  4. Zigbee Adapter sporadisch gelb
zigbee cc2531usb-port
26 Beiträge 6 Kommentatoren 3.2k Aufrufe 6 Beobachtet
  • amg_666A amg_666
    Hallo, bei meinem System kommt es immer mal wieder vor, dass der Adapter gelb ist, Adapter-Neustart bringt dann
    zigbee.0	2021-02-15 10:38:03.579	error	at Zigbee.emit (events.js:314:20)
    zigbee.0	2021-02-15 10:38:03.579	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:465:41)
    zigbee.0	2021-02-15 10:38:03.579	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:20)
    zigbee.0	2021-02-15 10:38:03.579	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:189:42)
    zigbee.0	2021-02-15 10:38:03.579	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:180:43)
    zigbee.0	2021-02-15 10:38:03.579	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:203:49)
    zigbee.0	2021-02-15 10:38:03.579	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:255:31)
    zigbee.0	2021-02-15 10:38:03.579	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
    zigbee.0	2021-02-15 10:38:03.579	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
    zigbee.0	2021-02-15 10:38:03.579	error	(1260) TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2021-02-15 10:38:03.573	error	(1260) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2021-02-15 10:38:03.572	error	(1260) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2021-02-15 10:38:03.569	info	(1260) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2021-02-15 10:38:03.567	info	(1260) terminating
    Er scheint den Stick nicht (mehr) zu erkennen. Wenn ich den Raspi runterfahre, Stick neu stecke und anschliessend wieder Raspi anschalte dann funktioniert wieder alles. Hat hier jemand eine Idee woran das liegen könnte?
    MAster/Slave System, Zigbee auf dem Master, der Stick CC2531 ist an /dev/ttyACM0 angeschlossen.
    Raspi 3b
    js-controller 3.2.16
    npm 6.14.10
    node-js 12.20.1
    arteckA Offline
    arteckA Offline
    arteck
    @amg_666 geht das auch wenn du nur den
    adapter stoppst
    stick rausziehst
    wieder rein
    und adapter startest
    • arteckA arteck
      adapter stoppst
      stick rausziehst
      wieder rein
      amg_666A Offline
      amg_666A Offline
      amg_666
      @arteck Das hat beim letzten Mal nicht geklappt
      • amg_666A amg_666
        amg_666A Offline
        amg_666A Offline
        amg_666
        schrieb am zuletzt editiert von amg_666
        @arteck Wir haben grade im "zigbee adapter thread" gechattet (update lief bei mir nicht, nach neustart raspi gings dann wieder.
        Aaaber: Adapter ist mal wieder gelb, wird nicht grün:
        zigbee.0	2021-02-15 21:21:18.116	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
        zigbee.0	2021-02-15 21:21:18.116	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        zigbee.0	2021-02-15 21:21:18.116	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
        zigbee.0	2021-02-15 21:21:18.116	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
        zigbee.0	2021-02-15 21:21:18.116	error	at new Promise (<anonymous>)
        zigbee.0	2021-02-15 21:21:18.116	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
        zigbee.0	2021-02-15 21:21:18.116	error	at Generator.next (<anonymous>)
        zigbee.0	2021-02-15 21:21:18.116	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
        zigbee.0	2021-02-15 21:21:18.116	error	(2220) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
        zigbee.0	2021-02-15 21:21:18.113	error	(2220) Failed to start Zigbee
        Jetzt hab ich es wie von dir oben vorgeschlagen gemacht:
        1. Adapter angehalten
        2. Stick rausgezogen und wieder gesteckt
        3. Adapter gestartet
        Adapter ist grün, also alles i.O., aber komisch ist es schon dass er den ab und zu nicht findet...
        Thomas BraunT arteckA 2 Antworten Letzte Antwort
        • amg_666A amg_666
          @amg_666 Hast du mal einen anderen USB-Port ausprobiert?
            amg_666A Offline
            amg_666A Offline
            amg_666
            @thomas-braun Meinst du HW Defekt? Kann ich mal machen, würde mich dann hier melden falls es wieder auftritt
            • amg_666A amg_666
              arteckA Offline
              arteckA Offline
              arteck
              @amg_666 ja das Ding hängt sich ab und zu mal auf.. manche vertragen den reboot nicht..
              • amg_666A amg_666
                @amg_666
                Zumindest beim Pi4 sind die USB3-Ports etwas zickig. Und der Stick ist auch dafür bekannt, eine kleine Diva zu sein.
