  4. Admin.1 Warning
Admin.1 Warning
admin adapter warning
19 Beiträge 6 Kommentatoren 666 Aufrufe 4 Beobachtet
  • lemonbiterL Offline
    lemonbiterL Offline
    lemonbiter
    Hallo zusammen
    habe gerade im Log folgenden Fehler gefunden. Hat jemand einen Rat was mir der Fehler sagen soll?
    admin.1	2021-01-26 00:41:13.878	warn	(7228) This object will not be created in future versions. Please report this to the developer.
    admin.1	2021-01-26 00:41:13.878	warn	(7228) Object info.0.sysinfo.disks.blockDevices.dev0.group is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    admin.1	2021-01-26 00:41:12.854	warn	(7228) This object will not be created in future versions. Please report this to the developer.
    admin.1	2021-01-26 00:41:12.854	warn	(7228) Object info.0.sysinfo.disks.blockDevices.dev1.group is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    admin.1	2021-01-26 00:41:12.413	warn	(7228) This object will not be created in future versions. Please report this to the developer.
    admin.1	2021-01-26 00:41:12.412	warn	(7228) Object info.0.sysinfo.disks.blockDevices.dev2.group is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    admin.1	2021-01-26 00:41:12.047	warn	(7228) This object will not be created in future versions. Please report this to the developer.
    admin.1	2021-01-26 00:41:12.046	warn	(7228) Object info.0.sysinfo.disks.blockDevices.dev3.group is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
    admin.1	2021-01-26 00:41:11.554	warn	(7228) This object will not be created in future versions. Please report this to the developer.
    admin.1	2021-01-26 00:41:11.543	warn	(7228) Object info.0.sysinfo.disks.blockDevices.dev4.group is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object
    sigi234S UncleSamU 2 Antworten Letzte Antwort
    • lemonbiterL lemonbiter
      Hallo zusammen
      sigi234S Online
      sigi234S Online
      @lemonbiter
      https://forum.iobroker.net/topic/41029/js-controller-3-2-jetzt-im-latest
      Könnte es sein, welche Version vom JS Controller hast du?
      lemonbiterL 1 Antwort Letzte Antwort
        Hallo zusammen
        UncleSamU Offline
        UncleSamU Offline
        UncleSam
        @lemonbiter Weshalb hast du zwei Admin Instanzen? Was sagt iobroker list instances?
        Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
        ♡-lichen Dank an meine Sponsoren
        • sigi234S sigi234
          @lemonbiter
          lemonbiterL Offline
          lemonbiterL Offline
          lemonbiter
          @sigi234
          Hallo Sigi
          danke für Dein Feedback. Ich habe jetzt aktuell auf beiden Systemen (Master und Slave) die Version 3.2.11 laufen. Mal sehen ob der Fehler noch mal auftritt.
          LG
          Lem
          haselchenH HomoranH 2 Antworten Letzte Antwort
          • UncleSamU UncleSam
            lemonbiterL Offline
            lemonbiterL Offline
            lemonbiter
            @unclesam
            Hi lieber Unclesam
            ich habe nur einen laufen denke ich... Weiss leider nicht genau, warum der eine x.1 anstelle x.0 hat... Hier mal die von Dir angefragten Infos:
            Muss ich was ändern?
