  4. String in Tabelle darstellen
35 Beiträge 4 Kommentatoren 8.1k Aufrufe
  • ruhr70R Offline
    ruhr70R Offline
    ruhr70
    @dtp:
    "1:An:05:00 Aus:12:00 2:An:15:00 Aus:21:00 3:An:– Aus:-- 4:An:-- Aus:--" `
    Javascript:
    var str = "1:An:05:00 Aus:12:00 2:An:15:00 Aus:21:00 3:An:-- Aus:-- 4:An:-- Aus:--"; ! var idTabelle = "tabelle"; // Pfad des Datenpunkts ! // Datenpunktanlagen createState(idTabelle, "", { name: 'Zeitentabelle als JSON Objekt', desc: 'neue CCU2 Firmware verfügbar', type: 'string', unit: '', role: 'value' }); ! function strToJson(str) { str = str.split(/\d:An:| Aus:/); tabelle = []; ! for (i=1; i<=str.length-1; i=i+2) { //log(str[i] + " . " + str[i+1]); tabelle.push({ "An" : str[i], "Aus": str[i+1], }); } return JSON.stringify(tabelle); } ! function main() { setState(idTabelle,strToJson(str)); } ! setTimeout(main, 2000);
    ! Widget:
    ! >! [spoiler]~~[code]~~[{"tpl":"tplTableBody","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","static_value":"[{\"Title\": \"first\", \"Value\": 1, \"_Description\": \"Value1\"}, {\"Title\": \"second\", \"Value\": 2, \"_Description\": \"Value2\"}]","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"table_oid":"javascript.0.tabelle"},"style":{"left":"20px","top":"220px","width":"300px","height":"130px"},"widgetSet":"basic"}][/code][/spoiler]
    ! Der Datenpunkt im Widget gilt für die Javascript Instanz 0. ggf. anpassen.
    ! Wenn Du davor noch die Spalte mit 1...x haben willst, kann man das schnell anpassen.[/i][/i]
    • ruhr70R Offline
      ruhr70R Offline
      ruhr70
      Noch die Version mit der Nummerierung in Spalte 1.
      Nur die Zeile 22 kommt hinzu:
                  "Nr" :  Math.floor((i+2)/2),
      Das ganze Skript:
      var str = "1:An:05:00 Aus:12:00 2:An:15:00 Aus:21:00 3:An:-- Aus:-- 4:An:-- Aus:--"; ! var idTabelle = "tabelle"; // Pfad des Datenpunkts ! // Datenpunktanlagen createState(idTabelle, "", { name: 'Zeitentabelle als JSON Objekt', desc: 'neue CCU2 Firmware verfügbar', type: 'string', unit: '', role: 'value' }); ! function strToJson(str) { str = str.split(/\d:An:| Aus:/); tabelle = []; ! for (i=1; i<=str.length-1; i=i+2) { log(str[i] + " . " + str[i+1]); tabelle.push({ "Nr" : Math.floor((i+2)/2), "An" : str[i], "Aus": str[i+1], }); } return JSON.stringify(tabelle); } ! function main() { setState(idTabelle,strToJson(str)); } ! setTimeout(main, 2000);
      ! 327_tabelle_string_2.jpg [/i][/i]
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        @ruhr70:
        Das ganze Skript:
        ! `var str = "1:An:05:00 Aus:12:00 2:An:15:00 Aus:21:00 3:An:-- Aus:-- 4:An:-- Aus:--"; ! var idTabelle = "tabelle"; // Pfad des Datenpunkts ! // Datenpunktanlagen createState(idTabelle, "", { name: 'Zeitentabelle als JSON Objekt', desc: 'neue CCU2 Firmware verfügbar', type: 'string', unit: '', role: 'value' }); ! function strToJson(str) { str = str.split(/\d:An:| Aus:/); tabelle = []; ! for (i=1; i<=str.length-1; i=i+2) { log(str[i] + " . " + str[i+1]); tabelle.push({ "Nr" : Math.floor((i+2)/2), "An" : str[i], "Aus": str[i+1], }); } return JSON.stringify(tabelle); } ! function main() { setState(idTabelle,strToJson(str)); } ! setTimeout(main, 2000);` ! Tabelle String_2.jpg ! Genial danke dir, war zufaellig auch auf der suche wie man das vereinfacht hinbekommt.[/i][/i] `
        • ruhr70R Offline
          ruhr70R Offline
          ruhr70
          @Dutchman:
          war zufaellig auch auf der suche wie man das vereinfacht hinbekommt. `
          Worum geht es denn da? Sah nicht nach einer Sache aus, die mehrfach im Einsatz ist.
            dtp
            Hallo ruhr70,
            klasse. Das hilft mir sehr.
