  4. Triggern DP ohne Wert nicht möglich (true/leer)-stiebel-isg
vis
119 Beiträge 16 Kommentatoren 15.2k Aufrufe 7 Beobachtet
  • F fastfoot
    @th-g Ich denke ich habs, die aktuelle Stable unterstützt noch kein async. Probiere so
     <variables>
       <variable id="X%@`%Fwh:N!{3?wFePrX">id</variable>
       <variable type="interval" id="Intervall">Intervall</variable>
       <variable id="a_[i#?T$qE6pO]a+|;|t">statusHeizung</variable>
     </variables>
     <block type="procedures_defcustomreturn" id="en56nesdIDI1w2p3?g4o" x="-613" y="37">
       <mutation statements="false">
         <arg name="id" varid="X%@`%Fwh:N!{3?wFePrX"></arg>
       </mutation>
       <field name="NAME">status</field>
       <field name="SCRIPT">DQppZighZXhpc3RzU3RhdGUoaWQpKSB7DQogICAgc3RhdCA9ICBmYWxzZTsNCn0gZWxzZSB7DQogICAgc3RhdCA9IGdldFN0YXRlKGlkKS52YWw7DQp9DQpyZXR1cm4gc3RhdDs=</field>
     </block>
     <block type="variables_set" id="*8.nqG@Jv]T}v.KRZ{@0" x="-613" y="62">
       <field name="VAR" id="X%@`%Fwh:N!{3?wFePrX">id</field>
       <value name="VALUE">
         <block type="text" id="PLa$]*nn#aVr.5!bBn@?">
           <field name="TEXT">0_userdata.0.Heizung.Heizen</field>
         </block>
       </value>
       <next>
         <block type="timeouts_clearinterval" id="-X.,*u/]42py`#]|-t:z">
           <field name="NAME">Intervall</field>
           <next>
             <block type="timeouts_setinterval" id="?aEn+kt6PmFGE[p~XA1e">
               <field name="INTERVAL">1000</field>
               <field name="UNIT">ms</field>
               <statement name="STATEMENT">
                 <block type="variables_set" id="w_dtgT{;Ok-WHNn^87$t">
                   <field name="VAR" id="a_[i#?T$qE6pO]a+|;|t">statusHeizung</field>
                     <block type="procedures_callcustomreturn" id="v_lqnLU}7B#A0%/chCT0" inline="true">
                       <mutation name="status">
                         <arg name="id"></arg>
                       </mutation>
                       <value name="ARG0">
                         <block type="variables_get" id="1B.vjc2JNw^M)p|t]5sv">
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="controls_if" id="~(bE[%vsILoN/Ek:_`m6">
                       <value name="IF0">
                         <block type="variables_get" id="0uW@6:JiLwo,RCzY#esL">
                         </block>
                       </value>
                       <statement name="DO0">
                         <block type="update" id="cZxPS)X@V0wnwD|mwVX1">
                           <field name="OID">0_userdata.0.Heizung.Status_WP</field>
                             <block type="text" id="52oB)g/-a?+Z~O=so-9H">
                               <field name="TEXT">Heizung läuft</field>
                             </block>
                           </value>
                         </block>
                       </statement>
                       <statement name="ELSE">
                         <block type="update" id="~$Cc9,M^,0_60=+abb,`">
                             <block type="text" id="H=b1z!W@8M}UyedaAVPb">
                               <field name="TEXT">Heizung nicht aktiv</field>
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    #97
    @fastfoot
    Funktioniert!!!!
    DANKE
    F 1 Antwort Letzte Antwort
      @fastfoot
      Funktioniert!!!!
      DANKE
      F Online
      F Online
      fastfoot
      #98
      @th-g sagte in Triggern DP ohne Wert nicht möglich (true/leer)-stiebel-isg:
      @fastfoot
      Funktioniert!!!!
      DANKE
      war ne schwere Geburt, schön dass es jetzt funktioniert!
      • F fastfoot
        @fastfoot
        Funktioniert!!!!
        DANKE
        #99
        @fastfoot
        Kann ich das Blockly auch für Warmwasser und Kühlen nutzen? Muss ich dann dafür etwas ändern außer den DP?
          @fastfoot
          F Online
          F Online
          fastfoot
          #100
          @fastfoot
          nein, ändern sollte nicht nötig sein, ausser der zu überwachende DP. bei Problemen aber einfach melden
          • F fastfoot
            @fastfoot
            #101
            @fastfoot
            Mus sich den Name ID und statusHeizung nicht anders nennen? Stören die sich sonst nicht?
              @fastfoot
              F Online
              F Online
              fastfoot
              #102
              @fastfoot
              In einem neuen Script kann die Variable weiterhin id heissen, der Inhalt ändert sich natürlich, da du ja einen anderen DP abfrägst
              • F fastfoot
                @fastfoot
                #103
                @fastfoot
                Ok aber was ist wenn sich dann beide Skripte überschneiden? Das kann für einige Sekunden durchaus sein.
