  4. [ Geklärt ] Wie kann ich eine HDD gegen SSD tauschen
hddssdwechsel
79 Beiträge 5 Kommentatoren 4.8k Aufrufe 4 Beobachtet
    @altersrentner
    dmesg
    anschauen.
    Tauschen: Backup anlegen, Hardware tauschen, System neu installieren, Backup einspielen.
    Altersrentner
    pi@raspberrypi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.9-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1396 SMP Thu Jan 21 15:57:42 GMT 2021
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [    0.000000]   Normal   empty
    [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
    [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
    [    0.000000] On node 0 totalpages: 1012480
    [    0.000000]   DMA zone: 2304 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 815872 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s50636 r8192 d23092 u81920
    [    0.000000] pcpu-alloc: s50636 r8192 d23092 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010176
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:1B:BD:83 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                   Please use sysfs to set IO scheduler for individual devices.
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
    [    0.000000] Memory: 3653920K/4049920K available (10240K kernel code, 1354K rwdata, 3152K rodata, 2048K init, 890K bss, 133856K reserved, 262144K cma-reserved, 3263488K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 33823 entries in 67 pages
    [    0.000000] ftrace: allocated 67 pages with 3 groups
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000]  Rude variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
    [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [    0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [    0.000100] bcm2835: system timer (irq = 25)
    [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000763] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000786] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [    0.000804] Switching to timer-based delay loop, resolution 18ns
    [    0.001055] Console: colour dummy device 80x30
    [    0.001800] printk: console [tty1] enabled
    [    0.001866] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [    0.001920] pid_max: default: 32768 minimum: 301
    [    0.002100] LSM: Security Framework initializing
    [    0.002297] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.002343] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.003912] Disabling memory control group subsystem
    [    0.004046] CPU: Testing write buffer coherency: ok
    [    0.004518] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.005748] Setting up static identity map for 0x200000 - 0x20003c
    [    0.005963] rcu: Hierarchical SRCU implementation.
    [    0.006901] smp: Bringing up secondary CPUs ...
    [    0.008128] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.009500] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.010815] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.010973] smp: Brought up 1 node, 4 CPUs
    [    0.011020] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.011050] CPU: All CPU(s) started in HYP mode.
    [    0.011077] CPU: Virtualization extensions available.
    [    0.011911] devtmpfs: initialized
    [    0.025569] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [    0.025842] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.025895] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.032618] pinctrl core: initialized pinctrl subsystem
    [    0.033697] NET: Registered protocol family 16
    [    0.037686] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.038471] audit: initializing netlink subsys (disabled)
    [    0.038747] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
    [    0.039309] thermal_sys: Registered thermal governor 'step_wise'
    [    0.039988] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.040042] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.040437] Serial: AMBA PL011 UART driver
    [    0.071670] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.090941] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-21T16:02:55, variant start
    [    0.100955] raspberrypi-firmware soc:firmware: Firmware hash is a5bf70c44ba93e99f955a66530916240a1661132
    [    0.145378] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.149519] vgaarb: loaded
    [    0.149990] SCSI subsystem initialized
    [    0.150217] usbcore: registered new interface driver usbfs
    [    0.150306] usbcore: registered new interface driver hub
    [    0.150394] usbcore: registered new device driver usb
    [    0.150737] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [    0.152974] clocksource: Switched to clocksource arch_sys_counter
    [    1.179771] VFS: Disk quotas dquot_6.6.0
    [    1.179899] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.180099] FS-Cache: Loaded
    [    1.180295] CacheFiles: Loaded
    [    1.189366] NET: Registered protocol family 2
    [    1.190267] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    1.190431] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    1.190512] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.190599] TCP: Hash tables configured (established 8192 bind 8192)
    [    1.190769] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.190825] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.191109] NET: Registered protocol family 1
    [    1.191888] RPC: Registered named UNIX socket transport module.
    [    1.191922] RPC: Registered udp transport module.
    [    1.191950] RPC: Registered tcp transport module.
