  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.3k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.5k Aufrufe 153 Beobachtet
  • D deifel
    @tombox
    Danke für Deine Hilfe.
    Hier das Log ein paar Einträge davor:
    1-01-19 08:24:36.015 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-68XXX: Program currently not available
    2021-01-19 08:24:37.513 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-68XXX: Program currently not available
    2021-01-19 08:24:39.009 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-6XCXCXC: Program currently not available
    2021-01-19 08:24:40.521 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-68AXXX: Program currently not available
    2021-01-19 08:24:42.011 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-68AXCXX: Program currently not available
    2021-01-19 08:24:43.514 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-6XXX: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 584 seconds.
    2021-01-19 08:24:45.007 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-68XXX: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 583 seconds.
    2021-01-19 08:24:46.510 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-68XXX: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 582 seconds.
    2021-01-19 08:24:48.010 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-6XXX: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 580 seconds.
    2021-01-19 08:24:49.512 - info: homeconnect.0 (19834) BOSCH-CTL636ES6-68XXX: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 578 seconds.
    2021-01-19 08:24:50.302 - info: homeconnect.0 (19834) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 578 seconds.
    2021-01-19 08:24:50.302 - error: homeconnect.0 (19834) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-01-19 08:24:50.303 - error: homeconnect.0 (19834) unhandled promise rejection: undefined
    2021-01-19 08:24:50.303 - info: homeconnect.0 (19834) cleaned everything up...
    2021-01-19 08:24:50.304 - info: homeconnect.0 (19834) terminating
    Eigenartig ist, dass der Adapter eigentlich ganz normal läuft und auch die States aktualisiert. Wenn ich dann z.B. die Kaffeemaschine ausschalte, dann nimmt er (meistens) den Befehl an, Gerät schaltet sich aus, aber der Adapter geht auf rot und das Log spuckt die Fehler aus, bis er in den Block für 5 Minuten läuft. Danach läuft der Adapter wieder und das Problem geht von vorne los.
    tombox
    #452
    @deifel Mal in den Adapter in Debug setzen und bei dem Fehler mir einfach per PN schicken
    • T tombox
      Update der Beschreibung nach Maintainer-Änderung 2022:
      Der Adapter ermöglicht die Anbindung von Homeconnect Geräte an den ioBroker.
      https://github.com/iobroker-community-adapters/ioBroker.homeconnect
      Es wird dabei die offizielle Homeconnect API verwendet.
      https://developer.home-connect.com/changelog
      Es werden nicht alle Funktionen aus der Homeconnect App unterstützt. Einige Status oder Programme sind nicht via Homeconnect API verfügbar. Wenn es dahingehend Änderungswünsche gibt, bitte direkt an Homeconnect API wenden:
      https://developer.home-connect.com/support/contact
      Anleitung für Client ID
      Für den Adapter wird eine Homeconnect API ClientID benötigt.
      https://developer.home-connect.com/user/register
      Bei Default Home Connect User Account for Testing die E-Mail-Adresse angeben, mit der die Home-Connect-App
      registriert wurde, diese wird später auch beim Authorization-Prozess benötigt.
      Bei Account Type Individual auswählen. Die restlichen Daten sofern vorhanden ergänzen.
      Dann auf Applications und anschließend auf Register Application gehen.
      https://developer.home-connect.com/applications
      Bei Application ID einen Namen für die Application eintragen, z.B. ioBroker. Bei OAuth Flow Device Flow selektieren.
      Home Connect User Account for Testing kann leer bleiben. Bei Success Redirect eine URI eintragen, z.B. https://example.com.
      Dann Speichern und dann hat man die benötigte ClientID.
      Konfiguration
      In der Adapter-Config muss der Homeconnect App Benutzername und Passwort und die erstellte ClientID eingetragen werden.
      Benutzung
      Mit den states in commands kannst du das Programm stoppen, pausieren oder fortführen.
      Mit den states in settings kannst du das Gerät ein oder ausschalten.
      Ändern des States programs.active.BSH_Common_Root_ActiveProgram führt zum starten eines Programms
      Ändern des States programs.selected.BSH_Common_Root_SelectedProgram führt zum auswählen des Programms oder Optionen
      Wenn man checken möchte, ob ein Programm fertig ist muss
      status.BSH_Common_Status_OperationState
      auf den kompletten Status Name übrprüft werden:
      BSH.Common.EnumType.OperationState.Finished
      Weitere Zustände sind noch:
      "BSH.Common.EnumType.OperationState.Inactive": "Inactive",
      "BSH.Common.EnumType.OperationState.Ready": "Ready",
      "BSH.Common.EnumType.OperationState.Run": "Run",
      "BSH.Common.EnumType.OperationState.ActionRequired": "ActionRequired",
      "BSH.Common.EnumType.OperationState.Finished": "Finished"
      Oder ob ein Gerät geöffnet ist
      "BSH.Common.EnumType.DoorState.Open": "Open",
      "BSH.Common.EnumType.DoorState.Closed": "Closed"
      Original AdapterAnnouncement von 2018:
      So, der Anfang ist gemacht.
      Der Adapter kann aber bisher noch nicht viel. Eigentlich fast garnix :D
      Bisher funktioniert erstmal nur die Authorisierung und die verbundenen Geräte werden abgefragt und in Datenpunkten hinterlegt.
      Da ich nur ein Home-Connect-Gerät besitze, kann ich leider nicht testen, ob auch mehrere Geräte in der Objektstruktur angelegt werden. Denke aber das funktioniert.
      Dummerweise kann ich das ganze auch nicht mit dem Simulator testen, da der leider den OAuth2-Deviceflow nicht unterstützt.
      Daher bin ich auf Eure Hilfe angewiesen.
      Wer möchte kann den Adapter ja mal installieren und schauen, ob die Geräte soweit angelegt werden.
