  3. Entwicklung
  4. [Neuer Adapter] Xiaomi Luftfilter
188 Beiträge 38 Kommentatoren 49.6k Aufrufe 28 Beobachtet
  • M moeff
    @Ente im miio sieht es bei mir so aus
    @JensA https://github.com/JoJ123/ioBroker.mihome-airpurifier ist der alte Adapter, hier habe ich nur die Vorgängerversionen der Xiaomi Purifier zur Auswahl - der Adapter startet zwar, sagt aber Unknown Purifier Version
    der Adapter von dontobi - https://github.com/dontobi/ioBroker.mihome-airpurifier Startet leider bei mir nicht - sondern bleibt mit hängen:
    host.iobroker	2020-12-25 02:16:31.218	error	instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/devices/air-purifier.js:11:18)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: SyntaxError: Unexpected token =
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: ^
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: fs1 = -1;
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/devices/capabilities/fan-speed.js:7
    dontobiD Offline
    dontobiD Offline
    dontobi
    #125
    @moeff in deiner Fehlermeldung steht auch woran es liegt, nämlich am Token. Ich pushe im Laufe der Woche eine neue Version, die lediglich die 2er Serie unterstützt. Dann ist wenigstens eine stabile Version online.
    Smart Home Zentrale: Raspberry Pi 4 4GB
    Meine Homepage: https://www.myHome.zone
    • M moeff
      JensA
      #126
      @moeff
      Aha, dann war ich also mit den git Links durcheinander gekommen. Der Adapter von dontobi - https://github.com/dontobi/ioBroker.mihome-airpurifier (0.2.1) startet bei mir ohne Probleme. Beim Abspeichern der Konfiguration bekomme ich folgende Meldung: "Einige Daten wurden nicht gespeichert. Verwerfen?" Er scheint sich aber die Daten doch zu merken, zumindest sind sie beim erneuten Aufrufen der Konfiguration vollständig:
      Ich bekomme aber den Kontakt zum 2H nicht hin. Das Log sieht folgendermaßen aus:
      Kann ich beim Auslesen des Token über den vacuum adapter was falsch gemacht haben? (mehrfach gecheckt, keine Leerzeichen am Ende etc.)
      Ist vielleicht meine H2 Firmware nicht kompatibel?
      dontobiD 1 Antwort Letzte Antwort
      • J JensA
        @moeff
        dontobiD Offline
        dontobiD Offline
        dontobi
        #127
        @JensA stell den Adapter bitte Mal auf debug und starte ihn neu. Anschließend poste hier Mal das Log, dann sollten wir mehr wissen.
        • dontobiD dontobi
          JensA
          #128
          @dontobi
          Hier wie gewünscht:
          • J JensA
            @dontobi
            Hier wie gewünscht:
            dontobiD Offline
            dontobiD Offline
            dontobi
            #129
            @JensA an dem Token liegt es wahrscheinlich nicht. Ist die IP richtig?
            • dontobiD dontobi
              JensA
              #130
              @dontobi
              Ja, die IP stimmt. Die Daten aus dem vacuum adapter sehen so aus:
              • dasquiddiD Offline
                dasquiddiD Offline
                dasquiddi
                #131
                Konnte mein Problem mit dem Wechsel von Node-v10 auf v12 lösen. Habe damit erfolgreich die Verbindung zu meinem 2H herstellen können und erhalte korrekte Daten davon.
                Meinen Token konnte ich nur mittels Tool von der HomeAssistant Seite über die Cloud auslesen. Link
                Der Weg über "miio discover" ergab nur ??? beim Token.
                • dasquiddiD dasquiddi
                  #132
                  @dasquiddi
                  Ein upgrade auf die gerade empfohlene node-Version ist immer eine gute Idee. (Hätte fast von mir sein können... :-) )
                  Die xiaomi-Token kann man übrigens auch über den ioBroker-Adapter für die Staubsauger auslesen.
                    @dasquiddi
                    dontobiD Offline
                    dontobiD Offline
                    dontobi
                    #133
                    Nachdem ich eben die Version 0.2.2 pushen wollte, ist irgend etwas schief gegangen. Auch ein Rebase von miio hat nichts gebracht. Daher habe ich mir gerade den ioBroker.miio Adapter angesehen. Dieser ist besser dokumentiert und ich werde diesen nun weiter verwenden und auch an der Entwicklung teilnehmen. Daher werde ich die Repos löschen.
