  4. Nach Update "admin"-modul kein Browser-Zugriff
adminmodul admin update fehler
78 Beiträge 4 Kommentatoren 7.8k Aufrufe 3 Beobachtet
  • R Raspo
    @Raspo said in Nach Update "admin"-modul kein Browser-Zugriff:
    @Thomas-Braun
    pi@ioBroker:~ $ iobroker del admin.1
    Delete adapter "admin.1"
    host.ioBroker Counted 1 instances of admin.1
    host.ioBroker Counted 1 channels of admin.1
    host.ioBroker Counted 6 states of admin.1
    host.ioBroker Counted 14 states of system.adapter.admin.1
    host.ioBroker Deleting 22 object(s).
    pi@ioBroker:~ $ iobroker start admin.0
    The adapter "admin.0" was started.
    pi@ioBroker:~ $ iobroker list instances
      system.adapter.admin.0                 : admin                 -  enabled, por                                             t: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                 : admin                 -  enabled, por                                             t: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.1                : alexa2                -  enabled
      system.adapter.cloud.0                 : cloud                 - disabled
      system.adapter.daswetter.0             : daswetter             - disabled
      system.adapter.discovery.0             : discovery             - disabled
      system.adapter.ical.0                  : ical                  -  enabled
      system.adapter.info.0                  : info                  -  enabled
    + system.adapter.iot.0                   : iot                   -  enabled
    + system.adapter.javascript.0            : javascript            -  enabled
      system.adapter.moma.0                  : moma                  - disabled
      system.adapter.proxy.0                 : proxy                 -  enabled
      system.adapter.samsung.0               : samsung               - disabled
    + system.adapter.sonoff.0                : sonoff                -  enabled, por                                             t: 1883, bind: 0.0.0.0
      system.adapter.telegram.0              : telegram              - disabled, por                                             t: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0              : terminal              -  enabled, por                                             t: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                : tr-064                - disabled
      system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
      system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
      system.adapter.vis-justgage.0          : vis-justgage          -  enabled
      system.adapter.vis-metro.0             : vis-metro             -  enabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
      system.adapter.vis-weather.0           : vis-weather           -  enabled
      system.adapter.vis.0                   : vis                   -  enabled
    + system.adapter.web.0                   : web                   -  enabled, por                                             t: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                 : yahka                 - disabled
    + instance is alive
    @Raspo NIcht gut. Immer noch da und jetzt beide auf dem selben port aktiv
    was sagt dmesg
    R HomoranH 2 Antworten Letzte Antwort
      was sagt dmesg
      Raspo
      @Homoran
      Witzig, anscheind sind alle gute dinge... "2" 😵
      host.ioBroker Deleting 1 object(s).
      pi@ioBroker:~ $ ^C
       system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
       system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      • R Raspo
        @Homoran
        pi@ioBroker:~ $ ^C
        + instance is alive
        @Raspo sagte in Nach Update "admin"-modul kein Browser-Zugriff:
        admin
        HomoranH R 2 Antworten Letzte Antwort
          admin
          @Thomas-Braun sagte in Nach Update "admin"-modul kein Browser-Zugriff:
          admin
          oder erst ein iobroker upload admin
          wenn die SD-Karte nicht bereits "flackert"
            admin
            Raspo
            schrieb am zuletzt editiert von Raspo
            @Thomas-Braun
            + instance is alive
            Webzugriff ist noch immer nicht möglich
            • R Raspo
              @Homoran
              pi@ioBroker:~ $ ^C
              + instance is alive
              @Raspo
              Wenn das alles wieder sauber läuft würde ich das System einer Frischzellenkur unterziehen.
              sudo apt update
              sudo apt dist-upgrade
              sudo reboot
              iobroker stop
              iobroker update
              iobroker upgrade
              iobroker start
                @Raspo
                sudo apt update
                sudo reboot
                iobroker stop
                iobroker update
                iobroker upgrade
                iobroker start
                tut es aber nicht
                  was sagt dmesg
                  @Homoran sagte in Nach Update "admin"-modul kein Browser-Zugriff:
                  was sagt dmesg
                  Hatten wir das schon?