      Eine Beschreibung ist in der Readme zum Adapter.
      Ich würde mich über Feedback freuen.
      Dann noch ein kleiner Hinweis:
      Der automatische Token-Refresh funktioniert scheinbar noch nicht richtig.
      Sollte der Token abgelaufen sein (Hinweis im Log), einfach den Datenpunkt 'access' unter dev auf false setzen
      und anschließend den Adapter neu starten. Dann wird der Authorisierungsprozess nochmals gestartet.
      LG
      dna909
      GarganoG Offline
      GarganoG Offline
      Gargano
      schrieb am zuletzt editiert von Gargano
      #453
      @dna909 Bei meinen Backofen sind die Datenpunkte vom Status auch schreibbar , sollten nur lesend sein
      GarganoG 1 Antwort Letzte Antwort
      • GarganoG Gargano
        GarganoG Offline
        GarganoG Offline
        Gargano
        #454
        Polling ist wohl nicht so gut
        FenriswolfF 1 Antwort Letzte Antwort
        • GarganoG Gargano
          FenriswolfF Offline
          FenriswolfF Offline
          Fenriswolf
          schrieb am zuletzt editiert von Fenriswolf
          #455
          Moin,
          ich habe seit geraumer Zeit immer wieder und in letzter Zeit permanent Fehler im Log.
          homeconnect.0	2021-02-02 13:25:26.201	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.BSH_Common_Option_ProgramProgress" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:25:25.603	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.BSH_Common_Option_RemainingProgramTime" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:25:21.618	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_BrillianceDry" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:25:21.617	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_VarioSpeedPlus" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:25:21.616	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_IntensivZone" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:25:21.613	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_HygienePlus" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:24:27.135	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_BrillianceDry" has no existing object, this might lead to an error in future vers
          homeconnect.0	2021-02-02 13:24:27.133	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_VarioSpeedPlus" has no existing object, this might lead to an error in future ver
          homeconnect.0	2021-02-02 13:24:27.120	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_IntensivZone" has no existing object, this might lead to an error in future versi
          homeconnect.0	2021-02-02 13:24:27.118	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_HygienePlus" has no existing object, this might lead to an error in future versio
          homeconnect.0	2021-02-02 13:24:27.116	warn	(646) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.BSH_Common_Option_StartInRelative" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:23:53.037	error	(646) {"data":{"programs":[]}}
          homeconnect.0	2021-02-02 13:23:53.036	error	(646) /programs
          homeconnect.0	2021-02-02 13:23:53.035	error	(646) TypeError: Cannot read property 'forEach' of undefined at /opt/iobroker/node_modules/iobroker.homeconnect/main.js:943:57 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/
          homeconnect.0	2021-02-02 13:23:53.025	error	(646) TypeError: Cannot read property 'forEach' of undefined
          homeconnect.0	2021-02-02 13:23:52.448	warn	(646) SIEMENS-WM14U840EU-68A40E072F79 is not connected cannot fetch information.
          Habe gerade nochmal mich angemeldet und die Client-ID neu übernommen und auch die Auth URL besucht und alles genehmigt. Wäre für eine Hilfestellung dankbar.
          Debug-Log:
          homeconnect.0	2021-02-02 13:32:33.614	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_ProgramProgress:80
          homeconnect.0	2021-02-02 13:32:33.613	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269153,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:32:33.561	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_RemainingProgramTime:1080
          homeconnect.0	2021-02-02 13:32:33.560	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269153,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:31:34.169	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_ProgramProgress:79
          homeconnect.0	2021-02-02 13:31:34.168	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269094,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:31:34.138	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_RemainingProgramTime:1140
          homeconnect.0	2021-02-02 13:31:34.137	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269094,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:31:25.664	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_ProgramProgress:78
          homeconnect.0	2021-02-02 13:31:25.663	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269085,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:31:25.568	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_RemainingProgramTime:1200
          homeconnect.0	2021-02-02 13:31:25.567	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269085,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:30:44.891	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_BrillianceDry
          homeconnect.0	2021-02-02 13:30:44.890	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_VarioSpeedPlus
          homeconnect.0	2021-02-02 13:30:44.889	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_IntensivZone
          homeconnect.0	2021-02-02 13:30:44.888	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_HygienePlus
          homeconnect.0	2021-02-02 13:30:44.888	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.BSH_Common_Option_StartInRelative
          homeconnect.0	2021-02-02 13:30:44.887	debug	(8718) {"data":{"options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.HygienePlus","value":false,"name":"HygienePlus"}
          homeconnect.0	2021-02-02 13:30:44.886	debug	(8718) /programs/selected/options
          homeconnect.0	2021-02-02 13:30:43.359	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_WaterForecast
          homeconnect.0	2021-02-02 13:30:43.358	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_EnergyForecast
          homeconnect.0	2021-02-02 13:30:43.357	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_RemainingProgramTime
          homeconnect.0	2021-02-02 13:30:43.356	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_ProgramProgress
          homeconnect.0	2021-02-02 13:30:43.355	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_BrillianceDry
