  4. (gelöst) iobroker auf neue Hardware umziehen
24 Beiträge 3 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • Y youthman1987
    die instanzen laufen. trotzdem nicht erreichbar.
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                : alexa2                -  enabled
      system.adapter.backitup.0              : backitup              -  enabled
      system.adapter.cloud.0                 : cloud                 -  enabled
      system.adapter.devices.0               : devices               -  enabled
      system.adapter.discovery.0             : discovery             -  enabled
      system.adapter.info.0                  : info                  -  enabled
      system.adapter.iot.0                   : iot                   -  enabled
      system.adapter.javascript.0            : javascript            -  enabled
      system.adapter.samsung_tizen.0         : samsung_tizen         -  enabled, port: 8002
      system.adapter.scenes.0                : scenes                -  enabled
      system.adapter.shelly.0                : shelly                -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis.0                   : vis                   -  enabled
      system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                 : yahka                 -  enabled
    Aber was mir aufgefallen ist.. nach upload all kommt das hier
    No alive host found which has the adapter yahka installed! No upload possible. Skipped.
    No alive host found which has the adapter web installed! No upload possible. Skipped.
    No alive host found which has the adapter vis installed! No upload possible. Skipped.
    No alive host found which has the adapter tuya installed! No upload possible. Skipped.
    No alive host found which has the adapter synology installed! No upload possible. Skipped.
    No alive host found which has the adapter sonoff installed! No upload possible. Skipped.
    No alive host found which has the adapter shelly installed! No upload possible. Skipped.
    No alive host found which has the adapter scenes installed! No upload possible. Skipped.
    No alive host found which has the adapter samsung_tizen installed! No upload possible. Skipped.
    No alive host found which has the adapter samsung installed! No upload possible. Skipped.
    No alive host found which has the adapter mqtt installed! No upload possible. Skipped.
    No alive host found which has the adapter javascript installed! No upload possible. Skipped.
    No alive host found which has the adapter iot installed! No upload possible. Skipped.
    upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
    upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
    upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
    upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
    upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
    upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
    upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
    upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
    upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
    upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
    upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
    upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
    upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
    upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
    upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
    upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
    upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
    upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
    upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
    upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
    upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
    upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
    upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
    upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
    upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
    upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
    upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
    Adapter "system.adapter.vis.0" restarted.
    No alive host found which has the adapter ham installed! No upload possible. Skipped.
    No alive host found which has the adapter fhem installed! No upload possible. Skipped.
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    No alive host found which has the adapter devices installed! No upload possible. Skipped.
    No alive host found which has the adapter cloud installed! No upload possible. Skipped.
    No alive host found which has the adapter broadlink2 installed! No upload possible. Skipped.
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    No alive host found which has the adapter alexa2 installed! No upload possible. Skipped.
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    @youthman1987
    iobroker host this
    iobroker start admin
    Y 1 Antwort Letzte Antwort
    • Y youthman1987
      Servus Jungs und Mädels : -D
      Ich habe mir einen Raspberry pi 4 zugelegt und würde gern mein iobroker von der Synology Nas (docker) umziehn.
      Backup machen und Wiederherstellen funktioniert auch.. egal ob übern backitup adapter oder übern terminal.
      Leider ist nach der Wiederherstellung iobroker nicht mehr erreichbar?
      Woran kann das liegen?
      @youthman1987 sagte in iobroker auf neue Hardware umziehen:
      wie lange hattest du nach dem Absetzen des restore Befehls gewartet, bis du etwas an der Installation gebastelt hast?
        @youthman1987
        iobroker host this
        Y Offline
        Y Offline
        youthman1987
        @thomas-braun said in iobroker auf neue Hardware umziehen:
        @youthman1987
        iobroker host this
        Das hat funktioniert!!
        DANKE vielmals!
        musste einfach der Host geändert werden?
        • Y youthman1987
          @youthman1987
          iobroker host this
          DANKE vielmals!
          @youthman1987
          Da war mit Sicherheit noch der host-Eintrag vom Altsystem drin.
            @youthman1987
            Y Offline
            Y Offline
            youthman1987
            ja bestimmt!
            jetzt hab ich wohl noch ein kleines Problem:
            pi@raspberrypi:~ $ sudo iobroker upload all
            INFO: Directory "for yahka.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "yahka"
            INFO: Directory "for yahka" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for web.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "web"
            INFO: Directory "for web" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for vis.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "vis"
            INFO: Directory "for vis" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for sonoff.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "sonoff"
            INFO: Directory "for sonoff" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for shelly.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "shelly"
            INFO: Directory "for shelly" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for scenes.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "scenes"
            INFO: Directory "for scenes" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for samsung_tizen.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "samsung_tizen"
            INFO: Directory "for samsung_tizen" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for javascript.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "javascript"
            INFO: Directory "for javascript" was not found! Nothing was uploaded or deleted.
            INFO: Directory "for iot.admin" was not found! Nothing was uploaded or deleted.
