  4. [Gelöst] Zigbee Adapter bleibt gelb
44 Beiträge 2 Kommentatoren 5.5k Aufrufe 2 Beobachtet
  • Masterg 23M Masterg 23
    Leider bekomme ich den Stick nicht zum laufen. Er bleibt bei gelb stehen.
    Hier noch einmal die Logs:
    2021-02-04 10:41:01.874 - error: zigbee.0 (24470) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
    at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
    at Controller. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
    at Generator.next ()
    at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
    at new Promise ()
    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
    at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:308:33))
    2021-02-04 10:41:01.874 - info: zigbee.0 (24470) terminating
    2021-02-04 10:41:01.876 - info: zigbee.0 (24470) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-02-04 10:41:01.877 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-02-04 10:41:01.878 - error: zigbee.0 (24470) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-02-04 10:41:01.880 - error: zigbee.0 (24470) TypeError: Cannot read property 'getEntries' of null
    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
    at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:201:49)
    at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:120:43)
    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:187:42)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:304:20)
    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:450:41)
    at Zigbee.emit (events.js:314:20)
    at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
    2021-02-04 10:41:02.431 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-02-04 10:41:16.637 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
    2021-02-04 10:41:16.705 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27259
    2021-02-04 10:41:18.691 - info: zigbee.0 (27259) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.1.6
    2021-02-04 10:41:18.787 - info: zigbee.0 (27259) Starting Zigbee npm ...
    2021-02-04 10:42:20.765 - error: zigbee.0 (27259) Failed to start Zigbee
    2021-02-04 10:42:20.768 - error: zigbee.0 (27259) Error: AREQ - ZDO - stateChangeInd after 60000ms
    at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
    at listOnTimeout (internal/timers.js:554:17)
    at processTimers (internal/timers.js:497:7)
    2021-02-04 10:42:29.075 - info: tankerkoenig.0 (8160) Reading data from tankerkoenig ...
    2021-02-04 10:42:30.771 - info: zigbee.0 (27259) Try to reconnect. 1 attempts left
    2021-02-04 10:42:30.772 - info: zigbee.0 (27259) Starting Zigbee npm ...
    2021-02-04 10:42:31.024 - error: zigbee.0 (27259) Failed to start Zigbee
    2021-02-04 10:42:31.026 - error: zigbee.0 (27259) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
    @masterg-23
    Meld dich gefälligst nicht als root auf dem Pi an!
    Masterg 23M 1 Antwort Letzte Antwort
      @masterg-23
      Masterg 23M Offline
      Masterg 23M Offline
      Masterg 23
      @thomas-braun ok werde ich mir beherzigen. Wie kann ich jetzt mein Problem beheben?
      Hast du nen Tipp? Es hat ja gestern funktioniert. Nachdem ich den Node.js auf 12 aktualisiert habe, hat der Zigbee Adapter angefangen rumzuspinnen.
        @masterg-23 Wer weiß was du dir da mit dem rumgemurkse als root alles verbogen hast.
          Masterg 23M Offline
          Masterg 23M Offline
          Masterg 23
          @thomas-braun das hat damit nichts zu tun. Der Adapter hat davor schon nicht funktioniert. als Root bin ich nicht lange eingeloggt.
          Hat keine eine Idee was ich machen kann?
            @masterg-23 sagte in Zigbee Adapter bleibt gelb:
            Das hat mit der Länge nix zu tun. In deinem Screenshot sehe ich, dass du auch nicht sattelfest mit Konsolenbefehlen bist und da blind rummurkst. In einer root-shell tödlich.
              Masterg 23M Offline
              Masterg 23M Offline
              Masterg 23
              schrieb am zuletzt editiert von Masterg 23
              @thomas-braun ich habe es verstanden, dass ich es nicht machen soll. Hast du vielleicht auch paar tipps was mir ein Stück weiterhilft? Die Logs habe ich ja gepostet. Ich versteh nur nicht warum du immer wieder darauf rumhackst, dass ich keine Ahnung habe. Ich weiß, dass ich in dem Gebiet Neuling bin.