          homeconnect.0	2021-02-02 13:30:43.354	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_VarioSpeedPlus
          homeconnect.0	2021-02-02 13:30:43.354	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_IntensivZone
          homeconnect.0	2021-02-02 13:30:43.353	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_HygienePlus
          homeconnect.0	2021-02-02 13:30:43.352	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_StartInRelative
          homeconnect.0	2021-02-02 13:30:43.352	debug	(8718) {"data":{"options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.HygienePlus","value":false,"name":"HygienePlus"}
          homeconnect.0	2021-02-02 13:30:43.351	debug	(8718) /programs/active/options
          homeconnect.0	2021-02-02 13:30:38.674	info	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D: Program currently not available
          homeconnect.0	2021-02-02 13:30:36.920	info	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D: Program currently not available
          homeconnect.0	2021-02-02 13:30:35.420	info	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D: Program currently not available
          homeconnect.0	2021-02-02 13:30:34.676	debug	(8718) {"data":{"key":"Dishcare.Dishwasher.Program.Kurz60","options":[],"name":"Kurz 60°C"}}
          homeconnect.0	2021-02-02 13:30:34.676	debug	(8718) /programs/available/Dishcare.Dishwasher.Program.Kurz60
          homeconnect.0	2021-02-02 13:30:32.546	info	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D: Program currently not available
          homeconnect.0	2021-02-02 13:30:30.922	info	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D: Program currently not available
          homeconnect.0	2021-02-02 13:30:29.400	info	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D: Program currently not available
          homeconnect.0	2021-02-02 13:30:27.881	info	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D: Program currently not available
          homeconnect.0	2021-02-02 13:30:25.766	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_ProgramProgress:76
          homeconnect.0	2021-02-02 13:30:25.765	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269025,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:30:25.693	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_RemainingProgramTime:1260
          homeconnect.0	2021-02-02 13:30:25.691	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612269025,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:30:24.992	debug	(8718) {"data":{"name":"Energiezustand","key":"BSH.Common.Setting.PowerState","constraints":{"allowedvalues":["BSH.Common.EnumType.PowerState.Off","BSH.Common.EnumType.PowerState.On"],"displayvalues":
          homeconnect.0	2021-02-02 13:30:24.991	debug	(8718) /settings/BSH.Common.Setting.PowerState
          homeconnect.0	2021-02-02 13:30:17.424	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.FrozenHeatupSpecial","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":275,"default"
          homeconnect.0	2021-02-02 13:30:17.422	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.FrozenHeatupSpecial
          homeconnect.0	2021-02-02 13:30:15.970	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.PreheatOvenware","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":70,"default":50},
          homeconnect.0	2021-02-02 13:30:15.969	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.PreheatOvenware
          homeconnect.0	2021-02-02 13:30:14.582	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.KeepWarm","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":60,"max":100,"default":60},"unit"
          homeconnect.0	2021-02-02 13:30:14.581	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.KeepWarm
          homeconnect.0	2021-02-02 13:30:13.114	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.Desiccation","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":150,"default":80},"un
          homeconnect.0	2021-02-02 13:30:13.114	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.Desiccation
          homeconnect.0	2021-02-02 13:30:12.836	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.BottomHeating","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":250,"default":150},
          homeconnect.0	2021-02-02 13:30:12.835	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.BottomHeating
          homeconnect.0	2021-02-02 13:30:09.943	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.SlowCook","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":70,"max":120,"default":80},"unit"
          homeconnect.0	2021-02-02 13:30:09.943	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.SlowCook
          homeconnect.0	2021-02-02 13:30:08.521	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.IntensiveHeat","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":300,"default":190},
          homeconnect.0	2021-02-02 13:30:08.521	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.IntensiveHeat
          homeconnect.0	2021-02-02 13:30:07.271	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.PizzaSetting","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":275,"default":200},"
          homeconnect.0	2021-02-02 13:30:07.270	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.PizzaSetting
          homeconnect.0	2021-02-02 13:30:05.429	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.HotAirGrilling","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":300,"default":180}
          homeconnect.0	2021-02-02 13:30:05.428	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.HotAirGrilling
          homeconnect.0	2021-02-02 13:30:03.864	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.TopBottomHeatingEco","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":300,"default"
          homeconnect.0	2021-02-02 13:30:03.864	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.TopBottomHeatingEco
          homeconnect.0	2021-02-02 13:30:02.442	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.HotAirEco","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":275,"default":160},"uni
          homeconnect.0	2021-02-02 13:30:02.441	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.HotAirEco
          homeconnect.0	2021-02-02 13:30:00.938	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.TopBottomHeating","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":300,"default":17
          homeconnect.0	2021-02-02 13:30:00.938	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.TopBottomHeating
          homeconnect.0	2021-02-02 13:29:59.509	debug	(8718) {"data":{"key":"Cooking.Oven.Program.HeatingMode.HotAir","options":[{"name":"Temperatur","key":"Cooking.Oven.Option.SetpointTemperature","constraints":{"min":30,"max":275,"default":160},"unit":