            LG
            Lem
            + system.adapter.admin.1                  : admin                 : Debian                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : Debian                                   -  enabled
            + system.adapter.backitup.0               : backitup              : Debian                                   -  enabled
            + system.adapter.bmw.0                    : bmw                   : Debian                                   -  enabled
            + system.adapter.cloud.0                  : cloud                 : Debian                                   -  enabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: Debian                                   -  enabled
              system.adapter.daswetter.0              : daswetter             : Debian                                   -  enabled
              system.adapter.devices.0                : devices               : Debian                                   - disabled
            + system.adapter.discovery.0              : discovery             : Debian                                   -  enabled
            + system.adapter.doorbird.0               : doorbird              : Debian                                   -  enabled
            + system.adapter.enigma2.0                : enigma2               : Debian                                   -  enabled
              system.adapter.feiertage.0              : feiertage             : Debian                                   -  enabled
              system.adapter.flot.0                   : flot                  : Debian                                   - disabled
            + system.adapter.fritzdect.0              : fritzdect             : Debian                                   -  enabled
            + system.adapter.harmony.0                : harmony               : Debian                                   -  enabled
            + system.adapter.history.0                : history               : Debian                                   -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : Debian                                   -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : Debian                                   -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : Debian                                   -  enabled, port: 12010
            + system.adapter.hm-rpc.2                 : hm-rpc                : Debian                                   -  enabled, port: 0
            + system.adapter.hue.1                    : hue                   : Debian                                   -  enabled, port: 443
              system.adapter.ical.0                   : ical                  : Debian                                   -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Debian                                   - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : Debian                                   - disabled
            + system.adapter.influxdb.0               : influxdb              : Debian                                   -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : Debian                                   -  enabled
            + system.adapter.iot.0                    : iot                   : Debian                                   -  enabled
            + system.adapter.javascript.0             : javascript            : Debian                                   -  enabled
              system.adapter.luftdaten.1              : luftdaten             : Debian                                   - disabled
              system.adapter.material.0               : material              : Debian                                   - disabled
              system.adapter.mobile.0                 : mobile                : Debian                                   - disabled
            + system.adapter.plenticore.0             : plenticore            : Debian                                   -  enabled
            + system.adapter.sayit.0                  : sayit                 : Debian                                   -  enabled, port: 0
            + system.adapter.sayit.1                  : sayit                 : Debian                                   -  enabled, port: 0
            + system.adapter.sayit.2                  : sayit                 : Debian                                   -  enabled, port: 0
            + system.adapter.scenes.0                 : scenes                : Debian                                   -  enabled
            + system.adapter.shelly.0                 : shelly                : Debian                                   -  enabled, port: 1884, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : Debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : Debian                                   -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.sonos.0                  : sonos                 : Debian                                   -  enabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : Debian                                   -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : Debian                                   -  enabled
            + system.adapter.telegram.0               : telegram              : Debian                                   -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : Debian                                   -  enabled
            + system.adapter.tinker.0                 : tinker                : Debian                                   -  enabled
            + system.adapter.tr-064.0                 : tr-064                : Debian                                   -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : Debian                                   -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Debian                                   - disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : Debian                                   - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : Debian                                   - disabled
              system.adapter.vis-players.0            : vis-players           : Debian                                   - disabled
              system.adapter.vis-weather.0            : vis-weather           : Debian                                   - disabled
              system.adapter.vis.0                    : vis                   : Debian                                   -  enabled
            + system.adapter.web.0                    : web                   : Debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.yahka.0                  : yahka                 : Debian                                   -  enabled
            + system.adapter.yeelight-2.0             : yeelight-2            : Debian                                   -  enabled
            + system.adapter.zigbee.0                 : zigbee                : ioBroker2-raspberrypi                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100G8L-if00
              @sigi234
              Hallo Sigi
              LG
              Lem
              haselchenH Offline
              haselchenH Offline
              haselchen
              @lemonbiter
              Die Antwort auf @UncleSam Frage, wäre dennoch interessant .
              Edit; warst schneller 😉
              • haselchenH haselchen
                @lemonbiter
                lemonbiterL Offline
                lemonbiterL Offline
                lemonbiter
                schrieb am zuletzt editiert von lemonbiter
                Ich fände es auch so toll, wenn ich wenigsten verstehen könnte, was die Fehlermeldung mir sagen will... Kann mir jemand verraten, was ich da lese?? Also in der Fehlermeldung, die ich oben geposted habe...
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @lemonbiter
                  Das sind Warnmeldungen keine "Fehler".
                  Das komplette Log wäre hilfreich für eine Analyse.
                  F 1 Antwort Letzte Antwort
                    @lemonbiter
                    fastfoot
                    schrieb am zuletzt editiert von fastfoot
                    @haselchen sagte in Admin.1 Warning:
                    @lemonbiter
                    steht doch alles da!
