  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • Jorge Santisteban PozasJ Jorge Santisteban Pozas
    Hilfe bitte. Ich kann es nicht zum Laufen bringen.
    Re-enable cpu cache.
    Rebooting...
    ets Jun  8 2016 00:22:57
    rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    mode:DIO, clock div:1
    load:0x3fff0030,len:4
    load:0x3fff0034,len:7140
    load:0x40078000,len:13856
    load:0x40080400,len:4052
    entry 0x40080688
    I (29) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
    I (29) boot: compile time 19:51:06
    I (29) boot: chip revision: 1
    I (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0
    I (40) boot.esp32: SPI Speed      : 80MHz
    I (44) boot.esp32: SPI Mode       : DIO
    I (49) boot.esp32: SPI Flash Size : 4MB
    I (53) boot: Enabling RNG early entropy source...
    I (59) boot: Partition Table:
    I (62) boot: ## Label            Usage          Type ST Offset   Length
    I (70) boot:  0 nvs              WiFi data        01 02 00009000 00004000
    I (77) boot:  1 otadata          OTA data         01 00 0000d000 00002000
    I (85) boot:  2 phy_init         RF data          01 01 0000f000 00001000
    I (92) boot:  3 ota_0            OTA app          00 10 00010000 001db000
    I (99) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
    I (107) boot: End of partition table
    I (111) boot_comm: chip revision: 1, min. application chip revision: 0
    I (118) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x4c730 (313136) map
    I (244) esp_image: segment 1: paddr=0x0005c758 vaddr=0x3ffb0000 size=0x038c0 ( 14528) load
    I (250) esp_image: segment 2: paddr=0x00060020 vaddr=0x400d0020 size=0x15f514 (1438996) map
    I (788) esp_image: segment 3: paddr=0x001bf53c vaddr=0x3ffb38c0 size=0x01860 (  6240) load
    I (791) esp_image: segment 4: paddr=0x001c0da4 vaddr=0x40080000 size=0x00404 (  1028) load
    I (795) esp_image: segment 5: paddr=0x001c11b0 vaddr=0x40080404 size=0x1ee54 (126548) load
    I (875) boot: Loaded app from partition at offset 0x10000
    I (875) boot: Disabling RNG early entropy source...
    I (876) psram: This chip is ESP32-D0WD
    E (881) cpu_start: Failed to init external RAM!
    abort() was called at PC 0x40081ce9 on core 0
    ELF file SHA256: b9ffc04c8ab59a15
    Backtrace: 0x4008e3e9:0x3ffe3c00 0x4008e785:0x3ffe3c20 0x40081ce9:0x3ffe3c40 0x4007931a:0x3ffe3c80 |<-CORRUPTED
    jomjol
    #829
    @jorge-santisteban-pozas Welchen ESP verwendest du den genau? Sieht so aus, als ob es kein PSRAM hat. Das sollte aber bei einem ESP32CAM nicht der Fall sein.
      Mirtl76
      #830
      Hallo Jomjol,
      erst mal ein sehr großes Lob für dein Projekt. Leider habe ich einen neuen Wasserzähler bekommen, der etwas anders aufgebaut ist. Die dritte Nachkommastelle müsste digital ausgelesen werden. Wäre das machbar?
      Ich bin mir auch noch nicht sicher ob die zweite Nachkommastelle überhaupt richtig erkannt wird da hier eine Aufnahme für einen Sensor fest im Klarsichtdeckel integriert ist.
      Gibt es auch eine Möglichkeit den Zählerstand an Thinkspeak zu senden?
      mirtl76
      J R 2 Antworten Letzte Antwort
      • M Mirtl76
        Hallo Jomjol,
        mirtl76
        jomjol
        #831
        @mirtl76 Hallo Mirtl,
        das Auslesen der 3. Stelle ist so momentan nicht möglich. Das würde ein größeres Eingreifen in die Programmlogik und Aufbau bedeuten, da ich ja dann 3 Arten von Ziffern habe (Digitale Ziffer, Analoge Zeiger & digitale Ziffern von links nach rechts).
        Der Aufwand dafür wäre eher groß und ist nicht auf der Roadmap. Wenn es zu einem größeren Thema wird, müsste man sich das mal anschauen.
        Gruß,
        jomjol
        W 1 Antwort Letzte Antwort
        • J jomjol
          Gruß,
          jomjol
          W Offline
          W Offline
          watcherkb
          schrieb am zuletzt editiert von watcherkb
          #832
          @jomjol Grüß dich. Hab ein Problem dass die alten Dateien im log Ordner nicht bereinigt werden obwohl das in der ini aktiviert ist. Auch lassen sich Ordner nicht löschen wenn darin Dateien vorhanden sind. Wenn der Ordner leer ist dann lässt er sich aber löschen. Bin übrigens noch auf dem master - v4.0.0 - 2020-11-15 Branch. Wollte demnächst mal updaten wenn mehr Zeit ist.
