  4. Ereignisliste erzeugen
89 Beiträge 21 Kommentatoren 28.4k Aufrufe 2 Beobachtet
  • K
    K
    kirbsi
    @sissiwup:
    um eine Ereignisliste:
    filename="Bildschirmfoto 2015-09-06 um 20.46.22.png" index="0">~~
    zu erzeugen, kann man folgendes Skript verwenden:
    `createState("vEreignisse","
    *   first
    var sensorsST = $('channel[state.id=*.STATE](functions=ST)').each(function(id) {
        var val = getObject(id).common.name;
        log("DeviceST=" + val);
    var sensorsVS = $('channel[state.id=*.STATE](functions=VS)').each(function(id) {
        log("DeviceVS=" + val);
    var sensorsBW = $('channel[state.id=*.MOTION](functions=BW)').each(function(id) {
        log("DeviceBW=" + val);
    var vAlarmanlage = $('state[id="hm-rega.0.3747"]').each(function(id) {
        log("Alarmanlage=" + val);
    function ereignis(text) {
        log("ereignis "+text);
        var ereignisStr = getState("vEreignisse").val;
        var ereignisArr;
        ereignisArr = ereignisStr.replace(/`
    `*   /, "").replace(/<\/li><\/ul>/, "").split("*   ");
            ereignisArr = ereignisArr.reverse();
            ereignisArr.push(text);
            ereignisArr.reverse().splice(99); // Liste auf 20 Einträge beschränken
            var str = ereignisArr.join("`
            setState("vEreignisse", "
        *   "+str+"
        function timestamp(ts) {
            var now=new Date(ts);
            var day = now.getDate();
            var month = now.getMonth() + 1;
            var year = now.getFullYear();
            var weekday = now.getDay();
            var hours = now.getHours();
            var minutes = now.getMinutes();
            var seconds = now.getSeconds();
            var day0  = ((day < 10) ? "0" : "");
            var month0  = ((month < 10) ? "0" : "");
            var hours0  = ((hours < 10) ? "0" : "");
            var minutes0  = ((minutes < 10) ? "0" : "");
            var seconds0  = ((seconds < 10) ? "0" : "");
            var output = year + "-" + month0 + month + "-" + day0 + day + " " + hours0 + hours + ":" + minutes0 + minutes + ":" + seconds0 + seconds;
            return output;
        function room(obj) {
            var devname=obj.deviceName;
            var dp = getObject(obj.id,"rooms");
            var raum=dp.enumNames;
        //    var raum="---";
            var rooms ={"ST-05" : "OG Balkontür", "ST-02" : "OG Wohnzimmer BW", "ST-03" : "EG Treppenhaustür"
              , "ST-01" : "EG Wintergarten" , "ST-04" : "EG Eingangstür"
              , "BW-01" : "UG Garage" , "BW-02" : "EG Wintergarten" , "BW-03" : "OG Wohnzimmer"
              , "VS-01" : "EG Eingangstür" , "VS-02" : "UG Eingangstür" , "VS-03" : "UG Waschküche"
              , "VS-04" : "UG Garagentor" , "VS-05" : "EG Balkontür Atrium" , "VS-06" : "EG Relaxraum"
              , "VS-07" : "OG Balkontür" , "VS-08" : "OG Dachfenster" , "VS-09" : "EG Katzen R"
              , "VS-10" : "EG Katzen L" , "VS-11" : "EG Wintergarten" , "VS-12" : "EG Wohnzimmerfenster"
              , "VS-13" : "EG Küche L" , "VS-14" : "EG Küche R" , "VS-15" : "EG Abstellkammer"
              , "VS-16" : "EG Trepphaus" , "VS-17" : "OG Gästezimmer" , "VS-18" : "OG Ankleidezimmer"
            if (devname in rooms) {
                return rooms[devname];
            return raum;
        sensorsST.on(function(obj) {
          var aktion="AUTO";
          if (obj.newState.val == 1) {
            aktion="OFF";
          var ts=timestamp(obj.newState.ts);
            ereignis(ts + " " + obj.deviceName + " " + room(obj) + " " + aktion);
        //    log("OBJ=" + JSON.stringify(obj,null,2));
        sensorsVS.on(function(obj) {
          var aktion="ZU";
            aktion="AUF";
        sensorsBW.on(function(obj) {
            ereignis(ts + " " + obj.deviceName + " " + room(obj) + " " + "Bewegung");
        vAlarmanlage.on(function(obj) {
          var aktion="Haus alles gesichert";
            aktion="im Haus/Lüften";
          if (obj.newState.val == 2) {
            aktion="OFF";
            ereignis(ts + " Alarmstatus: " + aktion);
        mit den Funktionen sensorsXX Frage ich alle Sensoren, die zu einer Gruppe gehören ab,
        bei VS = Verschluß, BW = Bewegung und ST = Statusänderung/Schalter
        mit vAlarmanlage Frage ich einen einzelnen Datenpunkt ab, hier eine Variable.
