  4. js-controller 3.2 jetzt im Latest!
    1.0k
575 Beiträge 70 Kommentatoren 189.4k Aufrufe 57 Beobachtet
  • Master67M Master67
    @apollon77 so hier mal die Fehlermeldung die ich erhalte :-)
    Update js-controller from @3.1.6 to @3.2.7
    NPM version: 6.14.10
    npm install iobroker.js-controller@3.2.7 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../authenticate_pam.cc:23:
    ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
    ../../nan/nan.h:2294:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
     2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../authenticate_pam.cc: In function 'void after_doing_auth(uv_work_t*, int)':
    ../authenticate_pam.cc:107:87: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      107 |   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
    ../../nan/nan.h:1026:46: note: declared here
     1026 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../authenticate_pam.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)':
    ../authenticate_pam.cc:147:83: warning: 'v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      147 |   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
    In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8-internal.h:14,
                     from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:27,
                     from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
                     from ../../nan/nan.h:56,
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:3553:51: note: declared here
     3553 |   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro 'V8_DEPRECATED'
      328 |   declarator __attribute__((deprecated(message)))
    ../authenticate_pam.cc:150:30: error: cannot convert 'char [128]' to 'v8::Isolate*'
      150 |    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
          |                              char [128]
    In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:26: note:   initializing argument 1 of 'int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const'
     2878 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    ../authenticate_pam.cc:152:69: warning: 'v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      152 |   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
    ../authenticate_pam.cc:155:29: error: cannot convert 'char [128]' to 'v8::Isolate*'
      155 |    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
          |                             char [128]
    ../authenticate_pam.cc:160:25: error: cannot convert 'char [128]' to 'v8::Isolate*'
      160 |  username->WriteUtf8(m->username, sizeof(m->username) - 1);
          |                         char [128]
    ../authenticate_pam.cc:161:25: error: cannot convert 'char [128]' to 'v8::Isolate*'
      161 |  password->WriteUtf8(m->password, sizeof(m->password) - 1);
          |                         char [128]
    ../authenticate_pam.cc: At global scope:
    ../authenticate_pam.cc:170:11: error: variable or field 'init' declared void
      170 | void init(Handle<Object> exports) {
    ../authenticate_pam.cc:170:11: error: 'Handle' was not declared in this scope
    ../authenticate_pam.cc:170:24: error: expected primary-expression before '>' token
    ../authenticate_pam.cc:170:26: error: 'exports' was not declared in this scope
    In file included from ../../nan/nan.h:56,
    ../authenticate_pam.cc:175:31: error: 'init' was not declared in this scope; did you mean 'int'?
      175 | NODE_MODULE(authenticate_pam, init);
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:36: note: in definition of macro 'NODE_MODULE_X'
      737 |       (node::addon_register_func) (regfunc),                          \
    ../authenticate_pam.cc:175:1: note: in expansion of macro 'NODE_MODULE'
    make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.78-2-pve
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v12.20.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Starting node restart.js
    @master67 Das ist alles ok ... bzw wenn du gluck hast sind die nach einem "iobroker fix" weg.
    Das sind faktisch nur warnungen von einem optionalen Paket
    Master67M 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Master67M Offline
      Master67M Offline
      Master67
      @apollon77 ... freut mich ja... aber ich kommen den noch nicht mehr auf den ioBroker drauf ;-)
      Gruß Master67
      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
        @master67
        Ist libpam0g-dev auf deinem System installiert?
        [Edit:] Das ist wieder so'n Container-Gesumsel, oder?
          @master67
          Master67M Offline
          Master67M Offline
          Master67
          schrieb am zuletzt editiert von Master67
          @thomas-braun .... keine Ahnung!