                • amg_666A amg_666
                  Raspi 3b
                  npm 6.14.10
                  node-js 12.20.1
                  Z Offline
                  Z Offline
                  zautrix
                  @amg_666 said in Zigbee Adapter sporadisch gelb:
                  Ja.
                  Es liegt an einem schwerwiegenden softwarerechnischen Designfehler des zigbee Adapters.
                  Lass mich raten.
                  Du hast irgendwo eine Leuchte, wo 2 (oder mehr) Zigbee Lampen drin sind? Und dieses werden von dir mit einem normalen Lichschalter öfter an und aus geschaltet?
                  Es kann aber auch sein, dass zufällig 2 Zigbee Geräte sich gleichzeitig mit dem Stick unterhalten wollen und es dann zum Absturz kommt.
                  Also, das ganze geht so:
                  Zwei Zigbee Lampen bekommen gleichzeitig Strom.
                  Sie versuchen den Stick anzufunken um sich anzumelden.
                  Es kann sein, dass das für beide klappt.
                  Es kann auch sein, dass das nicht klappt. D.h. ein Lampe unterhält sich gerade mit dem Stick und die andere "funkt" dazwischen. Dann meldet der Stick einen Error in der Kommunikation mit der ersten oder zweiten Lampe.
                  Ist erst einmal nicht schlimm. Ein Error in Funk-Kommunikation kann mal passieren. Vor allem wenn zu viele Geräte gleichzeitig funken.
                  Dieser gemeldete Error in der Kommunikation wird aber vom Zigbee Adapter auf "grausame Art" behandelt.
                  Es wird nämlich dieser Fehler im Adapter gar nicht behandelt, sondern eine Exception geworfen, die vom System aufgefangen wird und den Adapter beendet und neu startet:
                  In deinem Log ist das zu sehen an
                  "unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch()"
                  Das ist zwar jetzt möglicherweise speziell in deinem Log ein Folgefehler von dem ursprünglichen Fehler, aber genau diese "unhandled promise rejection" bei Kommunikationsfehlern bewirkt "das Abschießen" und Neustarten des zigbee Adapters.
                  Aber der Adapter war ja gerade bei der Kommunikation mit 2 neu eingeschalteten Lampen. Und diese Kommunikation wird nicht immer sauber beendet.
                  Es kommt also ab und zu einmal vor, dass dann intern der Stick abstürzt. Da hilft dann nur ein "reset" des Sticks durch stromlos machen.
                  Wenn man also bei Kommunikationsfehlern softwareseitig diesen einfach ignoriert und im Adapter nix macht läuft der Adapter mit dem Stick wesentlich stabiler.
                  Es gibt aber softwareseitig im zigbee Adapter viele Möglichkeiten bei den unterschiedlichsten Fehlern ( nicht nur bei dem von mir skizzierten Kommunikationsfehler beim Einschalten von 2 Lampen ) diese "unhandled promise rejection" zu bekommen. Und da besteht halt die Gefahr, dass der Stick irgendwann einmal abstürzt.
                  Wie gesagt, diese Abstürze geschehen nicht immer sofort, sondern es kann auch ein paar Tage gut laufen bis "nix mehr geht".
                  Ich fand das irgendwie blöd immer den Stick stromlos machen zu müssen, damit es wieder funzt. Ist nicht meine Vorstellung von "smart" home. Deswegen habe ich mir mal den Grund dafür angesehen.
                  -2
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    @zautrix sagte in Zigbee Adapter sporadisch gelb:
                    ahhhh ja... ok dann her mit dem PR... wenn du es besser kannst.. sollte eine Korrektur nicht so schwer sein...
                    zu den 2 Lampen.. ist nur eine Vermutung deinerseits.. gehen wir mal von aus Du hast recht.. dann ist es aber immer noch so im Zigbeenetzwerk die Messages unabhänging von er reihenfolge verarbeitet werden.. soll heissen .. ich kann 5 Lampen oder mehr auf einmal stromlos machen.. somit ZERSTÖRE ich dass Netzwerk da hier Routerfunktionalistäten abgeschaltet werden.. hängen Enddevices dran hast du ein Problem...
                    weiter gehts mit adm EINSCHALTEN alle 5 Lampen melden sich im Netz an .. und das Netz reorganisiert sich neu.. klapt bei mit mit 56 Geräten einwanfrei und ich kenn leute bei den es mit 160 Geräten kein Problem ist.. ABER nicht mit dem popeligen cc3531.. den hier ist DAS PROBLEM..dem geht ein der Speicher aus.. je länger der läuft und je grösser das Netz desto schneller verabschiedet der sich...
