  4. (gelöst)(Frage) ModubusTCP Adapter ?
    6.0k
57 Beiträge 5 Kommentatoren 9.1k Aufrufe 4 Beobachtet
  • HumidorH Humidor
    @wendy2702 super Danke!!!
    es läuft was, aber nicht wiklich korrektk.
    modbus.1	2021-02-13 11:07:43.784	debug	(11206) Closing client on purpose.
    modbus.1	2021-02-13 11:07:42.783	debug	(11206) Cleaning up request fifo.
    modbus.1	2021-02-13 11:07:42.782	debug	(11206) Socket closed with error
    modbus.1	2021-02-13 11:07:42.671	info	(11206) Disconnected from slave 192.168.0.98
    modbus.1	2021-02-13 11:07:42.670	debug	(11206) Closing client on purpose.
    modbus.1	2021-02-13 11:07:42.618	warn	(11206) Poll error count: 6 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.1	2021-02-13 11:07:42.617	debug	(11206) Received pdu describes an error.
    modbus.1	2021-02-13 11:07:42.572	debug	(11206) Poll holdingRegs DevID(1) address 40100 - 71 bytes
    modbus.1	2021-02-13 11:07:42.494	debug	(11206) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 11:07:42.493	debug	(11206) Poll device 1
    modbus.1	2021-02-13 11:07:41.440	warn	(11206) Poll error count: 5 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.1	2021-02-13 11:07:41.439	debug	(11206) Received pdu describes an error.
    modbus.1	2021-02-13 11:07:41.353	debug	(11206) Poll holdingRegs DevID(1) address 40100 - 71 bytes
    modbus.1	2021-02-13 11:07:41.281	debug	(11206) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 11:07:41.280	debug	(11206) Poll device 1
    modbus.1	2021-02-13 11:07:40.228	warn	(11206) Poll error count: 4 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.1	2021-02-13 11:07:40.227	debug	(11206) Received pdu describes an error.
    modbus.1	2021-02-13 11:07:40.139	debug	(11206) Poll holdingRegs DevID(1) address 40100 - 71 bytes
    modbus.1	2021-02-13 11:07:40.048	debug	(11206) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 11:07:40.047	debug	(11206) Poll device 1
    modbus.1	2021-02-13 11:07:38.995	warn	(11206) Poll error count: 3 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    modbus.1	2021-02-13 11:07:38.994	debug	(11206) Received pdu describes an error.
    modbus.1	2021-02-13 11:07:38.904	debug	(11206) Poll holdingRegs DevID(1) address 40100 - 71 bytes
    modbus.1	2021-02-13 11:07:38.857	debug	(11206) Poll holdingRegs DevID(1) address 40000 - 100 bytes
    modbus.1	2021-02-13 11:07:38.856	debug	(11206) Poll device 1
    modbus.1	2021-02-13 11:07:37.804	warn	(11206) Poll error count: 2 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
    die Objekte (Holding Register) aus dem "Spoiler" werden angelegt, die Werte stimmen aber gar nicht. der nächste Beitrag im Beitrag, sagt, dass die "Kommastelle" noch per JS-Script umgemodelt werden muss. OK, aber die Werte machen dann auch keinen Sinn, irgendwas passt da nicht.
    Der Adapter bleibt auf Gelg, die Werte werden auch nicht upgedatet.
    modbus.1	2021-02-13 11:29:27.514	info	(12625) Disconnected from slave 192.168.0.98
    modbus.1	2021-02-13 11:29:27.513	debug	(12625) Closing client on purpose.
    modbus.1	2021-02-13 11:29:26.511	debug	(12625) Cleaning up request fifo.
    modbus.1	2021-02-13 11:29:26.511	debug	(12625) Clearing timeout of the current request.
    modbus.1	2021-02-13 11:29:26.509	debug	(12625) Socket closed with error
    modbus.1	2021-02-13 11:29:26.505	debug	(12625) Poll holdingRegs DevID(1) address 40083 - 1 bytes
    modbus.1	2021-02-13 11:29:26.504	debug	(12625) Poll device 1
    modbus.1	2021-02-13 11:29:25.413	debug	(12625) Poll holdingRegs DevID(1) address 40083 - 1 bytes
    modbus.1	2021-02-13 11:29:25.412	debug	(12625) Poll device 1
    modbus.1	2021-02-13 11:29:24.316	debug	(12625) Poll holdingRegs DevID(1) address 40083 - 1 bytes
    modbus.1	2021-02-13 11:29:24.314	debug	(12625) Poll device 1
    modbus.1	2021-02-13 11:29:24.311	info	(12625) Connected to slave 192.168.0.98
    wendy2702W Online
    wendy2702W Online
    @humidor Das könnte an unterschiedlichen Firmware Versionen liegen oder eventuell an unterschiedlichen WR Typen.
