  4. trådfri nach Update Fehlermeldungen?
    6.6k
18 Beiträge 6 Kommentatoren 2.2k Aufrufe 4 Beobachtet
  • M Michaelnorge
    Hallo
    Ich habe Fehlermeldungen des Trådfri-Adapters im Log entdeckt.
    Die tauchen beim Start des Adapters auf sowie wenn ich die Rolläden steuere.
    Beim Öffnen der Handyapp wurde ich informiert daß das Gateway einen Update bekommen hat.
    Version Gateway: 1.13.21
    Version Rolläden: 2.2.009
    Version Signalverstärker: 2.2.005
    Kann diese Fehlermeldungen jemand bestätigen?
    Liegt es am Update des Gateways?
    Viele Grüße
    Michael
    2021-02-22 18:56:30.689 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.690 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"TRADFRI Signal Repeater","2":"","3":"2.2.005","6":1,"7":4354}
    2021-02-22 18:56:30.707 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.707 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":94}
    2021-02-22 18:56:30.720 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.721 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":94}
    2021-02-22 18:56:30.732 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.732 - warn: tradfri.0 (15441) object was: {"0":"\u0002KE","1":"TRADFRI open/close remote","2":"","3":"2.2.010","6":3,"7":4549,"9":47}
    2021-02-22 18:56:30.743 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.744 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":98}
    2021-02-22 18:56:30.755 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.755 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":95}
    2021-02-22 18:56:30.767 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.768 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"KADRILJ roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":97}
    2021-02-22 18:56:30.782 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.782 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":96}
    2021-02-22 18:56:30.795 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.796 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":97}
    2021-02-22 18:56:30.807 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.808 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":99}
    2021-02-22 18:56:30.823 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.823 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":98}
    2021-02-22 18:56:30.841 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.841 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":99}
    @michaelnorge
    Ja, habe ich auch. Dürfte am Update des Gateways liegen.
    Kannst mal ein issue beim Adapter dazu aufmachen, ich bin noch nicht dazu gekommen.
    BTW: Keine Fehlermeldungen, lediglich warnings.
    • M Michaelnorge
      Hallo
      Viele Grüße
      Michael
      @michaelnorge
      Ich habs für dich übernommen...
      https://github.com/AlCalzone/ioBroker.tradfri/issues/546
      LashandanL 1 Antwort Letzte Antwort
        @michaelnorge
        LashandanL Offline
        LashandanL Offline
        Lashandan
        schrieb am zuletzt editiert von Lashandan
        Kann den Fehler (Die Warnung) bestätigen, habe ihn auch entdeckt und bin grade bei der Suche auf deinen Eintrag gestoßen ;)
        Super das ihr gleich nen Issue erstellt habt.
        • LashandanL Lashandan
          @aaron-körtge
          Vielleicht kannst du mal schauen, ob du Meldungen/Geräte hast, die noch nicht im Issue verhanden sind und dann ggf. dort ergänzen.
          • AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            Kann hier jemand nachvollziehen, was "5849": 0 bedeutet?
            Das sind die Einstellungen nach einem Stromausfall, ich habe aber nur AN (2) und letzte Einstellung (4) in der App. Anscheinend gibt es auch 0. (AUS?)
            • AlCalzoneA AlCalzone
              @alcalzone
              Zumindest im GUI der App sind es ja auch nur die beiden Optionen.
              Ich habe allerdings eine Birne, die auf einem alten Firmwarestand ist (<2) und noch kein zigbee3 kann. Für diese gibt es keine Einstellungen zum Status nach Stromausfall. Vielleicht ist das die Null?
                @alcalzone
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @thomas-braun Könnte sein
                  AlCalzoneA Offline
                  AlCalzone
                  Bitte v2.7.0 probieren
                    @alcalzone So auf den ersten Blick bleibt das log jetzt ruhig. Muss ich mal was länger beobachten. Log Level : Info
                    [Edit:] Nach ein paar Stunden herumspielen: Alles ruhig im Log.
                      MarkusP
                      v.2.7.0 funktioniert bei mir leider nicht. Erhalte die gleichen Warnmeldungen im Log und zusätzlich lassen sich die Lampen aber nicht mehr Schalten bzw. beim Versuch zu Schalten geht der Adapter auf gelb. Bin daher wieder auf v2.6.5 zurück. Seit dem gibt es aber auch keine Warnmeldungen mehr im Log.
                      • LashandanL Offline
                        LashandanL Offline
                        Lashandan
                        @alcalzone Ich wollte die Version 2.7.0 installieren und testen.
                        Ich kann im Änderungsprotokoll des Adapters auch die Version 2.7.0 sehen allerdings nicht installieren.
                        Was mache ich falsch?
                          @aaron-körtge
                          Diese Version ist über das Latest/Beta-Repositroy verfügbar.
                            @alcalzone sagte in trådfri nach Update Fehlermeldungen?:
                            @thomas-braun sagte in trådfri nach Update Fehlermeldungen?:
                            cool
                            Hab die 2.6.5 im stable installiert, dann auf latest umgestellt um zu sehen, ob da schon die 2.7.0 ist - wird nur die 2.6.3 angeboten 😂
                            tradfri.0	2021-02-25 21:14:30.808	warn	(27370) object was: {"5706":"ebb63e","5707":4711,"5708":62138,"5709":36155,"5710":25932,"5849":2,"5850":1,"5851":101,"9003":0}
                            tradfri.0	2021-02-25 21:14:30.808	warn	(27370) found unknown property with key 5849
                            tradfri.0	2021-02-25 21:14:30.808	warn	(27370) object was: {"0":"IKEA of Sweden","1":"TRADFRI bulb E27 CWS opal 600lm","2":"","3":"1.3.013","6":1,"7":10241}
                            tradfri.0	2021-02-25 21:14:30.807	warn	(27370) found unknown property with key 7
                            werde morgen in aller Ruhe dann mal die 2.7.0 testen, wenn die Lampen nicht mehr gebraucht werden
                              cool
                              Müsste heute reingetropft sein:
                              github:	2.7.0
                              latest:	2.7.0 for 0 days
                              stable:	2.6.5 for 87 days
                              HomoranH M 2 Antworten Letzte Antwort
                                github:	2.7.0
                                war es gerade eben nicht.
                                Muss mal den anderen Pfad probieren. - aber erst morgen
                                  github:	2.7.0
                                  Michaelnorge
                                  Ich benutze die 2.7.0 seit vorgestern, der Adapter ist soweit ruhig und schmeisst keine Meldungen mehr ins Log.
                                  • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
                                  • M MarkusP
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    @markusp Wenn das bestehen bleibt, bitte mal 2.7.0 mit loglevel debug starten und mir schicken.
                                    Vermutlich hast du mit 2.6.5 jetzt auch die neue Version der node-tradfri-client library, die die geänderten Kommandos wenigstens versteht.
