  4. (gelöst)(Frage) ModubusTCP Adapter ?
    6.0k
57 Beiträge 5 Kommentatoren 9.1k Aufrufe 4 Beobachtet
  • HumidorH Humidor
    @wendy2702 inzwischen ist es mir etwas klarer
    die Instanz geht nur auf Grün, wenn eine Abfrage läuft, sonst Gelb.
    ich sehe allerdings Fehler :
    modbus.1	2021-02-13 12:55:10.673	debug	(17194) Closing client on purpose.
    modbus.1	2021-02-13 12:55:09.671	debug	(17194) Cleaning up request fifo.
    modbus.1	2021-02-13 12:55:09.671	debug	(17194) Socket closed with error
    modbus.1	2021-02-13 12:55:09.601	info	(17194) Disconnected from slave 192.168.0.98
    modbus.1	2021-02-13 12:55:09.600	debug	(17194) Closing client on purpose.
    modbus.1	2021-02-13 12:55:09.550	warn	(17194) Poll error count: 12 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.1	2021-02-13 12:55:09.549	debug	(17194) Received pdu describes an error.
    modbus.1	2021-02-13 12:55:09.463	debug	(17194) Poll holdingRegs DevID(1) address 40100 - 71 bytes
    modbus.1	2021-02-13 12:55:09.327	debug	(17194) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 12:55:09.327	debug	(17194) Poll device 1
    modbus.1	2021-02-13 12:55:09.326	info	(17194) Connected to slave 192.168.0.98
    modbus.1	2021-02-13 12:55:05.735	debug	(17194) sendTo "listUart" to system.adapter.admin.0 from system.adapter.modbus.1
    modbus.1	2021-02-13 12:55:05.735	info	(17194) List of port: [{"path":"/dev/ttyAMA0"}]
    modbus.1	2021-02-13 12:55:04.492	debug	(17194) system.adapter.admin.0: logging true
    modbus.1	2021-02-13 12:54:40.388	debug	(17194) Closing client on purpose.
    modbus.1	2021-02-13 12:54:39.386	debug	(17194) Cleaning up request fifo.
    modbus.1	2021-02-13 12:54:39.386	debug	(17194) Socket closed with error
    modbus.1	2021-02-13 12:54:39.323	info	(17194) Disconnected from slave 192.168.0.98
    modbus.1	2021-02-13 12:54:39.322	debug	(17194) Closing client on purpose.
    modbus.1	2021-02-13 12:54:39.271	warn	(17194) Poll error count: 11 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.1	2021-02-13 12:54:39.269	debug	(17194) Received pdu describes an error.
    modbus.1	2021-02-13 12:54:39.174	debug	(17194) Poll holdingRegs DevID(1) address 40100 - 71 bytes
    modbus.1	2021-02-13 12:54:36.496	debug	(17194) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 12:54:36.496	debug	(17194) Poll device 1
    auch ist die Instanz vom SMA dauerhaft Grün und die Polltime etwa 800ms.
    die Instanz vom SE pollt nicht, öffnet u schließt den Socket ständig
    ab 40100 bleiben die Objekte leer, obwohl im Log als gepollt drin
    wenn ich das Log richtig interpretiere, dann stimmt da ein Wert oder Adresse nicht?
    Tja, was heißt das: Received pdu describes an error.
    HumidorH Online
    HumidorH Online
    Humidor
    schrieb am zuletzt editiert von Humidor
    wurde im anderen Thread Link Text fertig gestellt!
    DANKE!!!! erledigt. ev. Fragen kommen noch.
    BG
    • HumidorH Humidor
      @humidor sagte in (gelöst)(Frage) ModubusTCP Adapter ?:
      wurde im anderen Thread fertig gestellt!
      Bitte verlinken und dann auf [gelöst] setzen
      • HumidorH Humidor
        Update habe ich bisher keines gemacht (never change a running system)
        Die Einstellung sollte überdacht werden. Die Updates werden ja nicht wegen einer höheren Versionsnummer vergeben sondern weil Fehler beseitigt worden sind.
          wendy2702W Online
          wendy2702W Online
          @thomas-braun Bei SMA wurde vor einigen Jahren damit sogar erst Modbus implementiert.
          • wendy2702W wendy2702
            maxpd
            @wendy2702 Ich habe über Sunny Explorer Modbus via TCP aktiviert und im Sunny Portal zeigt er diese Änderung auch erfolgreich an.
