  4. Steckdose messen > Internetzugang entziehen
synology docker iobrokersteckdoseallgemeinsonytvs
240 Beiträge 8 Kommentatoren 21.2k Aufrufe 5 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @gonzoooox
    Das ist dein Problem. Das wechselt ständig von True auf False.
    Stoppe mal die Instanz. Und dann stellt du dort das Loglevel von info auf debug. Dann Instanz wieder starten.
    gONZOOOOx
    #157
    @ofbeqnpolkkl6mby5e13 said in Steckdose messen > Internetzugang entziehen:
    @gonzoooox
    tuya.0	2021-02-11 13:38:13.402	debug	(2552) connected set to true
    tuya.0	2021-02-11 13:38:13.401	debug	(2552) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1613047093398,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1613047093398}
    tuya.0	2021-02-11 13:38:13.401	debug	(2552) stateChange tuya.0.12280017d8f15bde4c31.online {"val":true,"ack":true,"ts":1613047093398,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1613047093398}
    tuya.0	2021-02-11 13:38:13.395	debug	(2552) 12280017d8f15bde4c31: Connected to device
    tuya.0	2021-02-11 13:38:13.330	info	(2552) Listen for encrypted local Tuya devices on port 6667
    tuya.0	2021-02-11 13:38:13.329	info	(2552) Listen for local Tuya devices on port 6666
    tuya.0	2021-02-11 13:38:13.327	info	(2552) Existing devices initialized
    tuya.0	2021-02-11 13:38:13.324	info	(2552) 12280017d8f15bde4c31 Init with IP=192.168.178.25, Key=b86b68f304c79447, Version=undefined
    tuya.0	2021-02-11 13:38:12.793	debug	(2552) connected set to false
    tuya.0	2021-02-11 13:38:12.787	debug	(2552) 12280017d8f15bde4c31 Register onChange for 17
    tuya.0	2021-02-11 13:38:12.786	debug	(2552) 12280017d8f15bde4c31 Register onChange for 9
    tuya.0	2021-02-11 13:38:12.786	debug	(2552) 12280017d8f15bde4c31 Register onChange for 1
    tuya.0	2021-02-11 13:38:12.785	debug	(2552) 12280017d8f15bde4c31: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"cou
    tuya.0	2021-02-11 13:38:12.784	debug	(2552) 12280017d8f15bde4c31: Create device objects if not exist
    tuya.0	2021-02-11 13:38:12.782	debug	(2552) init 1 known devices
    tuya.0	2021-02-11 13:38:12.754	info	(2552) starting. Version 3.5.2 in /opt/iobroker/node_modules/iobroker.tuya, node: v12.20.1, js-controller: 3.1.6
    tuya.0	2021-02-11 13:38:12.661	debug	(2552) Plugin sentry Initialize Plugin (enabled=true)
    tuya.0	2021-02-11 13:38:12.034	debug	(2552) statesDB connected
    tuya.0	2021-02-11 13:38:12.034	debug	(2552) States connected to redis: 127.0.0.1:9000
    tuya.0	2021-02-11 13:38:12.030	debug	(2552) States create System PubSub Client
    tuya.0	2021-02-11 13:38:12.029	debug	(2552) States create User PubSub Client
    tuya.0	2021-02-11 13:38:12.025	debug	(2552) Redis States: Use Redis connection: 127.0.0.1:9000
    tuya.0	2021-02-11 13:38:12.024	debug	(2552) objectDB connected
    tuya.0	2021-02-11 13:38:12.021	debug	(2552) Objects connected to redis: 127.0.0.1:9001
    tuya.0	2021-02-11 13:38:12.016	debug	(2552) Objects client initialize lua scripts
    tuya.0	2021-02-11 13:38:12.015	debug	(2552) Objects create User PubSub Client
    tuya.0	2021-02-11 13:38:12.014	debug	(2552) Objects create System PubSub Client
    tuya.0	2021-02-11 13:38:12.008	debug	(2552) Objects client ready ... initialize now
    tuya.0	2021-02-11 13:38:11.983	debug	(2552) Redis Objects: Use Redis connection: 127.0.0.1:9001
    tuya.0	2021-02-11 13:37:51.343	info	(1708) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    tuya.0	2021-02-11 13:37:51.342	info	(1708) terminating
    tuya.0	2021-02-11 13:37:48.339	info	(1708) Got terminate signal TERMINATE_YOURSELF
      @gonzoooox
      Hast du ein 5Ghz. WLAN mit demselben Namen wie das 2,4GHz. WLAN?
      gONZOOOOx
      #158
      @gonzoooox
      WLAN läuft auf 2,4 und 5 Ghz
      O 1 Antwort Letzte Antwort
      • G gONZOOOOx
        @gonzoooox
        O Offline
        O Offline
        #159
        @gonzoooox
        Selber Name für beide Frequenzen?
        G 1 Antwort Letzte Antwort
          @gonzoooox
          gONZOOOOx
          #160
          @gonzoooox
          ja hatte ich schon immer so...sag jetzt nicht ich muss zwei getrennte Netze machen :D
          • G gONZOOOOx
            @gonzoooox
            O Offline
            O Offline
            #161
            @gonzoooox
            Also das Log sieht soweit ich das beurteilen kann in Ordnung aus. Wenn du jetzt über iobroker schaltest, was wird dann geloggt?
            Diese ganzen WLAN-Steckdosen können nur 2,4GHz. WLAN und wenn ein 5GHz. WLAN denselben Namen hat, kann das zu Problemen führen. Grundsätzlich, das hat weder was mit iobroker noch mit dem Tuya-Adapter zu tun.