                    Seltsamerweise habe ich diese Werte auch, aber keine Warnung
                    lemonbiterL haselchenH 2 Antworten Letzte Antwort
                    • F fastfoot
                      @lemonbiter
                      lemonbiterL Offline
                      lemonbiterL Offline
                      lemonbiter
                      @fastfoot
                      @fastfoot
                      Lieber fastfood, ich musste kurz durchatmen. Deine Antwort ist sicher nett gemeint, aber sie hilft mir leider nicht weiter. Was da steht - und von Dir freundlicherweise noch markiert- das habe ich auch gelesen. Ich bin sehr gut im Englischen. Aber das hilft mir nicht....
                      Schlicht gefragt: Was ist denn das: info.0.sysinfo.disks.blockDevices.dev3.group
                      Ist das ein Objekt, wenn ja welches??
                      Lem
                      • UncleSamU Offline
                        UncleSamU Offline
                        UncleSam
                        Welche Version des Admin und des Info Adapters hast du? Oder: iobroker list adapters
                        • F fastfoot
                          @lemonbiter
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @fastfoot
                          Sorry. Aufm S6 mit Samsung Browser war das nicht komplett lesbar 😣
                          Erst nach nem Refresh ☹
                            @fastfoot
                            @fastfoot
                            Lem
                            fastfoot
                            @lemonbiter sagte in Admin.1 Warning:
                            @fastfoot
                            @fastfoot
                            Lem
                            Die Antwort war an @haselchen gerichtet, der gerne mehr LOG gehabt hätte. Die Fehlermeldung besagt dass ein Objekt den falschen Typ hat, wozu es da ist ist dabei eigentlich uninteressant, oder anders ausgedrückt: ich weiss es auch nicht. Es handelt sich dabei offensichtlich um Informationen über dein System, speziell Festplatten.
                              lemonbiterL Offline
                              lemonbiterL Offline
                              lemonbiter
                              @unclesam
                              Zu dem Zeitpunkt nutzte ich noch Admin 4.1.11
                              UncleSamU 1 Antwort Letzte Antwort
                              • F fastfoot
                                @fastfoot
                                @fastfoot
                                Lem
                                lemonbiterL Offline
                                lemonbiterL Offline
                                lemonbiter
                                @fastfoot sagte in Admin.1 Warning:
                                @fastfoot
                                mmmmh... das kommt mir komisch vor. Mein ioBroker Master läuft auf einem Debian (in einer Virtualisierung) auf einem QNAP mit ca. 40TB freiem Platz usw...
                                Ich fände es toll, wenn so typen wir ich - mit gefährlichem Halbwissen - die fehler verstehen könnten ✌
                                  @fastfoot
                                  @lemonbiter Hallo Lem!
                                  Muss ich jetzt mit dir schimpfen?
                                  Der Satz geht anders weiter!
                                  ...trotzdem auf dem Beta-Kanal unterwegs sind!!!
                                    lemonbiterL Offline
                                    lemonbiterL Offline
                                    lemonbiter
                                    LOL, mein lieber schön von Dir zu lesen...
                                    Zum Zeitpunkt des Problems war ich ja noch nicht auf BETA "Abwegen" :-)
                                      @unclesam
                                      UncleSamU Offline
                                      UncleSamU Offline
                                      UncleSam
                                      @lemonbiter Und Info? Ich würde mal diese beiden updaten - auf die Stable Versionen!
                                        @sigi234
                                        Hallo Sigi
                                        LG
                                        Lem
                                        dann bezieht sich hier dein jetzt darauf, dass du dann erst auf latest gewechselt hattest?
                                        Dann sei dir alles verziehen ;-)
                                        Übrigens: Auch ich weiß nicht was die Fehlermeldung bedeutet.
                                        Wenn sie vom Controller 3.2.x gekommen wäre, hätte ich gedacht, das es noch weitere Infos für das Beta-Testing gewesen seine, aber so?????
                                        Das hast du ja hiermit getan, und da es um info.0 geht wäre da @ldittmar für zuständig.
                                        Der wird dir (und uns) wohl auch sagen können was das bedeutet
                                        EDIT:
                                        ich würde die Meldung so interpretieren, dass du den Datenpunkt:
                                        nicht für irgendetwas weiterhin (z.B. in Scripten) benutzen sollst, weil dieser bei enem kommenden Updaten verschwinden könnte
                                        EDIT2:
                                        und hier der Zusammenhang des states:
