  4. Test Adapter Diashow v0.0.x GitHub (ALPHA-Version)
    6.3k
83 Beiträge 6 Kommentatoren 13.0k Aufrufe 12 Beobachtet
  • A AggroRalf
    @liv-in-sky Grad nochmal eine Version gebaut. Kannst mal neue Version laden und das Logging auf Debug stellen?
    liv-in-skyL Offline
    liv-in-skyL Offline
    @aggroralf
    fehler:
    diashow.0	2021-01-17 23:01:31.193	error	(28678) Error occured: No pictures found in folder in Filesystem(updatePictureList)
    diashow.0	2021-01-17 23:01:31.191	debug	(28678) [Adapter] UpdatePictureStoreTimer occured
    diashow.0	2021-01-17 23:01:31.179	info	(28678) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.diashow, node: v12.20.0, js-controller: 3.1.6
    kann es sein, das dies beim installieren ein problem ist:
    $ ./iobroker url "https://github.com/gaudes/ioBroker.diashow"
    Info: Can not get current GitHub commit, we remember master branch only. Status: 422 (No commit found for SHA: master)install https://github.com/gaudes/ioBroker.diashow/tarball/masterNPM version: 6.14.8npm install https://github.com/gaudes/ioBroker.diashow/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR!
     code E404
    npm ERR!
     404 Not Found - GET https://codeload.github.com/gaudes/ioBroker.diashow/legacy.tar.gz/masternpm ERR! 404 npm ERR! 404  'https://github.com/gaudes/ioBroker.diashow/tarball/master' is not in the npm registry.npm ERR! 404
     Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital letters
    npm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-01-17T21_57_15_193Z-debug.log
    upload [4] diashow.admin /opt/iobroker/node_modules/iobroker.diashow/admin/words.js words.js application/javascript
    upload [3] diashow.admin /opt/iobroker/node_modules/iobroker.diashow/admin/style.css style.css text/css
    upload [2] diashow.admin /opt/iobroker/node_modules/iobroker.diashow/admin/index_m.html index_m.html text/html
    upload [1] diashow.admin /opt/iobroker/node_modules/iobroker.diashow/admin/diashow.png diashow.png image/png
    upload [0] diashow.admin /opt/iobroker/node_modules/iobroker.diashow/admin/admin.d.ts admin.d.ts video/mp2t
    Adapter "system.adapter.vis.0" restarted.
    process exited with code 0
    • liv-in-skyL liv-in-sky
      @aggroralf
      fehler:
      npm ERR!
       code E404
      npm ERR!
      AggroRalf
      schrieb am zuletzt editiert von AggroRalf
      @liv-in-sky Hast es wie oben beschrieben gemacht ? Also Katze --> Reiter "Beliebig" --> gaudes/ioBroker.diashow#main ?
      Leider (?) hat Github "Master" nach "Main" umbenannt, der aktuelle Controller kommt damit noch nicht ganz klar. Erst in der neuen Version ist es aktualisiert.
      Daher geht die "normale" Url "https://github.com/gaudes/ioBroker.diashow" nicht.
      • liv-in-skyL Offline
        liv-in-skyL Offline
        hat jmd anders schon mal getestet, ob die bilder von einem beliebigen ordner geholt werden können ? nicht das nur bei mir etwas fehlerhaft ist
        • A AggroRalf
          @homoran Bei der Demo habe ich Uhrzeit und die Infos unten zusätzlich selbst mittels anderen (Standard-)Widgets über das Diashow-Widget gelegt.
          Der Adapter bietet das nicht, aber deiner Kreativität sind keine Grenzen gesetzt :-)
          @aggroralf sagte in Test Adapter Diashow v0.0.x GitHub (ALPHA-Version):
          dann ist das kein Bildschirm schoner , dann brennt das bei oleds ein.
            AggroRalf
            @homoran Nochmal: Die Uhrzeit habe ich selbst mit einem weiteren Widget eingebaut.
            Das Widget vom Adapter zeigt wirklich nur Bilder an...
