  4. Synology- mal wieder Zigbee - CC2531 USB, Gelöst
zigbee cc2531
87 Beiträge 6 Kommentatoren 16.8k Aufrufe 7 Beobachtet
  • D dos1973
    @Glasfaser @arteck
    ich traf mich gerade nicht den ollen Thread wieder zu öffnen, aber ich muss.
    ich habe mir heute einen neuen Zigbee Stick CC2652P geholt - dachte alles wird schneller und besser....
    Egal, ich stehe hier wieder mit der gleichen FM, wie damals.
    zigbee.0	2021-01-05 21:41:44.143	info	(18665) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
    zigbee.0	2021-01-05 21:41:44.142	error	(18665) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stac
    zigbee.0	2021-01-05 21:41:44.141	error	(18665) Failed to start Zigbee
    zigbee.0	2021-01-05 21:41:44.134	info	(18665) Starting Zigbee npm ...
    zigbee.0	2021-01-05 21:41:44.133	info	(18665) Try to reconnect. 1 attempts left
    zigbee.0	2021-01-05 21:41:34.130	error	(18665) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stac
    zigbee.0	2021-01-05 21:41:34.126	error	(18665) Failed to start Zigbee
    zigbee.0	2021-01-05 21:41:34.055	info	(18665) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
    zigbee.0	2021-01-05 21:41:33.915	info	(18665) Starting Zigbee npm ...
    zigbee.0	2021-01-05 21:41:33.799	info	(18665) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1, js-controller: 3.1.6
    zigbee.0	2021-01-05 21:41:26.601	error	(17351) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Func
    zigbee.0	2021-01-05 21:41:26.585	error	(17351) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2021-01-05 21:41:26.583	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2021-01-05 21:41:26.527	info	(17351) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2021-01-05 21:41:26.522	info	(17351) terminating
    zigbee.0	2021-01-05 21:41:26.522	error	(17351) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.
    zigbee.0	2021-01-05 21:41:26.519	info	(17351) Zigbee: disabling joining new devices.
    zigbee.0	2021-01-05 21:41:26.513	info	(17351) cleaned everything up...
    zigbee.0	2021-01-05 21:41:26.511	info	(17351) Got terminate signal TERMINATE_YOURSELF
    ich habe alles aus dem Thread wiederholt 2x, was letztes mal zum Erfolg geführt, aber ich bekomme es nicht auf grün.
    könntet ihr mich nochmals unterstütze.
    GlasfaserG Offline
    GlasfaserG Offline
    @dos1973 sagte in Synology- mal wieder Zigbee - CC2531 USB, Gelöst:
    gleiches Thema .....wie oben ... was schonmal war.
    hast du überprüft welchen ttyACM .... Synology dafür angelegt hat .... ist er richtig durchgereicht in ENV usw.
    • GlasfaserG Glasfaser
      dos1973
      @Glasfaser
      ich bekomme es nicht raus welchen Synology verwendet??!
      • D dos1973
        @Glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @dos1973
        hier im Synology Verzeichniss !??
          @dos1973
          dos1973
          @Glasfaser
          ich weiß nicht was ich machen soll, sorry?
          root@iobroker:/dev# ls
          bsg              loop215             ptyac  ptyu6      tty31  ttyr3
          btrfs-control    loop216             ptyad  ptyu7      tty32  ttyr4
          bus              loop217             ptyae  ptyu8      tty33  ttyr5
          core             loop218             ptyaf  ptyu9      tty34  ttyr6
          cpu              loop219             ptyb0  ptyua      tty35  ttyr7
          cpu_dma_latency  loop22              ptyb1  ptyub      tty36  ttyr8
          dm-0             loop220             ptyb2  ptyuc      tty37  ttyr9
          dri              loop221             ptyb3  ptyud      tty38  ttyra
          fb0              loop222             ptyb4  ptyue      tty39  ttyrb
          fd               loop223             ptyb5  ptyuf      tty4   ttyrc
          full             loop224             ptyb6  ptyv0      tty40  ttyrd
          fuse             loop225             ptyb7  ptyv1      tty41  ttyre
          hda              loop226             ptyb8  ptyv2      tty42  ttyrf
          hda1             loop227             ptyb9  ptyv3      tty43  ttys0
          hda2             loop228             ptyba  ptyv4      tty44  ttyS0
          hda3             loop229             ptybb  ptyv5      tty45  ttys1
          hda4             loop23              ptybc  ptyv6      tty46  ttyS1
          i2c-0            loop230             ptybd  ptyv7      tty47  ttys2
          i2c-1            loop231             ptybe  ptyv8      tty48  ttyS2
          i2c-2            loop232             ptybf  ptyv9      tty49  ttys3
          i2c-3            loop233             ptyc0  ptyva      tty5   ttyS3
          i2c-4            loop234             ptyc1  ptyvb      tty50  ttys4
          kmem             loop235             ptyc2  ptyvc      tty51  ttys5
          kmsg             loop236             ptyc3  ptyvd      tty52  ttys6
          loop0            loop237             ptyc4  ptyve      tty53  ttys7
          loop1            loop238             ptyc5  ptyvf      tty54  ttys8
          loop10           loop239             ptyc6  ptyw0      tty55  ttys9
          loop100          loop24              ptyc7  ptyw1      tty56  ttysa
          loop101          loop240             ptyc8  ptyw2      tty57  ttysb
          loop102          loop241             ptyc9  ptyw3      tty58  ttysc
          loop103          loop242             ptyca  ptyw4      tty59  ttysd
          loop104          loop243             ptycb  ptyw5      tty6   ttyse
          loop105          loop244             ptycc  ptyw6      tty60  ttysf
          loop106          loop245             ptycd  ptyw7      tty61  ttyt0
          loop107          loop246             ptyce  ptyw8      tty62  ttyt1
          loop108          loop247             ptycf  ptyw9      tty63  ttyt2
          loop109          loop248             ptyd0  ptywa      tty7   ttyt3
          loop11           loop249             ptyd1  ptywb      tty8   ttyt4
          loop110          loop25              ptyd2  ptywc      tty9   ttyt5
          D GlasfaserG 2 Antworten Letzte Antwort
          • D dos1973
            @Glasfaser
            dos1973
            normalerweise müsste doch bereits hier /dev/ttyACM0;/dev/ttyACM1 zu sehen sein
            • D dos1973
              @Glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @dos1973
              ich seh da nichts ... an einem Stick .
