  4. ZIGBEE-Adapter bleibt "gelb"...
zigbee adapter
21 Beiträge 3 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • ub.privatU Offline
    ub.privatU Offline
    ub.privat
    @arteck ... Sicher schon oft diese Frage beantwortet, doch leider werde ich aus dem gelesenem nicht schlau.
    Der Adapter bleibt gelb!
    Ich habe gemäß Anleitung den Port ausgelesen:
    Entsprechend die Einstellungen vorgenommen:
    Habe den Adapter bereits neu installiert, leider immer die gleiche Auswirkung...
    Folgender Log:
    zigbee.0	2021-02-22 10:40:30.437	error	(5110) Cannot read property 'getEntries' of null
    zigbee.0	2021-02-22 10:40:30.436	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
    zigbee.0	2021-02-22 10:40:30.436	error	at Zigbee.emit (events.js:314:20)
    zigbee.0	2021-02-22 10:40:30.436	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
    zigbee.0	2021-02-22 10:40:30.436	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
    zigbee.0	2021-02-22 10:40:30.436	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
    zigbee.0	2021-02-22 10:40:30.436	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    zigbee.0	2021-02-22 10:40:30.436	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
    zigbee.0	2021-02-22 10:40:30.436	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:273:31)
    zigbee.0	2021-02-22 10:40:30.436	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
    zigbee.0	2021-02-22 10:40:30.436	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
    zigbee.0	2021-02-22 10:40:30.436	error	(5110) TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2021-02-22 10:40:30.434	error	(5110) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2021-02-22 10:40:30.433	error	(5110) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2021-02-22 10:40:30.432	warn	(5110) Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0	2021-02-22 10:40:30.431	info	(5110) terminating
    zigbee.0	2021-02-22 10:40:30.430	warn	(5110) Failed to stop zigbee during startup
    zigbee.0	2021-02-22 10:40:30.429	info	(5110) Zigbee: disabling joining new devices.
    zigbee.0	2021-02-22 10:40:30.426	info	(5110) cleaned everything up...
    zigbee.0	2021-02-22 10:40:30.410	error	(5110) Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
    zigbee.0	2021-02-22 10:40:30.410	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0	2021-02-22 10:40:30.410	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2021-02-22 10:40:30.410	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:157:45)
    zigbee.0	2021-02-22 10:40:30.410	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
    zigbee.0	2021-02-22 10:40:30.410	error	at new Promise (<anonymous>)
    zigbee.0	2021-02-22 10:40:30.410	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
    zigbee.0	2021-02-22 10:40:30.410	error	at Generator.next (<anonymous>)
    zigbee.0	2021-02-22 10:40:30.410	error	at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:159:28)
    zigbee.0	2021-02-22 10:40:30.410	error	(5110) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
    zigbee.0	2021-02-22 10:40:30.409	error	(5110) unhandled promise rejection: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
    zigbee.0	2021-02-22 10:40:30.408	error	(5110) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2021-02-22 10:40:10.625	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0	2021-02-22 10:40:10.625	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2021-02-22 10:40:10.625	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:157:45)
    zigbee.0	2021-02-22 10:40:10.625	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
    zigbee.0	2021-02-22 10:40:10.625	error	at new Promise (<anonymous>)
    zigbee.0	2021-02-22 10:40:10.625	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
    zigbee.0	2021-02-22 10:40:10.625	error	at Generator.next (<anonymous>)
    zigbee.0	2021-02-22 10:40:10.625	error	at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:159:28)
    zigbee.0	2021-02-22 10:40:10.625	error	(5110) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
    zigbee.0	2021-02-22 10:40:10.624	error	(5110) Failed to start Zigbee
    zigbee.0	2021-02-22 10:40:10.437	info	(5110) Installed Version: iobroker.zigbee@1.4.4
    zigbee.0	2021-02-22 10:40:10.415	info	(5110) Starting Zigbee npm ...
    zigbee.0	2021-02-22 10:40:10.414	info	(5110) Try to reconnect. 1 attempts left
    zigbee.0	2021-02-22 10:40:00.415	info	(5110) Installed Version: iobroker.zigbee@1.4.4
    Habe ich etwas übersehen??? Bitte um Hilfe...
    Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
    • ub.privatU ub.privat
      Folgender Log:
      @ub-privat sagte in ZIGBEE-Adapter bleibt "gelb"...:
      Starte die Kiste mal sauber durch.
      sudo reboot
      ub.privatU 1 Antwort Letzte Antwort
        Folgender Log:
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @ub-privat
        Läuft ggf. Die deconz Software im Hintergrund noch ?
        A.
          sudo reboot
          ub.privatU Offline
          ub.privatU Offline
          ub.privat
          @thomas-braun ... gesagt, getan und keine Änderung
          • AsgothianA Asgothian
            @ub-privat
            A.
            ub.privatU Offline
            ub.privatU Offline
            ub.privat
            @asgothian ... zumindest nicht auf dem Rechner, mit dem ich auf den Raspi zugreife.
            Könnte eventuell auf dem Raspi selbst laufen?
              @ub-privat
              systemctl status deconz deconz-gui
                @ub-privat
                ub.privatU Offline
                ub.privatU Offline
                ub.privat
                schrieb am zuletzt editiert von ub.privat
                @thomas-braun sagte in ZIGBEE-Adapter bleibt "gelb"...:
                Am Anfang grün: active - running
                In der letzten Zeile steht "inactive"... sollte also nicht laufen!