    Soweit ich mich erinnere ist das anpassen per Javascript notwendig da Solaredge mit Faktoren für Register arbeitet.
    Frage doch mal in dem Verlinkten Thread.
    Zum Testen kannst du mal die beiden Register 40100 und 40000 entfernen.
    Welchen WR genau hast du denn?
    Hast du denn auch die Adapter Einstellungen aus dem anderen Thread übernommen?
    HumidorH 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      HumidorH Online
      HumidorH Online
      Humidor
      schrieb am zuletzt editiert von Humidor
      @wendy2702 SE17k mit akt. FW meines Wissen, hatten gerade ein Update weil mehr Optimizer montiert wurden
      BG
      • HumidorH Humidor
        wendy2702W Online
        wendy2702W Online
        @humidor Schau mal hier.
        Wurde auch mit Modbus realisiert.
        https://forum.iobroker.net/topic/23020/solaredge-mit-zigbee-einbinden
          HumidorH Online
          HumidorH Online
          Humidor
          @wendy2702 inzwischen ist es mir etwas klarer
          die Instanz geht nur auf Grün, wenn eine Abfrage läuft, sonst Gelb.
          ich sehe allerdings Fehler :
          modbus.1	2021-02-13 12:55:10.673	debug	(17194) Closing client on purpose.
          modbus.1	2021-02-13 12:55:09.671	debug	(17194) Cleaning up request fifo.
          modbus.1	2021-02-13 12:55:09.671	debug	(17194) Socket closed with error
          modbus.1	2021-02-13 12:55:09.601	info	(17194) Disconnected from slave 192.168.0.98
          modbus.1	2021-02-13 12:55:09.600	debug	(17194) Closing client on purpose.
          modbus.1	2021-02-13 12:55:09.550	warn	(17194) Poll error count: 12 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          modbus.1	2021-02-13 12:55:09.549	debug	(17194) Received pdu describes an error.
          modbus.1	2021-02-13 12:55:09.463	debug	(17194) Poll holdingRegs DevID(1) address 40100 - 71 bytes
          modbus.1	2021-02-13 12:55:09.327	debug	(17194) Poll holdingRegs DevID(1) address 40000 - 100 bytes
          modbus.1	2021-02-13 12:55:09.327	debug	(17194) Poll device 1
          modbus.1	2021-02-13 12:55:09.326	info	(17194) Connected to slave 192.168.0.98
          modbus.1	2021-02-13 12:55:05.735	debug	(17194) sendTo "listUart" to system.adapter.admin.0 from system.adapter.modbus.1
          modbus.1	2021-02-13 12:55:05.735	info	(17194) List of port: [{"path":"/dev/ttyAMA0"}]
          modbus.1	2021-02-13 12:55:04.492	debug	(17194) system.adapter.admin.0: logging true
          modbus.1	2021-02-13 12:54:40.388	debug	(17194) Closing client on purpose.
          modbus.1	2021-02-13 12:54:39.386	debug	(17194) Cleaning up request fifo.
          modbus.1	2021-02-13 12:54:39.386	debug	(17194) Socket closed with error
          modbus.1	2021-02-13 12:54:39.323	info	(17194) Disconnected from slave 192.168.0.98
          modbus.1	2021-02-13 12:54:39.322	debug	(17194) Closing client on purpose.
          modbus.1	2021-02-13 12:54:39.271	warn	(17194) Poll error count: 11 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          modbus.1	2021-02-13 12:54:39.269	debug	(17194) Received pdu describes an error.
          modbus.1	2021-02-13 12:54:39.174	debug	(17194) Poll holdingRegs DevID(1) address 40100 - 71 bytes
          modbus.1	2021-02-13 12:54:36.496	debug	(17194) Poll holdingRegs DevID(1) address 40000 - 100 bytes
          modbus.1	2021-02-13 12:54:36.496	debug	(17194) Poll device 1
          auch ist die Instanz vom SMA dauerhaft Grün und die Polltime etwa 800ms.
          die Instanz vom SE pollt nicht, öffnet u schließt den Socket ständig
          ab 40100 bleiben die Objekte leer, obwohl im Log als gepollt drin
          wenn ich das Log richtig interpretiere, dann stimmt da ein Wert oder Adresse nicht?