                @masterg-23
                iobroker fix
                Ausgabe von
                dmesg | grep -i ext4
                  @masterg-23
                  iobroker fix
                  Ausgabe von
                  Masterg 23M Offline
                  Masterg 23M Offline
                  Masterg 23
                  pi@raspberrypi:~ $ iobroker fix
                  library: loaded
                  Library version=2021-01-23
                  ioBroker or some processes are still running:
                   io.admin.0
                   io.alexa2.0
                   io.backitup.0
                   io.discovery.0
                   io.history.0
                   io.hue.0
                   io.info.0
                   io.iot.0
                   io.javascript.0
                   io.ping.0
                   io.pollenflug.0
                   io.tankerkoenig.0
                   io.trashschedule.0
                   io.web.0
                   io.yahka.0
                   io.zigbee.0
                  Please stop them first and try again!
                  pi@raspberrypi:~ $ dmesg | grep -i ext4
                  [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:38:C2:56 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=99672983-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [    1.929269] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                  [    1.929307] EXT4-fs (sda2): write access will be enabled during recovery
                  [    7.438101] EXT4-fs (sda2): recovery complete
                  [    7.439846] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                  [    7.439955] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [    9.186455] EXT4-fs (sda2): re-mounted. Opts: (null)
                  pi@raspberrypi:~ $
                  • Masterg 23M Offline
                    Masterg 23M Offline
                    Masterg 23
                    hier noch einmal die aktuellen Logs
                    2021-02-04 13:16:30.366 - error: zigbee.0 (1802) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                    at new Promise ()
                    2021-02-04 13:16:30.367 - info: zigbee.0 (1802) terminating
                    2021-02-04 13:16:30.369 - info: zigbee.0 (1802) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2021-02-04 13:16:30.370 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2021-02-04 13:16:30.371 - error: zigbee.0 (1802) unhandled promise rejection: Cannot read property 'getEntries' of null
                    2021-02-04 13:16:30.375 - error: zigbee.0 (1802) TypeError: Cannot read property 'getEntries' of null
                    2021-02-04 13:16:30.919 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2021-02-04 13:16:33.430 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1998
                    2021-02-04 13:16:36.012 - info: zigbee.0 (1998) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.1.6
                    2021-02-04 13:16:36.108 - info: zigbee.0 (1998) Starting Zigbee npm ...
                    2021-02-04 13:16:41.604 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                    2021-02-04 13:16:41.606 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                    2021-02-04 13:16:41.612 - info: zigbee.0 (1998) Got terminate signal TERMINATE_YOURSELF
                    2021-02-04 13:16:41.613 - info: zigbee.0 (1998) cleaned everything up...
                    2021-02-04 13:16:41.617 - info: zigbee.0 (1998) Zigbee: disabling joining new devices.
                    2021-02-04 13:16:41.620 - error: zigbee.0 (1998) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                    at new Promise ()
                    2021-02-04 13:16:41.621 - info: zigbee.0 (1998) terminating
                    2021-02-04 13:16:41.622 - info: zigbee.0 (1998) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2021-02-04 13:16:41.623 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2021-02-04 13:16:41.624 - error: zigbee.0 (1998) unhandled promise rejection: Cannot read property 'getEntries' of null
                    2021-02-04 13:16:41.626 - error: zigbee.0 (1998) TypeError: Cannot read property 'getEntries' of null
                    2021-02-04 13:16:42.168 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2021-02-04 13:16:44.660 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2072
                    2021-02-04 13:16:47.130 - info: zigbee.0 (2072) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.1.6
                    2021-02-04 13:16:47.252 - info: zigbee.0 (2072) Starting Zigbee npm ...