                  @ub-privat Das sind aber zwei Paar Schuhe.
                  deconz läuft, deconz-gui nicht.
                  sudo systemctl stop deconz
                  sudo systemctl disable deconz
                  Dann sollte der Zugriff auf das Gerät wieder möglich sein.
                  Und bitte keine Screenshots von KonsolenTEXT, sondern TEXT auch als solchen in CodeTags hier ins Forum posten.
                  ub.privatU 3 Antworten Letzte Antwort
                    ub.privatU Offline
                    ub.privatU Offline
                    ub.privat
                    Sorry - in der Eile...
                    Starte das System nochmals nach der Änderung neu.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @ub-privat hattest du die deconz Software auf dem Radio installiert ?
                      Wenn nein bitte folgendes tun:
                      • zigbee Adapter beenden
                      • conbee abstecken
                      • 60 Sekunden warten
                      • conbee anstecken
                      • das heutige log löschen
                      • zigbee Adapter starten
                      • 30 Sekunden warten
                      • zigbee Adapter anhalten
                      Das log dieser 30 Sekunden zwischen Start und stop posten.
                      A.
                        ub.privatU Offline
                        ub.privatU Offline
                        ub.privat
                        @Asgothian
                        Nun kann ich auf den ZigBee Adapter zugreifen, d.h. er ist "grün".
                        Nach den Änderungen
                        Bleibt nun zu recht der DeConz-Adapter gelb. Das bedeutet, dass jeweils nur ein Adapter arbeiten darf!?
                        Mit den Konsolenbefehlen:
                        sudo systemctl start deconz
                        sudo systemctl enable deconz
                        Würde ich dann wieder den deConz-Adapter starten?
                        Kann mit diesen Einstellungen noch auf die Phoscon-App unter WIN10 zugegriffen werden?
                          • conbee abstecken
                          • conbee anstecken
                          A.
                          ub.privatU Offline
                          ub.privatU Offline
                          ub.privat
                          @asgothian
                          Noch eine Frage zur Verwendung des Adapters. Nach Betätigen des Buttons "Kopplung starten" kann ich mit dem Pairen von Zigbee-Komponenten beginnen?
                          Liest der Adapter auch bereits vorhandene Lichter, Gruppen aus dem DeConz-Stick aus?
                            ub.privatU Offline
                            ub.privatU Offline
                            ub.privat
                            @thomas-braun ... das war die Lösung! DANKE.
                              @ub-privat
                              Ist wie beim ollen Highlander:
                              Es kann nur einen geben!
                              Also entweder deconz ODER der zigbee-Adapter darf auf das Gerät zugreifen.
                                @Asgothian
                                Nach den Änderungen
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @ub-privat
                                Wenn du sowohl deconz als auch den zigbee Adapter nutzen willst brauchst du 2 zigbee Koordinatoren - einen für deconz, einen für iobroker.zigbee.
                                @asgothian
                                Nein, denn diese Informationen sind nicht auf dem Stick sondern in der deconz Software hinterlegt.
                                A.
                                @ub-privat
                                Das gilt solange du nur einen zigbee Stick hast.
                                ub.privatU Thomas BraunT 2 Antworten Letzte Antwort
                                  @ub-privat
                                  @asgothian
                                  A.
                                  @ub-privat
                                  ub.privatU Offline
                                  ub.privatU Offline
                                  ub.privat
                                  @asgothian
                                  @Thomas-Braun
                                  Erst einmal vielen Dank für eure schnelle Hilfe! Nun muss ich mal schauen, wie ich mit dem ZigBee-Adapter zurecht komme.
                                  Jetzt heißt es, alle Geräte neu anlernen...
                                  Falls ich wieder "zurück" möchte, sind folgende Befehle einzugeben:
                                    @ub-privat
                                    @asgothian
                                    A.
                                    @ub-privat
                                    @asgothian
                                    Klar, bei zwei Geräten hättest du aber ja auch zwei Dateien.
                                    Dann kann jeder Service auf 'sein' Gerät zugreifen.
                                      @asgothian
                                      @Thomas-Braun
                                      So als Hintergrund:
                                      startet den Service in einem laufenden System.
                                      legt den Service in den (vereinfacht gesagt) 'Autostart', wird also beim booten schon gestartet. Deswegen kommt der zigbee-Adapter auch nicht dran, der deconz-Service kommt dem immer zuvor, weil der viel früher gestartet wird.
                                        So als Hintergrund:
                                        ub.privatU Offline
                                        ub.privatU Offline
                                        ub.privat
                                        @thomas-braun - DANKE! Wieder viel dazu gelernt! Nun muss ich Ordnung ins System bringen...
                                          ub.privatU Offline
                                          ub.privatU Offline
                                          ub.privat
                                          @Thomas-Braun
                                          @Asgothian
                                          ich muss euch Beide nochmals befragen.
                                          1. Welchen "Mehrwert" erhalte ich durch den ioBroker.zigbee Adapter?
                                          2. Gibt es hierzu auch die Möglichkeit über Smartphone einzugreifen?
                                          3. Wenn ich zwei DeConz Sticks betreibe, werden dann alle Sensoren/Aktoren von beiden direkt angesprochen? Hierzu muss ich dann gemäß der heute gewonnen Erkenntnisse, den Start entsprechend einstellen!?
                                          Ich hoffe, meine Fragen sind verständlich gestellt... Danke für eure Geduld!