            Falls Du mich meintest, mit Deiner Frage, worum es geht. Nun, es handelt sich um Strings zur Zeiteinstellung meiner Viessmann Heizungsanlage, die mir von einem http://forum.iobroker.net/viewtopic.php?f=23&t=3048&start=60&sid=a9ab87c9cbb2300b0c3eb17cd87502c3&sid=a9ab87c9cbb2300b0c3eb17cd87502c3#p34424 geliefert werden. paul53 hat mir in dem entsprechenden Thread sehr unter die Arme gegriffen, und das Ganze läuft soweit auch sehr zufrieden stellend. Nun möchte ich aber noch die entsprechenden Timer darstellen und ggf. steuern.
            Der entsprechende View unter vis sieht folgendermaßen aus.
            Geplant ist nun, dass sich bei einem Klick auf "Betriebsart" ein Container-View öffnet, in dem die Tabellen angezeigt und ggf. geändert werden können.
            Gruß,
            Thorsten
              Brati
              @dtp
              Sowas ähnliches schreibe ich mir auch gerade. Vielleicht hilft dir dieser Thread
              http://forum.iobroker.net/viewtopic.php?f=21&t=3969
              Die Zeiten werden dabei in einem State gespeichert und daraus das Objekt für den jeweiligen Tag ausgelesen. In den System Einstellungen kann ich mir jeden Tag auswählen und editieren. Die Änderung wird dann wieder zurück in den State geschrieben, somit bin ich hier flexibel ohne jedesmal im Script Änderungen vollziehen zu müssen.
              Das sieht gerade so aus, bin aber noch am Testen (unten die Zeiten dienen nur der Kontrolle).
              @ruhr70
              Das Objekt ist im State wie folgt gespeichert…
              {"1":{"Kind1":{"wecken":true,"nachricht":0,"stunde":"6","minute":"30"},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"30"},"Optionen":{"KDienst":0,"Licht":150,"Option1":"","Option2":"","Option3":""}},"2":...
              Kann ich das direkt im JSON Widget einbinden oder muss das auch erst per JS umgewandelt werden. Ich würde nämlich auch gerne eine Tabelle daneben abbilden, um immer gleich alles zu sehen. Bei den Optionen müßte nur KDienst ausgeworfen werden und das Feld "nachricht" auch nicht. Vielleicht hilft ja nur ein Denkanstoss.
              Brati
                dtp
                bin schon mal etwas weiter gekommen. Vielen Dank für die Unterstützung.
                var idTabelle = "vis.VitotronicTimer"; // Pfad des Datenpunkts ! // Datenpunktanlagen createState(idTabelle, "", { name: 'vis.VitotronicTimer', desc: 'Vitotronic Timer-Tabelle als JSON-Objekt', type: 'string', unit: '', role: 'value' }); ! var str = []; function strToJson(str){ str = getState("javascript.0.Vitotronic.TimerMoHeizen").val; str = str.split(/\d:An:| Aus:/); tabelle = []; ! for(i=1; i<=str.length-1; i=i+2){ tabelle.push({ "Nr" : Math.floor((i+2)/2), "An" : str[i], "Aus": str[i+1], }); } return JSON.stringify(tabelle); } ! function main(){ setState(idTabelle,strToJson(str)); } ! setTimeout(main, 2000);
                ! Nun war das aber erst der Anfang und es ergeben sich neue Herausforderungen. Zum Einen bleibt es nicht bei diesem einen Datenstring. Vielmehr sind es insgesamt 21 (jeweils sieben (Mo, Di,..., So) für Heizen, Warmwasser und die Zirkulationspumpe), so dass die Tabelle letztlich so aussehen soll:
                ! Zum Anderen sollen sich die Tabellenwerte automatisch ändern, wenn sich die jeweiigen Datenpunkte ändern.
                ! Gruß,
                ! Thorsten[/i]
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  @Brati:
                  @ruhr70
                  Kann ich das direkt im JSON Widget einbinden oder muss das auch erst per JS umgewandelt werden. Ich würde nämlich auch gerne eine Tabelle daneben abbilden, um immer gleich alles zu sehen. Bei den Optionen müßte nur KDienst ausgeworfen werden und das Feld "nachricht" auch nicht. Vielleicht hilft ja nur ein Denkanstoss. `
                  Kannst Du das ganze JSON posten?
                  • ruhr70R Offline
                    ruhr70R Offline
                    ruhr70
                    @dtp:
                    ! Ich würde die Funktion allgemeingültig halten und str außerhalb der Funktion zuweisen. So macht die Übergabe von str keinen Sinn.
                    ! Die Funktion kannst Du dann auch für andere Datenpunkte verwenden.
                    ! Ungetesteter Code:
                    ! >! [spoiler]`~~[code]~~var idTabelle = "vis.VitotronicTimer"; // Pfad des Datenpunkts
                    ! // Datenpunktanlegen
                    type: 'string',
                    unit: '',
                    role: 'value'
                    ! function strToJson(str){
                    var tabelle = [];
                    tabelle.push({
                    "An" : str[i],
                    "Aus": str[i+1],
                    ! function main(){
                    var str = getState("javascript.0.Vitotronic.TimerMoHeizen").val;
                    ! setTimeout(main, 2000);! - str ist keine globale Variable mehr. ! - die Funktion strToJson bleibt vom Datenpunkt unabhängig. ! ~~[quote]~~ Nun war das aber erst der Anfang und es ergeben sich neue Herausforderungen. Zum Einen bleibt es nicht bei diesem einen Datenstring. Vielmehr sind es insgesamt 21 (jeweils sieben (Mo, Di,..., So) für Heizen, Warmwasser und die Zirkulationspumpe), so dass die Tabelle letztlich so aussehen soll: ! Du hast 21 Datenpunkte? ! Kannst Du die als Liste hier posten? ! ~~[quote]~~ Zum Anderen sollen sich die Tabellenwerte automatisch ändern, wenn sich die jeweiigen Datenpunkte ändern. ! Das kannst Du machen, indem Du auf Änderungen in den Datenpunkten reagierst -> on()[/i][/code][/spoiler][/i] ```
                      Brati
                      @ruhr70:
                      Kannst Du das ganze JSON posten? `
                      Das sieht so aus:
                      {"1":{"Kind1":{"wecken":true,"nachricht":0,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"2":{"Kind1":{"wecken":true,"nachricht":1,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"3":{"Kind1":{"wecken":true,"nachricht":1,"stunde":"6","minute":"30","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"30"},"Optionen":{"KDienst":0,"Licht":"25","Option1":"","Option2":"","Option3":""}},"4":{"Kind1":{"wecken":true,"nachricht":0,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"5":{"Kind1":{"wecken":false,"nachricht":0,"stunde":"9","minute":"30"},"Kind2":{"wecken":false,"nachricht":"","stunde":"9","minute":"30"},"Optionen":{"KDienst":2,"Licht":"25","Option1":"","Option2":"","Option3":""}},"6":{"Kind1":{"wecken":false,"nachricht":2,"stunde":"9","minute":"30"},"Kind2":{"wecken":false,"nachricht":"","stunde":"9","minute":"30"},"Optionen":{"KDienst":2,"Licht":"25","Option1":"","Option2":"","Option3":""}},"7":{"Kind1":{"wecken":true,"nachricht":2,"stunde":"6","minute":"30"},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"30"},"Optionen":{"KDienst":0,"Licht":"25","Option1":"","Option2":"","Option3":""}}}
                      Die Tabelle soll aber nur Uhrzeit pro Kind und aktiv und oder nicht und KDienst enthalten.
                      Also
                      …...Kind 1....aktiv....Kind 2....aktiv....KDienst
                      Mo 6 : 30.....x.... 6:30 ..... .... 0
                      Di 6 : 25.......... 6:25 .... x
                      usw.
                      Dazu eine Hilfe wäre toll, alle meine Versuche verliefen absolut negativ :(, hab aber auch keine Ahnung davon.
                      Brati
                      • ruhr70R Offline
                        ruhr70R Offline
                        ruhr70
                        @Brati:
                        @ruhr70:
                        Das sieht so aus:
                        Also
                        usw.
                        Dazu eine Hilfe wäre toll, alle meine Versuche verliefen absolut negativ :(, hab aber auch keine Ahnung davon. `
                        Ich würde die Tabelle per Skript umbauen. Ich schau mal, ob ich das vor dem Wochenende hinbekomme.
                        [{"Tag":"Mo","Kind_1":"6:30","aktiv_1":"x","Kind_2":"6:30","aktiv_2":""},{"Tag":"Di","Kind_1":"6:25","aktiv_1":"","Kind_2":"6:25","aktiv_2":"x"}]
                        So würde die Tabelle dann im JSON-Widget aussehen:
                        KDienst ist einmal bei Kind 1 drin, bei Kind 2 nicht und dann wieder unter Optionen.