                    2021-02-04 13:17:49.262 - error: zigbee.0 (2072) Failed to start Zigbee
                    2021-02-04 13:17:49.265 - error: zigbee.0 (2072) Error: AREQ - ZDO - stateChangeInd after 60000ms
                    2021-02-04 13:17:59.267 - info: zigbee.0 (2072) Try to reconnect. 1 attempts left
                    2021-02-04 13:17:59.268 - info: zigbee.0 (2072) Starting Zigbee npm ...
                    2021-02-04 13:17:59.470 - error: zigbee.0 (2072) Failed to start Zigbee
                    2021-02-04 13:17:59.471 - error: zigbee.0 (2072) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                    at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                    at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                    at new Promise ()
                    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                    at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                    at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                    at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                    2021-02-04 13:20:33.008 - info: tankerkoenig.0 (1614) Reading data from tankerkoenig ...
                    2021-02-04 13:25:33.019 - info: tankerkoenig.0 (1614) Reading data from tankerkoenig ...
                    2021-02-04 13:26:39.974 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 5029
                    2021-02-04 13:26:39.986 - warn: host.raspberrypi instance system.adapter.daswetter.0 does not started, because just executed
                    2021-02-04 13:26:40.010 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 5035
                    2021-02-04 13:26:40.018 - warn: host.raspberrypi instance system.adapter.dwd.0 does not started, because just executed
                    2021-02-04 13:26:40.052 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 5042
                    2021-02-04 13:26:42.056 - info: daswetter.0 (5029) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.1, js-controller: 3.1.6
                    2021-02-04 13:26:42.786 - info: openweathermap.0 (5042) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v12.20.1, js-controller: 3.1.6
                    2021-02-04 13:26:42.791 - info: dwd.0 (5035) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.1, js-controller: 3.1.6
                    2021-02-04 13:26:43.443 - info: dwd.0 (5035) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2021-02-04 13:26:43.964 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2021-02-04 13:26:43.978 - warn: host.raspberrypi instance system.adapter.openweathermap.0 already running with pid 5042
                      library: loaded
                       io.admin.0
                       io.alexa2.0
                       io.backitup.0
                       io.discovery.0
                       io.history.0
                       io.hue.0
                       io.info.0
                       io.iot.0
                       io.javascript.0
                       io.ping.0
                       io.pollenflug.0
                       io.tankerkoenig.0
                       io.trashschedule.0
                       io.web.0
                       io.yahka.0
                       io.zigbee.0
                      pi@raspberrypi:~ $
                      @masterg-23
                      Dein Speichermedium hat wie erwartet einen Schuss.
                      Austauschen, neuinstallieren, Backup einspielen, nie root werden.
                        @masterg-23
                        Masterg 23M Offline
                        Masterg 23M Offline
                        Masterg 23
                        @thomas-braun Danke für deine Rückmeldung.
                        Ich betreibe den Pi mit einer SSD (ohne zusätzliche SD Karte). Das heißt meine SSD ist im Eimer?
                          @masterg-23
                          Zumindest ist die mal unsauber aus dem laufenden System gerupft worden. Stecker gezogen?
                          Masterg 23M 2 Antworten Letzte Antwort
                            @masterg-23
                            Masterg 23M Offline
                            Masterg 23M Offline
                            Masterg 23
                            @thomas-braun said in Zigbee Adapter bleibt gelb:
                            @masterg-23
                            In der Tat wurde die SSD aus dem laufenden System (unabsichtlich) herausgezogen.
                            Ich werde die SSD komplett platt machen und alles neu installieren, in der Hoffnung, dass es wieder geht.
                            Danke dir für deine Mühe.
                              @masterg-23
                              Masterg 23M Offline
                              Masterg 23M Offline
                              Masterg 23
                              @masterg-23
                              Hab die SSD platt gemacht und alles neu aufgespielt und ein iObroker backup von vorgestern drauf gespielt. Der Zigbee Adapter funktioniert immer noch nicht.
