  4. Zigbee Adapter sporadisch gelb
zigbee cc2531usb-port
26 Beiträge 6 Kommentatoren 3.2k Aufrufe 6 Beobachtet
  • amg_666A amg_666
    Hallo, bei meinem System kommt es immer mal wieder vor, dass der Adapter gelb ist, Adapter-Neustart bringt dann
    zigbee.0	2021-02-15 10:38:03.579	error	at Zigbee.emit (events.js:314:20)
    zigbee.0	2021-02-15 10:38:03.579	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:465:41)
    zigbee.0	2021-02-15 10:38:03.579	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:20)
    zigbee.0	2021-02-15 10:38:03.579	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:189:42)
    zigbee.0	2021-02-15 10:38:03.579	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:180:43)
    zigbee.0	2021-02-15 10:38:03.579	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:203:49)
    zigbee.0	2021-02-15 10:38:03.579	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:255:31)
    zigbee.0	2021-02-15 10:38:03.579	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
    zigbee.0	2021-02-15 10:38:03.579	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
    zigbee.0	2021-02-15 10:38:03.579	error	(1260) TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2021-02-15 10:38:03.573	error	(1260) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2021-02-15 10:38:03.572	error	(1260) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2021-02-15 10:38:03.569	info	(1260) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2021-02-15 10:38:03.567	info	(1260) terminating
    Er scheint den Stick nicht (mehr) zu erkennen. Wenn ich den Raspi runterfahre, Stick neu stecke und anschliessend wieder Raspi anschalte dann funktioniert wieder alles. Hat hier jemand eine Idee woran das liegen könnte?
    MAster/Slave System, Zigbee auf dem Master, der Stick CC2531 ist an /dev/ttyACM0 angeschlossen.
    Raspi 3b
    js-controller 3.2.16
    npm 6.14.10
    node-js 12.20.1
    omega235O Offline
    omega235O Offline
    omega235
    @amg_666
    Startet der raspi über sd-Karte?
    Hängen noch andere usb Geräte am raspi?
    • Z zautrix
      @asgothian said in Zigbee Adapter sporadisch gelb:
      Es ist lange her das ich einen grösseren Unsinn gelesen habe:
      Damit, liebe Mitlesende und liebe Mitleidende, hat sich für mich jede weitere Diskussion mit diesen "Experten" hier erledigt.
      Ich würde ja gerne mithelfen den Zigbee Adapter zu verbessern. Nur leider halte ich das bei diesem Kommentar hier für aussichtslos.
      Was sind also die Fakten?
      Es gibt in diesem Forum jede Menge Meldungen, dass der CC2531 irgendwann hängenbleibt und abstürzt. Und nur durch "Stromlos-Reset" wieder zum Arbeiten überredet werden kann.
      Diese ganzen Fehlermeldungen wurden bisher von den Entwicklern ignoriert.
      Ich schreibe jetzt hier, woran es liegt.
      Was ist die Antwort:
      Nun gut. Ich rate jedem, der den CC2531 benutzt, von dem Zigbee Adapter ab.
      Es wird sich nix ändern.
      Ich habe in den letzten 22 Jahren vielen grottenschlechten Open Source Code gesehen. Der Zigbee Adapter ist sicherlich vorne mit dabei.
      Dabei muss ich natürlich erwähnen: ioBroker und bluefox&consorten halte ich für wirklich herausragend gute Open Source Entwickler. Deswegen nutze ich auch ioBroker.
      Aber dieser Zigbee Adapter hier ... aua!
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @zautrix sagte in Zigbee Adapter sporadisch gelb:
      Ich denke das ist auch am besten so wenn die Ursache und die Wirkung mit so wenig Verständnis durcheinander gebracht wird. Im übrigen - wenn du wirklich daran gedacht hast mit zu helfen frage ich mich wo deine PR oder Verbesserungsvorschläge auf GitHub sind.
      An dieser Stelle irrst du gewaltig. Die Fehler wurden im Detail untersucht und es wurde festgestellt das die meisten Probleme aus dem Zusammenspiel zwischen dem zigbee-herdsman und der Firmware des cc2531 stammen.