        Im unteren Bereich des Skriptes muss zu jeder Funktion eine *.on Funktion dazu erstellt werden.
        Diese kann je nach Geräteart die Ausgabe umformulieren.
        UPDATE: Angepasst an neue Timestamps!
    Ich bekomme es nicht so schön dargestellt mit diesem skript. Welches widget nutzt ihr?
    • ruhr70R
      ruhr70R
      ruhr70
      @michihorn:
      @ruhr70:
      Um "wichtige" Ereignisse des Tages in einer Liste darzustellen, die dann in Vis mit eingebunden ist.
      Ich lasse mir z.B. u.a. folgende Punkte anzeigen:
      • Anwesenheiten
      • Haustür geöffnet
      • Internetausfall / neue IP-Adresse
      • Anrufe in Abewesenheit
      • Änderungen von Logikschaltern (Logik ein/aus)
      • Änderung von diversen Variablen
      Die letzten 30 Ereignisse werden in einer Liste in VIS dargestellt. `
      Hallo
      wie realisierst Du denn Internetausfall?
      Michael `
      Oh… sorry. Hab die Frage irgendwie übersehen.
      Momentan nicht aktiv. Aber das war simpel gelöst.
      Drei "größere" externe Adressen (1x per IP, 2x per URL) mit dem PING Adapter überwacht. Wenn alle drei dreimal hintereinander nicht erreichbar sind, wurde das als Internetausfall gewertet und in die Ereignisliste geschrieben. Zusätzlich habe ich regelmässig die öffentlcihe IP-Adresse abgefragt und bei Änderung diese auch in die Ereignisliste geschrieben (das war einmal täglich Nachts, nach der Zwangstrennung).
      Internetausfall wurde zusätzlich im Haus per Sonos angesagt.
      • ruhr70R
        ruhr70R
        ruhr70
        @kirbsi:
        Ich bekomme es nicht so schön dargestellt mit diesem skript. Welches widget nutzt ihr? `
        Bei mir ist es ein "basic - html", da ich Infos tlw. farbig hervorhebe.
        • K
          K
          kirbsi
          Wie bekommst du es denn mit Basic HTML dargestellt. Komme doch gar nicht auf meine Objekt ID?
          • ruhr70R
            ruhr70R
            ruhr70
            @kirbsi:
            Wie bekommst du es denn mit Basic HTML dargestellt. Komme doch gar nicht auf meine Objekt ID? `
            Ich baue die Ereignislisten als Text mit html-Formatierungen auf und verweise auf den den Datenpunkt mit geschfeiten Klammern {Datentenpunkt_ID}.
            • K
              K
              kirbsi
              Vielen Dank. Hat super geklappt. Kannst du mir noch n Tip geben wie du das mit den Farben gemacht hast?
              • ruhr70R
                ruhr70R
                ruhr70
                @kirbsi:
                Vielen Dank. Hat super geklappt. Kannst du mir noch n Tip geben wie du das mit den Farben gemacht hast? `
                Im Text des Ereignis html-Formatierungen einbauen:
                event('ioBroker - **Update für ' + obj.state.val + '** Adapter verfügbar.');
                event() ist bei mir eine kurze globale Funktion, mit der ich aus jedem Skript ein Ereignis schreiben kann.
                In den Ereignissen, in den ich was farbig oder fett darstellen lassen möchte, formatiere ich das mit .
                • K
                  K
                  kirbsi
                  Ja das kann ich leider nicht mehr nachvollziehen.