                        Welcher Punkt ist denn gemeint?
                          dtp
                          @ruhr70:
                          Ungetesteter Code:
                          • str ist keine globale Variable mehr.
                          • die Funktion strToJson bleibt vom Datenpunkt unabhängig. `
                          Danke für die Hinweise und Deinen Code. Werde ich heute Abend mal testen.
                          @ruhr70:
                          Kannst Du die als Liste hier posten? `
                          Sehr gerne:
                          Allen Datenpunkten steht ein "javascript.0.Vitotronic." voran. Dann heißen sie:
                          'TimerMoHeizen','TimerDiHeizen','TimerMiHeizen','TimerDoHeizen','TimerFrHeizen','TimerSaHeizen','TimerSoHeizen','TimerMoWW','TimerDiWW','TimerMiWW','TimerDoWW','TimerFrWW','TimerSaWW','TimerSoWW','TimerMoPumpeZirku','TimerDiPumpeZirku','TimerMiPumpeZirku','TimerDoPumpeZirku','TimerFrPumpeZirku','TimerSaPumpeZirku','TimerSoPumpeZirku'
                          Der inhaltliche Struktur aller Datenpunkte ist identisch.
                          Hier mal das Skript (mit nochmaligem Dank an paul53), mit dem ich sie befülle:
                          `// Werte aus Vitotronic auslesen
                          ! var list1 = ['Betriebsart','BetriebsartHK','BetriebParty','BetriebSpar','TempAussen','TempWWIst','TempSpeicher','TempWWAuslauf','TempKesselIst','TempRLIst','TempRaumHK','TempSolarkol','TempSolarspeicher','StatusPumpeSpeicher','StatusFlamme','StatusPumpeIntern','DrehzahlPumpeIntern','StatusPumpeHK','StatusPumpeZirku','StatusUmschaltventil','Systemzeit'];
                          var list2 = ['BetriebFerien','BeginnFerien','EndeFerien','TempRaumNorSoll','TempRaumRedSoll','TempPartySoll','TempWWSoll','TempKesselSoll','TempVLSoll','KennlinieNeigung','KennlinieNiveau','LaufzeitBrenner','StartsBrenner','LaufzeitSolar','LeistungSolar','ErtragTagSolar'];
                          var list3 = ['StatusStoerung','Stoerung1','Stoerung2','Stoerung3','Stoerung4','Stoerung5','Stoerung6','Stoerung7','Stoerung8','Stoerung9','Stoerung10','Anlagenschema'];
                          var list4 = ['TimerMoHeizen','TimerDiHeizen','TimerMiHeizen','TimerDoHeizen','TimerFrHeizen','TimerSaHeizen','TimerSoHeizen','TimerMoWW','TimerDiWW','TimerMiWW','TimerDoWW','TimerFrWW','TimerSaWW','TimerSoWW','TimerMoPumpeZirku','TimerDiPumpeZirku','TimerMiPumpeZirku','TimerDoPumpeZirku','TimerFrPumpeZirku','TimerSaPumpeZirku','TimerSoPumpeZirku'];
                          ! // Objekte setzen
                          function init(list) {
                          var len = list.length;
                          var cmds = '';
                          for(var i = 0; i < len; i++) {
                          cmds = cmds + ',getVito' + list[i];
                          createState('Vitotronic.' + list[i], '', {
                          type: 'string',
                          read: true,
                          write: true,
                          desc: 'Vitotronic ' + list[i],
                          def: ''
                          return cmds.substr(1); // erstes Komma löschen
                          ! // Skript starten
                          var cmds1 = init(list1);
                          var cmds2 = init(list2);
                          var cmds3 = init(list3);
                          var cmds4 = init(list4);
                          ! function vito(cmds, list, timer) {
                          exec('vclient -h 127.0.0.1:3002 -c ' + cmds, function(err, stdout, stderr) {
                          if (err) {
                          log(stderr,'error');
                          return;
                          stdout = stdout.split("\n");
                          if(timer) setState("javascript."+ instance + ".Vitotronic." + list[i], stdout[5 * i + 1]+" "+stdout[5 * i + 2]+" "+stdout[5 * i + 3]+" "+stdout[5 * i + 4]);
                          else setState("javascript."+ instance + ".Vitotronic." + list[i], stdout[2 * i + 1]);
                          ! // Zeitintervalle definieren
                          setInterval(function() {
                          vito(cmds1, list1, false);
                          }, 180 * 1000); // alle 3 Minuten
                          vito(cmds2, list2, false);
                          }, 1800 * 1000); // alle 30 Minuten
                          ! setInterval(function() {
                          vito(cmds3, list3, false);
                          }, 3600 * 1000); // alle 60 Minuten
                          vito(cmds4, list4, true);
                          }, 7200 * 1000); // alle 120 Minuten! ~~[quote]~~ Das kannst Du machen, indem Du auf Änderungen in den Datenpunkten reagierst -> on() `
                          ! Jepp. Hatte mich nur gefragt, ob ich das in einem separaten Skript oder gleich in dem oben geposteten Skript zum Schreiben der Datenpunkte mache. Aber ich denke, ein separates Skript ist übersichtlicher.