                              [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:38:C2:56 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=055eb926-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                              [    1.929040] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                              [    1.929141] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                              [    3.403708] EXT4-fs (sda2): re-mounted. Opts: (null)
                              pi@raspberrypi:~ $
                                @masterg-23
                                pi@raspberrypi:~ $
                                @masterg-23 Starte die Kiste mal sauber durch und dann schau ob die Meldungen zum recovery wegbleiben.
                                [Edit:] Im zweiten Anlauf dann wohl i. O.
                                  Masterg 23M Offline
                                  Masterg 23M Offline
                                  Masterg 23
                                  hab oben es aktualisiert
                                  pi@raspberrypi:~ $
                                  Der Adapter bleibt nach wie vor gelb
                                  hier die neuen Logs
                                  2021-02-04 14:21:58.075 - info: hue.0 (912) created/updated 9 groups channels
                                  2021-02-04 14:21:58.101 - info: hue.0 (912) created/updated 135 scenes
                                  2021-02-04 14:21:58.101 - info: hue.0 (912) creating/updating bridge device
                                  2021-02-04 14:21:59.372 - info: host.raspberrypi instance scheduled system.adapter.ical.0 0,30 * * * *
                                  2021-02-04 14:21:59.386 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 939
                                  2021-02-04 14:22:01.835 - info: ical.0 (939) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:02.418 - info: ical.0 (939) processing URL: Stadreinigung https://www.stadtreinigung-leipzig.de/leistungen/abfallentsorgung/abfallkalender-entsorgungstermine.html&ical=true&loc=Gregor-Fuchs-Straße%20%2039&lid=x11899
                                  2021-02-04 14:22:02.593 - info: ical.0 (939) processing URL: Feiertage https://p25-calendars.icloud.com/holidays/de_de.ics
                                  2021-02-04 14:22:03.623 - info: ical.0 (939) processing URL: Privat http://p41-caldav.icloud.com/published/2/MTA2NDk4OTMwMDEwNjQ5OHD4D7RgkkYYFi7o7l9nUcHA8H_WdWzUnEJc8jO1iLf7
                                  2021-02-04 14:22:03.850 - info: host.raspberrypi instance system.adapter.info.0 started with pid 973
                                  2021-02-04 14:22:07.483 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 1017
                                  2021-02-04 14:22:09.508 - info: ical.0 (939) Terminated (NO_ERROR): Without reason
                                  2021-02-04 14:22:09.637 - info: alexa2.0 (613) Subscribing to states...
                                  2021-02-04 14:22:10.030 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                  2021-02-04 14:22:10.566 - info: iot.0 (1017) starting. Version 1.8.9 in /opt/iobroker/node_modules/iobroker.iot, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:10.631 - info: iot.0 (1017) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                  2021-02-04 14:22:11.398 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 1044
                                  2021-02-04 14:22:11.675 - info: info.0 (973) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:12.500 - info: iot.0 (1017) Connection changed: connect
                                  2021-02-04 14:22:15.457 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 1524
                                  2021-02-04 14:22:15.534 - info: javascript.0 (1044) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:15.682 - info: javascript.0 (1044) requesting all states
                                  2021-02-04 14:22:15.684 - info: javascript.0 (1044) requesting all objects
                                  2021-02-04 14:22:17.524 - info: javascript.0 (1044) received all objects
                                  2021-02-04 14:22:17.583 - info: ping.0 (1524) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:17.738 - info: javascript.0 (1044) received all states
                                  2021-02-04 14:22:18.354 - info: javascript.0 (1044) Start javascript script.js.common.Alexa.Bad_Licht
                                  2021-02-04 14:22:18.422 - info: javascript.0 (1044) script.js.common.Alexa.Bad_Licht: registered 1 subscription and 0 schedules
                                  2021-02-04 14:22:19.421 - info: host.raspberrypi instance system.adapter.pollenflug.0 started with pid 1569
                                  2021-02-04 14:22:21.476 - info: pollenflug.0 (1569) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.pollenflug, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:21.506 - info: pollenflug.0 (1569) Starting Adapter pollenflug.0 in version 1.0.6
                                  2021-02-04 14:22:21.545 - info: pollenflug.0 (1569) Requesting DWD pollen information now.
