  4. Nach Update "admin"-modul kein Browser-Zugriff
adminmodul admin update fehler
78 Beiträge 4 Kommentatoren 7.8k Aufrufe 3 Beobachtet
    @Homoran sagte in Nach Update "admin"-modul kein Browser-Zugriff:
    @Raspo NIcht gut. Immer noch da und jetzt beide auf dem selben port aktiv
    was sagt dmesg
    Hatten wir das schon?
    Raspo
    @Homoran
    jetzt:
    pi@ioBroker:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
    [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
    [    0.000000] On node 0 totalpages: 242688
    [    0.000000]   Normal zone: 2133 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
    [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
    [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
    [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=d474f063-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                       lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                       modules : 0x7f000000 - 0x80000000   (  16 MB)
                         .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                         .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                         .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                          .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 26394 entries in 78 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [    0.000019] Switching to timer-based delay loop, resolution 52ns
    [    0.000280] Console: colour dummy device 80x30
    [    0.000299] console [tty1] enabled
    [    0.000342] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [    0.000358] pid_max: default: 32768 minimum: 301
    [    0.000697] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000712] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001626] CPU: Testing write buffer coherency: ok
    [    0.002092] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.002738] Setting up static identity map for 0x100000 - 0x10003c
    [    0.002886] rcu: Hierarchical SRCU implementation.
    [    0.003677] smp: Bringing up secondary CPUs ...
    [    0.004516] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.005441] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.006302] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.006426] smp: Brought up 1 node, 4 CPUs
    [    0.006438] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.006443] CPU: All CPU(s) started in HYP mode.
    [    0.006448] CPU: Virtualization extensions available.
    [    0.007422] devtmpfs: initialized
    [    0.020552] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [    0.020793] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.020812] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.021399] pinctrl core: initialized pinctrl subsystem
    [    0.022261] NET: Registered protocol family 16
    [    0.025346] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.031160] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.031168] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.031371] Serial: AMBA PL011 UART driver
    [    0.033649] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.068868] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
    [    0.070550] SCSI subsystem initialized
    [    0.070779] usbcore: registered new interface driver usbfs
    [    0.070840] usbcore: registered new interface driver hub
    [    0.070935] usbcore: registered new device driver usb
    [    0.090139] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
    [    0.100401] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
    [    0.111819] clocksource: Switched to clocksource arch_sys_counter
    [    0.200953] VFS: Disk quotas dquot_6.6.0
    [    0.201034] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.201189] FS-Cache: Loaded
    [    0.201400] CacheFiles: Loaded
    [    0.211406] NET: Registered protocol family 2
    [    0.212212] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.212249] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.212358] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.212544] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.212676] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.212722] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.213032] NET: Registered protocol family 1
    [    0.213605] RPC: Registered named UNIX socket transport module.
    [    0.213611] RPC: Registered udp transport module.
    [    0.213617] RPC: Registered tcp transport module.
    [    0.213623] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.215425] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [    0.218434] Initialise system trusted keyrings
    [    0.218634] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.228590] FS-Cache: Netfs 'nfs' registered for caching
    [    0.229160] NFS: Registering the id_resolver key type
    [    0.229187] Key type id_resolver registered
    [    0.229194] Key type id_legacy registered
    [    0.229210] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.231492] Key type asymmetric registered
    [    0.231501] Asymmetric key parser 'x509' registered
    [    0.231549] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
    [    0.231707] io scheduler noop registered
    [    0.231714] io scheduler deadline registered (default)
    [    0.231972] io scheduler cfq registered
    [    0.231980] io scheduler mq-deadline registered (default)
    [    0.231987] io scheduler kyber registered
    [    0.234959] bcm2708_fb soc:fb: FB found 1 display(s)
    [    0.245803] Console: switching to colour frame buffer device 90x30
    [    0.251321] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 720x480
    [    0.253421] bcm2835-rng 3f104000.rng: hwrng registered
    [    0.253733] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    0.254236] vc-sm: Videocore shared memory driver
    [    0.254553] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [    0.265315] brd: module loaded
    [    0.275472] loop: module loaded
    [    0.276059] Loading iSCSI transport class v2.0-870.