    [    1.191978] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.192015] PCI: CLS 0 bytes, default 64
    [    1.194865] Initialise system trusted keyrings
    [    1.195139] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    1.203308] zbud: loaded
    [    1.205056] FS-Cache: Netfs 'nfs' registered for caching
    [    1.205976] NFS: Registering the id_resolver key type
    [    1.206036] Key type id_resolver registered
    [    1.206065] Key type id_legacy registered
    [    1.206229] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.207247] Key type asymmetric registered
    [    1.207280] Asymmetric key parser 'x509' registered
    [    1.207486] bounce: pool size: 64 pages
    [    1.207556] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    1.207794] io scheduler mq-deadline registered
    [    1.207826] io scheduler kyber registered
    [    1.212247] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    1.212299] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [    1.212401] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
    [    1.212510] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
    [    1.275082] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [    1.275594] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    1.275632] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.275670] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [    1.275792] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    1.276052] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    1.279465] PCI: bus0: Fast back to back transfers disabled
    [    1.279850] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    1.279995] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    1.280446] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    1.283875] PCI: bus1: Fast back to back transfers disabled
    [    1.283989] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    1.284032] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [    1.284136] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.284177] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    1.284614] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    1.284858] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
    [    1.293267] iproc-rng200 fe104000.rng: hwrng registered
    [    1.293595] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
    [    1.294484] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [    1.307749] brd: module loaded
    [    1.319997] loop: module loaded
    [    1.321642] Loading iSCSI transport class v2.0-870.
    [    1.324187] libphy: Fixed MDIO Bus: probed
    [    1.325443] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [    1.343040] libphy: bcmgenet MII bus: probed
    [    1.423146] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [    1.424306] usbcore: registered new interface driver r8152
    [    1.424393] usbcore: registered new interface driver lan78xx
    [    1.424483] usbcore: registered new interface driver smsc95xx
    [    1.426126] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [    1.426318] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.426370] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [    1.429693] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
    [    1.431041] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    1.431082] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.431119] usb usb1: Product: xHCI Host Controller
    [    1.431149] usb usb1: Manufacturer: Linux 5.10.9-v7l+ xhci-hcd
    [    1.431181] usb usb1: SerialNumber: 0000:01:00.0
    [    1.431926] hub 1-0:1.0: USB hub found
    [    1.432040] hub 1-0:1.0: 1 port detected
    [    1.432739] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.432783] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [    1.432829] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    1.433382] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    1.433422] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.433459] usb usb2: Product: xHCI Host Controller
    [    1.433489] usb usb2: Manufacturer: Linux 5.10.9-v7l+ xhci-hcd
    [    1.433520] usb usb2: SerialNumber: 0000:01:00.0
    [    1.434253] hub 2-0:1.0: USB hub found
    [    1.434376] hub 2-0:1.0: 4 ports detected
    [    1.436076] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.436391] dwc_otg: FIQ enabled
    [    1.436406] dwc_otg: NAK holdoff enabled
    [    1.436421] dwc_otg: FIQ split-transaction FSM enabled
    [    1.436440] Module dwc_common_port init
    [    1.436876] usbcore: registered new interface driver uas
    [    1.437012] usbcore: registered new interface driver usb-storage
    [    1.437221] mousedev: PS/2 mouse device common for all mice
    [    1.438842] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    1.442297] sdhci: Secure Digital Host Controller Interface driver
    [    1.442331] sdhci: Copyright(c) Pierre Ossman
    [    1.443135] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    1.443747] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.446647] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.446999] hid: raw HID events driver (C) Jiri Kosina
    [    1.447216] usbcore: registered new interface driver usbhid
    [    1.447246] usbhid: USB HID core driver
    [    1.452887] Initializing XFRM netlink socket
    [    1.452999] NET: Registered protocol family 17
    [    1.453140] Key type dns_resolver registered
    [    1.453501] Registering SWP/SWPB emulation handler
    [    1.453693] registered taskstats version 1
    [    1.453735] Loading compiled-in X.509 certificates
    [    1.454571] Key type ._fscrypt registered
    [    1.454602] Key type .fscrypt registered
    [    1.454629] Key type fscrypt-provisioning registered
    [    1.466169] uart-pl011 fe201000.serial: there is not valid maps for state default
    [    1.466494] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    1.466585] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
    [    1.473309] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    1.474384] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    1.474419] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    1.506609] of_cfs_init
    [    1.506885] of_cfs_init: OK
    [    1.521005] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.522684] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.524359] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.527345] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.529018] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.538915] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [    1.540060] Waiting for root device PARTUUID=6c586e13-02...