                  R 1 Antwort Letzte Antwort
                  • R Raspo
                    @Thomas-Braun
                    + instance is alive
                    @Raspo
                    iobroker stop
                    iobroker fix
                    iobroker upload all
                      was sagt dmesg
                      Raspo
                      @Homoran
                      jetzt:
                      pi@ioBroker:~ $ dmesg
                      [    0.000000] Booting Linux on physical CPU 0x0
                      [    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
                      [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
                      [    0.000000] CPU: div instructions available: patching division code
                      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                      [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
                      [    0.000000] Memory policy: Data cache writealloc
                      [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
                      [    0.000000] On node 0 totalpages: 242688
                      [    0.000000]   Normal zone: 2133 pages used for memmap
                      [    0.000000]   Normal zone: 0 pages reserved
                      [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
                      [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
                      [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
                      [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
                      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
                      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=d474f063-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
                      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
                      [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
                      [    0.000000] Virtual kernel memory layout:
                                         vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                         fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                         vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                                         lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                                         modules : 0x7f000000 - 0x80000000   (  16 MB)
                                           .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                                           .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                                           .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                                            .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
                      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                      [    0.000000] ftrace: allocating 26394 entries in 78 pages
                      [    0.000000] rcu: Hierarchical RCU implementation.
                      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                      [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
                      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
                      [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
                      [    0.000019] Switching to timer-based delay loop, resolution 52ns
                      [    0.000280] Console: colour dummy device 80x30
                      [    0.000299] console [tty1] enabled
                      [    0.000342] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
                      [    0.000358] pid_max: default: 32768 minimum: 301
                      [    0.000697] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
                      [    0.000712] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
                      [    0.001626] CPU: Testing write buffer coherency: ok
                      [    0.002092] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                      [    0.002738] Setting up static identity map for 0x100000 - 0x10003c
                      [    0.002886] rcu: Hierarchical SRCU implementation.
                      [    0.003677] smp: Bringing up secondary CPUs ...
                      [    0.004516] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                      [    0.005441] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                      [    0.006302] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                      [    0.006426] smp: Brought up 1 node, 4 CPUs
                      [    0.006438] SMP: Total of 4 processors activated (153.60 BogoMIPS).
                      [    0.006443] CPU: All CPU(s) started in HYP mode.
                      [    0.006448] CPU: Virtualization extensions available.
                      [    0.007422] devtmpfs: initialized
                      [    0.020552] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
                      [    0.020793] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                      [    0.020812] futex hash table entries: 1024 (order: 4, 65536 bytes)
                      [    0.021399] pinctrl core: initialized pinctrl subsystem
                      [    0.022261] NET: Registered protocol family 16
                      [    0.025346] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                      [    0.031160] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                      [    0.031168] hw-breakpoint: maximum watchpoint size is 8 bytes.
                      [    0.031371] Serial: AMBA PL011 UART driver
                      [    0.033649] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
                      [    0.068868] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
                      [    0.070550] SCSI subsystem initialized
                      [    0.070779] usbcore: registered new interface driver usbfs
                      [    0.070840] usbcore: registered new interface driver hub
                      [    0.070935] usbcore: registered new device driver usb
                      [    0.090139] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
                      [    0.100401] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
                      [    0.111819] clocksource: Switched to clocksource arch_sys_counter
                      [    0.200953] VFS: Disk quotas dquot_6.6.0
                      [    0.201034] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                      [    0.201189] FS-Cache: Loaded
                      [    0.201400] CacheFiles: Loaded
                      [    0.211406] NET: Registered protocol family 2
                      [    0.212212] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
                      [    0.212249] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
                      [    0.212358] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
                      [    0.212544] TCP: Hash tables configured (established 8192 bind 8192)
                      [    0.212676] UDP hash table entries: 512 (order: 2, 16384 bytes)
                      [    0.212722] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
                      [    0.213032] NET: Registered protocol family 1
                      [    0.213605] RPC: Registered named UNIX socket transport module.
                      [    0.213611] RPC: Registered udp transport module.
                      [    0.213617] RPC: Registered tcp transport module.
                      [    0.213623] RPC: Registered tcp NFSv4.1 backchannel transport module.