            Cannot find io-package.json for "iot"
            INFO: Directory "for iot" was not found! Nothing was uploaded or deleted.
            Update "system.adapter.discovery.0"
            upload [18] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
            upload [17] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
            upload [16] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/js/runtime-main.17cef1fa.js.map static/js/runtime-main.17cef1fa.js.map application/json
            upload [15] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/js/runtime-main.17cef1fa.js static/js/runtime-main.17cef1fa.js application/javascript
            upload [14] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/js/main.8672aec8.chunk.js.map static/js/main.8672aec8.chunk.js.map application/json
            upload [13] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/js/main.8672aec8.chunk.js static/js/main.8672aec8.chunk.js application/javascript
            upload [12] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/js/2.0b75fdfa.chunk.js.map static/js/2.0b75fdfa.chunk.js.map application/json
            upload [11] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/js/2.0b75fdfa.chunk.js.LICENSE.txt static/js/2.0b75fdfa.chunk.js.LICENSE.txt text/plain
            upload [10] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/js/2.0b75fdfa.chunk.js static/js/2.0b75fdfa.chunk.js application/javascript
            upload [9] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/css/2.63fb1a37.chunk.css.map static/css/2.63fb1a37.chunk.css.map application/json
            upload [8] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/css/2.63fb1a37.chunk.css static/css/2.63fb1a37.chunk.css text/css
            upload [7] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/service-worker.js service-worker.js application/javascript
            upload [6] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/precache-manifest.7acc0f29a651c3eef24d861cb817ad17.js precache-manifest.7acc0f29a651c3eef24d861cb817ad17.js application/javascript
            upload [5] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/manifest.json manifest.json application/json
            upload [4] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/index_m.html index_m.html text/html
            upload [3] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/index.html index.html text/html
            upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
            upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/devices.png devices.png image/png
            upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/asset-manifest.json asset-manifest.json application/json
            INFO: Directory "/opt/iobroker/node_modules/iobroker.devices/www" was not found! Nothing was uploaded or deleted.
            upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
            upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
            upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index.html index.html text/html
            upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
            upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
            upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
            upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
            upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
            Update "system.adapter.cloud.0"
            upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
            upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
            upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
            upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
            upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
            upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
            upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
            upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
            upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
            upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
            upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
            upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
            upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
            upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
            upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
            upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo4.png icons/echo4.png image/png
            upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
            upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
            upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo-input.png icons/echo-input.png image/png
            upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
            upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
            Update "system.adapter.admin.0"
            • Y youthman1987
              ja bestimmt!
              ja bestimmt
              ich habe eher den Eindruck der ist noch mitten im Restore
              • Y youthman1987
                ja bestimmt!
                @youthman1987
                Nix mit sudo und iobroker machen!
                Wenn das System zur Ruhe kommt:
                iobroker fix
                  ja bestimmt
                  Y Offline
                  Y Offline
                  youthman1987
                  das mit dem Host wird schon stimmen. Host namen waren unterschiedlich.
                  aber beim Rest würde ich es glauben. soll ich das alles von vorne starten und nach dem Restore länger warten bevor ich starte?
                  oder einfach jetzt warten?
                    @youthman1987
                    iobroker fix
                    Y Offline
                    Y Offline
                    youthman1987
                    oh ok! wusste ich nicht :) raspberry neuling : -D
                    • Y youthman1987
                      wie lange hattest du denn gewartet?
                      die Antwort steht noch aus.
                      sonst erst einmal warten
                        Y Offline
                        Y Offline
                        youthman1987
                        nicht lange.. Befehl ausgeführt und wo er fertig war weiter gemacht.
                        • Y youthman1987
                          böser fehler
                          danach installiert er alle Adapter neu.
                          im Backup ist nur die Konfig.
                          dauer etwa 1 Stunde
                          sieht man auch schön im log.
                            böser fehler
                            dauer etwa 1 Stunde
                            Y Offline
                            Y Offline
                            youthman1987
                            schrieb am zuletzt editiert von youthman1987
                            oh okay!
                            dann installiere ich iobroker einfach nochmal neu?
                            dann restore 0 und ne stunde warten.. dann weiter machen : -D
                            wobei.. wie du sagst er arbeitet gerade fleißig laut log
                            • Y youthman1987
                              oh okay!
                              oh okay!
                              keine operative Hektik!
                              warten!
                              neu machen kannst du immer noch
                                oh okay!
                                warten!
                                Y Offline
                                Y Offline
                                youthman1987
                                @homoran sieht so aus als hätte alles geklappt!
                                Danke euch nocheinmal! ihr seid die besten!
                                wartet ab bis ich mal ne VIS bauen will.. :D
                                • Y youthman1987
                                  @youthman1987
                                  Gut. Hast du den
                                  iobroker fix
                                  jetzt noch hinterhergeworfen?
                                    @youthman1987
                                    Gut. Hast du den
                                    iobroker fix
                                    Y Offline
                                    Y Offline
                                    youthman1987
                                    ja habe ich