                  • ruhr70R
                    ruhr70R
                    ruhr70
                    @kirbsi:
                    Ja das kann ich leider nicht mehr nachvollziehen. `
                    Am Beispiel oben:
                    hallo
                    Das hallo würde nun rot ausgegeben.
                    • htreckslerH
                      htreckslerH
                      htrecksler
                      Forum Testing
                      @ruhr70
                      kannst Du mir verraten wie Du das mit dem 3 mal hintereinander gemacht hast?
                      Wenn ich mit "on" subscribe reagiert er nur dann wenn der der Ping von TRUE auf FALSE ändert (und umgekehrt)
                      Bleibt der Status gleich passiert nichts.
                      var oldState = null;
                      var newState = null;
                      on("ping.0.IntelNuc.192_168_XXX_XX", function (obj) {
                           newState = obj.state;
                           oldState = obj.oldState;
                           log('Test-' + 'NewState: '+ newState.val + '-' + 'OldState: ' + oldState.val);
                      Der Logeintrag wird nur dann geschrieben wenn ich am Handy WLAN aus bzw einschalte.
                      Gruss Hermann
                      • ruhr70R
                        ruhr70R
                        ruhr70
                        @htrecksler:
                        emacht hast?
                        Bleibt der Status gleich passiert nichts. `
                        Schau mal bitte unter: https://github.com/ioBroker/ioBroker.ja … some-state
                        Du musst den Parameter "change" anders einstellen.
                        "ne" ist Default (keine Änderung des Datenpunkts.
                        Dann baust Du einen Zähler, der, in meinem Beispiel, bei einmal "true" immer auf 0 gesetzt wird und der hochzählt, sobald alle der überwachten Pings auf "false"stehen. Die Grenze ist dann z.B. drei.
                        • htreckslerH
                          htreckslerH
                          htrecksler
                          Forum Testing
                          OK, Danke … den Defaultwert für change hatte ich verdrängt.
                          Ich probiere es nachher aus. Danke für schnelle Hilfe.
                          EDIT: probiert...kaum macht man es richtig...funktioniert's. Danke nochmal
                          Gruss Hermann
                          • P
                            P
                            PrinzEisenherz1
                            @ruhr70:
                            @kirbsi:
                            In den Ereignissen, in den ich was farbig oder fett darstellen lassen möchte, formatiere ich das mit . `
                            Hi ruhr70!
                            Könntest Du mir vielleicht das genauer erklären wie Du das mit der globalen Funktion umgesetzt hast?
                            Ich habe da n paar Scripte wo ich gerne n Ereignis an die Ereignissliste übergeben möchte.
                            Des weiteren hab ich nämlich das Problem wenn ich z.B ein Javascript-Objekt auslesen möchte
                            var vBewegungGarten = $('state[id="javascript.0.Garten.Bewegung"]').each(function(id) {
                                log("Garten=" + val);
                            vBewegungGarten.on(function(obj) {
                              if (obj.newState.val === 0) {
                                var aktion="Bewegung erkannt";
                                ereignis(ts + " Garten: " + aktion);
                            Dann steigt irgendwie das Script bzw der Javascript-Adapter aus.
                            Könntest Du mir da vielleicht weiterhelfen?
                            Vielen Dank im voraus
                            Gruß Johnny
                            Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                            • ruhr70R
                              ruhr70R
                              ruhr70
                              @PrinzEisenherz1:
                              Ich habe da n paar Scripte wo ich gerne n Ereignis an die Ereignissliste übergeben möchte. `
                              ne, ist zu peinlich das zu schreiben ;-)
                              Das globale Skript: :roll:
                              function event(text) {
                                  setState("javascript.0.Ereignisliste.event",text);
                              Und dann das Skript für die Ereignisse als normales Skript. Überwachung des Datenpunkts im Ereignislistenskript. Erstellung der Ereignisliste.
                              Über einen zweiten Parameter könnte man jetzt noch einbauen, dass unterschiedliche Datenpunkte gefüllt werden, um unterschiedliche Ereignislisten global anzusteuern.
                              Das wars dann schon.
                              @PrinzEisenherz1:
                              Könntest Du mir da vielleicht weiterhelfen? `
                              Ich weiss nicht, ob ich Dir da helfen kann. Mit dem Selector habe ich recht wenig Erfahrung und die Infos sind jetzt etwas dürftig.