                  @fastfoot
                  F Online
                  F Online
                  fastfoot
                  #104
                  @fastfoot
                  Was meinst du mit überschneiden? Es handelt sich doch um verschiedene Datenpunkte
                  • F fastfoot
                    @fastfoot
                    #105
                    @fastfoot
                    Ich meine deine virtuellen Werte ID und statusHeizung oder verstehe ich da etwas nicht? Wenn ich mehrere Skripte nutze, die ID und statusHeizung nutzen, dann überschreibt doch jedes Skript die Werte.
                      @fastfoot
                      F Online
                      F Online
                      fastfoot
                      #106
                      @fastfoot
                      id heisst die Variable. In dieser ist der Pfad zu deinem Datenpiunkt gespeichert, dessen Wertänderung du prüfen möchtest. In einem anderen Skript kann die Variable genauso heissen, aber ihr Inhalt ist natürlich ein anderer. Gleiches gilt natürlich für Status_WP, den du dann anschliessend ansteuerst, der wird wohl auch ein anderer sein als für die Heizung. Du denkst zu kompliziert, probiere doch einfach mehr :-)
                      • F fastfoot
                        @fastfoot
                        #107
                        @fastfoot
                        Habe nun die Skripte auch für Kühlen und Warmwasser umgestellt aber nun läuft es nicht mehr und der Status wird nicht mehr geändert.
                        Bildschirmfoto 2021-01-22 um 08.39.31.png Bildschirmfoto 2021-01-22 um 08.39.56.png
                        Ich habe für jedes Skript die Variable in StatusHeizen, StatusKühlen und StatusWW geändert.
                          @fastfoot
                          tobi19
                          #108
                          In jedem Skript (d.h. = Datei) sind die Variablen in einem eigenen Raum geschützt und gelten nur in diesem Skript. Daher kann es in mehreren Skripten Variablen mit bleichem Nahmen aber unterschiedlichem Wert geben.
                          Datenpunkte gelten global. Wenn also der Datenpunkt "Status_WP" (der ja nicht mit seinem kompletten Namen "0_userdate-0-..Status_WP" dargestellt ist) immer der gleiche ist, wird er jede Sekunde 3 mal, nämlich in jedem Skript beschrieben und erhält einen neuen Wert. Je nach Zeitpunkt der Betrachtung sieht man dann unterschiedliche werte, mit 66% Wahrscheinlichkeit den Wert "nicht aktiv".
                          Das lässt sich lösen, in dem alles in einem Skript bearbeitet wird.
                          Das Weglassen der Variablen ID und StatusXXX ist nur eine Verkürzung zur Übersichtlichkeit.
                          Ich verwende Zwischenvariable nur, wenn ihre Werte mehrfach verwendet werden und sonst jedes mal neu berechnet oder gelesen werden müssten.
                          • T tobi19
                            #109
                            @tobi19
                            Danke und ist absolut einleuchten aber irgendwie bin ich zu doof für Blockly und Co. :-)
                              @tobi19
                              tobi19
                              #110
                              @tobi19
                              Die Abfrage kannst du so erstellen: Auf das Zahnrad Klicken und den Block "sonst falls" von der linken Hälfte nach rechts ziehen. Was fehlt noch?
                              ? 2 Antworten Letzte Antwort
                              • T tobi19
                                @tobi19
                                #111
                                @tobi19
                                Sorry das meinte ich nicht. Wie ich es machen muss, wenn man es mir erklärt, verstehe ich aber ohne Hilfe Blockly zu verstehen macht mir Schwierigkeiten.
                                • T tobi19
                                  @tobi19
                                  #112
                                  @tobi19
                                  Läuft :-)
                                    skorpion_inka
                                    #113
                                    Ich bin am verzweifeln,
                                    ich habe das Thema "Triggern DP ohne Wert nicht möglich (true/leer)-stiebel-isg" mehrmals durchgelesen und - bekommen es aber nicht zum laufen.
                                    Ziel ist es mehrer Datenpunkte auf einmal abzufragen und je nach Zustand verarbeiten.
                                    Mit einem Datenpunkt funktioniert es, aber bei mehreren stehen ich voll auf dem "Schlauch".
                                    Ich hoffe mir kann jemand helfen. Vielen Dank schon mal!!!
                                      skorpion_inka
                                      #114
                                      Halleluja ich hab hin bekommen, alledings kommen noch Warnungren im LOG.
                                      Ist da noch etwas faul?
                                      T 2 Antworten Letzte Antwort
                                      • S skorpion_inka
                                        tobi19
                                        schrieb am zuletzt editiert von tobi19
                                        #115
                                        @skorpion_inka sagte in Triggern DP ohne Wert nicht möglich (true/leer)-stiebel-isg:
                                        Was hat eine Fehlermeldung des Homatic Adapters mit dem Skript zu tun?
                                        • S skorpion_inka
                                          tobi19
                                          #116