                                  2021-02-04 14:22:23.205 - info: pollenflug.0 (1569) Next DWD pollen request starts on Fri Feb 05 2021 11:00:00 GMT+0000 (GMT)
                                  2021-02-04 14:22:23.415 - info: host.raspberrypi instance system.adapter.tankerkoenig.0 started with pid 1600
                                  2021-02-04 14:22:27.416 - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 1626
                                  2021-02-04 14:22:28.395 - info: tankerkoenig.0 (1600) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:28.429 - info: tankerkoenig.0 (1600) Sync time set to 5 minutes or 300000 ms
                                  2021-02-04 14:22:28.475 - info: tankerkoenig.0 (1600) Reading data from tankerkoenig ...
                                  2021-02-04 14:22:29.626 - info: trashschedule.0 (1626) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:31.450 - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 1669
                                  2021-02-04 14:22:32.764 - info: vis-inventwo.0 (1669) starting. Version 2.7.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:36.690 - info: vis.0 (1696) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:36.997 - info: vis.0 (1696) vis license is OK.
                                  2021-02-04 14:22:39.146 - info: vis.0 (1696) Terminated (NO_ERROR): Without reason
                                  2021-02-04 14:22:39.422 - info: host.raspberrypi instance system.adapter.web.0 started with pid 1723
                                  2021-02-04 14:22:39.681 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                                  2021-02-04 14:22:41.095 - info: web.0 (1723) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:41.377 - info: web.0 (1723) socket.io server listening on port 8082
                                  2021-02-04 14:22:41.382 - info: web.0 (1723) http server listening on port 8082
                                  2021-02-04 14:22:43.451 - info: host.raspberrypi instance system.adapter.yahka.0 started with pid 1762
                                  2021-02-04 14:22:45.248 - info: yahka.0 (1762) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.yahka, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:22:45.277 - info: yahka.0 (1762) adapter ready, checking config
                                  2021-02-04 14:22:45.292 - info: yahka.0 (1762) adding Raspberry Pi with UUID: e454435b-21ae-4258-bf01-336cd9b8344a
                                  2021-02-04 14:22:45.306 - info: yahka.0 (1762) adding Fernseher with UUID: 27c0d98c-39a3-4010-ae9a-9334398ba56b
                                  2021-02-04 14:22:45.312 - info: yahka.0 (1762) publishing bridge Yahka-0 on 0.0.0.0
                                  2021-02-04 14:23:06.071 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                                  2021-02-04 14:23:06.126 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1874
                                  2021-02-04 14:23:08.278 - info: zigbee.0 (1874) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:23:08.409 - info: zigbee.0 (1874) Starting Zigbee npm ...
                                  2021-02-04 14:24:10.393 - error: zigbee.0 (1874) Failed to start Zigbee
                                  2021-02-04 14:24:10.395 - error: zigbee.0 (1874) Error: AREQ - ZDO - stateChangeInd after 60000ms
                                  at Timeout.waiter.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
                                  at ontimeout (timers.js:436:11)
                                  at tryOnTimeout (timers.js:300:5)
                                  at listOnTimeout (timers.js:263:5)
                                  at Timer.processTimers (timers.js:223:10)
                                  2021-02-04 14:24:20.398 - info: zigbee.0 (1874) Try to reconnect. 1 attempts left
                                  2021-02-04 14:24:20.399 - info: zigbee.0 (1874) Starting Zigbee npm ...
