  4. js-controller 3.2 jetzt im STABLE!
275 Beiträge 58 Kommentatoren 130.6k Aufrufe 51 Beobachtet
  • J
    J
    Jack01
    #70
    Danke an die Entwickler und Tester!
    Bis auf ein paar komische Fehlermeldungen (die wohl nichts mit dem Update zu tan haben?) ist es problemlos durchgelaufen.
    raspberrypi
    Platform linux
    Betriebssystem linux
    Architektur arm
    CPUs 4
    Geschwindigkeit 700 MHz
    Modell ARMv7 Processor rev 3 (v7l)
    RAM 3.74 GB
    System Betriebszeit 70 T. 22:58:00
    Node.js v12.20.2 (Es gibt eine neuere Version: v12.21.0)
    NPM 6.14.11
    Festplatte Größe 14.09 GB
    Festplatte frei 10.7 GB
    Anzahl der Adapter 331
    Betriebszeit 00:06:00
    Aktive Instanzen 13
    Hostname raspberrypi
    pi@raspberrypi:~ $ iobroker upgrade self
    Update js-controller from @3.1.6 to @3.2.16
    NPM version: 6.14.11
    npm install iobroker.js-controller@3.2.16 --loglevel error --unsafe-perm --prefi                                        x "/opt/iobroker" (System call)
    Package pangocairo was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pangocairo.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pangocairo' found
    gyp: Call to 'pkg-config pangocairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.79-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.20.2
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.4.79-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.20.2
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    Starting node restart.js
    Proxmox LXC
    Node.js: V24.22.1
    NPM: 11.19.1
    JS-controller: 7.2.5
    • J Jack01
      raspberrypi
      Platform linux
      Architektur arm
      CPUs 4
      RAM 3.74 GB
      NPM 6.14.11
      Aktive Instanzen 13
      gyp ERR! not ok
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #71
      @jack01
      Zu den 'komischen' Meldungen:
      sudo apt update
      sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-dev
      sudo apt dist-upgrade
      sudo reboot
      Dann sollten die künftig nicht mehr auftauchen.
      J apollon77A 2 Antworten Letzte Antwort
        @jack01
        sudo apt update
        sudo reboot
        J
        J
        Jack01
        #72
        @thomas-braun sagte in js-controller 3.2 jetzt im STABLE!:
        @jack01
        Ohne den iobroker zu stoppen?
        Proxmox LXC
        Node.js: V24.22.1
        NPM: 11.19.1
        • J Jack01
          @jack01
          Thomas BraunT
          Thomas BraunT
          #73
          @jack01 Kannste machen wie ein Dachdecker.
          Beim notwendigen! Reboot wird der ioBroker natürlich auch neugestartet.
            @jack01
            sudo apt update
            sudo reboot
            apollon77A
            apollon77A
            #74
            @thomas-braun Das sollte iobroker fix inzwischen auf installieren :-)
            • apollon77A apollon77
              Thomas BraunT
              Thomas BraunT
              #75
              @apollon77
              Ja, aber kein Kernel-Update, was da auch noch in der Pipeline war.
                @apollon77
                apollon77A
                apollon77A
                #76
                @thomas-braun Ja, korrekt. war aucf die anderen pakete bezogen
                  Thomas BraunT
                  Thomas BraunT
                  #77
                  @apollon77
                  Wenn ich nicht den alten Kernel gesehen hätte dann hätte ich auch den Fixer vorgeschlagen.
                  • O
                    O
                    Octopyrox
                    #78
                    danke für die super Arbeit!! Und sorry, wenn das nicht hier her gehört. Dachte ich fange mal hier an...
                    Ich glaube, seit dem Update hab ich ein Problem mit dem FHEM Adapter. Adapter ist grün, bekomme aber folgende Fehlermeldung im Log:
                    • (32628) > SyntaxError jsonlist2 of FHEM device --> stop instance fhem.0 [main] [syncFHEM]32628) > SyntaxError jsonlist2 of FHEM device --> stop instance fhem.0 [main] [syncFHEM]
                    • (32628) State "system.adapter.fhem.1.alive" has no existing object, this might lead to an error in future versions
                    Somit kann ich keine Daten von FHEM empfangen oder senden.
                    Was kann ich da machen?
                    Vielen Dank schon mal!!
                    Viele Grüße
                    Markus
                    apollon77A LausiDL 2 Antworten Letzte Antwort
                    • O Octopyrox
                      Viele Grüße
                      Markus
                      apollon77A
                      apollon77A
                      #79
                      @markus-dickel sagte in js-controller 3.2 jetzt im STABLE!:
                      naja das heisst das dein FHEM keine validen daten zurückgibt ... das kann mit controller nichts zu tun haben
                      N 1 Antwort Letzte Antwort
                      • O Octopyrox
                        Viele Grüße
                        Markus
                        LausiDL
                        LausiDL
                        LausiD
                        #80
                        @markus-dickel
                        Es gab mal eine fehlerhafte FHEM Version...würde vorschlagen ein Update von FHEM durchzuführen.
