  4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
vodafone speedtest
208 Beiträge 43 Kommentatoren 52.4k Aufrufe 33 Beobachtet
  • E Ente
    wollte mir eben den Adapter installieren, via:
    https://github.com/peterbaumert/ioBroker.vodafone-speedtest
    Das ist das Ergebniss:
    $ ./iobroker url "https://github.com/peterbaumert/ioBroker.vodafone-speedtest.git" --debug
    install https://github.com/peterbaumert/ioBroker.vodafone-speedtest/tarball/210ae0ca3bb57126a37505a069bd4481ef533b96
    NPM version: 6.14.6
    npm install https://github.com/peterbaumert/ioBroker.vodafone-speedtest/tarball/210ae0ca3bb57126a37505a069bd4481ef533b96 --loglevel error --prefix "/opt/iobroker" (System call)
    > node-libcurl@2.2.0 install /opt/iobroker/node_modules/node-libcurl> node-pre-gyp install --fallback-to-build
    Could not run curl-config, please make sure libcurl dev package is installed.Output: /bin/sh: 1: curl-config: not found
    gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/tools/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v12.18.4gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-libcurl/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
    node-pre-gyp ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-libcurl/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlnode-pre-gyp ERR! node -v v12.18.4node-pre-gyp ERR! node-pre-gyp -v v0.15.0node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    npm
     ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm
    ERR! node-libcurl@2.2.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.2.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-09-30T22_11_09_706Z-debug.log
    ERROR: host.raspberrypi Cannot install https://github.com/peterbaumert/ioBroker.vodafone-speedtest/tarball/210ae0ca3bb57126a37505a069bd4481ef533b96: 1
    Irgendetwas mit curl brauche ich. Wie bekomme ich das?
    Danke für Eure Hilfe.
    Viele Grüße
    Chris
    #100
    @Ente
    sudo apt install libcurl-dev
    mal probiert?
    Bzw.
    sudo apt install libcurl4-openssl-dev
    E 1 Antwort Letzte Antwort
      @Ente
      mal probiert?
      Bzw.
      Ente
      #101
      @Thomas-Braun said in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
      @Ente
      mal probiert?
      Resultat:
      Bzw.
      Es kam bei letzterem keine Fehlermeldung.
      Installation des Adapters lief durch:
      Danke schön. Jetzt versuche ich mal die nächsten Schritte.
      • E Ente
        @Ente
        mal probiert?
        Resultat:
        Bzw.
        Ente
        #102
        wie bekomme ich jetzt die Datenpunkte? Der Adapter läuft:
        • E Ente
          #103
          @Ente Keine Ahnung, habe den Adapter nicht im Einsatz.
            Ente
            #104
            Ich habe nicht lange genug gewartet. DP's sind da.
            F 1 Antwort Letzte Antwort
            • E Ente
              flipkill1985
              #105
              Der Adapter läuft bei mir ein paar Stunden super.
              Dann läuft er einfach nicht mehr keine neuen Werte erst wenn ich ioBroker komplett neu starte.
              Jemand eine Idee?
              Grus
              • ChaotC Chaot
                @KarlGarry
                Um die Verwirrung zu steigern solltest du deinen Gigabit Anschluß mal hier testen:
                https://breitbandmessung.de/
                Speedtest.net und vodafone.de liefern bei mir immer falsche Ergebnisse die auch immer viel zu niedrig liegen.
                Master67M Offline
                Master67M Offline
                Master67
                #106
                @Chaot sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                @KarlGarry
                Danke, aber dort kann man (bei Vodafone) z. Zt. nur bis 400Mbit/s Messen lassen, da bin ich und andere mit einer 1.000Mbit/s Leitung schon mal raus :)
                Gruß Master67
                • Master67M Master67
                  @KarlGarry
                  ChaotC Offline
                  ChaotC Offline
                  Chaot
                  #107
                  @Master67 Das stimmt leider. Zum Zeitpunkt der Erstellung des Beitrags hat man dort noch Gigabit Anschlüsse sauber testen können. Offensichtlich haben die die Option wieder deaktiviert. Schade.
                  • KarlGarryK KarlGarry
                    @Chaot Top, läuft mittlerweile schon seit zwei Tagen wunderbar.