                      [    0.215425] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
                      [    0.218434] Initialise system trusted keyrings
                      [    0.218634] workingset: timestamp_bits=14 max_order=18 bucket_order=4
                      [    0.228590] FS-Cache: Netfs 'nfs' registered for caching
                      [    0.229160] NFS: Registering the id_resolver key type
                      [    0.229187] Key type id_resolver registered
                      [    0.229194] Key type id_legacy registered
                      [    0.229210] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                      [    0.231492] Key type asymmetric registered
                      [    0.231501] Asymmetric key parser 'x509' registered
                      [    0.231549] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
                      [    0.231707] io scheduler noop registered
                      [    0.231714] io scheduler deadline registered (default)
                      [    0.231972] io scheduler cfq registered
                      [    0.231980] io scheduler mq-deadline registered (default)
                      [    0.231987] io scheduler kyber registered
                      [    0.234959] bcm2708_fb soc:fb: FB found 1 display(s)
                      [    0.245803] Console: switching to colour frame buffer device 90x30
                      [    0.251321] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 720x480
                      [    0.253421] bcm2835-rng 3f104000.rng: hwrng registered
                      [    0.253733] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                      [    0.254236] vc-sm: Videocore shared memory driver
                      [    0.254553] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
                      [    0.265315] brd: module loaded
                      [    0.275472] loop: module loaded
                      [    0.276059] Loading iSCSI transport class v2.0-870.
                      [    0.276736] libphy: Fixed MDIO Bus: probed
                      [    0.276835] usbcore: registered new interface driver lan78xx
                      [    0.276893] usbcore: registered new interface driver smsc95xx
                      [    0.276909] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                      [    0.304753] dwc_otg 3f980000.usb: base=(ptrval)
                      [    0.504977] Core Release: 2.80a
                      [    0.504986] Setting default values for core params
                      [    0.505016] Finished setting default values for core params
                      [    0.705322] Using Buffer DMA mode
                      [    0.705329] Periodic Transfer Interrupt Enhancement - disabled
                      [    0.705334] Multiprocessor Interrupt Enhancement - disabled
                      [    0.705341] OTG VER PARAM: 0, OTG VER FLAG: 0
                      [    0.705359] Dedicated Tx FIFOs mode
                      [    0.705821] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
                      [    0.705846] FIQ FSM acceleration enabled for :
                                     Non-periodic Split Transactions
                                     Periodic Split Transactions
                                     High-Speed Isochronous Endpoints
                                     Interrupt/Control Split Transaction hack enabled
                      [    0.705854] dwc_otg: Microframe scheduler enabled
                      [    0.705909] WARN::hcd_init_fiq:457: FIQ on core 1
                      [    0.705920] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
                      [    0.705932] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
                      [    0.705949] dwc_otg 3f980000.usb: DWC OTG Controller
                      [    0.705982] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
                      [    0.706015] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
                      [    0.706061] Init: Port Power? op_state=1
                      [    0.706067] Init: Power Port (0)
                      [    0.706318] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
                      [    0.706330] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [    0.706339] usb usb1: Product: DWC OTG Controller
                      [    0.706348] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
                      [    0.706357] usb usb1: SerialNumber: 3f980000.usb
                      [    0.706966] hub 1-0:1.0: USB hub found
                      [    0.707010] hub 1-0:1.0: 1 port detected
                      [    0.707594] dwc_otg: FIQ enabled
                      [    0.707600] dwc_otg: NAK holdoff enabled
                      [    0.707605] dwc_otg: FIQ split-transaction FSM enabled
                      [    0.707616] Module dwc_common_port init
                      [    0.707875] usbcore: registered new interface driver usb-storage
                      [    0.708054] mousedev: PS/2 mouse device common for all mice
                      [    0.708899] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                      [    0.709132] bcm2835-cpufreq: min=600000 max=1200000
                      [    0.709589] sdhci: Secure Digital Host Controller Interface driver
                      [    0.709595] sdhci: Copyright(c) Pierre Ossman
                      [    0.709962] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
                      [    0.710339] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
                      [    0.710463] sdhci-pltfm: SDHCI platform and OF driver helper
                      [    0.712008] ledtrig-cpu: registered to indicate activity on CPUs
                      [    0.712201] hidraw: raw HID events driver (C) Jiri Kosina
                      [    0.712371] usbcore: registered new interface driver usbhid
                      [    0.712377] usbhid: USB HID core driver
                      [    0.713309] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
                      [    0.714811] [vc_sm_connected_init]: start
                      [    0.723466] [vc_sm_connected_init]: end - returning 0
                      [    0.724567] Initializing XFRM netlink socket
                      [    0.724593] NET: Registered protocol family 17
                      [    0.724711] Key type dns_resolver registered
                      [    0.725291] Registering SWP/SWPB emulation handler
                      [    0.725934] registered taskstats version 1
                      [    0.725950] Loading compiled-in X.509 certificates
                      [    0.733158] uart-pl011 3f201000.serial: cts_event_workaround enabled
                      [    0.733240] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
                      [    0.735071] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
                      [    0.735081] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
                      [    0.761301] sdhost: log_buf @ (ptrval) (fad07000)
                      [    0.797689] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                      [    0.799253] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                      [    0.800814] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                      [    0.803623] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                      [    0.809205] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
                      [    0.810527] of_cfs_init
                      [    0.810684] of_cfs_init: OK
                      [    0.811292] Waiting for root device PARTUUID=d474f063-02...
