  4. trådfri nach Update Fehlermeldungen?
    6.6k
18 Beiträge 6 Kommentatoren 2.2k Aufrufe 4 Beobachtet
    Michaelnorge
    Hallo
    Ich habe Fehlermeldungen des Trådfri-Adapters im Log entdeckt.
    Die tauchen beim Start des Adapters auf sowie wenn ich die Rolläden steuere.
    Beim Öffnen der Handyapp wurde ich informiert daß das Gateway einen Update bekommen hat.
    Version Gateway: 1.13.21
    Version Rolläden: 2.2.009
    Version Signalverstärker: 2.2.005
    Kann diese Fehlermeldungen jemand bestätigen?
    Liegt es am Update des Gateways?
    Viele Grüße
    Michael
    2021-02-22 18:56:30.689 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.690 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"TRADFRI Signal Repeater","2":"","3":"2.2.005","6":1,"7":4354}
    2021-02-22 18:56:30.707 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.707 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":94}
    2021-02-22 18:56:30.720 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.721 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":94}
    2021-02-22 18:56:30.732 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.732 - warn: tradfri.0 (15441) object was: {"0":"\u0002KE","1":"TRADFRI open/close remote","2":"","3":"2.2.010","6":3,"7":4549,"9":47}
    2021-02-22 18:56:30.743 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.744 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":98}
    2021-02-22 18:56:30.755 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.755 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":95}
    2021-02-22 18:56:30.767 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.768 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"KADRILJ roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":97}
    2021-02-22 18:56:30.782 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.782 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":96}
    2021-02-22 18:56:30.795 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.796 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":97}
    2021-02-22 18:56:30.807 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.808 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":99}
    2021-02-22 18:56:30.823 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.823 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":98}
    2021-02-22 18:56:30.841 - warn: tradfri.0 (15441) found unknown property with key 7
    2021-02-22 18:56:30.841 - warn: tradfri.0 (15441) object was: {"0":"IKEA of Sweden","1":"FYRTUR block-out roller blind","2":"","3":"2.2.009","6":3,"7":4487,"9":99}
    • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
    • M Michaelnorge
      Hallo
      Viele Grüße
      Michael
      @michaelnorge
      Ja, habe ich auch. Dürfte am Update des Gateways liegen.
      Kannst mal ein issue beim Adapter dazu aufmachen, ich bin noch nicht dazu gekommen.
      BTW: Keine Fehlermeldungen, lediglich warnings.
      • M Michaelnorge
        Hallo
        Viele Grüße
        Michael
        @michaelnorge
        Ich habs für dich übernommen...
        https://github.com/AlCalzone/ioBroker.tradfri/issues/546
        LashandanL 1 Antwort Letzte Antwort
          @michaelnorge
          LashandanL Offline
          LashandanL Offline
          Lashandan
          schrieb am zuletzt editiert von Lashandan
          Kann den Fehler (Die Warnung) bestätigen, habe ihn auch entdeckt und bin grade bei der Suche auf deinen Eintrag gestoßen ;)
          Super das ihr gleich nen Issue erstellt habt.
          • LashandanL Lashandan
            @aaron-körtge
            Vielleicht kannst du mal schauen, ob du Meldungen/Geräte hast, die noch nicht im Issue verhanden sind und dann ggf. dort ergänzen.
            • AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              Kann hier jemand nachvollziehen, was "5849": 0 bedeutet?
              Das sind die Einstellungen nach einem Stromausfall, ich habe aber nur AN (2) und letzte Einstellung (4) in der App. Anscheinend gibt es auch 0. (AUS?)
              • AlCalzoneA AlCalzone
                @alcalzone
                Zumindest im GUI der App sind es ja auch nur die beiden Optionen.
                Ich habe allerdings eine Birne, die auf einem alten Firmwarestand ist (<2) und noch kein zigbee3 kann. Für diese gibt es keine Einstellungen zum Status nach Stromausfall. Vielleicht ist das die Null?
                  @alcalzone
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @thomas-braun Könnte sein
                    AlCalzoneA Offline
                    AlCalzone
                    Bitte v2.7.0 probieren
                      @alcalzone So auf den ersten Blick bleibt das log jetzt ruhig. Muss ich mal was länger beobachten. Log Level : Info
                      [Edit:] Nach ein paar Stunden herumspielen: Alles ruhig im Log.
                        MarkusP
                        v.2.7.0 funktioniert bei mir leider nicht. Erhalte die gleichen Warnmeldungen im Log und zusätzlich lassen sich die Lampen aber nicht mehr Schalten bzw. beim Versuch zu Schalten geht der Adapter auf gelb. Bin daher wieder auf v2.6.5 zurück. Seit dem gibt es aber auch keine Warnmeldungen mehr im Log.
                        • LashandanL Offline
                          LashandanL Offline
                          Lashandan
                          @alcalzone Ich wollte die Version 2.7.0 installieren und testen.
                          Ich kann im Änderungsprotokoll des Adapters auch die Version 2.7.0 sehen allerdings nicht installieren.
                          Was mache ich falsch?
                            @aaron-körtge
                            Diese Version ist über das Latest/Beta-Repositroy verfügbar.
                              @alcalzone sagte in trådfri nach Update Fehlermeldungen?:
                              @thomas-braun sagte in trådfri nach Update Fehlermeldungen?:
                              cool
                              Hab die 2.6.5 im stable installiert, dann auf latest umgestellt um zu sehen, ob da schon die 2.7.0 ist - wird nur die 2.6.3 angeboten 😂
                              tradfri.0	2021-02-25 21:14:30.808	warn	(27370) object was: {"5706":"ebb63e","5707":4711,"5708":62138,"5709":36155,"5710":25932,"5849":2,"5850":1,"5851":101,"9003":0}
                              tradfri.0	2021-02-25 21:14:30.808	warn	(27370) found unknown property with key 5849
                              tradfri.0	2021-02-25 21:14:30.808	warn	(27370) object was: {"0":"IKEA of Sweden","1":"TRADFRI bulb E27 CWS opal 600lm","2":"","3":"1.3.013","6":1,"7":10241}
                              tradfri.0	2021-02-25 21:14:30.807	warn	(27370) found unknown property with key 7
                              werde morgen in aller Ruhe dann mal die 2.7.0 testen, wenn die Lampen nicht mehr gebraucht werden
                                cool
                                Müsste heute reingetropft sein:
                                github:	2.7.0
                                latest:	2.7.0 for 0 days
                                stable:	2.6.5 for 87 days
                                HomoranH M 2 Antworten Letzte Antwort
                                  github:	2.7.0
                                  war es gerade eben nicht.
                                  Muss mal den anderen Pfad probieren. - aber erst morgen
                                    github:	2.7.0
                                    Michaelnorge
                                    Ich benutze die 2.7.0 seit vorgestern, der Adapter ist soweit ruhig und schmeisst keine Meldungen mehr ins Log.
                                    • M MarkusP
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      @markusp Wenn das bestehen bleibt, bitte mal 2.7.0 mit loglevel debug starten und mir schicken.
                                      Vermutlich hast du mit 2.6.5 jetzt auch die neue Version der node-tradfri-client library, die die geänderten Kommandos wenigstens versteht.