          Da läuft nur der ioBroker unter Ubuntu 20.04.1
          Edit: japp Proxmox :-)
          Gruß Master67
            @master67
            apt policy libpam0g-dev
              @master67
              Master67M Offline
              Master67M Offline
              Master67
              @thomas-braun sagte in js-controller 3.2 jetzt im Latest!:
              Ja läuft....
              libpam0g-dev:
                Installed: 1.3.1-5ubuntu4.1
                Candidate: 1.3.1-5ubuntu4.1
                Version table:
               *** 1.3.1-5ubuntu4.1 500
                      500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
                   1.3.1-5ubuntu4 500
                      500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
              Gruß Master67
              • H Offline
                homecineplexx
                also mit dem js-controller 3.2.7 hab ich leuter Fehlermeldungen:
                2021-01-18 19:37:16.508  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]: TypeError: Cannot read property 'stateValue' of undefined
                2021-01-18 19:37:16.508  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at VirtualDevice.<anonymous> (script.js.VirtuelleDevices.ESP.watermeter:297:72)
                2021-01-18 19:37:16.509  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at runCallback (timers.js:706:11)
                2021-01-18 19:37:16.509  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at tryOnImmediate (timers.js:676:5)
                2021-01-18 19:37:16.509  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at processImmediate (timers.js:658:5)
                2021-01-18 19:37:16.509  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at process.topLevelDomainCallback (domain.js:126:23)
                2021-01-18 19:37:16.509  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]: TypeError: Cannot read property 'stateValue' of undefined
                2021-01-18 19:37:16.509  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at VirtualDevice.<anonymous> (script.js.VirtuelleDevices.ESP.watermeter:297:72)
                2021-01-18 19:37:16.510  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at processImmediate (timers.js:658:5)
                2021-01-18 19:37:16.510  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at process.topLevelDomainCallback (domain.js:126:23)
                2021-01-18 19:37:16.510  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]: TypeError: Cannot read property 'stateValue' of undefined
                2021-01-18 19:37:16.510  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at VirtualDevice.<anonymous> (script.js.VirtuelleDevices.ESP.watermeter:297:72)
                2021-01-18 19:37:16.510  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at runCallback (timers.js:706:11)
                2021-01-18 19:37:16.510  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at tryOnImmediate (timers.js:676:5)
                2021-01-18 19:37:16.511  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]: TypeError: Cannot read property 'stateValue' of undefined
                2021-01-18 19:37:16.511  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at VirtualDevice.<anonymous> (script.js.VirtuelleDevices.ESP.watermeter:297:72)
                2021-01-18 19:37:16.511  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at runCallback (timers.js:706:11)
                2021-01-18 19:37:16.511  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at tryOnImmediate (timers.js:676:5)
                2021-01-18 19:37:16.511  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at processImmediate (timers.js:658:5)
                2021-01-18 19:37:16.511  - ESC[31merrorESC[39m: host.IoBrokerSmartHome Caught by controller[0]:     at process.topLevelDomainCallback (domain.js:126:23)
                hab auch schon geschaut, aber wonach bitte zählt der denn die Line 297? nicht so, wie sie im JavaScript ist denke ich.
                • omega235O Offline
                  omega235O Offline
                  omega235
                  schrieb am zuletzt editiert von omega235
                  Die Installation von Branches über Github funktioniert nicht mehr korrekt.
                  js-controller: 3.2.7
                  os: Linux / Docker / buanet 5.1
                  architektur: x64
                  nodejs: v12.20.0
                  NPM: 6.14.8
                  über den bisher funktionierenden Link (https://github.com/Omega236/ioBroker.virtualpowermeter/tarball/1.3.0) kommt es zu einer Fehlermeldung (wird aber installiert, man muss aber manuell upload und neu starten):
                  $ ./iobroker url "https://github.com/Omega236/ioBroker.virtualpowermeter/tarball/1.3.0" --debug
                  install https://github.com/Omega236/ioBroker.virtualpowermeter/tarball/1.3.0
                  NPM version: 6.14.8
                  npm install https://github.com/Omega236/ioBroker.virtualpowermeter/tarball/1.3.0 --loglevel error --prefix "/opt/iobroker" (System call)
                  + iobroker.virtualpowermeter@1.3.0
                  updated 1 package in 43.181s
                  23 packages are looking for funding  run `npm fund` for details
                  ERROR: host.IoBrokerTestSystem1 Cannot install https://github.com/Omega236/ioBroker.virtualpowermeter/tarball/1.3.0: 0
                  Wenn man den Link von github nimmt (https://github.com/Omega236/ioBroker.virtualpowermeter/tree/1.3.0) dann installiert er die Version aus dem Master branch.