            • A AggroRalf
              @aggroralf Aaah,
              jetzt hab selbst ich es verstanden
              • A AggroRalf
                liv-in-skyL Offline
                liv-in-skyL Offline
                alles gelöscht - neu installiert - neuen ordner mit 777 angelegt
                selber fehler bei dateisystem
                mit "lokaler ordner" einstellung - kein fehler
                  AggroRalf
                  @liv-in-sky Hast das Log mal auf Debug gestellt ? Was steht dann im Log ?
                  • A AggroRalf
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @aggroralf
                    diashow.0	2021-01-18 09:17:46.019	error	(3168) Error occured: No pictures found in folder in Filesystem(updatePictureList)
                    diashow.0	2021-01-18 09:17:46.017	debug	(3168) [Adapter] UpdatePictureStoreTimer occured
                    diashow.0	2021-01-18 09:17:46.004	info	(3168) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.diashow, node: v12.20.0, js-controller: 3.1.6
                    diashow.0	2021-01-18 09:17:43.832	info	(3057) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    diashow.0	2021-01-18 09:17:43.832	info	(3057) terminating
                    diashow.0	2021-01-18 09:17:43.831	info	(3057) Got terminate signal TERMINATE_YOURSELF
                    discovery.0	2021-01-18 09:17:07.832	info	(3098) starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.20.0, js-controller: 3.1.6
                    diashow.0	2021-01-18 09:16:43.958	error	(3057) Error occured: No pictures found in folder in Filesystem(updatePictureList)
                    diashow.0	2021-01-18 09:16:43.956	debug	(3057) [Adapter] UpdatePictureStoreTimer occured
                    diashow.0	2021-01-18 09:16:43.944	info	(3057) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.diashow, node: v12.20.0, js-controller: 3.1.6
                      @aggroralf
                      AggroRalf
                      @liv-in-sky Es ist immer noch nicht die aktuellste Version, sonst müsste mehr im Log stehen.
                      Kannst nochmal ein Update probieren: Also Katze --> Reiter "Beliebig" --> gaudes/ioBroker.diashow#main ?
                      • A AggroRalf
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @aggroralf
                        muss kurz weg - müssen später weitermachen
                          @aggroralf
                          AggroRalf
                          @liv-in-sky Kannst bitte nochmal ein Update machen ? War mein Fehler, hab die Änderungen nicht hochgeladen 🙈
                          • A AggroRalf
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @aggroralf kein thema
                              AggroRalf
                              @liv-in-sky War ein Bug :-) Kannst nochmal Update machen ? Dann sollte es gehen.
                              • A AggroRalf
                                Aktuelle Test Version 0.0.4
                                Veröffentlichungsdatum 21.01.2021
                                Github Link https://github.com/gaudes/ioBroker.diashow
                                Adapter ioBroker.diashow 0.0.4
                                ich habe mir vor Weihnachten einen Amazon Echo Show 8 gegönnt. In Firefox stellt er mir mit VIS die Haussteuerung dar. Meine Idee war dann, diesen (und auch andere Anzeigegeräte wie Tablets) aber auch als "digitalen Bilderrahmen" zu verwenden. Ein Beispiel zeigt bekanntlich mehr als tausend Worte:
                                Diashow Demo
                                Der Adapter stellt eine somit eine Diashow mit Bilschirmschoner-Funktion für VIS zur Verfügung.
                                Folgende Quellen stehen aktuell zur Verfügung:
                                • Die letzten acht täglichen Bilder von Bing.com
                                • Via VIS-Dateimanager hochgeladene Bilder
                                • Bilder aus beliebigem Pfad im Dateisystem
                                • Bilder von Synology PhotoStation
                                Als Dateitypen gehen aktuell nur JPG, JPEG und PNG. Die Bilder werden beim Start des Adapters eingelesen, daher ist bei Änderungen ein Neustart des Adapters notwendig. Ausnahme ist Bing, diese werden täglich neu eingelesen.