                    • dontobiD dontobi
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #134
                      @dontobi das klingt nach......es könnte demnächst auch mit dem H3 klappen😇
                        dontobiD Offline
                        dontobiD Offline
                        dontobi
                        #135
                        @crunchip ich werde es versuchen. Brauche da aber jemanden, der einen 3 oder 3h hat.
                        crunchipC S 2 Antworten Letzte Antwort
                        • dontobiD dontobi
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #136
                          @dontobi hab ich, mio adapter läuft auch, hatte ich installiert, wegen den phillips zhirui downlights.
                          Datenpunkte sind vorhanden/angelegt jedoch keine Verbindung
                          • dontobiD dontobi
                            SaiBot1981
                            schrieb am zuletzt editiert von SaiBot1981
                            #137
                            @dontobi sagte in [Neuer Adapter] Xiaomi Luftfilter:
                            Ich hab den adapter auch installiert. Genau wie bei Crunship sind bei mir die datenpunkte nicht gefüllt. die verbindung ist jedoch da. Ich hab den 3H.
                            • dontobiD dontobi
                              moeff
                              #138
                              @dontobi said in [Neuer Adapter] Xiaomi Luftfilter:
                              Der/das Token ist korrekt gesetzt. Der Fehler bleibt. Der/das Token wurde per vacuum adapter ausgelesen und sogar nochmal händisch gecheckt. Ebenfalls habe ich im miio mit dem Token keine Probleme den 2H zu verbinden.
                                dontobiD Offline
                                dontobiD Offline
                                dontobi
                                #139
                                @crunchip ich kann mir auch schon vorstellen woran das liegt. Bin gerade dabei den Adapter zu verstehen und zu erweitern. Melde mich, wenn ich was zum testen habe.
                                • dontobiD Offline
                                  dontobiD Offline
                                  dontobi
                                  #140
                                  Ich habe meine eigene Version des ioBroker.miio Adapters seit ein paar Stunden im Einsatz. Wer den Mal testen möchte, kann sich gerne bei mir per PM melden.
                                  M crunchipC 2 Antworten Letzte Antwort
                                  • dontobiD dontobi
                                    moeff
                                    schrieb am zuletzt editiert von moeff
                                    #141
                                    @dontobi
                                    https://github.com/dontobi/ioBroker.miio ?
                                    Was ist der Unterschied? Der 2H funktioniert mit dem originalen alten miio Adapter perfekt, hab damit ein paar Routinen und kann auch mit Alexa nun mehr als nur ein/aus wie mit dem Xiaomi Home Skill steuern
                                    • M moeff
                                      @dontobi
                                      dontobiD Offline
                                      dontobiD Offline
                                      dontobi
                                      #142
                                      @moeff du kannst den alten noch verwenden. Jedoch werde ich in den alten keine Energie mehr stecken, denn ganz schlau wurde ich bis zum Schluss nicht.
                                      • dontobiD dontobi
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #143
                                        gibts auch was zu testen mit dem 3H
                                        • crunchipC Abwesend
                                          crunchipC Abwesend
                                          #144
                                          @dontobi hab mal installiert
                                          debuglog
                                          miio.0	2021-01-24 20:07:47.018	debug	(17411) system.adapter.admin.0: logging true
                                          miio.0	2021-01-24 20:07:27.543	debug	(17411) system.adapter.admin.0: logging false
                                          miio.0	2021-01-24 20:06:55.318	info	(17411) 308331024 becomes unavailable.
                                          miio.0	2021-01-24 20:06:14.659	info	(17411) discover stoped after 10 seconds.