          homeconnect.0	2021-02-02 13:29:59.509	debug	(8718) /programs/available/Cooking.Oven.Program.HeatingMode.HotAir
          homeconnect.0	2021-02-02 13:29:56.303	debug	(8718) {"data":{"name":"Energiezustand","key":"BSH.Common.Setting.PowerState","constraints":{"allowedvalues":["BSH.Common.EnumType.PowerState.MainsOff","BSH.Common.EnumType.PowerState.Off","BSH.Common
          homeconnect.0	2021-02-02 13:29:56.302	debug	(8718) /settings/BSH.Common.Setting.PowerState
          homeconnect.0	2021-02-02 13:29:47.711	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_BrillianceDry" has no existing object, this might lead to an error in future ver
          homeconnect.0	2021-02-02 13:29:47.701	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_VarioSpeedPlus" has no existing object, this might lead to an error in future ve
          homeconnect.0	2021-02-02 13:29:47.701	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_IntensivZone" has no existing object, this might lead to an error in future vers
          homeconnect.0	2021-02-02 13:29:47.700	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_HygienePlus" has no existing object, this might lead to an error in future versi
          homeconnect.0	2021-02-02 13:29:47.699	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.BSH_Common_Option_StartInRelative" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:29:47.692	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_BrillianceDry
          homeconnect.0	2021-02-02 13:29:47.691	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_VarioSpeedPlus
          homeconnect.0	2021-02-02 13:29:47.690	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_IntensivZone
          homeconnect.0	2021-02-02 13:29:47.689	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_HygienePlus
          homeconnect.0	2021-02-02 13:29:47.688	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.options.Kurz60.BSH_Common_Option_StartInRelative
          homeconnect.0	2021-02-02 13:29:47.687	debug	(8718) {"data":{"options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.HygienePlus","value":false,"name":"HygienePlus"}
          homeconnect.0	2021-02-02 13:29:47.686	debug	(8718) /programs/selected/options
          homeconnect.0	2021-02-02 13:29:47.203	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_BrillianceDry" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:29:47.202	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_VarioSpeedPlus" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:29:47.200	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_IntensivZone" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:29:47.198	warn	(8718) State "homeconnect.0.SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_HygienePlus" has no existing object, this might lead to an error in future versions
          homeconnect.0	2021-02-02 13:29:47.178	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_WaterForecast
          homeconnect.0	2021-02-02 13:29:47.177	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_EnergyForecast
          homeconnect.0	2021-02-02 13:29:47.176	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_RemainingProgramTime
          homeconnect.0	2021-02-02 13:29:47.175	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_ProgramProgress
          homeconnect.0	2021-02-02 13:29:47.175	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_BrillianceDry
          homeconnect.0	2021-02-02 13:29:47.174	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_VarioSpeedPlus
          homeconnect.0	2021-02-02 13:29:47.173	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_IntensivZone
          homeconnect.0	2021-02-02 13:29:47.172	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.Dishcare_Dishwasher_Option_HygienePlus
          homeconnect.0	2021-02-02 13:29:47.171	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_StartInRelative
          homeconnect.0	2021-02-02 13:29:47.170	debug	(8718) {"data":{"options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.HygienePlus","value":false,"name":"HygienePlus"}
          homeconnect.0	2021-02-02 13:29:47.169	debug	(8718) /programs/active/options
          homeconnect.0	2021-02-02 13:29:44.607	info	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC: There is no program selected
          homeconnect.0	2021-02-02 13:29:43.181	info	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC: There is no program active
          homeconnect.0	2021-02-02 13:29:41.837	info	(8718) SIEMENS-EX801KYW1E-68A40E26EDBB: There is no program selected
          homeconnect.0	2021-02-02 13:29:40.065	info	(8718) SIEMENS-EX801KYW1E-68A40E26EDBB: There is no program active
          homeconnect.0	2021-02-02 13:29:37.369	debug	(8718) {"data":{"name":"Temperaturformat","key":"BSH.Common.Setting.TemperatureUnit","constraints":{"allowedvalues":["BSH.Common.EnumType.TemperatureUnit.Celsius"],"displayvalues":["°C"],"default":"BS
          homeconnect.0	2021-02-02 13:29:37.369	debug	(8718) /settings/BSH.Common.Setting.TemperatureUnit
          homeconnect.0	2021-02-02 13:29:35.781	debug	(8718) {"data":{"name":"Energiezustand","key":"BSH.Common.Setting.PowerState","constraints":{"allowedvalues":["BSH.Common.EnumType.PowerState.Off","BSH.Common.EnumType.PowerState.On"],"displayvalues":
          homeconnect.0	2021-02-02 13:29:35.780	debug	(8718) /settings/BSH.Common.Setting.PowerState
          homeconnect.0	2021-02-02 13:29:34.075	debug	(8718) Rate per min: 47
          homeconnect.0	2021-02-02 13:29:34.033	debug	(8718) Rate per min: 46
          homeconnect.0	2021-02-02 13:29:34.031	debug	(8718) Delete: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options
          homeconnect.0	2021-02-02 13:29:34.030	debug	(8718) active.options.
          homeconnect.0	2021-02-02 13:29:33.480	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.selected.BSH_Common_Root_SelectedProgram
          homeconnect.0	2021-02-02 13:29:33.479	debug	(8718) {"data":{"key":"Dishcare.Dishwasher.Program.Kurz60","options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.Hygie
          homeconnect.0	2021-02-02 13:29:33.479	debug	(8718) /programs/selected
          homeconnect.0	2021-02-02 13:29:33.093	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.BSH_Common_Root_ActiveProgram
          homeconnect.0	2021-02-02 13:29:33.093	debug	(8718) {"data":{"key":"Dishcare.Dishwasher.Program.Kurz60","options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.Hygie
          homeconnect.0	2021-02-02 13:29:33.091	debug	(8718) /programs/active