    [    1.571316] random: fast init done
    [    1.596620] mmc1: new high speed SDIO card at address 0001
    [    1.793011] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.975754] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [    1.975796] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.975830] usb 1-1: Product: USB2.0 Hub
    [    1.977926] hub 1-1:1.0: USB hub found
    [    1.978183] hub 1-1:1.0: 4 ports detected
    [    2.123245] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [    2.154437] usb 2-1: New USB device found, idVendor=067b, idProduct=2773, bcdDevice= 1.00
    [    2.154477] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.154511] usb 2-1: Product: Quickport Combo U3
    [    2.154540] usb 2-1: Manufacturer: SHARKOON
    [    2.154570] usb 2-1: SerialNumber: SHARK000000002
    [    2.156966] usb 2-1: Set SEL for device-initiated U1 failed.
    [    2.157222] usb 2-1: Set SEL for device-initiated U2 failed.
    [    2.157510] usb-storage 2-1:1.0: USB Mass Storage device detected
    [    2.158276] scsi host0: usb-storage 2-1:1.0
    [    2.303006] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
    [    2.449322] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
    [    2.449363] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.449400] usb 1-1.3: Product: FT232R USB UART
    [    2.449430] usb 1-1.3: Manufacturer: FTDI
    [    2.449459] usb 1-1.3: SerialNumber: A900aSim
    [    2.553006] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
    [    2.691985] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
    [    2.692025] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.692062] usb 1-1.4: Product: TI CC2531 USB CDC
    [    2.692092] usb 1-1.4: Manufacturer: Texas Instruments
    [    2.692123] usb 1-1.4: SerialNumber: __0X00124B0012013B01
    [    3.232013] scsi 0:0:0:0: Direct-Access     Hitachi  HTS547575A9E384  JE4O PQ: 0 ANSI: 0
    [    3.233301] sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/699 GiB)
    [    3.234102] sd 0:0:0:0: [sda] Write Protect is off
    [    3.234139] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
    [    3.234897] sd 0:0:0:0: [sda] No Caching mode page found
    [    3.234933] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [    3.253301]  sda: sda1 sda2
    [    3.256587] sd 0:0:0:0: [sda] Attached SCSI disk
    [    3.296167] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [    3.296206] EXT4-fs (sda2): write access will be enabled during recovery
    [    3.323795] EXT4-fs (sda2): recovery complete
    [    3.325232] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.325329] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [    3.364152] devtmpfs: mounted
    [    3.373091] Freeing unused kernel memory: 2048K
    [    3.373428] Run /sbin/init as init process
    [    3.373456]   with arguments:
    [    3.373471]     /sbin/init
    [    3.373486]   with environment:
    [    3.373500]     HOME=/
    [    3.373514]     TERM=linux
    [    4.885553] systemd[1]: System time before build time, advancing clock.
    [    5.163083] NET: Registered protocol family 10
    [    5.164501] Segment Routing with IPv6
    [    5.310802] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    5.311621] systemd[1]: Detected architecture arm.
    [    5.377623] systemd[1]: Set hostname to <raspberrypi>.
    [    7.761433] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.778003] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.800357] systemd[1]: Listening on Syslog Socket.
    [    7.801261] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.803680] systemd[1]: Created slice User and Session Slice.
    [    7.806337] systemd[1]: Created slice system-getty.slice.
    [    7.807554] systemd[1]: Listening on Journal Socket (/dev/log).
    [    7.808666] systemd[1]: Listening on udev Control Socket.
    [    7.810152] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [    7.811435] systemd[1]: Listening on Journal Socket.