                                          miio.0	2021-01-24 20:06:06.275	debug	(17411) system.adapter.admin.0: logging true
                                          miio.0	2021-01-24 20:06:04.862	info	(17411) 84022681 token is hide
                                          miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.purifyVolume
                                          miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.usedTime
                                          miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.Temperature
                                          miio.0	2021-01-24 20:06:04.690	info	(17411) Create state object devices.308331024.humidity
                                          miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.averageAqi
                                          miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.motor1Speed
                                          miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.filterUsedTime
                                          miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.filterLife
                                          miio.0	2021-01-24 20:06:04.689	info	(17411) Create state object devices.308331024.aqi
                                          miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.learnSleepMode
                                          miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.favoriteLevel
                                          miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.ledBrightnessLevel
                                          miio.0	2021-01-24 20:06:04.688	info	(17411) Create state object devices.308331024.buzzer
                                          miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.childLock
                                          miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.led
                                          miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.mode
                                          miio.0	2021-01-24 20:06:04.687	info	(17411) Create state object devices.308331024.power
                                          miio.0	2021-01-24 20:06:04.686	info	(17411) Create state object devices.308331024.model
                                          miio.0	2021-01-24 20:06:04.686	info	(17411) Create state object devices.308331024.connected
                                          miio.0	2021-01-24 20:06:04.684	info	(17411) New device: zhimi.airpurifier.mb3. ID 308331024
                                          miio.0	2021-01-24 20:06:04.680	debug	(17411) Adapter init done!!!!!!
                                          miio.0	2021-01-24 20:06:04.669	info	(17411) new zhimi.airpurifier.mb device
                                          miio.0	2021-01-24 20:06:04.655	info	(17411) Start auto discover
                                          miio.0	2021-01-24 20:06:04.655	info	(17411) All defined devices are created
                                          miio.0	2021-01-24 20:06:04.653	info	(17411) 10.1.1.92 added.
                                          miio.0	2021-01-24 20:06:04.522	warn	(17411) 192.168.178.78 can not be connected.Error: Could not connect to device, handshake timeout
                                          miio.0	2021-01-24 20:06:02.207	info	(17411) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.miio, node: v12.20.1, js-controller: 3.2.10
                                          miio.0	2021-01-24 20:06:01.810	debug	(17411) statesDB connected
                                          miio.0	2021-01-24 20:06:01.809	debug	(17411) States connected to redis: 127.0.0.1:6379
                                          miio.0	2021-01-24 20:06:01.800	debug	(17411) States create User PubSub Client
                                          miio.0	2021-01-24 20:06:01.799	debug	(17411) States create System PubSub Client
                                          miio.0	2021-01-24 20:06:01.790	debug	(17411) Redis States: Use Redis connection: 127.0.0.1:6379
                                          miio.0	2021-01-24 20:06:01.788	debug	(17411) objectDB connected
                                          miio.0	2021-01-24 20:06:01.780	debug	(17411) Objects connected to redis: 127.0.0.1:9001
                                          miio.0	2021-01-24 20:06:01.736	debug	(17411) Objects client initialize lua scripts
                                          miio.0	2021-01-24 20:06:01.735	debug	(17411) Objects create User PubSub Client
                                          miio.0	2021-01-24 20:06:01.734	debug	(17411) Objects create System PubSub Client
                                          miio.0	2021-01-24 20:06:01.732	debug	(17411) Objects client ready ... initialize now
                                          miio.0	2021-01-24 20:06:01.682	debug	(17411) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          miio.0	2021-01-24 20:05:57.756	error	(17383) Network communication is unavailable, device might be destroyed
                                          miio.0	2021-01-24 20:05:57.756	error	at processTimers (internal/timers.js:497:7)
                                          miio.0	2021-01-24 20:05:57.756	error	at listOnTimeout (internal/timers.js:554:17)
                                          miio.0	2021-01-24 20:05:57.756	error	at Timeout._onTimeout (/opt/iobroker/node_modules/miio-lite/lib/network.js:52:9)
                                          miio.0	2021-01-24 20:05:57.756	error	at Network.get socket [as socket] (/opt/iobroker/node_modules/miio-lite/lib/network.js:229:10)
                                          miio.0	2021-01-24 20:05:57.756	error	(17383) Error: Network communication is unavailable, device might be destroyed
                                          miio.0	2021-01-24 20:05:57.755	error	(17383) uncaught exception: Network communication is unavailable, device might be destroyed
                                          miio.0	2021-01-24 20:05:57.325	info	(17383) 308331024 becomes unavailable.
