  4. RFlink (LOS GEHT ES ) Bestellung d.Hardware (20€) + 5€ Spende an Forum f.d. Adapter (crowdfunding like :-)
    6.3k
698 Beiträge 105 Kommentatoren 265.6k Aufrufe 13 Beobachtet
    Maxtox
    #215
    @Marcolotti:
    Hallo Maxtox,
    Ich hoffe du hast dir keinen Virus eingefangen und überträgst ihn dann auf den Arduino.
    Gute Besserung.
    P.S. In Hoffnung dass ich die ganze Weihnachts-Deko meiner Frau dann endlich automatisiert starten kann… `
    P.S.: aber sicher doch ;-)
    Arduino MEGA 2560 R3 / ioBroker / DOino Sketch
      Stuntteam
      #216
      New RFLink firmware (R45) now available!
      R45 Changelog:
      • New Device: Silvercrest switch set IAN276299
      • New Device: Silvercrest switch set IAN113854
      • New Device: Silvercrest switch set IAN91210
      • New Device: Quigg switch set GT-9000 (Tevion/Globaltronics/ALDI)
      • New Device: Unitec switch set 4811 model 50028 (Intertek)
      • New Device: Cotech switch set 36-6361
      • New Device: Sartano switch set, Model 50028, HN 10047
      • New Device: Electro Depot switch set, article code 940557
      • New Device: BL999 weather sensor
      • New Device: Digi-Tech 4-LD14554 Outdoor temperature sensor (Thanks: PJA)
      • New Device: PLC-T4022G X10 RF to Powerline
      • New Device: X10 UR76 E Remote Control
      • New Device: Konig Alarm system sensors
      • New Device: Alecto 1200 alternative protocol version
      • New Device: Oregon EW99
      • New Device: Smartwares RM174RF Smoke detector
      • New Device: FirstLine FWS802 Pool Thermometer (Thanks: BC)
      • New Device: Liwin Shutters / Blinds controller
      • Fixed: MiniGPIO command structure
      • Fixed: Conrad RSL pair command added
      • Fixed: Warema EWFS (Thanks: SH)
      • Fixed: Removed Ningbo debug message
      • Fixed: Mebus protocol detection for Auriol Z29536 IAN55982
      • Fixed: Removed debug messages on Atlantic protocol
      • Fixed: Milight color and brightness changing on groups
      • Fixed: DKW2012 Humidity conversion
      • Fixed: DKW2012 Wind speed conversion (Thanks: HJ)
      • Fixed: Xiron ID sometimes had an incorrect bit
      • Fixed: Blyss/Avidsen transmit
      • Fixed: Aster protocol split on/off and dim/bright into separate devices
      • Fixed: Improved detection of WH5029
      • Fixed: Improved HE800 protocol detection
      • Fixed: Improved detection of Cleverwatts, Kerui and compatible devices
      • Fixed: Proper handling of incoming serial commands for KAKU and related devices
      • Fixed: Improved Chacon EMW200 detection
      • Added: RTS protocol option to swap ON/OFF command
      • Added: RTS long TX option to extend the RTS transmit time
      • Added: "Settings reset" feature
      • Added: Extended Gaposa protocol
      • Added: Lacrosse V3 protocol support for negative temperature values
      Available on http://www.nemcon.nl/blog2
      Enjoy!
      • E Offline
        Elektroman
        #217
        Hallo Maxtox,
        Ich schaffe es glaube ich nicht dir eine PN zu schicken
        Kannst du mir eine mal schicken? Vielleicht kann ich darauf antworten
        Danke!!!
          Maxtox
          #218
          ALLE 433Mhz sind fertig und gehen morgen raus!
          FROHE WEIHNACHTEN!
            krissi
            #219
            Hat schon jemand Post bekommen? Ich bin gespannt wie ein Flitzebogen! :lol:
            ioBroker in VM (unraid) / CCU2 für IP FB-Heizungssteuerung raspi3 / 3x Echo Dot / IKEA Tradfri / zigBee mit Conbee II
            • a200A Offline
              a200A Offline
              a200
              #220
              @krissi:
              Hat schon jemand Post bekommen? Ich bin gespannt wie ein Flitzebogen! :lol: `
              nope… aber die Spannung steig! :o
              IoBroker auf QNAP TS-451, Raspi und NUC
                Marcolotti
                #221
                habe vorhin meinen Arduino von Maxtox bekommen. Scheint ganz gut zu funktionieren. Er findet trotz meiner abgelegenen Wohnlage vielerei Sensor. Frage mich gerade woher der Sensor mit den -20°C kommt? Sollte etwa mein Gefrierschrank echt was drauf haben? Aktuell sind es draußen 6°C
                Andere Frage:
                Ich habe bei Pollin mir 3 SETs mit PFS-3 geholt. Wenn ich diese Anlernen will, werden die vorhandenen überschrieben, trotz anderer Codierung.
                Maxtox? Kannst du mir da helfen?
                Gruß Marco
                CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
                  knopers1
                  #222
                  ja, mein Gerät kam auch heute an. Prima Arbeit. Das Gehäuse ist Top. Sogar die neuste Firmware ist drauf.
                  Gerade angesteckt und alles läuft wie vorher mit meinem Gerät.
                  Ich lasse jetzt das Gerät vom Maxtox dran. Mit dem Gehäuse ist es kompackt und die Reichweite ist auch o.k.
                  Danke Dir!
                  • P Offline
                    pepp86
                    #223
                    Meine Hardware ist auch heute angekommen. Funktioniert tadelos.