    [    9.096788] EXT4-fs (sda2): re-mounted. Opts: (null)
    [    9.232809] systemd-journald[112]: Received request to flush runtime journal from PID 1
    [   10.373018] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [   10.373633] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [   10.374139] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [   10.374654] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [   10.968410] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [   10.970486] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [   10.970510] [vc_sm_connected_init]: start
    [   10.971258] [vc_sm_connected_init]: installed successfully
    [   11.032087] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [   11.039061] bcm2835_audio bcm2835_audio: card created with 8 channels
    [   11.175515] mc: Linux media interface: v0.10
    [   11.333228] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [   11.453827] videodev: Linux video capture interface: v2.00
    [   11.794073] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [   11.794105] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [   11.797533] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.948612] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [   11.950909] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
    [   11.953549] usbcore: registered new interface driver cdc_acm
    [   11.953566] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [   11.958811] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [   11.964265] usbcore: registered new interface driver usbserial_generic
    [   11.964337] usbserial: USB Serial support registered for generic
    [   11.968526] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [   11.978733] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [   11.978872] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [   11.980754] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [   11.990790] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [   11.990840] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [   11.991386] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [   12.000245] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [   12.000765] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [   12.001190] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [   12.001231] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [   12.001519] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [   12.001910] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [   12.001937] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [   12.001973] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [   12.001997] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [   12.002019] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [   12.002211] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [   12.011313] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [   12.011361] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [   12.081450] usbcore: registered new interface driver ftdi_sio
    [   12.100201] usbserial: USB Serial support registered for FTDI USB Serial Device
    [   12.100479] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
    [   12.100686] usb 1-1.3: Detected FT232RL
    [   12.111878] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
    [   12.162421] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   12.319098] random: crng init done
    [   12.319113] random: 7 urandom warning(s) missed due to ratelimiting
    [   12.376477] brcmfmac: F1 signature read @0x18000000=0x15264345
    [   12.386462] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [   12.386931] usbcore: registered new interface driver brcmfmac
    [   12.548915] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [   12.820738] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [   12.842490] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
    [   15.405469] uart-pl011 fe201000.serial: no DMA platform data
    [   16.004195] 8021q: 802.1Q VLAN Support v1.8
    [   17.063052] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    [   17.224618] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [   17.625289] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [   17.625553] bcmgenet fd580000.ethernet eth0: Link is Down
    [   21.753264] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   21.753317] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   23.196800] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [   24.214175] Bluetooth: Core ver 2.22
    [   24.214287] NET: Registered protocol family 31
    [   24.214303] Bluetooth: HCI device and connection manager initialized
    [   24.214881] Bluetooth: HCI socket layer initialized
    [   24.214905] Bluetooth: L2CAP socket layer initialized
    [   24.214943] Bluetooth: SCO socket layer initialized
    [   24.300003] Bluetooth: HCI UART driver ver 2.3
    [   24.300021] Bluetooth: HCI UART protocol H4 registered
    [   24.300106] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   24.300386] Bluetooth: HCI UART protocol Broadcom registered
    [   25.049975] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   25.049984] Bluetooth: BNEP filters: protocol multicast
    [   25.049997] Bluetooth: BNEP socket layer initialized
    [  256.770062] FS-Cache: Netfs 'cifs' registered for caching
    [  256.937430] Key type cifs.spnego registered
    [  256.937451] Key type cifs.idmap registered
    [  256.938455] CIFS: Attempting to mount //192.168.178.35/homes/Backup/iobroker/minimalPi4
    [  256.938510] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [  263.196337] CIFS: VFS: Error connecting to socket. Aborting operation.
    [  263.196361] CIFS: VFS: cifs_mount failed w/return code = -113
    [  263.255184] CIFS: Attempting to mount //192.168.178.35/homes/Backup/iobroker/minimalPi4
    [  263.255245] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
    [  269.436401] CIFS: VFS: Error connecting to socket. Aborting operation.
    [  269.436428] CIFS: VFS: cifs_mount failed w/return code = -113
    Ist hier ein Problem erkennbar?
    wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
    • A Altersrentner
      [    3.373500]     HOME=/
      wendy2702W Online
      wendy2702W Online
      @altersrentner sagte in Wie kann ich eine HDD gegen SSD tauschen:
      XT4-fs (sda2): INFO: recovery required on readonly filesystem [ 3.296206] EXT4-fs (sda2): write access will be enabled during recovery [ 3.323795] EXT4-fs (sda2): recovery complete
      Gab zumindest mal was.
      Wie ist die Platte mit Spannung versorgt?
      Die Crucial SSD ist auch OK und sollte völlig ausreichen.
      • A Altersrentner
        [    3.373500]     HOME=/
        Das ist ungut. Da ist unlängst das System nicht sauber heruntergefahren worden.
        Und mit dem samba-Server gibt es wohl auch Kommunikationsprobleme.