      Beides sind im Übrigen keine Entwicklungen der zigbee Adapter Entwickler.
      Daher stimme ich dieser einen aussage zu:
      Das tun wir auch.
      Nebenbei - viel Spaß dabei über zigbee2mqtt und mqtt mit dem cc2531 bessere Ergebnisse zu erzielen.
      A.
      • Z zautrix
        @arteck said in Zigbee Adapter sporadisch gelb:
        finde ich schon FRECH.. ohne EINE CODE Zeile geschrieben zu haben
        Ich habe schon ziemlich viele Zeilen Code geschrieben.
        Ansonsten stimmt vieles von dem einfach nicht, was Du schreibst.
        Es werden eine Menge Fehlermeldungen eben ignoriert, was zum Neustart des Adapters führen kann.
        Und ich schreibe keine Vermutungen. Ich schreibe über Fakten.
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        Du bist gerne eingeladen die Fakten incl. code Zeilen aufzuzeigen. Ich bin echt gespannt an welcher Stelle Du da landest.
        A.
        P.s. das ist ernst gemeint. Lass deinen Behauptungen Beweise folgen.
        • Z zautrix
          arteckA Offline
          arteckA Offline
          arteck
          DANN MACH ES BESSER.. so einfach ist das.. klugscheissen kann jeder .. Fork den Adapter und gib gas..
          Z 1 Antwort Letzte Antwort
          • Z zautrix
            Z Offline
            Z Offline
            zautrix
            So, liebe Mitleser und (Ex-Mit)Leidende ( ich habe ja wegen des gefixten "Unsinns" diese Probleme nicht mehr ), genug über unfähige Programmierer aufgeregt. Ab jetzt will ich wieder lieb sein. Natürlich werde ich demnächst ( ich hoffe in den nächsten 30 Tagen) eine Zusammenfassung meiner Änderungen hier in einem extra Thread posten. Da kann dann jeder selbst sehen, ob er das bei sich selbst einbauen kann und will. Da die Programmierer das ja für " Unsinn" halten ist von dort wohl keine Hilfe bei unserem Problem zu erwarten. Aber man darf sich auch nicht zu viel erwarten. Ich habe einen Punkt gefixt. Es kann aber durchaus noch viel mehr Möglichkeiten im Adapter geben den Stick "aufs Kreuz zu legen". Und ein genereller Fix ist wegen des in vorherigen Beiträgen angesprochenen Designs nicht so leicht möglich. Ich habe jedenfalls mit meinem "Unsinn" meine regelmäßigen "unregelmäßigen Abstürze des Sticks in 3 bis 6 Tagen" beheben können. Und was die Verantwortlichen hier für einen "Mist" schreiben bezüglich "dem bösen Stick geht der Speicher aus" ist an Dümmlichkeit und Unwissenheit und Unfähigkeit nicht mehr zu überbieten. Denn bevor im Adapter das grundlegende Zigbee System geändert wurde lief dieser "böse Stick" bei mir (und bei anderen, es gibt viele Belege dafür in Beiträgen in diesem Forum) Monate ohne Probleme durch. Und da gingen auch noch die Gruppen ohne Probleme ... aber das ist ein anderes Thema.
            Ich muss aber erst einmal die wesentlichen Änderungen für diesen Bugfix aus meinen zahlreichen Änderungen an diesem Adapter extrahieren. Ich habe nämlich um überhaupt fähig zu sein länger ( meine Untersuchungen um das Problem zu lokalisieren und zu fixen haben mehrere Nächte und sicher über 21 Stunden gebraucht) an diesem Adapter arbeiten zu können äußerst zahlreiche Änderungen an dem Code vornehmen müssen um meinen Brechreiz beim Schauen auf den wirklich grausamen originalen Programmcode erfolgreich unterdrücken zu können. Ständig auf die Tastatur kotzen zu müssen hätte die Sache nur verzögert. Ich weiß, das ist eine wirkliche Schwäche von mir bei grauenhaft schlechten Programmierungskünsten anfangen müssen zu würgen. Aber so hat halt jeder seine Fehler...