                                  2021-02-04 14:24:20.611 - error: zigbee.0 (1874) Failed to start Zigbee
                                  2021-02-04 14:24:20.612 - error: zigbee.0 (1874) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                                  at new Promise ()
                                  at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                  at binding.open.then.err (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12)
                                  2021-02-04 14:24:28.755 - info: web.0 (1723) ==>Connected system.user.admin from ::ffff:192.168.0.2
                                  2021-02-04 14:24:28.782 - info: web.0 (1723) <==Disconnect system.user.admin from ::ffff:192.168.0.2 vis.0
                                  2021-02-04 14:24:29.948 - info: web.0 (1723) ==>Connected system.user.admin from ::ffff:192.168.0.2
                                  2021-02-04 14:25:00.044 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 2382
                                  2021-02-04 14:25:02.250 - info: dwd.0 (2382) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:25:07.297 - info: dwd.0 (2382) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-04 14:25:07.828 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-04 14:25:48.892 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                  2021-02-04 14:25:48.896 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                  2021-02-04 14:25:48.906 - info: zigbee.0 (1874) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-04 14:25:48.910 - info: zigbee.0 (1874) cleaned everything up...
                                  2021-02-04 14:25:48.922 - info: zigbee.0 (1874) Zigbee: disabling joining new devices.
                                  2021-02-04 14:25:48.927 - error: zigbee.0 (1874) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                                  at new Promise ()
                                  2021-02-04 14:25:48.929 - info: zigbee.0 (1874) terminating
                                  2021-02-04 14:25:48.932 - info: zigbee.0 (1874) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-04 14:25:48.934 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2021-02-04 14:25:48.935 - error: zigbee.0 (1874) unhandled promise rejection: Cannot read property 'getEntries' of null
                                  2021-02-04 14:25:48.938 - error: zigbee.0 (1874) TypeError: Cannot read property 'getEntries' of null
                                  at Zigbee.emit (events.js:198:13)
                                  2021-02-04 14:25:49.462 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-04 14:25:51.940 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2632
                                  2021-02-04 14:25:54.667 - info: zigbee.0 (2632) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:25:54.760 - info: zigbee.0 (2632) Starting Zigbee npm ...
                                  2021-02-04 14:26:00.362 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                  2021-02-04 14:26:00.364 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                  2021-02-04 14:26:00.368 - info: zigbee.0 (2632) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-04 14:26:00.370 - info: zigbee.0 (2632) cleaned everything up...
                                  2021-02-04 14:26:00.377 - info: zigbee.0 (2632) Zigbee: disabling joining new devices.
                                  2021-02-04 14:26:00.380 - error: zigbee.0 (2632) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                                  at new Promise ()
                                  2021-02-04 14:26:00.381 - info: zigbee.0 (2632) terminating
                                  2021-02-04 14:26:00.382 - info: zigbee.0 (2632) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-04 14:26:00.383 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2021-02-04 14:26:00.383 - error: zigbee.0 (2632) unhandled promise rejection: Cannot read property 'getEntries' of null
                                  2021-02-04 14:26:00.386 - error: zigbee.0 (2632) TypeError: Cannot read property 'getEntries' of null
                                  2021-02-04 14:26:01.367 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 2632
                                  2021-02-04 14:26:01.407 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-04 14:26:03.384 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2691
                                  2021-02-04 14:26:05.998 - info: zigbee.0 (2691) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:26:06.091 - info: zigbee.0 (2691) Starting Zigbee npm ...
                                  2021-02-04 14:26:27.358 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                  2021-02-04 14:26:27.360 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                  2021-02-04 14:26:27.366 - info: zigbee.0 (2691) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-04 14:26:27.368 - info: zigbee.0 (2691) cleaned everything up...
                                  2021-02-04 14:26:27.373 - info: zigbee.0 (2691) Zigbee: disabling joining new devices.
