  4. js-controller 3.2 jetzt im Latest!
575 Beiträge 70 Kommentatoren 189.5k Aufrufe 57 Beobachtet
  • FredFF FredF
    @apollon77
    Ist das ein Fehler des rpi2 Adapter den ich auf einem neuen 3.2.12 Slave installiert habe?
    Cannot read property 'length' of undefined at PacketManager.install (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupPacketManager.js:221:24) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-01-31 12:28:08.942 - info: host.iobTest iobroker add rpi2 --host iobroker-pi
    2021-01-31 12:28:10.202 - info: host.iobTest iobroker NPM version: 6.14.10
    2021-01-31 12:28:10.204 - info: host.iobTest iobroker npm install iobroker.rpi2@1.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
    2021-01-31 12:28:18.674 - info: host.iobTest iobroker host.iobTest install adapter rpi2
    2021-01-31 12:28:18.821 - error: host.iobTest iobroker TypeError: Cannot read property 'length' of undefined at PacketManager.install (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupPacketManager.js:221:24) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-01-31 12:28:18.833 - info: host.iobTest iobroker upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    2021-01-31 12:28:18.899 - info: host.iobTest iobroker upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
    2021-01-31 12:28:18.952 - info: host.iobTest iobroker upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
    2021-01-31 12:28:19.005 - info: host.iobTest iobroker upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index.html index.html text/html
    2021-01-31 12:28:19.082 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2 created/updated
    2021-01-31 12:28:19.098 - info: host.iobTest iobroker host.iobTest create instance rpi2
    2021-01-31 12:28:19.102 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.logLevel created
    2021-01-31 12:28:19.129 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.sigKill created
    2021-01-31 12:28:19.157 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.eventLoopLag created
    2021-01-31 12:28:19.184 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.outputCount created
    2021-01-31 12:28:19.212 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.inputCount created
    2021-01-31 12:28:19.239 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.uptime created
    2021-01-31 12:28:19.266 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.memRss created
    2021-01-31 12:28:19.294 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.memHeapTotal created
    2021-01-31 12:28:19.321 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.memHeapUsed created
    2021-01-31 12:28:19.348 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.cputime created
    2021-01-31 12:28:19.376 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.cpu created
    2021-01-31 12:28:19.405 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.compactMode created
    2021-01-31 12:28:19.431 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.connected created
    2021-01-31 12:28:19.458 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0.alive created
    2021-01-31 12:28:19.491 - info: host.iobTest iobroker host.iobTest object system.adapter.rpi2.0 created
    2021-01-31 12:28:20.501 - info: host.iobTest iobroker exit 0
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #345
    @fredf fix kommt mit in die 3.2.13
    Videotutorials & mehr
      #346
      Ich habe gerade noch eine uralte Installation "gefunden" mit Jessie und node 6.
      Die habe ich mal zum experimentieren genommen, zuerst Armbian über Stretch auf Buster gebracht, dann node auf 14.x
      Dann lief natürlich gar nichts mehr, auch ein npm rebuild (in /opt/iobroker) hat nichts geholfen.
      Also erstmal den Controller auf 3.2.12 gebracht und dann weiter.
      Jetzt hängt er beim Upgrade von cul mit einer mir nicht verständlichen Meldung:
      Update cul from @0.4.0 to @1.3.4
      npm install iobroker.cul@1.3.4 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code ENOENT
      npm ERR! syscall access
      npm ERR! path /opt/iobroker/node_modules/iobroker.rickshaw
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.rickshaw'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      Was will er denn von rickshaw?
      J apollon77A 2 Antworten Letzte Antwort
        npm ERR! errno -2
        npm ERR! enoent
        Jan1
        #347
        Den Adapter gibt's wohl nicht mehr da schon lange mit irgendwas nicht kompatibel und nie angepasst. Den hatte ich zu Beginn mal um den History schön zu visualisieren.
        Ich denke, dass den einfach löschen kannst, da der eh nicht mehr läuft.
        Ist aber mal interessant, ob Du es schaffst die Steinzeit Installation noch in die Neuzeit zu holen.
        • J Jan1
          #348
          @jan1 sagte in js-controller 3.2 jetzt im Latest!:
          mit dem funktionieren aber die Kurven in der History ;-)
          Das "Problem" war aber, was hat der mit dem Upgrade vvom CUL am Hut?
            Jan1
            #349
            Echt der geht noch?
            Wenn Das geht kommt der sofort wieder drauf, weil ich genau die Kurven vermisse.
            Warum der hier in der Kombi nun im Error mitauftaucht, absolut kein Plan.
            • J Jan1
              Echt der geht noch?
              crunchipC Abwesend
              crunchipC Abwesend
              #350
              @jan1 ich hab den auch noch drauf
                #351
                Und noch was:
                War zwar nicht easy, sieht aber vielversprechend aus.