          CC2538+CC2592 PA-Zigbee-Funkmodul
          S J 2 Antworten Letzte Antwort
          • W watcherkb
            Sandmanyz
            #833
            Ich bin ganz frisch in diesem Thema (Bilderkennung) und möchte dies gerne für meinen Stromzähler nutzen weil mein Netzbetreiber die optische Schnittstelle deaktiviert hat.
            Könnte ich mit dieser Lösung (ESP32 CAM) einen digitalen Stromzähler "lesen"?
            Wie sieht es mit der Helligkeit aus? Im Zählerschrank ist ja kein Licht.
            • W watcherkb
              jomjol
              #834
              @watcherkb sagte in Wasserzähler - Version 2 - all-in-device:
              Hi @watcherkb,
              das ist noch ein ziemlich alter Stand - vermutlich noch irgendein Bug mit den Logfiles. Einfach mal updaten, ggf. SD-Karte sicherheitshalber formatieren. Wenn der Fehler dann noch da ist, bitte melden.
              Gruß,
              jomjol
              • S Sandmanyz
                jomjol
                #835
                @sandmanyz sagte in Wasserzähler - Version 2 - all-in-device:
                Ja, digitale Ziffern gehen. Die Heligkeit ist kein Problem, da die ESP32CAM ja eine interne Beleuchtung hat!
                S HasontH 2 Antworten Letzte Antwort
                • Rumot SatuR Offline
                  Rumot SatuR Offline
                  Rumot Satu
                  #836
                  @jomjol i have flashed my esp32 using latest version 6 and got the result that esp cant booting again after reboot and need restart by cut off the power. any one get this issue?
                  • Rumot SatuR Rumot Satu
                    jomjol
                    #837
                    @rumot-satu Which kind of ESP32 are you using? Did you build up the file structure on the SD-card?
                    • J jomjol
                      Sandmanyz
                      #838
                      @jomjol
                      Danke Dir! 👍 Dann gehe ich das Projekt mal an 😊
                      • J jomjol
                        HasontH Offline
                        HasontH Offline
                        Hasont
                        schrieb am zuletzt editiert von Hasont
                        #839
                        @jomjol
                        Hallo, hab mir jetzt eine Wasserüberwachung mit Blockly gebaut und schau da alle 5 min nach dem Wasserverbrauch.
                        Im Urlaub würde er dann über Telegram einen Verbrauch > 1l melden und bei > 10l das Wasser abschalten.
                        Das Funktioniert soweit ganz gut aber ich bekomme die URL zum Schalten des GPIO nicht zum laufen.
                        Direkteingabe über den Browser geht inkl. Rückmeldung wunderbar!
                        Habt Ihr da einen Vorschlag wie man im Blockly die URL http://[IP-Adresse]/GPIO?GPIO=12&Status=high/low versenden kann. Dachte das wäre so möglich!
                        Edit: Sorry läuft, hab ein GPIO& im Link vergessen ;-)
                        Grad beim Tippen aufgefallen.
                        PS: Meine zwei Zähler laufen weiterhin absolut stabil
                          Sergey777
                          #840
                          Is it possible to use the ethernet LAN8720 module? My water meter is installed in a well 30 meters from the house, such are the requirements in rural areas. It is very problematic to use WiFi, and the power cable still needs to be laid.
                            Rebooting...
                            entry 0x40080688
                            stephan4711
                            #841
                            super Projekt und super Umsetzung. Vielen Dank hierfür.
                            Ich habe zwei ESP32Cams. (https://www.amazon.de/gp/product/B07SBTNMMC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1). Mit einer funktioniert es ohne Probleme, mit der anderen bekomme ich den selben Fehler wie Jorge Santisteban Pozas.
                            Hat vielleicht einer eine Idee, woran es liegen könnte?
                            Vielen Dank.
                            Grüße Stephan
                            pfriedP 1 Antwort Letzte Antwort
                            • S stephan4711
                              Vielen Dank.
                              Grüße Stephan
                              pfriedP Offline
                              pfriedP Offline
                              pfried
                              schrieb am zuletzt editiert von pfried
                              #842
                              @stephan4711 Ich nehme einmal an diese ESPs sind baugleich, dann liegt es meiner Erfahrung nach an der SD Karte. Hast Du schon mal die SD Karten untereinander ausgetauscht?
                              Es gibt ein Tool RescuePro Deluxe von SanDisk (für nicht kommerzielle Nutzung gratis) mit der man die SD Karten restlos löschen kann, das hat mir oft geholfen.
                                mcchickents
                                #843
                                Guten Abend,
                                hatte die Version 1 jetzt sehr lange erfolgreich laufen. Habe mir am Wocheende mal die Version 2 angeschaut. Und hätte eine Frage hierzu wenn ich den ESP Starte leuchtet sofort die weiße LED. Ich komme auch auf das Webinterface leider bekomme ich aber von der CAM keine Bilder. Jemand eine Idee an was da liegen könnte. Ein neuen ESP32 habe ich mal bestelllt. Gruss Julian
                                • KnallochseK Offline
                                  KnallochseK Offline
                                  Knallochse
                                  #844
                                  @jomjol Ich habe meinen Stromzähler (Ferris) mit der ESP32-Cam ausgestattet. Läuft soweit gar nicht schlecht.