        • wendy2702W wendy2702
          Altersrentner
          @wendy2702 said in Wie kann ich eine HDD gegen SSD tauschen:
          Über eine Docking Station. Ich glaube, das ist nicht ok.
          Was für ein Teil Brauche ich um die SSD mit dem PI zu verbinden.
          MfG Michael
          • wendy2702W Online
            wendy2702W Online
            Eigentlich nur einen SATA - USB Adapter wenn der PI denn mit einem ausreichenden Netzteil betrieben wird.
              Altersrentner
              schrieb am zuletzt editiert von Altersrentner
              @wendy2702
              Danke, ist bestellt.
              MfG Michael
                @altersrentner
                dmesg
                anschauen.
                Altersrentner
                Gestern ist die SSD und der Adapter gekommen.
                Heute habe ich den ganzen Tag versucht die SSD einzubinden.
                Der PI startet von einer SD aber nich von der SSD.
                Ich verstehe es nicht, denn vorher ist er ja von der HDD gestartet.
                jetzt auch nicht mehr.
                Das Problem ist die Boot Reihenfolge
                pi@raspberrypi:~ $ vcgencmd bootloader_config
                [all]
                BOOT_UART=0
                WAKE_ON_GPIO=1
                POWER_OFF_ON_HALT=0
                pi@raspberrypi:~ $ vcgencmd bootloader_version
                Dec 11 2020 11:15:17
                version c3f26b6070054bca030366de2550d79ddae1207a (release)
                timestamp 1607685317
                update-time 1609251112
                capabilities 0x0000001f
                pi@raspberrypi:~ $ sudo nano /etc/default/rpi-eeprom-update
                FIRMWARE_RELEASE_STATUS="default"
                pi@raspberrypi:~ $ sudo rpi-eeprom-update
                BCM2711 detected
                Dedicated VL805 EEPROM detected
                Checking for updates in /lib/firmware/raspberrypi/bootloader/default
                Use raspi-config to select either the default-production release or latest update.
                BOOTLOADER: up-to-date
                CURRENT: Fri 11 Dec 11:15:17 UTC 2020 (1607685317)
                 LATEST: Thu  3 Sep 12:11:43 UTC 2020 (1599135103)
                RELEASE: default
                VL805: up-to-date
                CURRENT: 000138a1
                 LATEST: 000138a1
                Jetzt komme ich nicht weiter
                Wie kann ich default in stable ändern
                Wer kann mir bitte helfen
                MfG Michael
                • A Altersrentner
                  [all]
                  BOOT_UART=0
                  WAKE_ON_GPIO=1
                  POWER_OFF_ON_HALT=0
                  BCM2711 detected
                  RELEASE: default
                  VL805: up-to-date
                  CURRENT: 000138a1
                   LATEST: 000138a1
                  MfG Michael
                  wendy2702W Online
                  wendy2702W Online
                  Steht doch da.
                  raspi-config
                    Steht doch da.
                    raspi-config
                    Altersrentner
                    @wendy2702
                    Danke für Deine Hilfe.
                    Und wo muss ich dann was umstellen?
                    MfG Michael
                    HomoranH wendy2702W 2 Antworten Letzte Antwort
                    • A Altersrentner
                      @wendy2702
                      MfG Michael
                      nirgends:
                      RELEASE: default VL805: up-to-date
                      • A Altersrentner
                        @wendy2702
                        MfG Michael
                        wendy2702W Online
                        wendy2702W Online
                        @altersrentner Aber solltest du es doch umstellen habe ich mal für dich gegoogelt:
                        Advanced Options -->
                        Boot Order
                        On the Raspberry Pi4, you can specify whether to boot from USB or network if the SD card isn't inserted. See this page for more information.
                        Bootloader Version
                        On the Raspberry Pi4, you can tell the system to use the very latest boot ROM software, or default to the factory default if the latest version causes problems.
                        Oder zum lesen hier drücken
                          nirgends:
                          Altersrentner
                          @homoran Hallo,
                          heißt, es ist alles OK?
                          Warum bootet der PI dann nicht von der SSD😧
                          MfG Michael
                          • A Altersrentner
                            @homoran Hallo,
                            MfG Michael
                            Ich hatte mal eine SSD (Patriot Burst), die war bei keinem PC zum Booten zu bewegen.