          homeconnect.0	2021-02-02 13:29:30.659	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_MachineCare
          homeconnect.0	2021-02-02 13:29:30.658	debug	(8718) Rate per min: 45
          homeconnect.0	2021-02-02 13:29:30.658	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.MachineCare","name":"Machine Care","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.657	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_Quick45
          homeconnect.0	2021-02-02 13:29:30.656	debug	(8718) Rate per min: 44
          homeconnect.0	2021-02-02 13:29:30.655	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.Quick45","name":"Schnell 45°C","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.654	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_Glas40
          homeconnect.0	2021-02-02 13:29:30.653	debug	(8718) Rate per min: 43
          homeconnect.0	2021-02-02 13:29:30.651	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.Glas40","name":"Glas 40°C","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.650	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_Kurz60
          homeconnect.0	2021-02-02 13:29:30.650	debug	(8718) Rate per min: 42
          homeconnect.0	2021-02-02 13:29:30.649	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.Kurz60","name":"Kurz 60°C","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.649	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_NightWash
          homeconnect.0	2021-02-02 13:29:30.648	debug	(8718) Rate per min: 41
          homeconnect.0	2021-02-02 13:29:30.646	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.NightWash","name":"Leise","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.646	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_Eco50
          homeconnect.0	2021-02-02 13:29:30.645	debug	(8718) Rate per min: 40
          homeconnect.0	2021-02-02 13:29:30.645	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.Eco50","name":"Eco 50°C","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.644	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_Auto2
          homeconnect.0	2021-02-02 13:29:30.643	debug	(8718) Rate per min: 39
          homeconnect.0	2021-02-02 13:29:30.643	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.Auto2","name":"Auto 45-65°C","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.642	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.available.Dishcare_Dishwasher_Program_Intensiv70
          homeconnect.0	2021-02-02 13:29:30.641	debug	(8718) Rate per min: 38
          homeconnect.0	2021-02-02 13:29:30.641	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D available: {"key":"Dishcare.Dishwasher.Program.Intensiv70","name":"Intensiv 70°C","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:30.640	debug	(8718) {"data":{"programs":[{"key":"Dishcare.Dishwasher.Program.Intensiv70","name":"Intensiv 70°C","constraints":{"execution":"selectandstart","available":true}},{"key":"Dishcare.Dishwasher.Program.Au
          homeconnect.0	2021-02-02 13:29:30.639	debug	(8718) /programs
          homeconnect.0	2021-02-02 13:29:29.154	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.settings.BSH_Common_Setting_PowerState
          homeconnect.0	2021-02-02 13:29:29.154	debug	(8718) Rate per min: 37
          homeconnect.0	2021-02-02 13:29:29.154	debug	(8718) {"data":{"settings":[{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.On","name":"Energiezustand","displayvalue":"An"}]}}
          homeconnect.0	2021-02-02 13:29:29.153	debug	(8718) /settings
          homeconnect.0	2021-02-02 13:29:27.486	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.status.BSH_Common_Status_RemoteControlStartAllowed
          homeconnect.0	2021-02-02 13:29:27.485	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.status.BSH_Common_Status_RemoteControlActive
          homeconnect.0	2021-02-02 13:29:27.484	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.status.BSH_Common_Status_OperationState
          homeconnect.0	2021-02-02 13:29:27.484	debug	(8718) Create State: SIEMENS-SX678X36TE-68A40E0AAD2D.status.BSH_Common_Status_DoorState
          homeconnect.0	2021-02-02 13:29:27.483	debug	(8718) {"data":{"status":[{"key":"BSH.Common.Status.DoorState","value":"BSH.Common.EnumType.DoorState.Closed","name":"Tür","displayvalue":"Geschlossen"},{"key":"BSH.Common.Status.OperationState","valu
          homeconnect.0	2021-02-02 13:29:27.482	debug	(8718) /status
          homeconnect.0	2021-02-02 13:29:26.607	info	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC: There is no program selected
          homeconnect.0	2021-02-02 13:29:25.832	info	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC: There is no program active
          homeconnect.0	2021-02-02 13:29:25.749	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_ProgramProgress:75
          homeconnect.0	2021-02-02 13:29:25.749	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612268965,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:29:25.628	debug	(8718) SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options.BSH_Common_Option_RemainingProgramTime:1320
          homeconnect.0	2021-02-02 13:29:25.627	debug	(8718) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1612268965,\"handling\":\"none\",\"uri\":\"/api/homeappliances/SIEMENS-SX678X36TE-68A40E0AAD2D/programs/active/options/BSH.Common.Opti
          homeconnect.0	2021-02-02 13:29:23.139	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_FrozenHeatupSpecial
          homeconnect.0	2021-02-02 13:29:23.138	debug	(8718) Rate per min: 36
          homeconnect.0	2021-02-02 13:29:23.138	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.FrozenHeatupSpecial","name":"coolStart-Funktion","constraints":{"execution":"selectandstart","available":true}
          homeconnect.0	2021-02-02 13:29:23.138	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_PreheatOvenware
          homeconnect.0	2021-02-02 13:29:23.137	debug	(8718) Rate per min: 35
          homeconnect.0	2021-02-02 13:29:23.137	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.PreheatOvenware","name":"Geschirr vorwärmen","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.137	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_KeepWarm
          homeconnect.0	2021-02-02 13:29:23.136	debug	(8718) Rate per min: 34
          homeconnect.0	2021-02-02 13:29:23.136	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.KeepWarm","name":"Warmhalten","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.136	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_Desiccation
          homeconnect.0	2021-02-02 13:29:23.135	debug	(8718) Rate per min: 33