            Aber der Modbus Adapter bleibt gelb.
            Webconnect habe ich auch aktiviert. Brauch es noch etwas?
            maxpd
            • M maxpd
              wendy2702W Online
              wendy2702W Online
              @maxpd Hast du Register eingetragen im Adapter?
                maxpd
                @wendy2702 Ich entschuldige mich für die Störung ^^
                maxpd
                • M maxpd
                  wendy2702W Online
                  wendy2702W Online
                  @maxpd ?
                  Was bedeutet das jetzt?
                  Läuft der Adapter jetzt und wenn ja, lag es an den Registern?
                    @maxpd ?
                    maxpd
                    @wendy2702 Ja genau. Er ist auf grün gewechselt. Außer ich geb ein Register an mit dem er nicht klar kommt, dann gehts direkt wieder auf Gelb.
                    Bei Eigenverbrauch gibt er momentan nur Quatsch aus und bei Einspeisung hat er ein Problem mit der Datenadresse.
                    Da muss ich noch experimentieren.
                    maxpd
                    • M maxpd
                      wendy2702W Online
                      wendy2702W Online
                      @maxpd Eigenverbrauch/Einspeisung geht nur wenn du den Sunny Homemager 2 hast soweit mir bekannt ist.
                      Hast du den?
                      Hier ist ne fertige CSV zum importieren mit den "wichtigsten" Registern wenn man, wie ich keinen Homemanager 2 hat.
                      https://forum.iobroker.net/topic/42173/gelöst-frage-modubustcp-adapter/10?page=1
                      Die kannst du ja noch manuel hinzufügen.
                        Hast du den?
                        maxpd
                        @wendy2702 JA, habe den Homemanager 2. Da das in diesem Topic angehängte Dokument von 2014 ist ist die Frage ob es für den HM2 noch gültig ist?
                        maxpd
                        • M maxpd
                          wendy2702W Online
                          wendy2702W Online
                          @maxpd Kommt eher auf die Kombination Typ WR / SW / Homemanager 2 und dessen SW an.
                          Du musst dir bei SMA passend zu deinem WR und dessen SW Stand die passenden Register raussuchen.
                          Mit dem HM2 habe ich mich persönlich bisher nur am rand beschäftigt da ich das Teil nicht habe.
                            maxpd
                            @wendy2702 ok, versuche mich schlau zu machen. einen filter werden sie diesbezüglich wohl nicht haben.
                            maxpd
                            • M maxpd
                              wendy2702W Online
                              wendy2702W Online
                              @maxpd sagte in (gelöst)(Frage) ModubusTCP Adapter ?:
                              Was meinst du mit Filter?
                                maxpd
                                @wendy2702 Ein Filter um die passende kombination für sich auf deren Website zu finden.
                                Ich habe aber nun über Google eine Excel gefunden in der mein WR drin ist mit der passenden SW. Allerdings ist da keine Spur von Werten, die einen Verbrauch oder Überschuss anzeigen.
                                maxpd
                                • M maxpd
                                  wendy2702W Online
                                  wendy2702W Online
                                  @maxpd Warum schaust du nicht direkt auf der SMA Webseite nach der Modbus Liste:
                                  https://www.sma.de/produkte/monitoring-control/modbus-protokoll-schnittstelle.html
                                    maxpd
                                    @wendy2702 Auch möglich, aber da werden noch weniger Werte angezeigt.
                                    maxpd
                                    • M maxpd
                                      wendy2702W Online
                                      wendy2702W Online
                                      @maxpd Welchen WR hast du denn?
                                        maxpd
                                        @wendy2702 Sunny Tripower 20000TL-30
                                        maxpd
                                        • M maxpd
                                          wendy2702W Online
                                          wendy2702W Online
                                          @maxpd OK.
                                          Das ZIP hast du aber schon runtergeladen und mal reingeschaut?
                                          Unabhängug davonhabe ich gerade nurmal die Homemanager 2 Anleitung überflogen. Ist der irgendwie direkt per Modbus mit dem WR verbunden worden?
                                          Du kannst auch mal versuchen die Werte mit dem SMA Energy Meter Adapter oder SMA-Speedwire Adapter aus dem HomeManager zu bekommen.
                                          Sonst hier mal lesen:
                                          https://forum.iobroker.net/topic/1100/sma-wechselrichter?lang=de&page=1
                                          HumidorH M 2 Antworten Letzte Antwort