              @gonzoooox
              gONZOOOOx
              #162
              @gonzoooox
              tuya.0	2021-02-11 13:53:01.726	debug	(2552) 12280017d8f15bde4c31Device communication not initialized ...
              tuya.0	2021-02-11 13:53:01.726	debug	(2552) 12280017d8f15bde4c31 onChange triggered for 1 and value true
              tuya.0	2021-02-11 13:53:01.726	debug	(2552) stateChange tuya.0.12280017d8f15bde4c31.1 {"val":true,"ack":false,"ts":1613047981725,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1613047981725}
              tuya.0	2021-02-11 13:52:36.616	debug	(2552) 12280017d8f15bde4c31Device communication not initialized ...
              tuya.0	2021-02-11 13:52:36.616	debug	(2552) 12280017d8f15bde4c31 onChange triggered for 1 and value false
              tuya.0	2021-02-11 13:52:36.616	debug	(2552) stateChange tuya.0.12280017d8f15bde4c31.1 {"val":false,"ack":false,"ts":1613047956615,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1613047956615}
              einmal false einmal true gemacht.
              Diese ganzen WLAN-Steckdosen können nur 2,4GHz. WLAN und wenn ein 5GHz. WLAN denselben Namen hat, kann das zu Problemen führen. Grundsätzlich, das hat weder was mit iobroker, noch mit dem Tuya-Adapter zu tun.
              Also würdest du die beiden trennen?
              • G gONZOOOOx
                @gonzoooox
                O Offline
                O Offline
                #163
                @gonzoooox
                Ich habe das getrennt. Aber bevor du das jetzt machst, vielleicht installierst du erst mal den neuesten Adapter, da wurden weitere Schemata ergänzt.
                  @gonzoooox
                  gONZOOOOx
                  #164
                  @gonzoooox
                  Als du geschrieben hast, habe ich das Netz schon getrennt. Habe jetzt zwei Netze.
                  Instanz gelöscht neu hinzufügt
                  über Proxy neu verbunden
                  IP der Gosund wieder eingetragen > Punkt is grün
                  Container gestoppt wieder gestartet
                  Über die App schaltet sich die Steckdose, über iobroker nicht.
                  Den Adapter habe ich installiert, ist doch der aktuellste?
                  • G gONZOOOOx
                    @gonzoooox
                    O Offline
                    O Offline
                    #165
                    @gonzoooox
                    Wenn du oben auf das dritte Symbol von rechts klickst, dann kannst du unter "Von GITHUB" einen Adapter wählen. Da tippst du "tuya" ein und wählst den angzeigten Adapter. Dann installieren klicken.
                    3.5.6 ist glaube ich der Aktuelle.
                      @gonzoooox
                      gONZOOOOx
                      #166
                      @gonzoooox
                      ja habe ich. Container gestoppt, Instanz gestoppt alles neugestartet aber er macht einfach nix.
                      • G gONZOOOOx
                        @gonzoooox
                        O Offline
                        O Offline
                        #167
                        @gonzoooox
                        Im Moment habe ich auch keine Idee mehr. Vielleicht lässt du das System einfach mal in Ruhe und probierst es in ein paar Stunden noch mal. Oder morgen.
                          @gonzoooox
                          gONZOOOOx
                          #168
                          @gonzoooox
                          oh man, dass es so schwer sein kann...das verstehe ich einfach nicht :D aber vielen Dank für die Geduld :D
                          • G gONZOOOOx
                            @gonzoooox
                            O Offline
                            O Offline
                            #169
                            @gonzoooox
                            Vielleicht hat noch jemand anderes eine Idee. Oder du sprichst den Entwickler an...
                            • G gONZOOOOx
                              @gonzoooox
                              Was steht im Log, wenn der Adapter startet?
                              O Offline
                              O Offline
                              #170
                              @gonzoooox sagte in Steckdose messen > Internetzugang entziehen:
                              @gonzoooox
                              Ist "Version" mit dem aktuellen Adapter immer noch "undefined"?
                                @gonzoooox
                                gONZOOOOx
                                #171
                                @gonzoooox
                                tuya.0	2021-02-11 14:37:49.142	info	(1546) Listen for encrypted local Tuya devices on port 6667
                                tuya.0	2021-02-11 14:37:49.142	info	(1546) Listen for local Tuya devices on port 6666
                                tuya.0	2021-02-11 14:37:49.139	info	(1546) Existing devices initialized
                                tuya.0	2021-02-11 14:37:49.137	info	(1546) 12280017d8f15bde4c31 Init with IP=192.168.178.25, Key=8b52b7fa2179b855, Version=undefined
                                ja immer noch :(
                                • G gONZOOOOx
                                  @gonzoooox
                                  ja immer noch :(
                                  O Offline
                                  O Offline
                                  #172
                                  @gonzoooox
                                  Das sollte aber nicht das Problem sein. Gibt es irgendwas, was ebenfalls auf Port 6666 oder 6667 läuft?
                                    @gonzoooox
                                    #173
                                    @ofbeqnpolkkl6mby5e13 sagte in Steckdose messen > Internetzugang entziehen:
                                    Am besten jemand der sich mit Docker und Tuya auskennt
                                      @gonzoooox
                                      gONZOOOOx
                                      #174
                                      @gonzoooox
                                      nicht das ich wüsste...
                                        O Offline
                                        O Offline
                                        #175
                                        @homoran sagte in Steckdose messen > Internetzugang entziehen:
                                        Läuft bei mir einwandfrei im Buanet-Container.
                                          #176
                                          Dann musst du ja wissen, warum es hier nicht läuft 😂