                    und wenn du dich schon mal mit dem Thema auseinander setzt dann schaue auch auf die Abhängigkeiten die WIR benutzen auf die wir kein einfluss haben wenn DIESE abschmieren.. ok hier könnte man gegenwirken und indem abhängigen Projekt dies beheben.. wenn es der Besitzer dessen sich da einlässt..UND wir dazu Zeitfinden..
                    wen ndu genauer nachschaust behandeln WIR in dem Adapter jegliche exception die WIR auch behandeln können..
                    dazu kommt noch dass die Firmware ab und an mal das Netzwerk zu macht .. simit ist auchjegliche kommunikation nicht möglich...
                    ODER
                    die Firmware ist ja auch nicht Fehlerfrei (wie jede Software) schon oft gesehen und getestet dass sich diese im Speicher mit einem Speicherüberlauf zerstört.
                    darüberhinaus ist jedes System unterschiedlich..der eine hat ein Multihost mit 2 unterschieldichen Versionen des Adapter.. schon erlebt..
                    oder der Stick wird am USB HUB betrieben mit 2 Festplatten und was weiss ich noch.. so dass die Stromversorgung zusammenbricht..
                    und und und.. ich könte inzwischen Romane schreiben darüber...
                    zum schluss noch...ich finde klasse deine Analyse ..ABERmit dieser ist es nicht getan.. wenn du mitwirken willst bist du hiermit herzlichst eingeladen.. ich gebe jeglichen PR von dir nach überprüfung frei... aber einfach zu sagen
                    finde ich schon FRECH.. ohne EINE CODE Zeile geschrieben zu haben
                    Z 1 Antwort Letzte Antwort
                    • Z zautrix
                      Ja.
                      Lass mich raten.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      Es ist lange her das ich einen grösseren Unsinn gelesen habe:
                      Erst einmal ein wenig Statistik zu dem was @zautrix zu den 2 Lampen geschrieben hat. Ich habe in meinem Zigbee Netz eine Lampe mit 6 identischen Zigbee-Leuchten. Und diese schalte ich auch von Zeit zu Zeit mal stromlos. Wenn ich den Strom wieder einschalte melden sich 6 Leuchten Gleichzeitig beim Zigbee Adapter an. Ich hatte bisher keinen einzigen Absturz dadurch.
                      Das deckt sich auch mit der Methode mit der Nachrichten im Zigbee behandelt werden. Auf der untersten Ebene werden diese nach den betroffenen Geräten getrennt worauf schon im Zigbee-Herdsman mit MultiThreading die Kommunikation mit den einzelnen Geräten vor nimmt. Das Zigbee Protokoll gibt dieses im Übrigen auch vor, da auf Grund des Aufbaus des Netzes der Koordinator nicht sicher stellen kann das er während der Kommunikation mit Gerät A nicht auch Nachrichten von Gerät B bekommt (und diese im Fall von Batterie betriebenen Geräten auch sofort behandeln muss, da diese die Nachricht nicht "mal eben" wiederholen können)
                      Das also ein Fehler bei der Funk Kommunikation den Adapter abstürzen lässt ist so nicht korrekt. Zwar finden sich im Log immer noch "error" Meldungen mit Stack-Trace die auf unvollständige Kommunikation hin deuten, allerdings ohne das deswegen der Adapter abstürzt.
                      Schwieriger ist es wenn ein Gerät selber "malformed", also syntaktisch inkorrekte Meldungen sendet. Dann kann es vorkommen das der für das Gerät geschriebene Converter diese Nachricht unsauber verarbeitet und den dabei auftretenden Fehler nicht behandelt. In diesem Fall sind die Fehler aber eindeutig einem bestimmten Gerät zuzuordnen und werden darauf basierend auch behoben.
                      Der Zigbee Adapter selber nutzt die asynchrone Kommunikation intensiv, und versucht bei allen Aufrufen der Zigbee Bibliotheken die geworfenen Fehler zu fangen. Alleine die Tatsache das eine Log-Meldung vorhanden ist zeigt das dieses funktioniert - sie wird nämlich vom Zigbee Adapter generiert.
                      Was der Adapter nicht abfangen kann ist wenn in der Kette der aufgerufenen Funktionen an einer Stelle ein Bruch auftritt der nicht entsprechend behandelt wird. Es sind genau diese die zu den schwer zu lokalisierenden "promise rejection" Fehlern führen.