                                          miio.0	2021-01-24 20:05:57.323	info	(17383) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          miio.0	2021-01-24 20:05:57.323	info	(17383) terminating
                                          miio.0	2021-01-24 20:05:57.322	info	(17383) cleaned everything up...
                                          miio.0	2021-01-24 20:05:57.321	info	(17383) Got terminate signal TERMINATE_YOURSELF
                                          miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.purifyVolume
                                          miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.usedTime
                                          miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.Temperature
                                          miio.0	2021-01-24 20:05:57.266	info	(17383) Create state object devices.308331024.humidity
                                          miio.0	2021-01-24 20:05:57.265	info	(17383) Create state object devices.308331024.averageAqi
                                          miio.0	2021-01-24 20:05:57.265	info	(17383) Create state object devices.308331024.motor1Speed
                                          miio.0	2021-01-24 20:05:57.265	info	(17383) Create state object devices.308331024.filterUsedTime
                                          miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.filterLife
                                          miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.aqi
                                          miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.learnSleepMode
                                          miio.0	2021-01-24 20:05:57.264	info	(17383) Create state object devices.308331024.favoriteLevel
                                          miio.0	2021-01-24 20:05:57.263	info	(17383) Create state object devices.308331024.ledBrightnessLevel
                                          miio.0	2021-01-24 20:05:57.263	info	(17383) Create state object devices.308331024.buzzer
                                          miio.0	2021-01-24 20:05:57.263	info	(17383) Create state object devices.308331024.childLock
                                          miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.led
                                          miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.mode
                                          miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.power
                                          miio.0	2021-01-24 20:05:57.262	info	(17383) Create state object devices.308331024.model
                                          miio.0	2021-01-24 20:05:57.261	info	(17383) Create state object devices.308331024.connected
                                          miio.0	2021-01-24 20:05:57.258	info	(17383) Update Device Purifier_H3's config: ip = 10.1.1.92, polling = 5000, id = 308331024
                                          miio.0	2021-01-24 20:05:57.257	info	(17383) New device: zhimi.airpurifier.mb3. ID 308331024
                                          miio.0	2021-01-24 20:05:57.250	debug	(17383) Adapter init done!!!!!!
                                          miio.0	2021-01-24 20:05:57.237	info	(17383) new zhimi.airpurifier.mb device
                                          miio.0	2021-01-24 20:05:57.218	info	(17383) Start auto discover
                                          miio.0	2021-01-24 20:05:57.218	info	(17383) All defined devices are created
                                          miio.0	2021-01-24 20:05:57.215	info	(17383) 10.1.1.92 added.
                                          miio.0	2021-01-24 20:05:57.075	warn	(17383) 192.168.178.78 can not be connected.Error: Could not connect to device, handshake timeout
                                          miio.0	2021-01-24 20:05:54.847	info	(17383) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.miio, node: v12.20.1, js-controller: 3.2.10
                                          miio.0	2021-01-24 20:05:54.457	debug	(17383) statesDB connected
                                          miio.0	2021-01-24 20:05:54.456	debug	(17383) States connected to redis: 127.0.0.1:6379
                                          miio.0	2021-01-24 20:05:54.451	debug	(17383) States create User PubSub Client
                                          miio.0	2021-01-24 20:05:54.450	debug	(17383) States create System PubSub Client
                                          miio.0	2021-01-24 20:05:54.445	debug	(17383) Redis States: Use Redis connection: 127.0.0.1:6379
                                          miio.0	2021-01-24 20:05:54.443	debug	(17383) objectDB connected
                                          miio.0	2021-01-24 20:05:54.437	debug	(17383) Objects connected to redis: 127.0.0.1:9001
                                          miio.0	2021-01-24 20:05:54.399	debug	(17383) Objects client initialize lua scripts
                                          miio.0	2021-01-24 20:05:54.398	debug	(17383) Objects create User PubSub Client
                                          miio.0	2021-01-24 20:05:54.397	debug	(17383) Objects create System PubSub Client
                                          miio.0	2021-01-24 20:05:54.396	debug	(17383) Objects client ready ... initialize now
                                          miio.0	2021-01-24 20:05:54.347	debug	(17383) Redis Objects: Use Redis connection: 127.0.0.1:9001