            • arteckA arteck
              Z Offline
              Z Offline
              zautrix
              Gute Idee! Warum bin ich da nicht drauf gekommen?
              Aber mal im Ernst. (Du bist hier wenigstens noch einigermaßen korrekt). Ob man den Adapter überhaupt vernünftig fixen kann ist mir noch nicht ganz klar. Ich lasse meine Änderungen schon seit Weihnachten bei mir laufen und es sieht besser aus. Aber bei nichtdeterministischen Fehlern hat das nicht unbedingt etwas zu sagen...
              AsgothianA Z arteckA 3 Antworten Letzte Antwort
              • Z zautrix
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                Wenn dem so ist, dann
                • mach doch einfach einen Pull Request mit deinen Anpassungen am Zigbee Adapter. Dann musst du die Sachen nicht erst irgendwo ausbuddeln, sondern kannst Direkt diese Anpassungen einem grösseren Publikum zukommen lassen.
                • Z zautrix
                  Z Offline
                  Z Offline
                  zautrix
                  Liebe Leute, liebe Programmierer
                  ich weiß ja nicht was ihr hier überhaupt treibt.
                  Als ich angefangen habe mich mit dem Problem zu beschäftigen musste ich erst einmal feststellen, dass noch nicht einmal (waren es Log oder Error ) Meldungen korrekt dargestellt werden. In einer Meldung kamen nur die Namen der Variablen, aber nicht deren Inhalt. Deswegen musste ich daraus schließen: So richtig Ahnung was ihr hier überhaupt macht, habt ihr nicht....
                  AsgothianA amg_666A 2 Antworten Letzte Antwort
                  • Z zautrix
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    Lieber @Zautrix.
                    Du kannst so lange wie du magst hier Kommentare schreiben. Ich werde mich damit erst dann wieder beschäftigen wenn ich
                    • einen (oder mehrere) PR auf Github vorfinde wo deine Anpassungen drin sind, oder
                    • ich hier code Zeilen und die geänderten Dateien finde.
                    Nur damit wir nicht aneinander vorbei schreiben: Die von denen Du so vollmundig behauptest das sie keine Ahnung haben sind ausschliesslich verantwortlich für den Code der sich im Zigbee Adapter selber (sprich ioBroker.zigbee) befindet. Alles was sich im zigbee-herdsman-converters oder im zigbee-herdsman befindet liegt ausserhalb dessen was wir direkt beeinflussen.
                    A.
                    • Z zautrix
                      amg_666A Offline
                      amg_666A Offline
                      amg_666
                      @zautrix Diese Community lebt davon, dass man sich gegenseitig hilft, und wer Bock und Ahnung hat kann ja gerne weitere (oder verbesserte) Adapter beisteuern.
                      Also, wenn die hier "kiene Ahnung haben was sie machen", dann hilf doch mit und schreib einen vernünftigen Adapter.
                      Ich würd den vielleicht sogar installieren, wenn er wirklich besser ist, allerdings ist mein zigbee Adapter "grün" und funktioniert tadellos (inkl. Logging).
                      • amg_666A amg_666
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @amg_666 na das ist schon mal gut... sry dass wir dein Thread gekappert haben
                        • Z zautrix
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @zautrix ick freu mir schon druff... auf ein umfassendes redesign .. @Asgothian das wird super.. hörmal.. wir haben endlich den EXPERTEN den wir jeehhh gesucht haben... da wir ja ehh keine Ahnung haben.. und nichtmal Programmieren können in dem " schwerwiegenden softwarerechnischen Designfehler"
                          klar ich sehs ein.. @zautrix danke dass du mich ENDLICH aufgeklärt hast.. und stell dir vor es ist keinem Aufgefallen dass ich keine Ahnung habe...
                          diese Freiheit...
                          • arteckA arteck
                            amg_666A Offline
                            amg_666A Offline
                            amg_666
                            @arteck sagte in Zigbee Adapter sporadisch gelb:
                            Ja, das ist ja das tolle hier, mir wurde geholfen, thread ist vom 15.02. und seitdem läuft es stabil...