                      Ich denke bevor Du Dich so weit aus dem Fenster lehnst solltest Du statt dessen daran mit arbeiten die (hoffentlich wirklich) von Dir gefundenen Stellen an denen Fehler nicht behandelt werden im Code zu eliminieren. Mitarbeit bei der Adapter Entwicklung ist immer gerne gesehen.
                      A.
                      Nachtrag: Es gibt aktuell einen Bereich bei dem immer noch promise rejections auftreten die nicht gefangen wurden. Das ist wenn der Adapter beendet wurde und in der Folge die noch laufenden Threads nacheinander auf ggf. ungültige Datenstrukturen stossen. In diesem Fall ist aber immer vorher ein "adapter stop" im Log zu finden und die Fehlermeldungen die auch gerne im Forum gepostet werden sind zumeist reine Folgefehler eines viel früher auftretenden und auch sauber behandelten Fehlers - in 95% der Fälle beim Start des Adapters.
                      • arteckA arteck
                        ODER
                        Z Offline
                        Z Offline
                        zautrix
                        @arteck said in Zigbee Adapter sporadisch gelb:
                        Ich habe schon ziemlich viele Zeilen Code geschrieben.
                        Ansonsten stimmt vieles von dem einfach nicht, was Du schreibst.
                        Es werden eine Menge Fehlermeldungen eben ignoriert, was zum Neustart des Adapters führen kann.
                        Und ich schreibe keine Vermutungen. Ich schreibe über Fakten.
                        • Z Offline
                          Z Offline
                          zautrix
                          @asgothian said in Zigbee Adapter sporadisch gelb:
                          Damit, liebe Mitlesende und liebe Mitleidende, hat sich für mich jede weitere Diskussion mit diesen "Experten" hier erledigt.
                          Ich würde ja gerne mithelfen den Zigbee Adapter zu verbessern. Nur leider halte ich das bei diesem Kommentar hier für aussichtslos.
                          Was sind also die Fakten?
                          Es gibt in diesem Forum jede Menge Meldungen, dass der CC2531 irgendwann hängenbleibt und abstürzt. Und nur durch "Stromlos-Reset" wieder zum Arbeiten überredet werden kann.
                          Diese ganzen Fehlermeldungen wurden bisher von den Entwicklern ignoriert.
                          Ich schreibe jetzt hier, woran es liegt.
                          Was ist die Antwort:
                          Nun gut. Ich rate jedem, der den CC2531 benutzt, von dem Zigbee Adapter ab.
                          Es wird sich nix ändern.
                          Ich habe in den letzten 22 Jahren vielen grottenschlechten Open Source Code gesehen. Der Zigbee Adapter ist sicherlich vorne mit dabei.
                          Dabei muss ich natürlich erwähnen: ioBroker und bluefox&consorten halte ich für wirklich herausragend gute Open Source Entwickler. Deswegen nutze ich auch ioBroker.
                          Aber dieser Zigbee Adapter hier ... aua!
                          AsgothianA arteckA Z 3 Antworten Letzte Antwort
                          -2
                          • amg_666A amg_666
                            Raspi 3b
                            npm 6.14.10
                            node-js 12.20.1
                            omega235O Offline
                            omega235O Offline
                            omega235
                            @amg_666
                            Startet der raspi über sd-Karte?
                            Hängen noch andere usb Geräte am raspi?
                            • Z zautrix
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              Ich denke das ist auch am besten so wenn die Ursache und die Wirkung mit so wenig Verständnis durcheinander gebracht wird. Im übrigen - wenn du wirklich daran gedacht hast mit zu helfen frage ich mich wo deine PR oder Verbesserungsvorschläge auf GitHub sind.
                              An dieser Stelle irrst du gewaltig. Die Fehler wurden im Detail untersucht und es wurde festgestellt das die meisten Probleme aus dem Zusammenspiel zwischen dem zigbee-herdsman und der Firmware des cc2531 stammen.
                              Beides sind im Übrigen keine Entwicklungen der zigbee Adapter Entwickler.
                              Daher stimme ich dieser einen aussage zu:
                              Das tun wir auch.
                              Nebenbei - viel Spaß dabei über zigbee2mqtt und mqtt mit dem cc2531 bessere Ergebnisse zu erzielen.
                              A.
                              • Z zautrix
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                Du bist gerne eingeladen die Fakten incl. code Zeilen aufzuzeigen. Ich bin echt gespannt an welcher Stelle Du da landest.
                                A.
                                P.s. das ist ernst gemeint. Lass deinen Behauptungen Beweise folgen.