                                  2021-02-04 14:26:27.375 - error: zigbee.0 (2691) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                                  at new Promise ()
                                  2021-02-04 14:26:27.376 - info: zigbee.0 (2691) terminating
                                  2021-02-04 14:26:27.378 - info: zigbee.0 (2691) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-04 14:26:27.379 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2021-02-04 14:26:27.379 - error: zigbee.0 (2691) unhandled promise rejection: Cannot read property 'getEntries' of null
                                  2021-02-04 14:26:27.382 - error: zigbee.0 (2691) TypeError: Cannot read property 'getEntries' of null
                                  2021-02-04 14:26:27.936 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-04 14:26:30.381 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2827
                                  2021-02-04 14:26:33.153 - info: zigbee.0 (2827) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.23.2, js-controller: 3.1.6
                                  2021-02-04 14:26:33.244 - info: zigbee.0 (2827) Starting Zigbee npm ...
                                  2021-02-04 14:27:28.532 - info: tankerkoenig.0 (1600) Reading data from tankerkoenig ...
                                    pi@raspberrypi:~ $
                                    hier die neuen Logs
                                    at new Promise ()
                                    at new Promise ()
                                    at new Promise ()
                                    at new Promise ()
                                    @masterg-23
                                    Da ist ja wieder node10 drin.
                                    Installierst du den ioBroker nicht per Einzeiler? Der bringt nämlich direkt node12 mit.
                                      @masterg-23
                                      Masterg 23M Offline
                                      Masterg 23M Offline
                                      Masterg 23
                                      @masterg-23
                                      Ich hatte ein Backup von dem gesamten System gemacht. Auf meinem Pi läuft nur PiHole und ioBroker. Dann habe ich mit dem Tool ApplePi-Baber v.2.2.3 das Image auf die Festplatte aufgespielt. Das Backup ist ca. 3 Wochen alt.
                                      Ich hatte damals ein komplett Backup erstellt, nachdem ich ioBroker inkl. die ganzen Adapter installiert hatte.
                                      Soll ich die Festplatte noch einmal platt machen und alles frisch installieren (ohne restore)?
                                      was meinst du genau mit Einzeiler?
                                      meinst du damit das hier?
                                      curl -sL https://iobroker.net/install.sh | bash -
                                        @masterg-23
                                        @masterg-23
                                        Den Einzeiler meine ich.
                                        Du kannst aber node jetzt auch händisch auf 12 bringen. Anleitung kennst du ja.
                                        Dann würde ich den zigbee-Adapter ausnahmsweise auch mal auf eine Version 1.4.x aus dem Beta-Repo bringen.
                                          @masterg-23
                                          Masterg 23M Offline
                                          Masterg 23M Offline
                                          Masterg 23
                                          @masterg-23
                                          In der Anleitung steht:
                                          Wichtig und richtig ist:
                                          nodejs liegt in /usr/bin
                                          node liegt in /usr/bin
                                          npm liegt in /usr/bin
                                          bei mir sieht es jedoch so aus:
                                          pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                          /usr/bin/nodejs
                                          v10.23.2
                                          /usr/bin/node
                                          v10.23.2
                                          /usr/bin/npm
                                          6.14.10
                                          nodejs:
                                            Installiert:           10.23.2-1nodesource1
                                            Installationskandidat: 12.20.1-1nodesource1
                                            Versionstabelle:
                                               12.20.1-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                           *** 10.23.2-1nodesource1 100
                                               10.23.1~dfsg-1~deb10u1 500
                                          scheint nicht geklappt zu haben. Ist immer noch node 10 drauf. Oh man :(
                                          EDIT: jetzt scheint es installiert zu sein
                                          /usr/bin/nodejs
                                          v12.20.1
                                          /usr/bin/node
                                          v12.20.1
                                          /usr/bin/npm
                                          6.14.10
                                          nodejs:
                                            Installiert:           12.20.1-1nodesource1
                                            Versionstabelle:
                                           *** 12.20.1-1nodesource1 500