                Ich kann nur jedem empfehlen immer alles aktuell zu halten und nicht zu denken "never touch..."
                  Und noch was:
                  #352
                  @homoran sagte in js-controller 3.2 jetzt im Latest!:
                  Mein Reden...
                  Man muss ja nicht 'on the bleeding edge' tänzeln, aber so alle paar Wochen, mindestens aber 2x im Jahr sollte man den großen Kehraus machen. Dann sind die zu tätigenden Klimmzüge auch nicht ganz so heftig.
                    Mein Reden...
                    #353
                    @thomas-braun ...und die Repos noch nicht im Archiv unter anderem Pfad (oder gar nicht mehr) verfügbar
                      #354
                      und noch etwas!
                      Vielleicht für die Roadmap für v4.
                      Wenn es denn umsetzbar ist.
                      Mir ist eben das Upgrade von mobile UI (04.10 -> 1.0.0) mit Fehler (cannot connect to databases) ausgestiegen.
                      Falls das so ist, weil mobileUI nicht mehr auf npm sein sollte, wäre es schön solche Dinge per Popup abzufangen.
                      Falls aber die Ursache eine andere ist (da stand später etwas von "falsche Version von Web" im log, wo es gar nicht hinpasste
                      Adapter "mikrotik"       is not installed.
                      Adapter "milight"        is not installed.
                      Adapter "milight-smart-light" is not installed.
                      Adapter "minuvis"        is not installed.
                      ERROR: Invalid version of "web". Installed "2.3.6", required ">=3.0.12
                      Adapter "modbus"         is not installed.
                      Adapter "moma"           is not installed.
                      Adapter "mpd"            is not installed.
                      Adapter "mqtt"           is not installed.
                      dann wäre es auch schön irgendwann einmal die Reihenfolge der Updates bei "alle Updaten" so zu konfigurieren, dass bei einer fehlenden Dependency diese zuerst abgearbeitet wird.
                      Ich hoffe das war verständlich!
                      Mir ist klar, dass so etwas nicht "mal eben" gehen wird, wenn überhaupt!
                      Thomas BraunT foxriver76F 2 Antworten Letzte Antwort
                        und noch etwas!
                        #355
                        'Dependency hell' ist nicht umsonst ein großes Problem bei Paket-orientierten Distributionen.
                          und noch etwas!
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          #356
                          Haben wir auf dem Schirm: https://github.com/ioBroker/ioBroker.js-controller/issues/1015
                            npm ERR! errno -2
                            npm ERR! enoent
                            #357
                            @homoran Naja das übliche npm Thema ... npm prüft seinen gesamten Baum bei jedem kleinsten install ... Da ist wohl irgendwas
                            • apollon77A apollon77
                              Bogie
                              #358
                              Habe den Controller in der Version 3.2.12 installiert und musste im Anschluss feststellen, dass damit der Innogy Smarthome Adapter nicht mehr funktioniert. Authorisation nicht mehr möglich, blanke Seite und Adapter auf rot. Vielleicht checkt das Mal jemand. Plattform Ubuntu 20.04, Innogy Smarthome Adapter 0.3.6, js-Controller 3.2.12.
                              • B Bogie
                                ChaotC Offline
                                ChaotC Offline
                                Chaot
                                #359
                                @bogie Einerseits währe eine vollständige Fehlermeldung nicht schlecht und andererseits wäre es auch sinnvoll wenn du das dem Adapterentwickler schreibst das er nachbessern muss.
                                • apollon77A Offline
                                  #360
                                  So, nach mehreren Tagen ohne weitere Probleme haben wir nochmals alles angefallene und ein paar Optimierungen zusammengesammelt und damit gibt es jetzt die 3.2.13 auf npm und bald im Latest:
                                  3.2.13 (2021-02-01)
                                  • see CHANGELOG.md, Finalized stable release
                                  • (Apollon77) adjust error logging in some places
                                  • (foxriver76) fix client name in redis
                                  • (foxriver76) fix errors from package manager
                                  ? O ChaotC L FeuersturmF 5 Antworten Letzte Antwort
                                    3.2.13 (2021-02-01)
                                    #361
                                    @apollon77
                                    Guten morgn!
                                    Dankeschön, die 3.2.13 läuft hier unter Node 12.20.0 ( Debian 10, Raspi Zero), Node 12.20.2 (Debian 10, Raspi2 und 3), Node 14.15.4 (LXC Debian 10) ohne Auffälligkeiten.