                    Leider bin ich wohl zu doof das Gehäuse zusammenzubauen. Kann mir jemand mal ein Foto vom zusammengebauten Gehäuse schicken? Danke!! :-)
                    Eine Frage noch. Ich habe ein Temperatursensor draußen hängen mit einer Innenstation. Die Signale werden auch sauber empfangen.
                    Jetzt ist meine Überlegung, die Temperatursensoren draußen zu ersetzen, und die Temperatur vom zentralen HM Thermostat zu verwenden.
                    Kann ich über rflink beliebige Temperaturen an meine Innenstation senden?
                    Nochmal Dank!
                      knopers1
                      #224
                      Die Anleitung zum Zusammenbauen ist doch in der Tüte mit drin.
                      • P Offline
                        pepp86
                        #225
                        @knopers1:
                        Die Anleitung zum Zusammenbauen ist doch in der Tüte mit drin. `
                        Ja, habe so ein Gehäuse auch schonmal für den BananaPi zusammengebaut. Aber das jetzt will in keiner Kombination passen. :-D
                        Vermutlich mache ich irgendwo einen Fehler.
                        • a200A Offline
                          a200A Offline
                          a200
                          #226
                          Das Teil ist da und….. läuft! :D
                          Für die Leitungen habe ich die hintere Wand weggelassen.
                          Firmware ist aktuell!
                          Krieg aber die 1.0.6 rflink von github unter raspi3 nicht installiert. Idee?
                          Vielen Dank an Maxtox!
                            #227
                            Bin nur am Handy.
                            Habe aber gesehen
                            Not found git
                            Bitte git installieren
                            sudo apt-get install git
                            Dann nochmals die Installation des Adapters versuchen.
                            • a200A Offline
                              a200A Offline
                              a200
                              #228
                              Strange…
                              Wenn ich es manuell starte, dann läuft er durch. gibt aber die 1.0.5 aus und nicht die 1.0.6.
                              ` > root@miniyou:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.rf … all/master --production --prefix "/opt/iobroker"
                              serialport@4.0.7 install /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport
                              node-pre-gyp install --fallback-to-build
                              node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz
                              node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.7.0 (node-v46 ABI) (falling back to source compile with node-gyp)
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build'
                              CXX(target) Release/obj.target/serialport/src/serialport.o
                              CXX(target) Release/obj.target/serialport/src/serialport_unix.o
                              CXX(target) Release/obj.target/serialport/src/serialport_poller.o
                              SOLINK_MODULE(target) Release/obj.target/serialport.node
                              COPY Release/serialport.node
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build'
                              serialport@2.1.2 install /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build'
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build'
                              iobroker.rflink@1.0.5 node_modules/iobroker.rflink
                              ├── request@2.79.0 (aws-sign2@0.6.0, forever-agent@0.6.1, tunnel-agent@0.4.3, oauth-sign@0.8.2, is-typedarray@1.0.0, caseless@0.11.0, stringstream@0.0.5, aws4@1.5.0, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, uuid@3.0.1, qs@6.3.0, combined-stream@1.0.5, mime-types@2.1.13, tough-cookie@2.3.2, form-data@2.1.2, hawk@3.1.3, http-signature@1.1.1, har-validator@2.0.6)
                              ├── avrgirl-arduino@1.11.6 (intel-hex@0.1.1, graceful-fs@4.1.11, chip.avr.avr109@1.0.6, browser-serialport@2.0.3, colors@1.1.2, minimist@1.2.0, awty@0.1.0, stk500-v2@1.0.2, stk500@1.0.4, async@2.1.4, serialport@4.0.7)
                              └── serialport@2.1.2 (bindings@1.2.1, sf@0.1.7, nan@2.2.1, bluebird@3.4.6, object.assign@4.0.4, optimist@0.6.1) `
                                knopers1
                                #229
                                Das Problem hatte ich auch gerade…..Ich wollte aber von 1.03 auf 1.05 !
                                Exakt die Warnungen hatte ich auch... Ich habe eine neue iobroker Seite aufgemacht und sah dass es trotz der Fehler auf 1.05 laut Anzeige gesprungen ist.
                                • lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  #230
                                  Bei mir bleibt nachdem ich den adapter rflink 1.0.5 deaktiviere unter Objekte info -> connection auf true. Sollte er sich nicht aktualisieren und auf false gehen?
                                  Wie aktualisiere ich auf sketch 45? Alles ueber die Instanzen -> Einstellungen des adapters?
                                  Host: NUC8i3 mit Proxmox:
                                  • Slave: Pi4
                                    krissi
                                    #231
                                    Alles gut, geht ohne Probleme :D
                                    @ Rainer
                                    Hi, hast Du den am NUC angeschlossen?
                                    Gruß,
                                    Andre
                                    • Alex1808A Offline
                                      Alex1808A Offline
                                      Alex1808
                                      #232
                                      @lobomau:
                                      Wie aktualisiere ich auf sketch 45? Alles ueber die Instanzen -> Einstellungen des adapters? `
                                      1. Wurde schon ausdiskutiert, einfach ignorieren, bei senden vom Kommando der wird schon grün :)
                                      2. Ja, Datei laden, Endpacken, und über Einstellungen des Adapters aktualisieren.
                                      • eric2905E Offline
                                        eric2905E Offline
                                        eric2905
                                        #233
                                        @Maxtox:
                                        ALLE 433Mhz sind fertig und gehen morgen raus! `
                                        Und die anderen?
                                        Bei mir ist noch nichts angekommen.
                                        Gruß,
                                        Eric
                                          Maxtox
                                          #234
                                          Die 868 werden als CUL ausgeliefert, da im OOK auf dieser Frequenz zu wenig Geräte gibt
                                          Sonst, kann ich dir es schon liefern… Gib mir bescheid