                                  Ich hebe hier mal ein par Zahlen zum anlernen für die Datenbank.
                                  Würde mich freuen, wenn du die Bilder zur besseren Erkennung mit aufnehmen könntest (bitte keinen Stress, so wie es passt)
                                  Stromzähler.zip
                                  Mega Projekt. Habe die verschiedenen Versionen seit Anfang an im Betrieb, und immer noch begeistert.
                                  • MierscheidM Offline
                                    MierscheidM Offline
                                    Mierscheid
                                    schrieb am zuletzt editiert von Mierscheid
                                    #845
                                    Mahlzeit,
                                    ich habe den Thread durchsucht, soweit ich die SuFu der Site verstanden habe, konnte aber nichts über mein Problem finden:
                                    ESP32-CAM ist geflasht, SD-Karte läuft, Device ist im WLAN und anpingbar.
                                    Nur ist der Webserver weder über Port 80, 81 noch 8081 erreichbar.
                                    Was mache ich falsch?
                                    Edit: So ein ESP ist keine Rakete, ist klar, aber ist das normal?
                                    66 packets transmitted, 39 received, 40% packet loss, time 65717ms
                                    rtt min/avg/max/mdev = 1.363/234.536/1870.686/301.235 ms, pipe 2
                                    Edit 2: OMG! Das ist kein Packet loss! Die Hänger sind vermutlich ein dauernder Reboot und das Anmelden an das WLAN.
                                    Habe ihn nun einige Male neu gestartet und die Bootzeit passt ziemlich genau zu den Lücken im Ping.
                                    5 Sekunden Bootezeit und bis zu 23 Sekunden, eher aber nur sechs bis acht Sekunden alive.
                                    Alter, was ist das Ding schnell oben und am WLAN angemeldet. Irre.
                                    Aber was mag das verursachen?
                                    Das Log sagt nix, das ist nur damit voll:
                                    2021-02-24_16-28-44: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                    2021-02-24_16-28-44: =============================================================================================
                                    2021-02-24_16-28-44: =================================== Main Started ============================================
                                    HasontH 1 Antwort Letzte Antwort
                                    • MierscheidM Mierscheid
                                      Mahlzeit,
                                      HasontH Offline
                                      HasontH Offline
                                      Hasont
                                      #846
                                      @mierscheid
                                      Hallo, kann nur aus meiner Erfahrung sprechen!
                                      Passen die Versionen und die Files zur SD Karte sauber zusammen?
                                      Hast du schon mal eine andere SD Karte versucht?
                                      Wenn er dauernd im Reboot hängt lag es bei mir meist an Fehlern mit der SD Karte oder bei der Erstkonfiguration.
                                      Welche Art von Zähler hast du. Konntest du schon mal ein gutes Bild vom Zähler erkennen?
                                      Gruß Horst
                                      MierscheidM 1 Antwort Letzte Antwort
                                      • HasontH Hasont
                                        @mierscheid
                                        Gruß Horst
                                        MierscheidM Offline
                                        MierscheidM Offline
                                        Mierscheid
                                        #847
                                        @hasont Danke für Deine Antwort.
                                        Da musst Du Jomjol fragen, woher soll ich das wissen? 😲
                                        Ich habe gerade keine < 16 GB zur Hand. Warte noch auf die Lieferung.
                                        Die Karte habe ich nun erneut formatiert und die Dateien darauf kopiert. Hilft nichts.
                                        Er kommt bis zum NTP-Sync, den er vermutlich nicht einmal abschließen kann. Nix Webserver.
                                        Edit:
                                        OMG... das kann nicht sein. Mit dem zweiten neuen ESP, schnell noch geflasht, gegengecheckt. Der geht.
                                        Kreuztausch Kamera und ESP32-CAM-MB auf den ersten ESP gesetzt: läuft.
                                        Kameramodul angesehen.
                                        ICH BIN SCHULD!
                                        Bin mit dem Skalpell abgerutscht, als ich die Linse lösen wollte. Ist ein Schnitt über zwei Leiterbahnen. Wer denkt da an so einen Reboot-Effekt?
                                        Edit 2:
                                        Also, das hat alles super geklappt, @jomjol! Vielen Dank für dieses Projekt! Wie der ESP32 aus spiegelnden Doppelbildern noch den Stand der Zeiger erahnen kann, ist schon sehr beeindruckend! Habe es auch als Anfänger schnell in ioBroker integrieren können.
                                        Jetzt muss ich nur mal sehen, ob man da irgendwie den aktuellen Wasserverbrauch errechnen und in Flot visualisieren kann. Aber ich denke, das funktioniert nicht, bei den langen Aktualisierungsintervallen, die der ESP braucht, oder?
                                        • pfriedP pfried
                                          stephan4711
                                          #848
                                          @pfried Danke für deinen Hinweis, hat leider auch nicht funktioniert. der esp startet nicht, auch nicht ohne sd-karte. ich habe mal einen neuen bestellt. mal schauen ob es damit besser funktioniert.