                                Zur Darstellung in VIS stellt der Adapter ein Widget zur Verfügung. Dieses bietet auch Funktionen für Effekt beim Bildwechsel, beispielsweise sanftes Ein- und Ausblenden. Zusätzlich kann ein Timeout eingestellt werden. Sofern auf anderen View im Projekt keine Aktion für das eingestellte Timeout erfolgt ist, wird zur View mit der Diashow gewechselt. Durck Klicken des Bilds wird entweder zurück zur letzten Ansicht oder zu einer eingestellten Ansicht gewechselt.
                                Über das Diashow-Widget habe ich für die obige Demo dann noch ein View-Wechsel-Widget gelegt, welches mittels eines kleinen Blockly-Script automatisch durch von mir definierte "Unter-Views" wechselt, wo ich trotz Diashow die wichtigsten Infos dargestellt bekomme.
                                Installation
                                Die Installation muss aktuell über die "Katze" erfolgen, einfach gaudes/ioBroker.diashow#main auf der Seite "Beliebig" eintragen.
                                Was tun bei Fehlern oder Problemen?
                                Bei Fehlern sollte zuerst das Log in ioBroker geprüft werden. Ich habe versucht, möglichst treffende Fehlermeldungen auszugeben.
                                Bei Problemen mit dem VIS-Widget gerne auch mal in die Konsole der Entwicklertools eines Browsers schauen (meist F12-Taste), eventuell stehen dort auch Fehlermeldungen.
                                Rückmeldungen gerne hier im Forum oder in Discord (Channel #diashow https://discord.gg/SjaaQdeM ).
                                So, und nun viel Spass beim Testen.
                                lobomauL Offline
                                lobomauL Offline
                                lobomau
                                Cool. Einen Show 8 habe ich auch und werde gerne deinen Adapter testen und einsetzen.
                                Installieren hat schon mal geklappt:
                                Host: NUC8i3 mit Proxmox:
                                • Slave: Pi4
                                • lobomauL lobomau
                                  lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  schrieb am zuletzt editiert von lobomau
                                  Ich habe mein synology Konto angegeben. Unter picture wird der Pfad auch alle 10s erneuert.
                                  Oder... es sieht eher nach dem jpg als raw aus, richtig? Hier stark abgekürzt und verfremded... das Original geht über Seiten.
                                  data:image/jpeg;base64,/9j/4AAQSkZxxxBAAD/2wBDAAoHxxxEExNDk7Pj4+JS5ESUM8SDc9Pjv/2wBDAQoLCw4NDhwQEBw7KCIoOzs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs...SElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6TGf/9k=
                                  Hier der Versuch das Widget zu erstellen. Beim Rüberschieben erscheint kein Widget im fenster.
                                  • Slave: Pi4
                                  • lobomauL lobomau
                                    AggroRalf
                                    @lobomau Alles richtig, das gehört so :-) Ich binde das Bild bei manchen Quellen als Pfad ein, bei anderen als Base64-kodiertes Bild. Alles korrekt, das Widget (und auch das Standard-Image-Widget) können damit was anfangen :-)
                                    Kannst mal in der Entwicklungs-Konsole im Browser (F12-Taste) schauen ob da ein Fehler erscheint beim Rüberziehen ?
                                    liv-in-skyL lobomauL 2 Antworten Letzte Antwort
                                    • A AggroRalf
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @aggroralf
                                      scheint hartnäckig zu sein
                                      • A AggroRalf
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @aggroralf
                                        kannst auch gerne über anydesk bei mir kucken - wenn das hilft
                                        • A AggroRalf
                                          lobomauL Offline
                                          lobomauL Offline
                                          lobomau
                                          Wenn ich den Inhalt aus "picture" in Browser eintrage, wird schon mal das bild auf der Synology wiedergegeben und es ändert sich alle 10s wie in der einstellung.
                                          Edit.: mit string image source Widget geht es 👍
                                          @aggroralf hier sieht man mal die Problematik
                                          Desweiteren weiß ich nicht wie ich alternativ den Pfad mit dem Basic Image Widget anwende.
                                          • Slave: Pi4
                                          lobomauL A 2 Antworten Letzte Antwort