              zeige mal :
              ls -l /dev/tty*
              Und :
              Nimm mal den alten Stick .... was dann ist .
              • D dos1973
                GlasfaserG Offline
                GlasfaserG Offline
                @dos1973
                Mal was anders ...
                Hast du ein Update auf DSM 7.0 gemacht !!???
                  @dos1973
                  zeige mal :
                  ls -l /dev/tty*
                  Und :
                  dos1973
                  @Glasfaser
                  da kommt ewig viel.
                  was suche ich hier? Die gibt es nicht
                    @dos1973
                    Mal was anders ...
                    dos1973
                    @Glasfaser Nein
                    • D dos1973
                      @Glasfaser Nein
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @dos1973
                      Ok ... bei 7.0 gibt es was anderes zu beachten. (noch ) .
                      Ja richtig nach /ttyACM0; oder /ttyACM1.
                      Was ist jetzt mit deinem alten Stick !===
                        @dos1973
                        dos1973
                        @Glasfaser
                        der alte sieht genauso aus, kein Unterschied
                        GlasfaserG D 2 Antworten Letzte Antwort
                        • D dos1973
                          @Glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @dos1973
                          Kann du hier etwas sehen !?
                          Nicht das sich da etwas an der Synology ausgeschaltet hat , USB Port.
                          Synology schonmal neu gestartet , ohne Stick´s und dann den alten rein .
                          • D dos1973
                            @Glasfaser
                            dos1973
                            @dos1973
                            es macht kein Unterschied ob ich den neuen oder den alten anschliesse.
                            mit
                            ls -l /dev/tty*
                            gibt es keine /dev/ttyACM0;/dev/ttyACM1
                            • D dos1973
                              @dos1973
                              mit
                              ls -l /dev/tty*
                              dos1973
                              das ist der neue
                              der alte
                              kann ich umstecken, aktualisiert sofort
                              • D dos1973
                                das ist der neue
                                der alte
                                dos1973
                                @dos1973
                                ich boote mal die Synonyme neu, ohne stick.
                                aber warum erst den alten rein?? nach reboot
                                • D dos1973
                                  @dos1973
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @dos1973
                                  das hat sich mit meiner Frage bzw. mit deiner Antwort überschnitten.
                                  Ich sagte ja ... bzw. war erst meine Vermutung das überhaupt kein USB mehr geht.
                                  Aber das hast du ja jetzt selber gesehen das es geht .
                                  • D dos1973
                                    das ist der neue
                                    der alte
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    der alte
                                    Die Putty Augabe ... soll die dann von dir deuten das er auf tty3 ist .
                                    Habe ich aber noch nie gesehen , das er wechselt von ttyACM0 auf nur tty3 und das auf einmal !?
                                      der alte
                                      dos1973
                                      @Glasfaser
                                      nein, sorry, das war das Fenster einfach drunter... das hate keinen Zusammenhang
                                      • D dos1973
                                        @Glasfaser
                                        dos1973
                                        @dos1973
                                        jetzt nach Neustart sehe ich keine usb gerate mehr im in der Syno
                                        • D dos1973
                                          @dos1973
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Eigentlich ist dieses mit den USB erst bei DSM 7 ... was bei der Offizelen Version behoben wird .(sollte)
                                          Finde es gerade merkwürdig bei dir.
                                          Schau mal hier , dort war es wie man es bei DSM 7 macht .
                                          https://forum.iobroker.net/topic/40110/docker-install-synology-dsm-7-zigbee-stick-nicht-erkannt/9