                    Habe die Vodafone 1000 Leitung und bekomme mit dem Vodafone Speedtest immer ~300mbit/s. Sind in 30min Abständen immer XX:00 und XX:30 Uhr.
                    Gleichzeitig lasse ich noch einen Speedtest über Speedtest.net laufen - hier bekomme ich ganz andere Ergebnisse. Läuft auch immer alle 30 Minuten, logischerweise versetzt, XX:15 und XX:45.
                    @Dr-Bakterius hat ja auch ein Unterschied zw Speedtest.net und Vodafone festgestellt.
                    Kann mir irgendwie nicht vorstellen dass die Daten so korrekt sind - limitiert mich da mein Pi4.
                    Lässt sich Breitbandmessung.de irgendwie auch loggen?
                    Abry
                    #108
                    @KarlGarry sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                    Ich habe das selbe Problem, dass bei meiner 1000er Leitung von Vodafone nur ca 300 gemessen werden. Wenn ich mit meinem Laptop direkt auf der Vodafone Seite messe, dann bekomm ich knapp 900Mbit.
                    Jemand eine Idee woran es liegen kann?
                    LG
                    • LashandanL Offline
                      LashandanL Offline
                      Lashandan
                      #109
                      ich habe den gesamten Thread durchgelesen und bekomme den Adapter einfach nicht zum Laufen.
                      Installiert ist der Adapter und ich kann die Instanz auch starten.
                      Habe lediglich den Cron-Job auf alle 10Minuten gestellt aber ich erhalte keine Objekte oder Testergbnisse.
                      Das Logfile schmeißt dementsprechende Errormeldungen:
                      Kann mir jemand weiterhelfen.
                      Oder ggf. an der Stelle einen anderen Adapter aufzeigen, mit dem ich einen zuverlässigen Speedtest machen kann?
                      Thomas BraunT peterbaumertP 2 Antworten Letzte Antwort
                      • LashandanL Lashandan
                        #110
                        @lashandan
                        Welche Versionen sind da im Spiel?
                        js-controller?
                        vodafone-speedest?
                        nodeJS? Diese sauber installiert?
                        LashandanL 1 Antwort Letzte Antwort
                          @lashandan
                          js-controller?
                          vodafone-speedest?
                          LashandanL Offline
                          LashandanL Offline
                          Lashandan
                          #111
                          Hi Thomas,
                          Node.js und NPM sehen so aus:
                          Speedtest:
                          Sind alle soweit sauber installiert.
                          Sag jetzt nicht, da fehlt noch etwas? 😰
                            Hi Thomas,
                            Speedtest:
                            wendy2702W Offline
                            wendy2702W Offline
                            #112
                            @lashandan Stell das loggen für den Adapter mal bitte auf Debug und poste die Ausgabe dann hier als Text in Code Tags </>
                              peterbaumertP Offline
                              peterbaumert
                              #113
                              @lashandan
                              npm rebuild
                              npm install
                              diese beiden befehle im iobroker/node_modules/iobroker.vodafone-speedtest ordner ausführen mit dem iobroker users
                                LashandanL Offline
                                Lashandan
                                #114
                                @peterbaumert
                                Hi Peter,
                                ich musste meinen ioBroker neu aufsetzen und komme nun bei der Installation des Adapters zu folgendem Fehler:
                                $ ./iobroker url "https://github.com/peterbaumert/ioBroker.vodafone-speedtest" --debug
                                install peterbaumert/ioBroker.vodafone-speedtest#879e618390a35dd82c8a992b6d3940eace6e241f
                                NPM version: 6.14.11
                                npm install peterbaumert/ioBroker.vodafone-speedtest#879e618390a35dd82c8a992b6d3940eace6e241f --loglevel error --prefix "/opt/iobroker" (System call)
                                > node-aead-crypto@2.2.0 preinstall /opt/iobroker/node_modules/node-aead-crypto> node lib/preinstall.js
                                node-aead-crypto not needed on this system, since all ciphers are natively supported
                                > node-libcurl@2.3.0 install /opt/iobroker/node_modules/node-libcurl> node-pre-gyp install --fallback-to-build
                                Output: /bin/sh: 1: curl-config: not foundgyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/scripts/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.10.11-v7l+
                                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v12.21.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
                                node-pre-gyp ERR! System Linux 5.10.11-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlnode-pre-gyp ERR! node -v v12.21.0node-pre-gyp ERR! node-pre-gyp -v v0.15.0node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 1
                                npm ERR! node-libcurl@2.3.0 install: `node-pre-gyp install --fallback-to-build`
                                npm ERR!