                      [    0.875117] random: fast init done
                      [    0.898772] mmc0: host does not support reading read-only switch, assuming write-enable
                      [    0.902166] mmc0: new high speed SDHC card at address aaaa
                      [    0.903425] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
                      [    0.906756]  mmcblk0: p1 p2
                      [    0.918538] mmc1: new high speed SDIO card at address 0001
                      [    0.927900] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                      [    0.927909] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                      [    0.941957] Indeed it is in host mode hprt0 = 00021501
                      [    1.151868] usb 1-1: new high-speed USB device number 2 using dwc_otg
                      [    1.151993] Indeed it is in host mode hprt0 = 00001101
                      [    1.392139] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
                      [    1.392153] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                      [    1.392816] hub 1-1:1.0: USB hub found
                      [    1.392907] hub 1-1:1.0: 5 ports detected
                      [    1.541181] EXT4-fs (mmcblk0p2): recovery complete
                      [    1.543543] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                      [    1.543602] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [    1.552267] devtmpfs: mounted
                      [    1.557564] Freeing unused kernel memory: 1024K
                      [    1.557965] Run /sbin/init as init process
                      [    1.711875] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                      [    1.842211] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
                      [    1.842226] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                      [    1.844956] smsc95xx v1.0.6
                      [    1.935443] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:43:8a:cf
                      [    1.965539] systemd[1]: System time before build time, advancing clock.
                      [    2.115077] NET: Registered protocol family 10
                      [    2.116505] Segment Routing with IPv6
                      [    2.156207] random: systemd: uninitialized urandom read (16 bytes read)
                      [    2.158664] random: systemd: uninitialized urandom read (16 bytes read)
                      [    2.164786] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
                      [    2.165390] systemd[1]: Detected architecture arm.
                      [    2.169934] systemd[1]: Set hostname to <ioBroker>.
                      [    2.249565] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read)
                      [    2.688652] systemd[1]: Listening on udev Kernel Socket.
                      [    2.689298] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                      [    2.689435] systemd[1]: Reached target Swap.
                      [    2.689762] systemd[1]: Listening on Journal Socket (/dev/log).
                      [    2.690036] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
                      [    2.691070] systemd[1]: Created slice User and Session Slice.
                      [    2.691354] systemd[1]: Listening on udev Control Socket.
                      [    2.783463] i2c /dev entries driver
                      [    3.285993] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                      [    3.406338] systemd-journald[112]: Received request to flush runtime journal from PID 1
                      [    3.718340] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                      [    3.721801] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                      [    3.731298] media: Linux media interface: v0.10
                      [    3.732383] [vc_sm_connected_init]: start
                      [    3.742395] [vc_sm_connected_init]: installed successfully
                      [    3.778745] videodev: Linux video capture interface: v2.00
                      [    3.868236] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                      [    3.868244] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                      [    3.895901] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                      [    3.900760] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                      [    3.929825] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                      [    3.933778] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                      [    3.933793] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                      [    3.938818] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                      [    3.938832] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                      [    3.939748] bcm2835_audio soc:audio: card created with 8 channels
                      [    3.954175] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                      [    3.954189] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                      [    4.132212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                      [    4.190715] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                      [    4.274141] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
                      [    4.283263] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
                      [    4.283534] usbcore: registered new interface driver brcmfmac
                      [    4.518559] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
                      [    4.518690] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
                      [    4.519618] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
                      [    5.616069] random: crng init done
                      [    5.616104] random: 7 urandom warning(s) missed due to ratelimiting
                      [    5.783329] uart-pl011 3f201000.serial: no DMA platform data
                      [    6.260323] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                      [    6.260518] brcmfmac: power management disabled
                      [    6.553813] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                      [    6.743168] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
                      [    6.743341] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                      [    7.829175] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                      [   10.351508] Bluetooth: Core ver 2.22
                      [   10.351647] NET: Registered protocol family 31
                      [   10.351651] Bluetooth: HCI device and connection manager initialized
                      [   10.355485] Bluetooth: HCI socket layer initialized
                      [   10.355501] Bluetooth: L2CAP socket layer initialized
                      [   10.355533] Bluetooth: SCO socket layer initialized
                      [   10.383982] Bluetooth: HCI UART driver ver 2.3
                      [   10.383992] Bluetooth: HCI UART protocol H4 registered
                      [   10.384071] Bluetooth: HCI UART protocol Three-wire (H5) registered
                      [   10.384206] Bluetooth: HCI UART protocol Broadcom registered
                      [   10.667714] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                      [   10.667723] Bluetooth: BNEP filters: protocol multicast
                      [   10.667740] Bluetooth: BNEP socket layer initialized
                      [   10.736300] Bluetooth: RFCOMM TTY layer initialized
                      [   10.736327] Bluetooth: RFCOMM socket layer initialized
                      [   10.736350] Bluetooth: RFCOMM ver 1.11
                      [   14.094331] fuse init (API version 7.27)
                      • R Raspo
                        @Homoran
                        jetzt:
                        [ 0.927900] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [ 0.927909] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                        Nicht gut, dürfte aber vom harten Stromwegnehmen kommen.