          homeconnect.0	2021-02-02 13:29:23.135	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.Desiccation","name":"Dörren","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.135	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_BottomHeating
          homeconnect.0	2021-02-02 13:29:23.135	debug	(8718) Rate per min: 32
          homeconnect.0	2021-02-02 13:29:23.134	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.BottomHeating","name":"Unterhitze","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.134	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_SlowCook
          homeconnect.0	2021-02-02 13:29:23.134	debug	(8718) Rate per min: 31
          homeconnect.0	2021-02-02 13:29:23.134	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.SlowCook","name":"Sanftgaren","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.133	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_IntensiveHeat
          homeconnect.0	2021-02-02 13:29:23.133	debug	(8718) Rate per min: 30
          homeconnect.0	2021-02-02 13:29:23.133	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.IntensiveHeat","name":"Intensivhitze","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.132	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_PizzaSetting
          homeconnect.0	2021-02-02 13:29:23.132	debug	(8718) Rate per min: 29
          homeconnect.0	2021-02-02 13:29:23.132	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.PizzaSetting","name":"Pizzastufe","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.131	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_HotAirGrilling
          homeconnect.0	2021-02-02 13:29:23.131	debug	(8718) Rate per min: 28
          homeconnect.0	2021-02-02 13:29:23.131	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.HotAirGrilling","name":"Umluftgrillen","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.131	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_TopBottomHeatingEco
          homeconnect.0	2021-02-02 13:29:23.130	debug	(8718) Rate per min: 27
          homeconnect.0	2021-02-02 13:29:23.130	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.TopBottomHeatingEco","name":"Ober-/ Unterhitze eco","constraints":{"execution":"selectandstart","available":tr
          homeconnect.0	2021-02-02 13:29:23.130	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_HotAirEco
          homeconnect.0	2021-02-02 13:29:23.129	debug	(8718) Rate per min: 26
          homeconnect.0	2021-02-02 13:29:23.129	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.HotAirEco","name":"Heißluft eco","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.129	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_TopBottomHeating
          homeconnect.0	2021-02-02 13:29:23.129	debug	(8718) Rate per min: 25
          homeconnect.0	2021-02-02 13:29:23.128	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.TopBottomHeating","name":"Ober-/ Unterhitze","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.128	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.available.Cooking_Oven_Program_HeatingMode_HotAir
          homeconnect.0	2021-02-02 13:29:23.128	debug	(8718) Rate per min: 24
          homeconnect.0	2021-02-02 13:29:23.127	debug	(8718) SIEMENS-HB678GBS6-68A40E2AC9AC available: {"key":"Cooking.Oven.Program.HeatingMode.HotAir","name":"4D Heißluft","constraints":{"execution":"selectandstart","available":true}}
          homeconnect.0	2021-02-02 13:29:23.127	debug	(8718) {"data":{"programs":[{"key":"Cooking.Oven.Program.HeatingMode.HotAir","name":"4D Heißluft","constraints":{"execution":"selectandstart","available":true}},{"key":"Cooking.Oven.Program.HeatingMod
          homeconnect.0	2021-02-02 13:29:23.126	debug	(8718) /programs
          homeconnect.0	2021-02-02 13:29:21.569	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.settings.BSH_Common_Setting_PowerState
          homeconnect.0	2021-02-02 13:29:21.568	debug	(8718) Rate per min: 23
          homeconnect.0	2021-02-02 13:29:21.567	debug	(8718) {"data":{"settings":[{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.Standby","name":"Energiezustand","displayvalue":"Standby"}]}}
          homeconnect.0	2021-02-02 13:29:21.566	debug	(8718) /settings
          homeconnect.0	2021-02-02 13:29:20.001	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.status.Cooking_Oven_Status_CurrentCavityTemperature
          homeconnect.0	2021-02-02 13:29:20.001	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.status.BSH_Common_Status_OperationState
          homeconnect.0	2021-02-02 13:29:20.000	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.status.BSH_Common_Status_RemoteControlActive
          homeconnect.0	2021-02-02 13:29:20.000	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.status.BSH_Common_Status_RemoteControlStartAllowed
          homeconnect.0	2021-02-02 13:29:20.000	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.status.BSH_Common_Status_LocalControlActive
          homeconnect.0	2021-02-02 13:29:19.999	debug	(8718) Create State: SIEMENS-HB678GBS6-68A40E2AC9AC.status.BSH_Common_Status_DoorState
          homeconnect.0	2021-02-02 13:29:19.999	debug	(8718) {"data":{"status":[{"key":"BSH.Common.Status.DoorState","value":"BSH.Common.EnumType.DoorState.Closed","name":"Tür","displayvalue":"Geschlossen"},{"key":"BSH.Common.Status.LocalControlActive","
          homeconnect.0	2021-02-02 13:29:19.999	debug	(8718) /status
          homeconnect.0	2021-02-02 13:29:18.689	info	(8718) SIEMENS-EX801KYW1E-68A40E26EDBB: There is no program selected
          homeconnect.0	2021-02-02 13:29:16.979	info	(8718) SIEMENS-EX801KYW1E-68A40E26EDBB: There is no program active
          homeconnect.0	2021-02-02 13:29:14.328	debug	(8718) Rate per min: 22
          homeconnect.0	2021-02-02 13:29:14.327	debug	(8718) Rate per min: 21
          homeconnect.0	2021-02-02 13:29:14.322	debug	(8718) Rate per min: 20
          homeconnect.0	2021-02-02 13:29:14.321	debug	(8718) Rate per min: 19
          homeconnect.0	2021-02-02 13:29:14.320	debug	(8718) Delete: SIEMENS-SX678X36TE-68A40E0AAD2D.programs.active.options
          homeconnect.0	2021-02-02 13:29:14.319	debug	(8718) active.options.
          homeconnect.0	2021-02-02 13:29:14.318	debug	(8718) Delete: SIEMENS-HB678GBS6-68A40E2AC9AC.programs.active.options
          homeconnect.0	2021-02-02 13:29:14.317	debug	(8718) active.options.
          homeconnect.0	2021-02-02 13:29:14.261	debug	(8718) Rate per min: 18
          homeconnect.0	2021-02-02 13:29:14.259	debug	(8718) Rate per min: 17
          homeconnect.0	2021-02-02 13:29:14.256	debug	(8718) Delete: SIEMENS-EX801KYW1E-68A40E26EDBB.programs.active.options
          homeconnect.0	2021-02-02 13:29:14.255	debug	(8718) active.options.