    [    0.276736] libphy: Fixed MDIO Bus: probed
    [    0.276835] usbcore: registered new interface driver lan78xx
    [    0.276893] usbcore: registered new interface driver smsc95xx
    [    0.276909] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.304753] dwc_otg 3f980000.usb: base=(ptrval)
    [    0.504977] Core Release: 2.80a
    [    0.504986] Setting default values for core params
    [    0.505016] Finished setting default values for core params
    [    0.705322] Using Buffer DMA mode
    [    0.705329] Periodic Transfer Interrupt Enhancement - disabled
    [    0.705334] Multiprocessor Interrupt Enhancement - disabled
    [    0.705341] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    0.705359] Dedicated Tx FIFOs mode
    [    0.705821] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
    [    0.705846] FIQ FSM acceleration enabled for :
                   Non-periodic Split Transactions
                   Periodic Split Transactions
                   High-Speed Isochronous Endpoints
                   Interrupt/Control Split Transaction hack enabled
    [    0.705854] dwc_otg: Microframe scheduler enabled
    [    0.705909] WARN::hcd_init_fiq:457: FIQ on core 1
    [    0.705920] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
    [    0.705932] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    [    0.705949] dwc_otg 3f980000.usb: DWC OTG Controller
    [    0.705982] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [    0.706015] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
    [    0.706061] Init: Port Power? op_state=1
    [    0.706067] Init: Power Port (0)
    [    0.706318] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    0.706330] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    0.706339] usb usb1: Product: DWC OTG Controller
    [    0.706348] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
    [    0.706357] usb usb1: SerialNumber: 3f980000.usb
    [    0.706966] hub 1-0:1.0: USB hub found
    [    0.707010] hub 1-0:1.0: 1 port detected
    [    0.707594] dwc_otg: FIQ enabled
    [    0.707600] dwc_otg: NAK holdoff enabled
    [    0.707605] dwc_otg: FIQ split-transaction FSM enabled
    [    0.707616] Module dwc_common_port init
    [    0.707875] usbcore: registered new interface driver usb-storage
    [    0.708054] mousedev: PS/2 mouse device common for all mice
    [    0.708899] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    0.709132] bcm2835-cpufreq: min=600000 max=1200000
    [    0.709589] sdhci: Secure Digital Host Controller Interface driver
    [    0.709595] sdhci: Copyright(c) Pierre Ossman
    [    0.709962] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    [    0.710339] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [    0.710463] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.712008] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.712201] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.712371] usbcore: registered new interface driver usbhid
    [    0.712377] usbhid: USB HID core driver
    [    0.713309] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
    [    0.714811] [vc_sm_connected_init]: start
    [    0.723466] [vc_sm_connected_init]: end - returning 0
    [    0.724567] Initializing XFRM netlink socket
    [    0.724593] NET: Registered protocol family 17
    [    0.724711] Key type dns_resolver registered
    [    0.725291] Registering SWP/SWPB emulation handler
    [    0.725934] registered taskstats version 1
    [    0.725950] Loading compiled-in X.509 certificates
    [    0.733158] uart-pl011 3f201000.serial: cts_event_workaround enabled
    [    0.733240] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
    [    0.735071] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    0.735081] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    [    0.761301] sdhost: log_buf @ (ptrval) (fad07000)
    [    0.797689] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    0.799253] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.800814] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.803623] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    0.809205] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    0.810527] of_cfs_init
    [    0.810684] of_cfs_init: OK
    [    0.811292] Waiting for root device PARTUUID=d474f063-02...
    [    0.875117] random: fast init done
    [    0.898772] mmc0: host does not support reading read-only switch, assuming write-enable
    [    0.902166] mmc0: new high speed SDHC card at address aaaa
    [    0.903425] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
    [    0.906756]  mmcblk0: p1 p2
    [    0.918538] mmc1: new high speed SDIO card at address 0001
    [    0.927900] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    0.927909] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [    0.941957] Indeed it is in host mode hprt0 = 00021501
    [    1.151868] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    1.151993] Indeed it is in host mode hprt0 = 00001101
    [    1.392139] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
    [    1.392153] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.392816] hub 1-1:1.0: USB hub found
    [    1.392907] hub 1-1:1.0: 5 ports detected
    [    1.541181] EXT4-fs (mmcblk0p2): recovery complete
    [    1.543543] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.543602] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.552267] devtmpfs: mounted
    [    1.557564] Freeing unused kernel memory: 1024K
    [    1.557965] Run /sbin/init as init process
    [    1.711875] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    1.842211] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
    [    1.842226] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.844956] smsc95xx v1.0.6
    [    1.935443] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:43:8a:cf
    [    1.965539] systemd[1]: System time before build time, advancing clock.
    [    2.115077] NET: Registered protocol family 10
    [    2.116505] Segment Routing with IPv6
    [    2.156207] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.158664] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.164786] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
    [    2.165390] systemd[1]: Detected architecture arm.
    [    2.169934] systemd[1]: Set hostname to <ioBroker>.
    [    2.249565] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read)
    [    2.688652] systemd[1]: Listening on udev Kernel Socket.
    [    2.689298] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.689435] systemd[1]: Reached target Swap.
    [    2.689762] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.690036] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [    2.691070] systemd[1]: Created slice User and Session Slice.
    [    2.691354] systemd[1]: Listening on udev Control Socket.