                        • R Raspo
                          @Homoran
                          jetzt:
                          Hab zwar keine Ahnung, aber die unknown tuples fielen mir noch auf.
                          zum Schluss
                          [    1.541181] EXT4-fs (mmcblk0p2): recovery complete        [    1.543543] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                          sah es IMHO brauchbar aus
                            zum Schluss
                            Raspo
                            @Homoran
                            @Thomas-Braun
                            Was meint ihr was ich jetzt machen sollte?
                            erstmal neu starten oder? 😊
                            • R Raspo
                              @Homoran
                              @Thomas-Braun
                              Hast du schon das iobroker upload all gemacht?
                                @Raspo
                                iobroker stop
                                iobroker fix
                                iobroker upload all
                                Raspo
                                @Thomas-Braun said in Nach Update "admin"-modul kein Browser-Zugriff:
                                @Raspo
                                iobroker stop
                                iobroker fix
                                iobroker upload all
                                das habe ich noch nicht... mache ich jetzt..
                                • R Raspo
                                  @Raspo
                                  iobroker stop
                                  iobroker fix
                                  iobroker upload all
                                  Raspo
                                  @Raspo
                                  mit dem hier konnte mein system nichts anfangen und hat mir eine Alternativ Befehlliste ausgegeben
                                  iobroker fix
                                  das hier ist nun durch:
                                  iobroker upload all
                                  • R Raspo
                                    @Raspo
                                    iobroker fix
                                    iobroker upload all
                                    @Raspo Dann hast du da noch einen alten js-controller laufen, der aktuelle kann mit
                                    iobroker fix
                                    was anfangen.
                                    Ich würde aber zunächst mal das Grundsystem per
                                    sudo apt update
                                    sudo reboot
                                    aktualisieren.
                                      iobroker fix
                                      was anfangen.
                                      sudo apt update
                                      sudo reboot
                                      aktualisieren.
                                      Raspo
                                      @Thomas-Braun
                                      ok, das mache ich jetzt mal
                                      • R Raspo
                                        @Raspo
                                        iobroker fix
                                        iobroker upload all
                                        Dann hast du aber einen sehr alten Controller :-(
                                        iobroker -v
                                        Dann musst du die lange Version nehmen wie sie in meiner Signatur steht: curl -fsL https://iobroker.net/fix.sh | bash -
                                          iobroker -v
                                          Raspo
                                          das ist jetzt durch:
                                          sudo apt update
                                          @Thomas-Braun
                                          sudo reboot
                                          @Homoran
                                          Nach den obigen update nun:
                                          pi@ioBroker:~ $ iobroker -v
                                          2.1.1
                                          fix
                                          pi@ioBroker:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
                                          library: loaded
                                          Library version=2020-12-07
                                              Welcome to the ioBroker installation fixer!
                                              Script version: 2020-12-07
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/3)
                                          OK:1 http://archive.raspberrypi.org/debian stretch InRelease
                                          OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                                          OK:3 https://deb.nodesource.com/node_8.x stretch InRelease
                                          Installed gcc-c++
                                              Checking ioBroker user and directory permissions (2/3)
                                              Checking autostart (3/3)
                                          Enabling autostart...
                                          Autostart enabled!
                                              Your installation was fixed successfully
                                              Run iobroker start to start ioBroker again!