                                    ilovegym@VMC123-iobroker:/opt/iobroker$ iobroker list adapters
                                    system.adapter.admin                   : admin          - v4.2.1
                                    system.adapter.alarm                   : alarm          - v1.9.0
                                    system.adapter.alexa2                  : alexa2         - v3.6.1
                                    system.adapter.amazon-dash             : amazon-dash    - v1.1.0
                                    system.adapter.backitup                : backitup       - v1.8.5
                                    system.adapter.ble                     : ble            - v0.12.0
                                    system.adapter.broadlink2              : broadlink2     - v2.1.5
                                    system.adapter.cloud                   : cloud          - v4.0.9
                                    system.adapter.countdown               : countdown      - v1.1.0
                                    system.adapter.device-reminder         : device-reminder - v1.0.6
                                    system.adapter.discovery               : discovery      - v2.5.0
                                    system.adapter.enigma2                 : enigma2        - v1.3.2
                                    system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.2
                                    system.adapter.feiertage               : feiertage      - v1.0.19
                                    system.adapter.fritzbox                : fritzbox       - v0.3.1
                                    system.adapter.fritzdect               : fritzdect      - v2.1.7
                                    system.adapter.fully-tablet-control    : fully-tablet-control - v0.3.2-beta.0
                                    system.adapter.fullybrowser            : fullybrowser   - v2.0.4
                                    system.adapter.gartenbewaesserung      : gartenbewaesserung - v0.0.7
                                    system.adapter.habpanel                : habpanel       - v0.4.3
                                    system.adapter.ham                     : ham            - v3.0.2
                                    system.adapter.hp-ilo                  : hp-ilo         - v1.0.6
                                    system.adapter.ical                    : ical           - v1.9.1
                                    system.adapter.influxdb                : influxdb       - v1.9.4
                                    system.adapter.info                    : info           - v1.7.15
                                    system.adapter.iot                     : iot            - v1.8.11
                                    system.adapter.javascript              : javascript     - v4.10.15
                                    system.adapter.lgtv                    : lgtv           - v1.1.10
                                    system.adapter.lgtv11                  : lgtv11         - v1.0.5
                                    system.adapter.life360                 : life360        - v0.2.12
                                    system.adapter.linux-control           : linux-control  - v1.1.2
                                    system.adapter.meteoalarm              : meteoalarm     - v1.1.1
                                    system.adapter.mihome                  : mihome         - v1.3.7
                                    system.adapter.mihome-vacuum           : mihome-vacuum  - v2.2.4
                                    system.adapter.minuvis                 : minuvis        - v1.3.1
                                    system.adapter.mqtt                    : mqtt           - v2.3.4
                                    system.adapter.nuki                    : nuki           - v1.4.3
                                    system.adapter.octoprint               : octoprint      - v1.0.7
                                    system.adapter.odl                     : odl            - v1.1.4
                                    system.adapter.openligadb              : openligadb     - v1.2.0
                                    system.adapter.pi-hole                 : pi-hole        - v1.3.1
                                    system.adapter.proxmox                 : proxmox        - v1.2.0
                                    system.adapter.roadtraffic             : roadtraffic    - v0.2.0
                                    system.adapter.ryd                     : ryd            - v0.3.3
                                    system.adapter.samsung                 : samsung        - v0.2.9
                                    system.adapter.simple-api              : simple-api     - v2.5.3
                                    system.adapter.smartmeter              : smartmeter     - v3.2.0
                                    system.adapter.socketio                : socketio       - v3.1.4
                                    system.adapter.sonoff                  : sonoff         - v2.3.3
                                    system.adapter.synology                : synology       - v0.1.18
                                    system.adapter.tankerkoenig            : tankerkoenig   - v2.0.10
                                    system.adapter.telegram                : telegram       - v1.7.0
                                    system.adapter.tr-064                  : tr-064         - v4.2.4
                                    system.adapter.tuya                    : tuya           - v3.5.4
                                    system.adapter.viessmannapi            : viessmannapi   - v1.3.2
                                    system.adapter.vis                     : vis            - v1.3.7
                                    system.adapter.weatherunderground      : weatherunderground - v3.3.0
                                    system.adapter.web                     : web            - v3.3.0
                                    system.adapter.web-speedy              : web-speedy     - v0.2.0
                                    system.adapter.whatsapp-cmb            : whatsapp-cmb   - v0.1.6
                                    system.adapter.wifilight               : wifilight      - v1.1.0
                                    system.adapter.windows-control         : windows-control - v0.1.5
                                    system.adapter.wled                    : wled           - v0.5.6
                                    system.adapter.yeelight-2              : yeelight-2     - v1.0.3
                                      3.2.13 (2021-02-01)
                                      O Offline
                                      O Offline
                                      oFbEQnpoLKKl6mbY5e13
                                      #362
                                      @apollon77 sagte in js-controller 3.2 jetzt im Latest!:
                                      • see CHANGELOG.md
                                      Interessant...
                                      • foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #363
                                        @ofbeqnpolkkl6mby5e13
                                        Schaust du hier ;-)
                                          3.2.13 (2021-02-01)
                                          ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          #364
                                          @apollon77 Laaaangweilig -- Alles läuft. Keine einzige Fehlermeldung. 👍