                              Kannst Du im Log mehr sehen?
                              Ansonsten was geht auskommentieren und nach und nach freigeben, um zu sehen, wann der Adapter aussteigt.
                              sorry
                              • P
                                P
                                PrinzEisenherz1
                                Danke für die Info!
                                Und wie hast Du Dein Ereignisscript abgeändert das es die Ereignisse so sauber untereinander reiht?
                                Mein Script sieht so aus
                                `/* Programm Ereignissliste für VIS */
                                	var logging = true;
                                createState("javascript.0.Servicemeldungen.vEreignisse","
                                *   first
                                var sensorsST = $('channel[state.id=*.STATE](functions=Schaltsteckdosen)').each(function(id) {
                                	if (logging) log("DeviceST=" + val);
                                var sensorsVS = $('channel[state.id=*.STATE](functions=Verschluss)').each(function(id) {
                                	if (logging) log("DeviceVS=" + val);
                                var sensorsBW = $('channel[state.id=*.MOTION](functions=Bewegungsmelder)').each(function(id) {
                                	if (logging) log("DeviceBW=" + val);
                                var vAlarmanlage_aussen = $('state[id="hm-rega.0.8834"]').each(function(id) {
                                	if (logging) log("Alarmanlage Aussenbereich= " + val);
                                var vAlarmanlage_gesamt = $('state[id="hm-rega.0.8835"]').each(function(id) {
                                	if (logging) log("Alarmanlage Gesamt= " + val);
                                var vAnwesenheitBaerchen = $('state[id="hm-rega.0.17897"]').each(function(id) {
                                	if (logging) log("Baerchen anwesend= " + val);
                                var vAnwesenheitHase = $('state[id="hm-rega.0.17898"]').each(function(id) {
                                	if (logging) log("Hase anwesend= " + val);
                                	if (logging) log("ereignis "+text);
                                    var ereignisStr = getState("javascript.0.Servicemeldungen.vEreignisse").val;
                                    var ereignisArr;
                                        setState("javascript.0.Servicemeldungen.vEreignisse", "
                                    *   "+str+"
                                        var output = day0 + day + "." + month0 + month + ". " + hours0 + hours + ":" + minutes0 + minutes+ " ";
                                        return output;
                                      var aktion=" => AUS";
                                        aktion=" => AN";
                                      ereignis(ts + "  " + obj.deviceName + " " + aktion);
                                    	if (logging) log("OBJ=" + JSON.stringify(obj,null,2));
                                      var aktion=" => VERSCHLOSSEN";
                                        aktion=" => AUF";
                                        aktion=" => KIPP";
                                      ereignis(ts + "  " + room(obj) + " " + " => Bewegung");
                                    vAlarmanlage_aussen.on(function(obj) {
                                      var aktion="Aussenbereich gesichert";
                                        aktion="Aussenbereich deaktiviert";
                                    vAlarmanlage_gesamt.on(function(obj) {
                                      var aktion="Komplettbereich gesichert";
                                        aktion="Komplettbereich deaktiviert";
                                    vAnwesenheitBaerchen.on(function(obj) {
                                      var aktion="Bärchen ist ausser Haus";
                                        aktion="Bärchen ist anwesend";
                                        ereignis(ts + "  Anwesenheit: " + aktion);
                                    vAnwesenheitHase.on(function(obj) {
                                      var aktion="Hase ist ausser Haus";
                                        aktion="Hase ist anwesend";
                                    und das Globale Script so
                                        setState("javascript.0.Servicemeldungen.vEreignisse",text);
                                    Wenn ich jetzt Dein Beispiel nehme
                                    on({id: 'admin.0.info.updatesNumber', change: 'any'},
                                    function(obj) {
                                    event2('ioBroker - **Update für ' + obj.state.val + '** Adapter verfügbar.');
                                    Dann werden zum einen alle Ereignisse gelöscht und nur dieses angezeigt und dann fehlt auch noch die Uhrzeit!
                                    Wie hast du das gelöst?
                                    gruß
                                    Johnny
                                • ruhr70R
                                  ruhr70R
                                  ruhr70
                                  @PrinzEisenherz1:
                                  Danke für die Info!