    [    2.783463] i2c /dev entries driver
    [    3.285993] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.406338] systemd-journald[112]: Received request to flush runtime journal from PID 1
    [    3.718340] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.721801] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    3.731298] media: Linux media interface: v0.10
    [    3.732383] [vc_sm_connected_init]: start
    [    3.742395] [vc_sm_connected_init]: installed successfully
    [    3.778745] videodev: Linux video capture interface: v2.00
    [    3.868236] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.868244] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.895901] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.900760] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.929825] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.933778] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    3.933793] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    3.938818] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    3.938832] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    3.939748] bcm2835_audio soc:audio: card created with 8 channels
    [    3.954175] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    3.954189] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    4.132212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    4.190715] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    4.274141] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
    [    4.283263] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [    4.283534] usbcore: registered new interface driver brcmfmac
    [    4.518559] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [    4.518690] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
    [    4.519618] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
    [    5.616069] random: crng init done
    [    5.616104] random: 7 urandom warning(s) missed due to ratelimiting
    [    5.783329] uart-pl011 3f201000.serial: no DMA platform data
    [    6.260323] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [    6.260518] brcmfmac: power management disabled
    [    6.553813] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [    6.743168] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [    6.743341] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    7.829175] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   10.351508] Bluetooth: Core ver 2.22
    [   10.351647] NET: Registered protocol family 31
    [   10.351651] Bluetooth: HCI device and connection manager initialized
    [   10.355485] Bluetooth: HCI socket layer initialized
    [   10.355501] Bluetooth: L2CAP socket layer initialized
    [   10.355533] Bluetooth: SCO socket layer initialized
    [   10.383982] Bluetooth: HCI UART driver ver 2.3
    [   10.383992] Bluetooth: HCI UART protocol H4 registered
    [   10.384071] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   10.384206] Bluetooth: HCI UART protocol Broadcom registered
    [   10.667714] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   10.667723] Bluetooth: BNEP filters: protocol multicast
    [   10.667740] Bluetooth: BNEP socket layer initialized
    [   10.736300] Bluetooth: RFCOMM TTY layer initialized
    [   10.736327] Bluetooth: RFCOMM socket layer initialized
    [   10.736350] Bluetooth: RFCOMM ver 1.11
    [   14.094331] fuse init (API version 7.27)
    • R Raspo
      @Homoran
      jetzt:
      @Raspo sagte in Nach Update "admin"-modul kein Browser-Zugriff:
      [ 0.927900] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [ 0.927909] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      Nicht gut, dürfte aber vom harten Stromwegnehmen kommen.
      • R Raspo
        @Homoran
        jetzt:
        Hab zwar keine Ahnung, aber die unknown tuples fielen mir noch auf.
        zum Schluss
        [    1.541181] EXT4-fs (mmcblk0p2): recovery complete        [    1.543543] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        sah es IMHO brauchbar aus
        R 1 Antwort Letzte Antwort
          zum Schluss
          Raspo
          @Homoran
          @Thomas-Braun
          Was meint ihr was ich jetzt machen sollte?
          erstmal neu starten oder? 😊
          • R Raspo
            @Homoran
            @Thomas-Braun
            Hast du schon das iobroker upload all gemacht?
              @Raspo
              iobroker stop
              iobroker fix
              iobroker upload all
              Raspo
              @Thomas-Braun said in Nach Update "admin"-modul kein Browser-Zugriff:
              @Raspo
              iobroker stop
              iobroker fix
              iobroker upload all
              das habe ich noch nicht... mache ich jetzt..
              • R Raspo
                @Raspo
                iobroker stop
                iobroker fix
                iobroker upload all
                Raspo
                schrieb am zuletzt editiert von Raspo
                @Raspo
                mit dem hier konnte mein system nichts anfangen und hat mir eine Alternativ Befehlliste ausgegeben
                iobroker fix
                das hier ist nun durch:
                iobroker upload all
                • R Raspo
                  @Raspo
                  iobroker fix
                  iobroker upload all
                  @Raspo Dann hast du da noch einen alten js-controller laufen, der aktuelle kann mit
                  iobroker fix
                  was anfangen.
                  Ich würde aber zunächst mal das Grundsystem per
                  sudo apt update
                  sudo apt dist-upgrade
                  sudo reboot
                  aktualisieren.
                    iobroker fix
                    was anfangen.
                    sudo apt update
                    sudo reboot
                    aktualisieren.
                    Raspo
                    @Thomas-Braun
                    ok, das mache ich jetzt mal
                    • R Raspo
                      @Raspo
                      iobroker fix
                      iobroker upload all
                      Dann hast du aber einen sehr alten Controller :-(
                      iobroker -v
                      Dann musst du die lange Version nehmen wie sie in meiner Signatur steht: curl -fsL https://iobroker.net/fix.sh | bash -
                        iobroker -v
                        Raspo
                        das ist jetzt durch:
                        sudo apt update
                        @Thomas-Braun
                        sudo reboot
                        @Homoran
                        Nach den obigen update nun:
                        pi@ioBroker:~ $ iobroker -v
                        2.1.1
                        fix
                        pi@ioBroker:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
                        library: loaded
                        Library version=2020-12-07
                            Welcome to the ioBroker installation fixer!