          homeconnect.0	2021-02-02 13:29:13.515	debug	(8718) Create State: SIEMENS-EX801KYW1E-68A40E26EDBB.status.BSH_Common_Status_RemoteControlActive
          homeconnect.0	2021-02-02 13:29:13.515	debug	(8718) Create State: SIEMENS-EX801KYW1E-68A40E26EDBB.status.BSH_Common_Status_OperationState
          homeconnect.0	2021-02-02 13:29:13.514	debug	(8718) Create State: SIEMENS-EX801KYW1E-68A40E26EDBB.status.BSH_Common_Status_LocalControlActive
          homeconnect.0	2021-02-02 13:29:13.513	debug	(8718) {"data":{"status":[{"key":"BSH.Common.Status.LocalControlActive","value":false,"name":"Lokale Bedienung aktiv"},{"key":"BSH.Common.Status.OperationState","value":"BSH.Common.EnumType.OperationS
          homeconnect.0	2021-02-02 13:29:13.512	debug	(8718) /status
          homeconnect.0	2021-02-02 13:29:12.999	debug	(8718) Create State: SIEMENS-EX801KYW1E-68A40E26EDBB.settings.BSH_Common_Setting_TemperatureUnit
          homeconnect.0	2021-02-02 13:29:12.998	debug	(8718) Rate per min: 16
          homeconnect.0	2021-02-02 13:29:12.997	debug	(8718) Create State: SIEMENS-EX801KYW1E-68A40E26EDBB.settings.BSH_Common_Setting_PowerState
          homeconnect.0	2021-02-02 13:29:12.996	debug	(8718) Rate per min: 15
          homeconnect.0	2021-02-02 13:29:12.994	debug	(8718) {"data":{"settings":[{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.Off","name":"Energiezustand","displayvalue":"Aus"},{"key":"BSH.Common.Setting.TemperatureUnit
          homeconnect.0	2021-02-02 13:29:12.994	debug	(8718) /settings
          homeconnect.0	2021-02-02 13:29:12.705	error	(8718) {"data":{"programs":[]}}
          homeconnect.0	2021-02-02 13:29:12.705	error	(8718) /programs
          homeconnect.0	2021-02-02 13:29:12.704	error	(8718) TypeError: Cannot read property 'forEach' of undefined at /opt/iobroker/node_modules/iobroker.homeconnect/main.js:943:57 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules
          homeconnect.0	2021-02-02 13:29:12.697	error	(8718) TypeError: Cannot read property 'forEach' of undefined
          homeconnect.0	2021-02-02 13:29:12.695	debug	(8718) {"data":{"programs":[]}}
          homeconnect.0	2021-02-02 13:29:12.693	debug	(8718) /programs
          homeconnect.0	2021-02-02 13:29:12.316	info	(8718) Accesstoken renewed...
          homeconnect.0	2021-02-02 13:29:12.245	debug	(8718) Start EventStream SIEMENS-SX678X36TE-68A40E0AAD2D
          homeconnect.0	2021-02-02 13:29:12.244	debug	(8718) Rate per min: 14
          homeconnect.0	2021-02-02 13:29:12.244	debug	(8718) Rate per min: 13
          homeconnect.0	2021-02-02 13:29:12.243	debug	(8718) Rate per min: 12
          homeconnect.0	2021-02-02 13:29:12.242	debug	(8718) Rate per min: 11
          homeconnect.0	2021-02-02 13:29:12.241	debug	(8718) Rate per min: 10
          homeconnect.0	2021-02-02 13:29:12.237	debug	(8718) Start EventStream SIEMENS-HB678GBS6-68A40E2AC9AC
          homeconnect.0	2021-02-02 13:29:12.236	debug	(8718) Rate per min: 9
          homeconnect.0	2021-02-02 13:29:12.235	debug	(8718) Rate per min: 8
          homeconnect.0	2021-02-02 13:29:12.234	debug	(8718) Rate per min: 7
          homeconnect.0	2021-02-02 13:29:12.233	debug	(8718) Rate per min: 6
          homeconnect.0	2021-02-02 13:29:12.233	debug	(8718) Rate per min: 5
          homeconnect.0	2021-02-02 13:29:12.223	debug	(8718) Start EventStream SIEMENS-EX801KYW1E-68A40E26EDBB
          homeconnect.0	2021-02-02 13:29:12.221	debug	(8718) Rate per min: 4
          homeconnect.0	2021-02-02 13:29:12.220	debug	(8718) Rate per min: 3
          homeconnect.0	2021-02-02 13:29:12.219	debug	(8718) Rate per min: 2
          homeconnect.0	2021-02-02 13:29:12.219	debug	(8718) Rate per min: 1
          homeconnect.0	2021-02-02 13:29:12.217	debug	(8718) Rate per min: 0
          homeconnect.0	2021-02-02 13:29:12.190	warn	(8718) SIEMENS-WM14U840EU-68A40E072F79 is not connected cannot fetch information.
          homeconnect.0	2021-02-02 13:29:11.303	info	(8718) starting. Version 0.0.31 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v12.20.1, js-controller: 3.2.12
          • GarganoG Offline
            GarganoG Offline
            Gargano
            #456
            @fenriswolf Sieht so aus , als wären die Informationen zu dem Zeitpunkt noch nicht da. Und Dein SIEMENS-WM14U840EU-68A40E072F79 is not connected
            • T tombox
              Konfiguration
              Benutzung
              LG
              dna909
              2 Offline
              2 Offline
              2hot4you
              #457
              Hallo @dna909
              der Adapter läuft bei mir, meine Spülmaschine wird auch erkannt und die Datenpunkte angezeigt.
              Nur nach einer gewissen Zeit wird der Adapter rot.
              Folgende Fehlermeldung bekomme ich.
              homeconnect.0	2021-02-08 22:01:25.416	error	(32340) The rate limit "1000 calls in 1 day" was reached. Requests are blocked during the remaining period of 50317 seconds.
              homeconnect.0	2021-02-08 22:01:25.416	error	(32340) Error getting Aplliances Error: 429
              Kann man die "calls" reduzieren ?
              • GarganoG Offline
                GarganoG Offline
                Gargano
                #458
                @2hot4you sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                The rate limit
                Ist ja interessant, da der Adapter so weit ich weiß nur auf Events reagiert und gar kein Polling macht. Was sagt denn der Log, wenn Du den Adapter auf Log Stufe Debug stellst ?
                Am besten Quelle auf homeconnect stellen.
                Kommt dann so eine Art Polling ?