                          ! Nochmals vielen, vielen Dank für Deine tolle Unterstützung.
                          ! Gruß,
                          ! Thorsten[/i][/i][/i][/i][/i]
                            dtp
                            @Brati:
                            @dtp
                            Sowas ähnliches schreibe ich mir auch gerade. Vielleicht hilft dir dieser Thread `
                            Danke Brati, das schaue ich mir mal näher an. Das mit den Pulldown-Menüs zum Ändern der Datenpunkte habe ich auch noch vor. Wird aber dann wohl erst im zweiten Schritt realisiert.
                            Gruß,
                            Thorsten
                              Brati
                              @dtp
                              Ich werde dort im Thread noch die Lösung vorstellen. Das Pulldown Menü dient gleich als Trigger um die jeweiligen Werte aus dem Objekt zu lesen. Wenn man eine Tabelle editieren wollte, bräuchte man sonst X Input Widgets mit State dahinter.
                              Mein Windows PC hat nur das letzte Win10 Update nicht überlebt :( ahhhrg Bootschleife…
                              Grüße Brati
                              von unterwegs gesendet.
                                Brati
                                @ruhr70:
                                Welcher Punkt ist denn gemeint? `
                                Das sieht schon mal sehr genial aus. KDienst ist unter Optionen gemeint und hatte folgende Bedeutung
                                (wer bringt die Kinder weg, also "KinderDienst")
                                0 = M(uddi)
                                1 = V(addi)
                                2 = n(iemand)
                                Bei Kind1 ist noch ein Fehler aus der Findungsphase :).
                                Danke.
                                • ruhr70R Offline
                                  ruhr70R Offline
                                  ruhr70
                                  @Brati:
                                  0 = M(uddi)
                                  1 = V(addi)
                                  2 = n(iemand)
                                  Danke. `
                                  Anbei Deine umgebaute Tabelle:
                                  Und das Skript dazu:
                                  ! var myJson = {"1":{"Kind1":{"wecken":true,"nachricht":0,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"2":{"Kind1":{"wecken":true,"nachricht":1,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"3":{"Kind1":{"wecken":true,"nachricht":1,"stunde":"6","minute":"30","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"30"},"Optionen":{"KDienst":0,"Licht":"25","Option1":"","Option2":"","Option3":""}},"4":{"Kind1":{"wecken":true,"nachricht":0,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"5":{"Kind1":{"wecken":false,"nachricht":0,"stunde":"9","minute":"30"},"Kind2":{"wecken":false,"nachricht":"","stunde":"9","minute":"30"},"Optionen":{"KDienst":2,"Licht":"25","Option1":"","Option2":"","Option3":""}},"6":{"Kind1":{"wecken":false,"nachricht":2,"stunde":"9","minute":"30"},"Kind2":{"wecken":false,"nachricht":"","stunde":"9","minute":"30"},"Optionen":{"KDienst":2,"Licht":"25","Option1":"","Option2":"","Option3":""}},"7":{"Kind1":{"wecken":true,"nachricht":2,"stunde":"6","minute":"30"},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"30"},"Optionen":{"KDienst":0,"Licht":"25","Option1":"","Option2":"","Option3":""}}}; ! var idKdienst = "Kinderdienst"; ! createState(idKdienst, "", { name: 'Kinderdienst JSON für VIS Widget', desc: 'Kinderdienst JSON für VIS Widget', type: 'string', role: 'value', unit: '' }); ! function setX (aktivBool) { return (aktivBool) ? "x" : ""; } ! function setKDienst (str) { var kDienst = {"0":"Muddi","1":"Vaddi","2":"---"}; return kDienst[str]; } ! function fillStr(n, str) { // liefere Anzahl n nbsp in utf-8, wenn str nicht angegeben oder n-mal str var fill = ""; for (var i = 0; i < n; ++i) { fill += ((!str) ? " " : str); //   als utf-8 Code (Mac: alt+Leerzeichen) } return fill; } ! function fillTime(stundeStr,minuteStr) { // baut den Zeitstring und füllt Stunde und Minute auf zweistellig auf return fillStr(2 - stundeStr.length,"0") + stundeStr + ":" + fillStr(2 - minuteStr.length,"0") + minuteStr; } ! function buildJson() { var tabelle = []; var tempJson ={}; var woTag = ["Mo","Di","Mi","Do","Fr","Sa","So"]; for (var i = 1; i <= 7; i++) { tempJson = myJson[(i).toString()]; tabelle.push({ "Tag" : woTag[i-1], "Kind1" : fillTime(tempJson.Kind1.stunde,tempJson.Kind1.minute), "aktiv1" : setX(tempJson.Kind1.wecken), "Kind2" : fillTime(tempJson.Kind2.stunde,tempJson.Kind2.minute), "aktiv2" : setX(tempJson.Kind2.wecken), "KDienst" : setKDienst(tempJson.Optionen.KDienst) }); } return tabelle; } ! function main () { log(JSON.stringify(buildJson())); setState("javascript." + instance + "." + idKdienst,JSON.stringify(buildJson())); } ! // Beim Skriptstart JSON-Tabelle für VIS Widget erstellen setTimeout(main,2000); !
                                    Brati
                                    @Ruhr70
                                    Tausend Dank, so sieht es aus:
                                    Brati
                                    • ruhr70R Offline
                                      ruhr70R Offline
                                      ruhr70
                                      @Barti: super! Sieht gut aus. Danke für die Rückmeldung.
                                      Ich hatte mir schon gedacht, dass die Tage mit 09:30 Samstag und Sonntag sind.
                                      Ich konnte dem JSON diese Logik allerdings nicht entlocken ;-)
                                      Denkfeher mit 1-7 = Mo-So oder war im Skript ein Fehler?
                                        Brati
                                        Na weil ich ja heute immer für morgen einlese ist 7= Montag und 1= Dienstag. Aber ein bisschen muss ich ja auch noch denken, hab eine Hilfsvariable eingebaut ;). Ich werde in einer ruhigen Minute auch mal versuchen zu verstehen, wie das mit den Json Tabellen funktioniert, sieht eigentlich logisch aus.
                                        Gesendet von iPad mit Tapatalk
                                          dtp
                                          So,
                                          habe mich zwischenzeitlich etwas versucht und bin auch weiter gekommen. Allerdings noch nicht so richtig. Hier der status quo:
                                          `// Beispiel-Format Timer: "1:An:05:00 Aus:12:00 2:An:15:00 Aus:21:00 3:An:-- Aus:-- 4:An:-- Aus:--"
                                          var list = ['TimerMoHeizen','TimerDiHeizen','TimerMiHeizen','TimerDoHeizen','TimerFrHeizen','TimerSaHeizen','TimerSoHeizen'];
                                          var idTable = "vis.VitotronicTimer"; // Pfad des Datenpunkts
                                          createState(idTable, "", {
                                          desc: 'Vitotronic Timer-Tabelle als JSON-Objekt für vis Widget',
                                          type: 'string',
                                          unit: '',
                                          role: 'value'
                                          var table = [];
                                          table.push({
                                          "An" : str[i],
                                          "Aus": str[i+1],
                                          return JSON.stringify(table);
                                          function main(list){
                                          str = '';
                                          for(var i=0; i<list.length; 20/i++)/str="str+getState("javascript."+instance+".Vitotronic."+list[i]).val;" setstate(idtable,strtojson(str));/}/setinterval(function(){/main(list);/},/*/1000);<e=""></list.length;>`
                                          ! Und hier die zugehörige Tabelle im Widget:
                                          ! Fragen:
                                          ! 1. Wie erreiche ich eine Modulo-4-Zählweise der Zeilen?
                                          ! 2. Wie binde ich jetzt noch die übrigen Timer-Spalten ein?
                                          ! 3. Kann ich auch über mehrere Zeilen bzw. Spalten verbundene Zeilen bzw. Spalten erstellen für die Wochentage und die Timerbeschreibungen?
                                          ! Gruß,
                                          ! Thorsten[/i][/i]