                                  Und wie hast Du Dein Ereignisscript abgeändert das es die Ereignisse so sauber untereinander reiht? `
                                  Das "globale Skript" und dann ein normales Skript, um die Ereignisliste zu erstellen:
                                  // Erstellt eine Ereignisliste mit 50 Einträgen //============================================== ! var eventsLength = 50; // maximale Anzahl von Ereignissen ! var idEventList = "Ereignisliste.eventlistArr"; // Hier wird die Lsite als Array angelegt var idEventListStr = "Ereignisliste.eventlist"; // Die Liste als String mit für VIS ! var idEvent = "javascript.0.Ereignisliste.event"/*Aktueller Event*/; // überwachter Datenpunkt ! // Events werden mit der globalen Funktion // event() als Text in die ID: idEvent geschrieben // neue Texte dort werden von diesem Skript verarbeitet ! // ----------------------------------------------------------------------------- ! // Datenpunkt für die Eventliste anlegen createState(idEventList ,formatDate(new Date(), 'DD.MM. hh:mm') + ' Datenpunkt angelegt'); createState(idEventListStr ,""); ! function readListEvent(id) { // lese ein JSON aus einem Datenpunkt var list; try { list = JSON.parse(getState(id).val); } catch (ex) { list = []; } if(!list) list = []; return list; } function writeListEvent(list,id) { // schreibt ein JSON in einen Datenpunkt setState(id, JSON.stringify(list)); } ! function getEventsList(events) { var text = ''; for (var i = 0; i < events.length; i++) { text += (text ? ' \n' : '') + events[i]; } return text; } ! // Ereignis schreiben function writeEvent(text) { var events = readListEvent(idEventList); // list die Liste aus einem Datenpunkt events.unshift(formatDate(new Date(), 'DD.MM. hh:mm ') + text); // fügt den Text als Event am Anfag der Liste ien if (events.length > eventsLength) events.pop(); // kürzt die Liste hinten, wenn die maximale Länge erreicht ist writeListEvent(events, idEventList); // schreibt die Liste in den Datenpunkt zurück setState(idEventListStr,getEventsList(events)); // erzeugt aus dem Array den String mit für neue Zeilen } ! // ----------------------------------------------------------------------------- ! on({id:idEvent,change:'any'}, function (obj) { // wenn ein neuer Event geschrieben wird //if (!obj.newState.ack && obj.newState.val) { log("neuer Event zum verarbeiten: " + obj.state.val); writeEvent(obj.state.val); //} }); ! // --------------- Script start ---------------- #### Script Start #### ! function main() { log("Ereignisliste: Skript gestartet"); } ! setTimeout(main, 500);
                                  ! Wenn in einem beliebigen anderen Skript nun event("Beispieltext") aufgerufen wird, dann erscheint in der Ereignisliste ein Eintrag mit aktuellem formatiertem Datum.
                                  ! Bei Dir ist die Ereignisliste und die Ereignisse ein großes Skript.
                                  ! Ich habe das in ein Skript für die Liste getrennt und kann dann aus jedem beliebigen anderem Skript entscheiden, ob ein "Ereignis":
                                  ! - in die Ereignisliste
                                  ! - als Pushover
                                  ! - als Telegram
                                  ! - als Email
                                  ! - als sayit
                                  ! - im log
                                  ! - usw.
                                  ! ausgegeben werden soll.
                                  ! Für sayit gibt es dann z.B. auch ein globales sayit().[/i]
                                  • P
                                    P
                                    PrinzEisenherz1
                                    Wow, das ist echt super von Dir!
                                    Das hilft mir schonmal rießig weiter!
                                    Tausend Dank!
                                    • J
                                      J
                                      jensus11
                                      @ruhr70
                                      Könntest du dein globes Skript noch einstellen? Und ein Bsp. für ein anderes in dem Event mit Test enthalten ist?
                                      gruss
                                      • ruhr70R
                                        ruhr70R
                                        ruhr70
                                        @jensus11:
                                        @ruhr70
                                        gruss `
                                        das große globale Skript findest Du im Post #34 ;-)
                                        • J
                                          J
                                          jensus11
                                          Frohe Weihnachten, das Globale hatte ich jetzt auch schon gefunden gehabt.
                                          Hättest du noch ein Bsp.Script in dem ein Event geschrieben?
                                          Ich weiss nicht wie ich das in andere Scripte schreiben soll.
                                          84.2k