                  edit:
                  im stable (3.1.6) sieht der log gut aus:
                  NPM version: 6.14.8
                  + iobroker.virtualpowermeter@1.3.0updated 1 package in 16.663s
                  25 packages are looking for funding  run `npm fund` for details
                  upload [8] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/words.js words.js application/javascript
                  upload [7] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/virtualpowermeter.png virtualpowermeter.png image/png
                  upload [6] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/tsconfig.json tsconfig.json application/json
                  upload [5] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/style.css style.css text/css
                  upload [4] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/index_m.html index_m.html text/html
                  upload [3] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/custom_m.html custom_m.html text/html
                  upload [2] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [1] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/InstanceSettings.PNG InstanceSettings.PNG image/png
                  upload [0] virtualpowermeter.admin /opt/iobroker/node_modules/iobroker.virtualpowermeter/admin/DatapointSample.PNG DatapointSample.PNG image/png
                  process exited with code 0
                    @prinzeisenherz1 Bitte mal die dwd Github version versuchen. Besser? Habe da im Adapter etwas nachgearbeitet
                    FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    #66
                    @apollon77 sagte in js-controller 3.2 jetzt im Latest!:
                    @apollon77 Bisher verhält sich mein DWD Adapter von Github unauffällig. :-)
                      #67
                      @master67 Dann muss es aber Fehler im Log geben wenn du startest ... schau mal ins Logfile
                      • H homecineplexx
                        #68
                        @homecineplexx Falls du globale Scripts hast werden die ja davorgehängt. du versuchst auf irgendetwas zuzugreifen was falsch ist. von solchen Javascripts hab ich auch einiges im Sentry wo versucht wird ein state zuzugreifen mit nem "." am ende - das ist jetzt verboten. Muss im javascript adapter wohl noch abgefangen werden
                        H 2 Antworten Letzte Antwort
                        • omega235O omega235
                          architektur: x64
                          nodejs: v12.20.0
                          NPM: 6.14.8
                          NPM version: 6.14.8
                          edit:
                          NPM version: 6.14.8
                          #69
                          @omega235 Ok, checke
                            architektur: x64
                            nodejs: v12.20.0
                            NPM: 6.14.8
                            NPM version: 6.14.8
                            edit:
                            NPM version: 6.14.8
                            #70
                            @omega235 sagte in js-controller 3.2 jetzt im Latest!:
                            BTW: in js.controller 3.2 geht das viel einfacher :-))
                            "iobroker url Omega236/ioBroker.virtualpowermeter#1.3.0"
                            besser als das alte?
                            omega235O UncleSamU 2 Antworten Letzte Antwort
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              #71
                              @apollon77 Derzeit alles normal ohne Fehlermeldungen.
                              Lediglich ist mir aufgefallen das scheinbar die Prozessorlast im CT leicht angestiegen ist. Ok, ein Anstieg von 9 auf 11 % ist jetzt nichts was Alarm auslösen sollte. Aber nur als Info an dich.
                                omega235O Offline
                                omega235O Offline
                                omega235
                                #72
                                @apollon77
                                Super, https://github.com/Omega236/ioBroker.virtualpowermeter#1.3.0 funktioniert auch (und ohne Fehler).
                                Merk ich mir.
                                  homecineplexx
                                  #73
                                  @apollon77 also eigentlich ist das kein globales Script. Ich kann's dir gern Mal anhängen
                                  • H homecineplexx
                                    #74
                                    @homecineplexx Nein ich sage i´nicht das das skript ein globales ist aber wen du ein globales skript definiert hast dann wird das vor alle anderen Skripte davor gehängt!
                                    H 1 Antwort Letzte Antwort
                                      UncleSamU Offline
                                      UncleSamU Offline
                                      UncleSam
                                      #75
                                      Das sollte aber meiner Meinung nach ganz klar in die Release Notes, dass das alte nicht mehr geht. Ist zwar nicht schlimm, aber es ist ein kleiner "breaking change".
                                      Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                                      ♡-lichen Dank an meine Sponsoren
                                      • UncleSamU UncleSam
                                        #76
                                        @unclesam Das "alte" und mehr wird mit der kommenden 3.2.8 wieder gehen ... Das da zB "tree" geklappt hat war denke bisher eher zufall als Absicht :-)
                                          Master67M Offline
                                          Master67M Offline
                                          Master67
                                          #77
                                          Geht leider nicht, habe wieder ein Backup Eingespielt, warte noch ein bisschen ab mit dem Update bis jetzt habe ich keine Nachteile mit dem "alten" js-controller ;-)
                                          Gruß Master67
