroker hatten am folgenden morgen Probleme. Habe dann den Strom gezogen und jetzt diese Meldungen
                    pi@iobroker:/opt/iobroker $ iobroker status
                    Objects type: file
                    States  type: file
                    MOD EDIT: LOGS BITTE ALS TEXT IN CODE TAGS </> POSTEN
                    Thomas BraunT A 2 Antworten Letzte Antwort
                    • S smarteshome2020
                      Objects type: file
                      States  type: file
                      @smarteshome2020
                      Ganz doofe Idee...
                      Besser eigenen Thread eröffnen.
                      • S smarteshome2020
                        Objects type: file
                        States  type: file
                        Achilles
                        @smarteshome2020 Habe das gleiche Problem.
                        Hat Jemand eine Lösung gefunden?
                        • A Achilles
                          wendy2702W Offline
                          wendy2702W Offline
                          @achilles Geht es ein wenig genauer?
                          @smarteshome2020 : Hatte ja mehrere Probleme aufgelistet nach Umstellung DNS
                          • PatrickP Offline
                            PatrickP Offline
                            Patrick
                            Giebt es schon Lösungen? Hab nun auch dieses Problem
                            • PatrickP Patrick
                              @patrick sagte in Cannot read system.config: null:
                              welches?
                              hier geht es ziemlich durcheinander
                              jeder hat "das selbe" und nachher doch was anderes.
                              passt das?
                              https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616096619995
                                bade_one
                                Hallo liebes Forum,
                                der Fehler
                                Alle Ursachen die in diesem Post dazu führten kann ich eigentlich bei mir ausschließen. Der Fehler tritt bei mir aus der "Kalten" auf. Ich bin schon von der SD-Karte auf SSD umgestiegen. Der Pi 4 ist up to date und hängt an einem USB-Hub. Ich betreib den ioBroker im Multihost-Modus als Master.
                                Habt ihr noch eine Idee was der Grund sein könnte, dass der config-Fehler fast einmal die Woche auftritt?
                                • B bade_one
                                  Hallo liebes Forum,
                                  der Fehler
                                  @bade_one sagte in Cannot read system.config: null:
                                  Könnte eine wackelige Stromversorgung mit sich bringen.
                                    bade_one
                                    @thomas-braun was empfiehlst du?
                                    • B bade_one
                                      @bade_one
                                      Einen Blick in
                                      dmesg -T
                                      werfen.
                                      Die größeren Raspis sind jedenfalls noch stärker auf eine solide, stabile Stromversorgung angewiesen als die Vorgänger.
                                      Irgendwelche zweckentfremdete Ladegeräte und USB-Hubs sind jedenfalls keine stabile Stromversorgung.
                                        @bade_one
                                        Einen Blick in
                                        dmesg -T
                                        werfen.
                                        bade_one
                                        @thomas-braun Ich hab gestern einen Boot drin. Bekommt man dafür die Ursache raus?
                                        • B bade_one
                                          @bade_one
                                          Ohne die Ausgaben des Befehls eher nicht.
                                          Glaskugel kaputt...