                                npm ERR! Failed at the node-libcurl@2.3.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                npm ERR!     /home/iobroker/.npm/_logs/2021-03-03T20_22_33_222Z-debug.log
                                ERROR: host.raspberrypi Cannot install peterbaumert/ioBroker.vodafone-speedtest#879e618390a35dd82c8a992b6d3940eace6e241f: 1
                                Kannst du mir hier weiter helfen?
                                Ich möchte den Adapter sehr gern verwenden.
                                Zumal ich mir zum Neuaufsetzen auch gleich einen neuen Pi verpasst habe ;)
                                Hatte vorher noch das 1GB Model und habe jetzt einen Pi 4 mit 8GB :-D
                                  @peterbaumert
                                  Hi Peter,
                                  npm ERR! errno 1
                                  npm ERR!
                                  #115
                                  @lashandan sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                  curl-config
                                  fehlt.
                                  Hast du eines der Pakete
                                  libcurl4-gnutls-dev, libcurl4-nss-dev, libcurl4-openssl-dev
                                  installiert?
                                  sudo apt update
                                  würde ich vorschlagen.
                                    LashandanL Offline
                                    Lashandan
                                    #116
                                    Hi Thomas,
                                    danke dir für den Hinweis.
                                    Ich habe den Pi heute frisch aufgesetzt und darauf nur den iOBroker installiert.
                                    Weiterhin habe ich vor später mal Grafana und NodeRed noch drauf zu packen.
                                    Aber das ist ein anderes Thema.
                                    Kannst du mir noch verraten, was dieses Paket macht bzw. wofür ich es brauche?
                                      Hi Thomas,
                                      #117
                                      @lashandan
                                      Der Adapter benötigt das Programm 'curl-config' zum funktionieren.
                                      Jedes der drei genannten Pakete stellt das bereit. Also eines der Pakete musst du halt nachinstallieren.
                                      Ich glaube das steht auch in der ReadMe zum Adapter drin.
                                        @lashandan
                                        LashandanL Offline
                                        LashandanL Offline
                                        Lashandan
                                        #118
                                        Vielen Dank Thomas 👍
                                        Das war der entscheidende Hinweis ;)
                                        Ich erhalte nun endlich meine Ergebnisse!
                                        Vielen Dank.
                                        • wendy2702W wendy2702
                                          LashandanL Offline
                                          LashandanL Offline
                                          Lashandan
                                          #119
                                          @wendy2702
                                          Hab den Adapter jetzt laufen und er liefert auch Ergebnisse.
                                          Wollte dir aber noch das Log auf Debug posten das ist aktuell:
                                          vodafone-speedtest.0	2021-03-04 11:25:30.228	info	(9436) Terminated (NO_ERROR): Without reason
                                          vodafone-speedtest.0	2021-03-04 11:25:30.226	debug	(9436) Plugin sentry destroyed
                                          vodafone-speedtest.0	2021-03-04 11:25:30.200	info	(9436) cleaned everything up...
                                          vodafone-speedtest.0	2021-03-04 11:25:30.198	info	(9436) Vodafone-Speedtest finished with 294.561mbit download speed and 11.185mbit upload speed.