                            Vielleicht liegt hier auch so etwas vor.
                            • A Altersrentner
                              @homoran Hallo,
                              MfG Michael
                              wendy2702W Online
                              wendy2702W Online
                              @altersrentner Kann tausend gründe haben. SSD Kapott, falsch formatiert, Spannungsversorgung nicht ausreichend.... usw. usw. usw.
                              Aber diese Anleitung scheint nicht schlecht zu sein.
                              https://kofler.info/usb-boot-fuer-den-raspberry-pi-4/
                              A 2 Antworten Letzte Antwort
                                Altersrentner
                                @wendy2702 Danke , werde ich morgen probieren,
                                MfG Michael
                                  Altersrentner
                                  @wendy2702; Guten Morgen,
                                  Habe jetzt die SD Karte mit dem 32-Bit Image bespielt und im Pi installiert.
                                  Die Kontrolle Das EEPROM ergab das selbe Ergebnis wie in der Anleitung.
                                  Die Boot Optionen waren so eingestellt wie im Bild und wurden nicht verändert.
                                  Wichtig für den späteren Bootprozess ist, dass die Datei /boot/cmdline.txt keinen absoluten Pfad zur Boot-Partition enthält, sondern deren UUID (Parammeter root=PARTUUID=...). In meinem Fall sieht cmdline.txt so aus:
                                  Wo finde ich diese Datei Zwecks Überprüfung?
                                  Mit freundlichen Grüßen
                                  Michael
                                  wendy2702W E 2 Antworten Letzte Antwort
                                  • A Altersrentner
                                    Michael
                                    wendy2702W Online
                                    wendy2702W Online
                                    /boot/cmdline.tx
                                    Auf der SSD im Ordner
                                    /boot
                                    • A Altersrentner
                                      Michael
                                      ente34
                                      @altersrentner
                                      Ich habe im Januar auf SSD umgestellt und fand es nicht ganz einfach.
                                      Auf der SSD hast Du ein funktionierendes System?
                                      Hast Du es von der SD-Karte/vorhandener Harddisk geclont oder neu installiert?
                                      Tippe mal bitte
                                      mount
                                      ein, damit wir wissen, wo wir stehen.
                                      Und dann
                                       cat /boot/cmdline.txt
                                      • E ente34
                                        @altersrentner
                                        Tippe mal bitte
                                        mount
                                        Und dann
                                        Altersrentner
                                        @ente34 Hallo,
                                        Ich habe nicht geclont, sondern direkt mittels
                                        Pi Imager installiert.
                                        Nur es fehlt die SSH Datei und somit gibt es keine Verbindung
                                        Habe die jetzt nachgeschoben und das ist das Ergebnis
                                        pi@raspberrypi:~ $  cat /boot/cmdline.txt
                                        console=serial0,115200 console=tty1 root=PARTUUID=add8200f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                        pi@raspberrypi:~ $ mount
                                        /dev/sda2 on / type ext4 (rw,noatime)
                                        devtmpfs on /dev type devtmpfs (rw,relatime,size=1827288k,nr_inodes=97773,mode=755)
                                        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
                                        proc on /proc type proc (rw,relatime)
                                        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
                                        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
                                        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
                                        tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
                                        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
                                        tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
                                        cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
                                        cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
                                        none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
                                        cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
                                        cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
                                        cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
                                        cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
                                        cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
                                        cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
                                        cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
                                        cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
                                        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                                        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                                        mqueue on /dev/mqueue type mqueue (rw,relatime)
                                        debugfs on /sys/kernel/debug type debugfs (rw,relatime)
                                        configfs on /sys/kernel/config type configfs (rw,relatime)
                                        /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                                        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=391876k,mode=700,uid=1000,gid=1000)
                                        Freundliche Grüße
                                        Michael
                                        E 1 Antwort Letzte Antwort
                                        • A Altersrentner
                                          @ente34 Hallo,
                                          Freundliche Grüße
                                          Michael
                                          ente34
                                          @altersrentner
                                          Glückwunsch, Du bist auf der SSD
                                          Bei mir sieht sie so aus (vgl. root=), aber wenn es funktioniert, würde ich nichts ändern
                                          root=/dev/sda2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