                                • Z zautrix
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  DANN MACH ES BESSER.. so einfach ist das.. klugscheissen kann jeder .. Fork den Adapter und gib gas..
                                  • Z zautrix
                                    Z Offline
                                    Z Offline
                                    zautrix
                                    So, liebe Mitleser und (Ex-Mit)Leidende ( ich habe ja wegen des gefixten "Unsinns" diese Probleme nicht mehr ), genug über unfähige Programmierer aufgeregt. Ab jetzt will ich wieder lieb sein. Natürlich werde ich demnächst ( ich hoffe in den nächsten 30 Tagen) eine Zusammenfassung meiner Änderungen hier in einem extra Thread posten. Da kann dann jeder selbst sehen, ob er das bei sich selbst einbauen kann und will. Da die Programmierer das ja für " Unsinn" halten ist von dort wohl keine Hilfe bei unserem Problem zu erwarten. Aber man darf sich auch nicht zu viel erwarten. Ich habe einen Punkt gefixt. Es kann aber durchaus noch viel mehr Möglichkeiten im Adapter geben den Stick "aufs Kreuz zu legen". Und ein genereller Fix ist wegen des in vorherigen Beiträgen angesprochenen Designs nicht so leicht möglich. Ich habe jedenfalls mit meinem "Unsinn" meine regelmäßigen "unregelmäßigen Abstürze des Sticks in 3 bis 6 Tagen" beheben können. Und was die Verantwortlichen hier für einen "Mist" schreiben bezüglich "dem bösen Stick geht der Speicher aus" ist an Dümmlichkeit und Unwissenheit und Unfähigkeit nicht mehr zu überbieten. Denn bevor im Adapter das grundlegende Zigbee System geändert wurde lief dieser "böse Stick" bei mir (und bei anderen, es gibt viele Belege dafür in Beiträgen in diesem Forum) Monate ohne Probleme durch. Und da gingen auch noch die Gruppen ohne Probleme ... aber das ist ein anderes Thema.
                                    Ich muss aber erst einmal die wesentlichen Änderungen für diesen Bugfix aus meinen zahlreichen Änderungen an diesem Adapter extrahieren. Ich habe nämlich um überhaupt fähig zu sein länger ( meine Untersuchungen um das Problem zu lokalisieren und zu fixen haben mehrere Nächte und sicher über 21 Stunden gebraucht) an diesem Adapter arbeiten zu können äußerst zahlreiche Änderungen an dem Code vornehmen müssen um meinen Brechreiz beim Schauen auf den wirklich grausamen originalen Programmcode erfolgreich unterdrücken zu können. Ständig auf die Tastatur kotzen zu müssen hätte die Sache nur verzögert. Ich weiß, das ist eine wirkliche Schwäche von mir bei grauenhaft schlechten Programmierungskünsten anfangen müssen zu würgen. Aber so hat halt jeder seine Fehler...
                                    • arteckA arteck
                                      Z Offline
                                      Z Offline
                                      zautrix
                                      Gute Idee! Warum bin ich da nicht drauf gekommen?
                                      Aber mal im Ernst. (Du bist hier wenigstens noch einigermaßen korrekt). Ob man den Adapter überhaupt vernünftig fixen kann ist mir noch nicht ganz klar. Ich lasse meine Änderungen schon seit Weihnachten bei mir laufen und es sieht besser aus. Aber bei nichtdeterministischen Fehlern hat das nicht unbedingt etwas zu sagen...
                                      AsgothianA Z arteckA 3 Antworten Letzte Antwort
                                      • Z zautrix
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        Wenn dem so ist, dann
                                        • mach doch einfach einen Pull Request mit deinen Anpassungen am Zigbee Adapter. Dann musst du die Sachen nicht erst irgendwo ausbuddeln, sondern kannst Direkt diese Anpassungen einem grösseren Publikum zukommen lassen.
                                        • Z zautrix
                                          Z Offline
                                          Z Offline
                                          zautrix
                                          Liebe Leute, liebe Programmierer
                                          ich weiß ja nicht was ihr hier überhaupt treibt.
                                          Als ich angefangen habe mich mit dem Problem zu beschäftigen musste ich erst einmal feststellen, dass noch nicht einmal (waren es Log oder Error ) Meldungen korrekt dargestellt werden. In einer Meldung kamen nur die Namen der Variablen, aber nicht deren Inhalt. Deswegen musste ich daraus schließen: So richtig Ahnung was ihr hier überhaupt macht, habt ihr nicht....
                                          AsgothianA amg_666A 2 Antworten Letzte Antwort