                                          vodafone-speedtest.0	2021-03-04 11:25:30.197	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.197	debug	(9436) Create_state called for : Results.ping.packetLoss with value : 0.000
                                          vodafone-speedtest.0	2021-03-04 11:25:30.196	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.196	debug	(9436) Create_state called for : Results.ping.avg with value : 35.366
                                          vodafone-speedtest.0	2021-03-04 11:25:30.195	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.194	debug	(9436) Create_state called for : Results.ping.max with value : 45.387
                                          vodafone-speedtest.0	2021-03-04 11:25:30.194	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.193	debug	(9436) Create_state called for : Results.ping.min with value : 22.804
                                          vodafone-speedtest.0	2021-03-04 11:25:30.164	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.164	debug	(9436) Create_state called for : Results.upload_Mb_calc with value : 10.9282
                                          vodafone-speedtest.0	2021-03-04 11:25:30.163	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.163	debug	(9436) Create_state called for : Results.upload_MB_calc with value : 1.366025
                                          vodafone-speedtest.0	2021-03-04 11:25:30.162	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.161	debug	(9436) Create_state called for : Results.download_Mb_calc with value : 264.90592307692305
                                          vodafone-speedtest.0	2021-03-04 11:25:30.161	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.160	debug	(9436) Create_state called for : Results.download_MB_calc with value : 33.11324038461538
                                          vodafone-speedtest.0	2021-03-04 11:25:30.159	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.158	debug	(9436) Create_state called for : Results.upload_Mb with value : 11.185
                                          vodafone-speedtest.0	2021-03-04 11:25:30.158	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.157	debug	(9436) Create_state called for : Results.upload_MB with value : 1.398125
                                          vodafone-speedtest.0	2021-03-04 11:25:30.156	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.156	debug	(9436) Create_state called for : Results.download_Mb with value : 294.561
                                          vodafone-speedtest.0	2021-03-04 11:25:30.155	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.154	debug	(9436) Create_state called for : Results.download_MB with value : 36.820125
                                          vodafone-speedtest.0	2021-03-04 11:25:30.153	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:30.152	debug	(9436) Create_state called for : Results.Last_Run with value : Thu Mar 04 2021 11:25:30 GMT+0100 (GMT+01:00)
                                          vodafone-speedtest.0	2021-03-04 11:25:25.574	debug	(9436) result:{"type":"upload","value":11185}
                                          vodafone-speedtest.0	2021-03-04 11:25:12.958	debug	(9436) result:{"type":"download","value":294561}
                                          vodafone-speedtest.0	2021-03-04 11:25:02.211	debug	(9436) SBC-Init (Success):{"downstreamSpeed":0,"upstreamSpeed":0,"downstreamBooked":null,"upstreamBooked":null,"speedtestId":"ssrnxdfxtn2b","isp":"Broadband Customer Network","ipCountry":"DE","client
                                          vodafone-speedtest.0	2021-03-04 11:25:02.210	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.210	debug	(9436) Create_state called for : upstreamBooked with value : null
                                          vodafone-speedtest.0	2021-03-04 11:25:02.209	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.209	debug	(9436) Create_state called for : downstreamBooked with value : null
                                          vodafone-speedtest.0	2021-03-04 11:25:02.208	debug	(9436) Create_state called for : upstreamSpeed with value : 0
                                          vodafone-speedtest.0	2021-03-04 11:25:02.208	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.208	debug	(9436) Create_state called for : downstreamSpeed with value : 0
                                          vodafone-speedtest.0	2021-03-04 11:25:02.207	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.207	debug	(9436) Create_state called for : ipCountry with value : DE
                                          vodafone-speedtest.0	2021-03-04 11:25:02.206	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.206	debug	(9436) Create_state called for : ip with value : 92.206.72.60
                                          vodafone-speedtest.0	2021-03-04 11:25:02.205	debug	(9436) Create_state called for : isp with value : Broadband Customer Network
                                          vodafone-speedtest.0	2021-03-04 11:25:02.205	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.205	debug	(9436) Create_state called for : isCustomer with value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.204	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.204	debug	(9436) Create_state called for : modem.text with value : null
                                          vodafone-speedtest.0	2021-03-04 11:25:02.203	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.203	debug	(9436) Create_state called for : modem.name with value : null
                                          vodafone-speedtest.0	2021-03-04 11:25:02.202	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.202	debug	(9436) Create_state called for : modem.code with value : null
                                          vodafone-speedtest.0	2021-03-04 11:25:02.201	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.201	debug	(9436) Create_state called for : modem.vendor with value :
                                          vodafone-speedtest.0	2021-03-04 11:25:02.199	debug	(9436) Write value : false
                                          vodafone-speedtest.0	2021-03-04 11:25:02.198	debug	(9436) Create_state called for : modem with value : undefined
                                          vodafone-speedtest.0	2021-03-04 11:25:01.660	info	(9436) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.21.0, js-controller: 3.2.16