                            Script version: 2020-12-07
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/3)
                        OK:1 http://archive.raspberrypi.org/debian stretch InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                        OK:3 https://deb.nodesource.com/node_8.x stretch InRelease
                        Installed gcc-c++
                            Checking ioBroker user and directory permissions (2/3)
                            Checking autostart (3/3)
                        Enabling autostart...
                        Autostart enabled!
                            Your installation was fixed successfully
                            Run iobroker start to start ioBroker again!
                        • R Raspo
                          sudo apt update
                          @Thomas-Braun
                          sudo reboot
                          @Homoran
                          2.1.1
                          fix
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          Raspo
                          @Raspo
                          @Homoran
                          @Thomas-Braun
                          puh, was meint ihr was ich nun noch machen könnte?
                          • R Raspo
                            @Raspo
                            @Homoran
                            @Thomas-Braun
                            zuerst mal den controller auf den aktuellen Stand bringen, da einige neuere Versionen mit 2.1.1 nicht mehr laufen
                            iobroker stop
                            iobroker update
                            iobroker upgrade self
                            Thomas BraunT R 2 Antworten Letzte Antwort
                              iobroker stop
                              iobroker update
                              @Homoran
                              Da wäre ich zunächst mal auf node12 gesprungen.
                              Das würde ich nach dem Grundsystem als nächstes aktuell halten. Erst dann den js-controller da reinsetzen.
                              @Raspo
                              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                              • R Raspo
                                @Raspo
                                @Homoran
                                @Thomas-Braun
                                @Raspo
                                Zeig mal die Ausgabe von
                                sudo apt update
                                  iobroker stop
                                  iobroker update
                                  Raspo
                                  @Homoran
                                  hier sieht es etwas unschön aus:
                                  pi@ioBroker:~ $ iobroker upgrade self
                                  Update js-controller from @2.1.1 to @3.1.6
                                  NPM version: 6.13.4
                                  npm install iobroker.js-controller@3.1.6 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                                  npm ERR! code ENOTSUP
                                  npm ERR! notsup Unsupported engine for iobroker.js-controller@3.1.6: wanted: {"node":">=10.0.0"} (current: {"node":"8.17.0","npm":"6.13.4"})
                                  npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@3.1.6
                                  npm ERR! notsup Required: {"node":">=10.0.0"}
                                  npm ERR! notsup Actual:   {"npm":"6.13.4","node":"8.17.0"}
                                  npm ERR!     /home/iobroker/.npm/_logs/2021-01-11T14_53_56_458Z-debug.log
                                  Starting node restart.js
                                    @Raspo
                                    sudo apt update
                                    Raspo
                                    @Thomas-Braun
                                    pi@ioBroker:~ $ sudo apt update
                                    OK:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                                    OK:2 http://archive.raspberrypi.org/debian stretch InRelease
                                    Abh▒ngigkeitsbaum wird aufgebaut.
                                    Alle Pakete sind aktuell.
                                    pi@ioBroker:~ $
                                    • R Raspo
                                      @Thomas-Braun
                                      pi@ioBroker:~ $
                                      @Raspo
                                      Jetzt ist dein node8 zu alt. Bring das mit der Anleitung auf node12:
                                      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                        @Homoran
                                        @Raspo
                                        Raspo
                                        @Thomas-Braun
                                        pi@ioBroker:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                        /usr/bin/nodejs
                                        v8.17.0
                                        /usr/bin/node
                                        v8.17.0
                                        /usr/bin/npm
                                        6.13.4
                                        nodejs:
                                          Installiert:           8.17.0-1nodesource1
                                          Installationskandidat: 8.17.0-1nodesource1
                                          Versionstabelle:
                                         *** 8.17.0-1nodesource1 500
                                                500 https://deb.nodesource.com/node_8.x stretch/main armhf Packages
                                             8.11.1~dfsg-2~bpo9+1 500
                                                500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                                             4.8.2~dfsg-1 500
                                                500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                                        • R Raspo
                                          @Thomas-Braun
                                          /usr/bin/nodejs
                                          v8.17.0
                                          /usr/bin/node
                                          v8.17.0
                                          /usr/bin/npm
                                          6.13.4
                                          nodejs:
                                            Versionstabelle:
                                               4.8.2~dfsg-1 500
                                          @Raspo
                                          Die Grundlagen sind schon mal sauber, jetzt nur noch auf node12 heben. S.o.