                • 2 2hot4you
                  Hallo @dna909
                  tombox
                  #459
                  @2hot4you Das kann nur passieren wenn du den adapter zu oft neustartest. Einfach ein Tag warten und den Adapter nicht neustarten
                  • sigi234S Online
                    sigi234S Online
                    #460
                    installiert, funktioniert mit meine GS, Danke.
                    Warum kommen bestimmte Werte mit Klammern?
                    • sigi234S sigi234
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #461
                      @sigi234 das ist der Orginal Wert was die api liefert.. klick da mal rein .. das ist dann ein Auswahlmenü
                      sigi234S oberfraggerO A 3 Antworten Letzte Antwort
                      • arteckA arteck
                        sigi234S Online
                        sigi234S Online
                        #462
                        @arteck sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                        Jupp, überlege gerade wie ich das in Vis angezeigt bekommen. Habe da ja kein true /false oder 0/1 ?
                        Beispiel DP: (homeconnect.0.XXXXXXXXXXXXX.status.BSH_Common_Status_OperationState)
                          "type": "state",
                          "common": {
                            "name": "Betriebsstatus",
                            "type": "mixed",
                            "role": "indicator",
                            "write": true,
                            "read": true,
                            "unit": "",
                            "min": null,
                            "max": null,
                            "states": {
                              "BSH.Common.EnumType.OperationState.Finished": "Finished",
                          "native": {},
                          "from": "system.adapter.homeconnect.0",
                          "user": "system.user.admin",
                          "ts": 1613138487835,
                          "_id": "homeconnect.0.XXXXXXXXXXXXX.status.BSH_Common_Status_OperationState",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                        • sigi234S sigi234
                            "type": "state",
                            "common": {
                              "type": "mixed",
                              "write": true,
                              "read": true,
                              "unit": "",
                              "min": null,
                              "max": null,
                              "states": {
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          S Nicht stören
                          S Nicht stören
                          stenmic
                          #463
                          @sigi234 wie kommst du an die Werte für Fortschritt, Energie und Wasser?
                          • S stenmic
                            sigi234S Online
                            sigi234S Online
                            #464
                            @stenmic sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                            S Z 2 Antworten Letzte Antwort
                            • sigi234S sigi234
                              S Nicht stören
                              S Nicht stören
                              stenmic
                              #465
                              @sigi234 muss ich gleich mal gucken gehen
                              • arteckA arteck
                                oberfraggerO Offline
                                oberfragger
                                schrieb am zuletzt editiert von oberfragger
                                #466
                                @arteck Ich habe seit einigen tagen immenso Probleme mit dem rate-Limit.
                                Heute erst gegen 8:49 Uhr den Adapter wieder aktiviert. Ich habe einige Vielfacheinträge:
                                Das hier ist nach dem Adapterstart passiert...
                                Ideen? bzw. soll ich dass mal in Github posten?
                                Ich mache eigentlich nichts besonderes, bis auf mir ansagen zu lassen, welchen Kaffee ich hatte. Aber irgendwas scheint sich auf Bosch-Seite geändert zu haben. Habe Dunstabzugshaube, Induktionsfeld, Backofen und Kaffeemaschine.
                                wendy2702W T 2 Antworten Letzte Antwort
                                • oberfraggerO oberfragger
                                  wendy2702W Online
                                  wendy2702W Online
                                  #467
                                  @oberfragger Kannst du logs bitte als Text in Code Tags </> Posten.
                                  Das ist nur schlecht zu verarbeiten.
                                  Den Text auch bitte nicht aus dem Browser Fenster kopieren, da ist er oft abgeschnitten also am besten direkt aus dem logfile
                                  tail -f /opt/iobroker/log/iobroker.current.log | grep homeconnect
                                  oberfraggerO 1 Antwort Letzte Antwort
                                  • wendy2702W wendy2702
                                    oberfragger
                                    #468
                                    @wendy2702 Klar. Sollte nur einne Eindruck geben.
                                    Lieber via Forum oder Github?
                                    Das mit dem code klappt leider nicht. Die Kommandozeile bleibt hängen. Das bekomme ich doch dicher schnell via Notepad++ hin oder so. Ich guck mal uns sichere das.
                                    • arteckA arteck
                                      Amokd0c
                                      schrieb am zuletzt editiert von Amokd0c
                                      #469
                                      Servus!
                                      Darf ich kurz fragen, wie du die Werte aus diesem DP rausbekommst, damit meine Waschmaschine bei dem Wert "Finished" die Alexa brüllen lässt, das sie fertig ist? :)
                                      Besten Dank für deine Hilfe vorab!!!!
                                      Grüße doc...
                                      • A Amokd0c
                                        Servus!
                                        Grüße doc...
                                        sigi234S Online
                                        sigi234S Online
                                        #470
                                        @amokd0c sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                        Servus!
                                        Grüße doc...
                                        Hallo, noch nicht gefunden.
                                        Thomas SchulzeT 1 Antwort Letzte Antwort
                                        • sigi234S sigi234
                                          Servus!
                                          Grüße doc...
                                          Thomas SchulzeT Offline
                                          Thomas Schulze
                                          #471
                                          Gibt es derzeit Probleme mit der HomeConnect API?
                                          Bekomme keine Werte mehr(Waschmaschine) und gestern (18:40) habe ich auch eine Email bekommen:
                                          "*eine vorübergehende technische Störung sorgt aktuell für Verbindungsprobleme zwischen einigen Hausgeräten und den Home Connect Servern. Dies kann zu Einschränkungen bei den Home Connect Services führen.
                                          Natürlich arbeiten unsere Techniker bereits an der Behebung. Wir informieren dich, sobald sie das Problem behoben haben und alles wieder geschmeidig läuft.
                                          Entschuldige bitte die Unannehmlichkeiten!
                                          Dein Home Connect Team*"
                                          Hat noch jemand die gleichen Probleme?