                        Gruß LausiD
                        Doku zum FHEM Adapter
                        Aktuelles zum FHEM Adapter
                        Test FHEM Adapter
                        O 2 Antworten Letzte Antwort
                        • LausiDL LausiD
                          @markus-dickel
                          Gruß LausiD
                          O
                          O
                          Octopyrox
                          #81
                          @lausid Hi, versteh zwar nicht warum es an einem Tag lief und am nächsten nicht, wenn ich bei FHEM gar keine Updates gemacht hab aber ich mach einfach Mal eins...
                          Mal schauen.
                          • LausiDL LausiD
                            @markus-dickel
                            Gruß LausiD
                            O
                            O
                            Octopyrox
                            #82
                            @lausid Update von FHEM hat es gebracht!! Versteh ich zwar nicht aber Danke @LausiD !!
                              N
                              N
                              Nordischerjung
                              schrieb am zuletzt editiert von Nordischerjung
                              #83
                              @apollon77
                              Moin ich hab auch versucht das Update zu machen. Irgend etwas ist da mächtig schief gegangen.
                              Erst konnte ich den iOBroker nicht normal stopen, musste es mit : sudo killall -u iobroker machen.
                              Dann hab ich
                              iobroker update
                              durchgeführt.
                              Dann kam das folgende LOG mit weiteren Anzeigen die ich schon mal gemacht habe
                              NPM version: 6.14.8
                              npm install iobroker.js-controller@3.2.16 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 22
                              npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
                              npm ERR! Exit status 22
                              npm ERR!
                              npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
                              npm ERR!     /home/iobroker/.npm/_logs/2021-03-01T09_30_42_079Z-debug.log
                              host.iobroker Cannot install iobroker.js-controller@3.2.16: 22
                              sb@iobroker:/opt/iobroker$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v
                              /usr/bin/nodejs
                              v12.19.0
                              /usr/bin/node
                              v12.19.0
                              /usr/bin/npm
                              6.14.8
                              sb@iobroker:/opt/iobroker$ iobroker status
                              internal/modules/cjs/loader.js:834
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:831:15)
                                  at Function.Module._load (internal/modules/cjs/loader.js:687:27)
                                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                                  at internal/main/run_main_module.js:17:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              sb@iobroker:/opt/iobroker$ iobroker start
                                throw err;
                                requireStack: []
                              sb@iobroker:/opt/iobroker$ iobroker list
                                throw err;
                                requireStack: []
                              sb@iobroker:/opt/iobroker$ iobroker fix
                              library: loaded
                              Library version=2021-01-23
                              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                              und hier der komplette Log 2021-03-01T09_30_42_079Z-debug.log
                              der Ordner iobroker.js-controller in /opt/iobroker/node_modules/ ist auch nicht mehr vorhanden
                              Gruß Nordischerjung
                              sonnige Grüße von der Ostsee
                              • N Nordischerjung
                                @apollon77
                                Dann hab ich
                                iobroker update
                                durchgeführt.
                                NPM version: 6.14.8
                                npm ERR! errno 22
                                npm ERR!
                                /usr/bin/nodejs
                                v12.19.0
                                /usr/bin/node
                                v12.19.0
                                /usr/bin/npm
                                6.14.8
                                  throw err;
                                  requireStack: []
                                  throw err;
                                  requireStack: []
                                  throw err;
                                  requireStack: []
                                library: loaded
                                apollon77A
                                apollon77A
                                #84
                                @nordischerjung Versuch mal iobroker fix als allererstes. Danach in /opt/iobroker nimm mal den direkten Install Befehl "npm i iobroker.js-controller@3.2.16"
                                  N
                                  N
                                  Nordischerjung
                                  #85
                                  @apollon77
                                  das kommt bei iobroker fix
                                  library: loaded
                                  Gruß Nordischerjung
                                  • N Nordischerjung
                                    @apollon77
                                    library: loaded
                                    apollon77A
                                    apollon77A
                                    #86
                                    @nordischerjung Ok, dann das npm install zuerst :-)) Irgendwie hat das update bzw npm komisch edinge getan. sieht an sich ok aus ... aber strange
                                    N foxriver76F 2 Antworten Letzte Antwort
                                      N
                                      N
                                      Nordischerjung
                                      #87
                                      @apollon77
                                      Guck an, hat funktioniert, startet wieder. Danke schön
                                      Gruß Nordischerjung
                                        foxriver76F
                                        foxriver76F
                                        foxriver76
                                        #88
                                        @apollon77 Komische Dinge ist relativ, setup first hat keine Verbindung zur Objects DB bekommen. Doof ist natürlich, dass dann der alte Controller auch futsch ist, wenn setup first fehlschlägt und der Nutzer mit einer unvollständigen Installation zurückbleibt. Evtl. hilft ja schon der erhöhte Timeout der eigentlich für die JSONL DB eingebaut wurde. Oder man macht das install Skript unfehlbar und loggt bei fail, dass man setup first manuell aufrufen soll, mit dem Nachteil, dass viele Nutzer dies überlesen werden.
                                        Videotutorials & mehr
                                        • foxriver76F foxriver76
                                          apollon77A
                                          apollon77A
                                          #89
                                          @foxriver76 Jupp, an dem Punkt war ich für mich auch :-) Die Gründe warum kein DB COnnect sind halt hier interessant. Würde mal abwarten wie oft so ein Fall passiert. Und wer weiss was ggf noch/wirklich los war :-)
                                          33.2k
                                          84.3k