          Tja, was heißt das: Received pdu describes an error.
          BG
          • HumidorH Humidor
            HumidorH Online
            HumidorH Online
            Humidor
            wurde im anderen Thread Link Text fertig gestellt!
            DANKE!!!! erledigt. ev. Fragen kommen noch.
            BG
            • HumidorH Humidor
              @humidor sagte in (gelöst)(Frage) ModubusTCP Adapter ?:
              wurde im anderen Thread fertig gestellt!
              Bitte verlinken und dann auf [gelöst] setzen
              • HumidorH Humidor
                Update habe ich bisher keines gemacht (never change a running system)
                Die Einstellung sollte überdacht werden. Die Updates werden ja nicht wegen einer höheren Versionsnummer vergeben sondern weil Fehler beseitigt worden sind.
                  wendy2702W Online
                  wendy2702W Online
                  @thomas-braun Bei SMA wurde vor einigen Jahren damit sogar erst Modbus implementiert.
                    maxpd
                    @wendy2702 Ich habe über Sunny Explorer Modbus via TCP aktiviert und im Sunny Portal zeigt er diese Änderung auch erfolgreich an.
                    Aber der Modbus Adapter bleibt gelb.
                    Webconnect habe ich auch aktiviert. Brauch es noch etwas?
                    maxpd
                    • M maxpd
                      wendy2702W Online
                      wendy2702W Online
                      @maxpd Hast du Register eingetragen im Adapter?
                        maxpd
                        @wendy2702 Ich entschuldige mich für die Störung ^^
                        maxpd
                        • M maxpd
                          wendy2702W Online
                          wendy2702W Online
                          @maxpd ?
                          Was bedeutet das jetzt?
                          Läuft der Adapter jetzt und wenn ja, lag es an den Registern?
                            @maxpd ?
                            maxpd
                            @wendy2702 Ja genau. Er ist auf grün gewechselt. Außer ich geb ein Register an mit dem er nicht klar kommt, dann gehts direkt wieder auf Gelb.
                            Bei Eigenverbrauch gibt er momentan nur Quatsch aus und bei Einspeisung hat er ein Problem mit der Datenadresse.
                            Da muss ich noch experimentieren.
                            maxpd
                            • M maxpd
                              wendy2702W Online
                              wendy2702W Online
                              @maxpd Eigenverbrauch/Einspeisung geht nur wenn du den Sunny Homemager 2 hast soweit mir bekannt ist.
                              Hast du den?
                              Hier ist ne fertige CSV zum importieren mit den "wichtigsten" Registern wenn man, wie ich keinen Homemanager 2 hat.
                              https://forum.iobroker.net/topic/42173/gelöst-frage-modubustcp-adapter/10?page=1
                              Die kannst du ja noch manuel hinzufügen.
                                Hast du den?
                                maxpd
                                @wendy2702 JA, habe den Homemanager 2. Da das in diesem Topic angehängte Dokument von 2014 ist ist die Frage ob es für den HM2 noch gültig ist?
                                maxpd
                                • M maxpd
                                  wendy2702W Online
                                  wendy2702W Online
                                  @maxpd Kommt eher auf die Kombination Typ WR / SW / Homemanager 2 und dessen SW an.
                                  Du musst dir bei SMA passend zu deinem WR und dessen SW Stand die passenden Register raussuchen.
                                  Mit dem HM2 habe ich mich persönlich bisher nur am rand beschäftigt da ich das Teil nicht habe.
                                    maxpd
                                    @wendy2702 ok, versuche mich schlau zu machen. einen filter werden sie diesbezüglich wohl nicht haben.
                                    maxpd
                                    • M maxpd
                                      wendy2702W Online
                                      wendy2702W Online
                                      @maxpd sagte in (gelöst)(Frage) ModubusTCP Adapter ?:
                                      Was meinst du mit Filter?
                                        maxpd
                                        @wendy2702 Ein Filter um die passende kombination für sich auf deren Website zu finden.
                                        Ich habe aber nun über Google eine Excel gefunden in der mein WR drin ist mit der passenden SW. Allerdings ist da keine Spur von Werten, die einen Verbrauch oder Überschuss anzeigen.
                                        maxpd
                                        • M maxpd
                                          wendy2702W Online
                                          wendy2702W Online
                                          @maxpd Warum schaust du nicht direkt auf der SMA Webseite nach der Modbus Liste:
                                          https://www.sma.de/produkte/monitoring-control/modbus-protokoll-schnittstelle.html
